    4. Iobroker nach Update nicht erreichbar
      Jan201 last edited by
      Gestern habe ich meinen NUC dann mal kurz vom Strom genommen, wieder neu gestartet und Iobroker hat wieder funktioniert. Heute nachmittag das selbe, wollte wieder drauf zu greifen, keine verbindung. weder zu 8081 noch zu 8082.
      Im Anhang mal die LOG-Datei
      2025-10-26 11:30:13.475 - info: dwd.0 (20939) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 11:30:14.174 - info: dwd.0 (20939) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-10-26 11:30:14.703 - info: host.iobroker instance system.adapter.dwd.0 having pid 20939 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-10-26 11:30:34.049 - info: host.iobroker instance system.adapter.tvspielfilm.0 in version "2.1.0" started with pid 20958
      2025-10-26 11:30:36.514 - info: tvspielfilm.0 (20958) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 11:30:38.083 - info: host.iobroker instance system.adapter.daswetter.0 in version "3.2.6" started with pid 20973
      2025-10-26 11:30:38.598 - info: tvspielfilm.0 (20958) objects written
      2025-10-26 11:30:40.555 - info: daswetter.0 (20973) starting. Version 3.2.6 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 11:30:49.106 - info: tvspielfilm.0 (20958) Terminated (NO_ERROR): Without reason
      2025-10-26 11:30:49.646 - info: host.iobroker instance system.adapter.tvspielfilm.0 having pid 20958 terminated with code 0 (NO_ERROR)
      2025-10-26 11:30:58.535 - info: daswetter.0 (20973) still wrong data structure from server received! repaired...
      2025-10-26 11:31:03.798 - info: daswetter.0 (20973) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
      2025-10-26 11:31:04.313 - info: daswetter.0 (20973) cleaned everything up...
      2025-10-26 11:31:04.330 - info: host.iobroker instance system.adapter.daswetter.0 having pid 20973 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-10-26 11:35:11.041 - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 21024
      2025-10-26 11:35:13.643 - info: dwd.0 (21024) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 11:35:14.369 - info: dwd.0 (21024) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-10-26 11:35:14.900 - info: host.iobroker instance system.adapter.dwd.0 having pid 21024 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-10-26 11:35:34.044 - info: host.iobroker instance system.adapter.tvspielfilm.0 in version "2.1.0" started with pid 21043
      2025-10-26 11:35:36.545 - info: tvspielfilm.0 (21043) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 11:35:38.614 - info: tvspielfilm.0 (21043) objects written
      2025-10-26 11:35:49.130 - info: tvspielfilm.0 (21043) Terminated (NO_ERROR): Without reason
      2025-10-26 11:35:49.659 - info: host.iobroker instance system.adapter.tvspielfilm.0 having pid 21043 terminated with code 0 (NO_ERROR)
      2025-10-26 11:40:11.041 - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 21094
      2025-10-26 11:40:13.496 - info: dwd.0 (21094) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 11:40:14.228 - info: dwd.0 (21094) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-10-26 11:40:14.758 - info: host.iobroker instance system.adapter.dwd.0 having pid 21094 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-10-26 11:40:34.043 - info: host.iobroker instance system.adapter.tvspielfilm.0 in version "2.1.0" started with pid 21113
      2025-10-26 11:40:36.516 - info: tvspielfilm.0 (21113) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 11:40:38.593 - info: tvspielfilm.0 (21113) objects written
      2025-10-26 11:40:49.101 - info: tvspielfilm.0 (21113) Terminated (NO_ERROR): Without reason
      2025-10-26 11:40:49.629 - info: host.iobroker instance system.adapter.tvspielfilm.0 having pid 21113 terminated with code 0 (NO_ERROR)
      2025-10-26 11:45:11.039 - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 21164
      2025-10-26 11:45:13.464 - info: dwd.0 (21164) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 11:45:14.178 - info: dwd.0 (21164) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-10-26 11:45:14.706 - info: host.iobroker instance system.adapter.dwd.0 having pid 21164 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-10-26 11:45:34.046 - info: host.iobroker instance system.adapter.tvspielfilm.0 in version "2.1.0" started with pid 21183
      2025-10-26 11:45:36.511 - info: tvspielfilm.0 (21183) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 11:45:38.077 - info: host.iobroker instance system.adapter.daswetter.0 in version "3.2.6" started with pid 21198
      2025-10-26 11:45:38.596 - info: tvspielfilm.0 (21183) objects written
      2025-10-26 11:45:40.583 - info: daswetter.0 (21198) starting. Version 3.2.6 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 11:45:49.108 - info: tvspielfilm.0 (21183) Terminated (NO_ERROR): Without reason
      2025-10-26 11:45:49.640 - info: host.iobroker instance system.adapter.tvspielfilm.0 having pid 21183 terminated with code 0 (NO_ERROR)
      2025-10-26 11:45:58.459 - info: daswetter.0 (21198) still wrong data structure from server received! repaired...
      2025-10-26 11:46:03.665 - info: daswetter.0 (21198) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
      2025-10-26 11:46:04.179 - info: daswetter.0 (21198) cleaned everything up...
      2025-10-26 11:46:04.193 - info: host.iobroker instance system.adapter.daswetter.0 having pid 21198 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-10-26 11:50:11.040 - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 21249
      2025-10-26 11:50:13.470 - info: dwd.0 (21249) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 11:50:14.197 - info: dwd.0 (21249) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-10-26 11:50:14.726 - info: host.iobroker instance system.adapter.dwd.0 having pid 21249 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-10-26 11:50:34.038 - info: host.iobroker instance system.adapter.tvspielfilm.0 in version "2.1.0" started with pid 21268
      2025-10-26 11:50:36.523 - info: tvspielfilm.0 (21268) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 11:50:38.594 - info: tvspielfilm.0 (21268) objects written
      2025-10-26 11:50:49.100 - info: tvspielfilm.0 (21268) Terminated (NO_ERROR): Without reason
      2025-10-26 11:50:49.630 - info: host.iobroker instance system.adapter.tvspielfilm.0 having pid 21268 terminated with code 0 (NO_ERROR)
      2025-10-26 11:55:11.039 - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 21319
      2025-10-26 11:55:13.446 - info: dwd.0 (21319) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 11:55:14.150 - info: dwd.0 (21319) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-10-26 11:55:14.680 - info: host.iobroker instance system.adapter.dwd.0 having pid 21319 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-10-26 11:55:34.042 - info: host.iobroker instance system.adapter.tvspielfilm.0 in version "2.1.0" started with pid 21339
      2025-10-26 11:55:36.535 - info: tvspielfilm.0 (21339) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 11:55:38.607 - info: tvspielfilm.0 (21339) objects written
      2025-10-26 11:55:49.115 - info: tvspielfilm.0 (21339) Terminated (NO_ERROR): Without reason
      2025-10-26 11:55:49.643 - info: host.iobroker instance system.adapter.tvspielfilm.0 having pid 21339 terminated with code 0 (NO_ERROR)
      2025-10-26 12:00:11.042 - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 21390
      2025-10-26 12:00:13.510 - info: dwd.0 (21390) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 12:00:14.211 - info: dwd.0 (21390) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-10-26 12:00:14.744 - info: host.iobroker instance system.adapter.dwd.0 having pid 21390 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-10-26 12:00:34.045 - info: host.iobroker instance system.adapter.tvspielfilm.0 in version "2.1.0" started with pid 21409
      2025-10-26 12:00:36.525 - info: tvspielfilm.0 (21409) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 12:00:38.078 - info: host.iobroker instance system.adapter.daswetter.0 in version "3.2.6" started with pid 21424
      2025-10-26 12:00:38.611 - info: tvspielfilm.0 (21409) objects written
      2025-10-26 12:00:40.555 - info: daswetter.0 (21424) starting. Version 3.2.6 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 12:00:49.119 - info: tvspielfilm.0 (21409) Terminated (NO_ERROR): Without reason
      2025-10-26 12:00:49.653 - info: host.iobroker instance system.adapter.tvspielfilm.0 having pid 21409 terminated with code 0 (NO_ERROR)
      2025-10-26 12:00:58.650 - info: daswetter.0 (21424) still wrong data structure from server received! repaired...
      2025-10-26 12:01:03.822 - info: daswetter.0 (21424) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
      2025-10-26 12:01:04.336 - info: daswetter.0 (21424) cleaned everything up...
      2025-10-26 12:01:04.352 - info: host.iobroker instance system.adapter.daswetter.0 having pid 21424 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-10-26 12:04:43.104 - info: web.0 (806) <== Disconnect system.user.admin from ::ffff:192.168.178.199
      2025-10-26 12:04:44.695 - info: web.0 (806) ==> Connected system.user.admin from ::ffff:192.168.178.199
      2025-10-26 12:05:11.041 - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 21475
      2025-10-26 12:05:13.472 - info: dwd.0 (21475) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 12:05:14.192 - info: dwd.0 (21475) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-10-26 12:05:14.721 - info: host.iobroker instance system.adapter.dwd.0 having pid 21475 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-10-26 12:05:34.040 - info: host.iobroker instance system.adapter.tvspielfilm.0 in version "2.1.0" started with pid 21494
      2025-10-26 12:05:36.538 - info: tvspielfilm.0 (21494) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 12:05:38.609 - info: tvspielfilm.0 (21494) objects written
      2025-10-26 12:05:49.117 - info: tvspielfilm.0 (21494) Terminated (NO_ERROR): Without reason
      2025-10-26 12:05:49.654 - info: host.iobroker instance system.adapter.tvspielfilm.0 having pid 21494 terminated with code 0 (NO_ERROR)
      2025-10-26 12:10:11.044 - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 21545
      2025-10-26 12:10:13.644 - info: dwd.0 (21545) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 12:10:14.366 - info: dwd.0 (21545) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-10-26 12:10:14.899 - info: host.iobroker instance system.adapter.dwd.0 having pid 21545 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-10-26 12:10:34.043 - info: host.iobroker instance system.adapter.tvspielfilm.0 in version "2.1.0" started with pid 21564
      2025-10-26 12:10:36.549 - info: tvspielfilm.0 (21564) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 12:10:38.619 - info: tvspielfilm.0 (21564) objects written
      2025-10-26 12:10:49.127 - info: tvspielfilm.0 (21564) Terminated (NO_ERROR): Without reason
      2025-10-26 12:10:49.654 - info: host.iobroker instance system.adapter.tvspielfilm.0 having pid 21564 terminated with code 0 (NO_ERROR)
      2025-10-26 12:15:11.045 - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 21615
      2025-10-26 12:15:13.521 - info: dwd.0 (21615) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 12:15:14.235 - info: dwd.0 (21615) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-10-26 12:15:14.770 - info: host.iobroker instance system.adapter.dwd.0 having pid 21615 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-10-26 12:15:34.054 - info: host.iobroker instance system.adapter.tvspielfilm.0 in version "2.1.0" started with pid 21634
      2025-10-26 12:15:36.574 - info: tvspielfilm.0 (21634) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 12:15:38.088 - info: host.iobroker instance system.adapter.daswetter.0 in version "3.2.6" started with pid 21649
      2025-10-26 12:15:38.655 - info: tvspielfilm.0 (21634) objects written
      2025-10-26 12:15:40.677 - info: daswetter.0 (21649) starting. Version 3.2.6 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 12:15:49.163 - info: tvspielfilm.0 (21634) Terminated (NO_ERROR): Without reason
      2025-10-26 12:15:49.701 - info: host.iobroker instance system.adapter.tvspielfilm.0 having pid 21634 terminated with code 0 (NO_ERROR)
      2025-10-26 12:15:58.593 - info: daswetter.0 (21649) still wrong data structure from server received! repaired...
      2025-10-26 12:16:03.645 - info: daswetter.0 (21649) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
      2025-10-26 12:16:04.159 - info: daswetter.0 (21649) cleaned everything up...
