    3. Off Topic
    4. Homematic RPC liefert keine Statusänderungen
    • haselchen
      haselchen Most Active @heldchen last edited by
      @heldchen
      Mehr Infos liefern.
      Zuerst mal in Codetags die Ausgabe von
      iob diag
      Sollte es nicht auf Anhieb funktionieren
      iob fix
      vorher.
        heldchen @haselchen last edited by heldchen
        @haselchen
        Script v.2025-08-09
        *** BASE SYSTEM ***
         Static hostname: PM-iObroker
               Icon name: computer-container
                 Chassis: container ☐
          Virtualization: lxc
                  Kernel: Linux 6.14.11-4-pve
            Architecture: x86-64
        OS is similar to:
        model name      : 13th Gen Intel(R) Core(TM) i9-13900H
        Docker          : false
        Virtualization  : lxc
        Kernel          : x86_64
        Userland        : 64 bit
        Systemuptime and Load:
         01:33:36 up 4 min,  2 users,  load average: 1.02, 1.35, 1.28
        CPU threads: 2
        *** LIFE CYCLE STATUS ***
        Debian 'bookworm' is the current oldstable version. Please upgrade to the latest stable release 'trixie' in due time!
        *** TIME AND TIMEZONES ***
                       Local time: Sun 2025-10-26 01:33:36 CEST
                   Universal time: Sat 2025-10-25 23:33:36 UTC
                         RTC time: n/a
                      NTP service: inactive
                  RTC in local TZ: no
        *** Users and Groups ***
        User that called 'iob diag':
        admin
        HOME=/home/admin
        GROUPS=admin adm dialout sudo audio video plugdev users iobroker
        iobroker
        HOME=/home/iobroker
        GROUPS=iobroker tty dialout audio video plugdev
        *** DISPLAY-SERVER SETUP ***
        Display-Server:         false
        Unit display-manager.service could not be found.
        Display-Manager:
        Desktop:
        Session:
        *** MEMORY ***
        Mem:            2.1G        1.5G        103M        118K        578M        682M
        Swap:           2.1G          0B        2.1G
        Total:          4.3G        1.5G        2.3G
        Active iob-Instances:   22
                 2048 M total memory
                 1398 M used memory
                 1456 M active memory
                  335 M inactive memory
                   97 M free memory
                    0 M buffer memory
                  552 M swap cache
                 2048 M total swap
                    0 M used swap
                 2048 M free swap
        top - 01:33:37 up 4 min,  2 users,  load average: 0.94, 1.33, 1.27
        Tasks:  48 total,   1 running,  47 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
        MiB Mem :   2048.0 total,     95.9 free,   1399.9 used,    552.3 buff/cache
        MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.    648.1 avail Mem
        *** FAILED SERVICES ***
          UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
        * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
        LOAD   = Reflects whether the unit definition was properly loaded.
        ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
        SUB    = The low-level unit activation state, values depend on unit type.
        1 loaded units listed.
        *** DMESG CRITICAL ERRORS ***
        dmesg: read kernel buffer failed: Operation not permitted
        No critical errors detected
        *** FILESYSTEM ***
        Filesystem                       Type      Size  Used Avail Use% Mounted on
        /dev/mapper/pve-vm--405--disk--0 ext4       20G  4.6G   14G  25% /
        none                             tmpfs     492K  4.0K  488K   1% /dev
        udev                             devtmpfs   32G     0   32G   0% /dev/tty
        tmpfs                            tmpfs      32G     0   32G   0% /dev/shm
        tmpfs                            tmpfs      13G  112K   13G   1% /run
        tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
        Show mounted filesystems:
        TARGET SOURCE                           FSTYPE OPTIONS
        /      /dev/mapper/pve-vm--405--disk--0 ext4   rw,relatime,stripe=16
        /var:
        635M    /var/
        335M    /var/cache
        331M    /var/cache/apt
        255M    /var/cache/apt/archives
        152M    /var/log/journal/c643c63321f8461eb5173bd401c846d2
        Archived and active journals take up 151.5M in the file system.
