    4. [Aufruf] test hm-rpc 1.6.0
    • eric2905
      eric2905 last edited by
      Hier der Log-Auszug, wenn die Bewegung erkannt wird:
      hm-rpc.3	2018-02-11 15:10:25.311	debug	redis pmessage io.hm-rpc.3.* io.hm-rpc.3.xxxxxxxxxxxxxx.1.MOTION_DETECTION_ACTIVE {"val":true,"ack":true,"ts":1518358225311,"q":0,"from":"system.adapter.hm-rpc.3","lc":1514928527133}
      hm-rpc.3	2018-02-11 15:10:25.311	debug	redis pmessage io.hm-rpc.3.* io.hm-rpc.3.xxxxxxxxxxxxxx.1.MOTION {"val":false,"ack":true,"ts":1518358225311,"q":0,"from":"system.adapter.hm-rpc.3","lc":1518355987445}
      hm-rpc.3	2018-02-11 15:10:25.311	debug	redis pmessage io.hm-rpc.3.* io.hm-rpc.3.xxxxxxxxxxxxxx.1.ILLUMINATION {"val":15.9,"ack":true,"ts":1518358225311,"q":0,"from":"system.adapter.hm-rpc.3","lc":1518358225311}
      hm-rpc.3	2018-02-11 15:10:25.310	debug	hm-rpc.3.xxxxxxxxxxxxxx.1.MOTION_DETECTION_ACTIVE ==> UNIT: "undefined" (min: false, max: true) From "true" => "true"
      hm-rpc.3	2018-02-11 15:10:25.310	debug	xmlrpc <- event ["hm-rpc.3","xxxxxxxxxxxxxx:1","MOTION_DETECTION_ACTIVE",true]
      hm-rpc.3	2018-02-11 15:10:25.310	debug	xml multicall : hm-rpc.3,xxxxxxxxxxxxxx:1,MOTION_DETECTION_ACTIVE,true
      Gruß,
      Eric
      • eric2905
        Jetzt kommen wieder keine Aktualisierungen … nach Neustart des hm-rpc kommen sie dann wieder ....
        Seltsam.
        Gruß,
        Eric
          Sieht erst mal gut aus:
          piVCCU: 2.31.25
          js-controller 1.2.3
          admin 3.2.0
          Geräte:
          • HM-PB-2-WM55
          • HM-Sen-MDIR-WM55
          • HM-OU-CFM-TW
          letztere wollte wohl ein paar Infos an den Developer loswerden.
          2018-02-11 14:53:36.293 - info: hm-rpc.0 binrpc -> getParamsetDescription ["JEQ0090871:0","VALUES"]
          2018-02-11 14:53:36.392 - warn: hm-rpc.0 Send this info to developer: _id: "hm-rpc.meta.VALUES.HM-PB-2-WM55.MAINTENANCE.8"
          2018-02-11 14:53:36.394 - warn: hm-rpc.0 Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"AES_KEY":{"DEFAULT":0,"FLAGS":0,"ID":"AES_KEY","MAX":127,"MIN":0,"OPERATIONS":1,"TAB_ORDER":6,"TYPE":"INTEGER","UNIT":""},"CONFIG_PENDING":{"DEFAULT":false,"FLAGS":9,"ID":"CONFIG_PENDING","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":2,"TYPE":"BOOL","UNIT":""},"LOWBAT":{"DEFAULT":false,"FLAGS":9,"ID":"LOWBAT","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":3,"TYPE":"BOOL","UNIT":""},"RSSI_DEVICE":{"DEFAULT":0,"FLAGS":1,"ID":"RSSI_DEVICE","MAX":2147483647,"MIN":-2147483648,"OPERATIONS":5,"TAB_ORDER":4,"TYPE":"INTEGER","UNIT":""},"RSSI_PEER":{"DEFAULT":0,"FLAGS":1,"ID":"RSSI_PEER","MAX":2147483647,"MIN":-2147483648,"OPERATIONS":5,"TAB_ORDER":5,"TYPE":"INTEGER","UNIT":""},"STICKY_UNREACH":{"DEFAULT":false,"FLAGS":25,"ID":"STICKY_UNREACH","MAX":true,"MIN":false,"OPERATIONS":7,"TAB_ORDER":1,"TYPE":"BOOL","UNIT":""},"UNREACH":{"DEFAULT":false,"FLAGS":9,"ID":"UNREACH","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":0,"TYPE":"BOOL","UNIT":""}}}
          2018-02-11 14:53:36.583 - info: hm-rpc.0 binrpc -> getParamsetDescription ["JEQ0090871:1","VALUES"]
          2018-02-11 14:53:36.659 - warn: hm-rpc.0 Send this info to developer: _id: "hm-rpc.meta.VALUES.HM-PB-2-WM55.KEY.8"
          2018-02-11 14:53:36.661 - warn: hm-rpc.0 Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"INSTALL_TEST":{"DEFAULT":false,"FLAGS":3,"ID":"INSTALL_TEST","MAX":true,"MIN":false,"OPERATIONS":4,"TAB_ORDER":2,"TYPE":"ACTION","UNIT":""},"PRESS_CONT":{"DEFAULT":false,"FLAGS":3,"ID":"PRESS_CONT","MAX":true,"MIN":false,"OPERATIONS":4,"TAB_ORDER":3,"TYPE":"ACTION","UNIT":""},"PRESS_LONG":{"CONTROL":"BUTTON.LONG","DEFAULT":false,"FLAGS":1,"ID":"PRESS_LONG","MAX":true,"MIN":false,"OPERATIONS":6,"TAB_ORDER":1,"TYPE":"ACTION","UNIT":""},"PRESS_LONG_RELEASE":{"DEFAULT":false,"FLAGS":3,"ID":"PRESS_LONG_RELEASE","MAX":true,"MIN":false,"OPERATIONS":4,"TAB_ORDER":4,"TYPE":"ACTION","UNIT":""},"PRESS_SHORT":{"CONTROL":"BUTTON.SHORT","DEFAULT":false,"FLAGS":1,"ID":"PRESS_SHORT","MAX":true,"MIN":false,"OPERATIONS":6,"TAB_ORDER":0,"TYPE":"ACTION","UNIT":""}}}
          2018-02-11 14:53:36.897 - info: hm-rpc.0 binrpc -> getParamsetDescription ["MEQ0092859:0","VALUES"]
          2018-02-11 14:53:37.023 - warn: hm-rpc.0 Send this info to developer: _id: "hm-rpc.meta.VALUES.HM-Sen-MDIR-WM55.MAINTENANCE.5"
          2018-02-11 14:53:37.025 - warn: hm-rpc.0 Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"AES_KEY":{"DEFAULT":0,"FLAGS":0,"ID":"AES_KEY","MAX":127,"MIN":0,"OPERATIONS":1,"TAB_ORDER":8,"TYPE":"INTEGER","UNIT":""},"CONFIG_PENDING":{"DEFAULT":false,"FLAGS":9,"ID":"CONFIG_PENDING","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":2,"TYPE":"BOOL","UNIT":""},"DEVICE_IN_BOOTLOADER":{"DEFAULT":false,"FLAGS":9,"ID":"DEVICE_IN_BOOTLOADER","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":6,"TYPE":"BOOL","UNIT":""},"LOWBAT":{"DEFAULT":false,"FLAGS":9,"ID":"LOWBAT","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":3,"TYPE":"BOOL","UNIT":""},"RSSI_DEVICE":{"DEFAULT":0,"FLAGS":1,"ID":"RSSI_DEVICE","MAX":2147483647,"MIN":-2147483648,"OPERATIONS":5,"TAB_ORDER":4,"TYPE":"INTEGER","UNIT":""},"RSSI_PEER":{"DEFAULT":0,"FLAGS":1,"ID":"RSSI_PEER","MAX":2147483647,"MIN":-2147483648,"OPERATIONS":5,"TAB_ORDER":5,"TYPE":"INTEGER","UNIT":""},"STICKY_UNREACH":{"DEFAULT":false,"FLAGS":25,"ID":"STICKY_UNREACH","MAX":true,"MIN":false,"OPERATIONS":7,"TAB_ORDER":1,"TYPE":"BOOL","UNIT":""},"UNREACH":{"DEFAULT":false,"FLAGS":9,"ID":"UNREACH","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":0,"TYPE":"BOOL","UNIT":""},"UPDATE_PENDING":{"DEFAULT":false,"FLAGS":9,"ID":"UPDATE_PENDING","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":7,"TYPE":"BOOL","UNIT":""}}}
          2018-02-11 14:53:37.250 - info: hm-rpc.0 binrpc -> getParamsetDescription ["MEQ0092859:1","VALUES"]
          2018-02-11 14:53:37.347 - warn: hm-rpc.0 Send this info to developer: _id: "hm-rpc.meta.VALUES.HM-Sen-MDIR-WM55.KEY.5"
          2018-02-11 14:53:37.349 - warn: hm-rpc.0 Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"INSTALL_TEST":{"DEFAULT":false,"FLAGS":3,"ID":"INSTALL_TEST","MAX":true,"MIN":false,"OPERATIONS":4,"TAB_ORDER":2,"TYPE":"ACTION","UNIT":""},"PRESS_CONT":{"DEFAULT":false,"FLAGS":3,"ID":"PRESS_CONT","MAX":true,"MIN":false,"OPERATIONS":4,"TAB_ORDER":3,"TYPE":"ACTION","UNIT":""},"PRESS_LONG":{"CONTROL":"BUTTON.LONG","DEFAULT":false,"FLAGS":1,"ID":"PRESS_LONG","MAX":true,"MIN":false,"OPERATIONS":6,"TAB_ORDER":1,"TYPE":"ACTION","UNIT":""},"PRESS_LONG_RELEASE":{"DEFAULT":false,"FLAGS":3,"ID":"PRESS_LONG_RELEASE","MAX":true,"MIN":false,"OPERATIONS":4,"TAB_ORDER":4,"TYPE":"ACTION","UNIT":""},"PRESS_SHORT":{"CONTROL":"BUTTON.SHORT","DEFAULT":false,"FLAGS":1,"ID":"PRESS_SHORT","MAX":true,"MIN":false,"OPERATIONS":6,"TAB_ORDER":0,"TYPE":"ACTION","UNIT":""}}}
          2018-02-11 14:53:37.616 - info: hm-rpc.0 binrpc -> getParamsetDescription ["MEQ0092859:3","VALUES"]
          2018-02-11 14:53:37.672 - warn: hm-rpc.0 Send this info to developer: _id: "hm-rpc.meta.VALUES.HM-Sen-MDIR-WM55.MOTION_DETECTOR.5"
          2018-02-11 14:53:37.674 - warn: hm-rpc.0 Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"BRIGHTNESS":{"DEFAULT":0,"FLAGS":1,"ID":"BRIGHTNESS","MAX":255,"MIN":0,"OPERATIONS":5,"TAB_ORDER":0,"TYPE":"INTEGER","UNIT":""},"INSTALL_TEST":{"DEFAULT":false,"FLAGS":3,"ID":"INSTALL_TEST","MAX":true,"MIN":false,"OPERATIONS":4,"TAB_ORDER":3,"TYPE":"ACTION","UNIT":""},"MOTION":{"DEFAULT":false,"FLAGS":1,"ID":"MOTION","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":2,"TYPE":"BOOL","UNIT":""}}}
          2018-02-11 14:53:37.752 - info: hm-rpc.0 binrpc -> getParamsetDescription ["NEQ0018682:0","VALUES"]
          2018-02-11 14:53:38.009 - warn: hm-rpc.0 Send this info to developer: _id: "hm-rpc.meta.VALUES.HM-OU-CFM-TW.MAINTENANCE.4"
          2018-02-11 14:53:38.011 - warn: hm-rpc.0 Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"AES_KEY":{"DEFAULT":0,"FLAGS":0,"ID":"AES_KEY","MAX":127,"MIN":0,"OPERATIONS":1,"TAB_ORDER":9,"TYPE":"INTEGER","UNIT":""},"CONFIG_PENDING":{"DEFAULT":false,"FLAGS":9,"ID":"CONFIG_PENDING","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":2,"TYPE":"BOOL","UNIT":""},"DEVICE_IN_BOOTLOADER":{"DEFAULT":false,"FLAGS":9,"ID":"DEVICE_IN_BOOTLOADER","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":7,"TYPE":"BOOL","UNIT":""},"DUTYCYCLE":{"DEFAULT":false,"FLAGS":9,"ID":"DUTYCYCLE","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":4,"TYPE":"BOOL","UNIT":""},"LOWBAT":{"DEFAULT":false,"FLAGS":9,"ID":"LOWBAT","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":3,"TYPE":"BOOL","UNIT":""},"RSSI_DEVICE":{"DEFAULT":0,"FLAGS":1,"ID":"RSSI_DEVICE","MAX":2147483647,"MIN":-2147483648,"OPERATIONS":5,"TAB_ORDER":5,"TYPE":"INTEGER","UNIT":""},"RSSI_PEER":{"DEFAULT":0,"FLAGS":1,"ID":"RSSI_PEER","MAX":2147483647,"MIN":-2147483648,"OPERATIONS":5,"TAB_ORDER":6,"TYPE":"INTEGER","UNIT":""},"STICKY_UNREACH":{"DEFAULT":false,"FLAGS":25,"ID":"STICKY_UNREACH","MAX":true,"MIN":false,"OPERATIONS":7,"TAB_ORDER":1,"TYPE":"BOOL","UNIT":""},"UNREACH":{"DEFAULT":false,"FLAGS":9,"ID":"UNREACH","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":0,"TYPE":"BOOL","UNIT":""},"UPDATE_PENDING":{"DEFAULT":false,"FLAGS":9,"ID":"UPDATE_PENDING","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":8,"TYPE":"BOOL","UNIT":""}}}
          2018-02-11 14:53:38.312 - info: hm-rpc.0 binrpc -> getParamsetDescription ["NEQ0018682:1","VALUES"]
          2018-02-11 14:53:38.427 - warn: hm-rpc.0 Send this info to developer: _id: "hm-rpc.meta.VALUES.HM-OU-CFM-TW.SIGNAL_LED.4"
          2018-02-11 14:53:38.428 - warn: hm-rpc.0 Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"INHIBIT":{"CONTROL":"NONE","DEFAULT":false,"FLAGS":1,"ID":"INHIBIT","MAX":true,"MIN":false,"OPERATIONS":7,"TAB_ORDER":2,"TYPE":"BOOL","UNIT":""},"INSTALL_TEST":{"DEFAULT":false,"FLAGS":3,"ID":"INSTALL_TEST","MAX":true,"MIN":false,"OPERATIONS":2,"TAB_ORDER":4,"TYPE":"ACTION","UNIT":""},"ON_TIME":{"CONTROL":"NONE","DEFAULT":0,"FLAGS":1,"ID":"ON_TIME","MAX":85825945.5,"MIN":0,"OPERATIONS":2,"TAB_ORDER":1,"TYPE":"FLOAT","UNIT":"s"},"STATE":{"CONTROL":"SWITCH.STATE","DEFAULT":false,"FLAGS":1,"ID":"STATE","MAX":true,"MIN":false,"OPERATIONS":7,"TAB_ORDER":0,"TYPE":"BOOL","UNIT":""},"SUBMIT":{"CONTROL":"NONE","DEFAULT":"","FLAGS":1,"ID":"SUBMIT","MAX":"","MIN":"","OPERATIONS":2,"TAB_ORDER":3,"TYPE":"STRING","UNIT":""},"WORKING":{"DEFAULT":false,"FLAGS":3,"ID":"WORKING","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":5,"TYPE":"BOOL","UNIT":""}}}
          2018-02-11 14:53:38.551 - info: hm-rpc.0 binrpc -> getParamsetDescription ["NEQ0018682:2","VALUES"]
          2018-02-11 14:53:38.644 - warn: hm-rpc.0 Send this info to developer: _id: "hm-rpc.meta.VALUES.HM-OU-CFM-TW.SIGNAL_CHIME.4"
          2018-02-11 14:53:38.646 - warn: hm-rpc.0 Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"INHIBIT":{"CONTROL":"NONE","DEFAULT":false,"FLAGS":1,"ID":"INHIBIT","MAX":true,"MIN":false,"OPERATIONS":7,"TAB_ORDER":2,"TYPE":"BOOL","UNIT":""},"INSTALL_TEST":{"DEFAULT":false,"FLAGS":3,"ID":"INSTALL_TEST","MAX":true,"MIN":false,"OPERATIONS":2,"TAB_ORDER":4,"TYPE":"ACTION","UNIT":""},"ON_TIME":{"CONTROL":"NONE","DEFAULT":0,"FLAGS":1,"ID":"ON_TIME","MAX":85825945.5,"MIN":0,"OPERATIONS":2,"TAB_ORDER":1,"TYPE":"FLOAT","UNIT":"s"},"STATE":{"CONTROL":"SWITCH.STATE","DEFAULT":false,"FLAGS":1,"ID":"STATE","MAX":true,"MIN":false,"OPERATIONS":7,"TAB_ORDER":0,"TYPE":"BOOL","UNIT":""},"SUBMIT":{"CONTROL":"NONE","DEFAULT":"","FLAGS":1,"ID":"SUBMIT","MAX":"","MIN":"","OPERATIONS":2,"TAB_ORDER":3,"TYPE":"STRING","UNIT":""},"WORKING":{"DEFAULT":false,"FLAGS":3,"ID":"WORKING","MAX":true,"MIN":false,"OPERATIONS":5,"TAB_ORDER":5,"TYPE":"BOOL","UNIT":""}}}
          Kann es sein, dass der hm-rpc auf off geht, wenn der hm-rega aktiv ist (nach konfig und erstem Download)?
