    4. RPI-Monitor und GPIO rpi2 v2.3.1
    • Torsten Lehmann
      Torsten Lehmann @Thomas Braun last edited by Homoran
      @thomas-braun neue SD ohne Backup zurücksetzen.
      added 5 packages in 4m
      91 packages are looking for funding
        run `npm fund` for details
      upload [13] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/de/translations.json i18n/de/translations.json application/json
      upload [12] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/en/translations.json i18n/en/translations.json application/json
      upload [11] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/es/translations.json i18n/es/translations.json application/json
      upload [10] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      upload [9] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/it/translations.json i18n/it/translations.json application/json
      upload [8] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      upload [7] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      upload [6] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      upload [5] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      upload [4] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
      upload [3] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      upload [2] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/jsonConfig.json jsonConfig.json application/json
      upload [1] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/rpi2.png rpi2.png image/png
      upload [0] rpi2.admin /opt/iobroker/node_modules/iobroker.rpi2/admin/words.js words.js application/javascript
      Updating objects from io-package.json for adapter "rpi2" with version "2.4.0"
      MOD-EDIT: Code in code-tags gesetzt
        Thomas Braun Most Active @Torsten Lehmann last edited by
        @torsten-lehmann
        Setz sowas bitte in </> Codetags. Und die ersten Zeilen fehlen.
        Torsten Lehmann 1 Reply Last reply Reply Quote 0
        • Torsten Lehmann
          @thomas-braun Guten Morgen nach erfolgreicher Installation rpi2 fehlt jedoch beim iobroker die rpi2 Instanz. Irgendwie mach ich wohl was falsch bei der iobroker Installation.
            @torsten-lehmann sagte in RPI-Monitor und GPIO rpi2 v2.3.1:
            Nein, wenn Adapter via GitHub installiert werden muss die Instanz manuell hinzugefügt werden.
            • Torsten Lehmann
              @thomas-braun said in RPI-Monitor und GPIO rpi2 v2.3.1:
              da bin ich überfordert. Entschuldige, Wie mache ich das?
                @torsten-lehmann
                Mit dem PlusZeichen-Icon.
                Steht auch 'Instanz hinzufügen' dran, wenn ich mich recht entsinne.
                  Homoran Global Moderator Administrators @Torsten Lehmann last edited by
                  Wie mache ich das?
                  https://www.iobroker.net/#de/documentation/tutorial/adapter.md
                  sogar mit Filmchen
                  • Torsten Lehmann
                    Torsten Lehmann last edited by Torsten Lehmann
                    @thomas-braun weiterhin viele Warn und Error.
                    Notice #797?
                    pi@raspberrypi:~ $ iobroker url https://github.com/Grothesk242/ioBroker.rpi2.git --host raspberrypi --debug
                    install Grothesk242/ioBroker.rpi2#c87e9539d89bac8f4d19b266679bcb78ed554f1d
                    NPM version: 10.9.3
                    Installing Grothesk242/ioBroker.rpi2#c87e9539d89bac8f4d19b266679bcb78ed554f1d... (System call)
                    npm warn skipping integrity check for git dependency ssh://git@github.com/Grothesk242/ioBroker.rpi2.git
                    npm warn deprecated npmlog@4.1.2: This package is no longer supported.
                    npm warn deprecated are-we-there-yet@1.1.7: This package is no longer supported.
                    npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
                    npm warn deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
                    npm warn deprecated gauge@2.7.4: This package is no longer supported.
                    > iobroker.rpi2@2.4.0 preinstall
                    > sudo apt-get install -y libgpiod-dev || exit 0
                    Reading package lists...
                    Building dependency tree...
                    Reading state information...
                    libgpiod-dev is already the newest version (2.2.1-2).
                    The following package was automatically installed and is no longer required:
                      libyuv0
                    Use 'sudo apt autoremove' to remove it.
