    3. Einsteigerfragen
    4. Alexa Adapter-Fehler bei Anmeldung im Alexa Konto
      Babu242 @Thomas Braun last edited by
      Leider habe ich keine Ahnung was das bedeutet oder was das ein kann.
      Du vielleicht ?
        Thomas Braun Most Active @Babu242 last edited by
        @babu242
        Du sollst dir anschauen, warum der Service nicht startet. Steht in der Regel in der Ausgabe von
        systemctl status NetworkManager-wait-online.service
        drin.
          @thomas-braun sagte in Alexa 2 meldet immer error 401 unauthorized:
          Soll ich das hier posten weil ich kann damit leider nix anfangen?
            @babu242
            Vielleicht aber andere...
              code_text
              ```pi@raspberrypi:~ $ systemctl status NetworkManager-wait-online.service
              × NetworkManager-wait-online.service - Network Manager Wait Online
                   Loaded: loaded (/lib/systemd/system/NetworkManager-wait-online.service; en>
                   Active: failed (Result: exit-code) since Tue 2025-10-21 18:37:50 CEST; 2h >
                     Docs: man:nm-online(1)
                  Process: 580 ExecStart=/usr/bin/nm-online -s -q (code=exited, status=1/FAIL>
                 Main PID: 580 (code=exited, status=1/FAILURE)
                      CPU: 135ms
              Oct 21 18:36:37 raspberrypi systemd[1]: Starting NetworkManager-wait-online.ser>
              Oct 21 18:37:50 raspberrypi systemd[1]: NetworkManager-wait-online.service: Mai>
              Oct 21 18:37:50 raspberrypi systemd[1]: NetworkManager-wait-online.service: Fai>
              Oct 21 18:37:50 raspberrypi systemd[1]: Failed to start NetworkManager-wait-onl>
              lines 1-12/12 (END)...skipping...
                   Loaded: loaded (/lib/systemd/system/NetworkManager-wait-online.service; enabled; preset: enabled)
                   Active: failed (Result: exit-code) since Tue 2025-10-21 18:37:50 CEST; 2h 28min ago
                  Process: 580 ExecStart=/usr/bin/nm-online -s -q (code=exited, status=1/FAILURE)
                      CPU: 135ms
              Oct 21 18:36:37 raspberrypi systemd[1]: Starting NetworkManager-wait-online.service - Network Manager Wait Online...
              Oct 21 18:37:50 raspberrypi systemd[1]: NetworkManager-wait-online.service: Main process exited, code=exited, status=1/FAILURE
              Oct 21 18:37:50 raspberrypi systemd[1]: NetworkManager-wait-online.service: Failed with result 'exit-code'.
              Oct 21 18:37:50 raspberrypi systemd[1]: Failed to start NetworkManager-wait-online.service - Network Manager Wait Online.
                @babu242
                Mach das Terminalfenster größer. Da fehlt rechts was. Vollständig sieht das so aus:
                echad@chet:~ $ systemctl status NetworkManager-wait-online.service
                ● NetworkManager-wait-online.service - Network Manager Wait Online
                     Loaded: loaded (/usr/lib/systemd/system/NetworkManager-wait-online.service; enabled; preset: enabled)
                     Active: active (exited) since Fri 2025-10-17 19:18:37 CEST; 4 days ago
                 Invocation: 0d12bc9b8d424505b4cbbcd301f66b88
                       Docs: man:NetworkManager-wait-online.service(8)
                    Process: 800 ExecStart=/usr/bin/nm-online -s -q (code=exited, status=0/SUCCESS)
                   Main PID: 800 (code=exited, status=0/SUCCESS)
                        CPU: 77ms
                Oct 17 19:18:33 chet systemd[1]: Starting NetworkManager-wait-online.service - Network Manager Wait Online...
                Oct 17 19:18:37 chet systemd[1]: Finished NetworkManager-wait-online.service - Network Manager Wait Online.
                echad@chet:~ $
                  Hmm
                  also mein Terminalfenster ist max. groß und ich sehe auch nicht mehr.
                    @babu242
                    Du hast das ja auch zweimal aufgerufen...
                    Bitte immer inkl. LogIn Prompt posten, dann sieht man was wo anfängt und wo was aufhört. Und man sieht auch wo du da im Dateibaum gerade herumstehst. Das kann wichtig sein.
                    sudo systemctl restart NetworkManager-wait-online.service
                      code_text
                      ```pi@raspberrypi:~ $ sudo systemctl restart NetworkManager-wait-online.service
                           Active: active (exited) since Tue 2025-10-21 21:22:55 CEST; 23s ago
                          Process: 3062 ExecStart=/usr/bin/nm-online -s -q (code=exited, status=0/SUCCESS)
                         Main PID: 3062 (code=exited, status=0/SUCCESS)
                              CPU: 36ms
                      Oct 21 21:22:55 raspberrypi systemd[1]: Starting NetworkManager-wait-online.service - Network Manager Wait Online...
                      Oct 21 21:22:55 raspberrypi systemd[1]: Finished NetworkManager-wait-online.service - Network Manager Wait Online.
                        @babu242
                        Dann läuft jetzt der Service schon mal wieder.
                        Nicht das der zwingend was mit deinem Alexa-Proxy zu tun hat, könnte aber sein.
                        Versuch jetzt nochmal den Adapter einzuloggen, vielleicht auch mal das Cookie neuziehen lassen.
                          @thomas-braun sagte in Neier Arbeitstitel:
                          @Homoran Bitte Thread splitten, das wird was anderes als im OP
                          erledigt!
                          typischer Fall von eben nicht
                          @babu242 sagte in Neier Arbeitstitel:
                          die gleiche Herausforderung.
                          @Babu242
                          Bitte Threadtitel anpassen
                            Babu242 @Homoran last edited by
                            Danke für denn neuen Thread.
                            Wie oder wo benenne ich den denn Neu?
                              Hi erst mall viele dank für deine Unterstützung.
                              Wollte ich schon gestern Abend sagen, konnte aber keine Nachricht mehr versenden habe dauernd eine Fehlermeldung bekommen.
                              hab ich schon gestern aber auch heute versucht geht nicht.
                                Homoran Global Moderator Administrators @Babu242 last edited by
                                @babu242 ersten Post editieren und Titel ändern
                                • mcm1957
                                  mcm1957 @Babu242 last edited by
                                  @babu242 said in Neier Arbeitstitel:
                                  Wenn du das Posten im Forum meinst:
                                  Einfach F5 / Refresh drücken und dann gehts
                                    Babu242 @mcm1957 last edited by
                                    @mcm1957
                                    ah nein Sorry ich hab das versucht:
                                      Danke hab es geändert
                                        so ich habe jetzt den Alexa Adapter neu installiert als eine zweite Instanz.
                                        Wenn ich dort jetzt auf den link gehe könnte ich mich wohl einloggen .
                                        Hab ich aber noch nicht.
                                        Macht doch aber kein sinn, oder?
                                          @babu242 sagte in Alexa Adapter-Fehler bei Anmeldung im Alexa Konto:
                                          Warum nicht?
                                            Kann ich mir da nix zerschießen ich weis es halt nicht ?
                                            81.1k
                                            457