          - Geräte und States wurden ordnungsgemäß eingelesen und lassen sich aus dem Objekte Reiter bedienen
          - Der Bewegungsmelder des HM-Sen-MDIR-WM55 musste erst sinnvoll in der piVCCU konfiguriert werden.
          - danach dann ähnliche Effekte wie bei Eric - läuft jetzt aber ok.
          Der Wert des Datenpunktes hm-rpc.0.updated lautet true, bleibt jedoch in rot (ACK??)
          Rainer
            apollon77 last edited by
            Aaaalso hmip ist xmlrpc und sollte damit genauso (schlecht?) klappen wie vorher.
            Updated ist meines Wissens nur ein Trigger und wird von Rega nicht bestätigt. Aber Rega ist gelaufen nach device Sync?
              @apollon77:
              Aber Rega ist gelaufen nach device Sync? `
              Auf jeden Fall - und ich vermute, dass in der Zeit der rpc-aus war
              2018-02-11 14:53:42.373 - info: host.ioBroker-BPi1 instance system.adapter.hm-rpc.0 started with pid 21661
              2018-02-11 14:53:42.400 - info: hm-rega.0 renamed hm-rpc.0.MEQ0092859.3.INSTALL_TEST to "HM-Sen-MDIR-WM55 MEQ0092859:3.INSTALL_TEST"
              2018-02-11 14:53:42.431 - info: hm-rega.0 renamed hm-rpc.0.MEQ0092859.3.BRIGHTNESS to "HM-Sen-MDIR-WM55 MEQ0092859:3.BRIGHTNESS"
              2018-02-11 14:53:42.474 - info: hm-rega.0 renamed hm-rpc.0.MEQ0092859.3 to "HM-Sen-MDIR-WM55 MEQ0092859:3"
              2018-02-11 14:53:42.554 - info: hm-rega.0 renamed hm-rpc.0.MEQ0092859.2.PRESS_SHORT to "HM-Sen-MDIR-WM55 MEQ0092859:2.PRESS_SHORT"
              2018-02-11 14:53:42.607 - info: hm-rega.0 renamed hm-rpc.0.MEQ0092859.2.PRESS_LONG_RELEASE to "HM-Sen-MDIR-WM55 MEQ0092859:2.PRESS_LONG_RELEASE"
              2018-02-11 14:53:42.647 - info: hm-rega.0 renamed hm-rpc.0.MEQ0092859.2.PRESS_LONG to "HM-Sen-MDIR-WM55 MEQ0092859:2.PRESS_LONG"
              2018-02-11 14:53:42.694 - info: hm-rega.0 renamed hm-rpc.0.MEQ0092859.2.PRESS_CONT to "HM-Sen-MDIR-WM55 MEQ0092859:2.PRESS_CONT"
              2018-02-11 14:53:42.821 - info: hm-rega.0 renamed hm-rpc.0.MEQ0092859.2.INSTALL_TEST to "HM-Sen-MDIR-WM55 MEQ0092859:2.INSTALL_TEST"
              2018-02-11 14:53:42.847 - info: hm-rega.0 renamed hm-rpc.0.MEQ0092859.2 to "HM-Sen-MDIR-WM55 MEQ0092859:2"
              2018-02-11 14:53:42.870 - info: hm-rega.0 renamed hm-rpc.0.MEQ0092859.1.PRESS_SHORT to "HM-Sen-MDIR-WM55 MEQ0092859:1.PRESS_SHORT"
              2018-02-11 14:53:42.904 - info: hm-rega.0 renamed hm-rpc.0.MEQ0092859.1.PRESS_LONG_RELEASE to "HM-Sen-MDIR-WM55 MEQ0092859:1.PRESS_LONG_RELEASE"
              2018-02-11 14:53:42.930 - info: hm-rega.0 renamed hm-rpc.0.MEQ0092859.1.PRESS_LONG to "HM-Sen-MDIR-WM55 MEQ0092859:1.PRESS_LONG"
              2018-02-11 14:53:42.974 - info: hm-rega.0 renamed hm-rpc.0.MEQ0092859.1.PRESS_CONT to "HM-Sen-MDIR-WM55 MEQ0092859:1.PRESS_CONT"
              2018-02-11 14:53:42.998 - info: hm-rega.0 renamed hm-rpc.0.MEQ0092859.1.INSTALL_TEST to "HM-Sen-MDIR-WM55 MEQ0092859:1.INSTALL_TEST"
              2018-02-11 14:53:43.022 - info: hm-rega.0 renamed hm-rpc.0.MEQ0092859.1 to "HM-Sen-MDIR-WM55 MEQ0092859:1"
              2018-02-11 14:53:43.046 - info: hm-rega.0 renamed hm-rpc.0.MEQ0092859.0.UPDATE_PENDING to "HM-Sen-MDIR-WM55 MEQ0092859:0.UPDATE_PENDING"
              2018-02-11 14:53:43.084 - info: hm-rega.0 renamed hm-rpc.0.MEQ0092859.0.UNREACH to "HM-Sen-MDIR-WM55 MEQ0092859:0.UNREACH"
              2018-02-11 14:53:43.107 - info: hm-rega.0 renamed hm-rpc.0.MEQ0092859.0.STICKY_UNREACH to "HM-Sen-MDIR-WM55 MEQ0092859:0.STICKY_UNREACH"..........
              • eric2905
                Bei mir passt das zeitlich nicht wirklich mit dem hm-rega und dessen Sync zusammen.
                Habe jetzt mal 5 Minuten keine Bewegung gehabt … und er läuft immer noch.
                Dann habe ich den hm-rega mal neu gestartet und sofort auch eine Bewegung gemacht ... wurde sofort erkannt.
                Ich sehe noch keinen Rhythmus oder andere Quelle für das seltsame Verhalten.
                Gruß,
                Eric
                  Mal auf Debug laufen lassen bei hmip?! Gibt das Infos?
                  • eric2905
                    Habe jetzt mal den hm-rpc (für IP) und den hm-rega im Debug mitlaufen lassen.
                    Am Anfang war noch alles ok.
                    Als dann keine Aktualisierungen vom BWM mehr kamen, habe ich das Log abgezogen.
