Zigbee Adaper läuft nicht
error: zigbee.0 (38369) Starting zigbee-herdsman problem : Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
Steck den Stick mal eine Minute auf zwei aus und dann wieder rein. Vielleicht auch mal die Firmwareupdaten, jenachdem wie alt die ist.
@thomas-braun said in Zigbee Adaper läuft nicht:
Hab ich gemacht, der Sonoff Flasher hat auch eine aktuellere Version gefunden.
Das Ergebnis ist gleich:overriding zigbee options with: extPanID : a019c6b597d65071 panID : 8820 channel : 15 port : /dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_7a6336835bf3ef119b6dbb1b6d9880ab-if00-port0 adapterType : zstack baudRate : 115200 precfgkey : 01030507090B0D0F00020406080A0C0D flowCTRL : false Starting Adapter npm ... Installed Version: iobroker.zigbee@3.1.5 (Converters 25.31.0 Herdsman 6.3.1) Starting zigbee-herdsman... Unable to obtain herdsman settings Starting zigbee-herdsman problem : Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms) Failed to start Zigbee: no message given
Hier noch der neueste Diag:
Script v.2025-08-09 *** BASE SYSTEM *** Operating System: Debian GNU/Linux 12 (bookworm) Static hostname: raspberrypi Icon name: computer Kernel: Linux 6.12.25+rpt-rpi-v8 Architecture: arm64 OS is similar to: Model : Raspberry Pi 4 Model B Rev 1.5 Docker : false Virtualization : none Kernel : aarch64 Userland : 64 bit Systemuptime and Load: 13:24:08 up 5:40, 2 users, load average: 2.96, 2.98, 2.68 CPU threads: 4 *** LIFE CYCLE STATUS *** Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time! *** RASPBERRY THROTTLING *** Current issues: No throttling issues detected. Previously detected issues: No throttling issues detected. *** TIME AND TIMEZONES *** Local time: Thu 2025-10-23 13:24:09 CEST Universal time: Thu 2025-10-23 11:24:09 UTC RTC time: n/a Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: active RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': admin HOME=/home/admin GROUPS=admin adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker User that is running 'js-controller': iobroker HOME=/home/iobroker GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c *** DISPLAY-SERVER SETUP *** Display-Server: false Unit display-manager.service could not be found. Display-Manager: Desktop: Session: tty *** MEMORY *** total used free shared buff/cache available Mem: 1.9G 1.5G 155M 1.5M 316M 398M Swap: 536M 536M 327K Total: 2.5G 2.1G 155M Active iob-Instances: 21 1846 M total memory 1466 M used memory 658 M active memory 844 M inactive memory 147 M free memory 25 M buffer memory 277 M swap cache 511 M total swap 511 M used swap 0 M free swap *** top - Table Of Processes *** top - 13:24:09 up 5:40, 2 users, load average: 2.96, 2.98, 2.68 Tasks: 201 total, 4 running, 197 sleeping, 0 stopped, 0 zombie %Cpu(s): 62.5 us, 12.5 sy, 0.0 ni, 25.0 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st MiB Mem : 1846.3 total, 146.0 free, 1467.7 used, 302.3 buff/cache MiB Swap: 512.0 total, 0.3 free, 511.7 used. 378.6 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION 0 loaded units listed. *** DMESG CRITICAL ERRORS *** No critical errors detected *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on udev devtmpfs 659M 0 659M 0% /dev tmpfs tmpfs 185M 4.3M 181M 3% /run /dev/mmcblk0p2 ext4 115G 17G 93G 16% / tmpfs tmpfs 924M 0 924M 0% /dev/shm tmpfs tmpfs 5.0M 16K 5.0M 1% /run/lock /dev/mmcblk0p1 vfat 510M 58M 453M 12% /boot/firmware tmpfs tmpfs 185M 0 185M 0% /run/user/1000 Messages concerning ext4 filesystem in dmesg: [Thu Oct 23 07:44:04 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 smsc95xx.macaddr=E4:5F:01:CF:41:0E vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=5c449d3e-02 rootfstype=ext4 fsck.repair=yes rootwait [Thu Oct 23 07:44:05 2025] EXT4-fs (mmcblk0p2): mounted filesystem 8f6cdea4-22b2-47be-88eb-087a00e3ee2b ro with ordered data mode. Quota mode: none. [Thu Oct 23 07:44:06 2025] EXT4-fs (mmcblk0p2): re-mounted 8f6cdea4-22b2-47be-88eb-087a00e3ee2b r/w. Quota mode: none. Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / /dev/mmcblk0p2 ext4 rw,noatime,commit=600 `-/boot/firmware /dev/mmcblk0p1 vfat rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro Files in neuralgic directories: /var: 951M /var/ 270M /var/cache 264M /var/cache/apt 168M /var/lib 151M /var/cache/apt/archives Archived and active journals take up 3.1M in the file system. /opt/iobroker/backups: 160M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 11G /opt/iobroker/iobroker-data/ioBroker_History 11G /opt/iobroker/iobroker-data/ 199M /opt/iobroker/iobroker-data/files 109M /opt/iobroker/iobroker-data/backup-objects 100M /opt/iobroker/iobroker-data/sonosCache The five largest files in iobroker-data are: 24M /opt/iobroker/iobroker-data/objects.jsonl 24M /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map 18M /opt/iobroker/iobroker-data/files/matter.admin/assets/index-CkWJSD9z.js 16M /opt/iobroker/iobroker-data/states.jsonl 11M /opt/iobroker/iobroker-data/ioBroker_History/20250723/history.0_userdata.0.PV.Stromverbrauch_aktuell.json USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': /dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_7a6336835bf3ef119b6dbb1b6d9880ab-if00-port0 /dev/serial/by-id/usb-1a86_USB2.0-Ser_-if00-port0 *** ZigBee Settings *** HINT: Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting: /dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_7a6336835bf3ef119b6dbb1b6d9880ab-if00-port0 Zigbee Network Settings on your coordinator/in nvbackup are: zigbee.X Extended Pan ID: *** MASKED *** Pan ID: *** MASKED *** Channel: *** MASKED *** Network Key: *** MASKED *** To unmask the settings run 'iob diag --unmask' *** NodeJS-Installation *** /usr/bin/nodejs v22.21.0 /usr/bin/node v22.21.0 /usr/bin/npm 10.9.4 /usr/bin/npx 10.9.4 /usr/bin/corepack 0.34.0 nodejs: Installed: 22.21.0-1nodesource1 Candidate: 22.21.0-1nodesource1 Version table: *** 22.21.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 100 /var/lib/dpkg/status 22.20.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.19.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.17.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.15.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.13.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.5.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.4.1-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 22.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_22.x nodistro/main arm64 Packages 18.20.4+dfsg-1~deb12u1 500 500 http://deb.debian.org/debian bookworm/main arm64 Packages 500 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages Temp directories causing deletion problem: 0 No problems detected Errors in npm tree: 0 No problems detected Checking for nodejs vulnerability: █████ ██ ██ ██████ ██████ ██████ ██████ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ███████ ██ ██ ██ ███ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ██ ███████ ███████ ██████ ██████ ██████ ██████ ██ *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Hosts: raspberrypi raspberrypi (version: 7.0.7, hostname: raspberrypi , alive, uptime: 15113) Core adapters versions js-controller: 7.0.7 admin: 7.7.2 