    3. Einsteigerfragen
    4. Updaten von Debian Buster 10 auf Bookworm 12
      Markus Frankl @Codierknecht last edited by
      @codierknecht hatte mir mal die Geschichte mit VMs angewöhnt, weil sie in sich geschlossene Systeme sind und das durchreichen von USB Geräten um einiges einfacher geht.
        Thomas Braun Most Active @Markus Frankl last edited by
        @markus-frankl
        Zeig mal den Output von
        iob diag
        • Codierknecht
          Codierknecht Developer Most Active @Markus Frankl last edited by
          @markus-frankl sagte in Updaten von Debian Buster 10 auf Bookworm 12:
          Da stimme ich zu.
          Mein ioBroker braucht keine USB-Geräte. Darum läuft der 1a als LXC.
            Markus Frankl @Thomas Braun last edited by
            Linux iobroker 4.19.0-27-amd64 #1 SMP Debian 4.19.316-1 (2024-06-25) x86_64
            The programs included with the Debian GNU/Linux system are free software;
            the exact distribution terms for each program are described in the
            individual files in /usr/share/doc/*/copyright.
            Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
            permitted by applicable law.
            Last login: Mon Oct 20 22:19:50 2025 from 192.168.178.64
            markus@iobroker:~$ iob diag
            [sudo] Passwort für markus:
            *** iob diag is starting up, please wait ***
            iob diag needs to be updated. Please execute 'iobroker fix' first.
            /home/iobroker/.diag.sh: line 72: debian-distro-info: command not found
            /home/iobroker/.diag.sh: line 73: ubuntu-distro-info: command not found
            /home/iobroker/.diag.sh: line 74: debian-distro-info: command not found
            /home/iobroker/.diag.sh: line 75: ubuntu-distro-info: command not found
            /home/iobroker/.diag.sh: line 76: ubuntu-distro-info: command not found
            /home/iobroker/.diag.sh: line 77: debian-distro-info: command not found
            /home/iobroker/.diag.sh: line 78: debian-distro-info: command not found
            *** ioBroker Diagnosis ***
            Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
            The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
            https://forum.iobroker.net
            Just copy and paste the Summary Page, including the ``` characters at start and end.
            It helps us to help you!
            * Some output is masked. For full results please use 'iob diag --unmask' *
            Press any key to continue
            ========== Start marking the full check here ===========
            ```bash
            Script v.2025-08-09
            *** BASE SYSTEM ***
            Operating System: Debian GNU/Linux 10 (buster)
               Static hostname: iobroker
                     Icon name: computer-vm
                       Chassis: vm
                Virtualization: kvm
                        Kernel: Linux 4.19.0-27-amd64
                  Architecture: x86-64
            OS is similar to:
            model name      : Common KVM processor
            Docker          : false
            Virtualization  : kvm
            Kernel          : x86_64
            Userland        : 64 bit
            Systemuptime and Load:
             22:53:37 up  7:59,  1 user,  load average: 0.25, 0.33, 0.30
            CPU threads: 8
            *** LIFE CYCLE STATUS ***
            Unknown release codenamed 'buster'. Please check yourself if the Operating System is actively maintained.
            *** TIME AND TIMEZONES ***
                           Local time: Mon 2025-10-20 22:53:37 CEST
                       Universal time: Mon 2025-10-20 20:53:37 UTC
                             RTC time: Mon 2025-10-20 20:53:38
                          NTP service: active
                      RTC in local TZ: no
            *** Users and Groups ***
            User that called 'iob diag':
            markus
            HOME=/home/markus
            GROUPS=markus cdrom floppy audio dip video plugdev netdev iobroker
            iobroker
            HOME=/home/iobroker
            GROUPS=iobroker tty dialout audio video plugdev
            *** DISPLAY-SERVER SETUP ***
            Display-Server:         false
            Unit display-manager.service could not be found.
            Display-Manager:
            Desktop:
            Session:                tty
            System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
            *** MEMORY ***
            Mem:           9.8G        3.6G        5.0G        8.0M        1.1G        5.8G
            Swap:          4.0G          0B        4.0G
            Total:          13G        3.6G        9.0G
            Active iob-Instances:   49
                     9756 M total memory
                     3639 M used memory
                     3879 M active memory
                      499 M inactive memory
                     5044 M free memory
                      195 M buffer memory
                      877 M swap cache
                     3996 M total swap
                        0 M used swap
                     3996 M free swap
            top - 22:53:38 up  7:59,  1 user,  load average: 0.25, 0.33, 0.30
            Tasks: 149 total,   1 running, 148 sleeping,   0 stopped,   0 zombie
            %Cpu(s): 10.0 us,  1.7 sy,  0.0 ni, 88.3 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
            MiB Mem :   9756.4 total,   5038.5 free,   3645.3 used,   1072.7 buff/cache
            MiB Swap:   3997.0 total,   3997.0 free,      0.0 used.   5821.0 avail Mem
            *** FAILED SERVICES ***
            0 loaded units listed. Pass --all to see loaded but inactive units, too.
