    3. Einsteigerfragen
    4. Alexa Adapter-Fehler bei Anmeldung im Alexa Konto
      Thomas Braun Most Active @Babu242 last edited by
      @babu242
      Ja, alles. Unverändert.
      B 3 Replies Last reply Reply Quote 0
        Babu242 @Thomas Braun last edited by
        und bitte
        iob logs --watch
        code_text
        ```========== Start marking the full check here ===========
        ```bash
        Script v.2025-08-09
        *** BASE SYSTEM ***
         Static hostname: raspberrypi
               Icon name: computer
                  Kernel: Linux 6.12.47+rpt-rpi-v8
            Architecture: arm64
        OS is similar to:
        Model           : Raspberry Pi 4 Model B Rev 1.2
        Docker          : false
        Virtualization  : none
        Kernel          : aarch64
        Userland        : 64 bit
        Systemuptime and Load:
         19:54:04 up  1:17,  2 users,  load average: 0.37, 0.32, 0.35
        CPU threads: 4
        *** LIFE CYCLE STATUS ***
        Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
        *** RASPBERRY THROTTLING ***
        Current issues:
        Previously detected issues:
        *** TIME AND TIMEZONES ***
                       Local time: Tue 2025-10-21 19:54:05 CEST
                   Universal time: Tue 2025-10-21 17:54:05 UTC
                         RTC time: n/a
                      NTP service: active
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        pi
        HOME=/home/pi
        GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
        *** DISPLAY-SERVER SETUP ***
        Display-Server:         false
        Unit display-manager.service could not be found.
        Display-Manager:
        Desktop:
        Session:                tty
        *** MEMORY ***
        Mem:            4.0G        1.7G        1.8G        1.2M        524M        2.3G
        Swap:           536M          0B        536M
        Total:          4.5G        1.7G        2.3G
        Active iob-Instances:   17
                 3795 M total memory
                 1650 M used memory
                 1787 M active memory
                  155 M inactive memory
                 1719 M free memory
                   43 M buffer memory
                  456 M swap cache
                  511 M total swap
                    0 M used swap
                  511 M free swap
        top - 19:54:05 up  1:17,  2 users,  load average: 0.37, 0.32, 0.35
        Tasks: 192 total,   1 running, 191 sleeping,   0 stopped,   0 zombie
        %Cpu(s): 16.7 us, 16.7 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   3795.9 total,   1719.3 free,   1650.3 used,    500.2 buff/cache
        MiB Swap:    512.0 total,    512.0 free,      0.0 used.   2145.5 avail Mem
        *** FAILED SERVICES ***
          UNIT                               LOAD   ACTIVE SUB    DESCRIPTION
        * NetworkManager-wait-online.service loaded failed failed Network Manager Wait Online
        LOAD   = Reflects whether the unit definition was properly loaded.
        ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
        SUB    = The low-level unit activation state, values depend on unit type.
        1 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        No critical errors detected
        *** FILESYSTEM ***
        udev           devtmpfs  1.6G     0  1.6G   0% /dev
        tmpfs          tmpfs     760M  1.2M  759M   1% /run
        /dev/sda2      ext4      110G  5.8G  100G   6% /
        tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
        /dev/sda1      vfat      510M   66M  445M  13% /boot/firmware
        tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
        [Tue Oct 21 18:36:45 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave nvme.max_host_mem_size_mb=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  numa=fake=2 system_heap.max_order=0 smsc95xx.macaddr=DC:A6:32:59:72:FC vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000  console=ttyS0,115200 console=tty1 root=PARTUUID=e12e16cb-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
        [Tue Oct 21 18:36:46 2025] EXT4-fs (sda2): mounted filesystem ce208fd3-38a8-424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
        [Tue Oct 21 18:36:47 2025] EXT4-fs (sda2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w.
        Show mounted filesystems:
        TARGET           SOURCE    FSTYPE OPTIONS
        /                /dev/sda2 ext4   rw,noatime,commit=600
        `-/boot/firmware /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
        /var:
        1.7G    /var/
        570M    /var/log
        566M    /var/log/journal/a81e89c245434f208844b59db739f6a9
        411M    /var/cache
        Archived and active journals take up 565.9M in the file system.
        /opt/iobroker/backups:
        140M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        267M    /opt/iobroker/iobroker-data/
        145M    /opt/iobroker/iobroker-data/files
        89M     /opt/iobroker/iobroker-data/backup-objects
        47M     /opt/iobroker/iobroker-data/files/admin.admin
        46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
        15M     /opt/iobroker/iobroker-data/objects.jsonl
        8.6M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BBu8-Y_o.js
        7.5M    /opt/iobroker/iobroker-data/states.jsonl
        4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
        3.7M    /opt/iobroker/iobroker-data/files/telegram.admin/custom/assets/index-DS28Nms8.js
        USB-Devices by-id:
        No Devices found 'by-id'
        Zigbee Network Settings on your coordinator/in nvbackup are:
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        To unmask the settings run 'iob diag --unmask'
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v22.21.0
        /usr/bin/node           v22.21.0
        /usr/bin/npm            10.9.4
        /usr/bin/npx            10.9.4
        /usr/bin/corepack       0.34.0
        nodejs:
          Installed: 22.21.0-1nodesource1
          Candidate: 22.21.0-1nodesource1
          Version table:
         *** 22.21.0-1nodesource1 1001
                500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages
                100 /var/lib/dpkg/status
             22.20.0-1nodesource1 1001
             22.19.0-1nodesource1 1001
             22.18.0-1nodesource1 1001
             22.17.1-1nodesource1 1001
             22.17.0-1nodesource1 1001
             22.16.0-1nodesource1 1001
             22.15.1-1nodesource1 1001
             22.15.0-1nodesource1 1001
             22.14.0-1nodesource1 1001
             22.13.1-1nodesource1 1001
             22.13.0-1nodesource1 1001
             22.12.0-1nodesource1 1001
             22.11.0-1nodesource1 1001
             22.10.0-1nodesource1 1001
             22.9.0-1nodesource1 1001
             22.8.0-1nodesource1 1001
             22.7.0-1nodesource1 1001
             22.6.0-1nodesource1 1001
             22.5.1-1nodesource1 1001
             22.5.0-1nodesource1 1001
             22.4.1-1nodesource1 1001
             22.4.0-1nodesource1 1001
             22.3.0-1nodesource1 1001
             22.2.0-1nodesource1 1001
             22.1.0-1nodesource1 1001
             22.0.0-1nodesource1 1001
             18.20.4+dfsg-1~deb12u1 500
        No problems detected
        Errors in npm tree: 0
        Checking for nodejs vulnerability:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        raspberrypi         raspberrypi (version: 7.0.7, hostname: raspberrypi   , alive, uptime: 4640)
        Core adapters versions
        js-controller:  7.0.7
        admin:          7.7.2
        javascript:     8.9.2
        nodejs modules from github:     1
        +-- iobroker.connector-local-control@0.0.3 (git+ssh://git@github.com/ConnectorGit/ioBroker.connector-local-control.git#16883762689caa1cbfe39d5db0c2eeb4202d10ea)
        Adapter State
        + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
        + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
        + system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              -  enabled
          system.adapter.connector-local-control.0: connector-local-control: raspberrypi                              - disabled
        + system.adapter.discovery.0              : discovery             : raspberrypi                              -  enabled
        + system.adapter.fritzdect.0              : fritzdect             : raspberrypi                              -  enabled
        + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
        + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
          system.adapter.netatmo-crawler.0        : netatmo-crawler       : raspberrypi                              -  enabled
        + system.adapter.onkyo.0                  : onkyo                 : raspberrypi                              -  enabled
        + system.adapter.pollenflug.0             : pollenflug            : raspberrypi                              -  enabled
        + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 192.168.178.79
        + system.adapter.shelly.1                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
          system.adapter.sonos.0                  : sonos                 : raspberrypi                              - disabled
        + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
        + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
        + system.adapter.tradfri.0                : tradfri               : raspberrypi                              -  enabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              -  enabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              -  enabled
          system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
        + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + instance is alive
        ioBroker-Repositories
        Active repo(s): stable
        Upgrade policy: none
        Installed ioBroker-Adapters
        Used repository: stable
        Adapter    "admin"        : 7.7.2    , installed 7.7.2
        Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
        Adapter    "backitup"     : 3.3.5    , installed 3.3.5
        Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
        Adapter    "dysonairpurifier": 3.2.7 , installed 3.2.7
        Adapter    "fritzdect"    : 2.6.2    , installed 2.6.2
        Adapter    "iot"          : 3.3.0    , installed 4.1.3
        Adapter    "javascript"   : 8.9.2    , installed 8.9.2
        Controller "js-controller": 7.0.7    , installed 7.0.7
        Adapter    "netatmo-crawler": 1.1.0  , installed 1.1.0
        Adapter    "onkyo"        : 2.1.2    , installed 2.1.2
        Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
        Adapter    "shelly"       : 10.2.0   , installed 10.2.0
        Adapter    "socketio"     : 6.7.1    , installed 6.7.1
        Adapter    "sonos"        : 3.0.0    , installed 3.0.0
        Adapter    "telegram"     : 4.1.0    , installed 4.1.0
        Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
        Adapter    "tradfri"      : 3.1.3    , installed 3.1.3
        Adapter    "web"          : 7.0.8    , installed 7.0.8
        Adapter    "ws"           : 2.6.2    , installed 2.6.2
        Objects and States
        Objects:        6132
        States:         6794
        Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
        Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       7397       862/io.shelly.1
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       5768       583/iobroker.js-con
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1895       583/iobroker.js-con
        tcp        0      0 0.0.0.0:33373           0.0.0.0:*               LISTEN      1001       33311      1252/io.alexa2.0
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          735        601/sshd: /usr/sbin
        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       6810       964/io.web.0
        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       807        673/io.admin.0
        tcp6       0      0 :::22                   :::*                    LISTEN      0          737        601/sshd: /usr/sbin
        udp        0      0 0.0.0.0:48291           0.0.0.0:*                           1001       39301      1273/io.broadlink2.
        udp        0      0 0.0.0.0:40121           0.0.0.0:*                           1001       9245       930/io.tradfri.0
        udp        0      0 0.0.0.0:40148           0.0.0.0:*                           1001       55535      802/io.onkyo.0
        udp        0      0 192.168.178.79:5353     0.0.0.0:*                           1001       6052       847/io.tr-064.0
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        3053       460/avahi-daemon: r
        udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       937        832/io.shelly.0
        udp        0      0 0.0.0.0:38638           0.0.0.0:*                           1001       46398      1273/io.broadlink2.
        udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       37218      1273/io.broadlink2.
        udp        0      0 0.0.0.0:37536           0.0.0.0:*                           104        3055       460/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                104        3054       460/avahi-daemon: r
        udp6       0      0 :::52946                :::*                                104        3056       460/avahi-daemon: r
        udp6       0      0 fe80::ee7f:45f6:989:546 :::*                                0          6279       532/NetworkManager
        2025-10-21 19:35:44.661  - error: shelly.1 (862) [MQTT] Wrong MQTT authentication of client "shellyht-F391C4": Incorrect password
        2025-10-21 19:35:44.670  - info: shelly.1 (862) [MQTT] Client Close: (shellyht / shellyht-F391C4 / SHHT-1#F391C4#1) (false)
        2025-10-21 19:35:49.031  - error: shelly.1 (862) [MQTT] Wrong MQTT authentication of client "shellyht-F391C4": Incorrect password
        2025-10-21 19:35:49.038  - info: shelly.1 (862) [MQTT] Client Close: (shellyht / shellyht-F391C4 / SHHT-1#F391C4#1) (false)
        2025-10-21 19:35:57.555  - error: shelly.1 (862) [MQTT] Wrong MQTT authentication of client "shellyht-F391C4": Incorrect password
        2025-10-21 19:35:57.562  - info: shelly.1 (862) [MQTT] Client Close: (shellyht / shellyht-F391C4 / SHHT-1#F391C4#1) (false)
        2025-10-21 19:38:37.923  - info: admin.0 (673) ==> Connected system.user.admin from ::ffff:192.168.178.32
        2025-10-21 19:38:47.030  - info: broadlink2.0 (1273) interface to be used: { netmaskBits: 24, address: '192.168.178.79/24', addrs: [ 192, 168, 178, 79 ], cidr: '192.168.178.79/24', bcaddr: '192.168.178.255'
        2025-10-21 19:38:47.032  - info: broadlink2.0 (1273) discover  [ '192.168.178.49' ] from 0.0.0.0:59289
        2025-10-21 19:39:58.984  - info: admin.0 (673) <== Disconnect system.user.admin from ::ffff:192.168.178.32
        2025-10-21 19:40:28.447  - info: admin.0 (673) ==> Connected system.user.admin from ::ffff:192.168.178.32
        2025-10-21 19:45:43.898  - error: shelly.1 (862) [MQTT] Wrong MQTT authentication of client "shellyht-F391C4": Incorrect password
        2025-10-21 19:45:43.907  - info: shelly.1 (862) [MQTT] Client Close: (shellyht / shellyht-F391C4 / SHHT-1#F391C4#1) (false)
        2025-10-21 19:45:46.006  - error: shelly.1 (862) [MQTT] Wrong MQTT authentication of client "shellyht-F391C4": Incorrect password
        2025-10-21 19:45:46.012  - info: shelly.1 (862) [MQTT] Client Close: (shellyht / shellyht-F391C4 / SHHT-1#F391C4#1) (false)
        2025-10-21 19:45:49.859  - error: shelly.1 (862) [MQTT] Wrong MQTT authentication of client "shellyht-F391C4": Incorrect password
        2025-10-21 19:45:49.881  - info: shelly.1 (862) [MQTT] Client Close: (shellyht / shellyht-F391C4 / SHHT-1#F391C4#1) (false)
        2025-10-21 19:45:57.455  - error: shelly.1 (862) [MQTT] Wrong MQTT authentication of client "shellyht-F391C4": Incorrect password
        2025-10-21 19:45:57.461  - info: shelly.1 (862) [MQTT] Client Close: (shellyht / shellyht-F391C4 / SHHT-1#F391C4#1) (false)
        2025-10-21 19:46:44.068  - info: admin.0 (673) <== Disconnect system.user.admin from ::ffff:192.168.178.32
        2025-10-21 19:46:47.054  - info: broadlink2.0 (1273) interface to be used: { netmaskBits: 24, address: '192.168.178.79/24', addrs: [ 192, 168, 178, 79 ], cidr: '192.168.178.79/24', bcaddr: '192.168.178.255'
        2025-10-21 19:46:47.057  - info: broadlink2.0 (1273) discover  [ '192.168.178.49' ] from 0.0.0.0:38638
        2025-10-21 19:53:40.818  - info: admin.0 (673) ==> Connected system.user.admin from ::ffff:192.168.178.32
        iob diag has finished.
        oadlink2.0 (2546) discover [ '192.168.178.49' ] from 0.0.0.0:41771
          teil 1
          code_text
          ```pi@raspberrypi:~ $ iob logs --watch
          2025-10-21 19:01:34.561  - debug: netatmo-crawler.0 (1150) Saving station data for station: 2
          2025-10-21 19:01:34.589  - debug: netatmo-crawler.0 (1150) Saving data for station: 70:ee:50:17:9d:ba and measure: temperature
          2025-10-21 19:01:34.601  - debug: netatmo-crawler.0 (1150) Rounded value 14.9 to 14.9
          2025-10-21 19:01:34.617  - debug: netatmo-crawler.0 (1150) Saving data for station: 70:ee:50:17:9d:ba and measure: pressure
          2025-10-21 19:01:34.625  - debug: netatmo-crawler.0 (1150) Rounded value 998.6 to 998.6
          2025-10-21 19:01:34.631  - debug: netatmo-crawler.0 (1150) Saving data for station: 70:ee:50:17:9d:ba and measure: humidity
          2025-10-21 19:01:34.638  - debug: netatmo-crawler.0 (1150) Rounded value 75 to 75
          2025-10-21 19:01:34.645  - debug: netatmo-crawler.0 (1150) Working with stationUrl: https://weathermap.netatmo.com//?zoom=15&type=rain&param=hourly&stationid=70%3Aee%3A50%3A00%3Ac1%3A94&maplayer=Map&lang=undefined
          2025-10-21 19:01:34.645  - debug: netatmo-crawler.0 (1150) Going to get information for station: 3
          2025-10-21 19:01:34.646  - info: netatmo-crawler.0 (1150) Getting data for stationid:70:ee:50:00:c1:94
          2025-10-21 19:01:34.747  - debug: netatmo-crawler.0 (1150) Body:[{"_id":"70:ee:50:00:c1:94","place":{"location":[13.4704260000001,52.5162059412954],"timezone":"Europe/Berlin","country":"DE","altitude":46,"city":"Berlin","street":"Schreinerstraße"},"mark":10,"measures":{"02:00:00:00:c7:32":{"res":{"1761065514":[15.9,68]},"type":["temperature","humidity"]},"70:ee:50:00:c1:94":{"res":{"1761065534":[1000]},"type":["pressure"]},"05:00:00:00:19:9a":{"res":{"1761063779":[0]},"type":["rain"]}}}]
          2025-10-21 19:01:34.747  - debug: netatmo-crawler.0 (1150) Saving station data for station: 3
          2025-10-21 19:01:34.777  - debug: netatmo-crawler.0 (1150) Saving data for station: 70:ee:50:00:c1:94 and measure: temperature
          2025-10-21 19:01:34.785  - debug: netatmo-crawler.0 (1150) Rounded value 15.9 to 15.9
          2025-10-21 19:01:34.812  - debug: netatmo-crawler.0 (1150) Saving data for station: 70:ee:50:00:c1:94 and measure: rain
          2025-10-21 19:01:34.822  - debug: netatmo-crawler.0 (1150) Rounded value 0 to 0
          2025-10-21 19:01:35.166  - debug: netatmo-crawler.0 (1150) Body Rain_Today:{"body":[{"beg_time":1760997600,"value":[[0.6]]}],"status":"ok","time_exec":0.061701059341430664,"time_server":1761066095}
          2025-10-21 19:01:35.166  - debug: netatmo-crawler.0 (1150) Rain Today for Station 70:ee:50:00:c1:94 is: 0.6
          2025-10-21 19:01:35.169  - debug: netatmo-crawler.0 (1150) Rounded value 0.6 to 0.6
          2025-10-21 19:01:35.175  - debug: netatmo-crawler.0 (1150) Saved rain_today for station: 70:ee:50:00:c1:94
