    4. [gelöst] Dringend: Node-Red Laufzeitfehler
      tp1de last edited by
      Loglevel hatte ich bereits auf Debug Mode gestellt.
      Seit ein paar Minuten verliert die Instanz wieder regelmäßig die Verbindung zur States DB.
      Hier der Logfile zum Stop und Neustart des node-red Adapters. Wie Du siehst versuchen die Flows auf iobroker States zuzugreifen, bevor die States DB zur Verfügung steht.
      node-red.0 2018-02-15 11:39:53.550 warn 2018-02-15 11:39:53.548 - [34mdebug[39m: node-red.0 statesDB connected
      node-red.0 2018-02-15 11:39:53.351 warn 2018-02-15 11:39:53.349 - [34mdebug[39m: node-red.0 objectDB connected
      node-red.0 2018-02-15 11:39:53.215 debug 15 Feb 11:39:53 - [info] [inject:Jede 10 Sekunden] repeat = 10000
      node-red.0 2018-02-15 11:39:53.211 error 15 Feb 11:39:53 - [error] [ioBroker out:Brennerauslastung] TypeError: adapter.getForeignState is not a function at IOBrokerOutNode. (/opt/iobroker/node_modules/iobroker.node-red/nodes/i
      node-red.0 2018-02-15 11:39:53.205 error 15 Feb 11:39:53 - [error] [ioBroker out:Brennerlaufzeit_Std] TypeError: adapter.getForeignState is not a function at IOBrokerOutNode. (/opt/iobroker/node_modules/iobroker.node-red/nodes
      node-red.0 2018-02-15 11:39:53.198 error 15 Feb 11:39:53 - [error] [ioBroker out:Brenner] TypeError: adapter.getForeignState is not a function at IOBrokerOutNode. (/opt/iobroker/node_modules/iobroker.node-red/nodes/ioBroker.js
      node-red.0 2018-02-15 11:39:53.187 error 15 Feb 11:39:53 - [error] [ioBroker get:Mischer_Loop] TypeError: adapter.getForeignState is not a function at IOBrokerGetNode. (/opt/iobroker/node_modules/iobroker.node-red/nodes/ioBrok
      node-red.0 2018-02-15 11:39:53.182 debug 15 Feb 11:39:53 - [info] [inject:Jede 15 Sekunden] repeat = 15000
      node-red.0 2018-02-15 11:39:53.178 error 15 Feb 11:39:53 - [error] [ioBroker get:Regelung Status] TypeError: adapter.getForeignState is not a function at IOBrokerGetNode. (/opt/iobroker/node_modules/iobroker.node-red/nodes/ioB
      node-red.0 2018-02-15 11:39:53.172 error 15 Feb 11:39:53 - [error] [ioBroker get:Status] TypeError: adapter.getForeignState is not a function at IOBrokerGetNode. (/opt/iobroker/node_modules/iobroker.node-red/nodes/ioBroker.js:
      node-red.0 2018-02-15 11:39:53.167 error 15 Feb 11:39:53 - [error] [ioBroker get:Status] TypeError: adapter.getForeignState is not a function at IOBrokerGetNode. (/opt/iobroker/node_modules/iobroker.node-red/nodes/ioBroker.js:
      node-red.0 2018-02-15 11:39:53.163 debug 15 Feb 11:39:53 - [info] [inject:Jede Minute] repeat = 60000
      node-red.0 2018-02-15 11:39:53.159 error 15 Feb 11:39:53 - [info] [inject:Jede 15 Sekunden] repeat = 15000 15 Feb 11:39:53 - [error] [ioBroker get:If connected to CCU] TypeError: adapter.getForeignState is not a function at IOBrokerGetNo
      node-red.0 2018-02-15 11:39:53.156 error 15 Feb 11:39:53 - [error] [ioBroker get:Wasser An] TypeError: adapter.getForeignState is not a function at IOBrokerGetNode. (/opt/iobroker/node_modules/iobroker.node-red/nodes/ioBroker.
