    4. Pi 3 als Bluetooth LE Scanner (Beispielscript)
      ple last edited by
      @Homoran:
      @ruhr70:
      Du sagst, das Du das ausgeführt hast und es die aktuellste Version ist:? `
      Du glaubst mir nicht? :evil:
      root@bananapi:~# sudo apt-get install bluetooth bluez libbluetooth-dev libudev-dev
      Reading package lists... Done
      Building dependency tree
      bluez is already the newest version.
      libbluetooth-dev is already the newest version.
      Suggested packages:
        bluez-cups bluez-obexd
      The following NEW packages will be installed:
        bluetooth libudev-dev
      0 upgraded, 2 newly installed, 0 to remove and 5 not upgraded.
      Need to get 59.4 kB of archives.
      After this operation, 332 kB of additional disk space will be used.
      Do you want to continue? [Y/n]
      Get:1 http://httpredir.debian.org/debian/ jessie/main bluetooth all 5.23-2 [36.3 kB]
      Get:2 http://httpredir.debian.org/debian/ jessie/main libudev-dev armhf 215-17+deb8u4 [23.1 kB]
      Fetched 59.4 kB in 0s (106 kB/s)
      Selecting previously unselected package bluetooth.
      (Reading database ... 56285 files and directories currently installed.)
      Preparing to unpack .../bluetooth_5.23-2_all.deb ...
      Unpacking bluetooth (5.23-2) ...
      Selecting previously unselected package libudev-dev:armhf.
      Preparing to unpack .../libudev-dev_215-17+deb8u4_armhf.deb ...
      Unpacking libudev-dev:armhf (215-17+deb8u4) ...
      Setting up bluetooth (5.23-2) ...
      Setting up libudev-dev:armhf (215-17+deb8u4) ...
      @ruhr70:
      Teste mal bitte, ob hcitool installiert ist (ist in bluez-utils enthalten) und ob hcitools ein Device findet: `
      Ja, … und nein!
      root@bananapi:~# hcitool dev
      Devices:
      @ruhr70:
      Du kannst auch mit dem hcitool einen Testscan machen (ein paar Sekunden Geduld): `
      Nein, kann ich nicht 😉
      root@bananapi:~# hcitool scan
      Device is not available: No such device
      Vielleicht doch:
      @ruhr70:
      Deine exotische Hardware `
      @[url=http://bananapi.com/index.php/component/content/article?layout=edit&id=85:
      ~~BananaPi Website"]~~Bluetooth
      BT4.0 `
      Rainer `
      ich habe gerade genau das gleiche Problem. Gestern meinen RPI3 neu aufgesetzt, iobroker frisch installiert und Backup eingespielt.
      Ich habe mich an die Anleitung gehalten, jedoch stürzt mein JavaScript direkt nach dem Script start ab.
      Als ich noble bei Java mit angegeben habe, hat er einen NPM Install gemacht aber da war ne Menge rot dabei. Weiß leider nicht mehr was.
      BL Controller wird auch nicht gefunden.
      Eigentlich wollte ich den Radar nutzen, aber der schmiert auch immer ab.
      installiert ist
      root@RPI3_ioBroker:~# node -v
      v6.11.0
      Hab ich da irgendwas falsch gemacht? Image läuft auf einem USB Stick.
      Gruß und Danke
      • Dutchman
        Schau Mal mach deinen Log dat im ioBroker Log Verzeichnisse
        Bei mir klappt de npm install nicht immer per Adapter sondern muss seperat auf de console
        Send from mobile device
          ple last edited by Jey Cee
          hab die Logs gefunden
          log.txt
          Über die Console kommt dann sowas.
          root@RPI3_ioBroker:/opt/iobroker# npm install noble --production --prefix
          npm WARN invalid config prefix=true
          npm WARN invalid config Must be a valid filesystem path
          iobroker@1.0.0 /opt/iobroker
          └── (empty)
           npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/noble/node_modules/xpc-connection):
          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
          npm ERR! code 1
          und das System ist doch gerade frisch aufgesetzt 😞
          • Dutchman
            Dutchman Developer Most Active Administrators last edited by Jey Cee
            @ple:
            log.txt
            └── (empty)
            npm ERR! code 1
            da geht auch deutlich was schief, mach mal bitte selber im terminal aber dan im richtigen verzeichniss ! (nur fuer javasript module erweiterungen !)