      2025-10-26 12:16:04.174 - info: host.iobroker instance system.adapter.daswetter.0 having pid 21649 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-10-26 12:20:11.040 - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 21703
      2025-10-26 12:20:13.545 - info: dwd.0 (21703) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 12:20:14.247 - info: dwd.0 (21703) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-10-26 12:20:14.776 - info: host.iobroker instance system.adapter.dwd.0 having pid 21703 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-10-26 12:20:34.039 - info: host.iobroker instance system.adapter.tvspielfilm.0 in version "2.1.0" started with pid 21722
      2025-10-26 12:20:36.593 - info: tvspielfilm.0 (21722) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 12:20:38.664 - info: tvspielfilm.0 (21722) objects written
      2025-10-26 12:20:49.170 - info: tvspielfilm.0 (21722) Terminated (NO_ERROR): Without reason
      2025-10-26 12:20:49.699 - info: host.iobroker instance system.adapter.tvspielfilm.0 having pid 21722 terminated with code 0 (NO_ERROR)
      2025-10-26 12:21:16.600 - info: web.0 (806) <== Disconnect system.user.admin from ::ffff:192.168.178.199
      2025-10-26 12:25:06.049 - info: host.iobroker instance system.adapter.weatherunderground.0 in version "3.7.0" started with pid 21774
      2025-10-26 12:25:08.388 - info: weatherunderground.0 (21774) starting. Version 3.7.0 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 12:25:11.038 - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 21789
      2025-10-26 12:25:13.472 - info: dwd.0 (21789) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 12:25:14.155 - info: dwd.0 (21789) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-10-26 12:25:14.683 - info: host.iobroker instance system.adapter.dwd.0 having pid 21789 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-10-26 12:25:24.350 - info: weatherunderground.0 (21774) Terminated (NO_ERROR): Without reason
      2025-10-26 12:25:24.875 - info: host.iobroker instance system.adapter.weatherunderground.0 having pid 21774 terminated with code 0 (NO_ERROR)
      2025-10-26 12:25:34.042 - info: host.iobroker instance system.adapter.tvspielfilm.0 in version "2.1.0" started with pid 21808
      2025-10-26 12:25:36.508 - info: tvspielfilm.0 (21808) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 12:25:38.581 - info: tvspielfilm.0 (21808) objects written
      2025-10-26 12:25:49.087 - info: tvspielfilm.0 (21808) Terminated (NO_ERROR): Without reason
      2025-10-26 12:25:49.615 - info: host.iobroker instance system.adapter.tvspielfilm.0 having pid 21808 terminated with code 0 (NO_ERROR)
      2025-10-26 12:26:03.174 - info: admin.0 (6415) <== Disconnect system.user.admin from ::ffff:192.168.178.70 admin
      2025-10-26 12:27:53.262 - info: web.0 (806) <== Disconnect system.user.admin from ::ffff:192.168.178.70
      2025-10-26 12:29:10.894 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] connection closed: timeout
      2025-10-26 12:29:14.303 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] connected with secret 1761478151226_3274
      2025-10-26 12:29:22.012 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] subscribes on "Schalter Alamierung/#" with regex /^Schalter_Alamierung../
      2025-10-26 12:29:22.012 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] subscribes on "Schalter Alamierung/#" with regex /^mqtt.0.Schalter_Alamierung..
      2025-10-26 12:29:22.213 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] publishOnSubscribe send all known states
      2025-10-26 12:30:11.042 - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 21859
      2025-10-26 12:30:13.486 - info: dwd.0 (21859) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 12:30:14.237 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] connection closed: timeout
      2025-10-26 12:30:14.480 - info: dwd.0 (21859) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-10-26 12:30:15.013 - info: host.iobroker instance system.adapter.dwd.0 having pid 21859 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-10-26 12:30:34.049 - info: host.iobroker instance system.adapter.tvspielfilm.0 in version "2.1.0" started with pid 21878
      2025-10-26 12:30:36.524 - info: tvspielfilm.0 (21878) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 12:30:38.081 - info: host.iobroker instance system.adapter.daswetter.0 in version "3.2.6" started with pid 21893
      2025-10-26 12:30:38.604 - info: tvspielfilm.0 (21878) objects written
      2025-10-26 12:30:40.551 - info: daswetter.0 (21893) starting. Version 3.2.6 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 12:30:49.114 - info: tvspielfilm.0 (21878) Terminated (NO_ERROR): Without reason
      2025-10-26 12:30:49.649 - info: host.iobroker instance system.adapter.tvspielfilm.0 having pid 21878 terminated with code 0 (NO_ERROR)
      2025-10-26 12:30:58.386 - info: daswetter.0 (21893) still wrong data structure from server received! repaired...
      2025-10-26 12:31:03.405 - info: daswetter.0 (21893) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
      2025-10-26 12:31:03.919 - info: daswetter.0 (21893) cleaned everything up...
      2025-10-26 12:31:03.934 - info: host.iobroker instance system.adapter.daswetter.0 having pid 21893 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-10-26 12:31:46.681 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] connected with secret 1761478306681_9499
      2025-10-26 12:31:46.698 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] subscribes on "Schalter Alamierung/#" with regex /^Schalter_Alamierung../
      2025-10-26 12:31:46.698 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] subscribes on "Schalter Alamierung/#" with regex /^mqtt.0.Schalter_Alamierung..
      2025-10-26 12:31:46.898 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] publishOnSubscribe send all known states
      2025-10-26 12:31:48.389 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] reconnected. Old secret 1761478306681_9499. New secret 1761478221551_3933
      2025-10-26 12:31:48.396 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] connection closed: closed
      2025-10-26 12:35:11.040 - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 21944
      2025-10-26 12:35:13.464 - info: dwd.0 (21944) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 12:35:14.146 - info: dwd.0 (21944) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-10-26 12:35:14.675 - info: host.iobroker instance system.adapter.dwd.0 having pid 21944 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-10-26 12:35:34.038 - info: host.iobroker instance system.adapter.tvspielfilm.0 in version "2.1.0" started with pid 21963
      2025-10-26 12:35:36.491 - info: tvspielfilm.0 (21963) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 12:35:38.562 - info: tvspielfilm.0 (21963) objects written
      2025-10-26 12:35:49.070 - info: tvspielfilm.0 (21963) Terminated (NO_ERROR): Without reason
      2025-10-26 12:35:49.598 - info: host.iobroker instance system.adapter.tvspielfilm.0 having pid 21963 terminated with code 0 (NO_ERROR)
      2025-10-26 12:40:11.040 - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 22014
      2025-10-26 12:40:13.555 - info: dwd.0 (22014) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 12:40:14.289 - info: dwd.0 (22014) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-10-26 12:40:14.818 - info: host.iobroker instance system.adapter.dwd.0 having pid 22014 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-10-26 12:40:34.040 - info: host.iobroker instance system.adapter.tvspielfilm.0 in version "2.1.0" started with pid 22033
      2025-10-26 12:40:36.560 - info: tvspielfilm.0 (22033) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 12:40:38.637 - info: tvspielfilm.0 (22033) objects written
      2025-10-26 12:40:49.143 - info: tvspielfilm.0 (22033) Terminated (NO_ERROR): Without reason
      2025-10-26 12:40:49.670 - info: host.iobroker instance system.adapter.tvspielfilm.0 having pid 22033 terminated with code 0 (NO_ERROR)
      2025-10-26 12:45:11.043 - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 22084
      2025-10-26 12:45:13.509 - info: dwd.0 (22084) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 12:45:14.295 - info: dwd.0 (22084) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-10-26 12:45:14.826 - info: host.iobroker instance system.adapter.dwd.0 having pid 22084 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-10-26 12:45:34.048 - info: host.iobroker instance system.adapter.tvspielfilm.0 in version "2.1.0" started with pid 22103
      2025-10-26 12:45:36.572 - info: tvspielfilm.0 (22103) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 12:45:38.081 - info: host.iobroker instance system.adapter.daswetter.0 in version "3.2.6" started with pid 22118
      2025-10-26 12:45:38.659 - info: tvspielfilm.0 (22103) objects written
      2025-10-26 12:45:40.581 - info: daswetter.0 (22118) starting. Version 3.2.6 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 12:45:49.168 - info: tvspielfilm.0 (22103) Terminated (NO_ERROR): Without reason
      2025-10-26 12:45:49.703 - info: host.iobroker instance system.adapter.tvspielfilm.0 having pid 22103 terminated with code 0 (NO_ERROR)
      2025-10-26 12:45:58.399 - info: daswetter.0 (22118) still wrong data structure from server received! repaired...
      2025-10-26 12:46:03.423 - info: daswetter.0 (22118) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
      2025-10-26 12:46:03.937 - info: daswetter.0 (22118) cleaned everything up...
      2025-10-26 12:46:03.950 - info: host.iobroker instance system.adapter.daswetter.0 having pid 22118 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-10-26 12:50:11.041 - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 22169
      2025-10-26 12:50:13.520 - info: dwd.0 (22169) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 12:50:14.250 - info: dwd.0 (22169) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-10-26 12:50:14.780 - info: host.iobroker instance system.adapter.dwd.0 having pid 22169 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-10-26 12:50:34.044 - info: host.iobroker instance system.adapter.tvspielfilm.0 in version "2.1.0" started with pid 22186
      2025-10-26 12:50:36.541 - info: tvspielfilm.0 (22186) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 12:50:38.612 - info: tvspielfilm.0 (22186) objects written
      2025-10-26 12:50:49.119 - info: tvspielfilm.0 (22186) Terminated (NO_ERROR): Without reason
      2025-10-26 12:50:49.649 - info: host.iobroker instance system.adapter.tvspielfilm.0 having pid 22186 terminated with code 0 (NO_ERROR)
      2025-10-26 12:55:11.038 - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 22239
      2025-10-26 12:55:13.442 - info: dwd.0 (22239) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 12:55:14.158 - info: dwd.0 (22239) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-10-26 12:55:14.688 - info: host.iobroker instance system.adapter.dwd.0 having pid 22239 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-10-26 12:55:34.040 - info: host.iobroker instance system.adapter.tvspielfilm.0 in version "2.1.0" started with pid 22256
      2025-10-26 12:55:36.521 - info: tvspielfilm.0 (22256) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 12:55:38.591 - info: tvspielfilm.0 (22256) objects written
      2025-10-26 12:55:49.097 - info: tvspielfilm.0 (22256) Terminated (NO_ERROR): Without reason
      2025-10-26 12:55:49.626 - info: host.iobroker instance system.adapter.tvspielfilm.0 having pid 22256 terminated with code 0 (NO_ERROR)
      2025-10-26 13:00:11.041 - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 22309
      2025-10-26 13:00:13.476 - info: dwd.0 (22309) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 13:00:14.318 - info: dwd.0 (22309) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-10-26 13:00:14.847 - info: host.iobroker instance system.adapter.dwd.0 having pid 22309 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-10-26 13:00:34.050 - info: host.iobroker instance system.adapter.tvspielfilm.0 in version "2.1.0" started with pid 22326
      2025-10-26 13:00:36.525 - info: tvspielfilm.0 (22326) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 13:00:38.082 - info: host.iobroker instance system.adapter.daswetter.0 in version "3.2.6" started with pid 22343
      2025-10-26 13:00:38.608 - info: tvspielfilm.0 (22326) objects written
      2025-10-26 13:00:40.486 - info: daswetter.0 (22343) starting. Version 3.2.6 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 13:00:49.116 - info: tvspielfilm.0 (22326) Terminated (NO_ERROR): Without reason
      2025-10-26 13:00:49.647 - info: host.iobroker instance system.adapter.tvspielfilm.0 having pid 22326 terminated with code 0 (NO_ERROR)
      2025-10-26 13:00:58.196 - info: daswetter.0 (22343) still wrong data structure from server received! repaired...
      2025-10-26 13:01:03.343 - info: daswetter.0 (22343) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
      2025-10-26 13:01:03.856 - info: daswetter.0 (22343) cleaned everything up...
      2025-10-26 13:01:03.871 - info: host.iobroker instance system.adapter.daswetter.0 having pid 22343 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-10-26 13:04:56.283 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] connected with secret 1761480296238_7417
      2025-10-26 13:04:56.329 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] subscribes on "Schalter Alamierung/#" with regex /^Schalter_Alamierung../
      2025-10-26 13:04:56.329 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] subscribes on "Schalter Alamierung/#" with regex /^mqtt.0.Schalter_Alamierung..
      2025-10-26 13:04:56.529 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] publishOnSubscribe send all known states
      2025-10-26 13:05:11.041 - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 22394
      2025-10-26 13:05:13.445 - info: dwd.0 (22394) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 13:05:14.150 - info: dwd.0 (22394) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-10-26 13:05:14.679 - info: host.iobroker instance system.adapter.dwd.0 having pid 22394 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-10-26 13:05:21.554 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] connection closed: timeout
      2025-10-26 13:05:27.214 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] connected with secret 1761480327213_9148
      2025-10-26 13:05:27.238 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] subscribes on "Schalter Alamierung/#" with regex /^Schalter_Alamierung../
      2025-10-26 13:05:27.240 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] subscribes on "Schalter Alamierung/#" with regex /^mqtt.0.Schalter_Alamierung..
      2025-10-26 13:05:27.440 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] publishOnSubscribe send all known states
      2025-10-26 13:05:34.041 - info: host.iobroker instance system.adapter.tvspielfilm.0 in version "2.1.0" started with pid 22411
      2025-10-26 13:05:36.487 - info: tvspielfilm.0 (22411) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 13:05:38.556 - info: tvspielfilm.0 (22411) objects written
      2025-10-26 13:05:49.062 - info: tvspielfilm.0 (22411) Terminated (NO_ERROR): Without reason
      2025-10-26 13:05:49.145 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] connection closed: closed
      2025-10-26 13:05:49.588 - info: host.iobroker instance system.adapter.tvspielfilm.0 having pid 22411 terminated with code 0 (NO_ERROR)
      2025-10-26 13:06:18.919 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] connected with secret 1761480378889_6626
      2025-10-26 13:06:18.933 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] subscribes on "Schalter Alamierung/#" with regex /^Schalter_Alamierung../
      2025-10-26 13:06:18.933 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] subscribes on "Schalter Alamierung/#" with regex /^mqtt.0.Schalter_Alamierung..
