    4. JavaScript
    5. Skript für Mondphase, Mondauf- und Untergang
    • Ro75
      Ro75 @Nashra last edited by
      @nashra ich habe meins mal exportiert.
      [{"tpl":"tplValueStringImg","data":{"oid":"alias.0.Wetter.Icon_Mond","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide"},"style":{"left":"1464px","top":"275px","width":"130px","height":"130px","z-index":"7"},"widgetSet":"basic"}]
      Kannst es importieren. Passe ggfs. den Datenpunkt an.
      Ro75.
      Nashra 1 Reply Last reply Reply Quote 1
      • Nashra
        Nashra Most Active Forum Testing @Ro75 last edited by
        @ro75
        Das ist das basic-string-img-src, daran hatte ich gar nicht gedacht 🤦‍♂️
        Naja, jetzt wird es angezeigt. Danke
        Da schaut man sich 100 mal die Widget-Liste an und sieht es trotzdem nicht 😬
          Micha 3 last edited by Micha 3
          @ro75 sagte in Skript für Mondphase, Mondauf- und Untergang:
          Zeilen 17 und 18 muss von dir an deine Position angepasst werden!
          Holt sich das suncalc nicht automatisch über die Systemeinstellung?
          Ro75 1 Reply Last reply Reply Quote 0
          • Ro75
            Ro75 @Micha 3 last edited by
            @micha-3 nein
            Ro75
            • Ro75
              Ro75 last edited by
              Ab Zeile 103 gibt es Neuerungen und Änderungen im Skript. Der Wert für die Mondbeleuchtung wird jetzt auch mittels "suncalc" ermittelt.
              Ro75.
              • Nashra
                @Ro75
                Schmeißt mir einen Error
                javascript.0	09:57:01.843	info	Start JavaScript script.js.Wetter.Mondphase-Ro75 (Javascript/js)
                javascript.0	09:57:01.859	error	script.js.Wetter.Mondphase-Ro75: ReferenceError: fRundenM is not defined
                javascript.0	09:57:01.859	error	at MondBeleuchtung (script.js.Wetter.Mondphase-Ro75:116:20)
                javascript.0	09:57:01.860	error	at script.js.Wetter.Mondphase-Ro75:125:1
                javascript.0	09:57:01.860	error	at script.js.Wetter.Mondphase-Ro75:132:3
                • Ro75
                  @nashra Da fehlte eine Funktion. Ich habe bei mir ein paar Globale Funktionen, da ich diese immer wieder an diversen Stellen benutze, Die Funktion "fRundenM" ist jetzt mit im Skript enthalten.
                  Ro75.
                  Walter.O. 1 Reply Last reply Reply Quote 1
                  • Walter.O.
                    Walter.O. @Ro75 last edited by
                    @ro75 Ist das hier noch Aktuell?
                    Bekommt ich noch eine Antwort auf meine Fragen?
                    Ich kann diesen Alias so wie du Ihn Beschreibst nicht Anlegen, Alias Manager v2.0.0
                    Ich kenne mich mit dem Alias Manager nicht wirklich aus.
                    0_userdata.0.Wetter. habe ich per Hand angelegt
                    Das Kopierte und angepasste Script legt aber keine Datenpunkte an Z.b.:
                    createState(DPMond+'MondphaseIcon', 0, {name: 'MondphaseIcon' ,type: 'number', read: true, write: true});
                    Fehler meldung:
                    script.js.common.Mondphasen compile failed:
                    at script.js.common.Mondphasen:19
                    Danke für deine Hilfe
                    Ro75 Homoran 3 Replies Last reply Reply Quote 0
                    • Ro75
                      Ro75 @Walter.O. last edited by
                      @walter-o das Skript her läuft, so wie es soll. Allerdings kenne ich nicht deine Anpassungen, damit es bei dir passt (z.B. Datenpunkte).
                      Ro75.
                      Walter.O. 1 Reply Last reply Reply Quote 0
                      • Walter.O.
                        @ro75 Was bräuchtest du damit du mir weiterhelfen könntest?