                    Hier ist es (gefiltert nach hm-rpc und hm-rega (481 Zeilen):
                    ! 2018-02-11 15:41:34.176 - debug: hm-rpc.3 xml multicall : hm-rpc.3,xxxxxxxxxxxxxx:0,RSSI_DEVICE,-56 2018-02-11 15:41:34.177 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","xxxxxxxxxxxxxx:0","RSSI_DEVICE",-56] 2018-02-11 15:41:34.177 - debug: hm-rpc.3 hm-rpc.3.xxxxxxxxxxxxxx.0.RSSI_DEVICE ==> UNIT: "undefined" (min: -128, max: 127) From "-56" => "-56" 2018-02-11 15:41:34.177 - debug: hm-rpc.3 xml multicall : hm-rpc.3,xxxxxxxxxxxxxx:0,DUTY_CYCLE,false 2018-02-11 15:41:34.177 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","xxxxxxxxxxxxxx:0","DUTY_CYCLE",false] 2018-02-11 15:41:34.177 - debug: hm-rpc.3 hm-rpc.3.xxxxxxxxxxxxxx.0.DUTY_CYCLE ==> UNIT: "undefined" (min: false, max: true) From "false" => "false" 2018-02-11 15:41:34.177 - debug: hm-rpc.3 xml multicall : hm-rpc.3,xxxxxxxxxxxxxx:0,UNREACH,false 2018-02-11 15:41:34.177 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","xxxxxxxxxxxxxx:0","UNREACH",false] 2018-02-11 15:41:34.177 - debug: hm-rpc.3 hm-rpc.3.xxxxxxxxxxxxxx.0.UNREACH ==> UNIT: "undefined" (min: false, max: true) From "false" => "false" 2018-02-11 15:41:34.177 - debug: hm-rpc.3 xml multicall : hm-rpc.3,xxxxxxxxxxxxxx:0,RSSI_PEER,-97 2018-02-11 15:41:34.177 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","xxxxxxxxxxxxxx:0","RSSI_PEER",-97] 2018-02-11 15:41:34.177 - debug: hm-rpc.3 hm-rpc.3.xxxxxxxxxxxxxx.0.RSSI_PEER ==> UNIT: "undefined" (min: -128, max: 127) From "-97" => "-97" 2018-02-11 15:41:34.178 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.xxxxxxxxxxxxxx.0.RSSI_DEVICE {"val":-56,"ack":true,"ts":1518360094177,"q":0,"from":"system.adapter.hm-rpc.3","lc":1518360094177} 2018-02-11 15:41:34.178 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.xxxxxxxxxxxxxx.0.DUTY_CYCLE {"val":false,"ack":true,"ts":1518360094177,"q":0,"from":"system.adapter.hm-rpc.3","lc":1513962866944} 2018-02-11 15:41:34.178 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.xxxxxxxxxxxxxx.0.UNREACH {"val":false,"ack":true,"ts":1518360094177,"q":0,"from":"system.adapter.hm-rpc.3","lc":1513962866944} 2018-02-11 15:41:34.178 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.xxxxxxxxxxxxxx.0.RSSI_PEER {"val":-97,"ack":true,"ts":1518360094178,"q":0,"from":"system.adapter.hm-rpc.3","lc":1518360094178} 2018-02-11 15:41:34.185 - debug: hm-rpc.3 xml multicall : hm-rpc.3,xxxxxxxxxxxxxx:2,STATE,true 2018-02-11 15:41:34.185 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","xxxxxxxxxxxxxx:2","STATE",true] 2018-02-11 15:41:34.185 - debug: hm-rpc.3 hm-rpc.3.xxxxxxxxxxxxxx.2.STATE ==> UNIT: "undefined" (min: false, max: true) From "true" => "true" 2018-02-11 15:41:34.186 - debug: hm-rpc.3 xml multicall : hm-rpc.3,xxxxxxxxxxxxxx:2,SECTION,2 2018-02-11 15:41:34.186 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","xxxxxxxxxxxxxx:2","SECTION",2] 2018-02-11 15:41:34.186 - debug: hm-rpc.3 hm-rpc.3.xxxxxxxxxxxxxx.2.SECTION ==> UNIT: "undefined" (min: 0, max: 15) From "2" => "2" 2018-02-11 15:41:34.186 - debug: hm-rpc.3 xml multicall : hm-rpc.3,xxxxxxxxxxxxxx:2,PROCESS,0 2018-02-11 15:41:34.186 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","xxxxxxxxxxxxxx:2","PROCESS",0] 2018-02-11 15:41:34.186 - debug: hm-rpc.3 hm-rpc.3.xxxxxxxxxxxxxx.2.PROCESS ==> UNIT: "undefined" (min: STABLE, max: NOT_STABLE) From "0" => "0" 2018-02-11 15:41:34.187 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.xxxxxxxxxxxxxx.2.STATE {"val":true,"ack":true,"ts":1518360094186,"q":0,"from":"system.adapter.hm-rpc.3","lc":1514926578543} 2018-02-11 15:41:34.187 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.xxxxxxxxxxxxxx.2.SECTION {"val":2,"ack":true,"ts":1518360094186,"q":0,"from":"system.adapter.hm-rpc.3","lc":1514926578543} 2018-02-11 15:41:34.187 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.xxxxxxxxxxxxxx.2.PROCESS {"val":0,"ack":true,"ts":1518360094186,"q":0,"from":"system.adapter.hm-rpc.3","lc":1513962866954} 2018-02-11 15:41:34.196 - debug: hm-rpc.3 xml multicall : hm-rpc.3,xxxxxxxxxxxxxx:3,STATE,true 2018-02-11 15:41:34.196 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","xxxxxxxxxxxxxx:3","STATE",true] 2018-02-11 15:41:34.196 - debug: hm-rpc.3 hm-rpc.3.xxxxxxxxxxxxxx.3.STATE ==> UNIT: "undefined" (min: false, max: true) From "true" => "true" 2018-02-11 15:41:34.196 - debug: hm-rpc.3 xml multicall : hm-rpc.3,xxxxxxxxxxxxxx:3,SECTION,2 2018-02-11 15:41:34.196 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","xxxxxxxxxxxxxx:3","SECTION",2] 2018-02-11 15:41:34.196 - debug: hm-rpc.3 hm-rpc.3.xxxxxxxxxxxxxx.3.SECTION ==> UNIT: "undefined" (min: 0, max: 15) From "2" => "2" 2018-02-11 15:41:34.197 - debug: hm-rpc.3 xml multicall : hm-rpc.3,xxxxxxxxxxxxxx:3,PROCESS,0 2018-02-11 15:41:34.197 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","xxxxxxxxxxxxxx:3","PROCESS",0] 2018-02-11 15:41:34.197 - debug: hm-rpc.3 hm-rpc.3.xxxxxxxxxxxxxx.3.PROCESS ==> UNIT: "undefined" (min: STABLE, max: NOT_STABLE) From "0" => "0" 2018-02-11 15:41:34.198 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.xxxxxxxxxxxxxx.3.STATE {"val":true,"ack":true,"ts":1518360094197,"q":0,"from":"system.adapter.hm-rpc.3","lc":1514926578552} 2018-02-11 15:41:34.198 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.xxxxxxxxxxxxxx.3.SECTION {"val":2,"ack":true,"ts":1518360094197,"q":0,"from":"system.adapter.hm-rpc.3","lc":1514926578553} 2018-02-11 15:41:34.198 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.xxxxxxxxxxxxxx.3.PROCESS {"val":0,"ack":true,"ts":1518360094197,"q":0,"from":"system.adapter.hm-rpc.3","lc":1513962866969} 2018-02-11 15:41:34.205 - debug: hm-rpc.3 xml multicall : hm-rpc.3,xxxxxxxxxxxxxx:4,STATE,false 2018-02-11 15:41:34.205 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","xxxxxxxxxxxxxx:4","STATE",false] 2018-02-11 15:41:34.205 - debug: hm-rpc.3 hm-rpc.3.xxxxxxxxxxxxxx.4.STATE ==> UNIT: "undefined" (min: false, max: true) From "false" => "false" 2018-02-11 15:41:34.205 - debug: hm-rpc.3 xml multicall : hm-rpc.3,xxxxxxxxxxxxxx:4,SECTION,0 2018-02-11 15:41:34.205 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","xxxxxxxxxxxxxx:4","SECTION",0] 2018-02-11 15:41:34.205 - debug: hm-rpc.3 hm-rpc.3.xxxxxxxxxxxxxx.4.SECTION ==> UNIT: "undefined" (min: 0, max: 15) From "0" => "0" 2018-02-11 15:41:34.205 - debug: hm-rpc.3 xml multicall : hm-rpc.3,xxxxxxxxxxxxxx:4,PROCESS,0 2018-02-11 15:41:34.205 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","xxxxxxxxxxxxxx:4","PROCESS",0] 2018-02-11 15:41:34.205 - debug: hm-rpc.3 hm-rpc.3.xxxxxxxxxxxxxx.4.PROCESS ==> UNIT: "undefined" (min: STABLE, max: NOT_STABLE) From "0" => "0" 2018-02-11 15:41:34.207 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.xxxxxxxxxxxxxx.4.STATE {"val":false,"ack":true,"ts":1518360094205,"q":0,"from":"system.adapter.hm-rpc.3","lc":1513962866977} 2018-02-11 15:41:34.207 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.xxxxxxxxxxxxxx.4.SECTION {"val":0,"ack":true,"ts":1518360094206,"q":0,"from":"system.adapter.hm-rpc.3","lc":1513962866977} 2018-02-11 15:41:34.207 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.xxxxxxxxxxxxxx.4.PROCESS {"val":0,"ack":true,"ts":1518360094206,"q":0,"from":"system.adapter.hm-rpc.3","lc":1513962866977} 2018-02-11 15:41:34.230 - debug: hm-rpc.3 xml multicall : hm-rpc.3,xxxxxxxxxxxxxx:5,STATE,false 2018-02-11 15:41:34.230 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","xxxxxxxxxxxxxx:5","STATE",false] 2018-02-11 15:41:34.230 - debug: hm-rpc.3 hm-rpc.3.xxxxxxxxxxxxxx.5.STATE ==> UNIT: "undefined" (min: false, max: true) From "false" => "false" 2018-02-11 15:41:34.230 - debug: hm-rpc.3 xml multicall : hm-rpc.3,xxxxxxxxxxxxxx:5,SECTION,0 2018-02-11 15:41:34.231 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","xxxxxxxxxxxxxx:5","SECTION",0] 2018-02-11 15:41:34.231 - debug: hm-rpc.3 hm-rpc.3.xxxxxxxxxxxxxx.5.SECTION ==> UNIT: "undefined" (min: 0, max: 15) From "0" => "0" 2018-02-11 15:41:34.231 - debug: hm-rpc.3 xml multicall : hm-rpc.3,xxxxxxxxxxxxxx:5,PROCESS,0 2018-02-11 15:41:34.231 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","xxxxxxxxxxxxxx:5","PROCESS",0] 2018-02-11 15:41:34.231 - debug: hm-rpc.3 hm-rpc.3.xxxxxxxxxxxxxx.5.PROCESS ==> UNIT: "undefined" (min: STABLE, max: NOT_STABLE) From "0" => "0" 2018-02-11 15:41:34.232 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.xxxxxxxxxxxxxx.5.STATE {"val":false,"ack":true,"ts":1518360094231,"q":0,"from":"system.adapter.hm-rpc.3","lc":1513962866992} 2018-02-11 15:41:34.232 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.xxxxxxxxxxxxxx.5.SECTION {"val":0,"ack":true,"ts":1518360094231,"q":0,"from":"system.adapter.hm-rpc.3","lc":1513962866992} 2018-02-11 15:41:34.232 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.xxxxxxxxxxxxxx.5.PROCESS {"val":0,"ack":true,"ts":1518360094231,"q":0,"from":"system.adapter.hm-rpc.3","lc":1513962866992} 2018-02-11 15:41:34.240 - debug: hm-rpc.3 xml multicall : hm-rpc.3,xxxxxxxxxxxxxx:6,ENERGY_COUNTER_OVERFLOW,false 2018-02-11 15:41:34.240 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","xxxxxxxxxxxxxx:6","ENERGY_COUNTER_OVERFLOW",false] 2018-02-11 15:41:34.240 - debug: hm-rpc.3 hm-rpc.3.xxxxxxxxxxxxxx.6.ENERGY_COUNTER_OVERFLOW ==> UNIT: "undefined" (min: false, max: true) From "false" => "false" 2018-02-11 15:41:34.240 - debug: hm-rpc.3 xml multicall : hm-rpc.3,xxxxxxxxxxxxxx:6,POWER,88.45 2018-02-11 15:41:34.240 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","xxxxxxxxxxxxxx:6","POWER",88.45] 2018-02-11 15:41:34.240 - debug: hm-rpc.3 hm-rpc.3.xxxxxxxxxxxxxx.6.POWER ==> UNIT: "W" (min: 0, max: 163830) From "88.45" => "88.45" 2018-02-11 15:41:34.240 - debug: hm-rpc.3 xml multicall : hm-rpc.3,xxxxxxxxxxxxxx:6,VOLTAGE,235.1 2018-02-11 15:41:34.240 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","xxxxxxxxxxxxxx:6","VOLTAGE",235.1] 2018-02-11 15:41:34.240 - debug: hm-rpc.3 hm-rpc.3.xxxxxxxxxxxxxx.6.VOLTAGE ==> UNIT: "V" (min: 0, max: 409.5) From "235.1" => "235.1" 2018-02-11 15:41:34.240 - debug: hm-rpc.3 xml multicall : hm-rpc.3,xxxxxxxxxxxxxx:6,ENERGY_COUNTER,52634.2 2018-02-11 15:41:34.240 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","xxxxxxxxxxxxxx:6","ENERGY_COUNTER",52634.2] 2018-02-11 15:41:34.240 - debug: hm-rpc.3 hm-rpc.3.xxxxxxxxxxxxxx.6.ENERGY_COUNTER ==> UNIT: "Wh" (min: 0, max: 838859.1) From "52634.2" => "52634.2" 2018-02-11 15:41:34.240 - debug: hm-rpc.3 xml multicall : hm-rpc.3,xxxxxxxxxxxxxx:6,CURRENT,390 2018-02-11 15:41:34.240 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","xxxxxxxxxxxxxx:6","CURRENT",390] 2018-02-11 15:41:34.240 - debug: hm-rpc.3 hm-rpc.3.xxxxxxxxxxxxxx.6.CURRENT ==> UNIT: "mA" (min: 0, max: 65535) From "390" => "390" 2018-02-11 15:41:34.240 - debug: hm-rpc.3 xml multicall : hm-rpc.3,xxxxxxxxxxxxxx:6,FREQUENCY,49.97 2018-02-11 15:41:34.241 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","xxxxxxxxxxxxxx:6","FREQUENCY",49.97] 2018-02-11 15:41:34.241 - debug: hm-rpc.3 hm-rpc.3.xxxxxxxxxxxxxx.6.FREQUENCY ==> UNIT: "Hz" (min: 29.52, max: 70.47) From "49.97" => "49.97" 2018-02-11 15:41:34.243 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.xxxxxxxxxxxxxx.6.ENERGY_COUNTER_OVERFLOW {"val":false,"ack":true,"ts":1518360094241,"q":0,"from":"system.adapter.hm-rpc.3","lc":1513962867008} 2018-02-11 15:41:34.243 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.xxxxxxxxxxxxxx.6.POWER {"val":88.45,"ack":true,"ts":1518360094241,"q":0,"from":"system.adapter.hm-rpc.3","lc":1518360094241} 2018-02-11 15:41:34.243 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.xxxxxxxxxxxxxx.6.VOLTAGE {"val":235.1,"ack":true,"ts":1518360094241,"q":0,"from":"system.adapter.hm-rpc.3","lc":1518360064253} 2018-02-11 15:41:34.243 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.xxxxxxxxxxxxxx.6.ENERGY_COUNTER {"val":52634.2,"ack":true,"ts":1518360094241,"q":0,"from":"system.adapter.hm-rpc.3","lc":1518360094241} 2018-02-11 15:41:34.243 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.xxxxxxxxxxxxxx.6.CURRENT {"val":390,"ack":true,"ts":1518360094242,"q":0,"from":"system.adapter.hm-rpc.3","lc":1518360094242} 2018-02-11 15:41:34.243 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.xxxxxxxxxxxxxx.6.FREQUENCY {"val":49.97,"ack":true,"ts":1518360094242,"q":0,"from":"system.adapter.hm-rpc.3","lc":1518360094242} 2018-02-11 15:41:37.958 - debug: hm-rpc.3 xml multicall : hm-rpc.3,yyyyyyyyyyyyyy:0,SABOTAGE,false 2018-02-11 15:41:37.958 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","yyyyyyyyyyyyyy:0","SABOTAGE",false] 2018-02-11 15:41:37.958 - debug: hm-rpc.3 hm-rpc.3.yyyyyyyyyyyyyy.0.SABOTAGE ==> UNIT: "undefined" (min: false, max: true) From "false" => "false" 2018-02-11 15:41:37.958 - debug: hm-rpc.3 xml multicall : hm-rpc.3,yyyyyyyyyyyyyy:0,DUTY_CYCLE,false 2018-02-11 15:41:37.958 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","yyyyyyyyyyyyyy:0","DUTY_CYCLE",false] 2018-02-11 15:41:37.958 - debug: hm-rpc.3 hm-rpc.3.yyyyyyyyyyyyyy.0.DUTY_CYCLE ==> UNIT: "undefined" (min: false, max: true) From "false" => "false" 2018-02-11 15:41:37.958 - debug: hm-rpc.3 xml multicall : hm-rpc.3,yyyyyyyyyyyyyy:0,LOW_BAT,false 2018-02-11 15:41:37.958 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","yyyyyyyyyyyyyy:0","LOW_BAT",false] 2018-02-11 15:41:37.958 - debug: hm-rpc.3 hm-rpc.3.yyyyyyyyyyyyyy.0.LOW_BAT ==> UNIT: "undefined" (min: false, max: true) From "false" => "false" 2018-02-11 15:41:37.958 - debug: hm-rpc.3 xml multicall : hm-rpc.3,yyyyyyyyyyyyyy:0,UNREACH,false 2018-02-11 15:41:37.958 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","yyyyyyyyyyyyyy:0","UNREACH",false] 2018-02-11 15:41:37.958 - debug: hm-rpc.3 hm-rpc.3.yyyyyyyyyyyyyy.0.UNREACH ==> UNIT: "undefined" (min: false, max: true) From "false" => "false" 2018-02-11 15:41:37.959 - debug: hm-rpc.3 xml multicall : hm-rpc.3,yyyyyyyyyyyyyy:0,RSSI_DEVICE,-58 2018-02-11 15:41:37.959 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","yyyyyyyyyyyyyy:0","RSSI_DEVICE",-58] 2018-02-11 15:41:37.959 - debug: hm-rpc.3 hm-rpc.3.yyyyyyyyyyyyyy.0.RSSI_DEVICE ==> UNIT: "undefined" (min: -128, max: 127) From "-58" => "-58" 2018-02-11 15:41:37.959 - debug: hm-rpc.3 xml multicall : hm-rpc.3,yyyyyyyyyyyyyy:0,OPERATING_VOLTAGE,2.7 2018-02-11 15:41:37.959 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","yyyyyyyyyyyyyy:0","OPERATING_VOLTAGE",2.7] 2018-02-11 15:41:37.959 - debug: hm-rpc.3 hm-rpc.3.yyyyyyyyyyyyyy.0.OPERATING_VOLTAGE ==> UNIT: "undefined" (min: 0, max: 25.2) From "2.7" => "2.7" 2018-02-11 15:41:37.959 - debug: hm-rpc.3 xml multicall : hm-rpc.3,yyyyyyyyyyyyyy:0,RSSI_PEER,-66 2018-02-11 15:41:37.959 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","yyyyyyyyyyyyyy:0","RSSI_PEER",-66] 2018-02-11 15:41:37.959 - debug: hm-rpc.3 hm-rpc.3.yyyyyyyyyyyyyy.0.RSSI_PEER ==> UNIT: "undefined" (min: -128, max: 127) From "-66" => "-66" 2018-02-11 15:41:37.959 - debug: hm-rpc.3 xml multicall : hm-rpc.3,yyyyyyyyyyyyyy:0,ERROR_CODE,0 2018-02-11 15:41:37.959 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","yyyyyyyyyyyyyy:0","ERROR_CODE",0] 2018-02-11 15:41:37.959 - debug: hm-rpc.3 hm-rpc.3.yyyyyyyyyyyyyy.0.ERROR_CODE ==> UNIT: "undefined" (min: 0, max: 255) From "0" => "0" 2018-02-11 15:41:37.960 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.yyyyyyyyyyyyyy.0.SABOTAGE {"val":false,"ack":true,"ts":1518360097959,"q":0,"from":"system.adapter.hm-rpc.3","lc":1518356947965} 2018-02-11 15:41:37.961 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.yyyyyyyyyyyyyy.0.DUTY_CYCLE {"val":false,"ack":true,"ts":1518360097959,"q":0,"from":"system.adapter.hm-rpc.3","lc":1518356947965} 2018-02-11 15:41:37.961 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.yyyyyyyyyyyyyy.0.LOW_BAT {"val":false,"ack":true,"ts":1518360097959,"q":0,"from":"system.adapter.hm-rpc.3","lc":1518356947965} 2018-02-11 15:41:37.961 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.yyyyyyyyyyyyyy.0.UNREACH {"val":false,"ack":true,"ts":1518360097959,"q":0,"from":"system.adapter.hm-rpc.3","lc":1518356947965} 2018-02-11 15:41:37.961 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.yyyyyyyyyyyyyy.0.RSSI_DEVICE {"val":-58,"ack":true,"ts":1518360097959,"q":0,"from":"system.adapter.hm-rpc.3","lc":1518360097959} 2018-02-11 15:41:37.961 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.yyyyyyyyyyyyyy.0.OPERATING_VOLTAGE {"val":2.7,"ack":true,"ts":1518360097959,"q":0,"from":"system.adapter.hm-rpc.3","lc":1518356947973} 2018-02-11 15:41:37.961 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.yyyyyyyyyyyyyy.0.RSSI_PEER {"val":-66,"ack":true,"ts":1518360097959,"q":0,"from":"system.adapter.hm-rpc.3","lc":1518360097959} 2018-02-11 15:41:37.961 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.yyyyyyyyyyyyyy.0.ERROR_CODE {"val":0,"ack":true,"ts":1518360097960,"q":0,"from":"system.adapter.hm-rpc.3","lc":1518356947973} 2018-02-11 15:41:37.969 - debug: hm-rpc.3 xml multicall : hm-rpc.3,yyyyyyyyyyyyyy:1,ILLUMINATION,8 2018-02-11 15:41:37.969 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","yyyyyyyyyyyyyy:1","ILLUMINATION",8] 2018-02-11 15:41:37.969 - debug: hm-rpc.3 hm-rpc.3.yyyyyyyyyyyyyy.1.ILLUMINATION ==> UNIT: "undefined" (min: 0, max: 163830) From "8" => "8" 2018-02-11 15:41:37.969 - debug: hm-rpc.3 xml multicall : hm-rpc.3,yyyyyyyyyyyyyy:1,MOTION,true 2018-02-11 15:41:37.969 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","yyyyyyyyyyyyyy:1","MOTION",true] 2018-02-11 15:41:37.969 - debug: hm-rpc.3 hm-rpc.3.yyyyyyyyyyyyyy.1.MOTION ==> UNIT: "undefined" (min: false, max: true) From "true" => "true" 2018-02-11 15:41:37.969 - debug: hm-rpc.3 xml multicall : hm-rpc.3,yyyyyyyyyyyyyy:1,MOTION_DETECTION_ACTIVE,true 2018-02-11 15:41:37.969 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","yyyyyyyyyyyyyy:1","MOTION_DETECTION_ACTIVE",true] 2018-02-11 15:41:37.969 - debug: hm-rpc.3 hm-rpc.3.yyyyyyyyyyyyyy.1.MOTION_DETECTION_ACTIVE ==> UNIT: "undefined" (min: false, max: true) From "true" => "true" 2018-02-11 15:41:37.971 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.yyyyyyyyyyyyyy.1.ILLUMINATION {"val":8,"ack":true,"ts":1518360097970,"q":0,"from":"system.adapter.hm-rpc.3","lc":1518358948928} 2018-02-11 15:41:37.971 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.yyyyyyyyyyyyyy.1.MOTION {"val":true,"ack":true,"ts":1518360097970,"q":0,"from":"system.adapter.hm-rpc.3","lc":1518360097970} 2018-02-11 15:41:37.971 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.yyyyyyyyyyyyyy.1.MOTION_DETECTION_ACTIVE {"val":true,"ack":true,"ts":1518360097970,"q":0,"from":"system.adapter.hm-rpc.3","lc":1518356947980} 2018-02-11 15:41:38.453 - debug: hm-rega.1 --> polling.fn 2018-02-11 15:41:38.454 - debug: hm-rega.1 --> programs.fn 2018-02-11 15:41:38.454 - debug: hm-rega.1 --> !# polling.fn 1.2 !# !# Dieses Script gibt die Werte aller Systemvariablen als 2018-02-11 15:41:38.461 - debug: hm-rega.1 <-- {"1235":[false,"1970-01-01 01:00:00"], "950":[true,"2018-01-02 21:40:31"], "5589":[true,"2018-02-10 19:05:48"], "6348":[false,"2018-02-11 07:30:00"], "5895":[false,"2018-01-02 21:40:29"], "5666":[false,"2018-01-11 21:03:30"], "6577":["keiner","2018-01-14 19:20:16"], "6405":[0,"2018-01-02 21:40:29"], "5501":[true,"2018-02-10 19:04:49"], "5502":[false,"2018-02-08 21:24:19"], "6076":[true,"2018-02-10 19:05:48"], "6644":["Test","2018-01-28 04:08:17"], "40":[0,"2018-01-02 21:40:30"], "41":[2,"2018-02-11 15:41:37"]} 2018-02-11 15:41:38.514 - debug: hm-rega.1 --> !# programs.fn 1.3 !# Dieses Script gibt eine Liste der Programme als JSON Stri 2018-02-11 15:41:38.524 - debug: hm-rega.1 <-- {"5575":{"Name":"Anwesenheit_iPhones","TypeName":"PROGRAM","PrgInfo":"", "Active":true,"Timestamp":"2018-02-10 19:04:49"}, "6276":{"Name":"P_Astro_setze_Nacht","TypeName":"PROGRAM","PrgInfo":"", "Active":true,"Timestamp":"2018-02-11 07:30:00"}, "6369":{"Name":"P_Astro_setze_Tag","TypeName":"PROGRAM","PrgInfo":"", "Active":true,"Timestamp":"2018-02-11 07:30:00"}, "5732":{"Name":"Prg_Abfrage_Fenster_Sprache","TypeName":"PROGRAM","PrgInfo":"", "Active":false,"Timestamp":"1970-01-01 01:00:00"}, "5658":{"Name":"Prg_Ku_Warmwasser","TypeName":"PROGRAM","PrgInfo":"", "Active":true,"Timestamp":"2018-01-11 21:03:30"}, "6523":{"Name":"Prg_Rauchmeldung","TypeName":"PROGRAM","PrgInfo":"", "Active":true,"Timestamp":"1970-01-01 01:00:00"}, "5535":{"Name":"Push_Zone_Eric","TypeName":"PROGRAM","PrgInfo":"", "Active":true,"Timestamp":"2018-02-10 19:04:49"}, "5548":{"Name":"Push_Zone_Zabka","TypeName":"PROGRAM","PrgInfo":"", "Active":true,"Timestamp":"2018-02-10 19:05:48"}, "5432":{"Name":"Strommesser_Basiswert_setzen","TypeName":"PROGRAM","PrgInfo":"", "Active":false,"Timestamp":"1970-01-01 01:00:00"}} 2018-02-11 15:41:38.568 - debug: hm-rega.1 --> dutycycle.fn 2018-02-11 15:41:38.569 - debug: hm-rega.1 --> !