      2025-10-26 13:06:19.133 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] publishOnSubscribe send all known states
      2025-10-26 13:07:20.207 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] connection closed: closed
      2025-10-26 13:07:20.291 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] connected with secret 1761480440248_6441
      2025-10-26 13:07:20.970 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] subscribes on "Schalter Alamierung/#" with regex /^Schalter_Alamierung../
      2025-10-26 13:07:20.970 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] subscribes on "Schalter Alamierung/#" with regex /^mqtt.0.Schalter_Alamierung..
      2025-10-26 13:07:21.171 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] publishOnSubscribe send all known states
      2025-10-26 13:08:22.228 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] connection closed: closed
      2025-10-26 13:08:22.282 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] connected with secret 1761480502280_384
      2025-10-26 13:08:22.296 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] subscribes on "Schalter Alamierung/#" with regex /^Schalter_Alamierung../
      2025-10-26 13:08:22.297 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] subscribes on "Schalter Alamierung/#" with regex /^mqtt.0.Schalter_Alamierung..
      2025-10-26 13:08:22.497 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] publishOnSubscribe send all known states
      2025-10-26 13:10:11.041 - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 22464
      2025-10-26 13:10:13.499 - info: dwd.0 (22464) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 13:10:14.213 - info: dwd.0 (22464) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-10-26 13:10:14.743 - info: host.iobroker instance system.adapter.dwd.0 having pid 22464 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-10-26 13:10:34.041 - info: host.iobroker instance system.adapter.tvspielfilm.0 in version "2.1.0" started with pid 22481
      2025-10-26 13:10:36.533 - info: tvspielfilm.0 (22481) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 13:10:38.605 - info: tvspielfilm.0 (22481) objects written
      2025-10-26 13:10:49.112 - info: tvspielfilm.0 (22481) Terminated (NO_ERROR): Without reason
      2025-10-26 13:10:49.640 - info: host.iobroker instance system.adapter.tvspielfilm.0 having pid 22481 terminated with code 0 (NO_ERROR)
      2025-10-26 13:10:55.110 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] connection closed: closed
      2025-10-26 13:11:28.884 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] connected with secret 1761480685849_38
      2025-10-26 13:11:29.155 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] subscribes on "Schalter Alamierung/#" with regex /^Schalter_Alamierung../
      2025-10-26 13:11:29.155 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] subscribes on "Schalter Alamierung/#" with regex /^mqtt.0.Schalter_Alamierung..
      2025-10-26 13:11:29.356 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] publishOnSubscribe send all known states
      2025-10-26 13:12:31.278 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] connection closed: closed
      2025-10-26 13:13:01.252 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] connected with secret 1761480781201_7092
      2025-10-26 13:13:03.715 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] subscribes on "Schalter Alamierung/#" with regex /^Schalter_Alamierung../
      2025-10-26 13:13:03.715 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] subscribes on "Schalter Alamierung/#" with regex /^mqtt.0.Schalter_Alamierung..
      2025-10-26 13:13:03.916 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] publishOnSubscribe send all known states
      2025-10-26 13:14:23.334 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] connection closed: closed
      2025-10-26 13:14:54.187 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] connected with secret 1761480894176_7434
      2025-10-26 13:14:56.400 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] subscribes on "Schalter Alamierung/#" with regex /^Schalter_Alamierung../
      2025-10-26 13:14:56.400 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] subscribes on "Schalter Alamierung/#" with regex /^mqtt.0.Schalter_Alamierung..
      2025-10-26 13:14:56.601 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] publishOnSubscribe send all known states
      2025-10-26 13:15:11.040 - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 22534
      2025-10-26 13:15:13.639 - info: dwd.0 (22534) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 13:15:14.363 - info: dwd.0 (22534) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-10-26 13:15:14.892 - info: host.iobroker instance system.adapter.dwd.0 having pid 22534 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-10-26 13:15:34.047 - info: host.iobroker instance system.adapter.tvspielfilm.0 in version "2.1.0" started with pid 22551
      2025-10-26 13:15:36.553 - info: tvspielfilm.0 (22551) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 13:15:38.080 - info: host.iobroker instance system.adapter.daswetter.0 in version "3.2.6" started with pid 22568
      2025-10-26 13:15:38.632 - info: tvspielfilm.0 (22551) objects written
      2025-10-26 13:15:40.558 - info: daswetter.0 (22568) starting. Version 3.2.6 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 13:15:49.140 - info: tvspielfilm.0 (22551) Terminated (NO_ERROR): Without reason
      2025-10-26 13:15:49.682 - info: host.iobroker instance system.adapter.tvspielfilm.0 having pid 22551 terminated with code 0 (NO_ERROR)
      2025-10-26 13:15:59.121 - info: daswetter.0 (22568) still wrong data structure from server received! repaired...
      2025-10-26 13:16:04.249 - info: daswetter.0 (22568) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
      2025-10-26 13:16:04.763 - info: daswetter.0 (22568) cleaned everything up...
      2025-10-26 13:16:04.779 - info: host.iobroker instance system.adapter.daswetter.0 having pid 22568 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-10-26 13:18:39.022 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] connection closed: closed
      2025-10-26 13:18:41.824 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] connected with secret 1761481119108_4942
      2025-10-26 13:18:42.469 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] subscribes on "Schalter Alamierung/#" with regex /^Schalter_Alamierung../
      2025-10-26 13:18:42.469 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] subscribes on "Schalter Alamierung/#" with regex /^mqtt.0.Schalter_Alamierung..
      2025-10-26 13:18:42.670 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] publishOnSubscribe send all known states
      2025-10-26 13:19:02.494 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] connection closed: closed
      2025-10-26 13:19:02.634 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] connected with secret 1761481142567_1395
      2025-10-26 13:19:07.875 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] subscribes on "Schalter Alamierung/#" with regex /^Schalter_Alamierung../
      2025-10-26 13:19:07.875 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] subscribes on "Schalter Alamierung/#" with regex /^mqtt.0.Schalter_Alamierung..
      2025-10-26 13:19:08.075 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] publishOnSubscribe send all known states
      2025-10-26 13:19:23.076 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] connection closed: timeout
      2025-10-26 13:19:23.458 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] connected with secret 1761481163429_2553
      2025-10-26 13:19:23.532 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] subscribes on "Schalter Alamierung/#" with regex /^Schalter_Alamierung../
      2025-10-26 13:19:23.532 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] subscribes on "Schalter Alamierung/#" with regex /^mqtt.0.Schalter_Alamierung..
      2025-10-26 13:19:23.732 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] publishOnSubscribe send all known states
      2025-10-26 13:19:48.753 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] connection closed: timeout
      2025-10-26 13:20:11.040 - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 22622
      2025-10-26 13:20:13.475 - info: dwd.0 (22622) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 13:20:14.183 - info: dwd.0 (22622) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-10-26 13:20:14.714 - info: host.iobroker instance system.adapter.dwd.0 having pid 22622 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-10-26 13:20:18.157 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] connected with secret 1761481218157_3857
      2025-10-26 13:20:30.818 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] connection closed: closed
      2025-10-26 13:20:34.040 - info: host.iobroker instance system.adapter.tvspielfilm.0 in version "2.1.0" started with pid 22639
      2025-10-26 13:20:36.532 - info: tvspielfilm.0 (22639) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 13:20:38.603 - info: tvspielfilm.0 (22639) objects written
      2025-10-26 13:20:49.111 - info: tvspielfilm.0 (22639) Terminated (NO_ERROR): Without reason
      2025-10-26 13:20:49.639 - info: host.iobroker instance system.adapter.tvspielfilm.0 having pid 22639 terminated with code 0 (NO_ERROR)
      2025-10-26 13:21:16.889 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] connected with secret 1761481276877_3297
      2025-10-26 13:21:32.174 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] connection closed: closed
      2025-10-26 13:22:01.158 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] connected with secret 1761481321157_2267
      2025-10-26 13:22:01.168 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] subscribes on "Schalter Alamierung/#" with regex /^Schalter_Alamierung../
      2025-10-26 13:22:01.169 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] subscribes on "Schalter Alamierung/#" with regex /^mqtt.0.Schalter_Alamierung..
      2025-10-26 13:22:01.369 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] publishOnSubscribe send all known states
      2025-10-26 13:25:06.046 - info: host.iobroker instance system.adapter.weatherunderground.0 in version "3.7.0" started with pid 22693
      2025-10-26 13:25:08.430 - info: weatherunderground.0 (22693) starting. Version 3.7.0 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 13:25:11.040 - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 22708
      2025-10-26 13:25:13.402 - info: dwd.0 (22708) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 13:25:14.107 - info: dwd.0 (22708) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-10-26 13:25:14.634 - info: host.iobroker instance system.adapter.dwd.0 having pid 22708 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-10-26 13:25:25.761 - info: weatherunderground.0 (22693) Terminated (NO_ERROR): Without reason
      2025-10-26 13:25:26.288 - info: host.iobroker instance system.adapter.weatherunderground.0 having pid 22693 terminated with code 0 (NO_ERROR)
      2025-10-26 13:25:34.040 - info: host.iobroker instance system.adapter.tvspielfilm.0 in version "2.1.0" started with pid 22725
      2025-10-26 13:25:36.589 - info: tvspielfilm.0 (22725) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 13:25:38.661 - info: tvspielfilm.0 (22725) objects written
      2025-10-26 13:25:49.166 - info: tvspielfilm.0 (22725) Terminated (NO_ERROR): Without reason
      2025-10-26 13:25:49.695 - info: host.iobroker instance system.adapter.tvspielfilm.0 having pid 22725 terminated with code 0 (NO_ERROR)
      2025-10-26 13:30:11.040 - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 22778
      2025-10-26 13:30:13.404 - info: dwd.0 (22778) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 13:30:14.100 - info: dwd.0 (22778) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-10-26 13:30:14.630 - info: host.iobroker instance system.adapter.dwd.0 having pid 22778 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-10-26 13:30:34.043 - info: host.iobroker instance system.adapter.tvspielfilm.0 in version "2.1.0" started with pid 22795
      2025-10-26 13:30:36.577 - info: tvspielfilm.0 (22795) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 13:30:38.076 - info: host.iobroker instance system.adapter.daswetter.0 in version "3.2.6" started with pid 22812
      2025-10-26 13:30:38.668 - info: tvspielfilm.0 (22795) objects written
      2025-10-26 13:30:40.619 - info: daswetter.0 (22812) starting. Version 3.2.6 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 13:30:49.178 - info: tvspielfilm.0 (22795) Terminated (NO_ERROR): Without reason
      2025-10-26 13:30:49.712 - info: host.iobroker instance system.adapter.tvspielfilm.0 having pid 22795 terminated with code 0 (NO_ERROR)
      2025-10-26 13:30:58.269 - info: daswetter.0 (22812) still wrong data structure from server received! repaired...
      2025-10-26 13:31:03.250 - info: daswetter.0 (22812) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
      2025-10-26 13:31:03.763 - info: daswetter.0 (22812) cleaned everything up...
      2025-10-26 13:31:03.780 - info: host.iobroker instance system.adapter.daswetter.0 having pid 22812 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-10-26 13:35:11.040 - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 22863
      2025-10-26 13:35:13.479 - info: dwd.0 (22863) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 13:35:14.151 - info: dwd.0 (22863) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-10-26 13:35:14.679 - info: host.iobroker instance system.adapter.dwd.0 having pid 22863 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-10-26 13:35:34.039 - info: host.iobroker instance system.adapter.tvspielfilm.0 in version "2.1.0" started with pid 22881
      2025-10-26 13:35:36.581 - info: tvspielfilm.0 (22881) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 13:35:38.651 - info: tvspielfilm.0 (22881) objects written
      2025-10-26 13:35:49.158 - info: tvspielfilm.0 (22881) Terminated (NO_ERROR): Without reason
      2025-10-26 13:35:49.690 - info: host.iobroker instance system.adapter.tvspielfilm.0 having pid 22881 terminated with code 0 (NO_ERROR)
      2025-10-26 13:40:11.039 - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 22934
      2025-10-26 13:40:13.435 - info: dwd.0 (22934) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 13:40:14.176 - info: dwd.0 (22934) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-10-26 13:40:14.709 - info: host.iobroker instance system.adapter.dwd.0 having pid 22934 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-10-26 13:40:34.038 - info: host.iobroker instance system.adapter.tvspielfilm.0 in version "2.1.0" started with pid 22951
      2025-10-26 13:40:36.569 - info: tvspielfilm.0 (22951) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 13:40:38.639 - info: tvspielfilm.0 (22951) objects written
      2025-10-26 13:40:49.145 - info: tvspielfilm.0 (22951) Terminated (NO_ERROR): Without reason
      2025-10-26 13:40:49.675 - info: host.iobroker instance system.adapter.tvspielfilm.0 having pid 22951 terminated with code 0 (NO_ERROR)
      2025-10-26 13:45:11.041 - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 23004
      2025-10-26 13:45:13.582 - info: dwd.0 (23004) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 13:45:14.289 - info: dwd.0 (23004) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-10-26 13:45:14.818 - info: host.iobroker instance system.adapter.dwd.0 having pid 23004 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-10-26 13:45:34.043 - info: host.iobroker instance system.adapter.tvspielfilm.0 in version "2.1.0" started with pid 23021
      2025-10-26 13:45:36.455 - info: tvspielfilm.0 (23021) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 13:45:38.076 - info: host.iobroker instance system.adapter.daswetter.0 in version "3.2.6" started with pid 23038
      2025-10-26 13:45:38.535 - info: tvspielfilm.0 (23021) objects written
      2025-10-26 13:45:40.542 - info: daswetter.0 (23038) starting. Version 3.2.6 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 13:45:49.045 - info: tvspielfilm.0 (23021) Terminated (NO_ERROR): Without reason
      2025-10-26 13:45:49.576 - info: host.iobroker instance system.adapter.tvspielfilm.0 having pid 23021 terminated with code 0 (NO_ERROR)
      2025-10-26 13:45:58.181 - info: daswetter.0 (23038) still wrong data structure from server received! repaired...