                    0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                    > @stoprocent/noble@1.19.1 install
                    > node-gyp-build
                    gyp info it worked if it ends with ok
                    gyp info using node-gyp@8.4.1
                    gyp info using node@22.20.0 | linux | arm64
                    (node:12953) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
                    (Use `node --trace-deprecation ...` to show where the warning was created)
                    gyp info find Python using Python version 3.13.5 found at "/usr/bin/python3"
                    gyp info spawn /usr/bin/python3
                    gyp info spawn args [
                    gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py',
                    gyp info spawn args   'binding.gyp',
                    gyp info spawn args   '-f',
                    gyp info spawn args   'make',
                    gyp info spawn args   '-I',
                    gyp info spawn args   '/opt/iobroker/node_modules/@stoprocent/noble/build/config.gypi',
                    gyp info spawn args   '/opt/iobroker/node_modules/node-gyp/addon.gypi',
                    gyp info spawn args   '/home/iobroker/.cache/node-gyp/22.20.0/include/node/common.gypi',
                    gyp info spawn args   '-Dlibrary=shared_library',
                    gyp info spawn args   '-Dvisibility=default',
                    gyp info spawn args   '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/22.20.0',
                    gyp info spawn args   '-Dnode_gyp_dir=/opt/iobroker/node_modules/node-gyp',
                    gyp info spawn args   '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/22.20.0/<(target_arch)/node.lib',
                    gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/@stoprocent/noble',
                    gyp info spawn args   '-Dnode_engine=v8',
                    gyp info spawn args   '--depth=.',
                    gyp info spawn args   '--no-parallel',
                    gyp info spawn args   '--generator-output',
                    gyp info spawn args   'build',
                    gyp info spawn args   '-Goutput_dir=.'
                    gyp info spawn args ]
                    Traceback (most recent call last):
                      File "/opt/iobroker/node_modules/node-gyp/gyp/gyp_main.py", line 42, in <module>
                        import gyp  # noqa: E402
                      File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 9, in <module>
                        import gyp.input
                      File "/opt/iobroker/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 19, in <module>
                        from distutils.version import StrictVersion
                    ModuleNotFoundError: No module named 'distutils'
                    gyp ERR! configure error
                    gyp ERR! stack Error: `gyp` failed with exit code: 1
                    gyp ERR! stack     at ChildProcess.onCpExit (/opt/iobroker/node_modules/node-gyp/lib/configure.js:259:16)
                    gyp ERR! stack     at ChildProcess.emit (node:events:519:28)
                    gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:293:12)
                    gyp ERR! System Linux 6.12.47+rpt-rpi-v8
                    gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                    gyp ERR! cwd /opt/iobroker/node_modules/@stoprocent/noble
                    gyp ERR! node -v v22.20.0
                    gyp ERR! node-gyp -v v8.4.1
                    gyp ERR! not ok
                    > mdns@2.7.2 install
                    > node-gyp rebuild
                    (node:12971) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
                    gyp info spawn args   '/opt/iobroker/node_modules/mdns/build/config.gypi',
                    gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/mdns',
                        import gyp.input
                    gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "rebuild"
                    gyp ERR! cwd /opt/iobroker/node_modules/mdns
                    gyp ERR! not ok
                    > node-dht-sensor@0.4.5 install
                    > node-gyp configure
                    (node:12987) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
                    gyp info spawn args   '/opt/iobroker/node_modules/node-dht-sensor/build/config.gypi',
                    gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/node-dht-sensor',
                        import gyp.input
                    gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-gyp" "configure"
                    gyp ERR! cwd /opt/iobroker/node_modules/node-dht-sensor
                    gyp ERR! not ok
                    > opengpio@2.0.2 install
                    > node-gyp rebuild
                    (node:13003) [DEP0060] DeprecationWarning: The `util._extend` API is deprecated. Please use Object.assign() instead.
                    gyp info spawn args   '/opt/iobroker/node_modules/opengpio/build/config.gypi',
                    gyp info spawn args   '-Dmodule_root_dir=/opt/iobroker/node_modules/opengpio',
                        import gyp.input
                    gyp ERR! cwd /opt/iobroker/node_modules/opengpio
                    gyp ERR! not ok
                    npm error code 1
                    npm error path /opt/iobroker/node_modules/opengpio
                    npm error command failed
                    npm error command sh -c node-gyp rebuild
                    npm error A complete log of this run can be found in: /home/iobroker/.npm/_logs/2025-10-20T11_05_16_554Z-debug-0.log
                        import gyp.input
                    gyp ERR! not ok
                        import gyp.input
                    gyp ERR! not ok
                        import gyp.input
                    gyp ERR! not ok
                        import gyp.input
                    gyp ERR! not ok
                    npm error code 1
                    host.raspberrypi Cannot install Grothesk242/ioBroker.rpi2#c87e9539d89bac8f4d19b266679bcb78ed554f1d: 1
                    Qix- created this issue in visionmedia/debug
                    closed ReDos Vulnerability Regression Visibility Notice #797
                      @torsten-lehmann
                      Was haste denn jetzt geändert?