      node-red.0 2018-02-15 11:39:53.152 error 15 Feb 11:39:53 - [error] [ioBroker get:HZG An] TypeError: adapter.getForeignState is not a function at IOBrokerGetNode. (/opt/iobroker/node_modules/iobroker.node-red/nodes/ioBroker.js:
      node-red.0 2018-02-15 11:39:53.145 error 15 Feb 11:39:53 - [error] [ioBroker get:FB An] TypeError: adapter.getForeignState is not a function at IOBrokerGetNode. (/opt/iobroker/node_modules/iobroker.node-red/nodes/ioBroker.js:3
      node-red.0 2018-02-15 11:39:53.137 debug 15 Feb 11:39:53 - [info] [inject:Jede 15 Sekunden] repeat = 15000
      node-red.0 2018-02-15 11:39:51.195 error 15 Feb 11:39:51 - [error] [ioBroker get:Aussentemperatur] TypeError: adapter.getForeignState is not a function at IOBrokerGetNode. (/opt/iobroker/node_modules/iobroker.node-red/nodes/io
      node-red.0 2018-02-15 11:39:51.185 error 15 Feb 11:39:51 - [error] [ioBroker get:Wassertemperatur] TypeError: adapter.getForeignState is not a function at IOBrokerGetNode. (/opt/iobroker/node_modules/iobroker.node-red/nodes/io
      node-red.0 2018-02-15 11:39:51.177 error 15 Feb 11:39:51 - [error] [ioBroker get:Kesseltemperatur] TypeError: adapter.getForeignState is not a function at IOBrokerGetNode. (/opt/iobroker/node_modules/iobroker.node-red/nodes/io
      node-red.0 2018-02-15 11:39:51.171 error 15 Feb 11:39:51 - [error] [ioBroker get:Fussbodenrücklauf] TypeError: adapter.getForeignState is not a function at IOBrokerGetNode. (/opt/iobroker/node_modules/iobroker.node-red/nodes/i
      node-red.0 2018-02-15 11:39:51.165 error 15 Feb 11:39:51 - [error] [ioBroker get:Heizungsrücklauf] TypeError: adapter.getForeignState is not a function at IOBrokerGetNode. (/opt/iobroker/node_modules/iobroker.node-red/nodes/io
      node-red.0 2018-02-15 11:39:51.160 error 15 Feb 11:39:51 - [error] [ioBroker get:Heizungsvorlauf] TypeError: adapter.getForeignState is not a function at IOBrokerGetNode. (/opt/iobroker/node_modules/iobroker.node-red/nodes/ioB
      node-red.0 2018-02-15 11:39:51.154 debug 15 Feb 11:39:51 - [info] [inject:8708f6be.fced8] repeat = 5000
      node-red.0 2018-02-15 11:39:51.147 error 15 Feb 11:39:51 - [error] [ioBroker out:Luftfeuchte] TypeError: adapter.getForeignState is not a function at IOBrokerOutNode. (/opt/iobroker/node_modules/iobroker.node-red/nodes/ioBroke
      node-red.0 2018-02-15 11:39:51.138 error 15 Feb 11:39:51 - [error] [ioBroker out:Temperatur] TypeError: adapter.getForeignState is not a function at IOBrokerOutNode. (/opt/iobroker/node_modules/iobroker.node-red/nodes/ioBroker
      node-red.0 2018-02-15 11:39:50.603 error 15 Feb 11:39:50 - [error] [ioBroker out:Heizungsstrom] TypeError: adapter.getForeignState is not a function at IOBrokerOutNode. (/opt/iobroker/node_modules/iobroker.node-red/nodes/ioBro
      node-red.0 2018-02-15 11:39:50.596 error 15 Feb 11:39:50 - [error] [ioBroker out:Heizungskessel] TypeError: adapter.getForeignState is not a function at IOBrokerOutNode. (/opt/iobroker/node_modules/iobroker.node-red/nodes/ioBr
      node-red.0 2018-02-15 11:39:50.585 error 15 Feb 11:39:50 - [error] [ioBroker out:Mischer auf] TypeError: adapter.getForeignState is not a function at IOBrokerOutNode. (/opt/iobroker/node_modules/iobroker.node-red/nodes/ioBroke
      node-red.0 2018-02-15 11:39:50.578 error 15 Feb 11:39:50 - [error] [ioBroker out:Fussbodenpumpe] TypeError: adapter.getForeignState is not a function at IOBrokerOutNode. (/opt/iobroker/node_modules/iobroker.node-red/nodes/ioBr
      node-red.0 2018-02-15 11:39:50.578 error 15 Feb 11:39:50 - [error] [ioBroker out:Heizungspumpe] TypeError: adapter.getForeignState is not a function at IOBrokerOutNode. (/opt/iobroker/node_modules/iobroker.node-red/nodes/ioBro
      node-red.0 2018-02-15 11:39:50.578 error 15 Feb 11:39:50 - [error] [ioBroker out:Vorrang Wasser] TypeError: adapter.getForeignState is not a function at IOBrokerOutNode. (/opt/iobroker/node_modules/iobroker.node-red/nodes/ioBr
      node-red.0 2018-02-15 11:39:50.578 error 15 Feb 11:39:50 - [error] [ioBroker get:Brennerstart_Zeit] TypeError: adapter.getForeignState is not a function at IOBrokerGetNode. (/opt/iobroker/node_modules/iobroker.node-red/nodes/i