# dutycycle.fn 0.3 string stderr; string stdout; system.Exec("/bin/sh -c '" 2018-02-11 15:41:38.631 - debug: hm-rega.1 <-- {ADDRESS zzzzzzzzzz CONNECTED 1 DEFAULT 1 DESCRIPTION {} DUTY_CYCLE 16 FIRMWARE_VERSION 2.8.5 TYPE CCU2} 2018-02-11 15:41:38.632 - debug: hm-rega.1 Dutycycle: hm-rega.1.zzzzzzzzzz.0.DUTY_CYCLE => 16 2018-02-11 15:41:38.632 - debug: hm-rega.1 Dutycycle: hm-rega.1.zzzzzzzzzz.0.CONNECTED => 1 2018-02-11 15:41:38.633 - debug: hm-rega.1 Dutycycle: hm-rega.1.zzzzzzzzzz.0.DEFAULT => 1 2018-02-11 15:41:38.633 - debug: hm-rega.1 Dutycycle: hm-rega.1.zzzzzzzzzz.0.FIRMWARE_VERSION => 2.8.5 2018-02-11 15:41:40.050 - info: sql.0 enabled logging of paw.0.TabletFlur.info.battery.level 2018-02-11 15:41:41.883 - info: web.0 Connected system.user.admin 2018-02-11 15:41:42.470 - info: radar.0 ScanAll: From all 1 devices dedected 1 are whoHere: Zabka-iPhone 2018-02-11 15:41:42.780 - info: javascript.0 script.js.Aktiv.Heizung.Aufheizmessung: Änderung Status Aktor FBH Arbeitszimmer: 55--> 55 (ack=true, from=system.adapter.hm-rpc.2) status bisher=true 2018-02-11 15:41:49.823 - info: sql.0 enabled logging of paw.0.TabletFlur.info.battery.level 2018-02-11 15:41:50.028 - info: javascript.0 script.js.Aktiv.Heizung.Aufheizmessung: Änderung Status Aktor FBH Hauswirtschaftsraum: 0--> 0 (ack=true, from=system.adapter.hm-rpc.2) status bisher=false 2018-02-11 15:41:52.668 - info: javascript.0 script.js.Aktiv.Heizung.Aufheizmessung: Änderung Status Aktor FBH Kueche: 0--> 0 (ack=true, from=system.adapter.hm-rpc.2) status bisher=false 2018-02-11 15:41:52.962 - debug: hm-rpc.3 xml multicall : hm-rpc.3,yyyyyyyyyyyyyy:0,SABOTAGE,false 2018-02-11 15:41:52.962 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","yyyyyyyyyyyyyy:0","SABOTAGE",false] 2018-02-11 15:41:52.962 - debug: hm-rpc.3 hm-rpc.3.yyyyyyyyyyyyyy.0.SABOTAGE ==> UNIT: "undefined" (min: false, max: true) From "false" => "false" 2018-02-11 15:41:52.962 - debug: hm-rpc.3 xml multicall : hm-rpc.3,yyyyyyyyyyyyyy:0,DUTY_CYCLE,false 2018-02-11 15:41:52.962 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","yyyyyyyyyyyyyy:0","DUTY_CYCLE",false] 2018-02-11 15:41:52.962 - debug: hm-rpc.3 hm-rpc.3.yyyyyyyyyyyyyy.0.DUTY_CYCLE ==> UNIT: "undefined" (min: false, max: true) From "false" => "false" 2018-02-11 15:41:52.962 - debug: hm-rpc.3 xml multicall : hm-rpc.3,yyyyyyyyyyyyyy:0,LOW_BAT,false 2018-02-11 15:41:52.962 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","yyyyyyyyyyyyyy:0","LOW_BAT",false] 2018-02-11 15:41:52.962 - debug: hm-rpc.3 hm-rpc.3.yyyyyyyyyyyyyy.0.LOW_BAT ==> UNIT: "undefined" (min: false, max: true) From "false" => "false" 2018-02-11 15:41:52.962 - debug: hm-rpc.3 xml multicall : hm-rpc.3,yyyyyyyyyyyyyy:0,UNREACH,false 2018-02-11 15:41:52.962 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","yyyyyyyyyyyyyy:0","UNREACH",false] 2018-02-11 15:41:52.962 - debug: hm-rpc.3 hm-rpc.3.yyyyyyyyyyyyyy.0.UNREACH ==> UNIT: "undefined" (min: false, max: true) From "false" => "false" 2018-02-11 15:41:52.963 - debug: hm-rpc.3 xml multicall : hm-rpc.3,yyyyyyyyyyyyyy:0,RSSI_DEVICE,-55 2018-02-11 15:41:52.963 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","yyyyyyyyyyyyyy:0","RSSI_DEVICE",-55] 2018-02-11 15:41:52.963 - debug: hm-rpc.3 hm-rpc.3.yyyyyyyyyyyyyy.0.RSSI_DEVICE ==> UNIT: "undefined" (min: -128, max: 127) From "-55" => "-55" 2018-02-11 15:41:52.963 - debug: hm-rpc.3 xml multicall : hm-rpc.3,yyyyyyyyyyyyyy:0,OPERATING_VOLTAGE,2.7 2018-02-11 15:41:52.963 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","yyyyyyyyyyyyyy:0","OPERATING_VOLTAGE",2.7] 2018-02-11 15:41:52.963 - debug: hm-rpc.3 hm-rpc.3.yyyyyyyyyyyyyy.0.OPERATING_VOLTAGE ==> UNIT: "undefined" (min: 0, max: 25.2) From "2.7" => "2.7" 2018-02-11 15:41:52.963 - debug: hm-rpc.3 xml multicall : hm-rpc.3,yyyyyyyyyyyyyy:0,RSSI_PEER,-84 2018-02-11 15:41:52.963 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","yyyyyyyyyyyyyy:0","RSSI_PEER",-84] 2018-02-11 15:41:52.963 - debug: hm-rpc.3 hm-rpc.3.yyyyyyyyyyyyyy.0.RSSI_PEER ==> UNIT: "undefined" (min: -128, max: 127) From "-84" => "-84" 2018-02-11 15:41:52.963 - debug: hm-rpc.3 xml multicall : hm-rpc.3,yyyyyyyyyyyyyy:0,ERROR_CODE,0 2018-02-11 15:41:52.963 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","yyyyyyyyyyyyyy:0","ERROR_CODE",0] 2018-02-11 15:41:52.963 - debug: hm-rpc.3 hm-rpc.3.yyyyyyyyyyyyyy.0.ERROR_CODE ==> UNIT: "undefined" (min: 0, max: 255) From "0" => "0" 2018-02-11 15:41:52.965 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.yyyyyyyyyyyyyy.0.SABOTAGE {"val":false,"ack":true,"ts":1518360112963,"q":0,"from":"system.adapter.hm-rpc.3","lc":1518356947965} 2018-02-11 15:41:52.965 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.yyyyyyyyyyyyyy.0.DUTY_CYCLE {"val":false,"ack":true,"ts":1518360112963,"q":0,"from":"system.adapter.hm-rpc.3","lc":1518356947965} 2018-02-11 15:41:52.965 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.yyyyyyyyyyyyyy.0.LOW_BAT {"val":false,"ack":true,"ts":1518360112963,"q":0,"from":"system.adapter.hm-rpc.3","lc":1518356947965} 2018-02-11 15:41:52.965 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.yyyyyyyyyyyyyy.0.UNREACH {"val":false,"ack":true,"ts":1518360112964,"q":0,"from":"system.adapter.hm-rpc.3","lc":1518356947965} 2018-02-11 15:41:52.965 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.yyyyyyyyyyyyyy.0.RSSI_DEVICE {"val":-55,"ack":true,"ts":1518360112964,"q":0,"from":"system.adapter.hm-rpc.3","lc":1518360112964} 2018-02-11 15:41:52.966 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.yyyyyyyyyyyyyy.0.OPERATING_VOLTAGE {"val":2.7,"ack":true,"ts":1518360112964,"q":0,"from":"system.adapter.hm-rpc.3","lc":1518356947973} 2018-02-11 15:41:52.966 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.yyyyyyyyyyyyyy.0.RSSI_PEER {"val":-84,"ack":true,"ts":1518360112965,"q":0,"from":"system.adapter.hm-rpc.3","lc":1518360112965} 2018-02-11 15:41:52.966 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.yyyyyyyyyyyyyy.0.ERROR_CODE {"val":0,"ack":true,"ts":1518360112965,"q":0,"from":"system.adapter.hm-rpc.3","lc":1518356947973} 2018-02-11 15:41:52.973 - debug: hm-rpc.3 xml multicall : hm-rpc.3,yyyyyyyyyyyyyy:1,ILLUMINATION,8 2018-02-11 15:41:52.973 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","yyyyyyyyyyyyyy:1","ILLUMINATION",8] 2018-02-11 15:41:52.973 - debug: hm-rpc.3 hm-rpc.3.yyyyyyyyyyyyyy.1.ILLUMINATION ==> UNIT: "undefined" (min: 0, max: 163830) From "8" => "8" 2018-02-11 15:41:52.973 - debug: hm-rpc.3 xml multicall : hm-rpc.3,yyyyyyyyyyyyyy:1,MOTION,false 2018-02-11 15:41:52.973 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","yyyyyyyyyyyyyy:1","MOTION",false] 2018-02-11 15:41:52.973 - debug: hm-rpc.3 hm-rpc.3.yyyyyyyyyyyyyy.1.MOTION ==> UNIT: "undefined" (min: false, max: true) From "false" => "false" 2018-02-11 15:41:52.973 - debug: hm-rpc.3 xml multicall : hm-rpc.3,yyyyyyyyyyyyyy:1,MOTION_DETECTION_ACTIVE,true 2018-02-11 15:41:52.973 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","yyyyyyyyyyyyyy:1","MOTION_DETECTION_ACTIVE",true] 2018-02-11 15:41:52.973 - debug: hm-rpc.3 hm-rpc.3.yyyyyyyyyyyyyy.1.MOTION_DETECTION_ACTIVE ==> UNIT: "undefined" (min: false, max: true) From "true" => "true" 2018-02-11 15:41:52.974 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.yyyyyyyyyyyyyy.1.ILLUMINATION {"val":8,"ack":true,"ts":1518360112973,"q":0,"from":"system.adapter.hm-rpc.3","lc":1518358948928} 2018-02-11 15:41:52.974 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.yyyyyyyyyyyyyy.1.MOTION {"val":false,"ack":true,"ts":1518360112973,"q":0,"from":"system.adapter.hm-rpc.3","lc":1518360112973} 2018-02-11 15:41:52.974 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.yyyyyyyyyyyyyy.1.MOTION_DETECTION_ACTIVE {"val":true,"ack":true,"ts":1518360112974,"q":0,"from":"system.adapter.hm-rpc.3","lc":1518356947980} 2018-02-11 15:42:04.183 - debug: hm-rpc.3 xml multicall : hm-rpc.3,xxxxxxxxxxxxxx:0,RSSI_DEVICE,-57 2018-02-11 15:42:04.183 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","xxxxxxxxxxxxxx:0","RSSI_DEVICE",-57] 2018-02-11 15:42:04.183 - debug: hm-rpc.3 hm-rpc.3.xxxxxxxxxxxxxx.0.RSSI_DEVICE ==> UNIT: "undefined" (min: -128, max: 127) From "-57" => "-57" 2018-02-11 15:42:04.183 - debug: hm-rpc.3 xml multicall : hm-rpc.3,xxxxxxxxxxxxxx:0,DUTY_CYCLE,false 2018-02-11 15:42:04.183 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","xxxxxxxxxxxxxx:0","DUTY_CYCLE",false] 2018-02-11 15:42:04.183 - debug: hm-rpc.3 hm-rpc.3.xxxxxxxxxxxxxx.0.DUTY_CYCLE ==> UNIT: "undefined" (min: false, max: true) From "false" => "false" 2018-02-11 15:42:04.183 - debug: hm-rpc.3 xml multicall : hm-rpc.3,xxxxxxxxxxxxxx:0,UNREACH,false 2018-02-11 15:42:04.183 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","xxxxxxxxxxxxxx:0","UNREACH",false] 2018-02-11 15:42:04.183 - debug: hm-rpc.3 hm-rpc.3.xxxxxxxxxxxxxx.0.UNREACH ==> UNIT: "undefined" (min: false, max: true) From "false" => "false" 2018-02-11 15:42:04.183 - debug: hm-rpc.3 xml multicall : hm-rpc.3,xxxxxxxxxxxxxx:0,RSSI_PEER,-65 2018-02-11 15:42:04.183 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","xxxxxxxxxxxxxx:0","RSSI_PEER",-65] 2018-02-11 15:42:04.183 - debug: hm-rpc.3 hm-rpc.3.xxxxxxxxxxxxxx.0.RSSI_PEER ==> UNIT: "undefined" (min: -128, max: 127) From "-65" => "-65" 2018-02-11 15:42:04.184 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.xxxxxxxxxxxxxx.0.RSSI_DEVICE {"val":-57,"ack":true,"ts":1518360124184,"q":0,"from":"system.adapter.hm-rpc.3","lc":1518360124184} 2018-02-11 15:42:04.184 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.xxxxxxxxxxxxxx.0.DUTY_CYCLE {"val":false,"ack":true,"ts":1518360124184,"q":0,"from":"system.adapter.hm-rpc.3","lc":1513962866944} 2018-02-11 15:42:04.184 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.xxxxxxxxxxxxxx.0.UNREACH {"val":false,"ack":true,"ts":1518360124184,"q":0,"from":"system.adapter.hm-rpc.3","lc":1513962866944} 2018-02-11 15:42:04.184 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.xxxxxxxxxxxxxx.0.RSSI_PEER {"val":-65,"ack":true,"ts":1518360124184,"q":0,"from":"system.adapter.hm-rpc.3","lc":1518360124184} 2018-02-11 15:42:04.192 - debug: hm-rpc.3 xml multicall : hm-rpc.3,xxxxxxxxxxxxxx:2,STATE,true 2018-02-11 15:42:04.192 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","xxxxxxxxxxxxxx:2","STATE",true] 2018-02-11 15:42:04.192 - debug: hm-rpc.3 hm-rpc.3.xxxxxxxxxxxxxx.2.STATE ==> UNIT: "undefined" (min: false, max: true) From "true" => "true" 2018-02-11 15:42:04.192 - debug: hm-rpc.3 xml multicall : hm-rpc.3,xxxxxxxxxxxxxx:2,SECTION,2 2018-02-11 15:42:04.192 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","xxxxxxxxxxxxxx:2","SECTION",2] 2018-02-11 15:42:04.192 - debug: hm-rpc.3 hm-rpc.3.xxxxxxxxxxxxxx.2.SECTION ==> UNIT: "undefined" (min: 0, max: 15) From "2" => "2" 2018-02-11 15:42:04.192 - debug: hm-rpc.3 xml multicall : hm-rpc.3,xxxxxxxxxxxxxx:2,PROCESS,0 2018-02-11 15:42:04.192 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","xxxxxxxxxxxxxx:2","PROCESS",0] 2018-02-11 15:42:04.192 - debug: hm-rpc.3 hm-rpc.3.xxxxxxxxxxxxxx.2.PROCESS ==> UNIT: "undefined" (min: STABLE, max: NOT_STABLE) From "0" => "0" 2018-02-11 