            To show all installed unit files use 'systemctl list-unit-files'.
            *** DMESG CRITICAL ERRORS ***
            No critical errors detected
            *** FILESYSTEM ***
            udev           devtmpfs  4.8G     0  4.8G   0% /dev
            tmpfs          tmpfs     976M  8.5M  968M   1% /run
            /dev/sda1      ext4       28G   14G   13G  51% /
            tmpfs          tmpfs     4.8G     0  4.8G   0% /dev/shm
            tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
            tmpfs          tmpfs     4.8G     0  4.8G   0% /sys/fs/cgroup
            tmpfs          tmpfs     976M     0  976M   0% /run/user/1000
            [Mon Oct 20 14:54:25 2025] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
            [Mon Oct 20 14:54:26 2025] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
            Show mounted filesystems:
            TARGET        SOURCE    FSTYPE OPTIONS
            /             /dev/sda1 ext4   rw,relatime,errors=remount-ro
            `-/sys/fs/bpf bpf       bpf    rw,nosuid,nodev,noexec,relatime,mode=700
            /var:
            661M    /var/
            469M    /var/cache
            462M    /var/cache/apt
            401M    /var/cache/apt/archives
            162M    /var/lib
                  Users in the 'systemd-journal' group can see all messages. Pass -q to
                  turn off this notice.
            No journal files were opened due to insufficient permissions.
            /opt/iobroker/backups:
            2.4G    /opt/iobroker/backups/
            436K    /opt/iobroker/backups/scripte
            432K    /opt/iobroker/backups/scripte/common
            316K    /opt/iobroker/backups/scripte/common/Blockly
            112K    /opt/iobroker/backups/scripte/common/Javascript
            /opt/iobroker/iobroker-data:
            727M    /opt/iobroker/iobroker-data/
            290M    /opt/iobroker/iobroker-data/files
            262M    /opt/iobroker/iobroker-data/backup-objects
            47M     /opt/iobroker/iobroker-data/files/admin.admin
            46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
            66M     /opt/iobroker/iobroker-data/states.jsonl
            48M     /opt/iobroker/iobroker-data/objects.jsonl
            24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
            19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
            18M     /opt/iobroker/iobroker-data/objects.json.migrated
            USB-Devices by-id:
            No Devices found 'by-id'
            Zigbee Network Settings on your coordinator/in nvbackup are:
            zigbee.X
            Extended Pan ID:
            *** MASKED ***
            Pan ID:
            *** MASKED ***
            Channel:
            *** MASKED ***
            Network Key:
            *** MASKED ***
            To unmask the settings run 'iob diag --unmask'
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v20.16.0
            /usr/bin/node           v20.16.0
            /usr/bin/npm            10.8.1
            /usr/bin/npx            10.8.1
            /usr/bin/corepack       0.28.2
            nodejs:
              Installed: 20.16.0-1nodesource1
              Candidate: 20.19.5-1nodesource1
              Version table:
                 20.19.5-1nodesource1 1001
                    500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                 20.19.4-1nodesource1 1001
                 20.19.3-1nodesource1 1001
                 20.19.2-1nodesource1 1001
                 20.19.1-1nodesource1 1001
                 20.19.0-1nodesource1 1001
                 20.18.3-1nodesource1 1001
                 20.18.2-1nodesource1 1001
                 20.18.1-1nodesource1 1001
                 20.18.0-1nodesource1 1001
                 20.17.0-1nodesource1 1001
             *** 20.16.0-1nodesource1 1001
                    100 /var/lib/dpkg/status
                 20.15.1-1nodesource1 1001
                 20.15.0-1nodesource1 1001
                 20.14.0-1nodesource1 1001
                 20.13.1-1nodesource1 1001
                 20.13.0-1nodesource1 1001
                 20.12.2-1nodesource1 1001
                 20.12.1-1nodesource1 1001
                 20.12.0-1nodesource1 1001
                 20.11.1-1nodesource1 1001
                 20.11.0-1nodesource1 1001
                 20.10.0-1nodesource1 1001
                 20.9.0-1nodesource1 1001
                 20.8.1-1nodesource1 1001
                 20.8.0-1nodesource1 1001
                 20.7.0-1nodesource1 1001
                 20.6.1-1nodesource1 1001
                 20.6.0-1nodesource1 1001
                 20.5.1-1nodesource1 1001
                 20.5.0-1nodesource1 1001
                 20.4.0-1nodesource1 1001
                 20.3.1-1nodesource1 1001
                 20.3.0-1nodesource1 1001
                 20.2.0-1nodesource1 1001