        /opt/iobroker/backups:
        500M    /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        499M    /opt/iobroker/iobroker-data/
        374M    /opt/iobroker/iobroker-data/files
        104M    /opt/iobroker/iobroker-data/backup-objects
        78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
        48M     /opt/iobroker/iobroker-data/files/iot.admin
        38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
        25M     /opt/iobroker/iobroker-data/files/wireless-settings.admin/static/js/main.fe851d24.js.map
        24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
        18M     /opt/iobroker/iobroker-data/objects.jsonl
        11M     /opt/iobroker/iobroker-data/files/wireless-settings.admin/static/js/main.fe851d24.js
        USB-Devices by-id:
        No Devices found 'by-id'
        Zigbee Network Settings on your coordinator/in nvbackup are:
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        To unmask the settings run 'iob diag --unmask'
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v20.19.5
        /usr/bin/node           v20.19.5
        /usr/bin/npm            10.8.2
        /usr/bin/npx            10.8.2
        /usr/bin/corepack       0.33.0
        nodejs:
          Installed: 20.19.5-1nodesource1
          Candidate: 20.19.5-1nodesource1
          Version table:
         *** 20.19.5-1nodesource1 1001
                500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                100 /var/lib/dpkg/status
             20.19.4-1nodesource1 1001
             20.19.3-1nodesource1 1001
             20.19.2-1nodesource1 1001
             20.19.1-1nodesource1 1001
             20.19.0-1nodesource1 1001
             20.18.3-1nodesource1 1001
             20.18.2-1nodesource1 1001
             20.18.1-1nodesource1 1001
             20.18.0-1nodesource1 1001
             20.17.0-1nodesource1 1001
             20.16.0-1nodesource1 1001
             20.15.1-1nodesource1 1001
             20.15.0-1nodesource1 1001
             20.14.0-1nodesource1 1001
             20.13.1-1nodesource1 1001
             20.13.0-1nodesource1 1001
             20.12.2-1nodesource1 1001
             20.12.1-1nodesource1 1001
             20.12.0-1nodesource1 1001
             20.11.1-1nodesource1 1001
             20.11.0-1nodesource1 1001
             20.10.0-1nodesource1 1001
             20.9.0-1nodesource1 1001
             20.8.1-1nodesource1 1001
             20.8.0-1nodesource1 1001
             20.7.0-1nodesource1 1001
             20.6.1-1nodesource1 1001
             20.6.0-1nodesource1 1001
             20.5.1-1nodesource1 1001
             20.5.0-1nodesource1 1001
             20.4.0-1nodesource1 1001
             20.3.1-1nodesource1 1001
             20.3.0-1nodesource1 1001
             20.2.0-1nodesource1 1001
             20.1.0-1nodesource1 1001
             20.0.0-1nodesource1 1001
             18.20.4+dfsg-1~deb12u1 500
                500 http://deb.debian.org/debian bookworm/main amd64 Packages
                500 http://security.debian.org bookworm-security/main amd64 Packages
        No problems detected
        Errors in npm tree: 0
        Checking for nodejs vulnerability:
        *** ioBroker-Installation ***
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        Hosts:
        PM-iObroker         PM-iObroker (version: 7.0.7, hostname: PM-iObroker   , alive, uptime: 226)
        Core adapters versions
        js-controller:  7.0.7
        admin:          7.7.2
        javascript:     8.9.2
        nodejs modules from github:     1
        +-- iobroker.icons-open-icon-library-png@0.1.3 (git+ssh://git@github.com/ioBroker/ioBroker.icons-open-icon-library-png.git#0847a79d713ee6725ccb6ccfb044c025b73ec946)
        Adapter State
        + system.adapter.admin.0                  : admin                 : PM-iObroker                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          system.adapter.alexa2.0                 : alexa2                : PM-iObroker                              - disabled
        + system.adapter.backitup.0               : backitup              : PM-iObroker                              -  enabled
        + system.adapter.discovery.0              : discovery             : PM-iObroker                              -  enabled
        + system.adapter.hm-rega.0                : hm-rega               : PM-iObroker                              -  enabled
        + system.adapter.hm-rega.1                : hm-rega               : PM-iObroker                              -  enabled
        + system.adapter.hm-rpc.0                 : hm-rpc                : PM-iObroker                              -  enabled, port: 0
        + system.adapter.hm-rpc.1                 : hm-rpc                : PM-iObroker                              -  enabled, port: 0
        + system.adapter.hm-rpc.2                 : hm-rpc                : PM-iObroker                              -  enabled, port: 0
        + system.adapter.hm-rpc.3                 : hm-rpc                : PM-iObroker                              -  enabled, port: 0
        + system.adapter.hm-rpc.4                 : hm-rpc                : PM-iObroker                              -  enabled, port: 0
        + system.adapter.hm-rpc.5                 : hm-rpc                : PM-iObroker                              -  enabled, port: 0
        + system.adapter.hue.0                    : hue                   : PM-iObroker                              -  enabled, port: 443
          system.adapter.ical.0                   : ical                  : PM-iObroker                              -  enabled
          system.adapter.icons-icons8.0           : icons-icons8          : PM-iObroker                              - disabled