15:42:04.193 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.xxxxxxxxxxxxxx.2.STATE {"val":true,"ack":true,"ts":1518360124193,"q":0,"from":"system.adapter.hm-rpc.3","lc":1514926578543} 2018-02-11 15:42:04.193 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.xxxxxxxxxxxxxx.2.SECTION {"val":2,"ack":true,"ts":1518360124193,"q":0,"from":"system.adapter.hm-rpc.3","lc":1514926578543} 2018-02-11 15:42:04.193 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.xxxxxxxxxxxxxx.2.PROCESS {"val":0,"ack":true,"ts":1518360124193,"q":0,"from":"system.adapter.hm-rpc.3","lc":1513962866954} 2018-02-11 15:42:04.208 - debug: hm-rpc.3 xml multicall : hm-rpc.3,xxxxxxxxxxxxxx:3,STATE,true 2018-02-11 15:42:04.208 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","xxxxxxxxxxxxxx:3","STATE",true] 2018-02-11 15:42:04.208 - debug: hm-rpc.3 hm-rpc.3.xxxxxxxxxxxxxx.3.STATE ==> UNIT: "undefined" (min: false, max: true) From "true" => "true" 2018-02-11 15:42:04.209 - debug: hm-rpc.3 xml multicall : hm-rpc.3,xxxxxxxxxxxxxx:3,SECTION,2 2018-02-11 15:42:04.209 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","xxxxxxxxxxxxxx:3","SECTION",2] 2018-02-11 15:42:04.209 - debug: hm-rpc.3 hm-rpc.3.xxxxxxxxxxxxxx.3.SECTION ==> UNIT: "undefined" (min: 0, max: 15) From "2" => "2" 2018-02-11 15:42:04.209 - debug: hm-rpc.3 xml multicall : hm-rpc.3,xxxxxxxxxxxxxx:3,PROCESS,0 2018-02-11 15:42:04.209 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","xxxxxxxxxxxxxx:3","PROCESS",0] 2018-02-11 15:42:04.209 - debug: hm-rpc.3 hm-rpc.3.xxxxxxxxxxxxxx.3.PROCESS ==> UNIT: "undefined" (min: STABLE, max: NOT_STABLE) From "0" => "0" 2018-02-11 15:42:04.210 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.xxxxxxxxxxxxxx.3.STATE {"val":true,"ack":true,"ts":1518360124210,"q":0,"from":"system.adapter.hm-rpc.3","lc":1514926578552} 2018-02-11 15:42:04.211 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.xxxxxxxxxxxxxx.3.SECTION {"val":2,"ack":true,"ts":1518360124210,"q":0,"from":"system.adapter.hm-rpc.3","lc":1514926578553} 2018-02-11 15:42:04.211 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.xxxxxxxxxxxxxx.3.PROCESS {"val":0,"ack":true,"ts":1518360124210,"q":0,"from":"system.adapter.hm-rpc.3","lc":1513962866969} 2018-02-11 15:42:04.226 - debug: hm-rpc.3 xml multicall : hm-rpc.3,xxxxxxxxxxxxxx:4,STATE,false 2018-02-11 15:42:04.226 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","xxxxxxxxxxxxxx:4","STATE",false] 2018-02-11 15:42:04.226 - debug: hm-rpc.3 hm-rpc.3.xxxxxxxxxxxxxx.4.STATE ==> UNIT: "undefined" (min: false, max: true) From "false" => "false" 2018-02-11 15:42:04.226 - debug: hm-rpc.3 xml multicall : hm-rpc.3,xxxxxxxxxxxxxx:4,SECTION,0 2018-02-11 15:42:04.226 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","xxxxxxxxxxxxxx:4","SECTION",0] 2018-02-11 15:42:04.226 - debug: hm-rpc.3 hm-rpc.3.xxxxxxxxxxxxxx.4.SECTION ==> UNIT: "undefined" (min: 0, max: 15) From "0" => "0" 2018-02-11 15:42:04.226 - debug: hm-rpc.3 xml multicall : hm-rpc.3,xxxxxxxxxxxxxx:4,PROCESS,0 2018-02-11 15:42:04.226 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","xxxxxxxxxxxxxx:4","PROCESS",0] 2018-02-11 15:42:04.226 - debug: hm-rpc.3 hm-rpc.3.xxxxxxxxxxxxxx.4.PROCESS ==> UNIT: "undefined" (min: STABLE, max: NOT_STABLE) From "0" => "0" 2018-02-11 15:42:04.228 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.xxxxxxxxxxxxxx.4.STATE {"val":false,"ack":true,"ts":1518360124227,"q":0,"from":"system.adapter.hm-rpc.3","lc":1513962866977} 2018-02-11 15:42:04.228 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.xxxxxxxxxxxxxx.4.SECTION {"val":0,"ack":true,"ts":1518360124227,"q":0,"from":"system.adapter.hm-rpc.3","lc":1513962866977} 2018-02-11 15:42:04.228 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.xxxxxxxxxxxxxx.4.PROCESS {"val":0,"ack":true,"ts":1518360124227,"q":0,"from":"system.adapter.hm-rpc.3","lc":1513962866977} 2018-02-11 15:42:04.236 - debug: hm-rpc.3 xml multicall : hm-rpc.3,xxxxxxxxxxxxxx:5,STATE,false 2018-02-11 15:42:04.236 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","xxxxxxxxxxxxxx:5","STATE",false] 2018-02-11 15:42:04.236 - debug: hm-rpc.3 hm-rpc.3.xxxxxxxxxxxxxx.5.STATE ==> UNIT: "undefined" (min: false, max: true) From "false" => "false" 2018-02-11 15:42:04.236 - debug: hm-rpc.3 xml multicall : hm-rpc.3,xxxxxxxxxxxxxx:5,SECTION,0 2018-02-11 15:42:04.236 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","xxxxxxxxxxxxxx:5","SECTION",0] 2018-02-11 15:42:04.236 - debug: hm-rpc.3 hm-rpc.3.xxxxxxxxxxxxxx.5.SECTION ==> UNIT: "undefined" (min: 0, max: 15) From "0" => "0" 2018-02-11 15:42:04.236 - debug: hm-rpc.3 xml multicall : hm-rpc.3,xxxxxxxxxxxxxx:5,PROCESS,0 2018-02-11 15:42:04.236 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","xxxxxxxxxxxxxx:5","PROCESS",0] 2018-02-11 15:42:04.236 - debug: hm-rpc.3 hm-rpc.3.xxxxxxxxxxxxxx.5.PROCESS ==> UNIT: "undefined" (min: STABLE, max: NOT_STABLE) From "0" => "0" 2018-02-11 15:42:04.238 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.xxxxxxxxxxxxxx.5.STATE {"val":false,"ack":true,"ts":1518360124237,"q":0,"from":"system.adapter.hm-rpc.3","lc":1513962866992} 2018-02-11 15:42:04.238 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.xxxxxxxxxxxxxx.5.SECTION {"val":0,"ack":true,"ts":1518360124237,"q":0,"from":"system.adapter.hm-rpc.3","lc":1513962866992} 2018-02-11 15:42:04.238 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.xxxxxxxxxxxxxx.5.PROCESS {"val":0,"ack":true,"ts":1518360124237,"q":0,"from":"system.adapter.hm-rpc.3","lc":1513962866992} 2018-02-11 15:42:04.255 - debug: hm-rpc.3 xml multicall : hm-rpc.3,xxxxxxxxxxxxxx:6,ENERGY_COUNTER_OVERFLOW,false 2018-02-11 15:42:04.255 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","xxxxxxxxxxxxxx:6","ENERGY_COUNTER_OVERFLOW",false] 2018-02-11 15:42:04.255 - debug: hm-rpc.3 hm-rpc.3.xxxxxxxxxxxxxx.6.ENERGY_COUNTER_OVERFLOW ==> UNIT: "undefined" (min: false, max: true) From "false" => "false" 2018-02-11 15:42:04.255 - debug: hm-rpc.3 xml multicall : hm-rpc.3,xxxxxxxxxxxxxx:6,POWER,88.32 2018-02-11 15:42:04.255 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","xxxxxxxxxxxxxx:6","POWER",88.32] 2018-02-11 15:42:04.255 - debug: hm-rpc.3 hm-rpc.3.xxxxxxxxxxxxxx.6.POWER ==> UNIT: "W" (min: 0, max: 163830) From "88.32" => "88.32" 2018-02-11 15:42:04.256 - debug: hm-rpc.3 xml multicall : hm-rpc.3,xxxxxxxxxxxxxx:6,VOLTAGE,235.2 2018-02-11 15:42:04.256 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","xxxxxxxxxxxxxx:6","VOLTAGE",235.2] 2018-02-11 15:42:04.256 - debug: hm-rpc.3 hm-rpc.3.xxxxxxxxxxxxxx.6.VOLTAGE ==> UNIT: "V" (min: 0, max: 409.5) From "235.2" => "235.2" 2018-02-11 15:42:04.256 - debug: hm-rpc.3 xml multicall : hm-rpc.3,xxxxxxxxxxxxxx:6,ENERGY_COUNTER,52634.9 2018-02-11 15:42:04.256 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","xxxxxxxxxxxxxx:6","ENERGY_COUNTER",52634.9] 2018-02-11 15:42:04.256 - debug: hm-rpc.3 hm-rpc.3.xxxxxxxxxxxxxx.6.ENERGY_COUNTER ==> UNIT: "Wh" (min: 0, max: 838859.1) From "52634.9" => "52634.9" 2018-02-11 15:42:04.256 - debug: hm-rpc.3 xml multicall : hm-rpc.3,xxxxxxxxxxxxxx:6,CURRENT,388 2018-02-11 15:42:04.256 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","xxxxxxxxxxxxxx:6","CURRENT",388] 2018-02-11 15:42:04.256 - debug: hm-rpc.3 hm-rpc.3.xxxxxxxxxxxxxx.6.CURRENT ==> UNIT: "mA" (min: 0, max: 65535) From "388" => "388" 2018-02-11 15:42:04.256 - debug: hm-rpc.3 xml multicall : hm-rpc.3,xxxxxxxxxxxxxx:6,FREQUENCY,49.98 2018-02-11 15:42:04.256 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","xxxxxxxxxxxxxx:6","FREQUENCY",49.98] 2018-02-11 15:42:04.256 - debug: hm-rpc.3 hm-rpc.3.xxxxxxxxxxxxxx.6.FREQUENCY ==> UNIT: "Hz" (min: 29.52, max: 70.47) From "49.98" => "49.98" 2018-02-11 15:42:04.264 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.xxxxxxxxxxxxxx.6.ENERGY_COUNTER_OVERFLOW {"val":false,"ack":true,"ts":1518360124256,"q":0,"from":"system.adapter.hm-rpc.3","lc":1513962867008} 2018-02-11 15:42:04.264 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.xxxxxxxxxxxxxx.6.POWER {"val":88.32,"ack":true,"ts":1518360124256,"q":0,"from":"system.adapter.hm-rpc.3","lc":1518360124256} 2018-02-11 15:42:04.264 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.xxxxxxxxxxxxxx.6.VOLTAGE {"val":235.2,"ack":true,"ts":1518360124256,"q":0,"from":"system.adapter.hm-rpc.3","lc":1518360124256} 2018-02-11 15:42:04.264 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.xxxxxxxxxxxxxx.6.ENERGY_COUNTER {"val":52634.9,"ack":true,"ts":1518360124256,"q":0,"from":"system.adapter.hm-rpc.3","lc":1518360124256} 2018-02-11 15:42:04.264 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.xxxxxxxxxxxxxx.6.CURRENT {"val":388,"ack":true,"ts":1518360124263,"q":0,"from":"system.adapter.hm-rpc.3","lc":1518360124263} 2018-02-11 15:42:04.264 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.xxxxxxxxxxxxxx.6.FREQUENCY {"val":49.98,"ack":true,"ts":1518360124263,"q":0,"from":"system.adapter.hm-rpc.3","lc":1518360124263} 2018-02-11 15:42:08.455 - debug: hm-rega.1 --> polling.fn 2018-02-11 15:42:08.455 - debug: hm-rega.1 --> programs.fn 2018-02-11 15:42:08.456 - debug: hm-rega.1 --> !# polling.fn 1.2 !# !# Dieses Script gibt die Werte aller Systemvariablen als 2018-02-11 15:42:08.462 - debug: hm-rega.1 <-- {"1235":[false,"1970-01-01 01:00:00"], "950":[true,"2018-01-02 21:40:31"], "5589":[true,"2018-02-10 19:05:48"], "6348":[false,"2018-02-11 07:30:00"], "5895":[false,"2018-01-02 21:40:29"], "5666":[false,"2018-01-11 21:03:30"], "6577":["keiner","2018-01-14 19:20:16"], "6405":[0,"2018-01-02 21:40:29"], "5501":[true,"2018-02-10 19:04:49"], "5502":[false,"2018-02-08 21:24:19"], "6076":[true,"2018-02-10 19:05:48"], "6644":["Test","2018-01-28 04:08:17"], "40":[0,"2018-01-02 21:40:30"], "41":[2,"2018-02-11 15:42:04"]} 2018-02-11 15:42:08.514 - debug: hm-rega.1 --> !# programs.fn 1.3 !# Dieses Script gibt eine Liste der Programme als JSON Stri 2018-02-11 15:42:08.520 - debug: hm-rega.1 <-- {"5575":{"Name":"Anwesenheit_iPhones","TypeName":"PROGRAM","PrgInfo":"", "Active":true,"Timestamp":"2018-02-10 19:04:49"}, "6276":{"Name":"P_Astro_setze_Nacht","TypeName":"PROGRAM","PrgInfo":"", "Active":true,"Timestamp":"2018-02-11 07:30:00"}, "6369":{"Name":"P_Astro_setze_Tag","TypeName":"PROGRAM","PrgInfo":"", "Active":true,"Timestamp":"2018-02-11 07:30:00"}, "5732":{"Name":"Prg_Abfrage_Fenster_Sprache","TypeName":"PROGRAM","PrgInfo":"", "Active":false,"Timestamp":"1970-01-01 01:00:00"}, "5658":{"Name":"Prg_Ku_Warmwasser","TypeName":"PROGRAM","PrgInfo":"", "Active":true,"Timestamp":"2018-01-11 21:03:30"}, "6523":{"Name":"Prg_Rauchmeldung","TypeName":"PROGRAM","PrgInfo":"", "Active":true,"Timestamp":"1970-01-01 01:00:00"}, "5535":{"Name":"Push_Zone_Eric","TypeName":"PROGRAM","PrgInfo":"", "Active":true,"Timestamp":"2018-02-10 19:04:49"}, "5548":{"Name":"Push_Zone_Zabka","TypeName":"PROGRAM","PrgInfo":"", "Active":true,"Timestamp":"2018-02-10 19:05:48"}, "5432":{"Name":"Strommesser_Basiswert_setzen","TypeName":"PROGRAM","PrgInfo":"", "Active":false,"Timestamp":"1970-01-01 01:00:00"}} 2018-02-11 15:42:08.569 - debug: hm-rega.1 --> dutycycle.fn 2018-02-11 15:42:08.570 - debug: hm-rega.1 --> !