      node-red.0 2018-02-15 11:39:50.577 error 15 Feb 11:39:50 - [error] [ioBroker get:Brennerlaufzeit_Tag] TypeError: adapter.getForeignState is not a function at IOBrokerGetNode. (/opt/iobroker/node_modules/iobroker.node-red/nodes
      node-red.0 2018-02-15 11:39:50.577 error 15 Feb 11:39:50 - [error] [ioBroker get:Brennerlaufzeit_Std] TypeError: adapter.getForeignState is not a function at IOBrokerGetNode. (/opt/iobroker/node_modules/iobroker.node-red/nodes
      node-red.0 2018-02-15 11:39:50.571 error 15 Feb 11:39:50 - [error] [ioBroker get:Brennerlaufzeit] TypeError: adapter.getForeignState is not a function at IOBrokerGetNode. (/opt/iobroker/node_modules/iobroker.node-red/nodes/ioB
      node-red.0 2018-02-15 11:39:50.527 warn 2018-02-15 11:39:50.524 - [31merror[39m: node-red.0 no connection to objects DB
      node-red.0 2018-02-15 11:39:50.502 debug 15 Feb 11:39:50 - [info] Started flows
      node-red.0 2018-02-15 11:39:47.097 debug 15 Feb 11:39:47 - [info] [inject:1 hour] repeat = 3600000
      node-red.0 2018-02-15 11:39:45.734 debug 15 Feb 11:39:45 - [info] [inject:Reset 00:00 Uhr] crontab = 00 00 * * *
      node-red.0 2018-02-15 11:39:23.601 debug 15 Feb 11:39:23 - [info] Starting flows
      node-red.0 2018-02-15 11:39:22.830 debug 15 Feb 11:39:22 - [info] Server now running at http://127.0.0.1:1880/
      node-red.0 2018-02-15 11:39:22.760 debug 15 Feb 11:39:22 - [37-rpi-piface.js] Error: "gpio load spi" command failed. Check device tree is disabled.
      node-red.0 2018-02-15 11:39:22.730 debug 15 Feb 11:39:22 - [info] Flows file : /opt/iobroker/iobroker-data/node-red/flows.json
      node-red.0 2018-02-15 11:39:22.722 warn 15 Feb 11:39:22 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
      node-red.0 2018-02-15 11:39:22.720 debug 15 Feb 11:39:22 - [info] User directory : /opt/iobroker/iobroker-data/node-red/
      node-red.0 2018-02-15 11:39:22.715 debug 15 Feb 11:39:22 - [info] Settings file : /opt/iobroker/iobroker-data/node-red/settings.js
      node-red.0 2018-02-15 11:39:22.566 debug 15 Feb 11:39:22 - [info] Dashboard version 2.8.0 started at /ui
      node-red.0 2018-02-15 11:39:21.929 debug 15 Feb 11:39:21 - [info] Polymer started at /polymer
      node-red.0 2018-02-15 11:39:16.704 debug 15 Feb 11:39:16 - [info] Loading palette nodes
      node-red.0 2018-02-15 11:39:15.532 debug 15 Feb 11:39:15 - [info] Linux 4.9.35-v7+ arm LE
      node-red.0 2018-02-15 11:39:15.532 debug 15 Feb 11:39:15 - [info] Node.js version: v4.8.7
      node-red.0 2018-02-15 11:39:15.531 debug 15 Feb 11:39:15 - [info] Node-RED version: v0.18.2
      node-red.0 2018-02-15 11:39:15.520 debug 15 Feb 11:39:15 - [info] Welcome to Node-RED ===================
      node-red.0 2018-02-15 11:39:12.300 info Starting node-red: --max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
      node-red.0 2018-02-15 11:39:11.635 info starting. Version 1.5.0 in /opt/iobroker/node_modules/iobroker.node-red, node: v4.8.7
      node-red.0 2018-02-15 11:39:11.579 debug statesDB connected
      node-red.0 2018-02-15 11:39:11.485 debug objectDB connected
      host.rasp1 2018-02-15 11:39:09.927 info instance system.adapter.node-red.0 started with pid 20442
      host.rasp1 2018-02-15 11:39:09.852 info object change system.adapter.node-red.0
      host.rasp1 2018-02-15 11:38:40.012 info instance system.adapter.node-red.0 terminated with code 0 (OK)
      Caught 2018-02-15 11:38:40.012 error by controller[2]: 2018-02-15 11:38:39.498 - node-red.0 2018-02-15 11:38:39.497 - info: node-red.0 terminating
      Caught 2018-02-15 11:38:40.010 error by controller[1]: 2018-02-15 11:38:38.987 - node-red.0 2018-02-15 11:38:38.985 - info: node-red.0 Adapter is disabled => stop
      node-red.0 2018-02-15 11:38:39.966 info terminating
      host.rasp1 2018-02-15 11:38:39.953 info stopInstance timeout "1000 system.adapter.node-red.0 killing pid 20051
      node-red.0 2018-02-15 11:38:39.542 info node-red exited with 0
      node-red.0 2018-02-15 11:38:39.498 debug 2018-02-15 11:38:39.497 - info: node-red.0 terminating
      node-red.0 2018-02-15 11:38:39.497 info terminating
      node-red.0 2018-02-15 11:38:38.987 debug 2018-02-15 11:38:38.985 - info: node-red.0 Adapter is disabled => stop
      node-red.0 2018-02-15 11:38:38.984 info Adapter is disabled => stop
      node-red.0 2018-02-15 11:38:38.969 info kill node-red task
