    4. Kann View nicht löschen
      oder so:
      http://www.iobroker.net/docu/?page_id=5 … stallieren
      gruß
      Rainer
      • hg6806
        hg6806 Most Active last edited by
        Danke Rainer, hat funktioniert!
        Fehler ist auch behoben. View konnte ich löschen.
          tempestas last edited by
          Ich kann leider nicht vom Git installieren, folgende Logs
          node js ist 6.11.3
          host.iobrokerNUC 2018-02-11 09:43:12.171 info Update repository "default" under "http://download.iobroker.net/sources-dist.json"
          iobroker 2018-02-11 09:43:11.653 info exit 0
          iobroker 2018-02-11 09:43:11.571 info npm ERR! Please include the following file with any support request:npm ERR! /opt/npm-debug.log
          iobroker 2018-02-11 09:43:11.559 info
          iobroker 2018-02-11 09:43:11.432 info npm ERR! There is likely additional logging output above.
          iobroker 2018-02-11 09:43:11.432 info npm ERR! npm owner ls iobroker.vis
          iobroker 2018-02-11 09:43:11.432 info npm ERR! Or if that isn't available, you can get their info via:
          iobroker 2018-02-11 09:43:11.432 info npm ERR! npm bugs iobroker.vis
          iobroker 2018-02-11 09:43:11.432 info npm ERR! You can get information on how to open an issue for this project with:
          iobroker 2018-02-11 09:43:11.432 info npm ERR! node main.js --install
          iobroker 2018-02-11 09:43:11.432 info npm ERR! Tell the author that this fails on your system:
          iobroker 2018-02-11 09:43:11.432 info npm ERR! not with npm itself.
          iobroker 2018-02-11 09:43:11.432 info npm ERR! If you do, this is most likely a problem with the iobroker.vis package,
          iobroker 2018-02-11 09:43:11.432 info npm ERR! Make sure you have the latest version of node.js and npm installed.
          iobroker 2018-02-11 09:43:11.432 info npm ERR! Failed at the iobroker.vis@1.1.2 install script 'node main.js --install'.
          iobroker 2018-02-11 09:43:11.432 info npm ERR! Exit status 1
          iobroker 2018-02-11 09:43:11.432 info npm ERR! iobroker.vis@1.1.2 install: node main.js --install
          iobroker 2018-02-11 09:43:11.432 info npm ERR! code ELIFECYCLE
          iobroker 2018-02-11 09:43:11.432 info npm ERR! npm v3.10.10
          iobroker 2018-02-11 09:43:11.432 info npm ERR! node v6.11.3
          iobroker 2018-02-11 09:43:11.432 info npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "https://github.com/ioBroker/ioBroker.vis/tarball/master" "--production" "--prefix" "/opt/iobroker"
          iobroker 2018-02-11 09:43:11.432 info npm ERR! Linux 4.4.0-96-generic
          iobroker 2018-02-11 09:43:11.432 info npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
          iobroker 2018-02-11 09:43:11.432 info npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/noble/node_modules/xpc-connection):
          iobroker 2018-02-11 09:43:11.432 info npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/iobroker.radar/node_modules/noble/node_modules/xpc-connection):
          iobroker 2018-02-11 09:43:11.432 info npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
          iobroker 2018-02-11 09:43:11.432 info npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})npm WARN optional SKIPPING OPTIONAL DE
          iobroker 2018-02-11 09:43:11.409 info npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@^1.0.0 (node_modules/chokidar/node_modules/fsevents):
          iobroker 2018-02-11 09:43:10.179 info at startup (bootstrap_node.js:149:9)
          iobroker 2018-02-11 09:43:10.179 info at run (bootstrap_node.js:389:7)
          iobroker 2018-02-11 09:43:10.179 info at Module.runMain (module.js:604:10)
          iobroker 2018-02-11 09:43:10.179 info at Function.Module._load (module.js:438:3)
          iobroker 2018-02-11 09:43:10.179 info at tryModuleLoad (module.js:446:12)
          iobroker 2018-02-11 09:43:10.179 info at Module.load (module.js:487:32)
          iobroker 2018-02-11 09:43:10.179 info at Object.Module._extensions..js (module.js:579:10)
          iobroker 2018-02-11 09:43:10.179 info at Module._compile (module.js:542:28)
          iobroker 2018-02-11 09:43:10.179 info at Object.runInThisContext (vm.js:97:10)
          iobroker 2018-02-11 09:43:10.179 info at createScript (vm.js:56:10)
          iobroker 2018-02-11 09:43:10.179 info SyntaxError: Unexpected token ,
          iobroker 2018-02-11 09:43:10.179 info ^
          iobroker 2018-02-11 09:43:10.179 info /opt/iobroker/node_modules/iobroker.vis/main.js:250 , function () {
          iobroker 2018-02-11 09:42:32.910 info npm install https://github.com/ioBroker/ioBroker.vis/tarball/master --production --prefix "/opt/iobroker" (System call)
          iobroker 2018-02-11 09:42:32.687 info install https://github.com/ioBroker/ioBroker.vis/tarball/master
          iobroker 2018-02-11 09:42:32.031 info url "https://github.com/ioBroker/ioBroker.vis.git"
          bzw ohne das .git am ende
          host.iobrokerNUC	2018-02-11 09:39:26.620	info	Update repository "default" under "http://download.iobroker.net/sources-dist.json"
          iobroker	2018-02-11 09:39:26.162	info	exit 0
          iobroker	2018-02-11 09:39:26.147	error	Cannot parse /opt/iobroker/node_modules/iobroker.js-controller/adapter/vis/io-package.json:Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/adapter/vi
          iobroker	2018-02-11 09:39:26.099	info	npm ERR! /opt/npm-debug.log
          iobroker	2018-02-11 09:39:26.099	info	npm ERR! Please include the following file with any support request:
          iobroker	2018-02-11 09:39:26.099	info	npm ERR! There is likely additional logging output above.
