      welli @Marc Berg last edited by
      @marc-berg
      Habe 15.0.1 drauf bekomme aber jetzt die Fehlermeldung wenn ich den TFT 5.0.2 flashe.
      7:59:13.965 FLH: Something has gone wrong flashing display firmware [bytes('9EE11E14E70F010D0000E1FDF77FFAFDDFFFB6F97F0FFEEEC002FFBFDFF6A000...')]
      17:59:14.066 FLH: Something has gone wrong flashing display firmware [bytes('2EFFD7F75F7FDF6B3BD110DB22C80694EFFFEFFCB415DDFF87CF8FD102FB36EF...')]
      17:59:14.171 FLH: Something has gone wrong flashing display firmware [bytes('B4FF1C56C0B4AD0158677273F8F710F20F078D000061DD8FEFFD7D97FF2C01FF...')]
      17:59:14.267 FLH: Something has gone wrong flashing display firmware [bytes('3EFBDFF9FDFDDCBAFBFEFFFBFFC97F2FFBF7BD19821F54860A0CFFFEDEBFC568...')]
      17:59:14.366 FLH: Something has gone wrong flashing display firmware [bytes('7BE3BE43AAB4E1FBF72F249EC4FBEDA98134D77C39D25FFF20EF0F27E201C17B...')]
      17:59:14.467 FLH: Something has gone wrong flashing display firmware [bytes('5EFFEBB7DBFE943BDD77FFFBBF4305FB36EF564EBFFDF48BA402FB36EF564EBF...')]
      17:59:14.566 FLH: Something has gone wrong flashing display firmware [bytes('163F14B46C5FEF1AC2FB030F0000CC0170FF52F7FFFDFAF7FD6D01FFDFFDFB67...')]
      17:59:14.666 FLH: Something has gone wrong flashing display firmware [bytes('D47FDFFB7DFBAFD940BDFD69013E23860AFAC8BF3FFBFEB409DDFF8B97675647...')]
      17:59:14.766 FLH: Something has gone wrong flashing display firmware [bytes('D4FB03070D0000F0FFD8DFDFFAFFFF7EFF9DADF7BBBB2DFEFDB9FDBB7FECBF7D...')]
      17:59:14.866 FLH: Something has gone wrong flashing display firmware [bytes('C2D6A9BC7DFF9DFFEDFEFA3FBFCB2B9312060628C817FDDDF7ED640EDDFF7D97...')]
      17:59:14.966 FLH: Something has gone wrong flashing display firmware [bytes('BA7C5DEF1DB07903030D01E1EFE7DFFAFD2BB603FFDF8FFF7DD102FDBFDFCF8A...')]
      17:59:15.066 FLH: Something has gone wrong flashing display firmware [bytes('F37D008005978C014F1DD710C0CB314000802B7166F2F7FB9FFAFC7F7FFFD9EE...')]
      17:59:15.172 FLH: Something has gone wrong flashing display firmware [bytes('7AA7DAB3A98478FD07149CA73FE41E42DF1B01B4000000F0FF73FFDFED07FFDF...')]
      17:59:15.267 FLH: Something has gone wrong flashing display firmware [bytes('FCDBE48EDFFF000FCE00B22D66F69BB76B7FDA3BDBFFF3DBCEA0027B32578B02...')]
      17:59:15.366 FLH: Something has gone wrong flashing display firmware [bytes('4FFFFEFA7CA43189F5AE12BEDFF41F712518FE0DB069705FBF26CB3917F20141...')]
      17:59:15.483 FLH: Something has gone wrong flashing display firmware [bytes('D40EDD773FF9797FEAF4F63ECC5501BFFDF48BA402FB36EF564EBFFDF48BA402...')]
      17:59:15.566 FLH: Something has gone wrong flashing display firmware [bytes('1E0C01C1FF7BFFED7CDFDFD875FF87FE5BD102FFBFDFF6A00000
        ticaki @welli last edited by
        @welli
        Panel stromlos machen
          welli @ticaki last edited by
          @ticaki
          Danke Jungs jetzt get es.
          Gruss
          Welli
          • Armilar
            Armilar Most Active Forum Testing @Frederik Buss last edited by
            @frederik-buss sagte in SONOFF NSPanel mit Lovelace UI:
            Hast Du vielleicht eine Idee wie man die Kacheln ähnlich hinbekommt?
            nach langem hin und her grübeln und diskutieren haben wir uns erstmals entschieden etwas nicht umzusetzen.
            Es ist machbar die Hintergründe der Icons mit Background-Colors zu versehen, jedoch ist das mit vielen Breaking-Changes, sowohl im Script als auch in der TFT verbunden, so dass wir den anderen Usern diese Änderungen und damit ggfs. auch ein temporäres Fehlverhalten nicht zumuten möchten.
            Jede einzelne Entität im Skript, Definition und jedes Page in der TFT inklusive Änderung des Serial-Protocol rechtfertigen außerdem den Aufwand zur Änderung der Hintergrundfarben nicht wirklich.
            Wir hoffen auf dein Verständnis
            VG
            Armilar
            Frederik Buss 1 Reply Last reply Reply Quote 1
              Habe ein Problem mit einem meiner zwei NSpanels.
              Firmware ,TFT , alles gleich auf den zwei panels nur im script ist 1 und 2 verschieden.
              Bei Panel 1 , bei drücken auf den Bildschrim leuchet er sofort hell aber bleibt im screensaver hängen und schaltet nicht auf mein erste Seite um, auch bei mehrmals drauf drücken , bei Panel 2 schaltet es sofort um.