      host.rasp1 2018-02-15 11:38:38.949 info stopInstance system.adapter.node-red.0
      Während der Laufzeit hatte ich gerade mehrere Verbindungsabbrüche zur States DB mit folgenden Fehlermeldungen:
      node-red.0	2018-02-15 11:28:19.673	warn	2018-02-15 11:28:19.672 - debug: node-red.0 statesDB connected
      node-red.0	2018-02-15 11:28:19.671	debug	statesDB connected
      node-red.0	2018-02-15 11:28:19.276	debug	objectDB connected
      node-red.0	2018-02-15 11:28:18.718	error	no connection to objects DB
      node-red.0	2018-02-15 11:28:19.278	warn	2018-02-15 11:28:19.277 - debug: node-red.0 objectDB connected
      node-red.0	2018-02-15 11:28:19.126	debug	15 Feb 11:28:19 - [info] [inject:Jede 10 Sekunden] repeat = 10000
      node-red.0	2018-02-15 11:28:19.122	error	at FunctionNode.Node.receive (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:215:14)
      node-red.0	2018-02-15 11:28:19.122	error	at FunctionNode.emit (events.js:169:7)
      node-red.0	2018-02-15 11:28:19.122	error	at emitOne (events.js:77:13)
      node-red.0	2018-02-15 11:28:19.122	error	at FunctionNode. (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/nodes/core/core/80-function.js:205:21)
      node-red.0	2018-02-15 11:28:19.122	error	at sendResults (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/nodes/core/core/80-function.js:52:18)
      node-red.0	2018-02-15 11:28:19.122	error	at FunctionNode.Node.send (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:202:14)
      node-red.0	2018-02-15 11:28:19.122	error	at IOBrokerOutNode.Node.receive (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:215:14)
      node-red.0	2018-02-15 11:28:19.122	error	at IOBrokerOutNode.emit (events.js:169:7)
      node-red.0	2018-02-15 11:28:19.122	error	at IOBrokerOutNode. (/opt/iobroker/node_modules/iobroker.node-red/nodes/ioBroker.js:261:29)
      node-red.0	2018-02-15 11:28:19.122	error	15 Feb 11:28:19 - [error] [ioBroker out:Brennerauslastung] TypeError: adapter.getForeignState is not a function
      node-red.0	2018-02-15 11:28:19.116	error	at FunctionNode.Node.receive (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:215:14)
      node-red.0	2018-02-15 11:28:19.116	error	at FunctionNode.emit (events.js:169:7)
      node-red.0	2018-02-15 11:28:19.116	error	at emitOne (events.js:77:13)
      node-red.0	2018-02-15 11:28:19.116	error	at FunctionNode. (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/nodes/core/core/80-function.js:205:21)
      node-red.0	2018-02-15 11:28:19.116	error	at sendResults (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/nodes/core/core/80-function.js:52:18)
      node-red.0	2018-02-15 11:28:19.116	error	at FunctionNode.Node.send (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:202:14)
      node-red.0	2018-02-15 11:28:19.116	error	at IOBrokerOutNode.Node.receive (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:215:14)
      node-red.0	2018-02-15 11:28:19.116	error	at IOBrokerOutNode.emit (events.js:169:7)
      node-red.0	2018-02-15 11:28:19.116	error	at IOBrokerOutNode. (/opt/iobroker/node_modules/iobroker.node-red/nodes/ioBroker.js:261:29)
      node-red.0	2018-02-15 11:28:19.116	error	15 Feb 11:28:19 - [error] [ioBroker out:Brennerlaufzeit_Std] TypeError: adapter.getForeignState is not a function
      node-red.0	2018-02-15 11:28:19.106	error	at FunctionNode.Node.receive (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:215:14)
      node-red.0	2018-02-15 11:28:19.106	error	at FunctionNode.emit (events.js:169:7)
      node-red.0	2018-02-15 11:28:19.106	error	at emitOne (events.js:77:13)
      node-red.0	2018-02-15 11:28:19.106	error	at FunctionNode. (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/nodes/core/core/80-function.js:205:21)
      node-red.0	2018-02-15 11:28:19.106	error	at sendResults (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/nodes/core/core/80-function.js:52:18)
      node-red.0	2018-02-15 11:28:19.106	error	at FunctionNode.Node.send (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:202:14)
      node-red.0	2018-02-15 11:28:19.106	error	at IOBrokerOutNode.Node.receive (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:215:14)
      node-red.0	2018-02-15 11:28:19.106	error	at IOBrokerOutNode.emit (events.js:169:7)