          iobroker	2018-02-11 09:39:26.099	info	npm ERR! npm owner ls iobroker.vis
          iobroker	2018-02-11 09:39:26.099	info	npm ERR! Or if that isn't available, you can get their info via:
          iobroker	2018-02-11 09:39:26.099	info	npm ERR! npm bugs iobroker.vis
          iobroker	2018-02-11 09:39:26.099	info	npm ERR! You can get information on how to open an issue for this project with:
          iobroker	2018-02-11 09:39:26.099	info	npm ERR! node main.js --install
          iobroker	2018-02-11 09:39:26.099	info	npm ERR! Tell the author that this fails on your system:
          iobroker	2018-02-11 09:39:26.099	info	npm ERR! not with npm itself.
          iobroker	2018-02-11 09:39:26.099	info	npm ERR! If you do, this is most likely a problem with the iobroker.vis package,
          iobroker	2018-02-11 09:39:26.099	info	npm ERR! Make sure you have the latest version of node.js and npm installed.
          iobroker	2018-02-11 09:39:26.099	info	npm ERR! Failed at the iobroker.vis@1.1.2 install script 'node main.js --install'.
          iobroker	2018-02-11 09:39:26.099	info	npm ERR! Exit status 1
          iobroker	2018-02-11 09:39:26.099	info	npm ERR! iobroker.vis@1.1.2 install: `node main.js --install`
          iobroker	2018-02-11 09:39:26.099	info	npm ERR! code ELIFECYCLE
          iobroker	2018-02-11 09:39:26.099	info	npm ERR! npm v3.10.10
          iobroker	2018-02-11 09:39:26.099	info	npm ERR! node v6.11.3
          iobroker	2018-02-11 09:39:26.099	info	npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "https://github.com/iobroker/iobroker.vis/tarball/master" "--production" "--prefix" "/opt/iobroker"
          iobroker	2018-02-11 09:39:26.099	info	npm ERR! Linux 4.4.0-96-generic
          iobroker	2018-02-11 09:39:26.099	info	npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
          iobroker	2018-02-11 09:39:26.099	info	npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/noble/node_modules/xpc-connection):
          iobroker	2018-02-11 09:39:26.099	info	npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/iobroker.radar/node_modules/noble/node_modules/xpc-connection):
          iobroker	2018-02-11 09:39:26.099	info	npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
          iobroker	2018-02-11 09:39:26.099	info	npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@^1.0.0 (node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents):
          iobroker	2018-02-11 09:39:26.099	info	npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@^1.0.0 (node_modules/chokidar/node_modules/fsevents):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.1.3: wa
          iobroker	2018-02-11 09:39:24.477	info	at startup (bootstrap_node.js:149:9)
          iobroker	2018-02-11 09:39:24.477	info	at run (bootstrap_node.js:389:7)
          iobroker	2018-02-11 09:39:24.477	info	at Module.runMain (module.js:604:10)
          iobroker	2018-02-11 09:39:24.477	info	at Function.Module._load (module.js:438:3)
          iobroker	2018-02-11 09:39:24.477	info	at tryModuleLoad (module.js:446:12)
          iobroker	2018-02-11 09:39:24.477	info	at Module.load (module.js:487:32)
          iobroker	2018-02-11 09:39:24.477	info	at Object.Module._extensions..js (module.js:579:10)
          iobroker	2018-02-11 09:39:24.477	info	at Module._compile (module.js:542:28)
          iobroker	2018-02-11 09:39:24.477	info	at Object.runInThisContext (vm.js:97:10)
          iobroker	2018-02-11 09:39:24.477	info	at createScript (vm.js:56:10)
          iobroker	2018-02-11 09:39:24.477	info	SyntaxError: Unexpected token ,
          iobroker	2018-02-11 09:39:24.477	info	^
          iobroker	2018-02-11 09:39:24.477	info	/opt/iobroker/node_modules/iobroker.vis/main.js:250 , function () {
          iobroker	2018-02-11 09:38:47.235	info	npm install https://github.com/iobroker/iobroker.vis/tarball/master --production --prefix "/opt/iobroker" (System call)
          iobroker	2018-02-11 09:38:46.894	info	install https://github.com/iobroker/iobroker.vis/tarball/master
          iobroker	2018-02-11 09:38:46.140	info	url "https://github.com/iobroker/iobroker.vis"
          • eric2905
            eric2905 last edited by
            Wie versuchst Du denn von Github zu installieren?