            Erst javascript adapter aus, dan code hier unten und dan wieder an
            cd /opt/iobroker/node_modules/iobroker.javascript/
            eventueel habe wir hier doch ein issue mit dem NPM install modul im adapter, sollte das der fall sein loest auf diese art und weise installieren dein problem und koennen wir nen bug report machen.
            Ich hatte das auch mit resol-vbus aber dachte mein fehler, bin jetzt gespannt…. und mach eventueel nen neuen thread diese fehlers hat nicht soviel mit topic zu tun, ich habe auch nur zufaellig gesehen (dank tapatalk aus PC waere es mir nicht aufgefallen) das du ein interessante problem hast 🙂
            Dutch
              ple last edited by
              root@RPI3_ioBroker:/opt/iobroker/node_modules/iobroker.javascript# npm install noble --production --prefix
              iobroker.javascript@3.3.8 /opt/iobroker/node_modules/iobroker.javascript
              └── noble@1.8.1
              Das kam jetzt bei raus.
              Da ich es ja aus dem falschen Verzeichnis gemacht habe, muss ich da wieder was löschen? nicht das das jetzt auch in /opt/iobroker/ irgendwo verankert ist.
              DAs script bringt meine Java Instanz immer noch zum Abbruch.
              Irgendwie ist das Bluetooth auch nicht richtig installiert habe ich das gefühl.
              root@RPI3_ioBroker:~# sudo service bluetooth status
              ● bluetooth.service - Bluetooth service
                 Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled)
                 Active: inactive (dead)
                   Docs: man:bluetoothd(8)
              root@RPI3_ioBroker:~# hcitool scan
              Device is not available: Address family not supported by protocol
              root@RPI3_ioBroker:~# hcitool dev
              Devices:
              Ich hatte beim Radar Adapter die gleichen Probleme, daher die Neuinstallation von Raspian.
              ich weiß leider nicht mehr weiter oder was ich da zerschossen habe. Ich will auch nicht mehr irgendwelche Befehle auf gut Glück eingeben 😉
              So, ich hab mal Try and Error gemacht.
              Ich habe einen 2ten Pi aufgesetzt mit 2017-04-10-raspbian-jessie-lite.
              Danach habe ich immer hciconfig - a eingegeben um zu gucken ob der Controller noch gefunden wird.
              Dann bin ich weiter mit dieser Anleitung wie immer
              http://www.iobroker.net/docu/?page_id=5106&lang=de
              Bis zum "sudo apt-get update && sudo apt-get upgrade" war alles gut. Ab danach gehts nicht mehr.
              Fehler ist immer "Can't open HCI socket.: Address family not supported by protocol"
              ich denke, ich werde morgen mal wieder einen neu aufsetzen und verzichte auf update, upgrade.
              • N
                Newmiraculix last edited by
                Hallo zusammen. Das ist ein spannendes Thema. Mein RPi3 steht leider oben im Schlafzimmer. Gibt es eine sinnvolle Möglichkeit mehrere davon im Haus zu verteilen und alle zu benutzen? Eventuell sogar mit der Auswertung ob jemand im EG, OG oder DG ist?
                Markus
                • ruhr70
                  ruhr70 last edited by
                  Android Handys müsstest Du scannen können, G-Tags am Schlüsselbund oder auch manche Fitnessarmbänder.
                  Die Pi 3 dann als Slaves in einer Multihostumgebung.
                  Es gibt mittlerweile auch einen BLE Adapter.
                  • N
                    @ruhr70:
                    Gesendet von iPhone mit Tapatalk `
                    Meinst du mit BLE Adapter den Radar Adapter oder gibts da noch einen anderen?
                    Markus
                    • ruhr70
                      den BLE Adapter
                        pxstd last edited by
                        Das ist ja SEHR SEHR genial!
                        Ich nutze aktuell ebenfalls Geofency auf den iPhones im Hause. Funktioniert ganz gut, aber ne Nummer sicherer wäre für mich natürlich ebenfalls eine Beacon Methode, bei der mich aber bislang immer der Umfang der Einrichtung abgeschreckt hat.
                        Heißt aber im Klartext:
                        Ich habe aktuell eine Single-Host installation.
                        Diese könnte ich problemlos auf Multihost erweitern und ein RPI3 +
                        BT Dongle (Jemand Erfahrungen hiermit? https://www.lm-technologies.com/product … nge-lm540/)
                        irgendwo im Netzwerk via WLAN platzieren.