                 20.1.0-1nodesource1 1001
                 20.0.0-1nodesource1 1001
                 10.24.0~dfsg-1~deb10u4 500
                    500 http://security.debian.org/debian-security buster/updates/main amd64 Packages
                 10.24.0~dfsg-1~deb10u1 500
                    500 http://ftp.de.debian.org/debian buster/main amd64 Packages
            No problems detected
            Errors in npm tree: 0
            Checking for nodejs vulnerability:
            The current Node.js version (v20.16.0) is vulnerable to the following CVEs:
            CVE-2025-23083(high): With the aid of the diagnostics_channel utility, an event can be hooked into whenever a worker thread is created. This is not limited only to workers but also exposes internal workers, where an instance of them can be fetched, and its constructor can be grabbed and reinstated for malicious usage.
            This vulnerability affects Permission Model users (--permission) on Node.js v20, v22, and v23.
            Patched versions: ^20.18.2 || ^22.13.1 || ^23.6.1
            CVE-2025-23085(medium): A memory leak could occur when a remote peer abruptly closes the socket without sending a GOAWAY notification. Additionally, if an invalid header was detected by nghttp2, causing the connection to be terminated by the peer, the same leak was triggered. This flaw could lead to increased memory consumption and potential denial of service under certain conditions.
            This vulnerability affects HTTP/2 Server users on Node.js v18.x, v20.x, v22.x and v23.x.
            Patched versions: ^18.20.6 || ^20.18.2 || ^22.13.1 || ^23.6.1
            CVE-2025-23166(high):  The C++ method SignTraits::DeriveBits() may incorrectly call ThrowException() based on user-supplied inputs when executing in a background thread, crashing the Node.js process. Such cryptographic operations are commonly applied to untrusted inputs. Thus, this mechanism potentially allows an adversary to remotely crash a Node.js runtime.
            Patched versions: ^20.19.2 || ^22.15.1 || ^23.11.1 || ^24.0.2
            CVE-2025-23167(medium): A flaw in Node.js 20's HTTP parser allows improper termination of HTTP/1 headers using `\r\n\rX` instead of the required `\r\n\r\n`.
            This inconsistency enables request smuggling, allowing attackers to bypass proxy-based access controls and submit unauthorized requests.
            The issue was resolved by upgrading `llhttp` to version 9, which enforces correct header termination.
            Impact:
            * This vulnerability affects only Node.js 20.x users prior to the `llhttp` v9 upgrade.
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            iobroker            iobroker (version: 7.0.6, hostname: iobroker      , alive, uptime: 7502)
            Core adapters versions
            js-controller:  7.0.6
            admin:          7.7.2
            javascript:     8.9.2
            nodejs modules from github:     5
            +-- iobroker.alexa-shoppinglist@1.1.0 (git+ssh://git@github.com/MiRo1310/ioBroker.alexa-shoppinglist.git#30ebd89f701179b790dce4705c6e7a943039f6e1)
            +-- iobroker.fully-tablet-control@0.3.8 (git+ssh://git@github.com/xXBJXx/ioBroker.fully-tablet-control.git#466a9f2565ccaa05fb5536b16a9c46b9d5f76e8a)
            +-- iobroker.homepilot20@0.0.72 (git+ssh://git@github.com/homecineplexx/ioBroker.homepilot20.git#3706cca661f6ac97f7b2d0a77043b9a79eb2847f)
            +-- iobroker.tesla-motors@1.4.5 (git+ssh://git@github.com/iobroker-community-adapters/ioBroker.tesla-motors.git#9325aa23185511923c353bc04c01781057e4f016)
            +-- iobroker.vw-connect@0.6.1 (git+ssh://git@github.com/TA2k/ioBroker.vw-connect.git#309769f6889c08b0789f21d327b98743f7147d3d)
            Adapter State
            + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            + system.adapter.alarm.0                  : alarm                 : iobroker                                 -  enabled
            + system.adapter.alexa-shoppinglist.0     : alexa-shoppinglist    : iobroker                                 -  enabled
            + system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
              system.adapter.alias-manager.0          : alias-manager         : iobroker                                 -  enabled
            + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
            + system.adapter.binance.0                : binance               : iobroker                                 -  enabled
            + system.adapter.cloud.0                  : cloud                 : iobroker                                 -  enabled
            + system.adapter.deconz.0                 : deconz                : iobroker                                 -  enabled, port: 80
            + system.adapter.device-reminder.0        : device-reminder       : iobroker                                 -  enabled