                          Homoran Global Moderator Administrators @Walter.O. last edited by
                          @walter-o sagte in Skript für Mondphase, Mondauf- und Untergang:
                          wo hast du hier in diesem Thread etwas gefragt?
                          • Walter.O.
                            @homoran Der satz bezog sich auf das Alter des Treads
                            Ro75 Homoran 2 Replies Last reply Reply Quote 0
                            • Ro75
                              @walter-o wo liegt denn das Problem genau? Ich verstehe nur Bahnhof.
                              Ro75.
                              • Ro75
                                Copy to ClipboardcreateState(DPMond+'MondphaseIcon', 0, {name: 'MondphaseIcon' ,type: 'number', read: true, write: true});
                                Falls du das meinst, zeige deinen Code mit den von dir durchgeführten Änderungen / Anpassungen.
                                Ro75.
                                • Walter.O.
                                  @ro75
                                  //Version 1.0.1 - 29.03.2025
                                  //Ersteller Ro75.
                                  //Voraussetzungen (Version 1.0.1 getestet mit)
                                  //NodeJS: 20.x
                                  //Javascript-Adapter: 8.8.1
                                  //Admin-Adapter: 7.4.10
                                  //JS-Controller: 7.0.3
                                  //Hinweis: Die Mondphasenberechnung basiert auf ein Skript aus dem Internet (Seite nicht mehr bekannt).
                                  //Das Skript wurde leicht modifiziert
                                  const SunCalc   = require("suncalc"); //Im Javascript-Adapter einzutragen (Zusätzliche NPM-Module)
                                  const DPMond    = '0_userdata.0.Wetter.'; //zentraler Datenpunkt
                                  const latitude  = 51.62; // muss an deinen Standort angepasst werden
                                  const longitude = 06.65; // muss an deinen Standort angepasst werden
                                  createState(DPMond+'MondphaseProz', 0, {name: 'MondphaseProz' ,type: 'number', read: true, write: true});
                                  createState(DPMond+'MondphaseDesc', '', {name: 'MondphaseDesc' ,type: 'string', read: true, write: true});
                                  createState(DPMond+'Mondaufgang', '', {name: 'Mondaufgang' ,type: 'string', read: true, write: true});
                                  createState(DPMond+'Monduntergang', '', {name: 'Monduntergang' ,type: 'string', read: true, write: true});
                                  function getMoonTimes(latitude, longitude, date) {
                                      const moonTimes = SunCalc.getMoonTimes(date, latitude, longitude);
                                      return moonTimes;
                                  function Mondphasenberechnung(){
                                      var heute, Vollmond_Refferenz, differenz, vVollmonde, ausgabetext;
                                      var synodischer_mondmonat = 29.530588;
                                      var phase = 1;
                                      if(phase == 0){
                                          phase = 100;
                                      if(phase < 25){
                                          ausgabetext = "abnehmender Mond";
                                      if(phase == 25){
                                      heute = new Date();
                                      Vollmond_Refferenz = new Date(2024, 11, 15, 10, 1, 42); //Berechnungsgrundlage
                                      heute = heute / 86400000;
                                      Vollmond_Refferenz = Vollmond_Refferenz / 86400000;
                                      differenz = heute - Vollmond_Refferenz;
                                      vVollmonde = differenz / synodischer_mondmonat;
                                      phase = vVollmonde * 100;
                                      phase = Math.round(phase);
                                      phase = phase / 100;
                                      phase = phase - Math.floor(phase);
                                      phase = phase * 100;
                                      phase = Math.floor(phase);
                                      if(phase == 0){
                                          phase = 100;
                                      if(phase < 25){
                                      if(phase == 25){
                                          ausgabetext = "Halbmond (3. Viertel)";
                                      if(phase > 25 && phase < 50){
                                      if(phase == 50){
                                          ausgabetext = "Neumond (4. Viertel)";
                                      if(phase > 50 && phase < 75){
                                          ausgabetext = "zunehmender Mond";
                                      if(phase == 75){
                                          ausgabetext = "Halbmond (1. Viertel)";
                                      if(phase > 75 && phase < 100){
                                      if(phase == 100){
                                          ausgabetext = "Vollmond (2. Viertel)";
                                      setState(DPMond+'MondphaseIcon',phase,true);