                        Wenn ich dann z.B. G-Tags nutze, wäre das auf jeden Fall praktischer.
                        Hat jemand Erfahrungen mit dem (scheinbar) Nachfolger vom G-Tag: Gigaset keeper?
                        Und nutzt jemand das MiBand2 als Leuchtfeuer?
                        Grüße,
                        p
                          Hello again!
                          Alten RPI2 mit BT Dongle rausgekramt, raspian und iobroker draufgeschmissen, NPM noble installiert (hoffentlich!)
                          Resultat des Scannerscriptes:
                          javascript.0 2018-02-14 11:39:29.894 error at ContextifyScript.Script.runInContext (vm.js:35:29)
                          javascript.0 2018-02-14 11:39:29.894 error at script.js.btscanner:281:1
                          javascript.0 2018-02-14 11:39:29.894 error ReferenceError: logs is not defined
                          javascript.0 2018-02-14 11:39:29.894 error ^
                          javascript.0 2018-02-14 11:39:29.893 error logs('--== ' + name + ' ==-- gestartet. Instanz: "' + instanz + '", Loglevel: ' + loglevel,"info","darkgreen");
                          javascript.0 2018-02-14 11:39:29.893 error script.js.btscanner: script.js.btscanner:281
                          javascript.0 2018-02-14 11:39:29.893 error at require (internal/module.js:20:19)
                          javascript.0 2018-02-14 11:39:29.893 error at Module.require (module.js:504:17)
                          javascript.0 2018-02-14 11:39:29.893 error at Function.Module._load (module.js:445:3)
                          javascript.0 2018-02-14 11:39:29.892 error at tryModuleLoad (module.js:453:12)
                          javascript.0 2018-02-14 11:39:29.892 error at Module.load (module.js:494:32)
                          javascript.0 2018-02-14 11:39:29.892 error at Object.Module._extensions..js (module.js:586:10)
                          javascript.0 2018-02-14 11:39:29.892 error at Module._compile (module.js:577:32)
                          javascript.0 2018-02-14 11:39:29.891 error at Object. (/opt/iobroker/node_modules/iobroker.javascript/node_modules/noble/index.js:2:49)
                          javascript.0 2018-02-14 11:39:29.891 error at module.exports (/opt/iobroker/node_modules/iobroker.javascript/node_modules/noble/lib/resolve-bindings.js:13:12)
                          javascript.0 2018-02-14 11:39:29.891 error at require (internal/module.js:20:19)
                          javascript.0 2018-02-14 11:39:29.891 error at Module.require (module.js:504:17)
                          javascript.0 2018-02-14 11:39:29.890 error at Function.Module._load (module.js:445:3)
                          javascript.0 2018-02-14 11:39:29.890 error at tryModuleLoad (module.js:453:12)
                          javascript.0 2018-02-14 11:39:29.890 error at Module.load (module.js:494:32)
                          javascript.0 2018-02-14 11:39:29.890 error at Object.Module._extensions..js (module.js:586:10)
                          javascript.0 2018-02-14 11:39:29.889 error at Module._compile (module.js:577:32)
                          javascript.0 2018-02-14 11:39:29.889 error at Object. (/opt/iobroker/node_modules/iobroker.javascript/node_modules/noble/lib/hci-socket/bindings.js:9:11)
                          javascript.0 2018-02-14 11:39:29.888 error at require (internal/module.js:20:19)
                          javascript.0 2018-02-14 11:39:29.887 error at Module.require (module.js:504:17)
                          javascript.0 2018-02-14 11:39:29.887 error at Function.Module._load (module.js:445:3)
                          javascript.0 2018-02-14 11:39:29.887 error at tryModuleLoad (module.js:453:12)
                          javascript.0 2018-02-14 11:39:29.887 error at Module.load (module.js:494:32)
                          javascript.0 2018-02-14 11:39:29.886 error at Object.Module._extensions..js (module.js:586:10)
                          javascript.0 2018-02-14 11:39:29.886 error at Module._compile (module.js:577:32)
                          javascript.0 2018-02-14 11:39:29.885 error at Object. (/opt/iobroker/node_modules/iobroker.javascript/node_modules/noble/lib/hci-socket/hci.js:6:26)
                          javascript.0 2018-02-14 11:39:29.885 error at require (internal/module.js:20:19)
                          javascript.0 2018-02-14 11:39:29.884 error at Module.require (module.js:504:17)
                          javascript.0 2018-02-14 11:39:29.884 error at Function.Module._load (module.js:445:3)