          system.adapter.icons-mfd-png.0          : icons-mfd-png         : PM-iObroker                              - disabled
          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : PM-iObroker                              - disabled
          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: PM-iObroker                              - disabled
          system.adapter.influxdb.1               : influxdb              : PM-iObroker                              - disabled, port: 8086
        + system.adapter.info.0                   : info                  : PM-iObroker                              -  enabled
        + system.adapter.iot.0                    : iot                   : PM-iObroker                              -  enabled
        + system.adapter.javascript.0             : javascript            : PM-iObroker                              -  enabled
        + system.adapter.lg-ess-home.0            : lg-ess-home           : PM-iObroker                              -  enabled
          system.adapter.mielecloudservice.0      : mielecloudservice     : PM-iObroker                              -  enabled
        + system.adapter.myenergi.1               : myenergi              : PM-iObroker                              -  enabled
        + system.adapter.myvbus.0                 : myvbus                : PM-iObroker                              -  enabled
        + system.adapter.shelly.0                 : shelly                : PM-iObroker                              -  enabled, port: 1883, bind: 0.0.0.0
        + system.adapter.viessmannapi.0           : viessmannapi          : PM-iObroker                              -  enabled
          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : PM-iObroker                              - disabled
          system.adapter.vis-colorpicker.0        : vis-colorpicker       : PM-iObroker                              - disabled
          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : PM-iObroker                              - disabled
          system.adapter.vis-history.0            : vis-history           : PM-iObroker                              - disabled
          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : PM-iObroker                              - disabled
          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : PM-iObroker                              - disabled
          system.adapter.vis-justgage.0           : vis-justgage          : PM-iObroker                              - disabled
          system.adapter.vis-metro.0              : vis-metro             : PM-iObroker                              - disabled
          system.adapter.vis-plumb.0              : vis-plumb             : PM-iObroker                              - disabled
          system.adapter.vis-rgraph.0             : vis-rgraph            : PM-iObroker                              - disabled
          system.adapter.vis-timeandweather.0     : vis-timeandweather    : PM-iObroker                              - disabled
          system.adapter.vis-weather.0            : vis-weather           : PM-iObroker                              - disabled
          system.adapter.vis.0                    : vis                   : PM-iObroker                              -  enabled
        + system.adapter.web.0                    : web                   : PM-iObroker                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          system.adapter.zehnder-cloud.0          : zehnder-cloud         : PM-iObroker                              - disabled
        + instance is alive
        ioBroker-Repositories
        │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json'        │ true         │
        Active repo(s): stable
        Upgrade policy: none
        Installed ioBroker-Adapters
        Used repository: stable
        Adapter    "admin"        : 7.7.2    , installed 7.7.2
        Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
        Adapter    "backitup"     : 3.3.5    , installed 3.3.5
        Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
        Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
        Adapter    "hue"          : 3.16.2   , installed 3.16.2
        Adapter    "ical"         : 1.17.0   , installed 1.17.0
        Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
        Adapter    "iot"          : 3.3.0    , installed 3.3.0
        Adapter    "javascript"   : 8.9.2    , installed 8.9.2
        Controller "js-controller": 7.0.7    , installed 7.0.7
        Adapter    "lg-ess-home"  : 0.4.1    , installed 0.4.1
        Adapter    "mielecloudservice": 6.5.10, installed 6.5.10
        Adapter    "myenergi"     : 0.0.3    , installed 0.0.3
        Adapter    "myvbus"       : 0.6.0    , installed 0.6.0
        Adapter    "shelly"       : 10.2.0   , installed 10.2.0
        Adapter    "socketio"     : 6.7.1    , installed 6.7.1
        Adapter    "viessmannapi" : 2.3.0    , installed 2.3.0
        Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
        Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
        Adapter    "vis-weather"  : 2.5.12   , installed 2.5.12
        Adapter    "web"          : 7.0.8    , installed 7.0.8
        Adapter    "wireless-settings": 1.0.2, installed 1.0.2
        Adapter    "ws"           : 2.6.2    , installed 2.6.2
        Adapter    "zehnder-cloud": 0.0.7    , installed 0.0.7
        Objects and States
        Objects:        11176
        States:         9748
        Hit:2 http://security.debian.org bookworm-security InRelease
        Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
        Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
        Reading package lists...