javascript: 8.9.2 nodejs modules from github: 0 Adapter State + system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0, run as: admin system.adapter.alias-manager.0 : alias-manager : raspberrypi - disabled + system.adapter.backitup.0 : backitup : raspberrypi - enabled system.adapter.devices.0 : devices : raspberrypi - disabled system.adapter.discovery.0 : discovery : raspberrypi - disabled + system.adapter.doorbird.0 : doorbird : raspberrypi - enabled system.adapter.dwd.0 : dwd : raspberrypi - enabled + system.adapter.email.0 : email : raspberrypi - enabled system.adapter.feiertage.0 : feiertage : raspberrypi - enabled system.adapter.flot.0 : flot : raspberrypi - disabled + system.adapter.followthesun.0 : followthesun : raspberrypi - enabled + system.adapter.fronius.0 : fronius : raspberrypi - enabled system.adapter.go-e.0 : go-e : raspberrypi - disabled + system.adapter.history.0 : history : raspberrypi - enabled system.adapter.ical.0 : ical : raspberrypi - disabled + system.adapter.javascript.0 : javascript : raspberrypi - enabled system.adapter.matter.0 : matter : raspberrypi - disabled + system.adapter.modbus.0 : modbus : raspberrypi - enabled + system.adapter.netatmo.0 : netatmo : raspberrypi - enabled + system.adapter.openknx.0 : openknx : raspberrypi - enabled system.adapter.operating-hours.0 : operating-hours : raspberrypi - disabled + system.adapter.pushsafer.0 : pushsafer : raspberrypi - enabled system.adapter.pvforecast.0 : pvforecast : raspberrypi - disabled system.adapter.roborock.0 : roborock : raspberrypi - disabled system.adapter.sayit.0 : sayit : raspberrypi - enabled system.adapter.schoolfree.0 : schoolfree : raspberrypi - enabled + system.adapter.simple-api.0 : simple-api : raspberrypi - enabled, port: 8087, bind: 0.0.0.0, run as: admin + system.adapter.smartgarden.0 : smartgarden : raspberrypi - enabled + system.adapter.sonos.0 : sonos : raspberrypi - enabled + system.adapter.statistics.0 : statistics : raspberrypi - enabled + system.adapter.tr-064.0 : tr-064 : raspberrypi - enabled system.adapter.weatherunderground.0 : weatherunderground : raspberrypi - enabled + system.adapter.web.0 : web : raspberrypi - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.yahka.0 : yahka : raspberrypi - enabled + system.adapter.zigbee.0 : zigbee : raspberrypi - enabled, port: /dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_7a6336835bf3ef119b6dbb1b6d9880ab-if00-port0 + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.simple-api.0 : simple-api : raspberrypi - enabled, port: 8087, bind: 0.0.0.0, run as: admin + system.adapter.web.0 : web : raspberrypi - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : raspberrypi - enabled, port: /dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_7a6336835bf3ef119b6dbb1b6d9880ab-if00-port0 ioBroker-Repositories ┌─────────┬──────────┬─────────────────────────────────────────────────────────┬──────────────┐ │ (index) │ name │ url │ auto upgrade │ ├─────────┼──────────┼─────────────────────────────────────────────────────────┼──────────────┤ │ 0 │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ true │ │ 1 │ 'beta' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │ └─────────┴──────────┴─────────────────────────────────────────────────────────┴──────────────┘ Active repo(s): stable Upgrade policy: minor Installed ioBroker-Adapters Used repository: stable Adapter "admin" : 7.7.2 , installed 7.7.2 Adapter "alias-manager": 2.0.0 , installed 2.0.0 Adapter "backitup" : 3.3.5 , installed 3.3.5 Adapter "devices" : 1.2.8 , installed 1.2.8 Adapter "discovery" : 5.0.0 , installed 