      2025-10-26 13:46:03.271 - info: daswetter.0 (23038) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
      2025-10-26 13:46:03.784 - info: daswetter.0 (23038) cleaned everything up...
      2025-10-26 13:46:03.798 - info: host.iobroker instance system.adapter.daswetter.0 having pid 23038 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-10-26 13:50:11.041 - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 23089
      2025-10-26 13:50:13.427 - info: dwd.0 (23089) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 13:50:14.131 - info: dwd.0 (23089) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-10-26 13:50:14.660 - info: host.iobroker instance system.adapter.dwd.0 having pid 23089 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-10-26 13:50:34.040 - info: host.iobroker instance system.adapter.tvspielfilm.0 in version "2.1.0" started with pid 23106
      2025-10-26 13:50:36.538 - info: tvspielfilm.0 (23106) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 13:50:38.607 - info: tvspielfilm.0 (23106) objects written
      2025-10-26 13:50:49.114 - info: tvspielfilm.0 (23106) Terminated (NO_ERROR): Without reason
      2025-10-26 13:50:49.643 - info: host.iobroker instance system.adapter.tvspielfilm.0 having pid 23106 terminated with code 0 (NO_ERROR)
      2025-10-26 13:55:11.042 - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 23159
      2025-10-26 13:55:13.449 - info: dwd.0 (23159) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 13:55:14.175 - info: dwd.0 (23159) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-10-26 13:55:14.704 - info: host.iobroker instance system.adapter.dwd.0 having pid 23159 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-10-26 13:55:34.039 - info: host.iobroker instance system.adapter.tvspielfilm.0 in version "2.1.0" started with pid 23176
      2025-10-26 13:55:36.522 - info: tvspielfilm.0 (23176) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 13:55:38.600 - info: tvspielfilm.0 (23176) objects written
      2025-10-26 13:55:49.106 - info: tvspielfilm.0 (23176) Terminated (NO_ERROR): Without reason
      2025-10-26 13:55:49.632 - info: host.iobroker instance system.adapter.tvspielfilm.0 having pid 23176 terminated with code 0 (NO_ERROR)
      2025-10-26 14:00:11.041 - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 23229
      2025-10-26 14:00:13.607 - info: dwd.0 (23229) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 14:00:14.317 - info: dwd.0 (23229) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-10-26 14:00:14.845 - info: host.iobroker instance system.adapter.dwd.0 having pid 23229 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-10-26 14:00:34.044 - info: host.iobroker instance system.adapter.tvspielfilm.0 in version "2.1.0" started with pid 23246
      2025-10-26 14:00:36.471 - info: tvspielfilm.0 (23246) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 14:00:38.078 - info: host.iobroker instance system.adapter.daswetter.0 in version "3.2.6" started with pid 23263
      2025-10-26 14:00:38.557 - info: tvspielfilm.0 (23246) objects written
      2025-10-26 14:00:40.544 - info: daswetter.0 (23263) starting. Version 3.2.6 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 14:00:49.064 - info: tvspielfilm.0 (23246) Terminated (NO_ERROR): Without reason
      2025-10-26 14:00:49.600 - info: host.iobroker instance system.adapter.tvspielfilm.0 having pid 23246 terminated with code 0 (NO_ERROR)
      2025-10-26 14:00:58.019 - info: daswetter.0 (23263) still wrong data structure from server received! repaired...
      2025-10-26 14:01:02.938 - info: daswetter.0 (23263) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
      2025-10-26 14:01:03.452 - info: daswetter.0 (23263) cleaned everything up...
      2025-10-26 14:01:03.468 - info: host.iobroker instance system.adapter.daswetter.0 having pid 23263 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-10-26 14:05:11.038 - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 23314
      2025-10-26 14:05:13.423 - info: dwd.0 (23314) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 14:05:14.127 - info: dwd.0 (23314) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-10-26 14:05:14.657 - info: host.iobroker instance system.adapter.dwd.0 having pid 23314 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-10-26 14:05:34.036 - info: host.iobroker instance system.adapter.tvspielfilm.0 in version "2.1.0" started with pid 23331
      2025-10-26 14:05:36.506 - info: tvspielfilm.0 (23331) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 14:05:38.579 - info: tvspielfilm.0 (23331) objects written
      2025-10-26 14:05:49.086 - info: tvspielfilm.0 (23331) Terminated (NO_ERROR): Without reason
      2025-10-26 14:05:49.614 - info: host.iobroker instance system.adapter.tvspielfilm.0 having pid 23331 terminated with code 0 (NO_ERROR)
      2025-10-26 14:10:11.038 - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 23384
      2025-10-26 14:10:13.433 - info: dwd.0 (23384) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 14:10:14.143 - info: dwd.0 (23384) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-10-26 14:10:14.672 - info: host.iobroker instance system.adapter.dwd.0 having pid 23384 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-10-26 14:10:34.038 - info: host.iobroker instance system.adapter.tvspielfilm.0 in version "2.1.0" started with pid 23401
      2025-10-26 14:10:36.460 - info: tvspielfilm.0 (23401) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 14:10:38.532 - info: tvspielfilm.0 (23401) objects written
      2025-10-26 14:10:49.038 - info: tvspielfilm.0 (23401) Terminated (NO_ERROR): Without reason
      2025-10-26 14:10:49.570 - info: host.iobroker instance system.adapter.tvspielfilm.0 having pid 23401 terminated with code 0 (NO_ERROR)
      2025-10-26 14:15:11.049 - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 23454
      2025-10-26 14:15:13.627 - info: dwd.0 (23454) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 14:15:14.351 - info: dwd.0 (23454) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-10-26 14:15:14.889 - info: host.iobroker instance system.adapter.dwd.0 having pid 23454 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-10-26 14:15:34.050 - info: host.iobroker instance system.adapter.tvspielfilm.0 in version "2.1.0" started with pid 23471
      2025-10-26 14:15:36.652 - info: tvspielfilm.0 (23471) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 14:15:38.084 - info: host.iobroker instance system.adapter.daswetter.0 in version "3.2.6" started with pid 23488
      2025-10-26 14:15:38.737 - info: tvspielfilm.0 (23471) objects written
      2025-10-26 14:15:40.544 - info: daswetter.0 (23488) starting. Version 3.2.6 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 14:15:49.245 - info: tvspielfilm.0 (23471) Terminated (NO_ERROR): Without reason
      2025-10-26 14:15:49.776 - info: host.iobroker instance system.adapter.tvspielfilm.0 having pid 23471 terminated with code 0 (NO_ERROR)
      2025-10-26 14:15:58.380 - info: daswetter.0 (23488) still wrong data structure from server received! repaired...
      2025-10-26 14:16:03.460 - info: daswetter.0 (23488) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
      2025-10-26 14:16:03.974 - info: daswetter.0 (23488) cleaned everything up...
      2025-10-26 14:16:03.989 - info: host.iobroker instance system.adapter.daswetter.0 having pid 23488 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-10-26 14:16:06.727 - info: admin.0 (6415) Request actual repository...
      2025-10-26 14:16:08.134 - info: host.iobroker Updating repository "beta" under "http://download.iobroker.net/sources-dist-latest.json"
      2025-10-26 14:16:14.346 - info: admin.0 (6415) Repository received successfully.
      2025-10-26 14:39:48.685 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] connection closed: timeout
      2025-10-26 15:44:19.285 - info: mqtt.0 (635) Client [Schalter_Alamierung_0] connected with secret 1761485862192_3347
      2025-10-26 17:54:50.867 - info: host.iobroker iobroker.js-controller version 7.0.7 js-controller starting
      2025-10-26 17:54:50.872 - info: host.iobroker Copyright (c) 2014-2024 bluefox, 2014 hobbyquaker
      2025-10-26 17:54:50.873 - info: host.iobroker hostname: iobroker, node: v20.18.2
      2025-10-26 17:54:50.874 - info: host.iobroker ip addresses: 192.168.178.62 2003:c4:af4f:6d00:be24:11ff:fe3c:5faa fe80::be24:11ff:fe3c:5faa
      2025-10-26 17:54:53.060 - info: host.iobroker connected to Objects and States
      2025-10-26 17:54:53.096 - info: host.iobroker added notifications configuration of host
      2025-10-26 17:54:53.919 - info: host.iobroker 57 instances found
      2025-10-26 17:54:54.010 - info: host.iobroker starting 26 instances
      2025-10-26 17:54:54.764 - info: host.iobroker Delete state "system.host.iobroker.versions.nodeCurrent"
      2025-10-26 17:54:54.878 - info: host.iobroker Delete state "system.host.iobroker.versions.nodeNewest"
      2025-10-26 17:54:54.897 - info: host.iobroker Delete state "system.host.iobroker.versions.nodeNewestNext"
      2025-10-26 17:54:54.953 - info: host.iobroker instance system.adapter.admin.0 in version "7.7.16" started with pid 304
      2025-10-26 17:54:54.961 - info: host.iobroker Delete state "system.host.iobroker.versions.npmCurrent"
      2025-10-26 17:54:55.009 - info: host.iobroker Delete state "system.host.iobroker.versions.npmNewest"
      2025-10-26 17:54:55.058 - info: host.iobroker Delete state "system.host.iobroker.versions.npmNewestNext"
      2025-10-26 17:54:55.106 - info: host.iobroker Some obsolete host states deleted.
      2025-10-26 17:54:58.703 - info: host.iobroker instance system.adapter.javascript.0 in version "9.0.11" started with pid 311
      2025-10-26 17:55:00.104 - error: admin.0 (304) admin.0 already running
      2025-10-26 17:55:00.109 - warn: admin.0 (304) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2025-10-26 17:55:00.811 - error: host.iobroker instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2025-10-26 17:55:00.811 - info: host.iobroker Restart adapter system.adapter.admin.0 because enabled
      2025-10-26 17:55:01.981 - error: javascript.0 (311) javascript.0 already running
      2025-10-26 17:55:01.985 - warn: javascript.0 (311) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2025-10-26 17:55:02.652 - info: host.iobroker instance system.adapter.backitup.0 in version "3.3.10" started with pid 326
      2025-10-26 17:55:02.738 - error: host.iobroker instance system.adapter.javascript.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2025-10-26 17:55:02.740 - info: host.iobroker Restart adapter system.adapter.javascript.0 because enabled
      2025-10-26 17:55:04.491 - error: backitup.0 (326) backitup.0 already running
      2025-10-26 17:55:04.495 - warn: backitup.0 (326) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2025-10-26 17:55:05.080 - error: host.iobroker instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2025-10-26 17:55:05.080 - info: host.iobroker Restart adapter system.adapter.backitup.0 because enabled
      2025-10-26 17:55:06.736 - info: host.iobroker instance scheduled system.adapter.weatherunderground.0 25 * * * *
      2025-10-26 17:55:06.744 - info: host.iobroker instance system.adapter.weatherunderground.0 in version "3.7.0" started with pid 337
      2025-10-26 17:55:08.994 - info: weatherunderground.0 (337) starting. Version 3.7.0 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 17:55:10.618 - info: host.iobroker instance system.adapter.alexa2.0 in version "3.27.3" started with pid 352
      2025-10-26 17:55:13.499 - info: alexa2.0 (352) starting. Version 3.27.3 in /opt/iobroker/node_modules/iobroker.alexa2, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 17:55:13.543 - info: alexa2.0 (352) Starting Alexa2 adapter ... it can take several minutes to initialize all data. Please be patient! A done message is logged.
      2025-10-26 17:55:14.714 - info: host.iobroker instance system.adapter.fullybrowser.0 in version "3.1.2" started with pid 367
      2025-10-26 17:55:17.270 - error: alexa2.0 (352) Error:
      2025-10-26 17:55:17.271 - error: alexa2.0 (352) Error: Please open http://192.168.178.62:34155/ with your browser and login to Amazon. The cookie will be output here after successfull login.