          2025-10-21 19:01:35.660  - debug: netatmo-crawler.0 (1150) Body Rain_Yesterday:[{"beg_time":1760911200,"value":[[0]]}]
          2025-10-21 19:01:35.660  - debug: netatmo-crawler.0 (1150) Rain Yesterday for Station 70:ee:50:00:c1:94 is: 0
          2025-10-21 19:01:35.664  - debug: netatmo-crawler.0 (1150) Rounded value 0 to 0
          2025-10-21 19:01:35.669  - debug: netatmo-crawler.0 (1150) Saved rain_yesterday for station: 70:ee:50:00:c1:94
          2025-10-21 19:01:35.812  - debug: netatmo-crawler.0 (1150) Body Rain_LastHour:[{"beg_time":1761062495,"value":[[0]]}]
          2025-10-21 19:01:35.813  - debug: netatmo-crawler.0 (1150) Rain Last Hour for Station 70:ee:50:00:c1:94 is: 0
          2025-10-21 19:01:35.817  - debug: netatmo-crawler.0 (1150) Rounded value 0 to 0
          2025-10-21 19:01:35.822  - debug: netatmo-crawler.0 (1150) Saved rain_lastHour for station: 70:ee:50:00:c1:94
          2025-10-21 19:01:35.829  - debug: netatmo-crawler.0 (1150) Saving data for station: 70:ee:50:00:c1:94 and measure: pressure
          2025-10-21 19:01:35.837  - debug: netatmo-crawler.0 (1150) Rounded value 1000 to 1000
          2025-10-21 19:01:35.842  - debug: netatmo-crawler.0 (1150) Saving data for station: 70:ee:50:00:c1:94 and measure: humidity
          2025-10-21 19:01:35.850  - debug: netatmo-crawler.0 (1150) Rounded value 68 to 68
          2025-10-21 19:01:35.855  - debug: netatmo-crawler.0 (1150) Working with stationUrl: https://weathermap.netatmo.com//?zoom=14.026073475931375&type=rain&param=hourly&stationid=70%3Aee%3A50%3A52%3Ae9%3Ac2&maplayer=Map&lang=undefined
          2025-10-21 19:01:35.856  - debug: netatmo-crawler.0 (1150) Going to get information for station: 4
          2025-10-21 19:01:35.857  - info: netatmo-crawler.0 (1150) Getting data for stationid:70:ee:50:52:e9:c2
          2025-10-21 19:01:35.949  - debug: netatmo-crawler.0 (1150) Body:[{"_id":"70:ee:50:52:e9:c2","place":{"location":[13.4855409,52.5401803],"timezone":"Europe/Berlin","country":"DE","altitude":59,"city":"Berlin","street":"Konrad-Wolf-Straße"},"mark":1,"measures":{"02:00:00:9d:23:d8":{"res":{"1761065832":[14.7,73]},"type":["temperature","humidity"]},"70:ee:50:52:e9:c2":{"res":{"1761065865":[1000.4]},"type":["pressure"]},"05:00:00:03:84:7c":{"res":{"1761065864":[0]},"type":["rain"]}}}]
          2025-10-21 19:01:35.949  - debug: netatmo-crawler.0 (1150) Saving station data for station: 4
          2025-10-21 19:01:35.977  - debug: netatmo-crawler.0 (1150) Saving data for station: 70:ee:50:52:e9:c2 and measure: temperature
          2025-10-21 19:01:35.984  - debug: netatmo-crawler.0 (1150) Rounded value 14.7 to 14.7
          2025-10-21 19:01:36.003  - debug: netatmo-crawler.0 (1150) Saving data for station: 70:ee:50:52:e9:c2 and measure: rain
          2025-10-21 19:01:36.011  - debug: netatmo-crawler.0 (1150) Rounded value 0 to 0
          2025-10-21 19:01:36.189  - debug: netatmo-crawler.0 (1150) Body Rain_Today:{"body":[{"beg_time":1760997600,"value":[[0]]}],"status":"ok","time_exec":0.05469322204589844,"time_server":1761066096}
          2025-10-21 19:01:36.190  - debug: netatmo-crawler.0 (1150) Rain Today for Station 70:ee:50:52:e9:c2 is: 0
          2025-10-21 19:01:36.193  - debug: netatmo-crawler.0 (1150) Rounded value 0 to 0
          2025-10-21 19:01:36.199  - debug: netatmo-crawler.0 (1150) Saved rain_today for station: 70:ee:50:52:e9:c2
          2025-10-21 19:01:36.421  - debug: netatmo-crawler.0 (1150) Body Rain_Yesterday:[{"beg_time":1760911200,"value":[[0]]}]
          2025-10-21 19:01:36.421  - debug: netatmo-crawler.0 (1150) Rain Yesterday for Station 70:ee:50:52:e9:c2 is: 0
          2025-10-21 19:01:36.424  - debug: netatmo-crawler.0 (1150) Rounded value 0 to 0
          2025-10-21 19:01:36.430  - debug: netatmo-crawler.0 (1150) Saved rain_yesterday for station: 70:ee:50:52:e9:c2
          2025-10-21 19:01:36.633  - debug: netatmo-crawler.0 (1150) Body Rain_LastHour:[{"beg_time":1761062496,"value":[[0]]}]
          2025-10-21 19:01:36.634  - debug: netatmo-crawler.0 (1150) Rain Last Hour for Station 70:ee:50:52:e9:c2 is: 0
          2025-10-21 19:01:36.637  - debug: netatmo-crawler.0 (1150) Rounded value 0 to 0
          2025-10-21 19:01:36.643  - debug: netatmo-crawler.0 (1150) Saved rain_lastHour for station: 70:ee:50:52:e9:c2
          2025-10-21 19:01:36.649  - debug: netatmo-crawler.0 (1150) Saving data for station: 70:ee:50:52:e9:c2 and measure: pressure
          2025-10-21 19:01:36.657  - debug: netatmo-crawler.0 (1150) Rounded value 1000.4 to 1000.4
          2025-10-21 19:01:36.663  - debug: netatmo-crawler.0 (1150) Saving data for station: 70:ee:50:52:e9:c2 and measure: humidity
          2025-10-21 19:01:36.670  - debug: netatmo-crawler.0 (1150) Rounded value 73 to 73
          2025-10-21 19:01:36.676  - debug: netatmo-crawler.0 (1150) Working with stationUrl: https://weathermap.netatmo.com//?zoom=14&type=rain&param=hourly&stationid=70%3Aee%3A50%3A33%3A4b%3Afc&maplayer=Map&lang=undefined
          2025-10-21 19:01:36.676  - debug: netatmo-crawler.0 (1150) Going to get information for station: 5
          2025-10-21 19:01:36.677  - info: netatmo-crawler.0 (1150) Getting data for stationid:70:ee:50:33:4b:fc
          2025-10-21 19:01:39.032  - debug: netatmo-crawler.0 (1150) Body:[{"_id":"70:ee:50:33:4b:fc","place":{"location":[13.4505570248038,52.5223887067962],"timezone":"Europe/Berlin","country":"DE","altitude":56,"city":"Berlin","street":"Straßmannstraße"},"mark":10,"measures":{"02:00:00:32:d9:da":{"res":{"1761065833":[15.4,77]},"type":["temperature","humidity"]},"70:ee:50:33:4b:fc":{"res":{"1761065875":[1001.9]},"type":["pressure"]},"05:00:00:07:14:d4":{"res":{"1761065872":[0]},"type":["rain"]}}}]
          2025-10-21 19:01:39.033  - debug: netatmo-crawler.0 (1150) Saving station data for station: 5
          2025-10-21 19:01:39.077  - debug: netatmo-crawler.0 (1150) Saving data for station: 70:ee:50:33:4b:fc and measure: temperature
          2025-10-21 19:01:39.087  - debug: netatmo-crawler.0 (1150) Rounded value 15.4 to 15.4
          2025-10-21 19:01:39.096  - debug: netatmo-crawler.0 (1150) Saving data for station: 70:ee:50:33:4b:fc and measure: rain
          2025-10-21 19:01:39.106  - debug: netatmo-crawler.0 (1150) Rounded value 0 to 0
          2025-10-21 19:01:39.252  - debug: netatmo-crawler.0 (1150) Body Rain_Today:{"body":[{"beg_time":1760997600,"value":[[1]]}],"status":"ok","time_exec":0.023659944534301758,"time_server":1761066099}
          2025-10-21 19:01:39.252  - debug: netatmo-crawler.0 (1150) Rain Today for Station 70:ee:50:33:4b:fc is: 1
          2025-10-21 19:01:39.266  - debug: netatmo-crawler.0 (1150) Rounded value 1 to 1
          2025-10-21 19:01:39.275  - debug: netatmo-crawler.0 (1150) Saved rain_today for station: 70:ee:50:33:4b:fc
          2025-10-21 19:01:39.433  - debug: netatmo-crawler.0 (1150) Body Rain_Yesterday:[{"beg_time":1760911200,"value":[[0]]}]
          2025-10-21 19:01:39.434  - debug: netatmo-crawler.0 (1150) Rain Yesterday for Station 70:ee:50:33:4b:fc is: 0
          2025-10-21 19:01:39.439  - debug: netatmo-crawler.0 (1150) Rounded value 0 to 0
          2025-10-21 19:01:39.447  - debug: netatmo-crawler.0 (1150) Saved rain_yesterday for station: 70:ee:50:33:4b:fc
          2025-10-21 19:01:39.678  - debug: netatmo-crawler.0 (1150) Body Rain_LastHour:[{"beg_time":1761062499,"value":[[0]]}]
          2025-10-21 19:01:39.679  - debug: netatmo-crawler.0 (1150) Rain Last Hour for Station 70:ee:50:33:4b:fc is: 0
          2025-10-21 19:01:39.684  - debug: netatmo-crawler.0 (1150) Rounded value 0 to 0
          2025-10-21 19:01:39.693  - debug: netatmo-crawler.0 (1150) Saved rain_lastHour for station: 70:ee:50:33:4b:fc
          2025-10-21 19:01:39.702  - debug: netatmo-crawler.0 (1150) Saving data for station: 70:ee:50:33:4b:fc and measure: pressure
          2025-10-21 19:01:39.712  - debug: netatmo-crawler.0 (1150) Rounded value 1001.9 to 1001.9
          2025-10-21 19:01:39.723  - debug: netatmo-crawler.0 (1150) Saving data for station: 70:ee:50:33:4b:fc and measure: humidity
          2025-10-21 19:01:39.732  - debug: netatmo-crawler.0 (1150) Rounded value 77 to 77
          2025-10-21 19:01:39.742  - debug: netatmo-crawler.0 (1150) all done, exiting
          2025-10-21 19:01:39.745  - info: netatmo-crawler.0 (1150) Terminated (NO_ERROR): Everything done. Going to terminate till next schedule
          2025-10-21 19:01:40.314  - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 having pid 1150 terminated with code 0 (NO_ERROR)
          2025-10-21 19:01:45.032  - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 in version "1.1.0" started with pid 1165
          2025-10-21 19:01:47.176  - debug: netatmo-crawler.0 (1165) Redis Objects: Use Redis connection: 127.0.0.1:9001
          2025-10-21 19:01:47.263  - debug: netatmo-crawler.0 (1165) Objects client ready ... initialize now
          2025-10-21 19:01:47.337  - debug: netatmo-crawler.0 (1165) Objects create System PubSub Client
          2025-10-21 19:01:47.339  - debug: netatmo-crawler.0 (1165) Objects create User PubSub Client
          2025-10-21 19:01:47.428  - debug: netatmo-crawler.0 (1165) Objects client initialize lua scripts
          2025-10-21 19:01:47.450  - debug: netatmo-crawler.0 (1165) Objects connected to redis: 127.0.0.1:9001
          2025-10-21 19:01:47.454  - silly: netatmo-crawler.0 (1165) redis psubscribe cfg.o.system.user.*
          2025-10-21 19:01:47.487  - silly: netatmo-crawler.0 (1165) redis psubscribe cfg.o.enum.*
          2025-10-21 19:01:47.492  - silly: netatmo-crawler.0 (1165) objectDB connected
          2025-10-21 19:01:47.497  - debug: netatmo-crawler.0 (1165) Redis States: Use Redis connection: 127.0.0.1:9000
          2025-10-21 19:01:47.569  - debug: netatmo-crawler.0 (1165) States create System PubSub Client
          2025-10-21 19:01:47.570  - debug: netatmo-crawler.0 (1165) States create User PubSub Client
          2025-10-21 19:01:47.659  - debug: netatmo-crawler.0 (1165) States connected to redis: 127.0.0.1:9000
          2025-10-21 19:01:47.660  - silly: netatmo-crawler.0 (1165) statesDB connected
          2025-10-21 19:01:48.048  - info: netatmo-crawler.0 (1165) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v22.21.0, js-controller: 7.0.7
          2025-10-21 19:01:48.075  - debug: netatmo-crawler.0 (1165) config stationUrls: https://weathermap.netatmo.com//?zoom=14&type=rain&param=hourly&stationid=70%3Aee%3A50%3A33%3A4b%3Afc&maplayer=Map&lang=undefined
          https://weathermap.netatmo.com//?zoom=14&type=rain&param=hourly&stationid=70%3Aee%3A50%3A17%3A9d%3Aba&maplayer=Map&lang=undefined
          2025-10-21 19:01:48.075  - debug: netatmo-crawler.0 (1165) Going to save station information with: id
          2025-10-21 19:01:48.077  - debug: netatmo-crawler.0 (1165) Trying to get token from state
          2025-10-21 19:01:48.100  - silly: netatmo-crawler.0 (1165) States system redis pmessage system.adapter.netatmo-crawler.0.logLevel/system.adapter.netatmo-crawler.0.logLevel:{"val":"silly","ack":true,"ts":1761066108080,"q":0,"from":"system.adapter.netatmo-crawler.0","lc":1732447437255}
          2025-10-21 19:01:48.178  - debug: netatmo-crawler.0 (1165) Working with stationUrl: https://weathermap.netatmo.com//?zoom=14&type=rain&param=hourly&stationid=70%3Aee%3A50%3A33%3A4b%3Afc&maplayer=Map&lang=undefined
          2025-10-21 19:01:48.180  - debug: netatmo-crawler.0 (1165) Going to get information for station: 1
          2025-10-21 19:01:48.184  - info: netatmo-crawler.0 (1165) Getting data for stationid:70:ee:50:33:4b:fc
          2025-10-21 19:01:48.372  - debug: netatmo-crawler.0 (1165) Body:[{"_id":"70:ee:50:33:4b:fc","place":{"location":[13.4505570248038,52.5223887067962],"timezone":"Europe/Berlin","country":"DE","altitude":56,"city":"Berlin","street":"Straßmannstraße"},"mark":10,"measures":{"02:00:00:32:d9:da":{"res":{"1761065833":[15.4,77]},"type":["temperature","humidity"]},"70:ee:50:33:4b:fc":{"res":{"1761065875":[1001.9]},"type":["pressure"]},"05:00:00:07:14:d4":{"res":{"1761065872":[0]},"type":["rain"]}}}]
          2025-10-21 19:01:48.373  - debug: netatmo-crawler.0 (1165) Saving station data for station: 1
          2025-10-21 19:01:48.417  - debug: netatmo-crawler.0 (1165) Saving data for station: 70:ee:50:33:4b:fc and measure: temperature
          2025-10-21 19:01:48.435  - debug: netatmo-crawler.0 (1165) Rounded value 15.4 to 15.4
          2025-10-21 19:01:48.441  - debug: netatmo-crawler.0 (1165) Saving data for station: 70:ee:50:33:4b:fc and measure: rain
          2025-10-21 19:01:48.451  - debug: netatmo-crawler.0 (1165) Rounded value 0 to 0
          2025-10-21 19:01:48.631  - debug: netatmo-crawler.0 (1165) Body Rain_Today:{"body":[{"beg_time":1760997600,"value":[[1]]}],"status":"ok","time_exec":0.023269176483154297,"time_server":1761066108}
          2025-10-21 19:01:48.631  - debug: netatmo-crawler.0 (1165) Rain Today for Station 70:ee:50:33:4b:fc is: 1
          2025-10-21 19:01:48.636  - debug: netatmo-crawler.0 (1165) Rounded value 1 to 1
          2025-10-21 19:01:48.643  - debug: netatmo-crawler.0 (1165) Saved rain_today for station: 70:ee:50:33:4b:fc
          2025-10-21 19:01:48.774  - debug: netatmo-crawler.0 (1165) Body Rain_Yesterday:[{"beg_time":1760911200,"value":[[0]]}]
          2025-10-21 19:01:48.775  - debug: netatmo-crawler.0 (1165) Rain Yesterday for Station 70:ee:50:33:4b:fc is: 0
          2025-10-21 19:01:48.780  - debug: netatmo-crawler.0 (1165) Rounded value 0 to 0
          2025-10-21 19:01:48.799  - debug: netatmo-crawler.0 (1165) Saved rain_yesterday for station: 70:ee:50:33:4b:fc
          2025-10-21 19:01:49.008  - debug: netatmo-crawler.0 (1165) Body Rain_LastHour:[{"beg_time":1761062508,"value":[[0]]}]
          2025-10-21 19:01:49.009  - debug: netatmo-crawler.0 (1165) Rain Last Hour for Station 70:ee:50:33:4b:fc is: 0
          2025-10-21 19:01:49.014  - debug: netatmo-crawler.0 (1165) Rounded value 0 to 0
          2025-10-21 19:01:49.021  - debug: netatmo-crawler.0 (1165) Saved rain_lastHour for station: 70:ee:50:33:4b:fc
          2025-10-21 19:01:49.028  - debug: netatmo-crawler.0 (1165) Saving data for station: 70:ee:50:33:4b:fc and measure: pressure
          2025-10-21 19:01:49.036  - debug: netatmo-crawler.0 (1165) Rounded value 1001.9 to 1001.9
          2025-10-21 19:01:49.043  - debug: netatmo-crawler.0 (1165) Saving data for station: 70:ee:50:33:4b:fc and measure: humidity
          2025-10-21 19:01:49.051  - debug: netatmo-crawler.0 (1165) Rounded value 77 to 77
          2025-10-21 19:01:49.057  - debug: netatmo-crawler.0 (1165) Working with stationUrl: https://weathermap.netatmo.com//?zoom=14&type=rain&param=hourly&stationid=70%3Aee%3A50%3A17%3A9d%3Aba&maplayer=Map&lang=undefined
          2025-10-21 19:01:49.057  - debug: netatmo-crawler.0 (1165) Going to get information for station: 2
          2025-10-21 19:01:49.058  - info: netatmo-crawler.0 (1165) Getting data for stationid:70:ee:50:17:9d:ba
          2025-10-21 19:01:50.680  - debug: netatmo-crawler.0 (1165) Body:[{"_id":"70:ee:50:17:9d:ba","place":{"location":[13.457895,52.523834],"timezone":"Europe/Berlin","country":"DE","altitude":48,"city":"Berlin","street":"Edith-Stein-Straße"},"mark":1,"measures":{"02:00:00:17:80:7a":{"res":{"1761065646":[14.9,75]},"type":["temperature","humidity"]},"70:ee:50:17:9d:ba":{"res":{"1761065660":[998.6]},"type":["pressure"]}}}]
          2025-10-21 19:01:50.681  - debug: netatmo-crawler.0 (1165) Saving station data for station: 2
          2025-10-21 19:01:50.712  - debug: netatmo-crawler.0 (1165) Saving data for station: 70:ee:50:17:9d:ba and measure: temperature
          2025-10-21 19:01:50.719  - debug: netatmo-crawler.0 (1165) Rounded value 14.9 to 14.9
          2025-10-21 19:01:50.729  - debug: netatmo-crawler.0 (1165) Saving data for station: 70:ee:50:17:9d:ba and measure: pressure
          2025-10-21 19:01:50.746  - debug: netatmo-crawler.0 (1165) Rounded value 998.6 to 998.6
          2025-10-21 19:01:50.751  - debug: netatmo-crawler.0 (1165) Saving data for station: 70:ee:50:17:9d:ba and measure: humidity
          2025-10-21 19:01:50.759  - debug: netatmo-crawler.0 (1165) Rounded value 75 to 75
          2025-10-21 19:01:50.765  - debug: netatmo-crawler.0 (1165) Working with stationUrl: https://weathermap.netatmo.com//?zoom=15&type=rain&param=hourly&stationid=70%3Aee%3A50%3A00%3Ac1%3A94&maplayer=Map&lang=undefined
          2025-10-21 19:01:50.765  - debug: netatmo-crawler.0 (1165) Going to get information for station: 3
          2025-10-21 19:01:50.766  - info: netatmo-crawler.0 (1165) Getting data for stationid:70:ee:50:00:c1:94
          2025-10-21 19:01:51.098  - debug: netatmo-crawler.0 (1165) Body:[{"_id":"70:ee:50:00:c1:94","place":{"location":[13.4704260000001,52.5162059412954],"timezone":"Europe/Berlin","country":"DE","altitude":46,"city":"Berlin","street":"Schreinerstraße"},"mark":10,"measures":{"02:00:00:00:c7:32":{"res":{"1761065514":[15.9,68]},"type":["temperature","humidity"]},"70:ee:50:00:c1:94":{"res":{"1761065534":[1000]},"type":["pressure"]},"05:00:00:00:19:9a":{"res":{"1761063779":[0]},"type":["rain"]}}}]
          2025-10-21 19:01:51.099  - debug: netatmo-crawler.0 (1165) Saving station data for station: 3
          2025-10-21 19:01:51.204  - debug: netatmo-crawler.0 (1165) Saving data for station: 70:ee:50:00:c1:94 and measure: temperature
          2025-10-21 19:01:51.212  - debug: netatmo-crawler.0 (1165) Rounded value 15.9 to 15.9
          2025-10-21 19:01:51.218  - debug: netatmo-crawler.0 (1165) Saving data for station: 70:ee:50:00:c1:94 and measure: rain
          2025-10-21 19:01:51.226  - debug: netatmo-crawler.0 (1165) Rounded value 0 to 0
          2025-10-21 19:01:51.402  - debug: netatmo-crawler.0 (1165) Body Rain_Today:{"body":[{"beg_time":1760997600,"value":[[0.6]]}],"status":"ok","time_exec":0.02463388442993164,"time_server":1761066111}
          2025-10-21 19:01:51.403  - debug: netatmo-crawler.0 (1165) Rain Today for Station 70:ee:50:00:c1:94 is: 0.6
          2025-10-21 19:01:51.408  - debug: netatmo-crawler.0 (1165) Rounded value 0.6 to 0.6
          2025-10-21 19:01:51.414  - debug: netatmo-crawler.0 (1165) Saved rain_today for station: 70:ee:50:00:c1:94
          2025-10-21 19:01:51.554  - debug: netatmo-crawler.0 (1165) Body Rain_Yesterday:[{"beg_time":1760911200,"value":[[0]]}]
          2025-10-21 19:01:51.554  - debug: netatmo-crawler.0 (1165) Rain Yesterday for Station 70:ee:50:00:c1:94 is: 0
          2025-10-21 19:01:51.558  - debug: netatmo-crawler.0 (1165) Rounded value 0 to 0
          2025-10-21 19:01:51.564  - debug: netatmo-crawler.0 (1165) Saved rain_yesterday for station: 70:ee:50:00:c1:94
          2025-10-21 19:01:51.752  - debug: netatmo-crawler.0 (1165) Body Rain_LastHour:[{"beg_time":1761062511,"value":[[0]]}]
          2025-10-21 19:01:51.753  - debug: netatmo-crawler.0 (1165) Rain Last Hour for Station 70:ee:50:00:c1:94 is: 0
          2025-10-21 19:01:51.757  - debug: netatmo-crawler.0 (1165) Rounded value 0 to 0
          2025-10-21 19:01:51.762  - debug: netatmo-crawler.0 (1165) Saved rain_lastHour for station: 70:ee:50:00:c1:94
          2025-10-21 19:01:51.769  - debug: netatmo-crawler.0 (1165) Saving data for station: 70:ee:50:00:c1:94 and measure: pressure
          2025-10-21 19:01:51.776  - debug: netatmo-crawler.0 (1165) Rounded value 1000 to 1000
          2025-10-21 19:01:51.783  - debug: netatmo-crawler.0 (1165) Saving data for station: 70:ee:50:00:c1:94 and measure: humidity
          2025-10-21 19:01:51.790  - debug: netatmo-crawler.0 (1165) Rounded value 68 to 68