5.0.0 Adapter "doorbird" : 3.0.0 , installed 3.0.0 Adapter "dwd" : 2.8.5 , installed 2.8.5 Adapter "email" : 2.0.4 , installed 2.0.4 Adapter "feiertage" : 1.2.1 , installed 1.2.1 Adapter "flot" : 1.12.0 , installed 1.12.0 Adapter "followthesun" : 0.5.2 , installed 0.5.2 Adapter "fronius" : 2.1.1 , installed 2.1.1 Adapter "go-e" : 1.0.41 , installed 1.0.41 Adapter "history" : 3.0.1 , installed 3.0.1 Adapter "ical" : 1.17.0 , installed 1.17.0 Adapter "javascript" : 8.9.2 , installed 8.9.2 Controller "js-controller": 7.0.7 , installed 7.0.7 Adapter "matter" : 0.5.5 , installed 0.5.5 Adapter "modbus" : 6.3.2 , installed 6.3.2 Adapter "netatmo" : 3.1.0 , installed 3.1.0 Adapter "openknx" : 0.9.0 , installed 0.9.0 Adapter "operating-hours": 1.3.0 , installed 1.3.0 Adapter "pushsafer" : 1.1.0 , installed 1.1.0 Adapter "pvforecast" : 5.0.0 , installed 5.0.0 Adapter "roborock" : 0.6.18 , installed 0.6.18 Adapter "sayit" : 5.0.0 , installed 5.0.0 Adapter "schoolfree" : 1.1.12 , installed 1.1.12 Adapter "simple-api" : 2.8.0 , installed 2.8.0 Adapter "smartgarden" : 2.0.1 , installed 2.0.1 Adapter "socketio" : 6.7.1 , installed 6.7.1 Adapter "sonos" : 3.0.0 , installed 3.0.0 Adapter "statistics" : 2.4.0 , installed 2.4.0 Adapter "tr-064" : 4.3.0 , installed 4.3.0 Adapter "weatherunderground": 3.7.0, installed 3.7.0 Adapter "web" : 7.0.8 , installed 7.0.8 Adapter "ws" : 2.6.2 , installed 2.6.2 Adapter "yahka" : 1.1.5 , installed 1.1.5 Adapter "zigbee" : 3.1.5 , installed 3.1.5 Objects and States Please stand by - This may take a while Objects: 6967 States: 5721 *** OS-Repositories and Updates *** Hit:1 http://deb.debian.org/debian bookworm InRelease Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease Hit:3 http://deb.debian.org/debian bookworm-updates InRelease Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease Hit:5 https://deb.nodesource.com/node_22.x nodistro InRelease Reading package lists... Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 127.0.0.1:45649 0.0.0.0:* LISTEN 1001 83667 38354/io.yahka.0 tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 83258 38026/iobroker.js-c tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 82405 38026/iobroker.js-c tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 73227 30450/sshd: /usr/sb tcp 0 0 192.168.10.13:8100 0.0.0.0:* LISTEN 1001 83671 38395/io.doorbird.0 tcp6 0 0 :::8087 :::* LISTEN 1001 85385 38455/io.simple-api tcp6 0 0 :::8082 :::* LISTEN 1001 86134 38500/io.web.0 tcp6 0 0 :::8081 :::* LISTEN 1001 79792 38048/io.admin.0 tcp6 0 0 :::3500 :::* LISTEN 1001 84206 38298/io.sonos.0 tcp6 0 0 :::22 :::* LISTEN 0 73229 30450/sshd: /usr/sb tcp6 0 0 :::40033 :::* LISTEN 1001 83666 38354/io.yahka.0 udp 0 0 0.0.0.0:53381 0.0.0.0:* 104 6399 456/avahi-daemon: r udp 0 0 0.0.0.0:5353 0.0.0.0:* 104 6397 456/avahi-daemon: r udp 0 0 0.0.0.0:41727 0.0.0.0:* 1001 82677 38267/io.openknx.0 udp6 0 0 :::5353 :::* 104 6398 456/avahi-daemon: r udp6 0 0 fe80::83ef:c731:b6f:546 :::* 0 6487 533/NetworkManager udp6 0 0 :::50840 :::* 104 6400 456/avahi-daemon: r *** Log File - Last 25 Lines *** 2025-10-23 13:25:07.973 - info: host.raspberrypi stopInstance system.adapter.sayit.0 (force=false, process=true) 2025-10-23 13:25:07.994 - info: sayit.0 (89581) stopping... 