    3. Off Topic
    4. Pflege des Betriebssystems
    5. Upgrade von Debian 12 'Bookworm' auf Debian 13 'Trixie'
      Cumulus 0 @Thomas Braun last edited by
      @thomas-braun said in Upgrade von Debian 12 'Bookworm' auf Debian 13 'Trixie':
      mount | sort
      Ja, im Juni neu installiert.
       mount | sort
      //192.168.xxx/fritz.nas/rout_bak/RaspSys on /media/nas type cifs (rw,relatime,vers=3.1.1,sec=ntlmv2,cache=strict,upcall_target=app,username=,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.,file_mode=0755,dir_mode=0755,soft,nounix,mapposix,reparse=nfs,rsize=1048576,wsize=1048576,bsize=1048576,retrans=1,echo_interval=60,actimeo=1,closetimeo=1,user=xxx)
      binfmt_misc on /proc/sys/fs/binfmt_misc type binfmt_misc (rw,nosuid,nodev,noexec,relatime)
      bpf on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
      cgroup2 on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot)
      configfs on /sys/kernel/config type configfs (rw,nosuid,nodev,noexec,relatime)
      debugfs on /sys/kernel/debug type debugfs (rw,nosuid,nodev,noexec,relatime)
      /dev/mmcblk0p2 on / type ext4 (rw,noatime)
      devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
      fusectl on /sys/fs/fuse/connections type fusectl (rw,nosuid,nodev,noexec,relatime)
      mqueue on /dev/mqueue type mqueue (rw,nosuid,nodev,noexec,relatime)
      proc on /proc type proc (rw,relatime)
      pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
      ramfs on /run/credentials/systemd-sysctl.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)
      ramfs on /run/credentials/systemd-sysusers.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)
      ramfs on /run/credentials/systemd-tmpfiles-setup-dev.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)
      ramfs on /run/credentials/systemd-tmpfiles-setup.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)
      securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
      sunrpc on /run/rpc_pipefs type rpc_pipefs (rw,relatime)
      sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
      systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=30,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=3534)
      tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
      tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
      tmpfs on /run type tmpfs (rw,nosuid,nodev,noexec,relatime,size=800856k,mode=755)
      tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=800852k,nr_inodes=200213,mode=700,uid=1000,gid=1000)
      tracefs on /sys/kernel/tracing type tracefs (rw,nosuid,nodev,noexec,relatime)
      udev on /dev type devtmpfs (rw,nosuid,relatime,size=3736304k,nr_inodes=934076,mode=755)
        Thomas Braun Most Active @Cumulus 0 last edited by
        @cumulus-0
        Da fehlt tatsächlich der mount von
        /dev/mmcblk0p2 auf /boot/firmware
        Wie bootest du das Ding denn??
        C 1 Reply Last reply Reply Quote 1
          Cumulus 0 @Thomas Braun last edited by Cumulus 0
           sudo parted -l
          Model: SD Y032V (sd/mmc)
          Disk /dev/mmcblk0: 31.0GB
          Sector size (logical/physical): 512B/512B
          Partition Table: msdos
          Disk Flags:
          Number  Start   End     Size    Type     File system  Flags
           1      8389kB  545MB   537MB   primary  fat32        lba
           2      545MB   31.0GB  30.5GB  primary  ext4
          Das hat bisher nie gestört. Vermutlich ist das nicht das einzige Problem.
          Ist eine Neuinstallation evtl. besser? Im Juni von Debian 11 auf 12. Dann hab ich noch 2-3 Jahre Zeit, oder?
            @cumulus-0 sagte in Upgrade von Debian 12 'Bookworm' auf Debian 13 'Trixie':
            Joh, und dabei geht das System an genau der Stelle kaputt.
            Das funktioniert nämlich nicht sauber. Installier es neu. Und zwar nicht in zwei Jahren sondern in zwei Wochen.
              Super! Das war aber eine Neuinstallation auf neuer Karte.
              Dann werde ich wohl den einfachen Weg gehen müssen. Ein paar Systemanwendungen wie email, open SSH mit Root und Backup sind dann wieder ein Problem.
              Aber erstmal vielen Dank für die schnelle und tolle Hilfe!
                open SSH mit Root
                Macht man NICHT.
                  Ist aber sehr praktisch, wenn man das braucht. Aber ich räume ein, root hab ich noch nie gebraucht. Aber ich habe immer ein schlechtes Gefühl, wenn ich irgendwo ausgesperrt bin.
                  Aber mein Vollbackup war gestern sehr praktisch. Das hatte ich vorher gezogen. Nach missglücktem Versuch einfach die Karte wechseln, und alles läuft wieder. Licht im Haus, Auto laden, PV und die ganzen Erfassungen dazu sind schon praktisch.
                  Also nochmals vielen Dank an Thomas!
                    Man braucht es ja eben NIE. Meld dich mit dem default user an und verwende dann innerhalb des Systems sudo.
                    • Siggi0904
                      Siggi0904 @Codierknecht last edited by Siggi0904
                      @codierknecht ich lauf bei meiner Synology seit dem Upgrade auf Trixie in den gleichen Fehler.
                      Wo finde ich denn die mysqldump.cnf ?
                      Dank dir.
                      Edit: gefunden, Datei liegt in /etc/mysql/conf.d
                      Danke für den super Hinweis, ich hatte nämlich keine Meldung erhalten, die erschien nur nach dem Neustart heute beim node-js update.
                      • David G.
                        David G. @Thomas Braun last edited by
                        Ich habe mal eine Frage zu den gepinnten Paketen.
                        Warum aktualisiert man diese nicht vor dem Update auf Trixie sondern erst während dessen?
                          Thomas Braun Most Active @David G. last edited by
                          @david-g sagte in Upgrade von Debian 12 'Bookworm' auf Debian 13 'Trixie':
                          Weil es keinen Unterschied macht. Du lässt die ja wieder freilaufen beim Upgrade. Sollten ja auch nicht viele sein.
                          • David G.
                            Danke.
                            Hatte bisher nie welche.
                            Hab mittlerweile alle Rechner upgedatet.
                            Auf der Arbeit habe ich noch einige.
                            Dafür hab ich mir grad ein kleines Script geschrieben, dabei hab ich mir die Frage grad gestellt.
                            81.1k
                            192
                            26209