          2025-10-21 19:01:51.796  - debug: netatmo-crawler.0 (1165) Working with stationUrl: https://weathermap.netatmo.com//?zoom=14.026073475931375&type=rain&param=hourly&stationid=70%3Aee%3A50%3A52%3Ae9%3Ac2&maplayer=Map&lang=undefined
          2025-10-21 19:01:51.797  - debug: netatmo-crawler.0 (1165) Going to get information for station: 4
          2025-10-21 19:01:51.798  - info: netatmo-crawler.0 (1165) Getting data for stationid:70:ee:50:52:e9:c2
          2025-10-21 19:01:51.936  - debug: netatmo-crawler.0 (1165) Body:[{"_id":"70:ee:50:52:e9:c2","place":{"location":[13.4855409,52.5401803],"timezone":"Europe/Berlin","country":"DE","altitude":59,"city":"Berlin","street":"Konrad-Wolf-Straße"},"mark":1,"measures":{"02:00:00:9d:23:d8":{"res":{"1761065832":[14.7,73]},"type":["temperature","humidity"]},"70:ee:50:52:e9:c2":{"res":{"1761065865":[1000.4]},"type":["pressure"]},"05:00:00:03:84:7c":{"res":{"1761065864":[0]},"type":["rain"]}}}]
          2025-10-21 19:01:51.937  - debug: netatmo-crawler.0 (1165) Saving station data for station: 4
          2025-10-21 19:01:51.966  - debug: netatmo-crawler.0 (1165) Saving data for station: 70:ee:50:52:e9:c2 and measure: temperature
          2025-10-21 19:01:51.973  - debug: netatmo-crawler.0 (1165) Rounded value 14.7 to 14.7
          2025-10-21 19:01:51.979  - debug: netatmo-crawler.0 (1165) Saving data for station: 70:ee:50:52:e9:c2 and measure: rain
          2025-10-21 19:01:51.986  - debug: netatmo-crawler.0 (1165) Rounded value 0 to 0
          2025-10-21 19:01:52.489  - debug: netatmo-crawler.0 (1165) Body Rain_Today:{"body":[{"beg_time":1760997600,"value":[[0]]}],"status":"ok","time_exec":0.02729201316833496,"time_server":1761066112}
          2025-10-21 19:01:52.490  - debug: netatmo-crawler.0 (1165) Rain Today for Station 70:ee:50:52:e9:c2 is: 0
          2025-10-21 19:01:52.493  - debug: netatmo-crawler.0 (1165) Rounded value 0 to 0
          2025-10-21 19:01:52.499  - debug: netatmo-crawler.0 (1165) Saved rain_today for station: 70:ee:50:52:e9:c2
          2025-10-21 19:01:52.630  - debug: netatmo-crawler.0 (1165) Body Rain_Yesterday:[{"beg_time":1760911200,"value":[[0]]}]
          2025-10-21 19:01:52.631  - debug: netatmo-crawler.0 (1165) Rain Yesterday for Station 70:ee:50:52:e9:c2 is: 0
          2025-10-21 19:01:52.634  - debug: netatmo-crawler.0 (1165) Rounded value 0 to 0
          2025-10-21 19:01:52.640  - debug: netatmo-crawler.0 (1165) Saved rain_yesterday for station: 70:ee:50:52:e9:c2
          2025-10-21 19:01:52.760  - debug: netatmo-crawler.0 (1165) Body Rain_LastHour:[{"beg_time":1761062512,"value":[[0]]}]
          2025-10-21 19:01:52.760  - debug: netatmo-crawler.0 (1165) Rain Last Hour for Station 70:ee:50:52:e9:c2 is: 0
          2025-10-21 19:01:52.764  - debug: netatmo-crawler.0 (1165) Rounded value 0 to 0
          2025-10-21 19:01:52.769  - debug: netatmo-crawler.0 (1165) Saved rain_lastHour for station: 70:ee:50:52:e9:c2
          2025-10-21 19:01:52.776  - debug: netatmo-crawler.0 (1165) Saving data for station: 70:ee:50:52:e9:c2 and measure: pressure
          2025-10-21 19:01:52.783  - debug: netatmo-crawler.0 (1165) Rounded value 1000.4 to 1000.4
          2025-10-21 19:01:52.789  - debug: netatmo-crawler.0 (1165) Saving data for station: 70:ee:50:52:e9:c2 and measure: humidity
          2025-10-21 19:01:52.796  - debug: netatmo-crawler.0 (1165) Rounded value 73 to 73
          2025-10-21 19:01:52.802  - debug: netatmo-crawler.0 (1165) Working with stationUrl: https://weathermap.netatmo.com//?zoom=14&type=rain&param=hourly&stationid=70%3Aee%3A50%3A33%3A4b%3Afc&maplayer=Map&lang=undefined
          2025-10-21 19:01:52.803  - debug: netatmo-crawler.0 (1165) Going to get information for station: 5
          2025-10-21 19:01:52.803  - info: netatmo-crawler.0 (1165) Getting data for stationid:70:ee:50:33:4b:fc
          2025-10-21 19:02:00.779  - info: broadlink2.0 (1127) interface to be used: { netmaskBits: 24, address: '192.168.178.79/24', addrs: [ 192, 168, 178, 79 ], cidr: '192.168.178.79/24', bcaddr: '192.168.178.255'
          2025-10-21 19:02:00.781  - info: broadlink2.0 (1127) discover  [ '192.168.178.49' ] from 0.0.0.0:43029
          2025-10-21 19:02:01.570  - debug: netatmo-crawler.0 (1165) Body:[{"_id":"70:ee:50:33:4b:fc","place":{"location":[13.4505570248038,52.5223887067962],"timezone":"Europe/Berlin","country":"DE","altitude":56,"city":"Berlin","street":"Straßmannstraße"},"mark":10,"measures":{"02:00:00:32:d9:da":{"res":{"1761065833":[15.4,77]},"type":["temperature","humidity"]},"70:ee:50:33:4b:fc":{"res":{"1761065875":[1001.9]},"type":["pressure"]},"05:00:00:07:14:d4":{"res":{"1761065872":[0]},"type":["rain"]}}}]
          2025-10-21 19:02:01.571  - debug: netatmo-crawler.0 (1165) Saving station data for station: 5
          2025-10-21 19:02:01.603  - debug: netatmo-crawler.0 (1165) Saving data for station: 70:ee:50:33:4b:fc and measure: temperature
          2025-10-21 19:02:01.611  - debug: netatmo-crawler.0 (1165) Rounded value 15.4 to 15.4
          2025-10-21 19:02:01.617  - debug: netatmo-crawler.0 (1165) Saving data for station: 70:ee:50:33:4b:fc and measure: rain
          2025-10-21 19:02:01.624  - debug: netatmo-crawler.0 (1165) Rounded value 0 to 0
          2025-10-21 19:02:01.906  - debug: netatmo-crawler.0 (1165) Body Rain_Today:{"body":[{"beg_time":1760997600,"value":[[1]]}],"status":"ok","time_exec":0.043231964111328125,"time_server":1761066121}
          2025-10-21 19:02:01.906  - debug: netatmo-crawler.0 (1165) Rain Today for Station 70:ee:50:33:4b:fc is: 1
          2025-10-21 19:02:01.909  - debug: netatmo-crawler.0 (1165) Rounded value 1 to 1
          2025-10-21 19:02:01.915  - debug: netatmo-crawler.0 (1165) Saved rain_today for station: 70:ee:50:33:4b:fc
          2025-10-21 19:02:02.077  - debug: netatmo-crawler.0 (1165) Body Rain_Yesterday:[{"beg_time":1760911200,"value":[[0]]}]
          2025-10-21 19:02:02.078  - debug: netatmo-crawler.0 (1165) Rain Yesterday for Station 70:ee:50:33:4b:fc is: 0
          2025-10-21 19:02:02.081  - debug: netatmo-crawler.0 (1165) Rounded value 0 to 0
          2025-10-21 19:02:02.087  - debug: netatmo-crawler.0 (1165) Saved rain_yesterday for station: 70:ee:50:33:4b:fc
          2025-10-21 19:02:02.257  - debug: netatmo-crawler.0 (1165) Body Rain_LastHour:[{"beg_time":1761062522,"value":[[0]]}]
          2025-10-21 19:02:02.257  - debug: netatmo-crawler.0 (1165) Rain Last Hour for Station 70:ee:50:33:4b:fc is: 0
          2025-10-21 19:02:02.262  - debug: netatmo-crawler.0 (1165) Rounded value 0 to 0
          2025-10-21 19:02:02.268  - debug: netatmo-crawler.0 (1165) Saved rain_lastHour for station: 70:ee:50:33:4b:fc
          2025-10-21 19:02:02.275  - debug: netatmo-crawler.0 (1165) Saving data for station: 70:ee:50:33:4b:fc and measure: pressure
          2025-10-21 19:02:02.283  - debug: netatmo-crawler.0 (1165) Rounded value 1001.9 to 1001.9
          2025-10-21 19:02:02.289  - debug: netatmo-crawler.0 (1165) Saving data for station: 70:ee:50:33:4b:fc and measure: humidity
          2025-10-21 19:02:02.297  - debug: netatmo-crawler.0 (1165) Rounded value 77 to 77
          2025-10-21 19:02:02.314  - debug: netatmo-crawler.0 (1165) all done, exiting
          2025-10-21 19:02:02.315  - info: netatmo-crawler.0 (1165) Terminated (NO_ERROR): Everything done. Going to terminate till next schedule
          2025-10-21 19:02:02.880  - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 having pid 1165 terminated with code 0 (NO_ERROR)
          2025-10-21 19:03:00.778  - info: broadlink2.0 (1127) interface to be used: { netmaskBits: 24, address: '192.168.178.79/24', addrs: [ 192, 168, 178, 79 ], cidr: '192.168.178.79/24', bcaddr: '192.168.178.255'
          2025-10-21 19:03:00.779  - info: broadlink2.0 (1127) discover  [ '192.168.178.49' ] from 0.0.0.0:37825
          2025-10-21 19:03:33.486  - info: shelly.0 (832) [CoAP] Device 192.168.178.225 (shellydw2 / shellydw2-AA920D / SHDW-2#AA920D#1) connected! Polltime set to 3600 sec.
          2025-10-21 19:05:00.780  - info: broadlink2.0 (1127) interface to be used: { netmaskBits: 24, address: '192.168.178.79/24', addrs: [ 192, 168, 178, 79 ], cidr: '192.168.178.79/24', bcaddr: '192.168.178.255'
          2025-10-21 19:05:00.782  - info: broadlink2.0 (1127) discover  [ '192.168.178.49' ] from 0.0.0.0:43601
          2025-10-21 19:05:40.039  - error: shelly.1 (862) [MQTT] Wrong MQTT authentication of client "shellyht-F391C4": Incorrect password
          2025-10-21 19:05:40.057  - info: shelly.1 (862) [MQTT] Client Close: (shellyht / shellyht-F391C4 / SHHT-1#F391C4#1) (false)
          2025-10-21 19:05:42.077  - error: shelly.1 (862) [MQTT] Wrong MQTT authentication of client "shellyht-F391C4": Incorrect password
          2025-10-21 19:05:42.084  - info: shelly.1 (862) [MQTT] Client Close: (shellyht / shellyht-F391C4 / SHHT-1#F391C4#1) (false)
          2025-10-21 19:05:45.901  - error: shelly.1 (862) [MQTT] Wrong MQTT authentication of client "shellyht-F391C4": Incorrect password
          2025-10-21 19:05:45.909  - info: shelly.1 (862) [MQTT] Client Close: (shellyht / shellyht-F391C4 / SHHT-1#F391C4#1) (false)
          2025-10-21 19:05:54.495  - error: shelly.1 (862) [MQTT] Wrong MQTT authentication of client "shellyht-F391C4": Incorrect password
          2025-10-21 19:05:54.544  - info: shelly.1 (862) [MQTT] Client Close: (shellyht / shellyht-F391C4 / SHHT-1#F391C4#1) (false)
          2025-10-21 19:08:01.690  - info: host.raspberrypi stopInstance system.adapter.alexa2.0 (force=false, process=true)
          2025-10-21 19:08:01.695  - info: alexa2.0 (1078) Got terminate signal TERMINATE_YOURSELF
          2025-10-21 19:08:01.698  - info: alexa2.0 (1078) terminating
          2025-10-21 19:08:01.701  - info: alexa2.0 (1078) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2025-10-21 19:08:01.745  - info: host.raspberrypi stopInstance system.adapter.alexa2.0 send kill signal
          2025-10-21 19:08:02.203  - info: alexa2.0 (1078) terminating
          2025-10-21 19:08:02.296  - info: host.raspberrypi instance system.adapter.alexa2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2025-10-21 19:08:05.938  - info: host.raspberrypi instance system.adapter.alexa2.0 in version "3.27.3" started with pid 1185
          2025-10-21 19:08:08.691  - info: alexa2.0 (1185) starting. Version 3.27.3 in /opt/iobroker/node_modules/iobroker.alexa2, node: v22.21.0, js-controller: 7.0.7
          2025-10-21 19:08:08.751  - info: alexa2.0 (1185) Starting Alexa2 adapter ... it can take several minutes to initialize all data. Please be patient! A done message is logged.
          2025-10-21 19:08:08.754  - error: alexa2.0 (1185) Adapter seems to have issues and crashed three times in a row. Disabling!! Please start again and check logs.
          2025-10-21 19:08:09.757  - info: alexa2.0 (1185) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2025-10-21 19:08:10.365  - info: host.raspberrypi instance system.adapter.alexa2.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
          2025-10-21 19:08:10.365  - info: host.raspberrypi Do not restart adapter system.adapter.alexa2.0 because desired by instance
          2025-10-21 19:08:13.700  - info: admin.0 (673) <== Disconnect system.user.admin from ::ffff:192.168.178.32
          2025-10-21 19:08:51.600  - info: host.raspberrypi instance system.adapter.alexa2.0 in version "3.27.3" started with pid 1200
          2025-10-21 19:08:54.533  - info: alexa2.0 (1200) starting. Version 3.27.3 in /opt/iobroker/node_modules/iobroker.alexa2, node: v22.21.0, js-controller: 7.0.7
          2025-10-21 19:08:54.594  - info: alexa2.0 (1200) Starting Alexa2 adapter ... it can take several minutes to initialize all data. Please be patient! A done message is logged.
          2025-10-21 19:08:55.350  - error: alexa2.0 (1200) Error:
          2025-10-21 19:08:55.351  - error: alexa2.0 (1200) Error: Please open http://192.168.178.43:44533/ with your browser and login to Amazon. The cookie will be output here after successfull login.
          2025-10-21 19:08:59.070  - info: admin.0 (673) ==> Connected system.user.admin from ::ffff:192.168.178.32
          2025-10-21 19:09:00.798  - info: broadlink2.0 (1127) interface to be used: { netmaskBits: 24, address: '192.168.178.79/24', addrs: [ 192, 168, 178, 79 ], cidr: '192.168.178.79/24', bcaddr: '192.168.178.255'
          2025-10-21 19:09:00.803  - info: broadlink2.0 (1127) discover  [ '192.168.178.49' ] from 0.0.0.0:46563
          2025-10-21 19:15:40.986  - error: shelly.1 (862) [MQTT] Wrong MQTT authentication of client "shellyht-F391C4": Incorrect password
          2025-10-21 19:15:40.997  - info: shelly.1 (862) [MQTT] Client Close: (shellyht / shellyht-F391C4 / SHHT-1#F391C4#1) (false)
          2025-10-21 19:15:43.061  - error: shelly.1 (862) [MQTT] Wrong MQTT authentication of client "shellyht-F391C4": Incorrect password
          2025-10-21 19:15:43.067  - info: shelly.1 (862) [MQTT] Client Close: (shellyht / shellyht-F391C4 / SHHT-1#F391C4#1) (false)
          2025-10-21 19:15:46.743  - error: shelly.1 (862) [MQTT] Wrong MQTT authentication of client "shellyht-F391C4": Incorrect password
          2025-10-21 19:15:46.749  - info: shelly.1 (862) [MQTT] Client Close: (shellyht / shellyht-F391C4 / SHHT-1#F391C4#1) (false)
          2025-10-21 19:15:55.308  - error: shelly.1 (862) [MQTT] Wrong MQTT authentication of client "shellyht-F391C4": Incorrect password
          2025-10-21 19:15:55.314  - info: shelly.1 (862) [MQTT] Client Close: (shellyht / shellyht-F391C4 / SHHT-1#F391C4#1) (false)
          2025-10-21 19:17:00.813  - info: broadlink2.0 (1127) interface to be used: { netmaskBits: 24, address: '192.168.178.79/24', addrs: [ 192, 168, 178, 79 ], cidr: '192.168.178.79/24', bcaddr: '192.168.178.255'
          2025-10-21 19:17:00.814  - info: broadlink2.0 (1127) discover  [ '192.168.178.49' ] from 0.0.0.0:54642
          2025-10-21 19:23:35.815  - info: host.raspberrypi stopInstance system.adapter.alexa2.0 (force=false, process=true)
          2025-10-21 19:23:35.821  - info: alexa2.0 (1200) Got terminate signal TERMINATE_YOURSELF
          2025-10-21 19:23:35.823  - info: alexa2.0 (1200) terminating
          2025-10-21 19:23:35.825  - info: alexa2.0 (1200) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2025-10-21 19:23:35.912  - info: host.raspberrypi stopInstance system.adapter.alexa2.0 send kill signal
          2025-10-21 19:23:36.326  - info: alexa2.0 (1200) terminating
          2025-10-21 19:23:36.422  - info: host.raspberrypi instance system.adapter.alexa2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2025-10-21 19:23:40.035  - info: host.raspberrypi instance system.adapter.alexa2.0 in version "3.27.3" started with pid 1236
          2025-10-21 19:23:42.894  - info: alexa2.0 (1236) starting. Version 3.27.3 in /opt/iobroker/node_modules/iobroker.alexa2, node: v22.21.0, js-controller: 7.0.7
          2025-10-21 19:23:42.953  - info: alexa2.0 (1236) Starting Alexa2 adapter ... it can take several minutes to initialize all data. Please be patient! A done message is logged.
          2025-10-21 19:23:42.956  - error: alexa2.0 (1236) Adapter seems to have issues and crashed three times in a row. Disabling!! Please start again and check logs.
          2025-10-21 19:23:43.958  - info: alexa2.0 (1236) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2025-10-21 19:23:44.555  - info: host.raspberrypi instance system.adapter.alexa2.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
          2025-10-21 19:23:44.555  - info: host.raspberrypi Do not restart adapter system.adapter.alexa2.0 because desired by instance
          2025-10-21 19:23:48.268  - info: host.raspberrypi instance system.adapter.alexa2.0 in version "3.27.3" started with pid 1252
          2025-10-21 19:23:50.936  - info: alexa2.0 (1252) starting. Version 3.27.3 in /opt/iobroker/node_modules/iobroker.alexa2, node: v22.21.0, js-controller: 7.0.7
          2025-10-21 19:23:50.996  - info: alexa2.0 (1252) Starting Alexa2 adapter ... it can take several minutes to initialize all data. Please be patient! A done message is logged.
          2025-10-21 19:23:51.286  - error: alexa2.0 (1252) Error:
          2025-10-21 19:23:51.287  - error: alexa2.0 (1252) Error: Please open http://192.168.178.43:33373/ with your browser and login to Amazon. The cookie will be output here after successfull login.
          2025-10-21 19:23:53.916  - info: admin.0 (673) <== Disconnect system.user.admin from ::ffff:192.168.178.32
          2025-10-21 19:23:59.641  - info: admin.0 (673) ==> Connected system.user.admin from ::ffff:192.168.178.32
          2025-10-21 19:24:25.043  - info: admin.0 (673) <== Disconnect system.user.admin from ::ffff:192.168.178.32
          2025-10-21 19:25:42.794  - error: shelly.1 (862) [MQTT] Wrong MQTT authentication of client "shellyht-F391C4": Incorrect password
          2025-10-21 19:25:42.835  - info: shelly.1 (862) [MQTT] Client Close: (shellyht / shellyht-F391C4 / SHHT-1#F391C4#1) (false)
          2025-10-21 19:25:44.783  - error: shelly.1 (862) [MQTT] Wrong MQTT authentication of client "shellyht-F391C4": Incorrect password
          2025-10-21 19:25:44.794  - info: shelly.1 (862) [MQTT] Client Close: (shellyht / shellyht-F391C4 / SHHT-1#F391C4#1) (false)
          2025-10-21 19:25:48.715  - error: shelly.1 (862) [MQTT] Wrong MQTT authentication of client "shellyht-F391C4": Incorrect password
          2025-10-21 19:25:48.726  - info: shelly.1 (862) [MQTT] Client Close: (shellyht / shellyht-F391C4 / SHHT-1#F391C4#1) (false)
          2025-10-21 19:25:56.454  - error: shelly.1 (862) [MQTT] Wrong MQTT authentication of client "shellyht-F391C4": Incorrect password
          2025-10-21 19:25:56.465  - info: shelly.1 (862) [MQTT] Client Close: (shellyht / shellyht-F391C4 / SHHT-1#F391C4#1) (false)
          2025-10-21 19:27:25.586  - info: admin.0 (673) ==> Connected system.user.admin from ::ffff:192.168.178.32
          2025-10-21 19:30:36.683  - info: shelly.0 (832) [CoAP] Device 192.168.178.226 (shellydw2 / shellydw2-AAB370 / SHDW-2#AAB370#1) connected! Polltime set to 3600 sec.
          2025-10-21 19:31:00.021  - info: broadlink2.0 (1127) Scheduled restart.
          2025-10-21 19:31:00.022  - info: broadlink2.0 (1127) Close all connections...
          2025-10-21 19:31:00.024  - info: broadlink2.0 (1127) Adapter disconnected and stopped with dostop(null) and callback(true)
          2025-10-21 19:31:00.070  - info: broadlink2.0 (1127) terminating
          2025-10-21 19:31:00.072  - info: broadlink2.0 (1127) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          2025-10-21 19:31:00.074  - info: broadlink2.0 (1127) terminating
          2025-10-21 19:31:00.529  - info: broadlink2.0 (1127) terminating
          2025-10-21 19:31:00.708  - info: host.raspberrypi instance system.adapter.broadlink2.0 scheduled normal terminated and will be restarted on schedule.
          2025-10-21 19:31:00.709  - info: host.raspberrypi Restart adapter system.adapter.broadlink2.0 because enabled
          2025-10-21 19:31:02.390  - info: host.raspberrypi instance system.adapter.broadlink2.0 in version "2.3.0" started with pid 1273
          2025-10-21 19:31:04.647  - info: broadlink2.0 (1273) starting. Version 2.3.0 in /opt/iobroker/node_modules/iobroker.broadlink2, node: v22.21.0, js-controller: 7.0.7
          2025-10-21 19:31:04.909  - info: broadlink2.0 (1273) broadlink2 initialization started...
          2025-10-21 19:31:04.914  - info: broadlink2.0 (1273) Scanning additional IP's: 192.168.178.86
          2025-10-21 19:31:04.915  - info: broadlink2.0 (1273) Devices to add: 0x649b=RM4P
          2025-10-21 19:31:04.915  - info: broadlink2.0 (1273) Devices to rename:
          2025-10-21 19:31:04.917  - info: broadlink2.0 (1273) broadlink2 has 2 old devices!