            Gruß,
            Eric
            Von unterwegs getippert
              ich nehme das Katzensymbol, gehe auf "beliebig" und füge https://github.com/ioBroker/ioBroker.vis.git bzw https://github.com/ioBroker/ioBroker.vis ein.
              Bei der option "von git installieren" und dann VIS auswählen kommt dieses LOG (habe debug ausgänge angewählt)
              ! host.iobrokerNUC 2018-02-11 09:57:01.191 info Update repository "default" under "http://download.iobroker.net/sources-dist.json" iobroker 2018-02-11 09:57:00.572 info exit 0 iobroker 2018-02-11 09:57:00.559 error Cannot parse /opt/iobroker/node_modules/iobroker.js-controller/adapter/vis/io-package.json:Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/adapter/vi iobroker 2018-02-11 09:57:00.490 info npm ERR! /opt/npm-debug.log iobroker 2018-02-11 09:57:00.490 info npm ERR! Please include the following file with any support request: iobroker 2018-02-11 09:57:00.393 info npm ERR! There is likely additional logging output above. iobroker 2018-02-11 09:57:00.393 info npm ERR! npm owner ls iobroker.vis iobroker 2018-02-11 09:57:00.393 info npm ERR! Or if that isn't available, you can get their info via: iobroker 2018-02-11 09:57:00.393 info npm ERR! npm bugs iobroker.vis iobroker 2018-02-11 09:57:00.393 info npm ERR! You can get information on how to open an issue for this project with: iobroker 2018-02-11 09:57:00.393 info npm ERR! node main.js --install iobroker 2018-02-11 09:57:00.393 info npm ERR! Tell the author that this fails on your system: iobroker 2018-02-11 09:57:00.393 info npm ERR! not with npm itself. iobroker 2018-02-11 09:57:00.393 info npm ERR! If you do, this is most likely a problem with the iobroker.vis package, iobroker 2018-02-11 09:57:00.393 info npm ERR! Make sure you have the latest version of node.js and npm installed. iobroker 2018-02-11 09:57:00.393 info npm ERR! Failed at the iobroker.vis@1.1.2 install script 'node main.js --install'. iobroker 2018-02-11 09:57:00.393 info npm ERR! iobroker 2018-02-11 09:57:00.393 info npm ERR! iobroker.vis@1.1.2 install: `node main.js --install`npm ERR! Exit status 1 iobroker 2018-02-11 09:57:00.383 info npm ERR! code ELIFECYCLE iobroker 2018-02-11 09:57:00.383 info npm ERR! npm v3.10.10 iobroker 2018-02-11 09:57:00.383 info npm ERR! node v6.11.3 iobroker 2018-02-11 09:57:00.383 info npm ERR! Linux 4.4.0-96-genericnpm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "https://github.com/ioBroker/ioBroker.vis/tarball/master" "--production" "--prefix" "/opt/iobroker" iobroker 2018-02-11 09:57:00.375 info npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"}) iobroker 2018-02-11 09:57:00.375 info npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/noble/node_modules/xpc-connection): iobroker 2018-02-11 09:57:00.375 info npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"}) iobroker 2018-02-11 09:57:00.375 info npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/iobroker.radar/node_modules/noble/node_modules/xpc-connection): iobroker 2018-02-11 09:57:00.375 info npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"}) iobroker 2018-02-11 09:57:00.375 info npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})npm WARN optional SKIPPING OPTIONAL DE iobroker 2018-02-11 09:57:00.372 info npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@^1.0.0 (node_modules/chokidar/node_modules/fsevents): iobroker 2018-02-11 09:56:59.171 info at startup (bootstrap_node.js:149:9) iobroker 2018-02-11 09:56:59.171 info at run (bootstrap_node.js:389:7) iobroker 2018-02-11 09:56:59.171 info at Module.runMain (module.js:604:10) iobroker 2018-02-11 09:56:59.171 info at Function.Module._load (module.js:438:3) iobroker 2018-02-11 09:56:59.171 info at tryModuleLoad (module.js:446:12) iobroker 2018-02-11 09:56:59.171 info at Module.load (module.js:487:32) iobroker 2018-02-11 09:56:59.171 info at Object.Module._extensions..js (module.js:579:10) iobroker 2018-02-11 09:56:59.171 info at Module._compile (module.js:542:28) iobroker 2018-02-11 09:56:59.171 info at Object.runInThisContext (vm.js:97:10) iobroker 2018-02-11 09:56:59.171 info at createScript (vm.js:56:10) iobroker 2018-02-11 09:56:59.171 info SyntaxError: Unexpected token , iobroker 2018-02-11 09:56:59.171 info ^ iobroker 2018-02-11 09:56:59.171 info /opt/iobroker/node_modules/iobroker.vis/main.js:250 , function () { iobroker 2018-02-11 09:56:58.990 info > node main.js --install iobroker 2018-02-11 09:56:58.990 info > iobroker.vis@1.1.2 install /opt/iobroker/node_modules/iobroker.vis web.0 2018-02-11 09:56:39.734 info 2018-02-11T08:56:39.734Z Connected system.user.admin iobroker 2018-02-11 09:56:22.084 info npm install https://github.com/ioBroker/ioBroker.vis/tarball/master --production --prefix "/opt/iobroker" (System call) iobroker 2018-02-11 09:56:21.846 info install https://github.com/ioBroker/ioBroker.vis/tarball/master iobroker 2018-02-11 09:56:21.116 info url "https://github.com/ioBroker/ioBroker.vis/tarball/master" vis --debug !
              was mir auch auffällt:
              in meiner Anzeige ist VIS gar nicht mehr installiert. sonst steht da ja immer [x / y] über dem Segment, bei mir steht [0 /4] und auch die installeirte Version neben der verfügbaren Version wird nicht angezeigt.
              Ich kann es aber nutzen
              filename="vis.png" index="0">~~
              • eric2905
                Installiert ist VIS schon, aber Du hast keine Instanz (mehr).
                Könntest Du mal auf npm 4 updaten? Mach aber vorher ein Backup (schadet nie).
                npm install -g npm@4
                Entweder als Root oder mit „sudo „ davor.
                Gruß,
                Eric
                  Ok, das mit "installiert aber ohne Instanz" ist mir zu hoch 🙂
                  Habe npm wie geschrieben aktualisiert, wieder versucht vis vom git zu installieren:
                  host.iobrokerNUC 2018-02-11 11:29:48.790 info Update repository "default" under "http://download.iobroker.net/sources-dist.json"
                  iobroker 2018-02-11 11:29:48.203 info exit 0
                  iobroker 2018-02-11 11:29:48.188 error Cannot parse /opt/iobroker/node_modules/iobroker.js-controller/adapter/vis/io-package.json:Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/adapter/vi
                  iobroker 2018-02-11 11:29:48.123 info npm ERR! /home/steffen/.npm/_logs/2018-02-11T10_29_48_105Z-debug.log
                  iobroker 2018-02-11 11:29:48.123 info npm ERR! A complete log of this run can be found in:
                  iobroker 2018-02-11 11:29:48.040 info npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                  iobroker 2018-02-11 11:29:48.040 info npm ERR! Failed at the iobroker.vis@1.1.2 install script.