              system.adapter.device-watcher.0         : device-watcher        : iobroker                                 - disabled
            + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
            + system.adapter.ems-esp.0                : ems-esp               : iobroker                                 -  enabled
              system.adapter.feiertage.0              : feiertage             : iobroker                                 -  enabled
              system.adapter.flot.0                   : flot                  : iobroker                                 -  enabled
            + system.adapter.fully-tablet-control.0   : fully-tablet-control  : iobroker                                 -  enabled
            + system.adapter.ham.0                    : ham                   : iobroker                                 -  enabled
            + system.adapter.harmony.0                : harmony               : iobroker                                 -  enabled
            + system.adapter.history.0                : history               : iobroker                                 -  enabled
            + system.adapter.homeconnect.0            : homeconnect           : iobroker                                 -  enabled
            + system.adapter.homepilot20.0            : homepilot20           : iobroker                                 -  enabled
              system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
              system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 -  enabled
            + system.adapter.info.0                   : info                  : iobroker                                 -  enabled
            + system.adapter.iot.0                    : iot                   : iobroker                                 -  enabled
            + system.adapter.iqontrol.0               : iqontrol              : iobroker                                 -  enabled
            + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
            + system.adapter.lametric.0               : lametric              : iobroker                                 -  enabled
            + system.adapter.meross.0                 : meross                : iobroker                                 -  enabled
            + system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
            + system.adapter.mihome-vacuum.1          : mihome-vacuum         : iobroker                                 -  enabled, port: 54321
              system.adapter.netatmo-crawler.0        : netatmo-crawler       : iobroker                                 -  enabled
            + system.adapter.nuki-extended.0          : nuki-extended         : iobroker                                 -  enabled
            + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
              system.adapter.ring.0                   : ring                  : iobroker                                 -  enabled
            + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
            + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
            + system.adapter.shuttercontrol.0         : shuttercontrol        : iobroker                                 -  enabled
            + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
            + system.adapter.socketio.0               : socketio              : iobroker                                 -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
            + system.adapter.spotify-premium.0        : spotify-premium       : iobroker                                 -  enabled
            + system.adapter.tado.0                   : tado                  : iobroker                                 -  enabled
            + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
            + system.adapter.telegram-menu.0          : telegram-menu         : iobroker                                 -  enabled
            + system.adapter.telegram.0               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
            + system.adapter.telegram.1               : telegram              : iobroker                                 -  enabled, port: 8443, bind: 0.0.0.0
            + system.adapter.terminal.0               : terminal              : iobroker                                 -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
            + system.adapter.tesla-motors.0           : tesla-motors          : iobroker                                 -  enabled
            + system.adapter.text2command.0           : text2command          : iobroker                                 -  enabled
            + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
            + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
            + system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