                          javascript.0 2018-02-14 11:39:29.884 error at tryModuleLoad (module.js:453:12)
                          javascript.0 2018-02-14 11:39:29.883 error at Module.load (module.js:494:32)
                          javascript.0 2018-02-14 11:39:29.883 error at Object.Module._extensions..js (module.js:586:10)
                          javascript.0 2018-02-14 11:39:29.882 error at Module._compile (module.js:577:32)
                          javascript.0 2018-02-14 11:39:29.882 error at Object. (/opt/iobroker/node_modules/iobroker.javascript/node_modules/bluetooth-hci-socket/index.js:8:20)
                          javascript.0 2018-02-14 11:39:29.882 error at require (internal/module.js:20:19)
                          javascript.0 2018-02-14 11:39:29.881 error at Module.require (module.js:504:17)
                          javascript.0 2018-02-14 11:39:29.881 error at Function.Module._load (module.js:445:3)
                          javascript.0 2018-02-14 11:39:29.880 error at tryModuleLoad (module.js:453:12)
                          javascript.0 2018-02-14 11:39:29.880 error at Module.load (module.js:494:32)
                          javascript.0 2018-02-14 11:39:29.880 error at Object.Module._extensions..js (module.js:586:10)
                          javascript.0 2018-02-14 11:39:29.879 error at Module._compile (module.js:577:32)
                          javascript.0 2018-02-14 11:39:29.879 error script.js.btscanner: Error: Cannot find module '../build/Release/binding.node'
                          Fehlen mir noch weitere Node Module?
                          • MathiasJ
                            MathiasJ last edited by
                            Ich habe den USB-Dongle und noble installiert.
                            Nur beim ersten Scan wurde hier überhaupt nichts gescannt.
                            Dann bin ich auf dumm auf das log gegangen.
                            Da fand ich folgendes: (siehe Bild)
                            ich habe die MAC-Adressen der G-Tags von einem anderen Raspberry mit einer Linux Grundinstallation übernommen, bei dem es einwandfrei ging.
                            Als USB-Stick habe ich mir den LogiLink BT0015 USB 2.0 Adapter Micro Bluetooth V4.0 Dongle Stick gekauft.
                            Irgentwie will der auf meinem NUC nicht.
                            Gruß,
                            Mathias
                            • MathiasJ
                              Hi zusammen,
                              ich finde das Projekt wirklich sehr spannend, habe aber jedoch ein gewaltiges Problem:
                              Wenn ich den Raspberry PI2 als single-host laufen lasse, werden alle G-tags gescannt.
                              Wenn ich den Raspberry als Slave laufen lasse, laufen die Scripts nicht mehr.
                              Ich habe den Slave mit einer Minimalinstallation laufen lassen und habe über das Admin des Masters alles nachinstalliert,
                              wie Homoran mir es geschrieben hat.
                              Siehe http://forum.iobroker.net/viewtopic.php?f=8&t=12136.
                              Muß ich nun die Skripte auf dem Slave oder dem Master laufen lassen?
                              Gruß,
                              Mathias
                              • MathiasJ
                                ich weiß, der treat ist schon älter.
                                ich versuche schon seit Wochen, meine Anwesenheits-Variablen der CCU2 mit einem Blocky-Programm zu triggern.
                                ich bin jedoch nach Aktualisierung des Blocky-Skripts nur eine Sekunde anwesend, danach wieder abwesend.
                                Hier ist der versuch, das umzusetzen:
                                viewtopic.php?f=21&t=13213&p=140444#p140444
                                jedoch sind alle Versuche, das umzusetzen, gescheitert.
                                Der Multihost-Betrieb läuft nun stabil.
                                Gruß,
                                Mathias
                                • ruhr70
                                  @MathiasJ:
                                  viewtopic.php?f=21&t=13213&p=140444#p140444 `
                                  Ich kann heute Abend mal näher schauen.
                                  In Blockly habe ich zwar keine Karten, aber vielleicht kommen wir ja trotzdem weiter 🙂
                                  Funktioniert den der Datenpunkt, denn Du für Dein Skript nehmen willst?