        Pending Updates: 0
        *** Listening Ports ***
        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1000       99568770   1672/iobroker.js-co
        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1000       99568765   1672/iobroker.js-co
        tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          99557635   314/master
        tcp        0      0 192.168.1.248:2000      0.0.0.0:*               LISTEN      1000       99568364   1818/io.hm-rpc.1
        tcp        0      0 192.168.1.248:2001      0.0.0.0:*               LISTEN      1000       99569238   1803/io.hm-rpc.0
        tcp        0      0 192.168.1.248:2002      0.0.0.0:*               LISTEN      1000       99569420   1848/io.hm-rpc.3
        tcp        0      0 192.168.1.248:2003      0.0.0.0:*               LISTEN      1000       99569479   1863/io.hm-rpc.4
        tcp        0      0 192.168.1.248:2010      0.0.0.0:*               LISTEN      1000       99569379   1833/io.hm-rpc.2
        tcp        0      0 192.168.1.248:2011      0.0.0.0:*               LISTEN      1000       99568484   1878/io.hm-rpc.5
        tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1000       99570725   1953/io.shelly.0
        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          99530558   1/init
        tcp6       0      0 ::1:25                  :::*                    LISTEN      0          99557636   314/master
        tcp6       0      0 :::8082                 :::*                    LISTEN      1000       99572886   2836/io.web.0
        tcp6       0      0 :::8081                 :::*                    LISTEN      1000       99568850   1690/io.admin.0
        tcp6       0      0 :::22                   :::*                    LISTEN      0          99540970   1/init
        tcp6       0      0 :::111                  :::*                    LISTEN      0          99530560   1/init
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          99557450   95/dhclient
        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          99530559   1/init
        udp6       0      0 :::111                  :::*                                0          99530561   1/init
        2025-10-26 01:31:18.694  - info: vis.0 (2659) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.vis, node: v20.19.5, js-controller: 7.0.7
        2025-10-26 01:31:19.401  - info: vis.0 (2659) Terminated (NO_ERROR): Without reason
        2025-10-26 01:31:19.929  - info: host.PM-iObroker instance system.adapter.vis.0 terminated while should be started once
        2025-10-26 01:31:22.120  - info: host.PM-iObroker instance system.adapter.web.0 in version "7.0.8" started with pid 2836
        2025-10-26 01:31:22.740  - info: web.0 (2836) starting. Version 7.0.8 in /opt/iobroker/node_modules/iobroker.web, node: v20.19.5, js-controller: 7.0.7
        2025-10-26 01:31:22.815  - info: web.0 (2836) http server listening on port 8082
        2025-10-26 01:31:22.856  - info: web.0 (2836) socket.io server listening on port 8082
        2025-10-26 01:31:26.149  - info: host.PM-iObroker instance system.adapter.myenergi.1 in version "0.0.3" started with pid 2905
        2025-10-26 01:31:26.719  - info: myenergi.1 (2905) starting. Version 0.0.3 in /opt/iobroker/node_modules/iobroker.myenergi, node: v20.19.5, js-controller: 7.0.7
        2025-10-26 01:31:27.036  - info: myenergi.1 (2905) Found device: eddi - 0
        2025-10-26 01:31:27.036  - info: myenergi.1 (2905) Found device: harvi - 0
        2025-10-26 01:31:27.036  - info: myenergi.1 (2905) Found device: libbi - 0
        2025-10-26 01:31:27.036  - info: myenergi.1 (2905) Found device: zappi - 1
        2025-10-26 01:31:27.079  - info: myenergi.1 (2905) skipping asn
        2025-10-26 01:31:32.985  - info: shelly.0 (1953) [MQTT] Device with client id "shellyplugsg3-543204663b80" connected from 192.168.1.134!
        2025-10-26 01:31:34.303  - info: shelly.0 (1953) [MQTT] Device with client id "shellyplug-s-6E9299" connected from 192.168.1.130!
        2025-10-26 01:31:34.453  - info: shelly.0 (1953) [MQTT] Device with client id "shellyplugsg3-5432046797c4" connected from 192.168.1.132!
        2025-10-26 01:31:35.364  - info: shelly.0 (1953) [MQTT] Device with client id "shellyplusplugs-d4d4daeb85e0" connected from 192.168.1.136!
        2025-10-26 01:31:35.575  - info: shelly.0 (1953) [MQTT] Device with client id "shellyplugsg3-84fce63656c4" connected from 192.168.1.131!
        2025-10-26 01:31:36.295  - info: shelly.0 (1953) [MQTT] Device with client id "shellypro3em-34987a449758" connected from 192.168.1.251!