      node-red.0	2018-02-15 11:28:19.106	error	at IOBrokerOutNode. (/opt/iobroker/node_modules/iobroker.node-red/nodes/ioBroker.js:261:29)
      node-red.0	2018-02-15 11:28:19.106	error	15 Feb 11:28:19 - [error] [ioBroker out:Brenner] TypeError: adapter.getForeignState is not a function
      node-red.0	2018-02-15 11:28:19.100	error	at Timer.listOnTimeout (timers.js:92:15)
      node-red.0	2018-02-15 11:28:19.100	error	at null._onTimeout (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/nodes/core/core/20-inject.js:58:20)
      node-red.0	2018-02-15 11:28:19.100	error	at InjectNode.emit (events.js:169:7)
      node-red.0	2018-02-15 11:28:19.100	error	at emitOne (events.js:77:13)
      node-red.0	2018-02-15 11:28:19.100	error	at InjectNode. (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/nodes/core/core/20-inject.js:77:22)
      node-red.0	2018-02-15 11:28:19.100	error	at InjectNode.Node.send (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:137:22)
      node-red.0	2018-02-15 11:28:19.100	error	at IOBrokerGetNode.Node.receive (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:215:14)
      node-red.0	2018-02-15 11:28:19.100	error	at IOBrokerGetNode.emit (events.js:169:7)
      node-red.0	2018-02-15 11:28:19.100	error	at IOBrokerGetNode. (/opt/iobroker/node_modules/iobroker.node-red/nodes/ioBroker.js:341:29)
      node-red.0	2018-02-15 11:28:19.100	error	15 Feb 11:28:19 - [error] [ioBroker get:Mischer_Loop] TypeError: adapter.getForeignState is not a function
      node-red.0	2018-02-15 11:28:19.085	debug	15 Feb 11:28:19 - [info] [inject:Jede 15 Sekunden] repeat = 15000
      node-red.0	2018-02-15 11:28:19.080	error	at Timer.listOnTimeout (timers.js:92:15)
      node-red.0	2018-02-15 11:28:19.080	error	at null._onTimeout (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/nodes/core/core/20-inject.js:58:20)
      node-red.0	2018-02-15 11:28:19.080	error	at InjectNode.emit (events.js:169:7)
      node-red.0	2018-02-15 11:28:19.080	error	at emitOne (events.js:77:13)
      node-red.0	2018-02-15 11:28:19.080	error	at InjectNode. (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/nodes/core/core/20-inject.js:77:22)
      node-red.0	2018-02-15 11:28:19.080	error	at InjectNode.Node.send (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:137:22)
      node-red.0	2018-02-15 11:28:19.080	error	at IOBrokerGetNode.Node.receive (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:215:14)
      node-red.0	2018-02-15 11:28:19.080	error	at IOBrokerGetNode.emit (events.js:169:7)
      node-red.0	2018-02-15 11:28:19.080	error	at IOBrokerGetNode. (/opt/iobroker/node_modules/iobroker.node-red/nodes/ioBroker.js:341:29)
      node-red.0	2018-02-15 11:28:19.080	error	15 Feb 11:28:19 - [error] [ioBroker get:Regelung Status] TypeError: adapter.getForeignState is not a function
      node-red.0	2018-02-15 11:28:19.074	error	15 Feb 11:28:19 - [info] [inject:Jede 15 Sekunden] repeat = 15000
      node-red.0	2018-02-15 11:28:19.074	error	at Timer.listOnTimeout (timers.js:92:15)
      node-red.0	2018-02-15 11:28:19.074	error	at null._onTimeout (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/nodes/core/core/20-inject.js:58:20)
      node-red.0	2018-02-15 11:28:19.074	error	at InjectNode.emit (events.js:169:7)
      node-red.0	2018-02-15 11:28:19.074	error	at emitOne (events.js:77:13)
      node-red.0	2018-02-15 11:28:19.074	error	at InjectNode. (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/nodes/core/core/20-inject.js:77:22)
      node-red.0	2018-02-15 11:28:19.074	error	at InjectNode.Node.send (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:137:22)
      node-red.0	2018-02-15 11:28:19.074	error	at IOBrokerGetNode.Node.receive (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:215:14)
      node-red.0	2018-02-15 11:28:19.074	error	at IOBrokerGetNode.emit (events.js:169:7)
      node-red.0	2018-02-15 11:28:19.074	error	at IOBrokerGetNode. (/opt/iobroker/node_modules/iobroker.node-red/nodes/ioBroker.js:341:29)
      node-red.0	2018-02-15 11:28:19.074	error	15 Feb 11:28:19 - [error] [ioBroker get:Status] TypeError: adapter.getForeignState is not a function
      node-red.0	2018-02-15 11:28:19.072	error	15 Feb 11:28:19 - [info] [inject:Jede 15 Sekunden] repeat = 15000
      node-red.0	2018-02-15 11:28:19.072	error	at Timer.listOnTimeout (timers.js:92:15)