          2025-10-21 19:31:04.922  - info: broadlink2.0 (1273) interface to be used: { netmaskBits: 24, address: '192.168.178.79/24', addrs: [ 192, 168, 178, 79 ], cidr: '192.168.178.79/24', bcaddr: '192.168.178.255'
          2025-10-21 19:31:04.923  - info: broadlink2.0 (1273) macObjects: [ '78:0f:77:00:cd:a0', 'ec:0b:ae:3d:d2:34' ]
          2025-10-21 19:31:05.104  - info: broadlink2.0 (1273) Discover Broadlink devices for 10sec on broadlink2.0
          2025-10-21 19:31:05.127  - info: broadlink2.0 (1273) interface to be used: { netmaskBits: 24, address: '192.168.178.79/24', addrs: [ 192, 168, 178, 79 ], cidr: '192.168.178.79/24', bcaddr: '192.168.178.255'
          2025-10-21 19:31:05.129  - info: broadlink2.0 (1273) discover  [ '192.168.178.255', '255.255.255.255', '224.0.0.251' ] from 0.0.0.0:44978
          2025-10-21 19:31:05.240  - info: broadlink2.0 (1273) Device RM:BroadLink-WiFi-Device-3d-d2-34 detected: address=192.168.178.86, mac=ec:0b:ae:3d:d2:34, typ=RM4P, id=0x649b devtype=rm4p
          2025-10-21 19:31:10.358  - info: broadlink2.0 (1273) interface to be used: { netmaskBits: 24, address: '192.168.178.79/24', addrs: [ 192, 168, 178, 79 ], cidr: '192.168.178.79/24', bcaddr: '192.168.178.255'
          2025-10-21 19:31:10.359  - info: broadlink2.0 (1273) discover  [ '192.168.178.86' ] from 0.0.0.0:42395
          2025-10-21 19:31:14.655  - warn: broadlink2.0 (1273) device RM:RMPROPLUS-00-cd-a0 not found, please rescan later again or delete it! It was: 192.168.178.49,80,10141,智能遥控,0,[object Object],78:0f:77:00:cd:a0,RMP,RM:RMPROPLUS-00-cd-a0,0x279d,RM3 Pro Plus,RM:RMPROPLUS-00-cd-a0,RMPROPLUS-00-cd-a0,57
          2025-10-21 19:31:14.751  - info: broadlink2.0 (1273) interface to be used: { netmaskBits: 24, address: '192.168.178.79/24', addrs: [ 192, 168, 178, 79 ], cidr: '192.168.178.79/24', bcaddr: '192.168.178.255'
          2025-10-21 19:31:14.753  - info: broadlink2.0 (1273) discover  [ '192.168.178.49' ] from 0.0.0.0:41749
          2025-10-21 19:31:15.891  - info: admin.0 (673) <== Disconnect system.user.admin from ::ffff:192.168.178.32
          2025-10-21 19:31:16.962  - info: broadlink2.0 (1273) Poll every 15 secods.
          2025-10-21 19:31:16.963  - info: broadlink2.0 (1273) broadlink2.0 started and found 1 devices named RM:BroadLink-WiFi-Device-3d-d2-34
          2025-10-21 19:31:16.963  - info: broadlink2.0 (1273) 1 were not found: RM:RMPROPLUS-00-cd-a0
          2025-10-21 19:31:16.964  - info: broadlink2.0 (1273) found macs: ec:0b:ae:3d:d2:34
          2025-10-21 19:31:47.012  - info: broadlink2.0 (1273) interface to be used: { netmaskBits: 24, address: '192.168.178.79/24', addrs: [ 192, 168, 178, 79 ], cidr: '192.168.178.79/24', bcaddr: '192.168.178.255'
          2025-10-21 19:31:47.014  - info: broadlink2.0 (1273) discover  [ '192.168.178.49' ] from 0.0.0.0:53771
          2025-10-21 19:32:47.020  - info: broadlink2.0 (1273) interface to be used: { netmaskBits: 24, address: '192.168.178.79/24', addrs: [ 192, 168, 178, 79 ], cidr: '192.168.178.79/24', bcaddr: '192.168.178.255'
          2025-10-21 19:32:47.022  - info: broadlink2.0 (1273) discover  [ '192.168.178.49' ] from 0.0.0.0:33324
          2025-10-21 19:34:47.017  - info: broadlink2.0 (1273) interface to be used: { netmaskBits: 24, address: '192.168.178.79/24', addrs: [ 192, 168, 178, 79 ], cidr: '192.168.178.79/24', bcaddr: '192.168.178.255'
          2025-10-21 19:34:47.018  - info: broadlink2.0 (1273) discover  [ '192.168.178.49' ] from 0.0.0.0:43019
          2025-10-21 19:35:42.806  - error: shelly.1 (862) [MQTT] Wrong MQTT authentication of client "shellyht-F391C4": Incorrect password
          2025-10-21 19:35:42.814  - info: shelly.1 (862) [MQTT] Client Close: (shellyht / shellyht-F391C4 / SHHT-1#F391C4#1) (false)
          2025-10-21 19:55:45.106  - error: shelly.1 (862) [MQTT] Wrong MQTT authentication of client "shellyht-F391C4": Incorrect password
          2025-10-21 19:55:45.116  - info: shelly.1 (862) [MQTT] Client Close: (shellyht / shellyht-F391C4 / SHHT-1#F391C4#1) (false)
          2025-10-21 19:55:46.991  - error: shelly.1 (862) [MQTT] Wrong MQTT authentication of client "shellyht-F391C4": Incorrect password
          2025-10-21 19:55:46.999  - info: shelly.1 (862) [MQTT] Client Close: (shellyht / shellyht-F391C4 / SHHT-1#F391C4#1) (false)
          2025-10-21 19:55:51.111  - error: shelly.1 (862) [MQTT] Wrong MQTT authentication of client "shellyht-F391C4": Incorrect password
          2025-10-21 19:55:51.129  - info: shelly.1 (862) [MQTT] Client Close: (shellyht / shellyht-F391C4 / SHHT-1#F391C4#1) (false)
          2025-10-21 19:55:58.533  - error: shelly.1 (862) [MQTT] Wrong MQTT authentication of client "shellyht-F391C4": Incorrect password
          2025-10-21 19:55:58.537  - info: shelly.1 (862) [MQTT] Client Close: (shellyht / shellyht-F391C4 / SHHT-1#F391C4#1) (false)
          2025-10-21 20:01:00.026  - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 in version "1.1.0" started with pid 2535
          2025-10-21 20:01:00.028  - info: broadlink2.0 (1273) Scheduled restart.
          2025-10-21 20:01:00.030  - info: broadlink2.0 (1273) Close all connections...
          2025-10-21 20:01:00.035  - info: broadlink2.0 (1273) Adapter disconnected and stopped with dostop(null) and callback(true)
          2025-10-21 20:01:00.061  - info: broadlink2.0 (1273) terminating
          2025-10-21 20:01:00.063  - info: broadlink2.0 (1273) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
          2025-10-21 20:01:00.065  - info: broadlink2.0 (1273) terminating
          2025-10-21 20:01:00.066  - info: broadlink2.0 (1273) terminating
          2025-10-21 20:01:00.537  - info: broadlink2.0 (1273) terminating
          2025-10-21 20:01:00.670  - info: host.raspberrypi instance system.adapter.broadlink2.0 scheduled normal terminated and will be restarted on schedule.
          2025-10-21 20:01:00.670  - info: host.raspberrypi Restart adapter system.adapter.broadlink2.0 because enabled
          2025-10-21 20:01:02.391  - debug: netatmo-crawler.0 (2535) Redis Objects: Use Redis connection: 127.0.0.1:9001
          2025-10-21 20:01:02.468  - debug: netatmo-crawler.0 (2535) Objects client ready ... initialize now
          2025-10-21 20:01:02.538  - debug: netatmo-crawler.0 (2535) Objects create System PubSub Client
          2025-10-21 20:01:02.545  - debug: netatmo-crawler.0 (2535) Objects create User PubSub Client
          2025-10-21 20:01:02.764  - debug: netatmo-crawler.0 (2535) Objects client initialize lua scripts
          2025-10-21 20:01:02.778  - info: host.raspberrypi instance system.adapter.broadlink2.0 in version "2.3.0" started with pid 2546
          2025-10-21 20:01:02.785  - debug: netatmo-crawler.0 (2535) Objects connected to redis: 127.0.0.1:9001
          2025-10-21 20:01:02.790  - silly: netatmo-crawler.0 (2535) redis psubscribe cfg.o.system.user.*
          2025-10-21 20:01:02.826  - silly: netatmo-crawler.0 (2535) redis psubscribe cfg.o.enum.*
          2025-10-21 20:01:02.831  - silly: netatmo-crawler.0 (2535) objectDB connected
          2025-10-21 20:01:02.836  - debug: netatmo-crawler.0 (2535) Redis States: Use Redis connection: 127.0.0.1:9000
          2025-10-21 20:01:02.862  - debug: netatmo-crawler.0 (2535) States create System PubSub Client
          2025-10-21 20:01:02.864  - debug: netatmo-crawler.0 (2535) States create User PubSub Client
          2025-10-21 20:01:02.952  - debug: netatmo-crawler.0 (2535) States connected to redis: 127.0.0.1:9000
          2025-10-21 20:01:02.953  - silly: netatmo-crawler.0 (2535) statesDB connected
          2025-10-21 20:01:03.143  - info: netatmo-crawler.0 (2535) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v22.21.0, js-controller: 7.0.7
          2025-10-21 20:01:03.170  - debug: netatmo-crawler.0 (2535) config stationUrls: https://weathermap.netatmo.com//?zoom=14&type=rain&param=hourly&stationid=70%3Aee%3A50%3A33%3A4b%3Afc&maplayer=Map&lang=undefined
          2025-10-21 20:01:03.171  - debug: netatmo-crawler.0 (2535) Going to save station information with: id
          2025-10-21 20:01:03.173  - debug: netatmo-crawler.0 (2535) Trying to get token from state
          2025-10-21 20:01:03.198  - silly: netatmo-crawler.0 (2535) States system redis pmessage system.adapter.netatmo-crawler.0.logLevel/system.adapter.netatmo-crawler.0.logLevel:{"val":"silly","ack":true,"ts":1761069663176,"q":0,"from":"system.adapter.netatmo-crawler.0","lc":1732447437255}
          2025-10-21 20:01:03.204  - debug: netatmo-crawler.0 (2535) Working with stationUrl: https://weathermap.netatmo.com//?zoom=14&type=rain&param=hourly&stationid=70%3Aee%3A50%3A33%3A4b%3Afc&maplayer=Map&lang=undefined
          2025-10-21 20:01:03.206  - debug: netatmo-crawler.0 (2535) Going to get information for station: 1
          2025-10-21 20:01:03.210  - info: netatmo-crawler.0 (2535) Getting data for stationid:70:ee:50:33:4b:fc
          2025-10-21 20:01:03.464  - debug: netatmo-crawler.0 (2535) Body:[{"_id":"70:ee:50:33:4b:fc","place":{"location":[13.4505570248038,52.5223887067962],"timezone":"Europe/Berlin","country":"DE","altitude":56,"city":"Berlin","street":"Straßmannstraße"},"mark":10,"measures":{"02:00:00:32:d9:da":{"res":{"1761069473":[15.1,79]},"type":["temperature","humidity"]},"70:ee:50:33:4b:fc":{"res":{"1761069505":[1002.1]},"type":["pressure"]},"05:00:00:07:14:d4":{"res":{"1761069499":[0]},"type":["rain"]}}}]
          2025-10-21 20:01:03.466  - debug: netatmo-crawler.0 (2535) Saving station data for station: 1
          2025-10-21 20:01:03.510  - debug: netatmo-crawler.0 (2535) Saving data for station: 70:ee:50:33:4b:fc and measure: temperature
          2025-10-21 20:01:03.521  - debug: netatmo-crawler.0 (2535) Rounded value 15.1 to 15.1
          2025-10-21 20:01:03.529  - debug: netatmo-crawler.0 (2535) Saving data for station: 70:ee:50:33:4b:fc and measure: rain
          2025-10-21 20:01:03.542  - debug: netatmo-crawler.0 (2535) Rounded value 0 to 0
          2025-10-21 20:01:03.674  - debug: netatmo-crawler.0 (2535) Body Rain_Today:{"body":[{"beg_time":1760997600,"value":[[1]]}],"status":"ok","time_exec":0.02438807487487793,"time_server":1761069663}
          2025-10-21 20:01:03.674  - debug: netatmo-crawler.0 (2535) Rain Today for Station 70:ee:50:33:4b:fc is: 1
          2025-10-21 20:01:03.679  - debug: netatmo-crawler.0 (2535) Rounded value 1 to 1
          2025-10-21 20:01:03.687  - debug: netatmo-crawler.0 (2535) Saved rain_today for station: 70:ee:50:33:4b:fc
          2025-10-21 20:01:03.821  - debug: netatmo-crawler.0 (2535) Body Rain_Yesterday:[{"beg_time":1760911200,"value":[[0]]}]
          2025-10-21 20:01:03.821  - debug: netatmo-crawler.0 (2535) Rain Yesterday for Station 70:ee:50:33:4b:fc is: 0
          2025-10-21 20:01:03.826  - debug: netatmo-crawler.0 (2535) Rounded value 0 to 0
          2025-10-21 20:01:03.833  - debug: netatmo-crawler.0 (2535) Saved rain_yesterday for station: 70:ee:50:33:4b:fc
          2025-10-21 20:01:03.975  - debug: netatmo-crawler.0 (2535) Body Rain_LastHour:[{"beg_time":1761066063,"value":[[0]]}]
          2025-10-21 20:01:03.976  - debug: netatmo-crawler.0 (2535) Rain Last Hour for Station 70:ee:50:33:4b:fc is: 0
          2025-10-21 20:01:03.982  - debug: netatmo-crawler.0 (2535) Rounded value 0 to 0
          2025-10-21 20:01:04.012  - debug: netatmo-crawler.0 (2535) Saved rain_lastHour for station: 70:ee:50:33:4b:fc
          2025-10-21 20:01:04.020  - debug: netatmo-crawler.0 (2535) Saving data for station: 70:ee:50:33:4b:fc and measure: pressure
          2025-10-21 20:01:04.031  - debug: netatmo-crawler.0 (2535) Rounded value 1002.1 to 1002.1
          2025-10-21 20:01:04.039  - debug: netatmo-crawler.0 (2535) Saving data for station: 70:ee:50:33:4b:fc and measure: humidity
          2025-10-21 20:01:04.054  - debug: netatmo-crawler.0 (2535) Rounded value 79 to 79
          2025-10-21 20:01:04.070  - debug: netatmo-crawler.0 (2535) Working with stationUrl: https://weathermap.netatmo.com//?zoom=14&type=rain&param=hourly&stationid=70%3Aee%3A50%3A17%3A9d%3Aba&maplayer=Map&lang=undefined
          2025-10-21 20:01:04.070  - debug: netatmo-crawler.0 (2535) Going to get information for station: 2
          2025-10-21 20:01:04.071  - info: netatmo-crawler.0 (2535) Getting data for stationid:70:ee:50:17:9d:ba
          2025-10-21 20:01:04.315  - debug: netatmo-crawler.0 (2535) Body:[{"_id":"70:ee:50:17:9d:ba","place":{"location":[13.457895,52.523834],"timezone":"Europe/Berlin","country":"DE","altitude":48,"city":"Berlin","street":"Edith-Stein-Straße"},"mark":1,"measures":{"02:00:00:17:80:7a":{"res":{"1761069287":[14.3,74]},"type":["temperature","humidity"]},"70:ee:50:17:9d:ba":{"res":{"1761069298":[998.8]},"type":["pressure"]}}}]
          2025-10-21 20:01:04.321  - debug: netatmo-crawler.0 (2535) Saving station data for station: 2
          2025-10-21 20:01:04.415  - debug: netatmo-crawler.0 (2535) Saving data for station: 70:ee:50:17:9d:ba and measure: temperature
          2025-10-21 20:01:04.439  - debug: netatmo-crawler.0 (2535) Rounded value 14.3 to 14.3
          2025-10-21 20:01:04.455  - debug: netatmo-crawler.0 (2535) Saving data for station: 70:ee:50:17:9d:ba and measure: pressure
          2025-10-21 20:01:04.489  - debug: netatmo-crawler.0 (2535) Rounded value 998.8 to 998.8
          2025-10-21 20:01:04.496  - debug: netatmo-crawler.0 (2535) Saving data for station: 70:ee:50:17:9d:ba and measure: humidity
          2025-10-21 20:01:04.506  - debug: netatmo-crawler.0 (2535) Rounded value 74 to 74
          2025-10-21 20:01:04.513  - debug: netatmo-crawler.0 (2535) Working with stationUrl: https://weathermap.netatmo.com//?zoom=15&type=rain&param=hourly&stationid=70%3Aee%3A50%3A00%3Ac1%3A94&maplayer=Map&lang=undefined
          2025-10-21 20:01:04.514  - debug: netatmo-crawler.0 (2535) Going to get information for station: 3
          2025-10-21 20:01:04.515  - info: netatmo-crawler.0 (2535) Getting data for stationid:70:ee:50:00:c1:94
          2025-10-21 20:01:04.615  - debug: netatmo-crawler.0 (2535) Body:[{"_id":"70:ee:50:00:c1:94","place":{"location":[13.4704260000001,52.5162059412954],"timezone":"Europe/Berlin","country":"DE","altitude":46,"city":"Berlin","street":"Schreinerstraße"},"mark":10,"measures":{"02:00:00:00:c7:32":{"res":{"1761069052":[15.5,69]},"type":["temperature","humidity"]},"70:ee:50:00:c1:94":{"res":{"1761069405":[1000.2]},"type":["pressure"]},"05:00:00:00:19:9a":{"res":{"1761069405":[0]},"type":["rain"]}}}]
          2025-10-21 20:01:04.616  - debug: netatmo-crawler.0 (2535) Saving station data for station: 3
          2025-10-21 20:01:04.673  - debug: netatmo-crawler.0 (2535) Saving data for station: 70:ee:50:00:c1:94 and measure: temperature
          2025-10-21 20:01:04.683  - debug: netatmo-crawler.0 (2535) Rounded value 15.5 to 15.5
          2025-10-21 20:01:04.691  - debug: netatmo-crawler.0 (2535) Saving data for station: 70:ee:50:00:c1:94 and measure: rain
          2025-10-21 20:01:04.701  - debug: netatmo-crawler.0 (2535) Rounded value 0 to 0
          2025-10-21 20:01:05.157  - debug: netatmo-crawler.0 (2535) Body Rain_Today:{"body":[{"beg_time":1760997600,"value":[[0.6]]}],"status":"ok","time_exec":0.02475595474243164,"time_server":1761069665}
          2025-10-21 20:01:05.158  - debug: netatmo-crawler.0 (2535) Rain Today for Station 70:ee:50:00:c1:94 is: 0.6
          2025-10-21 20:01:05.161  - debug: netatmo-crawler.0 (2535) Rounded value 0.6 to 0.6
          2025-10-21 20:01:05.170  - debug: netatmo-crawler.0 (2535) Saved rain_today for station: 70:ee:50:00:c1:94
          2025-10-21 20:01:05.352  - info: broadlink2.0 (2546) starting. Version 2.3.0 in /opt/iobroker/node_modules/iobroker.broadlink2, node: v22.21.0, js-controller: 7.0.7
          2025-10-21 20:01:05.396  - debug: netatmo-crawler.0 (2535) Body Rain_Yesterday:[{"beg_time":1760911200,"value":[[0]]}]
          2025-10-21 20:01:05.396  - debug: netatmo-crawler.0 (2535) Rain Yesterday for Station 70:ee:50:00:c1:94 is: 0
          2025-10-21 20:01:05.401  - debug: netatmo-crawler.0 (2535) Rounded value 0 to 0
          2025-10-21 20:01:05.413  - debug: netatmo-crawler.0 (2535) Saved rain_yesterday for station: 70:ee:50:00:c1:94
          2025-10-21 20:01:05.592  - debug: netatmo-crawler.0 (2535) Body Rain_LastHour:[{"beg_time":1761066065,"value":[[0]]}]
          2025-10-21 20:01:05.594  - debug: netatmo-crawler.0 (2535) Rain Last Hour for Station 70:ee:50:00:c1:94 is: 0
          2025-10-21 20:01:05.604  - debug: netatmo-crawler.0 (2535) Rounded value 0 to 0
          2025-10-21 20:01:05.626  - debug: netatmo-crawler.0 (2535) Saved rain_lastHour for station: 70:ee:50:00:c1:94
          2025-10-21 20:01:05.635  - debug: netatmo-crawler.0 (2535) Saving data for station: 70:ee:50:00:c1:94 and measure: pressure
          2025-10-21 20:01:05.635  - info: broadlink2.0 (2546) broadlink2 initialization started...
          2025-10-21 20:01:05.645  - debug: netatmo-crawler.0 (2535) Rounded value 1000.2 to 1000.2
          2025-10-21 20:01:05.653  - debug: netatmo-crawler.0 (2535) Saving data for station: 70:ee:50:00:c1:94 and measure: humidity
          2025-10-21 20:01:05.641  - info: broadlink2.0 (2546) Scanning additional IP's: 192.168.178.86
          2025-10-21 20:01:05.642  - info: broadlink2.0 (2546) Devices to add: 0x649b=RM4P
          2025-10-21 20:01:05.642  - info: broadlink2.0 (2546) Devices to rename:
          2025-10-21 20:01:05.644  - info: broadlink2.0 (2546) broadlink2 has 2 old devices!
