    3. Off Topic
    4. Microcontroller
    5. Bereitstellung der JSON-Daten für den Wiffi-WZ Adapter
      wenn ich mir deine Meldung ansehe
      @ufelet sagte in Bereitstellung der JSON-Daten für den Wiffi-WZ Adapter:
      Datagram error, could not find an ip!
      und die Struktur
      {"modultyp":"DHT_Sensor","vars":
      {"name":"0"
      ,"homematic_name":"DHT-Sensor-IP",
      "desc":"ip des DHT-Sensor",
      "type":"string",
      "unit":"","
      value":"192.168.200.40"},"
      Systeminfo":{"MAC-Adresse":"18:FE:34:CF:82:FA","Homematic_CCU_ip":"192.168.200.122","WLAN_ssid":"Platin","WLAN_Signal_dBm":"-57","sec_seit_reset":"2367","firmware":"WeMos_DHT_Sensor_20251024"}}
      passt das irgendwie nicht zu dem Format vom Wiffi
      {"modultyp":"wiffi-wz","vars":[{"name":"0","homematic_name":"wz_ip","desc":"ip des wiffi-wz","type":"string","unit":"","value":"192.168.123.45"},{"name":"1","homematic_name":"wz_co2","desc":"Luftqualitaet","type":"number","unit":"%","value":76},{"name":"2","homematic_name":"wz_temp","desc":"Temperatur","type":"number","unit":"gradC","value":20.0},{"name":"3","homematic_name":"wz_feuchte","desc":"Luftfeuchte","type":"number","unit":"%","value":67.2},{"name":"19","homematic_name":"wz_taupunkt","desc":"Taupunkt","type":"number","unit":"gradC","value":13.7},{"name":"18","homematic_name":"wz_feuchte_abs","desc":"Absolutfeuchte","type":"number","unit":"g/m3","value":11.6},{"name":"9","homematic_name":"wz_baro","desc":"Luftdruck","type":"number","unit":"mB","value":1002.23},{"name":"5","homematic_name":"wz_luftdrucktrend","desc":"Luftdrucktrend","type":"string","unit":"","value":"fallend"},{"name":"8","homematic_name":"wz_lux","desc":"Helligkeit","type":"number","unit":"lux","value":0.00},{"name":"6","homematic_name":"wz_motion_left","desc":"Bewegung links","type":"boolean","unit":"","value":true},{"name":"7","homematic_name":"wz_motion_right","desc":"Bewegung rechts","type":"boolean","unit":"","value":false},{"name":"20","homematic_name":"","desc":"Bewegung","type":"boolean","unit":"","value":false},{"name":"4","homematic_name":"wz_noise","desc":"Geraeusch","type":"boolean","unit":"","value":true},{"name":"10","homematic_name":"wz_elevation","desc":"Sonne-Elevation","type":"number","unit":"grad","value":-20.5},{"name":"11","homematic_name":"wz_azimut","desc":"Sonne-Azimut","type":"number","unit":"grad","value":273.9},{"name":"12","homematic_name":"wz_buzzer","desc":"Buzzer","type":"boolean","unit":"","value":false},{"name":"21","homematic_name":"","desc":"Relais","type":"boolean","unit":"","value":false}],"Systeminfo":{"MAC-Adresse":"aa.bb.cc.dd.ee.ff","ip_Homematic_CCU":"192.168.123.56","WLAN_ssid":"WLAN","WLAN_Signal_dBm":-57,"millis_seit_reset":46252671,"wiffizeit":" 1 19:21","firmware":"wiffi_wz_106"}}
      Da fehlen bei dir die Eckigen Klammern
      Möglich, dass deine Struktur dem Adapter nicht die IP des Sensors mitteilt, damit der Adapter die Konfiguration des Sensirs übernehmen kann
      https://github.com/t4qjXH8N/ioBroker.wiffi-wz?tab=readme-ov-file#setup
      • U
        ufelet @Homoran last edited by
        Vielen Dank.
        Diese Möglichkeit hatte ich noch gar nicht auf dem Schirm. Das werde ich erst mal verfolgen, genauso wie die fehlenden eckigen Klammern.