2025-10-23 13:25:08.501 - info: sayit.0 (89581) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason 2025-10-23 13:25:08.974 - info: host.raspberrypi stopInstance timeout 1000 system.adapter.sayit.0 killing pid 89581 2025-10-23 13:25:09.037 - warn: host.raspberrypi instance system.adapter.sayit.0 terminated due to SIGKILL 2025-10-23 13:25:09.037 - info: host.raspberrypi instance system.adapter.sayit.0 terminated with code null () 2025-10-23 13:25:09.716 - info: host.raspberrypi instance system.adapter.sayit.0 in version "5.0.0" started with pid 89939 2025-10-23 13:25:13.597 - info: sayit.0 (89939) starting. Version 5.0.0 in /opt/iobroker/node_modules/iobroker.sayit, node: v22.21.0, js-controller: 7.0.7 2025-10-23 13:25:13.736 - info: sayit.0 (89939) Upload announce mp3 files 2025-10-23 13:25:13.772 - info: host.raspberrypi stopInstance system.adapter.sayit.0 (force=false, process=true) 2025-10-23 13:25:13.794 - info: sayit.0 (89939) stopping... 2025-10-23 13:25:14.300 - info: sayit.0 (89939) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason 2025-10-23 13:25:14.775 - info: host.raspberrypi stopInstance timeout 1000 system.adapter.sayit.0 killing pid 89939 2025-10-23 13:25:14.837 - warn: host.raspberrypi instance system.adapter.sayit.0 terminated due to SIGKILL 2025-10-23 13:25:14.837 - info: host.raspberrypi instance system.adapter.sayit.0 terminated with code null () 2025-10-23 13:25:15.947 - info: host.raspberrypi instance system.adapter.sayit.0 in version "5.0.0" started with pid 89989 2025-10-23 13:25:21.223 - info: sayit.0 (89989) starting. Version 5.0.0 in /opt/iobroker/node_modules/iobroker.sayit, node: v22.21.0, js-controller: 7.0.7 2025-10-23 13:25:21.392 - info: sayit.0 (89989) Upload announce mp3 files 2025-10-23 13:25:21.443 - info: host.raspberrypi stopInstance system.adapter.sayit.0 (force=false, process=true) 2025-10-23 13:25:21.452 - info: sayit.0 (89989) stopping... 2025-10-23 13:25:21.958 - info: sayit.0 (89989) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason 2025-10-23 13:25:22.445 - info: host.raspberrypi stopInstance timeout 1000 system.adapter.sayit.0 killing pid 89989 2025-10-23 13:25:22.514 - warn: host.raspberrypi instance system.adapter.sayit.0 terminated due to SIGKILL 2025-10-23 13:25:22.516 - info: host.raspberrypi instance system.adapter.sayit.0 terminated with code null () 2025-10-23 13:25:23.120 - info: host.raspberrypi instance system.adapter.sayit.0 in version "5.0.0" started with pid 90378
Was bedeutet eigentlich?
/dev/serial/by-id/usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_7a6336835bf3ef119b6dbb1b6d9880ab-if00-port0Ich kann übrigens immer noch kein COM-Anschlussname auswählen, sondern muss das aus dem Diag reinkopieren.
Im "by-id" verzeichnis scheint es laut Diag Output ein zweites USB Device zu geben. Falls das nicht die Debug-Schnittstelle des Zigbee-Sticks ist, vielleicht mal entfernen / abziehen...
Ansonsten vielleicht die Ausgabe von
frigate@ubuntu-frigate-privileged:/media/frigate/recordings$ ls -l /dev/serial/by-id total 0 lrwxrwxrwx 1 root root 13 Sep 17 10:17 usb-dresden_elektronik_ConBee_III_DE03189531-if00-port0 -> ../../ttyUSB0 lrwxrwxrwx 1 root root 13 Oct 6 18:49 usb-WEMOS.CC_LOLIN-S2-MINI_0-if00 -> ../../ttyACM0 frigate@ubuntu-frigate-privileged:/media/frigate/recordings$
@martinp said in Zigbee Adaper läuft nicht:
Wie mache ich das?
Steht in der ersten Zeile
In der Kommandozeile eingeben ...
Da kommt folgendes:
admin@raspberrypi:~ $ ls -l /dev/serial/by-id total 0 lrwxrwxrwx 1 root root 13 Oct 23 07:43 usb-1a86_USB2.0-Ser_-if00-port0 -> ../../ttyUSB0 lrwxrwxrwx 1 root root 13 Oct 23 13:18 usb-Itead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_V2_7a6336835bf3ef119b6dbb1b6d9880ab-if00-port0 -> ../../ttyUSB1 admin@raspberrypi:~ $
Merkwürdig.
Gib mal das Link-Target direkt in den Einstellungen ein.
Also/dev/ttyUSB0
bzw.
/dev/ttyUSB1
@thomas-braun sagte in Zigbee Adaper läuft nicht:
Merkwürdig.