          2025-10-21 20:01:05.650  - info: broadlink2.0 (2546) interface to be used: { netmaskBits: 24, address: '192.168.178.79/24', addrs: [ 192, 168, 178, 79 ], cidr: '192.168.178.79/24', bcaddr: '192.168.178.255'
          2025-10-21 20:01:05.652  - info: broadlink2.0 (2546) macObjects: [ '78:0f:77:00:cd:a0', 'ec:0b:ae:3d:d2:34' ]
          2025-10-21 20:01:05.665  - debug: netatmo-crawler.0 (2535) Rounded value 69 to 69
          2025-10-21 20:01:05.673  - debug: netatmo-crawler.0 (2535) Working with stationUrl: https://weathermap.netatmo.com//?zoom=14.026073475931375&type=rain&param=hourly&stationid=70%3Aee%3A50%3A52%3Ae9%3Ac2&maplayer=Map&lang=undefined
          2025-10-21 20:01:05.674  - debug: netatmo-crawler.0 (2535) Going to get information for station: 4
          2025-10-21 20:01:05.674  - info: netatmo-crawler.0 (2535) Getting data for stationid:70:ee:50:52:e9:c2
          2025-10-21 20:01:05.726  - info: broadlink2.0 (2546) Discover Broadlink devices for 10sec on broadlink2.0
          2025-10-21 20:01:05.745  - info: broadlink2.0 (2546) interface to be used: { netmaskBits: 24, address: '192.168.178.79/24', addrs: [ 192, 168, 178, 79 ], cidr: '192.168.178.79/24', bcaddr: '192.168.178.255'
            Babu242 @Thomas Braun last edited by
            teil 2
            code_text
            ```2025-10-21 20:01:05.747  - info: broadlink2.0 (2546) discover  [ '192.168.178.255', '255.255.255.255', '224.0.0.251' ] from 0.0.0.0:53405
            2025-10-21 20:01:05.766  - debug: netatmo-crawler.0 (2535) Body:[{"_id":"70:ee:50:52:e9:c2","place":{"location":[13.4855409,52.5401803],"timezone":"Europe/Berlin","country":"DE","altitude":59,"city":"Berlin","street":"Konrad-Wolf-Straße"},"mark":1,"measures":{"02:00:00:9d:23:d8":{"res":{"1761069472":[14.4,74]},"type":["temperature","humidity"]},"70:ee:50:52:e9:c2":{"res":{"1761069494":[1000.6]},"type":["pressure"]},"05:00:00:03:84:7c":{"res":{"1761069492":[0]},"type":["rain"]}}}]
            2025-10-21 20:01:05.766  - debug: netatmo-crawler.0 (2535) Saving station data for station: 4
            2025-10-21 20:01:05.795  - debug: netatmo-crawler.0 (2535) Saving data for station: 70:ee:50:52:e9:c2 and measure: temperature
            2025-10-21 20:01:05.803  - debug: netatmo-crawler.0 (2535) Rounded value 14.4 to 14.4
            2025-10-21 20:01:05.809  - debug: netatmo-crawler.0 (2535) Saving data for station: 70:ee:50:52:e9:c2 and measure: rain
            2025-10-21 20:01:05.818  - debug: netatmo-crawler.0 (2535) Rounded value 0 to 0
            2025-10-21 20:01:05.858  - info: broadlink2.0 (2546) Device RM:BroadLink-WiFi-Device-3d-d2-34 detected: address=192.168.178.86, mac=ec:0b:ae:3d:d2:34, typ=RM4P, id=0x649b devtype=rm4p
            2025-10-21 20:01:06.009  - debug: netatmo-crawler.0 (2535) Body Rain_Today:{"body":[{"beg_time":1760997600,"value":[[0]]}],"status":"ok","time_exec":0.018838882446289062,"time_server":1761069665}
            2025-10-21 20:01:06.010  - debug: netatmo-crawler.0 (2535) Rain Today for Station 70:ee:50:52:e9:c2 is: 0
            2025-10-21 20:01:06.013  - debug: netatmo-crawler.0 (2535) Rounded value 0 to 0
            2025-10-21 20:01:06.020  - debug: netatmo-crawler.0 (2535) Saved rain_today for station: 70:ee:50:52:e9:c2
            2025-10-21 20:01:06.578  - debug: netatmo-crawler.0 (2535) Body Rain_Yesterday:[{"beg_time":1760911200,"value":[[0]]}]
            2025-10-21 20:01:06.579  - debug: netatmo-crawler.0 (2535) Rain Yesterday for Station 70:ee:50:52:e9:c2 is: 0
            2025-10-21 20:01:06.582  - debug: netatmo-crawler.0 (2535) Rounded value 0 to 0
            2025-10-21 20:01:06.589  - debug: netatmo-crawler.0 (2535) Saved rain_yesterday for station: 70:ee:50:52:e9:c2
            2025-10-21 20:01:06.726  - debug: netatmo-crawler.0 (2535) Body Rain_LastHour:[{"beg_time":1761066066,"value":[[0]]}]
            2025-10-21 20:01:06.726  - debug: netatmo-crawler.0 (2535) Rain Last Hour for Station 70:ee:50:52:e9:c2 is: 0
            2025-10-21 20:01:06.730  - debug: netatmo-crawler.0 (2535) Rounded value 0 to 0
            2025-10-21 20:01:06.737  - debug: netatmo-crawler.0 (2535) Saved rain_lastHour for station: 70:ee:50:52:e9:c2
            2025-10-21 20:01:06.745  - debug: netatmo-crawler.0 (2535) Saving data for station: 70:ee:50:52:e9:c2 and measure: pressure
            2025-10-21 20:01:06.753  - debug: netatmo-crawler.0 (2535) Rounded value 1000.6 to 1000.6
            2025-10-21 20:01:06.759  - debug: netatmo-crawler.0 (2535) Saving data for station: 70:ee:50:52:e9:c2 and measure: humidity
            2025-10-21 20:01:06.766  - debug: netatmo-crawler.0 (2535) Rounded value 74 to 74
            2025-10-21 20:01:06.772  - debug: netatmo-crawler.0 (2535) Working with stationUrl: https://weathermap.netatmo.com//?zoom=14&type=rain&param=hourly&stationid=70%3Aee%3A50%3A33%3A4b%3Afc&maplayer=Map&lang=undefined
            2025-10-21 20:01:06.773  - debug: netatmo-crawler.0 (2535) Going to get information for station: 5
            2025-10-21 20:01:06.773  - info: netatmo-crawler.0 (2535) Getting data for stationid:70:ee:50:33:4b:fc
            2025-10-21 20:01:10.961  - info: broadlink2.0 (2546) interface to be used: { netmaskBits: 24, address: '192.168.178.79/24', addrs: [ 192, 168, 178, 79 ], cidr: '192.168.178.79/24', bcaddr: '192.168.178.255'
            2025-10-21 20:01:10.963  - info: broadlink2.0 (2546) discover  [ '192.168.178.86' ] from 0.0.0.0:34728
            2025-10-21 20:01:13.041  - debug: netatmo-crawler.0 (2535) Body:[{"_id":"70:ee:50:33:4b:fc","place":{"location":[13.4505570248038,52.5223887067962],"timezone":"Europe/Berlin","country":"DE","altitude":56,"city":"Berlin","street":"Straßmannstraße"},"mark":10,"measures":{"02:00:00:32:d9:da":{"res":{"1761069473":[15.1,79]},"type":["temperature","humidity"]},"70:ee:50:33:4b:fc":{"res":{"1761069505":[1002.1]},"type":["pressure"]},"05:00:00:07:14:d4":{"res":{"1761069499":[0]},"type":["rain"]}}}]
            2025-10-21 20:01:13.042  - debug: netatmo-crawler.0 (2535) Saving station data for station: 5
            2025-10-21 20:01:13.072  - debug: netatmo-crawler.0 (2535) Saving data for station: 70:ee:50:33:4b:fc and measure: temperature
            2025-10-21 20:01:13.080  - debug: netatmo-crawler.0 (2535) Rounded value 15.1 to 15.1
            2025-10-21 20:01:13.086  - debug: netatmo-crawler.0 (2535) Saving data for station: 70:ee:50:33:4b:fc and measure: rain
            2025-10-21 20:01:13.094  - debug: netatmo-crawler.0 (2535) Rounded value 0 to 0
            2025-10-21 20:01:13.365  - debug: netatmo-crawler.0 (2535) Body Rain_Today:{"body":[{"beg_time":1760997600,"value":[[1]]}],"status":"ok","time_exec":0.02626800537109375,"time_server":1761069673}
            2025-10-21 20:01:13.365  - debug: netatmo-crawler.0 (2535) Rain Today for Station 70:ee:50:33:4b:fc is: 1
            2025-10-21 20:01:13.369  - debug: netatmo-crawler.0 (2535) Rounded value 1 to 1
            2025-10-21 20:01:13.375  - debug: netatmo-crawler.0 (2535) Saved rain_today for station: 70:ee:50:33:4b:fc
            2025-10-21 20:01:13.624  - debug: netatmo-crawler.0 (2535) Body Rain_Yesterday:[{"beg_time":1760911200,"value":[[0]]}]
            2025-10-21 20:01:13.625  - debug: netatmo-crawler.0 (2535) Rain Yesterday for Station 70:ee:50:33:4b:fc is: 0
            2025-10-21 20:01:13.628  - debug: netatmo-crawler.0 (2535) Rounded value 0 to 0
            2025-10-21 20:01:13.634  - debug: netatmo-crawler.0 (2535) Saved rain_yesterday for station: 70:ee:50:33:4b:fc
            2025-10-21 20:01:13.993  - debug: netatmo-crawler.0 (2535) Body Rain_LastHour:[{"beg_time":1761066073,"value":[[0]]}]
            2025-10-21 20:01:13.994  - debug: netatmo-crawler.0 (2535) Rain Last Hour for Station 70:ee:50:33:4b:fc is: 0
            2025-10-21 20:01:13.997  - debug: netatmo-crawler.0 (2535) Rounded value 0 to 0
            2025-10-21 20:01:14.003  - debug: netatmo-crawler.0 (2535) Saved rain_lastHour for station: 70:ee:50:33:4b:fc
            2025-10-21 20:01:14.010  - debug: netatmo-crawler.0 (2535) Saving data for station: 70:ee:50:33:4b:fc and measure: pressure
            2025-10-21 20:01:14.017  - debug: netatmo-crawler.0 (2535) Rounded value 1002.1 to 1002.1
            2025-10-21 20:01:14.027  - debug: netatmo-crawler.0 (2535) Saving data for station: 70:ee:50:33:4b:fc and measure: humidity
            2025-10-21 20:01:14.035  - debug: netatmo-crawler.0 (2535) Rounded value 79 to 79
            2025-10-21 20:01:14.043  - debug: netatmo-crawler.0 (2535) all done, exiting
            2025-10-21 20:01:14.044  - info: netatmo-crawler.0 (2535) Terminated (NO_ERROR): Everything done. Going to terminate till next schedule
            2025-10-21 20:01:14.585  - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 having pid 2535 terminated with code 0 (NO_ERROR)
            2025-10-21 20:01:15.032  - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 in version "1.1.0" started with pid 2566
            2025-10-21 20:01:15.252  - warn: broadlink2.0 (2546) device RM:RMPROPLUS-00-cd-a0 not found, please rescan later again or delete it! It was: 192.168.178.49,80,10141,智能遥控,0,[object Object],78:0f:77:00:cd:a0,RMP,RM:RMPROPLUS-00-cd-a0,0x279d,RM3 Pro Plus,RM:RMPROPLUS-00-cd-a0,RMPROPLUS-00-cd-a0,57
            2025-10-21 20:01:15.379  - info: broadlink2.0 (2546) interface to be used: { netmaskBits: 24, address: '192.168.178.79/24', addrs: [ 192, 168, 178, 79 ], cidr: '192.168.178.79/24', bcaddr: '192.168.178.255'
            2025-10-21 20:01:15.381  - info: broadlink2.0 (2546) discover  [ '192.168.178.49' ] from 0.0.0.0:33333
            2025-10-21 20:01:17.327  - debug: netatmo-crawler.0 (2566) Redis Objects: Use Redis connection: 127.0.0.1:9001
            2025-10-21 20:01:17.403  - debug: netatmo-crawler.0 (2566) Objects client ready ... initialize now
            2025-10-21 20:01:17.407  - debug: netatmo-crawler.0 (2566) Objects create System PubSub Client
            2025-10-21 20:01:17.409  - debug: netatmo-crawler.0 (2566) Objects create User PubSub Client
            2025-10-21 20:01:17.472  - debug: netatmo-crawler.0 (2566) Objects client initialize lua scripts
            2025-10-21 20:01:17.481  - debug: netatmo-crawler.0 (2566) Objects connected to redis: 127.0.0.1:9001
            2025-10-21 20:01:17.486  - silly: netatmo-crawler.0 (2566) redis psubscribe cfg.o.system.user.*
            2025-10-21 20:01:17.517  - silly: netatmo-crawler.0 (2566) redis psubscribe cfg.o.enum.*
            2025-10-21 20:01:17.521  - silly: netatmo-crawler.0 (2566) objectDB connected
            2025-10-21 20:01:17.525  - debug: netatmo-crawler.0 (2566) Redis States: Use Redis connection: 127.0.0.1:9000
            2025-10-21 20:01:17.549  - debug: netatmo-crawler.0 (2566) States create System PubSub Client
            2025-10-21 20:01:17.550  - debug: netatmo-crawler.0 (2566) States create User PubSub Client
            2025-10-21 20:01:17.598  - info: broadlink2.0 (2546) Poll every 15 secods.
            2025-10-21 20:01:17.599  - info: broadlink2.0 (2546) broadlink2.0 started and found 1 devices named RM:BroadLink-WiFi-Device-3d-d2-34
            2025-10-21 20:01:17.599  - info: broadlink2.0 (2546) 1 were not found: RM:RMPROPLUS-00-cd-a0
            2025-10-21 20:01:17.600  - info: broadlink2.0 (2546) found macs: ec:0b:ae:3d:d2:34
            2025-10-21 20:01:17.631  - debug: netatmo-crawler.0 (2566) States connected to redis: 127.0.0.1:9000
            2025-10-21 20:01:17.632  - silly: netatmo-crawler.0 (2566) statesDB connected
            2025-10-21 20:01:17.791  - info: netatmo-crawler.0 (2566) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v22.21.0, js-controller: 7.0.7
            2025-10-21 20:01:17.815  - debug: netatmo-crawler.0 (2566) config stationUrls: https://weathermap.netatmo.com//?zoom=14&type=rain&param=hourly&stationid=70%3Aee%3A50%3A33%3A4b%3Afc&maplayer=Map&lang=undefined
            2025-10-21 20:01:17.815  - debug: netatmo-crawler.0 (2566) Going to save station information with: id
            2025-10-21 20:01:17.817  - debug: netatmo-crawler.0 (2566) Trying to get token from state
            2025-10-21 20:01:17.839  - silly: netatmo-crawler.0 (2566) States system redis pmessage system.adapter.netatmo-crawler.0.logLevel/system.adapter.netatmo-crawler.0.logLevel:{"val":"silly","ack":true,"ts":1761069677820,"q":0,"from":"system.adapter.netatmo-crawler.0","lc":1732447437255}
            2025-10-21 20:01:17.843  - debug: netatmo-crawler.0 (2566) Working with stationUrl: https://weathermap.netatmo.com//?zoom=14&type=rain&param=hourly&stationid=70%3Aee%3A50%3A33%3A4b%3Afc&maplayer=Map&lang=undefined
            2025-10-21 20:01:17.845  - debug: netatmo-crawler.0 (2566) Going to get information for station: 1
            2025-10-21 20:01:17.848  - info: netatmo-crawler.0 (2566) Getting data for stationid:70:ee:50:33:4b:fc
            2025-10-21 20:01:18.059  - debug: netatmo-crawler.0 (2566) Body:[{"_id":"70:ee:50:33:4b:fc","place":{"location":[13.4505570248038,52.5223887067962],"timezone":"Europe/Berlin","country":"DE","altitude":56,"city":"Berlin","street":"Straßmannstraße"},"mark":10,"measures":{"02:00:00:32:d9:da":{"res":{"1761069473":[15.1,79]},"type":["temperature","humidity"]},"70:ee:50:33:4b:fc":{"res":{"1761069505":[1002.1]},"type":["pressure"]},"05:00:00:07:14:d4":{"res":{"1761069499":[0]},"type":["rain"]}}}]
            2025-10-21 20:01:18.061  - debug: netatmo-crawler.0 (2566) Saving station data for station: 1
            2025-10-21 20:01:18.105  - debug: netatmo-crawler.0 (2566) Saving data for station: 70:ee:50:33:4b:fc and measure: temperature
            2025-10-21 20:01:18.114  - debug: netatmo-crawler.0 (2566) Rounded value 15.1 to 15.1
            2025-10-21 20:01:18.121  - debug: netatmo-crawler.0 (2566) Saving data for station: 70:ee:50:33:4b:fc and measure: rain
            2025-10-21 20:01:18.130  - debug: netatmo-crawler.0 (2566) Rounded value 0 to 0
            2025-10-21 20:01:18.279  - debug: netatmo-crawler.0 (2566) Body Rain_Today:{"body":[{"beg_time":1760997600,"value":[[1]]}],"status":"ok","time_exec":0.03300189971923828,"time_server":1761069678}
            2025-10-21 20:01:18.280  - debug: netatmo-crawler.0 (2566) Rain Today for Station 70:ee:50:33:4b:fc is: 1
            2025-10-21 20:01:18.284  - debug: netatmo-crawler.0 (2566) Rounded value 1 to 1
            2025-10-21 20:01:18.291  - debug: netatmo-crawler.0 (2566) Saved rain_today for station: 70:ee:50:33:4b:fc
            2025-10-21 20:01:18.433  - debug: netatmo-crawler.0 (2566) Body Rain_Yesterday:[{"beg_time":1760911200,"value":[[0]]}]
            2025-10-21 20:01:18.433  - debug: netatmo-crawler.0 (2566) Rain Yesterday for Station 70:ee:50:33:4b:fc is: 0
            2025-10-21 20:01:18.437  - debug: netatmo-crawler.0 (2566) Rounded value 0 to 0
            2025-10-21 20:01:18.443  - debug: netatmo-crawler.0 (2566) Saved rain_yesterday for station: 70:ee:50:33:4b:fc
            2025-10-21 20:01:18.615  - debug: netatmo-crawler.0 (2566) Body Rain_LastHour:[{"beg_time":1761066078,"value":[[0]]}]
            2025-10-21 20:01:18.616  - debug: netatmo-crawler.0 (2566) Rain Last Hour for Station 70:ee:50:33:4b:fc is: 0
            2025-10-21 20:01:18.620  - debug: netatmo-crawler.0 (2566) Rounded value 0 to 0
            2025-10-21 20:01:18.626  - debug: netatmo-crawler.0 (2566) Saved rain_lastHour for station: 70:ee:50:33:4b:fc
            2025-10-21 20:01:18.633  - debug: netatmo-crawler.0 (2566) Saving data for station: 70:ee:50:33:4b:fc and measure: pressure
            2025-10-21 20:01:18.640  - debug: netatmo-crawler.0 (2566) Rounded value 1002.1 to 1002.1
            2025-10-21 20:01:18.646  - debug: netatmo-crawler.0 (2566) Saving data for station: 70:ee:50:33:4b:fc and measure: humidity
            2025-10-21 20:01:18.654  - debug: netatmo-crawler.0 (2566) Rounded value 79 to 79
            2025-10-21 20:01:18.660  - debug: netatmo-crawler.0 (2566) Working with stationUrl: https://weathermap.netatmo.com//?zoom=14&type=rain&param=hourly&stationid=70%3Aee%3A50%3A17%3A9d%3Aba&maplayer=Map&lang=undefined
            2025-10-21 20:01:18.660  - debug: netatmo-crawler.0 (2566) Going to get information for station: 2
            2025-10-21 20:01:18.662  - info: netatmo-crawler.0 (2566) Getting data for stationid:70:ee:50:17:9d:ba
            2025-10-21 20:01:19.857  - debug: netatmo-crawler.0 (2566) Body:[{"_id":"70:ee:50:17:9d:ba","place":{"location":[13.457895,52.523834],"timezone":"Europe/Berlin","country":"DE","altitude":48,"city":"Berlin","street":"Edith-Stein-Straße"},"mark":1,"measures":{"02:00:00:17:80:7a":{"res":{"1761069287":[14.3,74]},"type":["temperature","humidity"]},"70:ee:50:17:9d:ba":{"res":{"1761069298":[998.8]},"type":["pressure"]}}}]
            2025-10-21 20:01:19.858  - debug: netatmo-crawler.0 (2566) Saving station data for station: 2
            2025-10-21 20:01:19.886  - debug: netatmo-crawler.0 (2566) Saving data for station: 70:ee:50:17:9d:ba and measure: temperature
            2025-10-21 20:01:19.893  - debug: netatmo-crawler.0 (2566) Rounded value 14.3 to 14.3
            2025-10-21 20:01:19.900  - debug: netatmo-crawler.0 (2566) Saving data for station: 70:ee:50:17:9d:ba and measure: pressure
            2025-10-21 20:01:19.908  - debug: netatmo-crawler.0 (2566) Rounded value 998.8 to 998.8
            2025-10-21 20:01:19.914  - debug: netatmo-crawler.0 (2566) Saving data for station: 70:ee:50:17:9d:ba and measure: humidity
            2025-10-21 20:01:19.921  - debug: netatmo-crawler.0 (2566) Rounded value 74 to 74
            2025-10-21 20:01:19.927  - debug: netatmo-crawler.0 (2566) Working with stationUrl: https://weathermap.netatmo.com//?zoom=15&type=rain&param=hourly&stationid=70%3Aee%3A50%3A00%3Ac1%3A94&maplayer=Map&lang=undefined
            2025-10-21 20:01:19.928  - debug: netatmo-crawler.0 (2566) Going to get information for station: 3
            2025-10-21 20:01:19.929  - info: netatmo-crawler.0 (2566) Getting data for stationid:70:ee:50:00:c1:94
            2025-10-21 20:01:20.018  - debug: netatmo-crawler.0 (2566) Body:[{"_id":"70:ee:50:00:c1:94","place":{"location":[13.4704260000001,52.5162059412954],"timezone":"Europe/Berlin","country":"DE","altitude":46,"city":"Berlin","street":"Schreinerstraße"},"mark":10,"measures":{"02:00:00:00:c7:32":{"res":{"1761069052":[15.5,69]},"type":["temperature","humidity"]},"70:ee:50:00:c1:94":{"res":{"1761069405":[1000.2]},"type":["pressure"]},"05:00:00:00:19:9a":{"res":{"1761069405":[0]},"type":["rain"]}}}]
            2025-10-21 20:01:20.019  - debug: netatmo-crawler.0 (2566) Saving station data for station: 3
            2025-10-21 20:01:20.048  - debug: netatmo-crawler.0 (2566) Saving data for station: 70:ee:50:00:c1:94 and measure: temperature
            2025-10-21 20:01:20.056  - debug: netatmo-crawler.0 (2566) Rounded value 15.5 to 15.5
            2025-10-21 20:01:20.062  - debug: netatmo-crawler.0 (2566) Saving data for station: 70:ee:50:00:c1:94 and measure: rain
            2025-10-21 20:01:20.070  - debug: netatmo-crawler.0 (2566) Rounded value 0 to 0
            2025-10-21 20:01:20.251  - debug: netatmo-crawler.0 (2566) Body Rain_Today:{"body":[{"beg_time":1760997600,"value":[[0.6]]}],"status":"ok","time_exec":0.02898406982421875,"time_server":1761069680}