                                  Überwach den Datenpunkt mal mit History und am Besten auch noch mit einem Diagramm-Adapter, wie Flot.
                                  Dann kannst Du beim Datenpunkt schon einmal in die Tabelle schauen, ob die Infos so sind, wie Du Sie benötigst und im Flot Adapter auch grafisch, ob das für die Anwesenheit passt.
                                  Du müsstest dann ein Diagramm haben, bei dem der Ausschlag oben ist, wenn Du anwesend bis und auf 0, wenn Du abwesend bist.
                                  Du nutzt dafür einen nicht an der G-Tag App angemeldeten G-Tag?
                                  Folgende Möglichkeiten für die Überwachung sind denkbar:
                                  • das BLE Skript, funktioniert mit nicht angemeldeten G-Tags
                                  • der BLE Adapter (habe ich mit G-Tag noch nicht probiert)
                                  • Radar Adapter (nicht mit G-Tag probiert)
                                  Wenn wir einen funktionierenden Datenpunkt haben, können wir darauf aufbauen.
                                  Poste dann mal bitte die Tabelle aus History und ggf. auch das Flot Diagram.
                                  Und ich brauche die ID des Datenpunkts, der funktioniert.
                                  • MathiasJ
                                    Radar funktioniert bei mir nicht.
                                    es werden keine tags erkannt. Im Log steht zwar, dass meine Tags online sind. in den Objekten finde ich aber nichts.
                                    Meine Tags sind keiner App zugeordnet.
                                    Ich bin trotzdem nur eine Sekunde da und danach wieder weg.
                                    Wenn ich den Blocky-Skript aktualisiere oder aus- und wieder einschalte, bin ich wieder für eine Sekunde da.
                                    ich habe auch schon einen zeitgesteuerten Scan jede Sekunde versucht.
                                    Dann bekam ich sekündlich 2 Pushnachrichten, dass ich anwesend und dann wieder abwesend bin.
                                    Mit History habe ich noch nichts versucht.
                                    ich werde erst mal eine längere Pause einlegen, da ich es bereits seit 3 Monaten versuche, eine einigermaßen vernünftige Anwesenheitskennung hinzubekommen. Alle Versuche schlugen bisher fehl.
                                    ich werde mich hier erst einmal verabschieden, bis ich wieder die nötige Muße gefunden habe, weiter zu machen.
                                    Vllt geht ja bis dahin der NUC wieder.
                                    Gruß,
                                    Mathias
                                    • ruhr70
                                      @MathiasJ:
                                      Ich bin trotzdem nur eine Sekunde da und danach wieder weg. `
                                      Im Log online gemeldet vom BLE Skript?
                                      Poste bitte mal das Log und die Baumstruktur vom BLE Skript in den Objekten.
                                      Und deni Bereich vom Skript, in dem man die Einstellungen vornimmt.
                                      • MathiasJ
                                        Das ist ganz einfach erklärt.
                                        Ich habe den Beispielskript 1:1 ohne Änderungen übernommen.
                                        Bei BLE sehe ich nur die dB-Angaben. Ob die da oder weg sind, sehe ich nicht.
                                        So jetzt werde ich eine längere Pause einlegen.
                                        Ich werde in der nächsten Zeit definitiv nichts in diesem Bereich unternehmen. Hatte zu viele Rückschläge und brauche Ruhe.
                                        Gruß,
                                        Mathias
                                        Gesendet von meinem SM-N915FY mit Tapatalk
                                          LJSven last edited by
                                          Ich versuche das System zu installieren. Allerdings bekomme ich die iBeacon nicht angezeigt. Der "hcitool lescan" Befehlt gibt folgendes wieder.
                                          root@RASPBERRY-SVEN:/home/pi# sudo hcitool lescan
                                          Set scan parameters failed: Input/output error
                                          root@RASPBERRY-SVEN:/home/pi# hcitool lescan
                                          Was mache ich falsch?
                                          • ruhr70
                                            @LJSven:
                                            Set scan parameters failed: Input/output error `
                                            Schau mal die erste Antwort ob Dir das hilft:
                                            https://stackoverflow.com/questions/220 … -i-o-error
                                            An Pi3 lief das bei mir ansonsten problemlos.
                                            Ich denke den Bluetooth Stack (erster Post) hast Du installiert:
                                            sudo apt-get install bluetooth bluez li … ibudev-dev
                                            254
                                            57363