      node-red.0	2018-02-15 11:28:19.072	error	at null._onTimeout (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/nodes/core/core/20-inject.js:58:20)
      node-red.0	2018-02-15 11:28:19.072	error	at InjectNode.emit (events.js:169:7)
      node-red.0	2018-02-15 11:28:19.072	error	at emitOne (events.js:77:13)
      node-red.0	2018-02-15 11:28:19.072	error	at InjectNode. (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/nodes/core/core/20-inject.js:77:22)
      node-red.0	2018-02-15 11:28:19.072	error	at InjectNode.Node.send (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:137:22)
      node-red.0	2018-02-15 11:28:19.072	error	at IOBrokerGetNode.Node.receive (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:215:14)
      node-red.0	2018-02-15 11:28:19.072	error	at IOBrokerGetNode.emit (events.js:169:7)
      node-red.0	2018-02-15 11:28:19.072	error	at IOBrokerGetNode. (/opt/iobroker/node_modules/iobroker.node-red/nodes/ioBroker.js:341:29)
      node-red.0	2018-02-15 11:28:19.072	error	15 Feb 11:28:19 - [error] [ioBroker get:Status] TypeError: adapter.getForeignState is not a function
      node-red.0	2018-02-15 11:28:19.072	error	15 Feb 11:28:19 - [info] [inject:Jede Minute] repeat = 60000
      node-red.0	2018-02-15 11:28:19.066	error	at Timer.listOnTimeout (timers.js:92:15)
      node-red.0	2018-02-15 11:28:19.066	error	at null._onTimeout (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/nodes/core/core/20-inject.js:58:20)
      node-red.0	2018-02-15 11:28:19.066	error	at InjectNode.emit (events.js:169:7)
      node-red.0	2018-02-15 11:28:19.066	error	at emitOne (events.js:77:13)
      node-red.0	2018-02-15 11:28:19.066	error	at InjectNode. (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/nodes/core/core/20-inject.js:77:22)
      node-red.0	2018-02-15 11:28:19.066	error	at InjectNode.Node.send (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:137:22)
      node-red.0	2018-02-15 11:28:19.066	error	at IOBrokerGetNode.Node.receive (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:215:14)
      node-red.0	2018-02-15 11:28:19.066	error	at IOBrokerGetNode.emit (events.js:169:7)
      node-red.0	2018-02-15 11:28:19.066	error	at IOBrokerGetNode. (/opt/iobroker/node_modules/iobroker.node-red/nodes/ioBroker.js:341:29)
      node-red.0	2018-02-15 11:28:19.066	error	15 Feb 11:28:19 - [error] [ioBroker get:If connected to CCU] TypeError: adapter.getForeignState is not a function
      node-red.0	2018-02-15 11:28:19.066	error	15 Feb 11:28:19 - [info] [inject:Jede 15 Sekunden] repeat = 15000
      node-red.0	2018-02-15 11:28:19.063	error	at Timer.listOnTimeout (timers.js:92:15)
      node-red.0	2018-02-15 11:28:19.063	error	at null._onTimeout (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/nodes/core/core/20-inject.js:58:20)
      node-red.0	2018-02-15 11:28:19.063	error	at InjectNode.emit (events.js:169:7)
      node-red.0	2018-02-15 11:28:19.063	error	at emitOne (events.js:77:13)
      node-red.0	2018-02-15 11:28:19.063	error	at InjectNode. (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/nodes/core/core/20-inject.js:77:22)
      node-red.0	2018-02-15 11:28:19.063	error	at InjectNode.Node.send (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:202:14)
      node-red.0	2018-02-15 11:28:19.063	error	at IOBrokerGetNode.Node.receive (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:215:14)
      node-red.0	2018-02-15 11:28:19.063	error	at IOBrokerGetNode.emit (events.js:169:7)
      node-red.0	2018-02-15 11:28:19.063	error	at IOBrokerGetNode. (/opt/iobroker/node_modules/iobroker.node-red/nodes/ioBroker.js:341:29)
      node-red.0	2018-02-15 11:28:19.063	error	15 Feb 11:28:19 - [error] [ioBroker get:Vorlaufsoll FB] TypeError: adapter.getForeignState is not a function
      node-red.0	2018-02-15 11:28:19.061	error	at Timer.listOnTimeout (timers.js:92:15)
      node-red.0	2018-02-15 11:28:19.061	error	at null._onTimeout (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/nodes/core/core/20-inject.js:58:20)
      node-red.0	2018-02-15 11:28:19.061	error	at InjectNode.emit (events.js:169:7)
      node-red.0	2018-02-15 11:28:19.061	error	at emitOne (events.js:77:13)
      node-red.0	2018-02-15 11:28:19.061	error	at InjectNode. (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/nodes/core/core/20-inject.js:77:22)