              system.adapter.tvspielfilm.0            : tvspielfilm           : iobroker                                 -  enabled
            + system.adapter.vw-connect.0             : vw-connect            : iobroker                                 -  enabled
            + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            + system.adapter.wled.0                   : wled                  : iobroker                                 -  enabled
            + system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled
            + instance is alive
            ioBroker-Repositories
            │ (index) │ name               │ url                                                     │ auto upgrade │
            │ 0       │ 'Stable (default)' │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
            │ 1       │ 'Beta (latest)'    │ 'http://download.iobroker.net/sources-dist-latest.json' │ false        │
            │ 2       │ ''                 │ 'http://download.iobroker.net/sources-dist.json'        │ false        │
            Active repo(s): Stable (default)
            Upgrade policy: none
            Installed ioBroker-Adapters
            Used repository: Stable (default)
            Adapter    "admin"        : 7.7.2    , installed 7.7.2
            Adapter    "alarm"        : 3.7.4    , installed 3.7.4
            Adapter    "alexa-shoppinglist": 1.1.0, installed 1.1.0
            Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
            Adapter    "alias-manager": 2.0.0    , installed 2.0.0
            Adapter    "backitup"     : 3.3.5    , installed 3.3.5
            Adapter    "deconz"       : 1.6.4    , installed 1.6.4
            Adapter    "device-reminder": 3.1.2  , installed 3.1.2
            Adapter    "device-watcher": 2.13.1  , installed 2.13.1
            Adapter    "ems-esp"      : 6.0.0    , installed 6.0.0
            Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
            Adapter    "ham"          : 5.3.1    , installed 5.3.1
            Adapter    "harmony"      : 1.5.0    , installed 1.5.0
            Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
            Adapter    "ical"         : 1.17.0   , installed 1.17.0
            Adapter    "iot"          : 3.3.0    , installed 4.1.10
            Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
            Adapter    "javascript"   : 8.9.2    , installed 8.9.2
            Controller "js-controller": 7.0.7    , installed 7.0.6  [Updatable]
            Adapter    "lametric"     : 4.1.0    , installed 4.1.0
            Adapter    "meross"       : 1.17.0   , installed 1.17.0
            Adapter    "mihome-vacuum": 5.2.0    , installed 5.2.0
            Adapter    "mqtt-client"  : 3.0.0    , installed 3.0.0
            Adapter    "netatmo-crawler": 1.1.0  , installed 1.1.0
            Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
            Adapter    "proxmox"      : 2.4.0    , installed 2.4.0
            Adapter    "ring"         : 6.4.0    , installed 6.3.0  [Updatable]
            Adapter    "scenes"       : 3.2.3    , installed 3.2.3
            Adapter    "shelly"       : 10.2.0   , installed 10.2.0
            Adapter    "shuttercontrol": 2.0.5   , installed 2.0.5
            Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
            Adapter    "socketio"     : 6.7.1    , installed 6.7.1
            Adapter    "spotify-premium": 1.5.2  , installed 1.5.2
            Adapter    "tado"         : 0.8.0    , installed 0.8.0
            Adapter    "tankerkoenig" : 3.4.0    , installed 2.1.1  [Updatable]
            Adapter    "telegram"     : 4.1.0    , installed 4.1.0
            Adapter    "telegram-menu": 2.4.4    , installed 2.4.4
            Adapter    "terminal"     : 1.0.0    , installed 1.0.0
            Adapter    "tesla-motors" : 1.3.2    , installed 1.4.5
            Adapter    "text2command" : 3.0.3    , installed 3.0.3
            Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
            Adapter    "trashschedule": 3.3.0    , installed 3.3.0
            Adapter    "tuya"         : 3.16.0   , installed 3.16.0
            Adapter    "tvspielfilm"  : 2.1.0    , installed 2.1.0
            Adapter    "web"          : 7.0.8    , installed 7.0.8
            Adapter    "wled"         : 0.7.2    , installed 0.7.2
            Adapter    "ws"           : 2.6.2    , installed 2.6.2
            Adapter    "yahka"        : 1.1.5    , installed 1.1.5
            Objects and States
            Objects:        34426
            States:         28275
            E: The repository 'http://security.debian.org/debian-security buster/updates Release' no longer has a Release file.
            E: The repository 'http://ftp.de.debian.org/debian buster Release' no longer has a Release file.
            E: The repository 'http://ftp.de.debian.org/debian buster-updates Release' no longer has a Release file.