        Viele Grüße Bernd
        • mcm1957
          mcm1957 last edited by
          An alle hier Beteiligten:
          Der Adapter https://github.com/t4qjXH8N/ioBroker.wiffi-wz ist wie schon geschrieben steinalt und nicht mehr gewartet. Auf eine entsprechende Nachfrage Ende 2024 hat der bisherige Maintainer keinerlei Reaktion gezeigt:
          https://github.com/t4qjXH8N/ioBroker.wiffi-wz/issues/186
          Der Adapter wird daher entweder (zumindest) aus dem STABLE Repository fliegen oder ich versuche ihn in den iobroker-community-organisation Bereich zu verschieben.
          Bevor och da aber Arbeit reinstecke hätte ich gerne Rückmeldungen:
          • gibts dafür Interesse (Bei dir @ufelet geh ich mal davon aus 🙂 ) ?
          • gibts User die bereit wären einen migrierte Version kurz auf ihre Funktion zu testen ? Mangels entsprechender Hardware kann ich da absolut nichts tun...
          • kann jemand bestätigen dass es die zum Adapetr gehörige Hatrdware nwirklich noch gibt (wenshop sieht alive aus)?
          mcm1957 created this issue in t4qjXH8N/ioBroker.wiffi-wz
          open Is this adapter still maintained? - PLEASE RESPOND UNTIL 15.11.2024 LATEST #186
          Homoran U 2 Replies Last reply Reply Quote 0
            Homoran Global Moderator Administrators @mcm1957 last edited by Homoran
            @mcm1957 sagte in Bereitstellung der JSON-Daten für den Wiffi-WZ Adapter:
            hab zwar keider seit Corona den Kontakt zu Eugen verloren/vernachlässigt 😢 aber wie du schreibst ist der Shop noch aktiv
            https://www.stall.biz/shop/
            Abgesehen davon sind etliche Geräte im Feld, der Adapter ist 280x installiert, was zwar absolut nicht viel ist, aber...
            • U
              ufelet @mcm1957 last edited by
              @mcm1957
              Also ich habe im Moment Wiffi-Pump, Wiffi-Counter und RainyMan von stall.biz in Betrieb. Alle Geräte werden problemlos erkannt und ihre Daten erscheinen auch im ioBroker. Und ja, ich bin nach wie vor noch am Adapter aus obigen Gründen interessiert.
              Die Sensoren vertreibt Eugen auch noch in immer neueren Versionen.
              Ich glaube einfach nicht, dass ich der Einzige bin, der die Sensoren von Eugen im ioBroker nutzt. Mit meiner Anfrage wollte ich User finden, die schon Sensoren geschrieben haben, die diesen Adapter nutzen. Eugen kann doch nicht der Einzige sein.
              Eine derartige Welle wollte ich mit meiner Anfrage überhaupt nicht auslösen.
              Ich wollte nur meine selbst geschriebenen Sensoren in den ioBroker bringen. Der Adapter schien mir am geeignetsten, weil er ein einfaches JSON Protokoll nutzt. (woran ich immer noch scheitere)
              Ich habe gestern auch Dr. Stall (Eugen - vy73) geschrieben, habe aber noch niemals von ihm eine Antwort erhalten.
              Bitte noch mindestens eine Woche vor irgendwelchen Aktivitäten warten. Danke
              ufelet Bernd
                Linedancer last edited by
                Hallo Gemeinde,
                Ich habe den Adapter seit ewigen Zeiten mit dem Weatherman am laufen. Der macht völlig problemlos und unauffällig seinen Dienst.
                Natürlich sollte der Adapter weiter im Stable bleiben. Wenn es eine Community Edition geben sollte, bin ich gerne zum Testen bereit, auch wenn ich z.Zt. Keine wirkliche Testumgebung habe.
                • mcm1957
                  mcm1957 @Linedancer last edited by
                  @linedancer
                  Danke f.d. Info.