      2025-10-26 17:55:18.793 - info: host.iobroker instance system.adapter.hm-rega.0 in version "5.1.0" started with pid 374
      2025-10-26 17:55:20.644 - error: fullybrowser.0 (367) fullybrowser.0 already running
      2025-10-26 17:55:20.647 - warn: fullybrowser.0 (367) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2025-10-26 17:55:21.263 - error: host.iobroker instance system.adapter.fullybrowser.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2025-10-26 17:55:21.264 - info: host.iobroker Restart adapter system.adapter.fullybrowser.0 because enabled
      2025-10-26 17:55:21.273 - error: hm-rega.0 (374) hm-rega.0 already running
      2025-10-26 17:55:21.277 - warn: hm-rega.0 (374) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2025-10-26 17:55:21.864 - error: host.iobroker instance system.adapter.hm-rega.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2025-10-26 17:55:21.865 - info: host.iobroker Restart adapter system.adapter.hm-rega.0 because enabled
      2025-10-26 17:55:22.629 - info: host.iobroker instance system.adapter.hm-rpc.0 in version "3.0.1" started with pid 389
      2025-10-26 17:55:24.503 - error: hm-rpc.0 (389) hm-rpc.0 already running
      2025-10-26 17:55:24.508 - warn: hm-rpc.0 (389) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2025-10-26 17:55:25.096 - error: host.iobroker instance system.adapter.hm-rpc.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2025-10-26 17:55:25.096 - info: host.iobroker Restart adapter system.adapter.hm-rpc.0 because enabled
      2025-10-26 17:55:26.628 - info: host.iobroker instance system.adapter.hm-rpc.1 in version "3.0.1" started with pid 400
      2025-10-26 17:55:29.156 - error: hm-rpc.1 (400) hm-rpc.1 already running
      2025-10-26 17:55:29.160 - warn: hm-rpc.1 (400) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2025-10-26 17:55:29.748 - error: host.iobroker instance system.adapter.hm-rpc.1 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2025-10-26 17:55:29.748 - info: host.iobroker Restart adapter system.adapter.hm-rpc.1 because enabled
      2025-10-26 17:55:30.640 - info: host.iobroker instance system.adapter.mqtt.0 in version "6.1.4" started with pid 411
      2025-10-26 17:55:31.403 - info: host.iobroker instance system.adapter.admin.0 in version "7.7.16" started with pid 418
      2025-10-26 17:55:33.628 - info: host.iobroker instance system.adapter.javascript.0 in version "9.0.11" started with pid 429
      2025-10-26 17:55:33.945 - error: mqtt.0 (411) mqtt.0 already running
      2025-10-26 17:55:33.957 - warn: mqtt.0 (411) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2025-10-26 17:55:36.528 - error: host.iobroker instance system.adapter.mqtt.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2025-10-26 17:55:36.532 - info: host.iobroker Restart adapter system.adapter.mqtt.0 because enabled
      2025-10-26 17:55:36.694 - info: host.iobroker instance system.adapter.shelly.0 in version "10.4.0" started with pid 440
      2025-10-26 17:55:36.763 - info: host.iobroker instance system.adapter.backitup.0 in version "3.3.10" started with pid 446
      2025-10-26 17:55:39.408 - info: weatherunderground.0 (337) Terminated (NO_ERROR): Without reason
      2025-10-26 17:55:39.904 - info: host.iobroker instance system.adapter.shelly.1 in version "10.4.0" started with pid 462
      2025-10-26 17:55:40.270 - info: host.iobroker instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
      2025-10-26 17:55:41.059 - info: admin.0 (418) starting. Version 7.7.16 in /opt/iobroker/node_modules/iobroker.admin, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 17:55:41.251 - info: admin.0 (418) requesting all objects
      2025-10-26 17:55:44.250 - info: host.iobroker instance system.adapter.sonoff.0 in version "3.3.0" started with pid 482
      2025-10-26 17:55:44.272 - info: javascript.0 (429) starting. Version 9.0.11 in /opt/iobroker/node_modules/iobroker.javascript, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 17:55:44.973 - error: shelly.0 (440) shelly.0 already running
      2025-10-26 17:55:44.989 - warn: shelly.0 (440) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2025-10-26 17:55:45.004 - error: shelly.1 (462) shelly.1 already running
      2025-10-26 17:55:45.017 - warn: shelly.1 (462) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2025-10-26 17:55:45.064 - info: admin.0 (418) received all objects
      2025-10-26 17:55:46.322 - error: host.iobroker instance system.adapter.shelly.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2025-10-26 17:55:46.335 - info: host.iobroker Restart adapter system.adapter.shelly.0 because enabled
      2025-10-26 17:55:46.856 - info: admin.0 (418) socket.io server listening on port 8081
      2025-10-26 17:55:46.866 - info: admin.0 (418) http server listening on port 8081
      2025-10-26 17:55:46.867 - info: admin.0 (418) Use link "http://127.0.0.1:8081" to configure.
      2025-10-26 17:55:47.517 - error: host.iobroker instance system.adapter.shelly.1 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2025-10-26 17:55:47.521 - info: host.iobroker Restart adapter system.adapter.shelly.1 because enabled
      2025-10-26 17:55:47.532 - info: javascript.0 (429) requesting all states
      2025-10-26 17:55:47.535 - info: javascript.0 (429) requesting all objects
      2025-10-26 17:55:47.531 - info: backitup.0 (446) starting. Version 3.3.10 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 17:55:48.122 - info: backitup.0 (446) [iobroker] backup will be activated at 02:40 every 1 day(s)
      2025-10-26 17:55:50.360 - info: javascript.0 (429) received all states
      2025-10-26 17:55:51.519 - info: javascript.0 (429) received all objects
      2025-10-26 17:55:51.767 - info: host.iobroker instance system.adapter.spotify-premium.0 in version "1.5.3" started with pid 522
      2025-10-26 17:55:52.737 - info: host.iobroker instance scheduled system.adapter.tvspielfilm.0 */5 * * * *
      2025-10-26 17:55:52.748 - info: host.iobroker instance system.adapter.tvspielfilm.0 in version "2.1.0" started with pid 529
      2025-10-26 17:55:53.427 - error: sonoff.0 (482) sonoff.0 already running
      2025-10-26 17:55:53.444 - warn: sonoff.0 (482) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2025-10-26 17:55:53.996 - info: host.iobroker instance system.adapter.fullybrowser.0 in version "3.1.2" started with pid 536
      2025-10-26 17:55:54.637 - info: host.iobroker instance system.adapter.hm-rega.0 in version "5.1.0" started with pid 547
      2025-10-26 17:55:55.986 - error: host.iobroker instance system.adapter.sonoff.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2025-10-26 17:55:55.990 - info: host.iobroker Restart adapter system.adapter.sonoff.0 because enabled
      2025-10-26 17:55:57.922 - info: host.iobroker instance system.adapter.yahka.0 in version "1.1.5" started with pid 566
      2025-10-26 17:55:58.243 - info: host.iobroker instance system.adapter.hm-rpc.0 in version "3.0.1" started with pid 573
      2025-10-26 17:56:00.085 - error: spotify-premium.0 (522) spotify-premium.0 already running
      2025-10-26 17:56:00.096 - warn: spotify-premium.0 (522) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2025-10-26 17:56:02.070 - info: host.iobroker instance system.adapter.web.0 in version "7.0.9" started with pid 588
      2025-10-26 17:56:02.157 - error: host.iobroker instance system.adapter.spotify-premium.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2025-10-26 17:56:02.164 - info: host.iobroker Restart adapter system.adapter.spotify-premium.0 because enabled
      2025-10-26 17:56:03.459 - info: host.iobroker instance system.adapter.hm-rpc.1 in version "3.0.1" started with pid 595
      2025-10-26 17:56:04.085 - info: host.iobroker instance system.adapter.vis-2.0 in version "2.13.6" started with pid 602
      2025-10-26 17:56:04.799 - error: yahka.0 (566) yahka.0 already running
      2025-10-26 17:56:04.808 - warn: yahka.0 (566) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2025-10-26 17:56:06.042 - info: javascript.0 (429) script.js.common.Akku_laden_Tablet: start JavaScript (Blockly)
      2025-10-26 17:56:06.133 - info: javascript.0 (429) script.js.common.Akku_laden_Tablet: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
      2025-10-26 17:56:06.285 - error: host.iobroker instance system.adapter.yahka.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2025-10-26 17:56:06.286 - info: host.iobroker Restart adapter system.adapter.yahka.0 because enabled
      2025-10-26 17:56:06.442 - info: javascript.0 (429) script.js.common.Skipte.Licht_Alamierung: start JavaScript (Blockly)
      2025-10-26 17:56:06.508 - info: javascript.0 (429) script.js.common.Skipte.Licht_Alamierung: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
      2025-10-26 17:56:06.509 - info: javascript.0 (429) script.js.common.Skipte.Licht_Alamierung_AUS: start JavaScript (Blockly)
      2025-10-26 17:56:06.526 - info: javascript.0 (429) script.js.common.Skipte.Licht_Alamierung_AUS: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
      2025-10-26 17:56:06.526 - info: javascript.0 (429) script.js.common.Skipte.Longpush_Hoflicht_klein: start JavaScript (Blockly)
      2025-10-26 17:56:06.544 - info: javascript.0 (429) script.js.common.Skipte.Longpush_Hoflicht_klein: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
      2025-10-26 17:56:09.044 - info: host.iobroker instance system.adapter.bring.0 in version "1.9.1" started with pid 621
      2025-10-26 17:56:09.230 - info: host.iobroker instance system.adapter.mqtt.0 in version "6.1.4" started with pid 628
      2025-10-26 17:56:09.573 - error: web.0 (588) web.0 already running
      2025-10-26 17:56:09.585 - warn: web.0 (588) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2025-10-26 17:56:09.655 - info: fullybrowser.0 (536) starting. Version 3.1.2 in /opt/iobroker/node_modules/iobroker.fullybrowser, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 17:56:09.760 - error: vis-2.0 (602) vis-2.0 already running
      2025-10-26 17:56:09.772 - warn: vis-2.0 (602) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2025-10-26 17:56:09.772 - info: fullybrowser.0 (536) 🗸 192.168.178.199 (192.168.178.199): Config successfully verified.
      2025-10-26 17:56:13.778 - error: host.iobroker instance system.adapter.web.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2025-10-26 17:56:13.785 - info: host.iobroker Restart adapter system.adapter.web.0 because enabled
      2025-10-26 17:56:13.785 - error: host.iobroker instance system.adapter.vis-2.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2025-10-26 17:56:13.786 - info: host.iobroker Restart adapter system.adapter.vis-2.0 because enabled
      2025-10-26 17:56:14.508 - info: host.iobroker instance scheduled system.adapter.daswetter.0 /15 * * * *
      2025-10-26 17:56:14.520 - info: host.iobroker instance system.adapter.daswetter.0 in version "3.2.6" started with pid 661
      2025-10-26 17:56:15.836 - info: host.iobroker instance scheduled system.adapter.dwd.0 /5 * * * *
      2025-10-26 17:56:15.857 - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 668
      2025-10-26 17:56:16.026 - info: tvspielfilm.0 (529) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 17:56:16.041 - error: bring.0 (621) bring.0 already running
      2025-10-26 17:56:16.047 - info: hm-rpc.0 (573) starting. Version 3.0.1 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 17:56:16.061 - warn: bring.0 (621) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2025-10-26 17:56:16.344 - info: hm-rega.0 (547) starting. Version 5.1.0 in /opt/iobroker/node_modules/iobroker.hm-rega, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 17:56:17.871 - info: fullybrowser.0 (536) 🚀 Start RESTApi request intervall
      2025-10-26 17:56:18.228 - info: hm-rpc.0 (573) xmlrpc server is trying to listen on 192.168.178.62:42001
      2025-10-26 17:56:18.234 - info: hm-rpc.0 (573) xmlrpc client is trying to connect to 192.168.178.66:42001/ with ["http://192.168.178.62:42001","iobroker:hm-rpc.0:a594111bf7728bd48cfae82d3b16b530"]
      2025-10-26 17:56:18.677 - info: hm-rpc.0 (573) xmlrpc <- system.listMethods ["iobroker:hm-rpc.0:a594111bf7728bd48cfae82d3b16b530"]
      2025-10-26 17:56:18.706 - info: hm-rpc.0 (573) xmlrpc <- listDevices ["iobroker:hm-rpc.0:a594111bf7728bd48cfae82d3b16b530"]
      2025-10-26 17:56:19.321 - error: host.iobroker instance system.adapter.bring.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2025-10-26 17:56:19.322 - info: host.iobroker Restart adapter system.adapter.bring.0 because enabled
      2025-10-26 17:56:19.559 - info: hm-rpc.0 (573) xmlrpc -> 52 devices
      2025-10-26 17:56:19.590 - info: hm-rpc.0 (573) Connected
      2025-10-26 17:56:19.911 - info: tvspielfilm.0 (529) objects written
      2025-10-26 17:56:20.283 - info: host.iobroker instance system.adapter.shelly.0 in version "10.4.0" started with pid 695
      2025-10-26 17:56:20.510 - info: host.iobroker instance system.adapter.shelly.1 in version "10.4.0" started with pid 702
      2025-10-26 17:56:20.660 - info: host.iobroker instance system.adapter.fullcalendar.0 in version "2.4.5" started with pid 709
      2025-10-26 17:56:20.721 - error: daswetter.0 (661) daswetter.0 already running
      2025-10-26 17:56:20.734 - warn: daswetter.0 (661) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2025-10-26 17:56:20.792 - info: hm-rega.0 (547) subscribe hm-rpc.0.BidCoS-RF.50.PRESS_SHORT
      2025-10-26 17:56:20.812 - info: hm-rpc.1 (595) starting. Version 3.0.1 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 17:56:21.412 - info: hm-rega.0 (547) ReGaHSS 192.168.178.66 up
      2025-10-26 17:56:21.803 - info: hm-rpc.1 (595) xmlrpc server is trying to listen on 192.168.178.62:42010
      2025-10-26 17:56:21.803 - error: host.iobroker instance system.adapter.daswetter.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2025-10-26 17:56:21.900 - info: mqtt.0 (628) starting. Version 6.1.4 in /opt/iobroker/node_modules/iobroker.mqtt, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 17:56:22.087 - warn: mqtt.0 (628) No ioBroker changes will be published to the clients. Set the "publish" option in the adapter settings to subscribe for relevant changes.