Also/dev/ttyUSB0
bzw.
/dev/ttyUSB1
Definitiv
/dev/ttuUSB1
. Unter/dev/ttyUSB0
ist die Firmware nicht erreichbar !Die Meldung
bedeutet das der Adapter die serielle Schnittstelle zwar geöffnet bekommt, nicht aber per Seriellen Befehlen mit der Firmware sprechen kann.
@sascha-0 Ich hab da mal ein paar Fragen:
- Hast du den Stick auf dem Rechner mit Firmware versorgt auf dem du den jetzt auch nutzt ?
- Hast du andere Geräte an anderen USB Ports angeschlossen (wenn ja, welche) (Ziel: NEIN - insbesondere keine SSD / USB3 HDD)
- Hast du eine USB Verlängerung für den Stick benutzt ? (Ziel: JA)
A.
l das
Leider mit dem gleichen Ergebnis:
overriding zigbee options with: extPanID : a019c6b597d65071 panID : 8820 channel : 15 port : /dev/ttyUSB1 adapterType : zstack baudRate : 115200 precfgkey : 01030507090B0D0F00020406080A0C0D flowCTRL : false Starting Adapter npm ... Installed Version: iobroker.zigbee@3.1.5 (Converters 25.31.0 Herdsman 6.3.1) Starting zigbee-herdsman... Unable to obtain herdsman settings Starting zigbee-herdsman problem : Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms) Failed to start Zigbee: no message given
@asgothian said in Zigbee Adaper läuft nicht:
Hast du eine USB Verlängerung für den Stick benutzt ? (Ziel: JA)Ich habe das Firmware Update auf meinem Windows PC damit gemacht: https://dongle.sonoff.tech/sonoff-dongle-flasher/
Das andere USB Gerät ist eine Wechselrichter Anbindung mit Modbus.
Klar habe ich eine Verlängerung verwendet, geht ja physisch schon nicht anders.
@sascha-0 Welche Firmware hast Du auf den Stick gespielt, es soll Varianten für Router-Betrieb, und welche für Coordinator geben...
Coordinator und Version >= 2.7.x wären korrekt
Das sieht so aus:
@sascha-0 Ich bin auch nicht gerade Experte in diesen Chipsets
Ist "adapterType : zstack" aus Deinem Logging denn überhaupt korrekt - müsste es nicht "ember" heißen?
"zstack" ist doch nur für Ti-Chipsets, und der Dongle-E hat SiLab EFR32...
https://github.com/Koenkk/zigbee2mqtt/discussions/21462
Update 2025
The ember driver is now the recommended way to use EmberZNet-based adapters.
The ezsp driver is deprecated but kept for old firmware support (pre 7.4.x).Das hier scheint nicht mehr zu gelten
https://github.com/Koenkk/Z-Stack-firmware/discussions/497
Regardless,, it is specifically recommend to use a EmberZNet NCP firmware with 115200 speed for Z2M (not a RCP based firmware).
Ich glaube das war es. Jedenfalls wird jetzt das hier ausgegeben:
overriding zigbee options with: extPanID : a019c6b597d65071 panID : 8820 channel : 15 port : /dev/ttyUSB1 adapterType : ember baudRate : 115200 precfgkey : 01030507090B0D0F00020406080A0C0D flowCTRL : false Starting Adapter npm ... Installed Version: iobroker.zigbee@3.1.5 (Converters 25.31.0 Herdsman 6.3.1) Starting zigbee-herdsman... Zigbee-Herdsman started successfully with Coordinator firmware version: EmberZNet : 8.0.2 [GA] (X-X.X.X.X) Network parameters: panID=8820 channel=15 extendedPanID=7150d697b5c619a0 Unable to disable LED, unsupported function. No devices
Und ich glaube ich kann jetzt Geräte koppeln:
@sascha-0 sagte in Zigbee Adaper läuft nicht:
Kannst du. Aber das hier:
weist darauf hin das du den Haken
nicht gesetzt hast. Sprich wenn du den Adapter neu startest startet Dein Zigbee Netz aktuell nicht
A.
