    3. Cloud Dienste
    4. Sammelthread : Cloud (free), Cloud.Pro und Alexa-Abbrüche
    • N
      NyanCat last edited by
      Version 2.4.4
      Cloud-Free
      "Error while connecting to cloud: timeout"
      Seit ca. einer Stunde.
      Grüße 🙂
      • Ralf_N
        Ralf_N last edited by
        Und BluFox hat die Grippe….
        Wenns läuft, läufts ... 😕
        Gute Besserung @ BluFox!
          The Master last edited by
          Egal welcher Cloud Adapter 2.4.4 -2.4.6
          cloud.0 2018-02-11 00:35:56.294 error Error while connecting to cloud: timeout
          cloud.0 2018-02-11 00:35:55.303 info Trying to connect as system.user.admin
          cloud.0 2018-02-11 00:35:26.283 error Error while connecting to cloud: timeout
          cloud.0 2018-02-11 00:35:25.288 info Trying to connect as system.user.admin
          cloud.0 2018-02-11 00:34:56.273 error Error while connecting to cloud: timeout
          cloud.0 2018-02-11 00:34:55.279 info Trying to connect as system.user.admin
          cloud.0 2018-02-11 00:34:26.268 error Error while connecting to cloud: timeout
          cloud.0 2018-02-11 00:34:25.274 info Trying to connect as system.user.admin
          cloud.0 2018-02-11 00:33:56.264 error Error while connecting to cloud: timeout
          cloud.0 2018-02-11 00:33:55.270 info Trying to connect as system.user.admin
          cloud.0 2018-02-11 00:33:26.257 error Error while connecting to cloud: timeout
          cloud.0 2018-02-11 00:33:25.260 info Trying to connect as system.user.admin
          cloud.0 2018-02-11 00:32:56.254 error Error while connecting to cloud: timeout
          cloud.0 2018-02-11 00:32:55.260 info Trying to connect as system.user.admin
          cloud.0 2018-02-11 00:32:26.247 error Error while connecting to cloud: timeout
          cloud.0 2018-02-11 00:32:25.253 info Trying to connect as system.user.admin
          cloud.0 2018-02-11 00:31:56.245 error Error while connecting to cloud: timeout
          cloud.0 2018-02-11 00:31:55.251 info Trying to connect as system.user.admin
          cloud.0 2018-02-11 00:31:26.239 error Error while connecting to cloud: timeout
          cloud.0 2018-02-11 00:31:25.246 info Trying to connect as system.user.admin
          cloud.0 2018-02-11 00:30:56.236 error Error while connecting to cloud: timeout
          • AlCalzone
            Timeout liegt (höchstwahrscheinlich) am Server und nicht am Adapter. Hab ich auch.
            • eric2905
              eric2905 last edited by
              @The Master:
              Egal welcher Cloud Adapter 2.4.4 -2.4.6 `
              Auch hier : Welche Cloud? Pro oder Free?
              Und Log-Auszüge immer in Code-Tags setzen.
              Gruß,
              Eric
              Von unterwegs getippert
              • AlCalzone
                Läuft seit ca. 1 Uhr heute Nacht wieder. (free)
                • BBTown
                  BBTown last edited by
                  Jetzt war es mal wieder so weit, dass der cloud-Adapter v.2.4.6. (pro) meinte die Geräte seien nicht erreichbar/bereit.
                  Zurück auf die v.2.4.4 und alle ausprobierten Geräte reagierten sofort wieder.
                  Ergo: für mich ist erneut d.v.2.4.6 (wie bereits die v.2.4.5) unberechenbar und mal erreichbar, und dann eben wieder nicht. So ein unberechenbares Verhalten kenne ich von der v.2.4.4 bis dato nicht.
                    apollon77 last edited by
                    Bitte gehe mal in der 2.4.6 in alexa App, lösche alle Geräte und synce neu. Dann besser?
                    • BBTown
                      @apollon77:
                      Bitte gehe mal in der 2.4.6 in alexa App, lösche alle Geräte und synce neu. Dann besser? ` genau das habe ich gestern nach der Installation von 2.4.6 gemacht und zunächst lief der Adapter und Alexa.
                      Aber es ist unberechenbar wie lange und wann ja und wann nein.
                      AlCalzone hatte bereits den Tip mit dem Löschen und Neu-Sync gegeben, daher gab ich der 2.4.6 eine neue Chance.
                      Aber lange vorgehalten hat das ganze nicht.
                      Besonders ärgerlich ist, dass alle Gruppen anschließend auch wieder manuell in der Alexa-App eingerichtet werden müssen
                      [EDIT] anbei noch ein Auszug von Logs während die v.2.4.6 nicht reagierte
                      • AlCalzone
                        Das wundert mich jetzt, hat WolfspiritM nicht irgendwo geschrieben, dass jetzt nur noch SmartNames als appliance-id verwendet werden und nicht die State-IDs? Für mich sieht das schwer nach der State-ID aus.