                  Der Adapter benötigt nur einige Anpassungen da er z.B. noch deprecated Funktionen verwendet die mit dem nächsten major Release entfernt werden. Wenn Interesse existiert (und so sieht es aus) werde ich eine Migration einplanen. Das wird KEIN neuer Adapter und es wird auch auch keine Änderungen an den States geben. Es würde / wird nur das Repository verlegt damit ein Wartungszugriff möglich wird.
                    Homoran Global Moderator Administrators @ufelet last edited by
                    @ufelet erst einmal zur Klarstellung:
                    Was du da machst geht an der Aufgabe des Adapters vorbei!
                    Wenn's klappt ist gut, wenn nicht würde ich sagen: ist so!
                    Da wir aber alle kleine Bastler sind, finde ich das Projekt interessant.
                    Deswegen habe ich dir gestern den Link zum Adapter Readme auf github geschickt.
                    Deine Sensoren erfüllen demnach nicht die Voraussetzungen um mit dem Adapter funktionieren zu können.
                    doch! Der Adapter ist ja für seine Geräte geschrieben worden!
                    Ansonsten:
                    wer, wo ist das denn?
                    Eugen läuft unter @funkleuchtturm, war hier allerdings zuletzt 2018 unterwegs.
                    im Homematic Forum dürftest du eher Glück haben
                    F U 2 Replies Last reply Reply Quote 0
                      funkleuchtturm @Homoran last edited by
                      Hallo, der wiffi wz adapter kann nicht nur für den alten wiffi wz sondern auch für die aktuellen Module verwendet werden.
                      Ich bekomme oft Anfragen, wie eine Integration insbesondere meiner Wetterstation (Weatherman 2) unter IObroker gemacht werden kann und dann verweise ich gerne auf dieses Forum.
                      Der aktuelle Weatherman kann auch Mqtt insbesondere für Homeassistant und wäre damit sicher auch über diesen alternativen Weg in Iobroker einzubinden.
                      Würde mich freuen, wenn ihr den wiffi wz Adapter nicht herausnehmt.
                      • U
                        Ich wusste nicht, dass Dr. Stall auch hier unter funkleuchtturm angemeldet ist. Ihn mit Vornamen anzusprechen ist zwar unter Funkamateuren so üblich, deshalb eine gebräuchliche Abkürzung unter Funkamateuren für viel Grüße, im Forum steht mir allerdings das Recht nicht zu ihn zu duzen.
                        Die Readme hat nur noch meine Annahme bestätigt, dass die Sensoren ihre Daten an den Adapter senden und nicht vom Adapter abgefragt werden. Zum Protokoll ist nichts gesagt.
                        Inzwischen bin ich der Überzeugung, dass ich hier ganz bestimmt keine Antwort auf meine Frage erhalten werde.
                          Homoran Global Moderator Administrators @funkleuchtturm last edited by
                          @funkleuchtturm Hallo Eugen!
                          schön von dir hier zu hören.
                          Hoffentlich geht's dir gut.
                          @funkleuchtturm sagte in Bereitstellung der JSON-Daten für den Wiffi-WZ Adapter:
                          ich hoffe, der bleibt!
                          ich nutze ihn ja auch.
                          Aber hier ist gerade die umgekehrte Herausforderung!
                          @ufelet hat selbstgebastelte Sensoren, die er dem Adapter als WIFFIs verkaufen will.
                          Da bräuchte er Infos wie die notwendige Datenstruktur auf Sensorseite se7n muss.
                            Homoran Global Moderator Administrators @ufelet last edited by Homoran
                            ja, deswegen hab ich es dir ja verlinkt!
                            mit ausführlicher Erklärung
                            @homoran sagte in Bereitstellung der JSON-Daten für den Wiffi-WZ Adapter:
                            So!
                            habe mich nach Jahren nochmal eingearbeitet.
                            Anscheinend kann der Adapter auch an iobroker pushen.
                            Das hatte ich nie genutzt, weil mein wiffi an die CCU gepusht hat, und ich von iob gepullt habe.
                            pushen an 2 clients geht nicht!