            2025-10-21 20:01:20.252  - debug: netatmo-crawler.0 (2566) Rain Today for Station 70:ee:50:00:c1:94 is: 0.6
            2025-10-21 20:01:20.256  - debug: netatmo-crawler.0 (2566) Rounded value 0.6 to 0.6
            2025-10-21 20:01:20.263  - debug: netatmo-crawler.0 (2566) Saved rain_today for station: 70:ee:50:00:c1:94
            2025-10-21 20:01:20.456  - debug: netatmo-crawler.0 (2566) Body Rain_Yesterday:[{"beg_time":1760911200,"value":[[0]]}]
            2025-10-21 20:01:20.457  - debug: netatmo-crawler.0 (2566) Rain Yesterday for Station 70:ee:50:00:c1:94 is: 0
            2025-10-21 20:01:20.463  - debug: netatmo-crawler.0 (2566) Rounded value 0 to 0
            2025-10-21 20:01:20.478  - debug: netatmo-crawler.0 (2566) Saved rain_yesterday for station: 70:ee:50:00:c1:94
            2025-10-21 20:01:20.941  - debug: netatmo-crawler.0 (2566) Body Rain_LastHour:[{"beg_time":1761066080,"value":[[0]]}]
            2025-10-21 20:01:20.942  - debug: netatmo-crawler.0 (2566) Rain Last Hour for Station 70:ee:50:00:c1:94 is: 0
            2025-10-21 20:01:20.948  - debug: netatmo-crawler.0 (2566) Rounded value 0 to 0
            2025-10-21 20:01:20.958  - debug: netatmo-crawler.0 (2566) Saved rain_lastHour for station: 70:ee:50:00:c1:94
            2025-10-21 20:01:20.969  - debug: netatmo-crawler.0 (2566) Saving data for station: 70:ee:50:00:c1:94 and measure: pressure
            2025-10-21 20:01:20.981  - debug: netatmo-crawler.0 (2566) Rounded value 1000.2 to 1000.2
            2025-10-21 20:01:20.990  - debug: netatmo-crawler.0 (2566) Saving data for station: 70:ee:50:00:c1:94 and measure: humidity
            2025-10-21 20:01:21.001  - debug: netatmo-crawler.0 (2566) Rounded value 69 to 69
            2025-10-21 20:01:21.010  - debug: netatmo-crawler.0 (2566) Working with stationUrl: https://weathermap.netatmo.com//?zoom=14.026073475931375&type=rain&param=hourly&stationid=70%3Aee%3A50%3A52%3Ae9%3Ac2&maplayer=Map&lang=undefined
            2025-10-21 20:01:21.011  - debug: netatmo-crawler.0 (2566) Going to get information for station: 4
            2025-10-21 20:01:21.012  - info: netatmo-crawler.0 (2566) Getting data for stationid:70:ee:50:52:e9:c2
            2025-10-21 20:01:21.148  - debug: netatmo-crawler.0 (2566) Body:[{"_id":"70:ee:50:52:e9:c2","place":{"location":[13.4855409,52.5401803],"timezone":"Europe/Berlin","country":"DE","altitude":59,"city":"Berlin","street":"Konrad-Wolf-Straße"},"mark":1,"measures":{"02:00:00:9d:23:d8":{"res":{"1761069472":[14.4,74]},"type":["temperature","humidity"]},"70:ee:50:52:e9:c2":{"res":{"1761069494":[1000.6]},"type":["pressure"]},"05:00:00:03:84:7c":{"res":{"1761069492":[0]},"type":["rain"]}}}]
            2025-10-21 20:01:21.153  - debug: netatmo-crawler.0 (2566) Saving station data for station: 4
            2025-10-21 20:01:21.217  - debug: netatmo-crawler.0 (2566) Saving data for station: 70:ee:50:52:e9:c2 and measure: temperature
            2025-10-21 20:01:21.225  - debug: netatmo-crawler.0 (2566) Rounded value 14.4 to 14.4
            2025-10-21 20:01:21.231  - debug: netatmo-crawler.0 (2566) Saving data for station: 70:ee:50:52:e9:c2 and measure: rain
            2025-10-21 20:01:21.239  - debug: netatmo-crawler.0 (2566) Rounded value 0 to 0
            2025-10-21 20:01:21.866  - debug: netatmo-crawler.0 (2566) Body Rain_Today:{"body":[{"beg_time":1760997600,"value":[[0]]}],"status":"ok","time_exec":0.03335404396057129,"time_server":1761069681}
            2025-10-21 20:01:21.867  - debug: netatmo-crawler.0 (2566) Rain Today for Station 70:ee:50:52:e9:c2 is: 0
            2025-10-21 20:01:21.870  - debug: netatmo-crawler.0 (2566) Rounded value 0 to 0
            2025-10-21 20:01:21.877  - debug: netatmo-crawler.0 (2566) Saved rain_today for station: 70:ee:50:52:e9:c2
            2025-10-21 20:01:22.002  - debug: netatmo-crawler.0 (2566) Body Rain_Yesterday:[{"beg_time":1760911200,"value":[[0]]}]
            2025-10-21 20:01:22.003  - debug: netatmo-crawler.0 (2566) Rain Yesterday for Station 70:ee:50:52:e9:c2 is: 0
            2025-10-21 20:01:22.007  - debug: netatmo-crawler.0 (2566) Rounded value 0 to 0
            2025-10-21 20:01:22.013  - debug: netatmo-crawler.0 (2566) Saved rain_yesterday for station: 70:ee:50:52:e9:c2
            2025-10-21 20:01:22.352  - debug: netatmo-crawler.0 (2566) Body Rain_LastHour:[{"beg_time":1761066082,"value":[[0]]}]
            2025-10-21 20:01:22.353  - debug: netatmo-crawler.0 (2566) Rain Last Hour for Station 70:ee:50:52:e9:c2 is: 0
            2025-10-21 20:01:22.356  - debug: netatmo-crawler.0 (2566) Rounded value 0 to 0
            2025-10-21 20:01:22.362  - debug: netatmo-crawler.0 (2566) Saved rain_lastHour for station: 70:ee:50:52:e9:c2
            2025-10-21 20:01:22.368  - debug: netatmo-crawler.0 (2566) Saving data for station: 70:ee:50:52:e9:c2 and measure: pressure
            2025-10-21 20:01:22.376  - debug: netatmo-crawler.0 (2566) Rounded value 1000.6 to 1000.6
            2025-10-21 20:01:22.381  - debug: netatmo-crawler.0 (2566) Saving data for station: 70:ee:50:52:e9:c2 and measure: humidity
            2025-10-21 20:01:22.389  - debug: netatmo-crawler.0 (2566) Rounded value 74 to 74
            2025-10-21 20:01:22.396  - debug: netatmo-crawler.0 (2566) Working with stationUrl: https://weathermap.netatmo.com//?zoom=14&type=rain&param=hourly&stationid=70%3Aee%3A50%3A33%3A4b%3Afc&maplayer=Map&lang=undefined
            2025-10-21 20:01:22.397  - debug: netatmo-crawler.0 (2566) Going to get information for station: 5
            2025-10-21 20:01:22.398  - info: netatmo-crawler.0 (2566) Getting data for stationid:70:ee:50:33:4b:fc
            2025-10-21 20:01:22.549  - debug: netatmo-crawler.0 (2566) Body:[{"_id":"70:ee:50:33:4b:fc","place":{"location":[13.4505570248038,52.5223887067962],"timezone":"Europe/Berlin","country":"DE","altitude":56,"city":"Berlin","street":"Straßmannstraße"},"mark":10,"measures":{"02:00:00:32:d9:da":{"res":{"1761069473":[15.1,79]},"type":["temperature","humidity"]},"70:ee:50:33:4b:fc":{"res":{"1761069505":[1002.1]},"type":["pressure"]},"05:00:00:07:14:d4":{"res":{"1761069499":[0]},"type":["rain"]}}}]
            2025-10-21 20:01:22.550  - debug: netatmo-crawler.0 (2566) Saving station data for station: 5
            2025-10-21 20:01:22.644  - debug: netatmo-crawler.0 (2566) Saving data for station: 70:ee:50:33:4b:fc and measure: temperature
            2025-10-21 20:01:22.652  - debug: netatmo-crawler.0 (2566) Rounded value 15.1 to 15.1
            2025-10-21 20:01:22.658  - debug: netatmo-crawler.0 (2566) Saving data for station: 70:ee:50:33:4b:fc and measure: rain
            2025-10-21 20:01:22.666  - debug: netatmo-crawler.0 (2566) Rounded value 0 to 0
            2025-10-21 20:01:22.881  - debug: netatmo-crawler.0 (2566) Body Rain_Today:{"body":[{"beg_time":1760997600,"value":[[1]]}],"status":"ok","time_exec":0.030659914016723633,"time_server":1761069682}
            2025-10-21 20:01:22.882  - debug: netatmo-crawler.0 (2566) Rain Today for Station 70:ee:50:33:4b:fc is: 1
            2025-10-21 20:01:22.886  - debug: netatmo-crawler.0 (2566) Rounded value 1 to 1
            2025-10-21 20:01:22.892  - debug: netatmo-crawler.0 (2566) Saved rain_today for station: 70:ee:50:33:4b:fc
            2025-10-21 20:01:23.064  - debug: netatmo-crawler.0 (2566) Body Rain_Yesterday:[{"beg_time":1760911200,"value":[[0]]}]
            2025-10-21 20:01:23.065  - debug: netatmo-crawler.0 (2566) Rain Yesterday for Station 70:ee:50:33:4b:fc is: 0
            2025-10-21 20:01:23.069  - debug: netatmo-crawler.0 (2566) Rounded value 0 to 0
            2025-10-21 20:01:23.077  - debug: netatmo-crawler.0 (2566) Saved rain_yesterday for station: 70:ee:50:33:4b:fc
            2025-10-21 20:01:23.431  - debug: netatmo-crawler.0 (2566) Body Rain_LastHour:[{"beg_time":1761066083,"value":[[0]]}]
            2025-10-21 20:01:23.431  - debug: netatmo-crawler.0 (2566) Rain Last Hour for Station 70:ee:50:33:4b:fc is: 0
            2025-10-21 20:01:23.435  - debug: netatmo-crawler.0 (2566) Rounded value 0 to 0
            2025-10-21 20:01:23.441  - debug: netatmo-crawler.0 (2566) Saved rain_lastHour for station: 70:ee:50:33:4b:fc
            2025-10-21 20:01:23.449  - debug: netatmo-crawler.0 (2566) Saving data for station: 70:ee:50:33:4b:fc and measure: pressure
            2025-10-21 20:01:23.457  - debug: netatmo-crawler.0 (2566) Rounded value 1002.1 to 1002.1
            2025-10-21 20:01:23.464  - debug: netatmo-crawler.0 (2566) Saving data for station: 70:ee:50:33:4b:fc and measure: humidity
            2025-10-21 20:01:23.472  - debug: netatmo-crawler.0 (2566) Rounded value 79 to 79
            2025-10-21 20:01:23.479  - debug: netatmo-crawler.0 (2566) all done, exiting
            2025-10-21 20:01:23.480  - info: netatmo-crawler.0 (2566) Terminated (NO_ERROR): Everything done. Going to terminate till next schedule
            2025-10-21 20:01:24.018  - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 having pid 2566 terminated with code 0 (NO_ERROR)
            2025-10-21 20:01:30.051  - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 in version "1.1.0" started with pid 2581
            2025-10-21 20:01:32.286  - debug: netatmo-crawler.0 (2581) Redis Objects: Use Redis connection: 127.0.0.1:9001
            2025-10-21 20:01:32.355  - debug: netatmo-crawler.0 (2581) Objects client ready ... initialize now
            2025-10-21 20:01:32.359  - debug: netatmo-crawler.0 (2581) Objects create System PubSub Client
            2025-10-21 20:01:32.361  - debug: netatmo-crawler.0 (2581) Objects create User PubSub Client
            2025-10-21 20:01:32.422  - debug: netatmo-crawler.0 (2581) Objects client initialize lua scripts
            2025-10-21 20:01:32.430  - debug: netatmo-crawler.0 (2581) Objects connected to redis: 127.0.0.1:9001
            2025-10-21 20:01:32.434  - silly: netatmo-crawler.0 (2581) redis psubscribe cfg.o.system.user.*
            2025-10-21 20:01:32.467  - silly: netatmo-crawler.0 (2581) redis psubscribe cfg.o.enum.*
            2025-10-21 20:01:32.472  - silly: netatmo-crawler.0 (2581) objectDB connected
            2025-10-21 20:01:32.477  - debug: netatmo-crawler.0 (2581) Redis States: Use Redis connection: 127.0.0.1:9000
            2025-10-21 20:01:32.500  - debug: netatmo-crawler.0 (2581) States create System PubSub Client
            2025-10-21 20:01:32.501  - debug: netatmo-crawler.0 (2581) States create User PubSub Client
            2025-10-21 20:01:32.583  - debug: netatmo-crawler.0 (2581) States connected to redis: 127.0.0.1:9000
            2025-10-21 20:01:32.584  - silly: netatmo-crawler.0 (2581) statesDB connected
            2025-10-21 20:01:32.749  - info: netatmo-crawler.0 (2581) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v22.21.0, js-controller: 7.0.7
            2025-10-21 20:01:32.775  - debug: netatmo-crawler.0 (2581) config stationUrls: https://weathermap.netatmo.com//?zoom=14&type=rain&param=hourly&stationid=70%3Aee%3A50%3A33%3A4b%3Afc&maplayer=Map&lang=undefined
            2025-10-21 20:01:32.776  - debug: netatmo-crawler.0 (2581) Going to save station information with: id
            2025-10-21 20:01:32.778  - debug: netatmo-crawler.0 (2581) Trying to get token from state
            2025-10-21 20:01:32.799  - silly: netatmo-crawler.0 (2581) States system redis pmessage system.adapter.netatmo-crawler.0.logLevel/system.adapter.netatmo-crawler.0.logLevel:{"val":"silly","ack":true,"ts":1761069692780,"q":0,"from":"system.adapter.netatmo-crawler.0","lc":1732447437255}
            2025-10-21 20:01:32.809  - debug: netatmo-crawler.0 (2581) Working with stationUrl: https://weathermap.netatmo.com//?zoom=14&type=rain&param=hourly&stationid=70%3Aee%3A50%3A33%3A4b%3Afc&maplayer=Map&lang=undefined
            2025-10-21 20:01:32.811  - debug: netatmo-crawler.0 (2581) Going to get information for station: 1
            2025-10-21 20:01:32.815  - info: netatmo-crawler.0 (2581) Getting data for stationid:70:ee:50:33:4b:fc
            2025-10-21 20:01:33.003  - debug: netatmo-crawler.0 (2581) Body:[{"_id":"70:ee:50:33:4b:fc","place":{"location":[13.4505570248038,52.5223887067962],"timezone":"Europe/Berlin","country":"DE","altitude":56,"city":"Berlin","street":"Straßmannstraße"},"mark":10,"measures":{"02:00:00:32:d9:da":{"res":{"1761069473":[15.1,79]},"type":["temperature","humidity"]},"70:ee:50:33:4b:fc":{"res":{"1761069505":[1002.1]},"type":["pressure"]},"05:00:00:07:14:d4":{"res":{"1761069499":[0]},"type":["rain"]}}}]
            2025-10-21 20:01:33.004  - debug: netatmo-crawler.0 (2581) Saving station data for station: 1
            2025-10-21 20:01:33.041  - debug: netatmo-crawler.0 (2581) Saving data for station: 70:ee:50:33:4b:fc and measure: temperature
            2025-10-21 20:01:33.050  - debug: netatmo-crawler.0 (2581) Rounded value 15.1 to 15.1
            2025-10-21 20:01:33.056  - debug: netatmo-crawler.0 (2581) Saving data for station: 70:ee:50:33:4b:fc and measure: rain
            2025-10-21 20:01:33.065  - debug: netatmo-crawler.0 (2581) Rounded value 0 to 0
            2025-10-21 20:01:33.207  - debug: netatmo-crawler.0 (2581) Body Rain_Today:{"body":[{"beg_time":1760997600,"value":[[1]]}],"status":"ok","time_exec":0.03669309616088867,"time_server":1761069693}
            2025-10-21 20:01:33.207  - debug: netatmo-crawler.0 (2581) Rain Today for Station 70:ee:50:33:4b:fc is: 1
            2025-10-21 20:01:33.212  - debug: netatmo-crawler.0 (2581) Rounded value 1 to 1
            2025-10-21 20:01:33.218  - debug: netatmo-crawler.0 (2581) Saved rain_today for station: 70:ee:50:33:4b:fc
            2025-10-21 20:01:33.346  - debug: netatmo-crawler.0 (2581) Body Rain_Yesterday:[{"beg_time":1760911200,"value":[[0]]}]
            2025-10-21 20:01:33.346  - debug: netatmo-crawler.0 (2581) Rain Yesterday for Station 70:ee:50:33:4b:fc is: 0
            2025-10-21 20:01:33.350  - debug: netatmo-crawler.0 (2581) Rounded value 0 to 0
            2025-10-21 20:01:33.356  - debug: netatmo-crawler.0 (2581) Saved rain_yesterday for station: 70:ee:50:33:4b:fc
            2025-10-21 20:01:33.487  - debug: netatmo-crawler.0 (2581) Body Rain_LastHour:[{"beg_time":1761066093,"value":[[0]]}]
            2025-10-21 20:01:33.488  - debug: netatmo-crawler.0 (2581) Rain Last Hour for Station 70:ee:50:33:4b:fc is: 0
            2025-10-21 20:01:33.491  - debug: netatmo-crawler.0 (2581) Rounded value 0 to 0
            2025-10-21 20:01:33.497  - debug: netatmo-crawler.0 (2581) Saved rain_lastHour for station: 70:ee:50:33:4b:fc
            2025-10-21 20:01:33.504  - debug: netatmo-crawler.0 (2581) Saving data for station: 70:ee:50:33:4b:fc and measure: pressure
            2025-10-21 20:01:33.512  - debug: netatmo-crawler.0 (2581) Rounded value 1002.1 to 1002.1
            2025-10-21 20:01:33.518  - debug: netatmo-crawler.0 (2581) Saving data for station: 70:ee:50:33:4b:fc and measure: humidity
            2025-10-21 20:01:33.525  - debug: netatmo-crawler.0 (2581) Rounded value 79 to 79
            2025-10-21 20:01:33.532  - debug: netatmo-crawler.0 (2581) Working with stationUrl: https://weathermap.netatmo.com//?zoom=14&type=rain&param=hourly&stationid=70%3Aee%3A50%3A17%3A9d%3Aba&maplayer=Map&lang=undefined
            2025-10-21 20:01:33.533  - debug: netatmo-crawler.0 (2581) Going to get information for station: 2
            2025-10-21 20:01:33.534  - info: netatmo-crawler.0 (2581) Getting data for stationid:70:ee:50:17:9d:ba
            2025-10-21 20:01:33.679  - debug: netatmo-crawler.0 (2581) Body:[{"_id":"70:ee:50:17:9d:ba","place":{"location":[13.457895,52.523834],"timezone":"Europe/Berlin","country":"DE","altitude":48,"city":"Berlin","street":"Edith-Stein-Straße"},"mark":1,"measures":{"02:00:00:17:80:7a":{"res":{"1761069287":[14.3,74]},"type":["temperature","humidity"]},"70:ee:50:17:9d:ba":{"res":{"1761069298":[998.8]},"type":["pressure"]}}}]
            2025-10-21 20:01:33.681  - debug: netatmo-crawler.0 (2581) Saving station data for station: 2
            2025-10-21 20:01:33.715  - debug: netatmo-crawler.0 (2581) Saving data for station: 70:ee:50:17:9d:ba and measure: temperature
            2025-10-21 20:01:33.725  - debug: netatmo-crawler.0 (2581) Rounded value 14.3 to 14.3
            2025-10-21 20:01:33.734  - debug: netatmo-crawler.0 (2581) Saving data for station: 70:ee:50:17:9d:ba and measure: pressure
            2025-10-21 20:01:33.745  - debug: netatmo-crawler.0 (2581) Rounded value 998.8 to 998.8
            2025-10-21 20:01:33.751  - debug: netatmo-crawler.0 (2581) Saving data for station: 70:ee:50:17:9d:ba and measure: humidity
            2025-10-21 20:01:33.758  - debug: netatmo-crawler.0 (2581) Rounded value 74 to 74
            2025-10-21 20:01:33.764  - debug: netatmo-crawler.0 (2581) Working with stationUrl: https://weathermap.netatmo.com//?zoom=15&type=rain&param=hourly&stationid=70%3Aee%3A50%3A00%3Ac1%3A94&maplayer=Map&lang=undefined
            2025-10-21 20:01:33.765  - debug: netatmo-crawler.0 (2581) Going to get information for station: 3
            2025-10-21 20:01:33.765  - info: netatmo-crawler.0 (2581) Getting data for stationid:70:ee:50:00:c1:94
            2025-10-21 20:01:33.863  - debug: netatmo-crawler.0 (2581) Body:[{"_id":"70:ee:50:00:c1:94","place":{"location":[13.4704260000001,52.5162059412954],"timezone":"Europe/Berlin","country":"DE","altitude":46,"city":"Berlin","street":"Schreinerstraße"},"mark":10,"measures":{"02:00:00:00:c7:32":{"res":{"1761069052":[15.5,69]},"type":["temperature","humidity"]},"70:ee:50:00:c1:94":{"res":{"1761069405":[1000.2]},"type":["pressure"]},"05:00:00:00:19:9a":{"res":{"1761069405":[0]},"type":["rain"]}}}]
            2025-10-21 20:01:33.864  - debug: netatmo-crawler.0 (2581) Saving station data for station: 3
            2025-10-21 20:01:33.895  - debug: netatmo-crawler.0 (2581) Saving data for station: 70:ee:50:00:c1:94 and measure: temperature
            2025-10-21 20:01:33.903  - debug: netatmo-crawler.0 (2581) Rounded value 15.5 to 15.5
            2025-10-21 20:01:33.909  - debug: netatmo-crawler.0 (2581) Saving data for station: 70:ee:50:00:c1:94 and measure: rain
            2025-10-21 20:01:33.917  - debug: netatmo-crawler.0 (2581) Rounded value 0 to 0
            2025-10-21 20:01:34.145  - debug: netatmo-crawler.0 (2581) Body Rain_Today:{"body":[{"beg_time":1760997600,"value":[[0.6]]}],"status":"ok","time_exec":0.03744912147521973,"time_server":1761069694}
            2025-10-21 20:01:34.146  - debug: netatmo-crawler.0 (2581) Rain Today for Station 70:ee:50:00:c1:94 is: 0.6
            2025-10-21 20:01:34.149  - debug: netatmo-crawler.0 (2581) Rounded value 0.6 to 0.6
            2025-10-21 20:01:34.155  - debug: netatmo-crawler.0 (2581) Saved rain_today for station: 70:ee:50:00:c1:94
            2025-10-21 20:01:34.339  - debug: netatmo-crawler.0 (2581) Body Rain_Yesterday:[{"beg_time":1760911200,"value":[[0]]}]
            2025-10-21 20:01:34.339  - debug: netatmo-crawler.0 (2581) Rain Yesterday for Station 70:ee:50:00:c1:94 is: 0
            2025-10-21 20:01:34.343  - debug: netatmo-crawler.0 (2581) Rounded value 0 to 0
            2025-10-21 20:01:34.359  - debug: netatmo-crawler.0 (2581) Saved rain_yesterday for station: 70:ee:50:00:c1:94
            2025-10-21 20:01:34.563  - debug: netatmo-crawler.0 (2581) Body Rain_LastHour:[{"beg_time":1761066094,"value":[[0]]}]