                  iobroker 2018-02-11 11:29:48.040 info npm ERR! Exit status 1
                  iobroker 2018-02-11 11:29:48.040 info npm ERR! iobroker.vis@1.1.2 install: node main.js --install
                  iobroker 2018-02-11 11:29:48.040 info npm ERR! code ELIFECYCLEnpm ERR! errno 1
                  iobroker 2018-02-11 11:29:48.031 info npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                  iobroker 2018-02-11 11:29:48.031 info npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/noble/node_modules/xpc-connection):
                  iobroker 2018-02-11 11:29:48.031 info npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/iobroker.radar/node_modules/noble/node_modules/xpc-connection):
                  iobroker 2018-02-11 11:29:48.031 info npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                  iobroker 2018-02-11 11:29:48.031 info npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})npm WARN optional SKIPPING OPTIONAL DE
                  iobroker 2018-02-11 11:29:48.027 info npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@^1.0.0 (node_modules/chokidar/node_modules/fsevents):
                  iobroker 2018-02-11 11:29:46.804 info at startup (bootstrap_node.js:149:9)
                  iobroker 2018-02-11 11:29:46.804 info at run (bootstrap_node.js:389:7)
                  iobroker 2018-02-11 11:29:46.804 info at Module.runMain (module.js:604:10)
                  iobroker 2018-02-11 11:29:46.804 info at Function.Module._load (module.js:438:3)
                  iobroker 2018-02-11 11:29:46.804 info at tryModuleLoad (module.js:446:12)
                  iobroker 2018-02-11 11:29:46.804 info at Module.load (module.js:487:32)
                  iobroker 2018-02-11 11:29:46.804 info at Object.Module._extensions..js (module.js:579:10)
                  iobroker 2018-02-11 11:29:46.804 info at Module._compile (module.js:542:28)
                  iobroker 2018-02-11 11:29:46.804 info at Object.runInThisContext (vm.js:97:10)
                  iobroker 2018-02-11 11:29:46.804 info at createScript (vm.js:56:10)
                  iobroker 2018-02-11 11:29:46.804 info SyntaxError: Unexpected token ,
                  iobroker 2018-02-11 11:29:46.804 info ^
                  iobroker 2018-02-11 11:29:46.804 info /opt/iobroker/node_modules/iobroker.vis/main.js:250 , function () {
                  iobroker 2018-02-11 11:29:46.632 info > node main.js --install
                  iobroker 2018-02-11 11:29:46.632 info > iobroker.vis@1.1.2 install /opt/iobroker/node_modules/iobroker.vis
                  iobroker 2018-02-11 11:28:28.096 info npm install https://github.com/ioBroker/ioBroker.vis/tarball/master --production --prefix "/opt/iobroker" (System call)
                  • eric2905
                    @tempestas:
                    Ok, das mit "installiert aber ohne Instanz" ist mir zu hoch 🙂 `
                    Poste bitte mal einen Screenshot vom Admin, Reiter „Adapter“. Aber bitte volle Breite.
                      Sieht aus wie vorher.
                      Kann ich vis einfach löschen und nochmal neu installieren, oder verliere ich da meine Projekte und Bilder?
                      Wie lösche ich, wenn gar keine Instanz da ist?
                      filename="adapter.png" index="1">~~
                      Nachtrag:
                      damit man sieht, dass grundsätzlich aber instanzen da sind:
                      filename="adapter2.png" index="0">~~
                        @tempestas:
                        das mit "installiert aber ohne Instanz" ist mir zu hoch `
                        Du kannst die Installationsdateien für den Adapter installieren ohne danach eine Instanz zu erzeugen.
                        Der Konsolenbefehl dazu wäre:
                        sudo iobroker install AdapterName
                        Die Instanz legst du dann mit dem (+) im Reiter Adapter an oder über die Konsole mit:
                        sudo iobroker add AdapterName
                        @tempestas:
                        Wie lösche ich, wenn gar keine Instanz da ist? `
                        Die Frage ist das Gegenstück zu deinem oben gefragten.
                        Löschen der Installationsdateien finden im Reiter Adapter - Icon Mülltonne statt
                        Löschen von Instanzen dagegen im Reiter Instanzen.
                        Der Konsolenbefehl für das Löschen einer Instanz wäre:
                        sudo iobroker del AdapterName.Instanz
                        Wobei "Instanz" die Zahl hinter dem Punkt ist, z.B. javascript.1
                        Mit dem Befehl
                        löschst du die Installationsdaten.
                        @tempestas:
                        wieder versucht vis vom git zu installieren: `
                        nach der Installation vom git kann es notwendig sein ein Upload zu machen, um die neuen Installationsdateien auch an die Instanzen weiterzugeben.
                        sudo iobroker upload AdapterName
                        Außerdem ist IMMER ein Leeren des Browsercaches sehr hilfreich 😉
                        Rainer
                          @ eric und @ homoran:
                          ich danke euch.
                          ein neues sudo iobroker add vis hat dazu geführt, dass er zwar sagt "nur eine Instanz erlaubt", aber nun wird alles angezeigt und ich sehe auch wieder eine Instanz.
                          Rainer: bei mir wird grundsätzlich immer alles gelöscht automatisch. Da wird nicht sim Browser gespeichert 🙂
                          Dein Posting kommt bei mir gleich wieder in die Lesezeichen
                          1047