      node-red.0	2018-02-15 11:28:19.061	error	at InjectNode.Node.send (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:202:14)
      node-red.0	2018-02-15 11:28:19.061	error	at IOBrokerGetNode.Node.receive (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:215:14)
      node-red.0	2018-02-15 11:28:19.061	error	at IOBrokerGetNode.emit (events.js:169:7)
      node-red.0	2018-02-15 11:28:19.061	error	at IOBrokerGetNode. (/opt/iobroker/node_modules/iobroker.node-red/nodes/ioBroker.js:341:29)
      node-red.0	2018-02-15 11:28:19.061	error	15 Feb 11:28:19 - [error] [ioBroker get:Aussentemperatur] TypeError: adapter.getForeignState is not a function
      node-red.0	2018-02-15 11:28:19.059	error	at FunctionNode.Node.receive (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:215:14)
      node-red.0	2018-02-15 11:28:19.059	error	at FunctionNode.emit (events.js:169:7)
      node-red.0	2018-02-15 11:28:19.059	error	at emitOne (events.js:77:13)
      node-red.0	2018-02-15 11:28:19.059	error	at FunctionNode. (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/nodes/core/core/80-function.js:205:21)
      node-red.0	2018-02-15 11:28:19.059	error	at sendResults (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/nodes/core/core/80-function.js:52:18)
      node-red.0	2018-02-15 11:28:19.059	error	at FunctionNode.Node.send (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:202:14)
      node-red.0	2018-02-15 11:28:19.059	error	at IOBrokerGetNode.Node.receive (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:215:14)
      node-red.0	2018-02-15 11:28:19.059	error	at IOBrokerGetNode.emit (events.js:169:7)
      node-red.0	2018-02-15 11:28:19.059	error	at IOBrokerGetNode. (/opt/iobroker/node_modules/iobroker.node-red/nodes/ioBroker.js:341:29)
      node-red.0	2018-02-15 11:28:19.059	error	15 Feb 11:28:19 - [error] [ioBroker get:Wasser An] TypeError: adapter.getForeignState is not a function
      node-red.0	2018-02-15 11:28:19.059	error	15 Feb 11:28:19 - [error] [ioBroker get:HZG An] TypeError: adapter.getForeignState is not a function
      node-red.0	2018-02-15 11:28:19.053	error	at FunctionNode.Node.receive (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:215:14)
      node-red.0	2018-02-15 11:28:19.053	error	at FunctionNode.emit (events.js:169:7)
      node-red.0	2018-02-15 11:28:19.053	error	at emitOne (events.js:77:13)
      node-red.0	2018-02-15 11:28:19.053	error	at FunctionNode. (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/nodes/core/core/80-function.js:205:21)
      node-red.0	2018-02-15 11:28:19.053	error	at sendResults (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/nodes/core/core/80-function.js:52:18)
      node-red.0	2018-02-15 11:28:19.053	error	at FunctionNode.Node.send (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:202:14)
      node-red.0	2018-02-15 11:28:19.053	error	at IOBrokerGetNode.Node.receive (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:215:14)
      node-red.0	2018-02-15 11:28:19.053	error	at IOBrokerGetNode.emit (events.js:169:7)
      node-red.0	2018-02-15 11:28:19.053	error	at IOBrokerGetNode. (/opt/iobroker/node_modules/iobroker.node-red/nodes/ioBroker.js:341:29)
      node-red.0	2018-02-15 11:28:19.053	error	15 Feb 11:28:19 - [error] [ioBroker get:FB An] TypeError: adapter.getForeignState is not a function
      node-red.0	2018-02-15 11:28:19.047	debug	15 Feb 11:28:19 - [info] [inject:Jede 15 Sekunden] repeat = 15000
      node-red.0	2018-02-15 11:28:18.960	error	at Timer.listOnTimeout (timers.js:92:15)
      node-red.0	2018-02-15 11:28:18.960	error	at null._onTimeout (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/nodes/core/core/20-inject.js:58:20)
      node-red.0	2018-02-15 11:28:18.960	error	at InjectNode.emit (events.js:169:7)
      node-red.0	2018-02-15 11:28:18.960	error	at emitOne (events.js:77:13)
      node-red.0	2018-02-15 11:28:18.960	error	at InjectNode. (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/nodes/core/core/20-inject.js:77:22)
      node-red.0	2018-02-15 11:28:18.960	error	at InjectNode.Node.send (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:202:14)
      node-red.0	2018-02-15 11:28:18.960	error	at IOBrokerGetNode.Node.receive (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:215:14)