# dutycycle.fn 0.3 string stderr; string stdout; system.Exec("/bin/sh -c '" 2018-02-11 15:42:08.632 - debug: hm-rega.1 <-- {ADDRESS zzzzzzzzzz CONNECTED 1 DEFAULT 1 DESCRIPTION {} DUTY_CYCLE 16 FIRMWARE_VERSION 2.8.5 TYPE CCU2} 2018-02-11 15:42:08.633 - debug: hm-rega.1 Dutycycle: hm-rega.1.zzzzzzzzzz.0.DUTY_CYCLE => 16 2018-02-11 15:42:08.633 - debug: hm-rega.1 Dutycycle: hm-rega.1.zzzzzzzzzz.0.CONNECTED => 1 2018-02-11 15:42:08.633 - debug: hm-rega.1 Dutycycle: hm-rega.1.zzzzzzzzzz.0.DEFAULT => 1 2018-02-11 15:42:08.633 - debug: hm-rega.1 Dutycycle: hm-rega.1.zzzzzzzzzz.0.FIRMWARE_VERSION => 2.8.5 2018-02-11 15:42:09.423 - debug: hm-rpc.3 xml multicall : hm-rpc.3,yyyyyyyyyyyyyy:0,SABOTAGE,false 2018-02-11 15:42:09.424 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","yyyyyyyyyyyyyy:0","SABOTAGE",false] 2018-02-11 15:42:09.424 - debug: hm-rpc.3 hm-rpc.3.yyyyyyyyyyyyyy.0.SABOTAGE ==> UNIT: "undefined" (min: false, max: true) From "false" => "false" 2018-02-11 15:42:09.424 - debug: hm-rpc.3 xml multicall : hm-rpc.3,yyyyyyyyyyyyyy:0,DUTY_CYCLE,false 2018-02-11 15:42:09.424 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","yyyyyyyyyyyyyy:0","DUTY_CYCLE",false] 2018-02-11 15:42:09.424 - debug: hm-rpc.3 hm-rpc.3.yyyyyyyyyyyyyy.0.DUTY_CYCLE ==> UNIT: "undefined" (min: false, max: true) From "false" => "false" 2018-02-11 15:42:09.424 - debug: hm-rpc.3 xml multicall : hm-rpc.3,yyyyyyyyyyyyyy:0,LOW_BAT,false 2018-02-11 15:42:09.424 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","yyyyyyyyyyyyyy:0","LOW_BAT",false] 2018-02-11 15:42:09.424 - debug: hm-rpc.3 hm-rpc.3.yyyyyyyyyyyyyy.0.LOW_BAT ==> UNIT: "undefined" (min: false, max: true) From "false" => "false" 2018-02-11 15:42:09.424 - debug: hm-rpc.3 xml multicall : hm-rpc.3,yyyyyyyyyyyyyy:0,UNREACH,false 2018-02-11 15:42:09.424 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","yyyyyyyyyyyyyy:0","UNREACH",false] 2018-02-11 15:42:09.424 - debug: hm-rpc.3 hm-rpc.3.yyyyyyyyyyyyyy.0.UNREACH ==> UNIT: "undefined" (min: false, max: true) From "false" => "false" 2018-02-11 15:42:09.424 - debug: hm-rpc.3 xml multicall : hm-rpc.3,yyyyyyyyyyyyyy:0,RSSI_DEVICE,-57 2018-02-11 15:42:09.424 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","yyyyyyyyyyyyyy:0","RSSI_DEVICE",-57] 2018-02-11 15:42:09.424 - debug: hm-rpc.3 hm-rpc.3.yyyyyyyyyyyyyy.0.RSSI_DEVICE ==> UNIT: "undefined" (min: -128, max: 127) From "-57" => "-57" 2018-02-11 15:42:09.424 - debug: hm-rpc.3 xml multicall : hm-rpc.3,yyyyyyyyyyyyyy:0,OPERATING_VOLTAGE,2.7 2018-02-11 15:42:09.424 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","yyyyyyyyyyyyyy:0","OPERATING_VOLTAGE",2.7] 2018-02-11 15:42:09.424 - debug: hm-rpc.3 hm-rpc.3.yyyyyyyyyyyyyy.0.OPERATING_VOLTAGE ==> UNIT: "undefined" (min: 0, max: 25.2) From "2.7" => "2.7" 2018-02-11 15:42:09.424 - debug: hm-rpc.3 xml multicall : hm-rpc.3,yyyyyyyyyyyyyy:0,RSSI_PEER,-66 2018-02-11 15:42:09.424 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","yyyyyyyyyyyyyy:0","RSSI_PEER",-66] 2018-02-11 15:42:09.424 - debug: hm-rpc.3 hm-rpc.3.yyyyyyyyyyyyyy.0.RSSI_PEER ==> UNIT: "undefined" (min: -128, max: 127) From "-66" => "-66" 2018-02-11 15:42:09.424 - debug: hm-rpc.3 xml multicall : hm-rpc.3,yyyyyyyyyyyyyy:0,ERROR_CODE,0 2018-02-11 15:42:09.425 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","yyyyyyyyyyyyyy:0","ERROR_CODE",0] 2018-02-11 15:42:09.425 - debug: hm-rpc.3 hm-rpc.3.yyyyyyyyyyyyyy.0.ERROR_CODE ==> UNIT: "undefined" (min: 0, max: 255) From "0" => "0" 2018-02-11 15:42:09.428 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.yyyyyyyyyyyyyy.0.SABOTAGE {"val":false,"ack":true,"ts":1518360129425,"q":0,"from":"system.adapter.hm-rpc.3","lc":1518356947965} 2018-02-11 15:42:09.429 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.yyyyyyyyyyyyyy.0.DUTY_CYCLE {"val":false,"ack":true,"ts":1518360129425,"q":0,"from":"system.adapter.hm-rpc.3","lc":1518356947965} 2018-02-11 15:42:09.429 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.yyyyyyyyyyyyyy.0.LOW_BAT {"val":false,"ack":true,"ts":1518360129426,"q":0,"from":"system.adapter.hm-rpc.3","lc":1518356947965} 2018-02-11 15:42:09.429 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.yyyyyyyyyyyyyy.0.UNREACH {"val":false,"ack":true,"ts":1518360129427,"q":0,"from":"system.adapter.hm-rpc.3","lc":1518356947965} 2018-02-11 15:42:09.429 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.yyyyyyyyyyyyyy.0.RSSI_DEVICE {"val":-57,"ack":true,"ts":1518360129427,"q":0,"from":"system.adapter.hm-rpc.3","lc":1518360129427} 2018-02-11 15:42:09.429 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.yyyyyyyyyyyyyy.0.OPERATING_VOLTAGE {"val":2.7,"ack":true,"ts":1518360129427,"q":0,"from":"system.adapter.hm-rpc.3","lc":1518356947973} 2018-02-11 15:42:09.429 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.yyyyyyyyyyyyyy.0.RSSI_PEER {"val":-66,"ack":true,"ts":1518360129427,"q":0,"from":"system.adapter.hm-rpc.3","lc":1518360129427} 2018-02-11 15:42:09.429 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.yyyyyyyyyyyyyy.0.ERROR_CODE {"val":0,"ack":true,"ts":1518360129428,"q":0,"from":"system.adapter.hm-rpc.3","lc":1518356947973} 2018-02-11 15:42:09.448 - debug: hm-rpc.3 xml multicall : hm-rpc.3,yyyyyyyyyyyyyy:1,ILLUMINATION,8 2018-02-11 15:42:09.448 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","yyyyyyyyyyyyyy:1","ILLUMINATION",8] 2018-02-11 15:42:09.448 - debug: hm-rpc.3 hm-rpc.3.yyyyyyyyyyyyyy.1.ILLUMINATION ==> UNIT: "undefined" (min: 0, max: 163830) From "8" => "8" 2018-02-11 15:42:09.448 - debug: hm-rpc.3 xml multicall : hm-rpc.3,yyyyyyyyyyyyyy:1,MOTION,true 2018-02-11 15:42:09.448 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","yyyyyyyyyyyyyy:1","MOTION",true] 2018-02-11 15:42:09.448 - debug: hm-rpc.3 hm-rpc.3.yyyyyyyyyyyyyy.1.MOTION ==> UNIT: "undefined" (min: false, max: true) From "true" => "true" 2018-02-11 15:42:09.448 - debug: hm-rpc.3 xml multicall : hm-rpc.3,yyyyyyyyyyyyyy:1,MOTION_DETECTION_ACTIVE,true 2018-02-11 15:42:09.448 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","yyyyyyyyyyyyyy:1","MOTION_DETECTION_ACTIVE",true] 2018-02-11 15:42:09.448 - debug: hm-rpc.3 hm-rpc.3.yyyyyyyyyyyyyy.1.MOTION_DETECTION_ACTIVE ==> UNIT: "undefined" (min: false, max: true) From "true" => "true" 2018-02-11 15:42:09.453 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.yyyyyyyyyyyyyy.1.ILLUMINATION {"val":8,"ack":true,"ts":1518360129450,"q":0,"from":"system.adapter.hm-rpc.3","lc":1518358948928} 2018-02-11 15:42:09.453 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.yyyyyyyyyyyyyy.1.MOTION {"val":true,"ack":true,"ts":1518360129451,"q":0,"from":"system.adapter.hm-rpc.3","lc":1518360129451} 2018-02-11 15:42:09.453 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.yyyyyyyyyyyyyy.1.MOTION_DETECTION_ACTIVE {"val":true,"ack":true,"ts":1518360129452,"q":0,"from":"system.adapter.hm-rpc.3","lc":1518356947980} 2018-02-11 15:42:24.433 - debug: hm-rpc.3 xml multicall : hm-rpc.3,yyyyyyyyyyyyyy:0,SABOTAGE,false 2018-02-11 15:42:24.433 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","yyyyyyyyyyyyyy:0","SABOTAGE",false] 2018-02-11 15:42:24.433 - debug: hm-rpc.3 hm-rpc.3.yyyyyyyyyyyyyy.0.SABOTAGE ==> UNIT: "undefined" (min: false, max: true) From "false" => "false" 2018-02-11 15:42:24.433 - debug: hm-rpc.3 xml multicall : hm-rpc.3,yyyyyyyyyyyyyy:0,DUTY_CYCLE,false 2018-02-11 15:42:24.434 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","yyyyyyyyyyyyyy:0","DUTY_CYCLE",false] 2018-02-11 15:42:24.434 - debug: hm-rpc.3 hm-rpc.3.yyyyyyyyyyyyyy.0.DUTY_CYCLE ==> UNIT: "undefined" (min: false, max: true) From "false" => "false" 2018-02-11 15:42:24.434 - debug: hm-rpc.3 xml multicall : hm-rpc.3,yyyyyyyyyyyyyy:0,LOW_BAT,false 2018-02-11 15:42:24.434 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","yyyyyyyyyyyyyy:0","LOW_BAT",false] 2018-02-11 15:42:24.434 - debug: hm-rpc.3 hm-rpc.3.yyyyyyyyyyyyyy.0.LOW_BAT ==> UNIT: "undefined" (min: false, max: true) From "false" => "false" 2018-02-11 15:42:24.434 - debug: hm-rpc.3 xml multicall : hm-rpc.3,yyyyyyyyyyyyyy:0,UNREACH,false 2018-02-11 15:42:24.434 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","yyyyyyyyyyyyyy:0","UNREACH",false] 2018-02-11 15:42:24.434 - debug: hm-rpc.3 hm-rpc.3.yyyyyyyyyyyyyy.0.UNREACH ==> UNIT: "undefined" (min: false, max: true) From "false" => "false" 2018-02-11 15:42:24.434 - debug: hm-rpc.3 xml multicall : hm-rpc.3,yyyyyyyyyyyyyy:0,RSSI_DEVICE,-55 2018-02-11 15:42:24.434 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","yyyyyyyyyyyyyy:0","RSSI_DEVICE",-55] 2018-02-11 15:42:24.434 - debug: hm-rpc.3 hm-rpc.3.yyyyyyyyyyyyyy.0.RSSI_DEVICE ==> UNIT: "undefined" (min: -128, max: 127) From "-55" => "-55" 2018-02-11 15:42:24.434 - debug: hm-rpc.3 xml multicall : hm-rpc.3,yyyyyyyyyyyyyy:0,OPERATING_VOLTAGE,2.7 2018-02-11 15:42:24.434 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","yyyyyyyyyyyyyy:0","OPERATING_VOLTAGE",2.7] 2018-02-11 15:42:24.434 - debug: hm-rpc.3 hm-rpc.3.yyyyyyyyyyyyyy.0.OPERATING_VOLTAGE ==> UNIT: "undefined" (min: 0, max: 25.2) From "2.7" => "2.7" 2018-02-11 15:42:24.434 - debug: hm-rpc.3 xml multicall : hm-rpc.3,yyyyyyyyyyyyyy:0,RSSI_PEER,-67 2018-02-11 15:42:24.434 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","yyyyyyyyyyyyyy:0","RSSI_PEER",-67] 2018-02-11 15:42:24.434 - debug: hm-rpc.3 hm-rpc.3.yyyyyyyyyyyyyy.0.RSSI_PEER ==> UNIT: "undefined" (min: -128, max: 127) From "-67" => "-67" 2018-02-11 15:42:24.434 - debug: hm-rpc.3 xml multicall : hm-rpc.3,yyyyyyyyyyyyyy:0,ERROR_CODE,0 2018-02-11 15:42:24.434 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","yyyyyyyyyyyyyy:0","ERROR_CODE",0] 2018-02-11 15:42:24.434 - debug: hm-rpc.3 hm-rpc.3.yyyyyyyyyyyyyy.0.ERROR_CODE ==> UNIT: "undefined" (min: 0, max: 255) From "0" => "0" 2018-02-11 15:42:24.435 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.yyyyyyyyyyyyyy.0.SABOTAGE {"val":false,"ack":true,"ts":1518360144435,"q":0,"from":"system.adapter.hm-rpc.3","lc":1518356947965} 2018-02-11 15:42:24.435 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.yyyyyyyyyyyyyy.0.DUTY_CYCLE {"val":false,"ack":true,"ts":1518360144435,"q":0,"from":"system.adapter.hm-rpc.3","lc":1518356947965} 