                      Oben ist es doch durchgelaufen?
                      • Torsten Lehmann
                        @thomas-braun wenn ich ein Backup zurücksetze geht rpi2 nicht mehr zu installieren. Bin jetzt gerade soweit hab SD Karte iobroker neue aufgesetzt rpi2 Adapter und Instanz funktioniert auch. Befürchte hole ich das gespeichert Backup zurück wird rpi2 nicht mehr funktionieren.
                          @torsten-lehmann
                          Hast du im Backup vielleicht einen sehr alten Versionsstand eingebacken?
                          • Torsten Lehmann
                            @torsten-lehmann
                            Danke für Deine Geduld, vor dem zurücksetzen des Backups hab ich opt/iobroker/node_modules/iobroker.rpi2 gesichert und nach dem zurücksetzen des Backups wieder zurück gespeichert. rpi2 v2.4.0 lebenzeichen und mit Host verbunden.
                            Wenn es so bleibt, werde ich mich, um das Problem Zigbee upgrade von 2.0.5 auf 3.0.5 kümmern.
                              Das macht man NICHT. Außer vielleicht unter anderen Betriebssystemen, aber auch da ist das Krampf.
                              • Torsten Lehmann
                                @thomas-braun dachte ich mir schon. bekomme es nicht ohne Backup hin. Viele Adapter, Skripte usw. jahrelange Arbeit.
                                  @torsten-lehmann
                                  Durch das wüste hin- und herkopieren zerballerst du dir die 'npm-Versionsdatenbank'.
                                  Kein Wunder, das dann alles ins Schleudern gerät.
                                  Wie schaut denn deine Ausgangslage aus?
                                  Generelle Vorgehensweise (bei allen Sprüngen): Alt-System auf den allerletzten Stand bringen, davon ein gescheites Backup ziehen (Backitup-Adapter!), neues Betriebssystem installieren, auf den letzten Stand bringen, iobroker leer installieren, in den leeren ioBroker das Backup einspielen.
                                  • Asgothian
                                    Asgothian Developer @Thomas Braun last edited by Asgothian
                                    @thomas-braun sagte in RPI-Monitor und GPIO rpi2 v2.3.1:
                                    Da fehlt ein wichtiger Punkt. Da auch das auf Stand bringen schon Probleme erzeugen kann:
                                    • Backup (A) ziehen (So wie das System ist)
                                    • Auf den neusten möglichen Stand bringen, ohne das Betriebssystem hoch zu ziehen
                                    • Backup (B) ziehen
                                    • neues OS installieren
                                    • IoBroker installieren
                                    • Backup einspielen - wenn Möglich Backup B, im Notfall Backup A
                                    A.
                                    Torsten Lehmann Thomas Braun 3 Replies Last reply Reply Quote 0
                                    • Torsten Lehmann
                                      Torsten Lehmann @Asgothian last edited by
                                      @asgothian said in RPI-Monitor und GPIO rpi2 v2.3.1:
                                      • Backup (B) ziehen
                                      A.
                                      okay nutze neben das iobroker backup noch ein windows tool (iobroker Tool) um ein komplettes Backup zu erstellen. erstelle neue SD mit iobroker.
                                      • Torsten Lehmann
                                        @asgothian
                                        [How-to] ioBroker richtig installieren
                                        sudo apt update && sudo apt upgrade -y
                                        curl -sl https://deb.nodesource.com/setup_22.x | sudo bash -
                                        sudo apt-get install -y build-essential libavahi-compat-libdnssd-dev libudev-dev libpam0g-dev nodejs
                                        node -v && nodejs -v && npm -v
                                        curl -sL https://iobroker.net/install.sh | bash -
                                          @torsten-lehmann
                                          Wo hast du denn das her?
                                          Im Grunde reicht der Einzeiler:
                                          curl -sLf https://iobroker.net/install.sh | bash -
                                          Der Installer zieht dann auch nodejs usw. rein.
                                            Thomas Braun Most Active @Asgothian last edited by
                                            @asgothian
                                            Naja, ein struppiges Backup (A) würde ich gar nicht einspielen. Die Installation wird ja nicht besser dadurch.
                                            Also vorher die ganze Choose auf das richtige Gleis setzen.
                                            502