            Pending Updates: 1
            *** Listening Ports ***
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       468612     15071/iobroker.js-c
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       469107     15071/iobroker.js-c
            tcp        0      0 127.0.0.1:42411         0.0.0.0:*               LISTEN      1001       635203     15464/io.yahka.0
            tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          1351       1/init
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14595      549/sshd
            tcp6       0      0 :::37761                :::*                    LISTEN      1001       471037     15464/io.yahka.0
            tcp6       0      0 :::61991                :::*                    LISTEN      1001       464592     15286/io.harmony.0
            tcp6       0      0 :::111                  :::*                    LISTEN      0          11551      1/init
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       469142     15089/io.admin.0
            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       473592     16297/io.web.0
            tcp6       0      0 :::8084                 :::*                    LISTEN      1001       472918     16436/io.socketio.0
            tcp6       0      0 :::51989                :::*                    LISTEN      1001       502594     17128/io.nuki-exten
            tcp6       0      0 :::22                   :::*                    LISTEN      0          14597      549/sshd
            tcp6       0      0 :::8087                 :::*                    LISTEN      1001       475918     16267/io.simple-api
            tcp6       0      0 :::8088                 :::*                    LISTEN      1001       472570     16158/io.terminal.0
            udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       466493     15241/io.deconz.0
            udp        0      0 0.0.0.0:60067           0.0.0.0:*                           108        12221      399/avahi-daemon: r
            udp        0      0 0.0.0.0:53420           0.0.0.0:*                           1001       469826     15662/io.mihome-vac
            udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       466930     15515/io.mihome-vac
            udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       464593     15286/io.harmony.0
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       472805     16359/io.wled.0
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       471042     15464/io.yahka.0
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       471041     15464/io.yahka.0
            udp        0      0 192.168.178.97:5353     0.0.0.0:*                           1001       470408     15346/io.tr-064.0
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        12219      399/avahi-daemon: r
            udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       466536     15271/io.shelly.0
            udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       473093     15530/io.tuya.0
            udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       473094     15530/io.tuya.0
            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13260      331/dhclient
            udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          10372      1/init
            udp6       0      0 :::1900                 :::*                                1001       466496     15241/io.deconz.0
            udp6       0      0 :::1900                 :::*                                1001       466495     15241/io.deconz.0
            udp6       0      0 :::1900                 :::*                                1001       466494     15241/io.deconz.0
            udp6       0      0 :::5353                 :::*                                108        12220      399/avahi-daemon: r
            udp6       0      0 :::38465                :::*                                108        12222      399/avahi-daemon: r
            udp6       0      0 :::111                  :::*                                0          10377      1/init
            2025-10-20 22:53:06.008  - info: iqontrol.0 (16282) CALCULATION Adapter-Monitor Green+Grey_NAMES_LIST has changed
            2025-10-20 22:53:06.209  - info: iqontrol.0 (16282) COMBINATION Adapter-Monitor HTML has changed
            2025-10-20 22:53:58.444  - warn: spotify-premium.0 (20742) empty playlist name
            2025-10-20 22:53:58.444  - error: spotify-premium.0 (20742) playlist error empty playlist name
            2025-10-20 22:54:00.006  - info: spotify-premium.0 (20742) Scheduled restart.
            2025-10-20 22:54:00.490  - info: spotify-premium.0 (20742) terminating
            2025-10-20 22:54:00.491  - info: spotify-premium.0 (20742) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
            2025-10-20 22:54:00.581  - info: spotify-premium.0 (20742) terminating
            2025-10-20 22:54:00.825  - info: iqontrol.0 (16282) COUNTER Adapter-Monitor Red: 2 of 49
            2025-10-20 22:54:01.026  - info: iqontrol.0 (16282) CALCULATION Adapter-Monitor Red+Yellow has changed
            2025-10-20 22:54:01.027  - info: iqontrol.0 (16282) COMBINATION Adapter-Monitor HTML has changed
            2025-10-20 22:54:01.033  - info: iqontrol.0 (16282) CALCULATION Adapter-Monitor Red+Yellow_LIST has changed
            2025-10-20 22:54:01.041  - info: iqontrol.0 (16282) CALCULATION Adapter-Monitor Red+Yellow_LIST_JSON has changed
            2025-10-20 22:54:01.046  - info: iqontrol.0 (16282) CALCULATION Adapter-Monitor Red+Yellow_NAMES_LIST has changed
            2025-10-20 22:54:01.155  - info: host.iobroker instance system.adapter.spotify-premium.0 scheduled normal terminated and will be restarted on schedule.
            2025-10-20 22:54:01.155  - info: host.iobroker Restart adapter system.adapter.spotify-premium.0 because enabled
            2025-10-20 22:54:01.687  - info: iqontrol.0 (16282) COUNTER Adapter-Monitor Yellow: 0 of 49
            2025-10-20 22:54:01.817  - info: iqontrol.0 (16282) COUNTER Adapter-Monitor Green: 47 of 49
            2025-10-20 22:54:02.019  - info: iqontrol.0 (16282) CALCULATION Adapter-Monitor Green+Grey has changed
            2025-10-20 22:54:02.019  - info: iqontrol.0 (16282) CALCULATION Adapter-Monitor Green+Grey_LIST has changed
            2025-10-20 22:54:02.021  - info: iqontrol.0 (16282) CALCULATION Adapter-Monitor Green+Grey_LIST_JSON has changed
            2025-10-20 22:54:02.022  - info: iqontrol.0 (16282) CALCULATION Adapter-Monitor Green+Grey_NAMES_LIST has changed
            2025-10-20 22:54:02.023  - info: iqontrol.0 (16282) COMBINATION Adapter-Monitor HTML has changed
            2025-10-20 22:54:02.226  - info: iqontrol.0 (16282) COMBINATION Adapter-Monitor HTML has changed
            2025-10-20 22:54:02.685  - info: host.iobroker instance system.adapter.spotify-premium.0 in version "1.5.2" started with pid 21248
            iob diag has finished.
            markus@iobroker:~$
              @markus-frankl
              Die ganzen Meldungen zu fehlenden Updates usw. siehste hoffentlich selber.