2018-02-11 15:42:24.435 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.yyyyyyyyyyyyyy.0.LOW_BAT {"val":false,"ack":true,"ts":1518360144435,"q":0,"from":"system.adapter.hm-rpc.3","lc":1518356947965} 2018-02-11 15:42:24.435 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.yyyyyyyyyyyyyy.0.UNREACH {"val":false,"ack":true,"ts":1518360144435,"q":0,"from":"system.adapter.hm-rpc.3","lc":1518356947965} 2018-02-11 15:42:24.435 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.yyyyyyyyyyyyyy.0.RSSI_DEVICE {"val":-55,"ack":true,"ts":1518360144435,"q":0,"from":"system.adapter.hm-rpc.3","lc":1518360144435} 2018-02-11 15:42:24.435 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.yyyyyyyyyyyyyy.0.OPERATING_VOLTAGE {"val":2.7,"ack":true,"ts":1518360144435,"q":0,"from":"system.adapter.hm-rpc.3","lc":1518356947973} 2018-02-11 15:42:24.436 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.yyyyyyyyyyyyyy.0.RSSI_PEER {"val":-67,"ack":true,"ts":1518360144435,"q":0,"from":"system.adapter.hm-rpc.3","lc":1518360144435} 2018-02-11 15:42:24.436 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.yyyyyyyyyyyyyy.0.ERROR_CODE {"val":0,"ack":true,"ts":1518360144435,"q":0,"from":"system.adapter.hm-rpc.3","lc":1518356947973} 2018-02-11 15:42:24.451 - debug: hm-rpc.3 xml multicall : hm-rpc.3,yyyyyyyyyyyyyy:1,ILLUMINATION,8 2018-02-11 15:42:24.451 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","yyyyyyyyyyyyyy:1","ILLUMINATION",8] 2018-02-11 15:42:24.451 - debug: hm-rpc.3 hm-rpc.3.yyyyyyyyyyyyyy.1.ILLUMINATION ==> UNIT: "undefined" (min: 0, max: 163830) From "8" => "8" 2018-02-11 15:42:24.451 - debug: hm-rpc.3 xml multicall : hm-rpc.3,yyyyyyyyyyyyyy:1,MOTION,false 2018-02-11 15:42:24.451 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","yyyyyyyyyyyyyy:1","MOTION",false] 2018-02-11 15:42:24.451 - debug: hm-rpc.3 hm-rpc.3.yyyyyyyyyyyyyy.1.MOTION ==> UNIT: "undefined" (min: false, max: true) From "false" => "false" 2018-02-11 15:42:24.451 - debug: hm-rpc.3 xml multicall : hm-rpc.3,yyyyyyyyyyyyyy:1,MOTION_DETECTION_ACTIVE,true 2018-02-11 15:42:24.451 - debug: hm-rpc.3 xmlrpc <- event ["hm-rpc.3","yyyyyyyyyyyyyy:1","MOTION_DETECTION_ACTIVE",true] 2018-02-11 15:42:24.451 - debug: hm-rpc.3 hm-rpc.3.yyyyyyyyyyyyyy.1.MOTION_DETECTION_ACTIVE ==> UNIT: "undefined" (min: false, max: true) From "true" => "true" 2018-02-11 15:42:24.453 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.yyyyyyyyyyyyyy.1.ILLUMINATION {"val":8,"ack":true,"ts":1518360144452,"q":0,"from":"system.adapter.hm-rpc.3","lc":1518358948928} 2018-02-11 15:42:24.453 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.yyyyyyyyyyyyyy.1.MOTION {"val":false,"ack":true,"ts":1518360144452,"q":0,"from":"system.adapter.hm-rpc.3","lc":1518360144452} 2018-02-11 15:42:24.453 - debug: hm-rpc.3 redis pmessage io.hm-rpc.3.* io.hm-rpc.3.yyyyyyyyyyyyyy.1.MOTION_DETECTION_ACTIVE {"val":true,"ack":true,"ts":1518360144452,"q":0,"from":"system.adapter.hm-rpc.3","lc":1518356947980} 2018-02-11 15:42:26.373 - debug: hm-rpc.3 Send PING... 2018-02-11 15:42:26.388 - debug: hm-rpc.3 PING ok 2018-02-11 15:42:38.456 - debug: hm-rega.1 --> polling.fn 2018-02-11 15:42:38.456 - debug: hm-rega.1 --> programs.fn 2018-02-11 15:42:38.457 - debug: hm-rega.1 --> !# programs.fn 1.3 !# Dieses Script gibt eine Liste der Programme als JSON Stri 2018-02-11 15:42:38.463 - debug: hm-rega.1 <-- {"5575":{"Name":"Anwesenheit_iPhones","TypeName":"PROGRAM","PrgInfo":"", "Active":true,"Timestamp":"2018-02-10 19:04:49"}, "6276":{"Name":"P_Astro_setze_Nacht","TypeName":"PROGRAM","PrgInfo":"", "Active":true,"Timestamp":"2018-02-11 07:30:00"}, "6369":{"Name":"P_Astro_setze_Tag","TypeName":"PROGRAM","PrgInfo":"", "Active":true,"Timestamp":"2018-02-11 07:30:00"}, "5732":{"Name":"Prg_Abfrage_Fenster_Sprache","TypeName":"PROGRAM","PrgInfo":"", "Active":false,"Timestamp":"1970-01-01 01:00:00"}, "5658":{"Name":"Prg_Ku_Warmwasser","TypeName":"PROGRAM","PrgInfo":"", "Active":true,"Timestamp":"2018-01-11 21:03:30"}, "6523":{"Name":"Prg_Rauchmeldung","TypeName":"PROGRAM","PrgInfo":"", "Active":true,"Timestamp":"1970-01-01 01:00:00"}, "5535":{"Name":"Push_Zone_Eric","TypeName":"PROGRAM","PrgInfo":"", "Active":true,"Timestamp":"2018-02-10 19:04:49"}, "5548":{"Name":"Push_Zone_Zabka","TypeName":"PROGRAM","PrgInfo":"", "Active":true,"Timestamp":"2018-02-10 19:05:48"}, "5432":{"Name":"Strommesser_Basiswert_setzen","TypeName":"PROGRAM","PrgInfo":"", "Active":false,"Timestamp":"1970-01-01 01:00:00"}} 2018-02-11 15:42:38.515 - debug: hm-rega.1 --> !# polling.fn 1.2 !# !# Dieses Script gibt die Werte aller Systemvariablen als 2018-02-11 15:42:38.521 - debug: hm-rega.1 <-- {"1235":[false,"1970-01-01 01:00:00"], "950":[true,"2018-01-02 21:40:31"], "5589":[true,"2018-02-10 19:05:48"], "6348":[false,"2018-02-11 07:30:00"], "5895":[false,"2018-01-02 21:40:29"], "5666":[false,"2018-01-11 21:03:30"], "6577":["keiner","2018-01-14 19:20:16"], "6405":[0,"2018-01-02 21:40:29"], "5501":[true,"2018-02-10 19:04:49"], "5502":[false,"2018-02-08 21:24:19"], "6076":[true,"2018-02-10 19:05:48"], "6644":["Test","2018-01-28 04:08:17"], "40":[0,"2018-01-02 21:40:30"], "41":[2,"2018-02-11 15:42:35"]} 2018-02-11 15:42:38.570 - debug: hm-rega.1 --> dutycycle.fn 2018-02-11 15:42:38.570 - debug: hm-rega.1 --> !# dutycycle.fn 0.3 string stderr; string stdout; system.Exec("/bin/sh -c '" 2018-02-11 15:42:38.634 - debug: hm-rega.1 <-- {ADDRESS zzzzzzzzzz CONNECTED 1 DEFAULT 1 DESCRIPTION {} DUTY_CYCLE 16 FIRMWARE_VERSION 2.8.5 TYPE CCU2} 2018-02-11 15:42:38.635 - debug: hm-rega.1 Dutycycle: hm-rega.1.zzzzzzzzzz.0.DUTY_CYCLE => 16 2018-02-11 15:42:38.635 - debug: hm-rega.1 Dutycycle: hm-rega.1.zzzzzzzzzz.0.CONNECTED => 1 2018-02-11 15:42:38.635 - debug: hm-rega.1 Dutycycle: hm-rega.1.zzzzzzzzzz.0.DEFAULT => 1 2018-02-11 15:42:38.635 - debug: hm-rega.1 Dutycycle: hm-rega.1.zzzzzzzzzz.0.FIRMWARE_VERSION => 2.8.5 !
                    Gruß,
                    Eric
                      apollon77 last edited by
                      Funktioniert hmip vllt inzwischen per binrpc auch? Hab leider keine ip devices
                      • eric2905
                        eric2905 last edited by
                        @apollon77:
                        Funktioniert hmip vllt inzwischen per binrpc auch? Hab leider keine ip devices `
                        Nope.
                        Dauert ewig, aber dann kommt:
                        2018-02-11 16:01:18.657 - error: hm-rpc.3 init error: Error: timeout
                          Semenchkare last edited by
                          zur Info: ich habe Komplettsicherungen meiner IoBroker vom letzten Jahr, (nahezu) wöchentlich. Ich habe jetzt mal die Woche 01/2018 rübergespielt…
                          Mal zum testen, wo der Fehler liegt. Mehr folgt Morgen...
                            ich habe nun folgende Restores gemacht:
                            den Iobroker vom 22.01.2018- Da war noch der "Alte" admin, aber der Fehler blieb weiterhin.
                            den Iobroker vom 02.01.2018- Hier funktionierte plötzlich alles wieder.
                            Stand der ReGaHSS: 1.6.6
                            Stand vom RPC 1.4.14
                            Beide Stände kann ich nicht unter dem neuen Admin aufspielen. Die 1.7.0 wurde wohl extra wegen des neuen Admin angepasst/geschaffen.
                            Hilft das weiter?
                              Ok, du sagst also das mit hm-rpc 1.4.14 HMIP tut und mit 1.6 nicht ?! Ok ich schau mir mal die Unterschiede an.
                              Weisst Du noch ob es ggf zwischenversionen gab ab wann es nicht mehr tat?
                                es gab noch die 1.4.15 und die 1.5.1
                                ich vermute der Fehler müsste von der 1.4.14 auf die 1.4.15 oder auf die 1.5.1 aufgetreten sein.
                                Bei der 1.5.1. dürfte es schon nicht mehr funktioniert haben, die kam mit dem neuen Admin.
                                  Kannst Du das mal testen?
                                  ich habe gerade die commits durchgeschaut und da ist nichts dabei was das verursacht haben könnte. Zumindestens nicht direkt im Code. Auch die xmlrpc-Library ist seit 2 Jahren unverändert.
                                  Du kannst im Admin unter "Adapter" auch ältere Versionen direkt installieren.
                                  Auch 1.5.0 hat nur Admin3 Dinge mitgebracht und an der sonstigen Logik nichts geändert. Hochinteressant
                                    PS: Ansonsten wäre es interessnt mal einen Log auf Loglevel "Debug" zu sehen von der 1.4.1 im Vergleich zur 1.6.0 … vllt sieht man da unterschiede
                                      ich habe gestern bereits versucht, unter dem neuen Admin die 1.4.15 draufzubekommen. das ging irgendwie nicht…
                                      OK, jetzt habe ich die 1.4.14 drauf auf meiner aktuellen Version. Ich teste mal...
                                        also auf der aktuellen Version geht es mit der 1.4.14 nicht. Keine Aktuelle Veränderungen der HMIP.
                                        ReGaHSS habe ich auf 1.6.6 gedowngradet, auch mit dieser version und RPC 1.4.14 läuft es nicht.
                                        An was kann das denn liegen? Dem Admin? Dem Controller?? Leider habe ich da jetzt nicht so die Ahnung…
                                        Ich mache jetzt mal noch weitere gesicherte Versionen drauf, 2 habe ich noch zwischen der funktionierenden und der nicht funktionierenden. So kann ich die Fehler bzw. Versionen eingrenzen.
                                          Danke fürs "forschen".
                                          Also an rega sollte es nicht liegen, die ist nur für die Namensgebung, Skripte und Systemvariablen da.
                                          Was mich wundert ist das wenn es schon in der 1.4.14 nicht ging reden wir von "ist vor Juli 2017 kaputt gegangen" … die Meldungen kamen aber erst in den letzten Wochen, oder ?! Das wäre doch früher aufgefallen.
                                          Damit also ggf Zusammenhang mit CCU-Firmware?
                                            man glaubt es nicht!
                                            Nachdem ich die 1.6.6 (ReGaHSS) und die 1.4.14 (RPC) drauf hatte und es nicht funktionierte,
                                            habe ich wieder die 1.7.0 (ReGaHSS) und die 1.5.1 (RPC) im Hintergrund aktualisiert.
                                            Jetzt geht's! Ich spiel jetzt mal die 1.6.0 des RPC noch drauf und melde nochmals zurück! Sehr seltsam…
                                            4434