      2025-10-26 17:56:22.123 - info: hm-rega.0 (547) time difference local-ccu 0s
      2025-10-26 17:56:21.809 - info: hm-rpc.1 (595) xmlrpc client is trying to connect to 192.168.178.66:42010/ with ["http://192.168.178.62:42010","iobroker:hm-rpc.1:bd49cc4978d5af05a1e6049f3cc06d60"]
      2025-10-26 17:56:22.379 - info: hm-rpc.1 (595) Connected
      2025-10-26 17:56:22.416 - info: hm-rpc.1 (595) xmlrpc <- listDevices ["iobroker:hm-rpc.1:bd49cc4978d5af05a1e6049f3cc06d60"]
      2025-10-26 17:56:22.498 - info: mqtt.0 (628) Starting MQTT authenticated server on 0.0.0.0:1886
      2025-10-26 17:56:23.985 - info: hm-rpc.1 (595) xmlrpc -> 0 devices
      2025-10-26 17:56:24.444 - info: host.iobroker instance system.adapter.reolink.0 in version "1.2.3" started with pid 724
      2025-10-26 17:56:24.771 - info: hm-rpc.1 (595) xmlrpc <- newDevices 81
      2025-10-26 17:56:24.996 - info: hm-rpc.1 (595) new HMIP devices/channels after filter: 0
      2025-10-26 17:56:26.182 - info: dwd.0 (668) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 17:56:26.709 - info: hm-rega.0 (547) request state values
      2025-10-26 17:56:28.554 - info: host.iobroker instance system.adapter.sonoff.0 in version "3.3.0" started with pid 751
      2025-10-26 17:56:28.586 - info: host.iobroker instance system.adapter.tankerkoenig.0 in version "3.4.0" started with pid 757
      2025-10-26 17:56:29.232 - error: fullcalendar.0 (709) fullcalendar.0 already running
      2025-10-26 17:56:29.242 - warn: fullcalendar.0 (709) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2025-10-26 17:56:29.276 - error: reolink.0 (724) reolink.0 already running
      2025-10-26 17:56:29.286 - warn: reolink.0 (724) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2025-10-26 17:56:30.023 - error: host.iobroker instance system.adapter.fullcalendar.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2025-10-26 17:56:30.024 - info: host.iobroker Restart adapter system.adapter.fullcalendar.0 because enabled
      2025-10-26 17:56:30.224 - error: host.iobroker instance system.adapter.reolink.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2025-10-26 17:56:30.225 - info: host.iobroker Restart adapter system.adapter.reolink.0 because enabled
      2025-10-26 17:56:31.417 - info: tvspielfilm.0 (529) Terminated (NO_ERROR): Without reason
      2025-10-26 17:56:31.749 - info: host.iobroker instance system.adapter.time-switch.0 in version "2.2.2" started with pid 773
      2025-10-26 17:56:33.177 - info: host.iobroker instance system.adapter.tvspielfilm.0 terminated with code 0 (NO_ERROR)
      2025-10-26 17:56:33.747 - info: host.iobroker instance system.adapter.spotify-premium.0 in version "1.5.3" started with pid 780
      2025-10-26 17:56:35.370 - error: tankerkoenig.0 (757) tankerkoenig.0 already running
      2025-10-26 17:56:35.377 - warn: tankerkoenig.0 (757) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2025-10-26 17:56:35.637 - info: dwd.0 (668) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-10-26 17:56:35.656 - info: shelly.1 (702) starting. Version 10.4.0 in /opt/iobroker/node_modules/iobroker.shelly, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 17:56:35.659 - info: shelly.0 (695) starting. Version 10.4.0 in /opt/iobroker/node_modules/iobroker.shelly, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 17:56:38.098 - error: host.iobroker instance system.adapter.tankerkoenig.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2025-10-26 17:56:38.099 - info: host.iobroker Restart adapter system.adapter.tankerkoenig.0 because enabled
      2025-10-26 17:56:38.262 - info: host.iobroker instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-10-26 17:56:38.500 - info: host.iobroker instance system.adapter.yahka.0 in version "1.1.5" started with pid 814
      2025-10-26 17:56:38.918 - info: shelly.1 (702) Starting in MQTT mode. Listening on 0.0.0.0:1884 (QoS 0)
      2025-10-26 17:56:38.942 - info: hm-rega.0 (547) Updated all datapoints
      2025-10-26 17:56:38.956 - error: time-switch.0 (773) time-switch.0 already running
      2025-10-26 17:56:38.962 - warn: time-switch.0 (773) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2025-10-26 17:56:39.123 - info: hm-rega.0 (547) got 4 variables
      2025-10-26 17:56:39.664 - info: hm-rega.0 (547) added/updated 4 variables
      2025-10-26 17:56:39.665 - info: hm-rega.0 (547) deleted 0 variables
      2025-10-26 17:56:39.829 - info: hm-rega.0 (547) got 0 programs
      2025-10-26 17:56:39.914 - error: host.iobroker instance system.adapter.time-switch.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2025-10-26 17:56:39.921 - info: shelly.0 (695) Starting in CoAP mode. Listening on 0.0.0.0:5683
      2025-10-26 17:56:39.915 - info: host.iobroker Restart adapter system.adapter.time-switch.0 because enabled
      2025-10-26 17:56:39.969 - info: sonoff.0 (751) starting. Version 3.3.0 in /opt/iobroker/node_modules/iobroker.sonoff, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 17:56:39.996 - info: hm-rega.0 (547) added/updated 0 programs
      2025-10-26 17:56:39.997 - info: hm-rega.0 (547) deleted 0 programs
      2025-10-26 17:56:40.088 - info: sonoff.0 (751) Starting MQTT authenticated server on port 1883
      2025-10-26 17:56:40.106 - info: shelly.0 (695) [CoAP Server] Listening for packets in the network
      2025-10-26 17:56:40.153 - info: hm-rega.0 (547) update rooms to enum.rooms
      2025-10-26 17:56:40.503 - info: hm-rega.0 (547) update functions to enum.functions
      2025-10-26 17:56:40.631 - info: hm-rega.0 (547) update favorites to enum.favorites
      2025-10-26 17:56:40.755 - info: vis.0 (791) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.vis, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 17:56:41.866 - info: spotify-premium.0 (780) starting. Version 1.5.3 in /opt/iobroker/node_modules/iobroker.spotify-premium, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 17:56:42.189 - info: shelly.0 (695) [CoAP] Device 192.168.178.180 (shellyswitch / shellyswitch-9F6085 / SHSW-21#9F6085#1) connected! Polltime set to 15 sec.
      2025-10-26 17:56:42.286 - error: spotify-premium.0 (780) Client_ID is not filled
      2025-10-26 17:56:42.478 - info: shelly.0 (695) [CoAP] Device 192.168.178.181 (shelly1 / shelly1-DC4F2277189D / SHSW-1#DC4F2277189D#1) connected! Polltime set to 15 sec.
      2025-10-26 17:56:43.440 - info: yahka.0 (814) starting. Version 1.1.5 in /opt/iobroker/node_modules/iobroker.yahka, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 17:56:43.494 - info: yahka.0 (814) adapter ready, checking config
      2025-10-26 17:56:43.548 - info: yahka.0 (814) adding Hoflicht with UUID: 0f446216-bcd1-4947-8a27-4995a05e57e3
      2025-10-26 17:56:43.562 - info: yahka.0 (814) adding Badezimmer with UUID: a1926ead-1ee6-4787-aa57-908d60ab133f
      2025-10-26 17:56:43.566 - info: yahka.0 (814) adding Badezimmer Groß with UUID: 010169d6-fb61-4abb-8cbd-b6baf1d62f35
      2025-10-26 17:56:43.570 - info: yahka.0 (814) adding Garten with UUID: 03f31a32-ff4c-4802-ae24-cd2b2fdb2cb8
      2025-10-26 17:56:43.573 - info: yahka.0 (814) adding Scheune with UUID: cad15d02-4aad-4578-a940-3f20e525c4d7
      2025-10-26 17:56:43.577 - info: yahka.0 (814) publishing bridge Yahka0 on 0.0.0.0 using avahi
      2025-10-26 17:56:44.627 - info: sonoff.0 (751) Client [4Kanal] connected with secret 1761497804618_6431
      2025-10-26 17:56:45.283 - info: host.iobroker instance system.adapter.web.0 in version "7.0.9" started with pid 843
      2025-10-26 17:56:45.305 - info: host.iobroker instance system.adapter.vis-2.0 in version "2.13.6" started with pid 849
      2025-10-26 17:56:46.141 - info: vis.0 (791) Terminated (NO_ERROR): Without reason
      2025-10-26 17:56:46.874 - info: host.iobroker instance system.adapter.vis.0 terminated while should be started once
      2025-10-26 17:56:49.585 - info: shelly.0 (695) [CoAP] Device 192.168.178.183 (shelly1 / shelly1-DC4F227718A9 / SHSW-1#DC4F227718A9#1) connected! Polltime set to 15 sec.
      2025-10-26 17:56:50.373 - info: host.iobroker instance system.adapter.bring.0 in version "1.9.1" started with pid 865
      2025-10-26 17:56:51.716 - info: shelly.1 (702) [MQTT] Device with client id "shelly2pmg3-8cbfea94ad7c" connected from 192.168.178.85!
      2025-10-26 17:56:51.931 - info: shelly.0 (695) [CoAP] Device 192.168.178.182 (shellyswitch25 / shellyswitch25-687959 / SHSW-25#687959#1) connected! Polltime set to 15 sec.
      2025-10-26 17:56:52.609 - info: vis-2.0 (849) starting. Version 2.13.6 in /opt/iobroker/node_modules/iobroker.vis-2, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 17:56:52.910 - info: web.0 (843) starting. Version 7.0.9 in /opt/iobroker/node_modules/iobroker.web, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 17:56:53.358 - info: mqtt.0 (628) Client [Schalter_Alamierung_0] connected with secret 1761497813333_8604
      2025-10-26 17:56:53.459 - info: vis-2.0 (849) vis-2 license is OK.
      2025-10-26 17:56:53.645 - info: mqtt.0 (628) Client [Schalter_Alamierung_0] subscribes on "Schalter Alamierung/#" with regex /^Schalter_Alamierung..
      2025-10-26 17:56:53.660 - info: mqtt.0 (628) Client [Schalter_Alamierung_0] subscribes on "Schalter Alamierung/#" with regex /^mqtt.0.Schalter_Alamierung..
      2025-10-26 17:56:53.861 - info: mqtt.0 (628) Client [Schalter_Alamierung_0] publishOnSubscribe send all known states
      2025-10-26 17:56:54.700 - info: web.0 (843) socket.io server listening on port 8082
      2025-10-26 17:56:54.752 - info: web.0 (843) http server listening on port 8082
      2025-10-26 17:56:56.211 - info: bring.0 (865) starting. Version 1.9.1 in /opt/iobroker/node_modules/iobroker.bring, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 17:56:57.514 - info: bring.0 (865) [LOGIN] Successfully logged in as Jan
      2025-10-26 17:57:01.132 - info: host.iobroker instance system.adapter.fullcalendar.0 in version "2.4.5" started with pid 890
      2025-10-26 17:57:01.193 - info: host.iobroker instance system.adapter.reolink.0 in version "1.2.3" started with pid 897
      2025-10-26 17:57:01.915 - info: shelly.1 (702) [MQTT] Client Close: 192.168.178.85 (shelly2pmg3 / shelly2pmg3-8cbfea94ad7c / shelly2pmg3#8cbfea94ad7c#1) (false)
      2025-10-26 17:57:01.986 - error: shelly.1 (702) [MQTT] Error in function setMqttPrefixHttp (Gen 1) for client undefined: TypeError: Cannot read properties of undefined (reading 'replace')
      2025-10-26 17:57:01.992 - error: shelly.1 (702) [MQTT] Unable to get mqttprefix of client with id "shelly2pmg3-8cbfea94ad7c"
      2025-10-26 17:57:04.855 - info: reolink.0 (897) starting. Version 1.2.3 in /opt/iobroker/node_modules/iobroker.reolink, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 17:57:04.887 - info: reolink.0 (897) Reolink adapter has started
      2025-10-26 17:57:04.892 - info: reolink.0 (897) Current IP: 192.168.178.82
      2025-10-26 17:57:04.953 - info: fullcalendar.0 (890) starting. Version 2.4.5 in /opt/iobroker/node_modules/iobroker.fullcalendar, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 17:57:07.004 - info: reolink.0 (897) State value to set for "reolink.0.settings.EmailNotification" has to be type "number" but received type "string"
      2025-10-26 17:57:07.043 - info: reolink.0 (897) Changed state: EmailNotification
      2025-10-26 17:57:07.043 - error: reolink.0 (897) Set mail notification: Value not supported!