            2025-10-21 20:01:34.564  - debug: netatmo-crawler.0 (2581) Rain Last Hour for Station 70:ee:50:00:c1:94 is: 0
            2025-10-21 20:01:34.568  - debug: netatmo-crawler.0 (2581) Rounded value 0 to 0
            2025-10-21 20:01:34.575  - debug: netatmo-crawler.0 (2581) Saved rain_lastHour for station: 70:ee:50:00:c1:94
            2025-10-21 20:01:34.582  - debug: netatmo-crawler.0 (2581) Saving data for station: 70:ee:50:00:c1:94 and measure: pressure
            2025-10-21 20:01:34.589  - debug: netatmo-crawler.0 (2581) Rounded value 1000.2 to 1000.2
            2025-10-21 20:01:34.595  - debug: netatmo-crawler.0 (2581) Saving data for station: 70:ee:50:00:c1:94 and measure: humidity
            2025-10-21 20:01:34.602  - debug: netatmo-crawler.0 (2581) Rounded value 69 to 69
            2025-10-21 20:01:34.609  - debug: netatmo-crawler.0 (2581) Working with stationUrl: https://weathermap.netatmo.com//?zoom=14.026073475931375&type=rain&param=hourly&stationid=70%3Aee%3A50%3A52%3Ae9%3Ac2&maplayer=Map&lang=undefined
            2025-10-21 20:01:34.610  - debug: netatmo-crawler.0 (2581) Going to get information for station: 4
            2025-10-21 20:01:34.610  - info: netatmo-crawler.0 (2581) Getting data for stationid:70:ee:50:52:e9:c2
            2025-10-21 20:01:34.754  - debug: netatmo-crawler.0 (2581) Body:[{"_id":"70:ee:50:52:e9:c2","place":{"location":[13.4855409,52.5401803],"timezone":"Europe/Berlin","country":"DE","altitude":59,"city":"Berlin","street":"Konrad-Wolf-Straße"},"mark":1,"measures":{"02:00:00:9d:23:d8":{"res":{"1761069472":[14.4,74]},"type":["temperature","humidity"]},"70:ee:50:52:e9:c2":{"res":{"1761069494":[1000.6]},"type":["pressure"]},"05:00:00:03:84:7c":{"res":{"1761069492":[0]},"type":["rain"]}}}]
            2025-10-21 20:01:34.755  - debug: netatmo-crawler.0 (2581) Saving station data for station: 4
            2025-10-21 20:01:34.783  - debug: netatmo-crawler.0 (2581) Saving data for station: 70:ee:50:52:e9:c2 and measure: temperature
            2025-10-21 20:01:34.790  - debug: netatmo-crawler.0 (2581) Rounded value 14.4 to 14.4
            2025-10-21 20:01:34.796  - debug: netatmo-crawler.0 (2581) Saving data for station: 70:ee:50:52:e9:c2 and measure: rain
            2025-10-21 20:01:34.812  - debug: netatmo-crawler.0 (2581) Rounded value 0 to 0
            2025-10-21 20:01:34.949  - debug: netatmo-crawler.0 (2581) Body Rain_Today:{"body":[{"beg_time":1760997600,"value":[[0]]}],"status":"ok","time_exec":0.026121139526367188,"time_server":1761069694}
            2025-10-21 20:01:34.949  - debug: netatmo-crawler.0 (2581) Rain Today for Station 70:ee:50:52:e9:c2 is: 0
            2025-10-21 20:01:34.952  - debug: netatmo-crawler.0 (2581) Rounded value 0 to 0
            2025-10-21 20:01:34.958  - debug: netatmo-crawler.0 (2581) Saved rain_today for station: 70:ee:50:52:e9:c2
            2025-10-21 20:01:35.090  - debug: netatmo-crawler.0 (2581) Body Rain_Yesterday:[{"beg_time":1760911200,"value":[[0]]}]
            2025-10-21 20:01:35.091  - debug: netatmo-crawler.0 (2581) Rain Yesterday for Station 70:ee:50:52:e9:c2 is: 0
            2025-10-21 20:01:35.094  - debug: netatmo-crawler.0 (2581) Rounded value 0 to 0
            2025-10-21 20:01:35.102  - debug: netatmo-crawler.0 (2581) Saved rain_yesterday for station: 70:ee:50:52:e9:c2
            2025-10-21 20:01:35.238  - debug: netatmo-crawler.0 (2581) Body Rain_LastHour:[{"beg_time":1761066095,"value":[[0]]}]
            2025-10-21 20:01:35.238  - debug: netatmo-crawler.0 (2581) Rain Last Hour for Station 70:ee:50:52:e9:c2 is: 0
            2025-10-21 20:01:35.243  - debug: netatmo-crawler.0 (2581) Rounded value 0 to 0
            2025-10-21 20:01:35.250  - debug: netatmo-crawler.0 (2581) Saved rain_lastHour for station: 70:ee:50:52:e9:c2
            2025-10-21 20:01:35.258  - debug: netatmo-crawler.0 (2581) Saving data for station: 70:ee:50:52:e9:c2 and measure: pressure
            2025-10-21 20:01:35.268  - debug: netatmo-crawler.0 (2581) Rounded value 1000.6 to 1000.6
            2025-10-21 20:01:35.276  - debug: netatmo-crawler.0 (2581) Saving data for station: 70:ee:50:52:e9:c2 and measure: humidity
            2025-10-21 20:01:35.286  - debug: netatmo-crawler.0 (2581) Rounded value 74 to 74
            2025-10-21 20:01:35.293  - debug: netatmo-crawler.0 (2581) Working with stationUrl: https://weathermap.netatmo.com//?zoom=14&type=rain&param=hourly&stationid=70%3Aee%3A50%3A33%3A4b%3Afc&maplayer=Map&lang=undefined
            2025-10-21 20:01:35.294  - debug: netatmo-crawler.0 (2581) Going to get information for station: 5
            2025-10-21 20:01:35.295  - info: netatmo-crawler.0 (2581) Getting data for stationid:70:ee:50:33:4b:fc
            2025-10-21 20:01:35.437  - debug: netatmo-crawler.0 (2581) Body:[{"_id":"70:ee:50:33:4b:fc","place":{"location":[13.4505570248038,52.5223887067962],"timezone":"Europe/Berlin","country":"DE","altitude":56,"city":"Berlin","street":"Straßmannstraße"},"mark":10,"measures":{"02:00:00:32:d9:da":{"res":{"1761069473":[15.1,79]},"type":["temperature","humidity"]},"70:ee:50:33:4b:fc":{"res":{"1761069505":[1002.1]},"type":["pressure"]},"05:00:00:07:14:d4":{"res":{"1761069499":[0]},"type":["rain"]}}}]
            2025-10-21 20:01:35.437  - debug: netatmo-crawler.0 (2581) Saving station data for station: 5
            2025-10-21 20:01:35.478  - debug: netatmo-crawler.0 (2581) Saving data for station: 70:ee:50:33:4b:fc and measure: temperature
            2025-10-21 20:01:35.489  - debug: netatmo-crawler.0 (2581) Rounded value 15.1 to 15.1
            2025-10-21 20:01:35.497  - debug: netatmo-crawler.0 (2581) Saving data for station: 70:ee:50:33:4b:fc and measure: rain
            2025-10-21 20:01:35.508  - debug: netatmo-crawler.0 (2581) Rounded value 0 to 0
            2025-10-21 20:01:35.654  - debug: netatmo-crawler.0 (2581) Body Rain_Today:{"body":[{"beg_time":1760997600,"value":[[1]]}],"status":"ok","time_exec":0.02826094627380371,"time_server":1761069695}
            2025-10-21 20:01:35.655  - debug: netatmo-crawler.0 (2581) Rain Today for Station 70:ee:50:33:4b:fc is: 1
            2025-10-21 20:01:35.658  - debug: netatmo-crawler.0 (2581) Rounded value 1 to 1
            2025-10-21 20:01:35.664  - debug: netatmo-crawler.0 (2581) Saved rain_today for station: 70:ee:50:33:4b:fc
            2025-10-21 20:01:35.907  - debug: netatmo-crawler.0 (2581) Body Rain_Yesterday:[{"beg_time":1760911200,"value":[[0]]}]
            2025-10-21 20:01:35.907  - debug: netatmo-crawler.0 (2581) Rain Yesterday for Station 70:ee:50:33:4b:fc is: 0
            2025-10-21 20:01:35.910  - debug: netatmo-crawler.0 (2581) Rounded value 0 to 0
            2025-10-21 20:01:35.924  - debug: netatmo-crawler.0 (2581) Saved rain_yesterday for station: 70:ee:50:33:4b:fc
            2025-10-21 20:01:36.098  - debug: netatmo-crawler.0 (2581) Body Rain_LastHour:[{"beg_time":1761066095,"value":[[0]]}]
            2025-10-21 20:01:36.099  - debug: netatmo-crawler.0 (2581) Rain Last Hour for Station 70:ee:50:33:4b:fc is: 0
            2025-10-21 20:01:36.103  - debug: netatmo-crawler.0 (2581) Rounded value 0 to 0
            2025-10-21 20:01:36.111  - debug: netatmo-crawler.0 (2581) Saved rain_lastHour for station: 70:ee:50:33:4b:fc
            2025-10-21 20:01:36.118  - debug: netatmo-crawler.0 (2581) Saving data for station: 70:ee:50:33:4b:fc and measure: pressure
            2025-10-21 20:01:36.126  - debug: netatmo-crawler.0 (2581) Rounded value 1002.1 to 1002.1
            2025-10-21 20:01:36.132  - debug: netatmo-crawler.0 (2581) Saving data for station: 70:ee:50:33:4b:fc and measure: humidity
            2025-10-21 20:01:36.141  - debug: netatmo-crawler.0 (2581) Rounded value 79 to 79
            2025-10-21 20:01:36.151  - debug: netatmo-crawler.0 (2581) all done, exiting
            2025-10-21 20:01:36.153  - info: netatmo-crawler.0 (2581) Terminated (NO_ERROR): Everything done. Going to terminate till next schedule
            2025-10-21 20:01:36.697  - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 having pid 2581 terminated with code 0 (NO_ERROR)
            2025-10-21 20:01:45.036  - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 in version "1.1.0" started with pid 2596
            2025-10-21 20:01:47.315  - debug: netatmo-crawler.0 (2596) Redis Objects: Use Redis connection: 127.0.0.1:9001
            2025-10-21 20:01:47.392  - debug: netatmo-crawler.0 (2596) Objects client ready ... initialize now
            2025-10-21 20:01:47.397  - debug: netatmo-crawler.0 (2596) Objects create System PubSub Client
            2025-10-21 20:01:47.400  - debug: netatmo-crawler.0 (2596) Objects create User PubSub Client
            2025-10-21 20:01:47.467  - debug: netatmo-crawler.0 (2596) Objects client initialize lua scripts
            2025-10-21 20:01:47.476  - debug: netatmo-crawler.0 (2596) Objects connected to redis: 127.0.0.1:9001
            2025-10-21 20:01:47.480  - silly: netatmo-crawler.0 (2596) redis psubscribe cfg.o.system.user.*
            2025-10-21 20:01:47.514  - silly: netatmo-crawler.0 (2596) redis psubscribe cfg.o.enum.*
            2025-10-21 20:01:47.519  - silly: netatmo-crawler.0 (2596) objectDB connected
            2025-10-21 20:01:47.524  - debug: netatmo-crawler.0 (2596) Redis States: Use Redis connection: 127.0.0.1:9000
            2025-10-21 20:01:47.552  - debug: netatmo-crawler.0 (2596) States create System PubSub Client
            2025-10-21 20:01:47.553  - debug: netatmo-crawler.0 (2596) States create User PubSub Client
            2025-10-21 20:01:47.635  - debug: netatmo-crawler.0 (2596) States connected to redis: 127.0.0.1:9000
            2025-10-21 20:01:47.636  - silly: netatmo-crawler.0 (2596) statesDB connected
            2025-10-21 20:01:47.652  - info: broadlink2.0 (2546) interface to be used: { netmaskBits: 24, address: '192.168.178.79/24', addrs: [ 192, 168, 178, 79 ], cidr: '192.168.178.79/24', bcaddr: '192.168.178.255'
            2025-10-21 20:01:47.655  - info: broadlink2.0 (2546) discover  [ '192.168.178.49' ] from 0.0.0.0:51758
            2025-10-21 20:01:47.793  - info: netatmo-crawler.0 (2596) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.netatmo-crawler, node: v22.21.0, js-controller: 7.0.7
            2025-10-21 20:01:47.818  - debug: netatmo-crawler.0 (2596) config stationUrls: https://weathermap.netatmo.com//?zoom=14&type=rain&param=hourly&stationid=70%3Aee%3A50%3A33%3A4b%3Afc&maplayer=Map&lang=undefined
            2025-10-21 20:01:47.819  - debug: netatmo-crawler.0 (2596) Going to save station information with: id
            2025-10-21 20:01:47.820  - debug: netatmo-crawler.0 (2596) Trying to get token from state
            2025-10-21 20:01:47.842  - silly: netatmo-crawler.0 (2596) States system redis pmessage system.adapter.netatmo-crawler.0.logLevel/system.adapter.netatmo-crawler.0.logLevel:{"val":"silly","ack":true,"ts":1761069707823,"q":0,"from":"system.adapter.netatmo-crawler.0","lc":1732447437255}
            2025-10-21 20:01:47.846  - debug: netatmo-crawler.0 (2596) Working with stationUrl: https://weathermap.netatmo.com//?zoom=14&type=rain&param=hourly&stationid=70%3Aee%3A50%3A33%3A4b%3Afc&maplayer=Map&lang=undefined
            2025-10-21 20:01:47.848  - debug: netatmo-crawler.0 (2596) Going to get information for station: 1
            2025-10-21 20:01:47.852  - info: netatmo-crawler.0 (2596) Getting data for stationid:70:ee:50:33:4b:fc
            2025-10-21 20:01:48.341  - debug: netatmo-crawler.0 (2596) Body:[{"_id":"70:ee:50:33:4b:fc","place":{"location":[13.4505570248038,52.5223887067962],"timezone":"Europe/Berlin","country":"DE","altitude":56,"city":"Berlin","street":"Straßmannstraße"},"mark":10,"measures":{"02:00:00:32:d9:da":{"res":{"1761069473":[15.1,79]},"type":["temperature","humidity"]},"70:ee:50:33:4b:fc":{"res":{"1761069505":[1002.1]},"type":["pressure"]},"05:00:00:07:14:d4":{"res":{"1761069499":[0]},"type":["rain"]}}}]
            2025-10-21 20:01:48.342  - debug: netatmo-crawler.0 (2596) Saving station data for station: 1
            2025-10-21 20:01:48.378  - debug: netatmo-crawler.0 (2596) Saving data for station: 70:ee:50:33:4b:fc and measure: temperature
            2025-10-21 20:01:48.387  - debug: netatmo-crawler.0 (2596) Rounded value 15.1 to 15.1
            2025-10-21 20:01:48.393  - debug: netatmo-crawler.0 (2596) Saving data for station: 70:ee:50:33:4b:fc and measure: rain
            2025-10-21 20:01:48.402  - debug: netatmo-crawler.0 (2596) Rounded value 0 to 0
            2025-10-21 20:01:48.919  - debug: netatmo-crawler.0 (2596) Body Rain_Today:{"body":[{"beg_time":1760997600,"value":[[1]]}],"status":"ok","time_exec":0.023617029190063477,"time_server":1761069708}
            2025-10-21 20:01:48.920  - debug: netatmo-crawler.0 (2596) Rain Today for Station 70:ee:50:33:4b:fc is: 1
            2025-10-21 20:01:48.924  - debug: netatmo-crawler.0 (2596) Rounded value 1 to 1
            2025-10-21 20:01:48.930  - debug: netatmo-crawler.0 (2596) Saved rain_today for station: 70:ee:50:33:4b:fc
            2025-10-21 20:01:50.166  - debug: netatmo-crawler.0 (2596) Body Rain_Yesterday:[{"beg_time":1760911200,"value":[[0]]}]
            2025-10-21 20:01:50.166  - debug: netatmo-crawler.0 (2596) Rain Yesterday for Station 70:ee:50:33:4b:fc is: 0
            2025-10-21 20:01:50.170  - debug: netatmo-crawler.0 (2596) Rounded value 0 to 0
            2025-10-21 20:01:50.176  - debug: netatmo-crawler.0 (2596) Saved rain_yesterday for station: 70:ee:50:33:4b:fc
            2025-10-21 20:01:50.382  - debug: netatmo-crawler.0 (2596) Body Rain_LastHour:[{"beg_time":1761066110,"value":[[0]]}]
            2025-10-21 20:01:50.383  - debug: netatmo-crawler.0 (2596) Rain Last Hour for Station 70:ee:50:33:4b:fc is: 0
            2025-10-21 20:01:50.386  - debug: netatmo-crawler.0 (2596) Rounded value 0 to 0
            2025-10-21 20:01:50.392  - debug: netatmo-crawler.0 (2596) Saved rain_lastHour for station: 70:ee:50:33:4b:fc
            2025-10-21 20:01:50.399  - debug: netatmo-crawler.0 (2596) Saving data for station: 70:ee:50:33:4b:fc and measure: pressure
            2025-10-21 20:01:50.406  - debug: netatmo-crawler.0 (2596) Rounded value 1002.1 to 1002.1
            2025-10-21 20:01:50.412  - debug: netatmo-crawler.0 (2596) Saving data for station: 70:ee:50:33:4b:fc and measure: humidity
            2025-10-21 20:01:50.420  - debug: netatmo-crawler.0 (2596) Rounded value 79 to 79
            2025-10-21 20:01:50.426  - debug: netatmo-crawler.0 (2596) Working with stationUrl: https://weathermap.netatmo.com//?zoom=14&type=rain&param=hourly&stationid=70%3Aee%3A50%3A17%3A9d%3Aba&maplayer=Map&lang=undefined
            2025-10-21 20:01:50.426  - debug: netatmo-crawler.0 (2596) Going to get information for station: 2
            2025-10-21 20:01:50.427  - info: netatmo-crawler.0 (2596) Getting data for stationid:70:ee:50:17:9d:ba
            2025-10-21 20:01:51.433  - debug: netatmo-crawler.0 (2596) Body:[{"_id":"70:ee:50:17:9d:ba","place":{"location":[13.457895,52.523834],"timezone":"Europe/Berlin","country":"DE","altitude":48,"city":"Berlin","street":"Edith-Stein-Straße"},"mark":1,"measures":{"02:00:00:17:80:7a":{"res":{"1761069287":[14.3,74]},"type":["temperature","humidity"]},"70:ee:50:17:9d:ba":{"res":{"1761069298":[998.8]},"type":["pressure"]}}}]
            2025-10-21 20:01:51.434  - debug: netatmo-crawler.0 (2596) Saving station data for station: 2
            2025-10-21 20:01:51.470  - debug: netatmo-crawler.0 (2596) Saving data for station: 70:ee:50:17:9d:ba and measure: temperature
            2025-10-21 20:01:51.480  - debug: netatmo-crawler.0 (2596) Rounded value 14.3 to 14.3
            2025-10-21 20:01:51.487  - debug: netatmo-crawler.0 (2596) Saving data for station: 70:ee:50:17:9d:ba and measure: pressure
            2025-10-21 20:01:51.495  - debug: netatmo-crawler.0 (2596) Rounded value 998.8 to 998.8
            2025-10-21 20:01:51.501  - debug: netatmo-crawler.0 (2596) Saving data for station: 70:ee:50:17:9d:ba and measure: humidity
            2025-10-21 20:01:51.511  - debug: netatmo-crawler.0 (2596) Rounded value 74 to 74
            2025-10-21 20:01:51.528  - debug: netatmo-crawler.0 (2596) Working with stationUrl: https://weathermap.netatmo.com//?zoom=15&type=rain&param=hourly&stationid=70%3Aee%3A50%3A00%3Ac1%3A94&maplayer=Map&lang=undefined
            2025-10-21 20:01:51.528  - debug: netatmo-crawler.0 (2596) Going to get information for station: 3
            2025-10-21 20:01:51.529  - info: netatmo-crawler.0 (2596) Getting data for stationid:70:ee:50:00:c1:94
            2025-10-21 20:01:51.715  - debug: netatmo-crawler.0 (2596) Body:[{"_id":"70:ee:50:00:c1:94","place":{"location":[13.4704260000001,52.5162059412954],"timezone":"Europe/Berlin","country":"DE","altitude":46,"city":"Berlin","street":"Schreinerstraße"},"mark":10,"measures":{"02:00:00:00:c7:32":{"res":{"1761069052":[15.5,69]},"type":["temperature","humidity"]},"70:ee:50:00:c1:94":{"res":{"1761069405":[1000.2]},"type":["pressure"]},"05:00:00:00:19:9a":{"res":{"1761069405":[0]},"type":["rain"]}}}]
            2025-10-21 20:01:51.716  - debug: netatmo-crawler.0 (2596) Saving station data for station: 3
            2025-10-21 20:01:51.766  - debug: netatmo-crawler.0 (2596) Saving data for station: 70:ee:50:00:c1:94 and measure: temperature
            2025-10-21 20:01:51.778  - debug: netatmo-crawler.0 (2596) Rounded value 15.5 to 15.5
            2025-10-21 20:01:51.786  - debug: netatmo-crawler.0 (2596) Saving data for station: 70:ee:50:00:c1:94 and measure: rain
            2025-10-21 20:01:51.796  - debug: netatmo-crawler.0 (2596) Rounded value 0 to 0
            2025-10-21 20:01:51.988  - debug: netatmo-crawler.0 (2596) Body Rain_Today:{"body":[{"beg_time":1760997600,"value":[[0.6]]}],"status":"ok","time_exec":0.029054880142211914,"time_server":1761069711}
            2025-10-21 20:01:51.989  - debug: netatmo-crawler.0 (2596) Rain Today for Station 70:ee:50:00:c1:94 is: 0.6
            2025-10-21 20:01:51.999  - debug: netatmo-crawler.0 (2596) Rounded value 0.6 to 0.6
            2025-10-21 20:01:52.014  - debug: netatmo-crawler.0 (2596) Saved rain_today for station: 70:ee:50:00:c1:94
            2025-10-21 20:01:52.178  - debug: netatmo-crawler.0 (2596) Body Rain_Yesterday:[{"beg_time":1760911200,"value":[[0]]}]
            2025-10-21 20:01:52.179  - debug: netatmo-crawler.0 (2596) Rain Yesterday for Station 70:ee:50:00:c1:94 is: 0
            2025-10-21 20:01:52.183  - debug: netatmo-crawler.0 (2596) Rounded value 0 to 0
            2025-10-21 20:01:52.191  - debug: netatmo-crawler.0 (2596) Saved rain_yesterday for station: 70:ee:50:00:c1:94
            2025-10-21 20:01:52.340  - debug: netatmo-crawler.0 (2596) Body Rain_LastHour:[{"beg_time":1761066112,"value":[[0]]}]
            2025-10-21 20:01:52.341  - debug: netatmo-crawler.0 (2596) Rain Last Hour for Station 70:ee:50:00:c1:94 is: 0
            2025-10-21 20:01:52.347  - debug: netatmo-crawler.0 (2596) Rounded value 0 to 0
            2025-10-21 20:01:52.357  - debug: netatmo-crawler.0 (2596) Saved rain_lastHour for station: 70:ee:50:00:c1:94
            2025-10-21 20:01:52.366  - debug: netatmo-crawler.0 (2596) Saving data for station: 70:ee:50:00:c1:94 and measure: pressure