                            Die Pull option hat Eugen damals für ioBroker "nachgerüstet"
                            bevor es den Adapter gab, gab es das folgende Skript
                            //var request = require("request");
                            var pfad    = "WIFFI" + ".";
                            var url     = 'http://192.168.123.45/?json:';
                            // TODO:
                            function timeLastData() {
                               return formatDate(new Date(), "DD.MM, hh:mm:ss");
                            function parseJson(text) {
                               if (text === "") return {};
                               try {
                                   json = JSON.parse(text);
                               } catch (ex) {
                                   json = {};
                               if(!json) json = {};
                               return json;
                            function readJson(url, callback) {
                               httpGet(url, function (err, response, state){
                                   if (response.data) {
                                       var json = parseJson(response.data);
                                       callback(null, json);
                                   } else {
                                       var error = "(" + err + ") ERROR bei Abfrage 33 von: " + url;
                                       log(error, "warn");
                                       callback(error, null);
                            function readVars() {
                               readJson(url, function(err,json) {
                                   if(!err) {
                                       var myJson = json;
                                       var dPname, init;
                                       var anzahlVars = myJson.vars.length;
                                       for (var i = 1; i < anzahlVars; i++) {
                                           if(myJson.vars[i].homematic_name) {
                                          dPname = pfad + myJson.vars[i].homematic_name;
                                          init = myJson.vars[i].value;
                                          setState(dPname, init,true);
                                       for (var systeminfo in myJson.Systeminfo) {
                                           dPname = pfad + "Systeminfo." + systeminfo;
                                           init = myJson.Systeminfo[systeminfo];
                                           setState(dPname, init ,true);
                                       setState(pfad + "LetzteAbfrage",timeLastData(),true);
                                       var statusNe = getState(pfad + "Last_State_Count").val;
                                       if (statusNe < 0) {
                                           setState(pfad + "Last_State_Count",0,true);
                                       } else {
                                           setState(pfad + "Last_State_Count",statusNe + 1,true);
                                       log("WIFFI Daten aktualisiert: " + url,"debug");
                                   } else {
                                       log("Fehler beim Auslesen des JSON 69. Keine Daten erhalten.","warn");
                                       if (statusNe > 0) {
                                       } else {
                                           setState(pfad + "Last_State_Count",statusNe - 1,true);
                            function createDpFromJson(myJson) {
                               var dPname = "";
                               var name = "";
                               var forceCreation = false;
                               var common;
                               var init;
                               var type, desc, unit;
                                   type = myJson.vars[i].type;
                                   desc = myJson.vars[i].desc;
                                   name = desc;
                                   unit = myJson.vars[i].unit.replace('grad','°');
                                   common = '{"desc":"' + desc + '","type":"' + type + '","unit":"' + unit + '","role":"value"' +',"name":"' + name + '"}';
                                   common = JSON.parse(common);
                                   //createState(dPname, init , forceCreation, common);
                                   if(myJson.vars[i].homematic_name) createState(dPname, init , forceCreation, common);
                                   //createState(dPname, init);
                                   log("neuer Datenpunkt: " + dPname + ": " + init +", common: " + common,"info");
                                   common = '{"name":"'+systeminfo+'","desc":"'+systeminfo+'","role":"value"}';
                               createState(pfad + "System.Modultyp",myJson.modultyp);
                               createState(pfad + "System.url",url.replace("json:","xpert:0:"));
                               createState(pfad + "Last_State_Count",0,true);
                               createState(pfad + "LetzteAbfrage"  ,timeLastData());
                               createState(pfad + "Skriptstart"    ,timeLastData()),true;
                               createState(pfad + "Control_GetData",false,true,        {"name":"Daten mit true manuell abrufen","type":"boolean","role":"value"});
                            function createDp() {
                               readJson(url, function (err,json) {
                                   if(!err) {
                                       var myJson = json;
                                       createDpFromJson(myJson);
                                       log("WIFFI Datenpunkte angelegt/aktualisiert");
                                   } else {
                                       log("Fehler beim Auslesen des JSON. Keine Daten erhalten.","error");
                                       log("Keine Datenpunkte angelegt. Skript beendet","error");
                                       return;
                            function createOn() {
                               var dpId = "javascript." + instance + "." + pfad + "Control_GetData";
                               on({id: dpId ,change:'any'}, function (obj) {
                                   log(obj.state.val,"warn");
                                   if(obj.state.val) {
                                       readVars();
                               schedule("*/4 * * * *", function () { // alle 4 Minute die Werte abfragen
                                   readVars();
                            function main() {
                               readVars();
                            // Skriptstart
                            createDp();
                            setTimeout(createOn,    3000);
                            setTimeout(main,        3000);
                            Was Eugen in seinen Wiffis zum pushen programmiert hat weiß ich nicht.