      2025-10-26 17:57:08.702 - info: host.iobroker instance system.adapter.tankerkoenig.0 in version "3.4.0" started with pid 920
      2025-10-26 17:57:10.549 - info: host.iobroker instance system.adapter.time-switch.0 in version "2.2.2" started with pid 931
      2025-10-26 17:57:11.637 - info: tankerkoenig.0 (920) starting. Version 3.4.0 in /opt/iobroker/node_modules/iobroker.tankerkoenig, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 17:57:11.704 - info: tankerkoenig.0 (920) Adapter is already in daemon mode
      2025-10-26 17:57:11.706 - warn: tankerkoenig.0 (920) Sync time was too short (5). New sync time is 10 min
      2025-10-26 17:57:11.707 - info: tankerkoenig.0 (920) Sync time set to 10 minutes or 600000 ms
      2025-10-26 17:57:13.623 - info: time-switch.0 (931) starting. Version 2.2.2 in /opt/iobroker/node_modules/iobroker.time-switch, node: v20.18.2, js-controller: 7.0.7
      2025-10-26 17:57:18.530 - info: tankerkoenig.0 (920) Start first request
      2025-10-26 17:57:58.243 - info: shelly.1 (702) [MQTT] Device with client id "shelly2pmg3-8cbfea94ad7c" connected from 192.168.178.85!
      Thomas Braun crunchip 2 Replies Last reply Reply Quote 0
        Thomas Braun Most Active @Jan201 last edited by
        @jan201
        Was sagt und denn nun
        iob diag
          crunchip Forum Testing Most Active @Jan201 last edited by crunchip
          @jan201 habs jetzt nur grob am Handy überflogen
          Zumindest stimmt etwas mit dem daswetter Adapter nicht und dein alexa2 Adapter.
          Nicht das dir aufgrund von diversen Problemen der Ram ausgeht.
            Jan201 @Thomas Braun last edited by
            Ich habe mich versucht über putty anzumelden. Aber auch hier scheine ich das falsche Passwort aufgeschrieben zu haben. Jedenfalls ist es nicht das selbe welches ich auf der Weboberfläche nutze. Port 22 ist doch richtig oder?
              @jan201
              Das ist das Passwort zur Anmeldung beim Betriebssystem. Das hat mit ioBroker und irgendeiner Weboberfläche nix zu tun.
                Jan201 @Thomas Braun last edited by Jan201
                Ja und das muss ich auch falsch notiert haben. Ebenso das welches ich bei Proxmoxx brauche.
                das ist über das terminal auf der weboberfläche raus gekommen:
                /opt/iobroker$ iob diag
                TERM environment variable not set.
                *** iob diag is starting up, please wait ***
                107*** ioBroker Diagnosis ***
                Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
                The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
                https://forum.iobroker.net
                Just copy and paste the Summary Page, including the ``` characters at start and end.
                It helps us to help you!
                • Some output is masked. For full results please use 'iob diag --unmask' *
                Press any key to continue
                Thomas Braun Meister Mopper 2 Replies Last reply Reply Quote 0
                  @jan201
                  Dann 'press mal den any key'.
                  • Meister Mopper
                    Meister Mopper @Jan201 last edited by
                    @jan201 sagte in Iobroker nach Update nicht erreichbar:
                    Für mich gilt die Regel:
                    Je komplexer das System wird, desto genauer muss die Dokumentation und deren Pflege sein, denn es gibt fast täglich Anpassungen und Änderungen, die vom menschlichen Erinnerungsvermögen kaum zu bewältigen sind.
                    Meine Empfehlung:
                    Schaff dir ein Doku-System an und halte es auf Stand.
                      /opt/iobroker$ iob diag --unmask
                      ========== Start marking the full check here ===========
                      Script v.2025-08-09
                      107*** BASE SYSTEM ***
                      Static hostname: iobroker
                             Icon name: computer-container
                               Chassis: container ☐
                        Virtualization: lxc
                                Kernel: Linux 6.8.12-7-pve
                          Architecture: x86-64
                      OS is similar to:
                      model name    : Intel(R) Celeron(R) CPU J3455 @ 1.50GHz
                      Docker          : false
                      Virtualization  : lxc
                      Kernel          : x86_64
                      Userland        : 64 bit
                      Systemuptime and Load:
                      18:37:40 up 1 day, 42 min,  0 user,  load average: 0.14, 0.47, 0.42
                      CPU threads: 2
                      107*** LIFE CYCLE STATUS ***
                      Operating System is the current Debian stable version codenamed 'bookworm'!
                      107*** TIME AND TIMEZONES ***
                                     Local time: Mon 2025-10-27 18:37:40 CET
                                 Universal time: Mon 2025-10-27 17:37:40 UTC
                                       RTC time: n/a
                                    NTP service: inactive
                                RTC in local TZ: no
                      107*** Users and Groups ***
                      User that called 'iob diag':
                      iobroker
                      HOME=/home/iobroker
                      GROUPS=iobroker tty dialout audio video plugdev
                      iobroker
                      HOME=/home/iobroker
                      A default user should be created! This user will be enabled to temporarily switch to root via 'sudo'!
                      A root login is not required in most Linux Distributions.
                      Run 'iobroker fix' or use the system tools to create a user.
                      107*** DISPLAY-SERVER SETUP ***
                      Display-Server:     false
                      Unit display-manager.service could not be found.
                      Display-Manager:
                      Desktop:
                      Session:
                      107*** MEMORY ***
                      Mem:            2.1G        1.7G        224M         32K        239M        464M
                      Swap:           536M        455M         81M
                      Total:          2.7G        2.1G        306M
                      Active iob-Instances:     22
                               2048 M total memory
                               1605 M used memory
                                622 M active memory
                               1105 M inactive memory
                                213 M free memory
                                  0 M buffer memory
                                228 M swap cache
                                512 M total swap
                                433 M used swap
                                 78 M free swap
                      107*** top - Table Of Processes  ***
                      top - 18:37:41 up 1 day, 42 min,  0 user,  load average: 0.21, 0.48, 0.43
                      Tasks:  45 total,   1 running,  44 sleeping,   0 stopped,   0 zombie
                      %Cpu(s): 33.3 us, 33.3 sy,  0.0 ni, 33.3 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                      MiB Mem :   2048.0 total,    211.9 free,   1607.6 used,    228.5 buff/cache
                      MiB Swap:    512.0 total,     78.1 free,    433.9 used.    440.4 avail Mem
                      107*** FAILED SERVICES ***
                      0 loaded units listed.
                      107*** DMESG CRITICAL ERRORS ***
                      sudo: a terminal is required to read the password; either use the -S option to read from standard input or configure an askpass helper
                      sudo: a password is required
                      No critical errors detected
                      107*** FILESYSTEM ***
                      Filesystem                       Type      Size  Used Avail Use% Mounted on
                      /dev/mapper/pve-vm--100--disk--0 ext4       24G  6.8G   16G  31% /
                      none                             tmpfs     492K  4.0K  488K   1% /dev
                      udev                             devtmpfs  3.8G     0  3.8G   0% /dev/tty
                      tmpfs                            tmpfs     3.9G     0  3.9G   0% /dev/shm
                      tmpfs                            tmpfs     1.6G  104K  1.6G   1% /run
                      tmpfs                            tmpfs     5.0M     0  5.0M   0% /run/lock
                      Show mounted filesystems:
                      TARGET SOURCE                           FSTYPE OPTIONS
                      /      /dev/mapper/pve-vm--100--disk--0 ext4   rw,relatime,stripe=16
                      /var:
                      Archived and active journals take up 56.0M in the file system.
                      /opt/iobroker/backups:
                      659M    /opt/iobroker/backups/
                      /opt/iobroker/iobroker-data:
                      731M    /opt/iobroker/iobroker-data/
                      611M    /opt/iobroker/iobroker-data/files
                      217M    /opt/iobroker/iobroker-data/files/vis
                      210M    /opt/iobroker/iobroker-data/files/vis/widgets
                      115M    /opt/iobroker/iobroker-data/files/vis-2
                      30M    /opt/iobroker/iobroker-data/objects.jsonl
                      27M    /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
                      20M    /opt/iobroker/iobroker-data/files/fullcalendar.admin/static/js/main.c13d3761.js.map
                      9.8M    /opt/iobroker/iobroker-data/files/vis-2/material-icons/knx-uf.json
                      9.2M    /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js
                      USB-Devices by-id:
                      No Devices found 'by-id'
                      Zigbee Network Settings on your coordinator/in nvbackup are:
                      zigbee.X
                      Extended Pan ID:
                      *** MASKED ***
                      Pan ID:
                      *** MASKED ***
                      Channel:
                      *** MASKED ***
                      Network Key:
                      *** MASKED ***
                      To unmask the settings run 'iob diag --unmask'
                      107*** NodeJS-Installation ***
                      /usr/bin/nodejs     v20.18.2
                      /usr/bin/node         v20.18.2
                      /usr/bin/npm         10.8.2
                      /usr/bin/npx         10.8.2
                      /usr/bin/corepack     0.29.4
                      nodejs:
                        Installed: 20.18.2-1nodesource1
                        Candidate: 20.19.5-1nodesource1
                        Version table:
                           20.19.5-1nodesource1 1001
                              500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                           20.19.4-1nodesource1 1001
                           20.19.3-1nodesource1 1001
                           20.19.2-1nodesource1 1001
                           20.19.1-1nodesource1 1001
                           20.19.0-1nodesource1 1001
                           20.18.3-1nodesource1 1001
                      *** 20.18.2-1nodesource1 1001
                              100 /var/lib/dpkg/status
                           20.18.1-1nodesource1 1001
                           20.18.0-1nodesource1 1001
                           20.17.0-1nodesource1 1001
                           20.16.0-1nodesource1 1001
                           20.15.1-1nodesource1 1001
                           20.15.0-1nodesource1 1001
                           20.14.0-1nodesource1 1001
                           20.13.1-1nodesource1 1001
                           20.13.0-1nodesource1 1001
                           20.12.2-1nodesource1 1001
                           20.12.1-1nodesource1 1001
                           20.12.0-1nodesource1 1001
                           20.11.1-1nodesource1 1001
                           20.11.0-1nodesource1 1001
                           20.10.0-1nodesource1 1001
                           20.9.0-1nodesource1 1001
                           20.8.1-1nodesource1 1001
                           20.8.0-1nodesource1 1001
                           20.7.0-1nodesource1 1001
                           20.6.1-1nodesource1 1001
                           20.6.0-1nodesource1 1001
                           20.5.1-1nodesource1 1001
                           20.5.0-1nodesource1 1001
                           20.4.0-1nodesource1 1001
                           20.3.1-1nodesource1 1001
                           20.3.0-1nodesource1 1001
                           20.2.0-1nodesource1 1001
                           20.1.0-1nodesource1 1001
                           20.0.0-1nodesource1 1001
                           18.20.4+dfsg-1~deb12u1 500
                              500 http://deb.debian.org/debian bookworm/main amd64 Packages
                              500 http://security.debian.org bookworm-security/main amd64 Packages
                      No problems detected
                      Errors in npm tree: 0
                      Checking for nodejs vulnerability:
                      The current Node.js version (v20.18.2) is vulnerable to the following CVEs:
                      CVE-2025-23166(high):  The C++ method SignTraits::DeriveBits() may incorrectly call ThrowException() based on user-supplied inputs when executing in a background thread, crashing the Node.js process. Such cryptographic operations are commonly applied to untrusted inputs. Thus, this mechanism potentially allows an adversary to remotely crash a Node.js runtime.
                      Patched versions: ^20.19.2 || ^22.15.1 || ^23.11.1 || ^24.0.2
                      CVE-2025-23167(medium): A flaw in Node.js 20's HTTP parser allows improper termination of HTTP/1 headers using `\r\n\rX` instead of the required `\r\n\r\n`.
                      This inconsistency enables request smuggling, allowing attackers to bypass proxy-based access controls and submit unauthorized requests.
                      The issue was resolved by upgrading `llhttp` to version 9, which enforces correct header termination.
                      Impact:
                      * This vulnerability affects only Node.js 20.x users prior to the `llhttp` v9 upgrade.