                        • Z
                          Zippolighter last edited by
                          Keine neuen Smart Geräte einrichtbar
                          Hallo, weiß jetzt gar nicht ob ich hier noch richtig bin oder ob es einen anderen Thread hierzu gibt oder ob ich einen neuen aufmachen soll.
                          Cloud Adapter 2.4.6, Cloud free
                          Versuche jetzt schon die ganze Zeit ein Javascript Objekt dem Cloud Adapter hinzuzufügen. Aber es passiert gar nichts. Auch nach wechseln der Karteireiter.
                          Ein Neustart vom Cloud Adapter sowie downgrade auf 2.4.4 helfen auch nicht.
                          Hoffe Ihr habt eine Idee
                          Gruß Zippolighter
                          Edit:
                          Habe dann nochmal ein bischen geforscht
                          Der Javascript Eintrag sah bei mir so aus
                          Ein funktionierender sah bei mir so aus
                          Ich habe ihn dann den nicht funktionierenden gelöscht und neu eingerichtet
                          Nachdem ich manuel dann in den RAW Settings den SmartName eingetragen habe,
                          war der Eintrag auch sofort in der Cloud vorhanden.
                          Nach Sync mit Amazon Alexa Skill ioBroker Neue Geräte hinzufügen funktionierte der Eintrag sofort
                          • BBTown
                            Bei mir ist die Kombination Admin v.3.2 in Verbindung mit dem cloud-Adapter v.2.4.6 nach wie vor absolut unzuverlässig.
                            Ständig kommt lediglich die Rückmeldung "Das Geräte reagiert nicht / ist nicht verfügbar"
                            2 Dinge fallen mit dabei auf:
                            In der Alexa App auf meinem Smartphone kann ich die Smart Geräte direkt schalten, ohne Probleme
                            Wenn ich per Sprachkommando nach "Geräten suchen" lasse, reagiert Alexa auf das Sprachkommando, welches zuvor als "Gerät reagiert nicht" erfolglos blieb.
                            • AlCalzone
                              @Zippolighter:
                              Versuche jetzt schon die ganze Zeit ein Javascript Objekt dem Cloud Adapter hinzuzufügen. Aber es passiert gar nichts. Auch nach wechseln der Karteireiter. `
                              Gib dem Objekt mal eine common.role="switch" und probier es dann. Die neueren Versionen versuchen anhand dieser, schlaue Entscheidungen zum Schalten zu treffen.
                                FoxMulder last edited by
                                Bei mir seid heute :
                                Gesendet von meinem SM-G950F mit Tapatalk
                                  maxeddy last edited by
                                  Seit Stunden ist keine Anmeldung beim Cloud-Adapter (free) möglich. Habe alle o.g. Probleme/Fälle (alles neu einrichten usw.) auch erlebt.
                                  Ich würde die "pro-Version" ja auch kaufen. Befürchte nur , wenn es viele machen, läuft die auch nicht mehr stabil und "geschenkt" bekommt man sie auch nicht gerade.
                                  1-2 Tage kann man gut Alexa nutzen und dann gibt es zig Stunden wieder keine Verbindung zum cloud-Adapter.
                                  cloud.0 2018-02-15 18:08:36.190 error Error while connecting to cloud: timeout
                                  cloud.0 2018-02-15 18:08:35.234 info Trying to connect as system.user.admin
                                  Version 2.4.6
                                    Wildbill last edited by
                                    Weil es so schön passt und ich vermute, dass der eine oder andere die Cloud nur verwendet um ioBroker mit Alexa zu steuern. Das geht auch ohne die Cloud mittels node-red: http://forum.iobroker.net/viewtopic.php?f=37&t=11302
                                    Wer die Cloud nicht für den Zugriff von unterwegs braucht, der kann den Adapter dann beenden oder gar löschen und Alexa macht trotzdem brav mit. Das könnte den Cloud-Server ja vielleicht mit entlasten, wenn hier der eine oder andere umsteigt…
                                    Gruss, Jürgen
                                    • TJJochen
                                      TJJochen last edited by
                                      Was ist denn los? Warum ist der Cloudserver mal wieder futsch?
                                      • eric2905
                                        Sieht wohl so aus ….
                                        Warum? Mal meine Glaskugel suchen ...
                                        Habe gerade was dazu gepostet.
                                        • eric2905
                                          Siehe hier:
                                          http://forum.iobroker.net/viewtopic.php?f=8&t=11841
                                          Gruß,
                                          Eric
                                          • AlCalzone
                                            @maxeddy:
                                            Ich würde die "pro-Version" ja auch kaufen. Befürchte nur , wenn es viele machen, läuft die auch nicht mehr stabil und "geschenkt" bekommt man sie auch nicht gerade. `
                                            Wenn es viele machen, hat Bluefox genug Einnahmen, um den Server hochzuskalieren und dabei nicht aus eigener Tasche drauf zu legen 😉
                                            So herum solltest du es mal sehen 😉
                                            318
                                            53402