                            Der Header war anscheinend nur für die CCU notwendig. Zu ioBroker wird IMHO nur das JSON geschickt
                            wieso nicht?
                            wende dich doch vertrauensvoll an deinen Vorposter
                            • mcm1957
                              @funkleuchtturm said in Bereitstellung der JSON-Daten für den Wiffi-WZ Adapter:
                              Danke für dein Feedback.
                              Um im Fehlerfall besser eingreifen zu können bzw. den Code besser zu verstehen eine Frage:
                              Ist das Format der gesendeten JSON Blöcke irgendwo dokumentiert? Es kann natürlich aus dem Adaptercode rekonstruiert werden - weniger Aufwand wär's allerdings wenn es eine (auch nur minimalistische) Doku dazu gäbe. Auch wäre es mit Doku leichter möglich für Testzwecke simulierte Blöcke zu senden.
                              Und da der Adapter offensichtlich benutzt wird wird er zu 99% nicht enfernt sondern nur soweit Zeit vorhanden und zwingender Bedarf gegeben ist aktualisisert werden.
                              • bahnuhr
                                @mcm1957
                                Ist die Doku auf git nicht ausreichend ?
                                und darin verlinkt:
                                https://www.stall.biz/project/der-wiffi-wz-2-0-der-wohnzimmersensor/
                                Da steht schon vieles drin.
                                • mcm1957
                                  @bahnuhr said in Bereitstellung der JSON-Daten für den Wiffi-WZ Adapter:
                                  @mcm1957
                                  und darin verlinkt:
                                  Ich habe da aufs erste mal keine Dokumentation der JSON Datenpakete gefunden. Wenn du sie wo gesehen hast, bitte sag mir wo.
                                  • bahnuhr
                                    bahnuhr Forum Testing Most Active @mcm1957 last edited by
                                    @mcm1957
                                    Habe den Wiffi schon lange nicht mehr.
                                    Für mich waren die Punkte damals klar.
                                    • mcm1957
                                      mcm1957 @bahnuhr last edited by
                                      @bahnuhr
                                      Es geht mir NICHT um die States die der Adapter anlegt. Da der Adapter nicht mehr gewartet ist plane ich ihn in den iobroker-community Bereich zu übernehmen. Um den Adapetr längerfristig warten zu können ist es allerdings notwendig zu verstehen wie die Daten "auf der Leitung" übermittelt werden - sprich wie die Datenpakate / json Pakete aussehen.
                                      Auch zum Testen des Adapters ist es notwendig simulierte Pakate senden zu können - und dazu muss deren Format un Inhalt bekannt sein.
                                      Das ist das Ziel meiner Frage nach einer Doku.
                                        also im Prinzip
                                        { "modultyp":"Gerätebezeichnung",
                                        "vars":[array mit Sensoren und Werten],
                                        "Systeminfo":{systemspez. Informationen}}
                                        • mcm1957
                                          mcm1957 @Homoran last edited by
                                          Danke - hab das mal als example in einem Issue beim Adapter abgelegt - damit sollte es wiederfindbar sein,
                                          X 1 Reply Last reply Reply Quote 1
                                          • X
                                            x4tlaoguo @mcm1957 last edited by
                                            Hallo in die Runde, Maintainer vom Wiffi Adapter hier. Sorry, hatte aus familiären Gründen keine Zeit den Adapter zu pflegen. Habe mir in den letzten Tagen die offenen Issues und die Fragen dazu angeschaut. Werde den Adapter am Wochende auf den neuesten Stand bringen.
                                            Hoffe er funktioniert dann wieder einwandfrei.
                                            mcm1957 1 Reply Last reply Reply Quote 2
                                            81.1k
                                            356