                                      setState(DPMond+'MondphaseDesc',ausgabetext,true);
                                  function Monddaten(){
                                      const date = new Date(); // aktuelles Datum
                                      const moonTimes = getMoonTimes(latitude, longitude, date);
                                      if (moonTimes.rise) {
                                          setState(DPMond+'Mondaufgang',moonTimes.rise.toLocaleTimeString([], {hour: '2-digit', minute:'2-digit', hour12: false}),true);
                                      } else {
                                          setState(DPMond+'Mondaufgang','--:--',true);
                                      if (moonTimes.set) {
                                          setState(DPMond+'Monduntergang',moonTimes.set.toLocaleTimeString([], {hour: '2-digit', minute:'2-digit', hour12: false}),true);
                                      } else {
                                          setState(DPMond+'Monduntergang','--:--',true);
                                  function berechneMondBeleuchtung(datum) {
                                      const mondInfo = SunCalc.getMoonIllumination(datum);
                                      const beleuchtungProzent = (mondInfo.fraction * 100);
                                      return {
                                          beleuchtung: `${beleuchtungProzent}`
                                   51.18
                                  function fRundenM(num) {
                                      var m = Number((Math.abs(num) * 100).toPrecision(15));
                                      return Math.round(m) / 100 * Math.sign(num);
                                  function MondBeleuchtung() {
                                      const mondBeleuchtung = berechneMondBeleuchtung(new Date());
                                      setState(DPMond+'MondphaseProz', fRundenM(mondBeleuchtung.beleuchtung), true);
                                  schedule('10 * * * *', Mondphasenberechnung);
                                  schedule('10 * * * *', Monddaten);
                                  schedule('10 * * * *', MondBeleuchtung);
                                  Mondphasenberechnung();
                                  Monddaten();
                                  MondBeleuchtung();
                                  • Walter.O.
                                    Walter.O. @Walter.O. last edited by Walter.O.
                                    @walter-o suncalc ist im Javascript adapter eingetragen
                                    Das anlegen eines alias so wie du es beschrieben hast kann leider auch nicht Nachvollziehen
                                    Ro75 2 Replies Last reply Reply Quote 0
                                    • Ro75
                                      @walter-o dann muss das Skript auch laufen. Zeige bitte das Log. Das Skript wurde auch als JS angelegt?
                                      Ro75.
                                      • Walter.O.
                                        @ro75 Script als JS.
                                        javascript.0
                                        2025-11-05 19:43:27.016	error	at processImmediate (node:internal/timers:485:21)
                                        javascript.0
                                        2025-11-05 19:43:27.016	error	at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/main.js:1732:17)
                                        javascript.0
                                        2025-11-05 19:43:27.016	error	at /opt/iobroker/node_modules/iobroker.javascript/main.js:2322:17
                                        javascript.0
                                        2025-11-05 19:43:27.016	error	at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:2224:37)
                                        javascript.0
                                        2025-11-05 19:43:27.016	error	at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1956:21)
                                        javascript.0
                                        2025-11-05 19:43:27.016	error	at new Script (node:vm:117:7)
                                        javascript.0
                                        2025-11-05 19:43:27.016	error	SyntaxError: Unexpected number
                                        javascript.0
                                        2025-11-05 19:43:27.016	error	^^^
                                        javascript.0
                                        2025-11-05 19:43:27.015	error	const longitude = 06.65; // muss an deinen Standort angepasst werden
                                        javascript.0
                                        2025-11-05 19:43:27.013	error	script.js.common.Mondphasen compile failed: at script.js.common.Mondphasen:19
                                        • Ro75
                                          1. Hast du die Bilder in VIS 1 an die korrekte Stelle gelegt?
                                          2. Wie legst du denn den Alias an? Ich, ohne Manager.
                                          Ro75.
                                          • Ro75
                                            Versuche doch mal
                                             const longitude = 6.65;
                                            Ro75.
                                            1262