              Habe jetzt die letze Firmware drauf bei Panel 1 aber das gleiche.
              Einer ne idee was das sein könnte?
              Gruss
              Welli
              T Armilar 2 Replies Last reply Reply Quote 0
                ticaki @welli last edited by ticaki
                @welli
                drückste auf die indicators? Drück mal 2mal schnell auf die bottoms
                • Armilar
                  Armilar Most Active Forum Testing @welli last edited by Armilar
                  @welli
                  sieh mal nach, ob die
                  0_userdata.0.NSPanel.X.Config.Screensaver.screenSaverDoubleClick
                  unterschiedlich sind?
                  false = Einfachklick
                  true = Doppelklick
                    welli @Armilar last edited by
                    @armilar said in SONOFF NSPanel mit Lovelace UI:
                    Habe den Doppelklick auf false gestellt. jetzt dauerts es 20-30sek bis die Anzeige umschaltet , sowie auch die Relais klicken sofort aber nach 20-30sek ändert die Anzeige im Bildschirm von aus auf ein Symbol.
                    • Armilar
                      @welli
                      Dann gehen da die WLAN/MQTT-Signale in Schleichfahrt zum Router.
                      Schon mal die ioBroker-Büchse durchgestartet?
                      P.S.: Die Relays müssen sofort klicken... Die gehören zur Hardware...
                      • Frederik Buss
                        Frederik Buss @Armilar last edited by
                        @armilar Hi Armilar, klar verstehe ich das, auch wenn ich es schade finde - ich bin sicher, dass eine Kacheloptik ein echtes optisches Highlight wäre. Vielleicht finden sich ja in Zukunft mehr Zusprecher 🙂
                          australien last edited by australien
                          Ich würde gerne im StandardScreensafer eine eigene Temperatur anzeigen lassen.
                          Wo kann ich diesen DP eintragen? Ohne Pirate Weather hatte ich dieses schon, nun weiß ich aber die Änderung nicht mehr.
                          v5.0.0.1 mit Pirate Wetter
                            TT-Tom @australien last edited by
                            @australien
                            Siehe hier im Wiki https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker-ALIAS-Definitionen#wettervorhersage
                            Das sollte funktionieren
                              australien @TT-Tom last edited by australien
                              @tt-tom
                              steht da auch drinnen, und hat bis jetzt funktioniert. nur wird jetzt der wert aus dem pirate wetter angezeigt. momentan 7,2 anstatt 3,9
                              mit der Version v4.6.2.1 wird auch noch die richtige Temp genommen.
                                TT-Tom @australien last edited by TT-Tom
                                @australien
                                im Punkt 3 der Config, was steht da bei dir? da musst du deine Temp hinterlegen
                                const weatherEntityPath: string = 'alias.0.Pirate_Weather
                                Edit : welche Script Version hast du jetzt?
                                  @tt-tom said in SONOFF NSPanel mit Lovelace UI:
                                  die Version TypeScript v5.0.0.1
                                  und es steht
                                  // DE: Dieser Alias wird automatisch für den gewählten Wetter erstellt und kann entsprechend angepasst werden
                                  // EN: This alias is automatically created for the selected weather and can be adjusted accordingly
                                  const weatherEntityPath: string = 'alias.0.Pirate_Weather'; //Please rename if change weatherAdapterInstance!
                                    @australien
                                    dann gehe in den Alias rein und verbinde die TEMP mit deinem Sensor
                                    • Armilar
                                      Armilar Most Active Forum Testing @australien last edited by
                                      @australien
                                      Für die Anzeige der aktuellen Screensaver-Temperatur wird immer die Konstante weatherEntityPath
                                      genutzt.
                                      Im hinteren selbst definierten Namen des ALIAS-Wetter-Channel (kann ja abweichen), kannst du unter TEMP dann deinen eigenen Sensor zuweisen.
                                      Das hat sich seit Bereitstellung des NSPanel-Skriptes auch nicht geändert...
                                        australien @Armilar last edited by australien
                                        @armilar mein Alias wurde auch nicht geändert, nur durch das script auf die Pirate Weather min und max.
                                        Es ist auch egal wohin ich den temp verweise, das script verwendet immer nur die original pirate weather temp
                                        siehe screenshot oben
                                        wie gesagt, ging es so auch unter den vorherigen Versionen.
                                        • Armilar
                                          Armilar Most Active Forum Testing @australien last edited by Armilar
                                          @australien
                                          In deinem Alias (dein Screenshot) steht ja auch der Verweis auf die pirate-weather.0.weather.currently.temp drin. Der müsste dann auf deinen eigenen Sensor zeigen.
                                            richtig ist doch das gelbe? oder sehe ich das falsch?
                                              "common": {
                                                "type": "number",
                                                "role": "value.temperature",
                                                "name": "TEMP",
                                                "alias": {
                                                  "id": "0_userdata.0.NSPanel.eigen_TEMP"
                                                "unit": "°C",
                                                "read": true,
                                                "write": true
                                              "native": {},
                                              "type": "state",
                                              "_id": "alias.0.Wetter.TEMP",
                                              "acl": {
                                                "object": 1636,
                                                "state": 1636,
                                                "owner": "system.user.admin",
                                              "user": "system.user.admin",
                                              "ts": 1763026764484
                                            lovelace ui nspanel sonoff
                                            271
                                            7747
                                            6660651