                      107*** ioBroker-Installation ***
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Hosts:
                      iobroker            iobroker (version: 7.0.7, hostname: iobroker      , alive, uptime: 88990)
                      Core adapters versions
                      admin:         7.7.19
                      javascript:     9.0.11
                      nodejs modules from github:     0
                      Adapter State
                      + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                      + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                      + system.adapter.bring.0                  : bring                 : iobroker                                 -  enabled
                        system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
                        system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
                        system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
                        system.adapter.energiefluss.0           : energiefluss          : iobroker                                 - disabled
                        system.adapter.eventlist.0              : eventlist             : iobroker                                 - disabled
                        system.adapter.flot.0                   : flot                  : iobroker                                 - disabled
                      + system.adapter.fullcalendar.0           : fullcalendar          : iobroker                                 -  enabled
                      + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
                        system.adapter.history.0                : history               : iobroker                                 - disabled
                      + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
                      + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                      + system.adapter.hm-rpc.1                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                        system.adapter.ical.0                   : ical                  : iobroker                                 - disabled
                        system.adapter.icons-icons8.0           : icons-icons8          : iobroker                                 - disabled
                        system.adapter.icons-material-png.0     : icons-material-png    : iobroker                                 - disabled
                        system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
                        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
                      + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                        system.adapter.mihome-vacuum.0          : mihome-vacuum         : iobroker                                 - disabled, port: 54321
                        system.adapter.mqtt-client.0            : mqtt-client           : iobroker                                 - disabled, port: 1884
                      + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
                      + system.adapter.reolink.0                : reolink               : iobroker                                 -  enabled
                        system.adapter.ring.0                   : ring                  : iobroker                                 - disabled
                      + system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
                      + system.adapter.shelly.1                 : shelly                : iobroker                                 -  enabled, port: 1884, bind: 0.0.0.0
                      + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                        system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 - disabled
                      + system.adapter.spotify-premium.0        : spotify-premium       : iobroker                                 -  enabled
                      + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
                      + system.adapter.terminal.0               : terminal              : iobroker                                 -  enabled, port: 8088, bind: 0.0.0.0, run as: admin
                      + system.adapter.time-switch.0            : time-switch           : iobroker                                 -  enabled
                        system.adapter.tr-064.0                 : tr-064                : iobroker                                 - disabled
                        system.adapter.trashschedule.0          : trashschedule         : iobroker                                 - disabled
                        system.adapter.tvspielfilm.0            : tvspielfilm           : iobroker                                 -  enabled
                        system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : iobroker                                 - disabled
                        system.adapter.vis-2-widgets-icontwo.0  : vis-2-widgets-icontwo : iobroker                                 -  enabled
                        system.adapter.vis-2-widgets-inventwo.0 : vis-2-widgets-inventwo: iobroker                                 - disabled
                        system.adapter.vis-2-widgets-jaeger-design.0: vis-2-widgets-jaeger-design: iobroker                                 - disabled
                        system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: iobroker                                 - disabled
                        system.adapter.vis-2-widgets-weather-and-heating.0: vis-2-widgets-weather-and-heating: iobroker                                 - disabled
                      + system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
                        system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 - disabled
                        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
                        system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
                        system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 - disabled
                        system.adapter.vis-metro.0              : vis-metro             : iobroker                                 - disabled
                        system.adapter.vis-players.0            : vis-players           : iobroker                                 - disabled
                        system.adapter.vis-plumb.0              : vis-plumb             : iobroker                                 - disabled
                        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
                        system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
                        system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                        system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
                      + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                      + system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled
                      + instance is alive
                      ioBroker-Repositories
                      Active repo(s): beta
                      Upgrade policy: none
                      Installed ioBroker-Adapters
                      Used repository: beta
                      Adapter    "admin"        : 7.7.19   , installed 7.7.19
                      Adapter    "backitup"     : 3.3.10   , installed 3.3.10
                      Adapter    "bring"        : 1.9.1    , installed 1.9.1
                      Adapter    "daswetter"    : 3.2.6    , installed 3.2.6
                      Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
                      Adapter    "eventlist"    : 2.1.0    , installed 2.1.0
                      Adapter    "fullcalendar" : 2.4.5    , installed 2.4.5
                      Adapter    "fullybrowser" : 3.1.2    , installed 3.1.2
                      Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
                      Adapter    "hm-rpc"       : 3.0.1    , installed 3.0.1
                      Adapter    "ical"         : 1.18.1   , installed 1.18.1
                      Adapter    "javascript"   : 9.0.11   , installed 9.0.11
                      Controller "js-controller": 7.0.7    , installed 7.0.7
                      Adapter    "mihome-vacuum": 5.3.0    , installed 5.3.0
                      Adapter    "mqtt"         : 6.1.4    , installed 6.1.4
                      Adapter    "mqtt-client"  : 3.0.0    , installed 3.0.0
                      Adapter    "reolink"      : 1.2.3    , installed 1.2.3
                      Adapter    "ring"         : 6.4.0    , installed 6.4.0
                      Adapter    "shelly"       : 10.4.0   , installed 10.4.0
                      Adapter    "socketio"     : 7.0.8    , installed 7.0.8
                      Adapter    "sonoff"       : 3.3.0    , installed 3.3.0
                      Adapter    "sourceanalytix": 0.4.14  , installed 0.4.14
                      Adapter    "spotify-premium": 1.5.3  , installed 1.5.3
                      Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                      Adapter    "terminal"     : 1.0.0    , installed 1.0.0
                      Adapter    "time-switch"  : 2.2.2    , installed 2.2.2
                      Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
                      Adapter    "trashschedule": 4.0.1    , installed 4.0.1
                      Adapter    "tvspielfilm"  : 2.1.0    , installed 2.1.0
                      Adapter    "vis-2"        : 2.13.6   , installed 2.13.6
                      Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
                      Adapter    "vis-2-widgets-icontwo": 1.17.0, installed 1.17.0
                      Adapter    "vis-2-widgets-inventwo": 0.3.9, installed 0.3.9
                      Adapter    "vis-2-widgets-jaeger-design": 1.4.9, installed 1.4.9
                      Adapter    "vis-2-widgets-material": 1.6.0, installed 1.6.0
                      Adapter    "vis-2-widgets-weather-and-heating": 1.1.5, installed 1.1.5
                      Adapter    "vis-hqwidgets": 1.6.0    , installed 1.6.0
                      Adapter    "vis-icontwo"  : 1.18.0   , installed 1.18.0
                      Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
                      Adapter    "vis-weather"  : 2.5.13   , installed 2.5.13
                      Adapter    "weatherunderground": 3.7.0, installed 3.7.0
                      Adapter    "web"          : 7.0.9    , installed 7.0.9
                      Adapter    "ws"           : 3.0.19   , installed 3.0.19
                      Adapter    "yahka"        : 1.1.5    , installed 1.1.5
                      Objects and States
                      Objects:     11191
                      States:     9892
                      107*** OS-Repositories and Updates ***
                      Hit:1 http://security.debian.org bookworm-security InRelease
                      Hit:2 http://deb.debian.org/debian bookworm InRelease
                      Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                      Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                      Reading package lists...
                      Pending Updates: 127
                      107*** Listening Ports ***
                      107*** Log File - Last 25 Lines ***
                      2025-10-27 18:34:58.251  - info: host.iobroker iobroker host.iobroker object system.adapter.terminal.0.eventLoopLag created
                      2025-10-27 18:34:58.260  - info: host.iobroker iobroker host.iobroker object system.adapter.terminal.0.sigKill created
                      2025-10-27 18:34:58.270  - info: host.iobroker iobroker host.iobroker object system.adapter.terminal.0.logLevel created
                      2025-10-27 18:34:58.280  - info: host.iobroker iobroker host.iobroker object system.adapter.terminal.upload created
                      2025-10-27 18:34:58.286  - info: host.iobroker iobroker host.iobroker object terminal.0.info created
                      2025-10-27 18:34:58.293  - info: host.iobroker iobroker host.iobroker object terminal.0.info.connection created
                      2025-10-27 18:34:58.300  - info: host.iobroker iobroker host.iobroker Set default value of terminal.0.info.connection: false
                      2025-10-27 18:34:58.311  - info: host.iobroker iobroker host.iobroker object system.adapter.terminal.0 created
                      2025-10-27 18:34:59.401  - info: host.iobroker iobroker exit 0
                      2025-10-27 18:35:01.946  - info: host.iobroker instance system.adapter.terminal.0 in version "1.0.0" started with pid 24209
                      2025-10-27 18:35:02.139  - info: admin.0 (23809) ==> Connected system.user.admin from ::ffff:192.168.178.70
                      2025-10-27 18:35:04.925  - info: terminal.0 (24209) starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.terminal, node: v20.18.2, js-controller: 7.0.7
                      2025-10-27 18:35:04.990  - info: terminal.0 (24209) http server listening on port 8088
                      2025-10-27 18:35:09.040  - info: host.iobroker instance system.adapter.dwd.0 in version "2.8.5" started with pid 24226
                      2025-10-27 18:35:09.682  - info: admin.0 (23809) <== Disconnect system.user.admin from ::ffff:192.168.178.70
                      2025-10-27 18:35:11.491  - info: dwd.0 (24226) starting. Version 2.8.5 in /opt/iobroker/node_modules/iobroker.dwd, node: v20.18.2, js-controller: 7.0.7
                      2025-10-27 18:35:12.208  - info: dwd.0 (24226) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      2025-10-27 18:35:12.747  - info: host.iobroker instance system.adapter.dwd.0 having pid 24226 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      2025-10-27 18:35:21.040  - info: host.iobroker instance system.adapter.tvspielfilm.0 in version "2.1.0" started with pid 24243
                      2025-10-27 18:35:23.702  - info: tvspielfilm.0 (24243) starting. Version 2.1.0 in /opt/iobroker/node_modules/iobroker.tvspielfilm, node: v20.18.2, js-controller: 7.0.7
                      2025-10-27 18:35:25.773  - info: tvspielfilm.0 (24243) objects written
                      2025-10-27 18:35:36.282  - info: tvspielfilm.0 (24243) Terminated (NO_ERROR): Without reason
                      2025-10-27 18:35:36.813  - info: host.iobroker instance system.adapter.tvspielfilm.0 having pid 24243 terminated with code 0 (NO_ERROR)
                      2025-10-27 18:38:40.886  - info: admin.0 (23809) <== Disconnect system.user.admin from ::ffff:192.168.178.70 admin
                      2025-10-27 18:38:42.593  - info: admin.0 (23809) ==> Connected system.user.admin from ::ffff:192.168.178.70
                      iob diag has finished.
                      crunchip Thomas Braun 2 Replies Last reply Reply Quote 0
                        107*** MEMORY *** total used free shared buff/cache available Mem: 2.1G 1.7G 224M 32K 239M 464M Swap: 536M 455M 81M Total: 2.7G 2.1G 306M
                        wie schon vermutet, der Ram geht dir aus, daher die die vielen Neustarts deiner Prozesse
                        und wie oben schon
                          Bring das auf das aktuelle stable release.
                          Leg dir einen eigenen user an mit dem du durch das System springst. Und merk dir dessen PW.
                          Gib dem System mehr Luft, 2,1GB RAM ist zu wenig.
                          sudo scheint nicht richtig eingerichtet zu sein.
                          Bring nodejs auf Version 22.
                          Bring das System insgesamt auf Stand. Und kümmer dich regelmäßiger darum es auch auf Stand zu halten.
                            Ich werde die Festplatte vom nuc einmal leer machen und Proxmox und Iobroker unter Debian neu installieren. Ohne Passwörter macht das keinen Sinn. Auf dem NUC läuft nur Iobroker.
                            Wieviel RAM wäre denn optimal?
                            Wenn ich unter "Backitup" ein Backup mache, sichert er mir dann alles? Also die Adapter und VIS?
                              Thomas Braun Most Active @Jan201 last edited by Thomas Braun
                              Mindestens 4GB. Mehr ist immer besser...
                              Ja, aber ich würde zuvor das Alt-System möglichst nah an einen frisch installierten ioBroker heranfahren.
                              Also nodejs@22 und alle Adapter auf dem neusten Stand. Und davon ein Backitup-Backup ziehen.
                              Mach die Installation danach:
                              https://www.iobroker.net/#de/documentation/install/proxmox.md
                                Proxmox und Debian sind nun Installiert. Unter Proxmox > VM100 > Konsole wird mit nun aber eine Oberfläche angezeigt. Ist das richtig?
                                Auf was ist es denn besser IoBroker zu installieren, in einer VM oder CT?
                                Thomas Braun wendy2702 2 Replies Last reply Reply Quote 0
                                  @jan201
                                  Wenn ich Proxmox verwenden würde, dann würde ich das in einen LXC verfrachten.
                                  • wendy2702
                                    wendy2702 @Jan201 last edited by
                                    @jan201 bist du der Anleitung aus dem Link gefolgt ?
                                      crunchip Forum Testing Most Active @wendy2702 last edited by
                                      @wendy2702 scheinbar nicht, zumindest nicht aufmerksam genug.
                                      Und auf die Frage VM oder LXC... Ist Geschmackssache und hängt immer von den Gegebenheiten eines Einzelnen ab.
                                      31
                                      631