            2025-10-21 20:01:52.377  - debug: netatmo-crawler.0 (2596) Rounded value 1000.2 to 1000.2
            2025-10-21 20:01:52.385  - debug: netatmo-crawler.0 (2596) Saving data for station: 70:ee:50:00:c1:94 and measure: humidity
            2025-10-21 20:01:52.396  - debug: netatmo-crawler.0 (2596) Rounded value 69 to 69
            2025-10-21 20:01:52.404  - debug: netatmo-crawler.0 (2596) Working with stationUrl: https://weathermap.netatmo.com//?zoom=14.026073475931375&type=rain&param=hourly&stationid=70%3Aee%3A50%3A52%3Ae9%3Ac2&maplayer=Map&lang=undefined
            2025-10-21 20:01:52.404  - debug: netatmo-crawler.0 (2596) Going to get information for station: 4
            2025-10-21 20:01:52.405  - info: netatmo-crawler.0 (2596) Getting data for stationid:70:ee:50:52:e9:c2
            2025-10-21 20:01:52.500  - debug: netatmo-crawler.0 (2596) Body:[{"_id":"70:ee:50:52:e9:c2","place":{"location":[13.4855409,52.5401803],"timezone":"Europe/Berlin","country":"DE","altitude":59,"city":"Berlin","street":"Konrad-Wolf-Straße"},"mark":1,"measures":{"02:00:00:9d:23:d8":{"res":{"1761069472":[14.4,74]},"type":["temperature","humidity"]},"70:ee:50:52:e9:c2":{"res":{"1761069494":[1000.6]},"type":["pressure"]},"05:00:00:03:84:7c":{"res":{"1761069492":[0]},"type":["rain"]}}}]
            2025-10-21 20:01:52.501  - debug: netatmo-crawler.0 (2596) Saving station data for station: 4
            2025-10-21 20:01:52.543  - debug: netatmo-crawler.0 (2596) Saving data for station: 70:ee:50:52:e9:c2 and measure: temperature
            2025-10-21 20:01:52.554  - debug: netatmo-crawler.0 (2596) Rounded value 14.4 to 14.4
            2025-10-21 20:01:52.563  - debug: netatmo-crawler.0 (2596) Saving data for station: 70:ee:50:52:e9:c2 and measure: rain
            2025-10-21 20:01:52.574  - debug: netatmo-crawler.0 (2596) Rounded value 0 to 0
            2025-10-21 20:01:52.718  - debug: netatmo-crawler.0 (2596) Body Rain_Today:{"body":[{"beg_time":1760997600,"value":[[0]]}],"status":"ok","time_exec":0.03166007995605469,"time_server":1761069712}
            2025-10-21 20:01:52.718  - debug: netatmo-crawler.0 (2596) Rain Today for Station 70:ee:50:52:e9:c2 is: 0
            2025-10-21 20:01:52.723  - debug: netatmo-crawler.0 (2596) Rounded value 0 to 0
            2025-10-21 20:01:52.730  - debug: netatmo-crawler.0 (2596) Saved rain_today for station: 70:ee:50:52:e9:c2
            2025-10-21 20:01:52.909  - debug: netatmo-crawler.0 (2596) Body Rain_Yesterday:[{"beg_time":1760911200,"value":[[0]]}]
            2025-10-21 20:01:52.909  - debug: netatmo-crawler.0 (2596) Rain Yesterday for Station 70:ee:50:52:e9:c2 is: 0
            2025-10-21 20:01:52.912  - debug: netatmo-crawler.0 (2596) Rounded value 0 to 0
            2025-10-21 20:01:52.918  - debug: netatmo-crawler.0 (2596) Saved rain_yesterday for station: 70:ee:50:52:e9:c2
            2025-10-21 20:01:53.047  - debug: netatmo-crawler.0 (2596) Body Rain_LastHour:[{"beg_time":1761066112,"value":[[0]]}]
            2025-10-21 20:01:53.047  - debug: netatmo-crawler.0 (2596) Rain Last Hour for Station 70:ee:50:52:e9:c2 is: 0
            2025-10-21 20:01:53.051  - debug: netatmo-crawler.0 (2596) Rounded value 0 to 0
            2025-10-21 20:01:53.057  - debug: netatmo-crawler.0 (2596) Saved rain_lastHour for station: 70:ee:50:52:e9:c2
            2025-10-21 20:01:53.064  - debug: netatmo-crawler.0 (2596) Saving data for station: 70:ee:50:52:e9:c2 and measure: pressure
            2025-10-21 20:01:53.071  - debug: netatmo-crawler.0 (2596) Rounded value 1000.6 to 1000.6
            2025-10-21 20:01:53.077  - debug: netatmo-crawler.0 (2596) Saving data for station: 70:ee:50:52:e9:c2 and measure: humidity
            2025-10-21 20:01:53.084  - debug: netatmo-crawler.0 (2596) Rounded value 74 to 74
            2025-10-21 20:01:53.090  - debug: netatmo-crawler.0 (2596) Working with stationUrl: https://weathermap.netatmo.com//?zoom=14&type=rain&param=hourly&stationid=70%3Aee%3A50%3A33%3A4b%3Afc&maplayer=Map&lang=undefined
            2025-10-21 20:01:53.091  - debug: netatmo-crawler.0 (2596) Going to get information for station: 5
            2025-10-21 20:01:53.091  - info: netatmo-crawler.0 (2596) Getting data for stationid:70:ee:50:33:4b:fc
            2025-10-21 20:01:53.631  - debug: netatmo-crawler.0 (2596) Body:[{"_id":"70:ee:50:33:4b:fc","place":{"location":[13.4505570248038,52.5223887067962],"timezone":"Europe/Berlin","country":"DE","altitude":56,"city":"Berlin","street":"Straßmannstraße"},"mark":10,"measures":{"02:00:00:32:d9:da":{"res":{"1761069473":[15.1,79]},"type":["temperature","humidity"]},"70:ee:50:33:4b:fc":{"res":{"1761069505":[1002.1]},"type":["pressure"]},"05:00:00:07:14:d4":{"res":{"1761069499":[0]},"type":["rain"]}}}]
            2025-10-21 20:01:53.632  - debug: netatmo-crawler.0 (2596) Saving station data for station: 5
            2025-10-21 20:01:53.664  - debug: netatmo-crawler.0 (2596) Saving data for station: 70:ee:50:33:4b:fc and measure: temperature
            2025-10-21 20:01:53.672  - debug: netatmo-crawler.0 (2596) Rounded value 15.1 to 15.1
            2025-10-21 20:01:53.678  - debug: netatmo-crawler.0 (2596) Saving data for station: 70:ee:50:33:4b:fc and measure: rain
            2025-10-21 20:01:53.685  - debug: netatmo-crawler.0 (2596) Rounded value 0 to 0
            2025-10-21 20:01:54.179  - debug: netatmo-crawler.0 (2596) Body Rain_Today:{"body":[{"beg_time":1760997600,"value":[[1]]}],"status":"ok","time_exec":0.02421402931213379,"time_server":1761069713}
            2025-10-21 20:01:54.180  - debug: netatmo-crawler.0 (2596) Rain Today for Station 70:ee:50:33:4b:fc is: 1
            2025-10-21 20:01:54.184  - debug: netatmo-crawler.0 (2596) Rounded value 1 to 1
            2025-10-21 20:01:54.195  - debug: netatmo-crawler.0 (2596) Saved rain_today for station: 70:ee:50:33:4b:fc
            2025-10-21 20:01:54.329  - debug: netatmo-crawler.0 (2596) Body Rain_Yesterday:[{"beg_time":1760911200,"value":[[0]]}]
            2025-10-21 20:01:54.329  - debug: netatmo-crawler.0 (2596) Rain Yesterday for Station 70:ee:50:33:4b:fc is: 0
            2025-10-21 20:01:54.332  - debug: netatmo-crawler.0 (2596) Rounded value 0 to 0
            2025-10-21 20:01:54.338  - debug: netatmo-crawler.0 (2596) Saved rain_yesterday for station: 70:ee:50:33:4b:fc
            2025-10-21 20:01:54.478  - debug: netatmo-crawler.0 (2596) Body Rain_LastHour:[{"beg_time":1761066114,"value":[[0]]}]
            2025-10-21 20:01:54.479  - debug: netatmo-crawler.0 (2596) Rain Last Hour for Station 70:ee:50:33:4b:fc is: 0
            2025-10-21 20:01:54.482  - debug: netatmo-crawler.0 (2596) Rounded value 0 to 0
            2025-10-21 20:01:54.488  - debug: netatmo-crawler.0 (2596) Saved rain_lastHour for station: 70:ee:50:33:4b:fc
            2025-10-21 20:01:54.496  - debug: netatmo-crawler.0 (2596) Saving data for station: 70:ee:50:33:4b:fc and measure: pressure
            2025-10-21 20:01:54.519  - debug: netatmo-crawler.0 (2596) Rounded value 1002.1 to 1002.1
            2025-10-21 20:01:54.526  - debug: netatmo-crawler.0 (2596) Saving data for station: 70:ee:50:33:4b:fc and measure: humidity
            2025-10-21 20:01:54.535  - debug: netatmo-crawler.0 (2596) Rounded value 79 to 79
            2025-10-21 20:01:54.545  - debug: netatmo-crawler.0 (2596) all done, exiting
            2025-10-21 20:01:54.548  - info: netatmo-crawler.0 (2596) Terminated (NO_ERROR): Everything done. Going to terminate till next schedule
            2025-10-21 20:01:55.086  - info: host.raspberrypi instance system.adapter.netatmo-crawler.0 having pid 2596 terminated with code 0 (NO_ERROR)
            2025-10-21 20:02:47.655  - info: broadlink2.0 (2546) interface to be used: { netmaskBits: 24, address: '192.168.178.79/24', addrs: [ 192, 168, 178, 79 ], cidr: '192.168.178.79/24', bcaddr: '192.168.178.255'
            2025-10-21 20:02:47.657  - info: broadlink2.0 (2546) discover  [ '192.168.178.49' ] from 0.0.0.0:46875
            2025-10-21 20:04:47.650  - info: broadlink2.0 (2546) interface to be used: { netmaskBits: 24, address: '192.168.178.79/24', addrs: [ 192, 168, 178, 79 ], cidr: '192.168.178.79/24', bcaddr: '192.168.178.255'
            2025-10-21 20:04:47.652  - info: broadlink2.0 (2546) discover  [ '192.168.178.49' ] from 0.0.0.0:47746
            2025-10-21 20:05:13.225  - info: admin.0 (673) ==> Connected system.user.admin from ::ffff:192.168.178.32
            2025-10-21 20:05:19.127  - info: admin.0 (673) ==> Connected system.user.admin from ::ffff:192.168.178.32
            2025-10-21 20:05:45.053  - warn: backitup.0 (738) [iobroker/clean] No older backup files are deleted, because this backup was started manually
            2025-10-21 20:05:46.299  - error: shelly.1 (862) [MQTT] Wrong MQTT authentication of client "shellyht-F391C4": Incorrect password
            2025-10-21 20:05:46.311  - info: shelly.1 (862) [MQTT] Client Close: (shellyht / shellyht-F391C4 / SHHT-1#F391C4#1) (false)
            2025-10-21 20:05:48.410  - error: shelly.1 (862) [MQTT] Wrong MQTT authentication of client "shellyht-F391C4": Incorrect password
            2025-10-21 20:05:48.416  - info: shelly.1 (862) [MQTT] Client Close: (shellyht / shellyht-F391C4 / SHHT-1#F391C4#1) (false)
            2025-10-21 20:05:52.266  - error: shelly.1 (862) [MQTT] Wrong MQTT authentication of client "shellyht-F391C4": Incorrect password
            2025-10-21 20:05:52.271  - info: shelly.1 (862) [MQTT] Client Close: (shellyht / shellyht-F391C4 / SHHT-1#F391C4#1) (false)
            2025-10-21 20:05:59.600  - error: shelly.1 (862) [MQTT] Wrong MQTT authentication of client "shellyht-F391C4": Incorrect password
            2025-10-21 20:05:59.607  - info: shelly.1 (862) [MQTT] Client Close: (shellyht / shellyht-F391C4 / SHHT-1#F391C4#1) (false)
            2025-10-21 20:08:47.669  - info: broadlink2.0 (2546) interface to be used: { netmaskBits: 24, address: '192.168.178.79/24', addrs: [ 192, 168, 178, 79 ], cidr: '192.168.178.79/24', bcaddr: '192.168.178.255'
            2025-10-21 20:08:47.672  - info: broadlink2.0 (2546) discover  [ '192.168.178.49' ] from 0.0.0.0:35207
            ========== Start marking the full check here ===========
            ```bash
            Script v.2025-08-09
            *** BASE SYSTEM ***
             Static hostname: raspberrypi
                   Icon name: computer
                      Kernel: Linux 6.12.47+rpt-rpi-v8
                Architecture: arm64
            OS is similar to:
            Model           : Raspberry Pi 4 Model B Rev 1.2
            Docker          : false
            Virtualization  : none
            Kernel          : aarch64
            Userland        : 64 bit
            Systemuptime and Load:
             19:54:04 up  1:17,  2 users,  load average: 0.37, 0.32, 0.35
            CPU threads: 4
            *** LIFE CYCLE STATUS ***
            Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
            *** RASPBERRY THROTTLING ***
            Current issues:
              Thomas Braun Most Active @Babu242 last edited by
              @babu242 sagte in Alexa 2 meldet immer error 401 unauthorized:
              *** FAILED SERVICES ***
              • NetworkManager-wait-online.service loaded failed failed Network Manager Wait Online
              Ich hatte schon die Vermutung, dass es in Richtung 'Netzwerk' geht.
              Irgendwas klemmt da bei dir.
              systemctl status NetworkManager-wait-online.service
              sagt?
              Und setz den netatmo-crawler vom debug-LogLevel runter. Der interessiert nicht. Und deine shellies scheinen ein falsche mqtt-PW zu haben.
                @babu242
                Die aufzurufende URL steht auch im Log:
                2025-10-21 19:23:51.287  - error: alexa2.0 (1252) Error: Please open http://192.168.178.43:33373/ with your browser and login to Amazon. The cookie will be output here after successfull login.
                Das ist natürlich was anders als:
                Das ist die ip auf die zugegriffen werden soll, geht aber nicht. 192.168.178.79:8081/#tab-instances
                Seite nicht erreichbar
                  Babu242 @Thomas Braun last edited by
                  @thomas-braun sagte in Alexa 2 meldet immer error 401 unauthorized:
                  Sorry mein Fehler tatsächlich habe ich die falsche ip kopiert.
                  Es wurde tatsächlich diese aufgerufen ohne Erfolg!
                    @babu242
                    sagt?
                      Leider habe ich keine Ahnung was das bedeutet oder was das ein kann.
                      Du vielleicht ?
                        @babu242
                        Du sollst dir anschauen, warum der Service nicht startet. Steht in der Regel in der Ausgabe von
                        drin.
                          Soll ich das hier posten weil ich kann damit leider nix anfangen?
                            @babu242
                            Vielleicht aber andere...
                              code_text
                              ```pi@raspberrypi:~ $ systemctl status NetworkManager-wait-online.service
                              × NetworkManager-wait-online.service - Network Manager Wait Online
                                   Loaded: loaded (/lib/systemd/system/NetworkManager-wait-online.service; en>
                                   Active: failed (Result: exit-code) since Tue 2025-10-21 18:37:50 CEST; 2h >
                                     Docs: man:nm-online(1)
                                  Process: 580 ExecStart=/usr/bin/nm-online -s -q (code=exited, status=1/FAIL>
                                 Main PID: 580 (code=exited, status=1/FAILURE)
                                      CPU: 135ms
                              Oct 21 18:36:37 raspberrypi systemd[1]: Starting NetworkManager-wait-online.ser>
                              Oct 21 18:37:50 raspberrypi systemd[1]: NetworkManager-wait-online.service: Mai>
                              Oct 21 18:37:50 raspberrypi systemd[1]: NetworkManager-wait-online.service: Fai>
                              Oct 21 18:37:50 raspberrypi systemd[1]: Failed to start NetworkManager-wait-onl>
                              lines 1-12/12 (END)...skipping...
                                   Loaded: loaded (/lib/systemd/system/NetworkManager-wait-online.service; enabled; preset: enabled)
                                   Active: failed (Result: exit-code) since Tue 2025-10-21 18:37:50 CEST; 2h 28min ago
                                  Process: 580 ExecStart=/usr/bin/nm-online -s -q (code=exited, status=1/FAILURE)
                                      CPU: 135ms
                              Oct 21 18:36:37 raspberrypi systemd[1]: Starting NetworkManager-wait-online.service - Network Manager Wait Online...
                              Oct 21 18:37:50 raspberrypi systemd[1]: NetworkManager-wait-online.service: Main process exited, code=exited, status=1/FAILURE
                              Oct 21 18:37:50 raspberrypi systemd[1]: NetworkManager-wait-online.service: Failed with result 'exit-code'.
                              Oct 21 18:37:50 raspberrypi systemd[1]: Failed to start NetworkManager-wait-online.service - Network Manager Wait Online.
                                @babu242
                                Mach das Terminalfenster größer. Da fehlt rechts was. Vollständig sieht das so aus:
                                echad@chet:~ $ systemctl status NetworkManager-wait-online.service
                                ● NetworkManager-wait-online.service - Network Manager Wait Online
                                     Loaded: loaded (/usr/lib/systemd/system/NetworkManager-wait-online.service; enabled; preset: enabled)
                                     Active: active (exited) since Fri 2025-10-17 19:18:37 CEST; 4 days ago
                                 Invocation: 0d12bc9b8d424505b4cbbcd301f66b88
                                       Docs: man:NetworkManager-wait-online.service(8)
                                    Process: 800 ExecStart=/usr/bin/nm-online -s -q (code=exited, status=0/SUCCESS)
                                   Main PID: 800 (code=exited, status=0/SUCCESS)
                                        CPU: 77ms
                                Oct 17 19:18:33 chet systemd[1]: Starting NetworkManager-wait-online.service - Network Manager Wait Online...
                                Oct 17 19:18:37 chet systemd[1]: Finished NetworkManager-wait-online.service - Network Manager Wait Online.
                                echad@chet:~ $
                                  Hmm
                                  also mein Terminalfenster ist max. groß und ich sehe auch nicht mehr.
                                    @babu242
                                    Du hast das ja auch zweimal aufgerufen...
                                    Bitte immer inkl. LogIn Prompt posten, dann sieht man was wo anfängt und wo was aufhört. Und man sieht auch wo du da im Dateibaum gerade herumstehst. Das kann wichtig sein.
                                    sudo systemctl restart NetworkManager-wait-online.service
                                      code_text
                                      ```pi@raspberrypi:~ $ sudo systemctl restart NetworkManager-wait-online.service
                                           Active: active (exited) since Tue 2025-10-21 21:22:55 CEST; 23s ago
                                          Process: 3062 ExecStart=/usr/bin/nm-online -s -q (code=exited, status=0/SUCCESS)
                                         Main PID: 3062 (code=exited, status=0/SUCCESS)
                                              CPU: 36ms
                                      Oct 21 21:22:55 raspberrypi systemd[1]: Starting NetworkManager-wait-online.service - Network Manager Wait Online...
                                      Oct 21 21:22:55 raspberrypi systemd[1]: Finished NetworkManager-wait-online.service - Network Manager Wait Online.
                                        @babu242
                                        Dann läuft jetzt der Service schon mal wieder.
                                        Nicht das der zwingend was mit deinem Alexa-Proxy zu tun hat, könnte aber sein.
                                        Versuch jetzt nochmal den Adapter einzuloggen, vielleicht auch mal das Cookie neuziehen lassen.
                                          @thomas-braun sagte in Neier Arbeitstitel:
                                          @Homoran Bitte Thread splitten, das wird was anderes als im OP
                                          erledigt!
                                          typischer Fall von eben nicht
                                          @babu242 sagte in Neier Arbeitstitel:
                                          die gleiche Herausforderung.
                                          @Babu242
                                          Bitte Threadtitel anpassen
                                            Babu242 @Homoran last edited by
                                            Danke für denn neuen Thread.
                                            Wie oder wo benenne ich den denn Neu?
                                            81.1k
                                            457