              • Armilar
                Armilar Most Active Forum Testing @Codierknecht last edited by
                @codierknecht sagte in Updaten von Debian Buster 10 auf Bookworm 12:
                Wenn Du da schon neu aufsetzen musst: Warum eine VM und kein LXC?
                LXC? Wird das noch supported? Du meinst doch bestimmt LXD, oder?
                  TT-Tom @Armilar last edited by TT-Tom
                  @armilar
                  man spricht auch in der 9 Version noch vom LXC Container.
                  • Armilar
                    Armilar Most Active Forum Testing @TT-Tom last edited by
                    @tt-tom
                    Dann ist das noch nicht gänzlich gestorben... QNAP hat da schon komplett auf LXD Container umgestellt, unterstützt allerdings noch laufende LXC Container
                      @thomas-braun ja, Das ich zu spät dran bin weiß ich auch selbst.
                      Aus diesem Grund ja hier auch die Frage wie am besten durchführen.
                      Wenn ich jetzt jammern würde, würde ich deine Reaktion ja wohl verstehen… Aber ich wollte einfach nur wissen, was nach eurer Sicht die beste Vorgehensweise wäre…
                      Hätte ja auch sein können, dass es sich trotzdem einfach hochziehen lässt.
                        @markus-frankl
                        Welche Reaktion bekrittelst du?
                        Ich wollte die Ausgabe von iob diag sehen, damit man bewerten kann ob es 'trotzdem einfach hochzuziehen' ist.
                          Alles gut. Lassen wir das nicht in eine Wortklauberei ausarten.
                          Ich weiß was zu tun ist und hab auch gelernt öfter mal das Betriebssystem zu checken und ggf hochzuziehen.
                          Da bin ich halt Apple verwöhnt… das sagt mir halt wenn es Zeit is zu updaten. Wenn man eben wenig mit Linux macht, kann sowas halt auch mal passieren.
                            Thomas Braun Most Active @Markus Frankl last edited by Thomas Braun
                            @markus-frankl
                            Das ist die Freiheit von Linux (hier Debian). Das bevormundet dich nicht, weil du ja weißt was du wann zu tun hast.
                            Bei anderen Distributionen sagt die Kiste dir auch Bescheid, wenn der Support aus läuft, bzw. wenn ein neues Release verfügbar ist. Schnubbibuntu macht das soweit ich weiß auf den Desktop-Versionen.
                            Debian (und insbesondere im Serverbetrieb) geht davon aus, das der Administrator so sattelfest ist, das er die Supportzeiträume selber im Blick hat. Gibt ja nicht ohne Grund Übersichten dafür:
                            https://wiki.debian.org/DebianReleases
                              @thomas-braun ja, das hatte ich so tatsächlich nicht auf dem Schirm. Auch die relativ kurzen Zeiträume der Versionssprünge nicht.
                              Aber man lernt ja nicht aus und dank Proxmox und Backups vom iOBroker wirds jetzt auch nicht so der Aufwand werden.
                              Vermute ich zumindest.
                                Immer im Sommer eines ungeraden Jahres erscheint ein neues Release. Die abgelöste Version wird dann noch ein Jahr voll unterstützt. Und innerhalb dieser 12 Monate sollte man mal ein Stündchen finden für ein Upgrade auf die dann jeweils aktuelle 'stable'. Je zeitnaher das erfolgt desto besser sind die Aussichten auf ein erfolgreiches Dist-Upgrade.
                                Wenn du da zwei Versionen auslässt wird es halt komplizierter und aufwändiger und eine Neuinstallation ist schneller, sicherer und stabiler.
                                Ob die Supportzeiträume (zu) kurz sind liegt im Auge des Betrachters. Denn eigentlich wird Debian ja immer vorgehalten, sich zu lange Zeit zu lassen. Drei Jahre voller Support sind in meinen Augen aber ein guter Kompromiss zwischen Aktualität und Stabilität.