        2025-10-26 01:31:36.598  - info: shelly.0 (1953) [MQTT] Device with client id "shellyplugsg3-54320465e730" connected from 192.168.1.133!
        2025-10-26 01:31:37.572  - info: shelly.0 (1953) [MQTT] Device with client id "shellyplug-s-0DA223" connected from 192.168.1.135!
        2025-10-26 01:31:37.776  - info: shelly.0 (1953) [MQTT] Device with client id "shellyplusplugs-d4d4daeb55bc" connected from 192.168.1.119!
        2025-10-26 01:31:45.052  - info: shelly.0 (1953) [MQTT] Device with client id "shellyplusplugs-d4d4daedbbb8" connected from 192.168.1.238!
        2025-10-26 01:31:48.190  - info: shelly.0 (1953) [MQTT] Device with client id "shellyplugsg3-543204664428" connected from 192.168.1.139!
        • haselchen
          haselchen Most Active @heldchen last edited by haselchen
          @heldchen
          Rein interessehalber, wozu brauchst Du 2 HM-Rega und 6 HM-RPC Instanzen?
          Edit:
          Nebenschauplatz: Node auf Stand bringen. Und eventuell kurz das Repo auf Beta stellen, die V3.0.1 vom HM-RPC installieren und wieder zurück auf Stable schalten.
          Dann wäre man soweit erstmal aktuell.
            @haselchen Habe 2 Homematiczentralen, 2 Wohnungen getrennt. Da jeweils Wired, ip-wired und normale sowie ip Komponenten.
              Homoran Global Moderator Administrators @heldchen last edited by
              @heldchen hab kein ipw, aber braucht das auch ne eigene Instanz?
              ich hab alleine 3 Instanzen bei hm, hmip und hmw
                heldchen @Homoran last edited by heldchen
                @homoran Jeweils eine für rfd, 485(also HMW) und HMIP. Das ganze mal 2 bei mir. HMIPW braucht wohl keine eigene.
                  @haselchen Updates haben im Übrigen nichts verbessert in der Richtung
                  • haselchen
                    @heldchen
                    Naja, gibt jetzt x Möglichkeiten.
                    CCU neu starten .
                    Einstellungen von den besagten Instanzen posten (HM Rega /HM RPC)
                    Firewall Einstellungen der CCU.
                    • vowill
                      vowill @heldchen last edited by vowill
                      @heldchen Von Zeit zu Zeit (und zufällig auch gestern) habe ich dieses Problem auch. Was dann hilft ist ein Aufruf der Instanz hm-rpc.x in der ioBroker-Oberfläche, Klick auf den Schraubenschlüssel und dann das Häkchen setzen bei "Geräte neu einlesen (einmalig)".
                      Leider habe ich noch keine Option gefunden, dieses einmalige Neu-Einlesen über ein Skript zu starten ...
                        heldchen @vowill last edited by heldchen
                        @vowill Danke für den Hinweis, das werde ich nachher direkt mal versuchen! Ich hoffe das Ganze hat dann keine Effekte für die eingebundenen Datenpunkte in VIS und Skripten?
                        vowill 1 Reply Last reply Reply Quote 0
                        • vowill
                          @heldchen Nein, das ist tatsächlich nur eine erneute Synchronisation (und kann beliebig oft wiederholt werden).
                            @vowill Hat leider alles nix gebracht. Habe eine neue RPC Instanz angelegt, nun scheint es erstmal zu funktionieren.
                              @heldchen das sieht dann aber nach Fehlkonfiguration aus.
                              @haselchen sagte in Homematic RPC liefert keine Statusänderungen:
                              hast du leider nicht gemacht
                                RPC habe ich 1:1 so eingestellt wie den alten, und in Rega nur 485 von RPC4 auf RPC6 geändert und gespeichert.
                                • black.falcon87
                                  black.falcon87 last edited by
                                  Hast du in den Einstellungen der Instanz etwas bei Callback Adresse eingetragen? Ich glaube da muss bei Verwendung von Containern bzw. Docker die Adresse vom ioBroker Host rein.
                                  https://github.com/ioBroker/ioBroker.hm-rpc?tab=readme-ov-file#adapter-callback-address
                                    heldchen @black.falcon87 last edited by
                                    alles genau wie beim alten RPC
                                      @heldchen das steht im zweiten Reiter
                                          @heldchen da muss die IP des hosts eingetragen werden, sonst hast du das Problem bald wieder
                                            @homoran Ahh ok. Warum kommt das dann erst nach einer Zeit??
                                            375