                                Asgothian M 2 Replies Last reply Reply Quote 1
                                • Asgothian
                                  Asgothian Developer @Thomas Braun last edited by
                                  @thomas-braun sagte in Updaten von Debian Buster 10 auf Bookworm 12:
                                  3 Jahre ist am Ende deutlich zu wenig. Die EU fordert inzwischen 7 Jahre Support mit Sicherheitspatches bei vielen Geräten / Systemen.
                                  Das in Verbindung mit der Aussage das man am besten neu installiert, anstatt ein DistUpgrade zu machen - da sind 3 Jahre support schon 'geplante Obsoleszenz'
                                  A.
                                  Thomas Braun MartinP L 3 Replies Last reply Reply Quote 0
                                    Thomas Braun Most Active @Asgothian last edited by Thomas Braun
                                    @asgothian Du kannst ja jederzeit hochziehen. Darfst halt nicht den passenden Zeitpunkt dafür verpassen. Die Karawane zieht ja nur weiter, der Support ist ja für das jeweilige stable release gewährt. Wenn du weißt was du wann tun musst/kannst dann auch über Jahre/Jahrzehnte hinweg.
                                    LTS (5 Jahre) und ELTS (10 Jahre, musste allerdings dann zukaufen) gibt es ja auch noch für Debian. Nur ist das nix für Systeme, bei denen andere Software im Upstream weiterzieht. Beim ioBroker z. B. nodejs. Irgendwann können die im Upstream halt keine Rücksicht mehr auf Debian oldoldoldstable nehmen. Da wird es dann dünn, insbesondere für Leute, die 'von Linux keine Ahnung haben'.
                                    Und deswegen halt die klare Empfehlung, sich mit seinen Kisten immer auf dem aktuellen stable zu bewegen.
                                    • Asgothian
                                      Da bin ich dabei. Es ist (leider) inzwischen gängige Praxis jedes Jahr was neues zu bringen.
                                      Aber ich finde es irritierend das es inzwischen als 'ok' angesehen wird das ein System nur für 2 oder 3 Jahre für einen Endnutzer stabil zu nutzen ist, und das Abwärtskompatibilität und Langzeit-Nutzbarkeit kaum noch ein Thema ist.
                                      geplante Obsoleszenz halt.
                                      A.
                                        @asgothian
                                        Kannst ja Arch oder Gentoo Linux verwenden.
                                        Aber das ist dann naturgemäß nicht 'stabil', da ändern sich "am laufenden Band" die Schnittstellen und Software die letzte Woche noch lief funktioniert plötzlich mit der gerade frisch veröffentlichten libxys nicht mehr und muss angepasst werden.
                                        Das haste mit Debian 'stable' halt nicht. Einmal veröffentlicht ist hat das Ding für mindestens 3 Jahre stabile APIs.
                                        Fluch und Segen zugleich. Aber halt der beste Kompromiss aus Aktualität und Stabilität. Einen Tod musste halt sterben, 'top aktuell' und 'rockstable' schließt sich aus.
                                        • MartinP
                                          MartinP @Asgothian last edited by MartinP
                                          @asgothian sagte in Updaten von Debian Buster 10 auf Bookworm 12:
                                          A.
                                          Das ist eine falsche Interpretation dessen, was die EU verlangt.
                                          In de sieben Jahren wird Dir der Hersteller sukzessive mehrere neue Android Versionen auf Dein Smartphone spielen.
                                          Alternativ sieben Jahre immer bei der gleichen Android Version zu bleiben und nur Patches zu installieren, wird kein Hersteller zubilligen, weil es für ihn Mehraufwand bedeuten würde.
                                          Thomas Braun Asgothian 2 Replies Last reply Reply Quote 1
                                            Labersack @Asgothian last edited by
                                            Ist ja nicht so, dass wie z.B. einem Handy nach 3 Jahren das Gerät nicht mehr nutzbar ist, weil vom Hersteller keine Software mit aktuellen (Sicherheits-)Funktionen mehr verfügbar ist.
                                            Es muss einfach nur eine neue Version installiert werden, wozu man eben ein klein wenig Hand anlegen muss.
                                            Das hat man bei der ersten Inbetriebnahme ja auch hinbekommen.
                                            Nichts muss weggeworfen/verschrottet/neu gekauft werden, sondern es gibt aus offziellen und gut dokumentierten Quellen eine aktuelle Software. Der Support ist weiterhin vom "Hersteller" geleistet, dem du dafür nichtmal Geld geben musstest.
                                            Von daher finde ich den Begriff 'geplante Obsoleszenz' hier nicht ganz zutreffend.
                                            81.1k
                                            638