      node-red.0	2018-02-15 11:28:18.960	error	at IOBrokerGetNode.emit (events.js:169:7)
      node-red.0	2018-02-15 11:28:18.960	error	at IOBrokerGetNode. (/opt/iobroker/node_modules/iobroker.node-red/nodes/ioBroker.js:341:29)
      node-red.0	2018-02-15 11:28:18.960	error	15 Feb 11:28:18 - [error] [ioBroker get:Aussentemperatur] TypeError: adapter.getForeignState is not a function
      node-red.0	2018-02-15 11:28:18.956	error	at Timer.listOnTimeout (timers.js:92:15)
      node-red.0	2018-02-15 11:28:18.956	error	at null._onTimeout (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/nodes/core/core/20-inject.js:58:20)
      node-red.0	2018-02-15 11:28:18.956	error	at InjectNode.emit (events.js:169:7)
      node-red.0	2018-02-15 11:28:18.956	error	at emitOne (events.js:77:13)
      node-red.0	2018-02-15 11:28:18.956	error	at InjectNode. (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/nodes/core/core/20-inject.js:77:22)
      node-red.0	2018-02-15 11:28:18.956	error	at InjectNode.Node.send (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:202:14)
      node-red.0	2018-02-15 11:28:18.956	error	at IOBrokerGetNode.Node.receive (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:215:14)
      node-red.0	2018-02-15 11:28:18.956	error	at IOBrokerGetNode.emit (events.js:169:7)
      node-red.0	2018-02-15 11:28:18.956	error	at IOBrokerGetNode. (/opt/iobroker/node_modules/iobroker.node-red/nodes/ioBroker.js:341:29)
      node-red.0	2018-02-15 11:28:18.956	error	15 Feb 11:28:18 - [error] [ioBroker get:Wassertemperatur] TypeError: adapter.getForeignState is not a function
      node-red.0	2018-02-15 11:28:18.952	error	at Timer.listOnTimeout (timers.js:92:15)
      node-red.0	2018-02-15 11:28:18.952	error	at null._onTimeout (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/nodes/core/core/20-inject.js:58:20)
      node-red.0	2018-02-15 11:28:18.952	error	at InjectNode.emit (events.js:169:7)
      node-red.0	2018-02-15 11:28:18.952	error	at emitOne (events.js:77:13)
      node-red.0	2018-02-15 11:28:18.952	error	at InjectNode. (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/nodes/core/core/20-inject.js:77:22)
      node-red.0	2018-02-15 11:28:18.952	error	at InjectNode.Node.send (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:202:14)
      node-red.0	2018-02-15 11:28:18.952	error	at IOBrokerGetNode.Node.receive (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:215:14)
      node-red.0	2018-02-15 11:28:18.952	error	at IOBrokerGetNode.emit (events.js:169:7)
      node-red.0	2018-02-15 11:28:18.952	error	at IOBrokerGetNode. (/opt/iobroker/node_modules/iobroker.node-red/nodes/ioBroker.js:341:29)
      node-red.0	2018-02-15 11:28:18.952	error	15 Feb 11:28:18 - [error] [ioBroker get:Kesseltemperatur] TypeError: adapter.getForeignState is not a function
      node-red.0	2018-02-15 11:28:18.952	error	15 Feb 11:28:18 - [error] [ioBroker get:Fussbodenrücklauf] TypeError: adapter.getForeignState is not a function
      node-red.0	2018-02-15 11:28:18.946	error	at Timer.listOnTimeout (timers.js:92:15)
      node-red.0	2018-02-15 11:28:18.946	error	at null._onTimeout (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/nodes/core/core/20-inject.js:58:20)
      node-red.0	2018-02-15 11:28:18.946	error	at InjectNode.emit (events.js:169:7)
      node-red.0	2018-02-15 11:28:18.946	error	at emitOne (events.js:77:13)
      node-red.0	2018-02-15 11:28:18.946	error	at InjectNode. (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/nodes/core/core/20-inject.js:77:22)
      node-red.0	2018-02-15 11:28:18.946	error	at InjectNode.Node.send (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:202:14)
      node-red.0	2018-02-15 11:28:18.946	error	at IOBrokerGetNode.Node.receive (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:215:14)
      node-red.0	2018-02-15 11:28:18.946	error	at IOBrokerGetNode.emit (events.js:169:7)
      node-red.0	2018-02-15 11:28:18.946	error	at IOBrokerGetNode. (/opt/iobroker/node_modules/iobroker.node-red/nodes/ioBroker.js:341:29)
      node-red.0	2018-02-15 11:28:18.946	error	15 Feb 11:28:18 - [error] [ioBroker get:Fussbodenvorlauf] TypeError: adapter.getForeignState is not a function
      node-red.0	2018-02-15 11:28:18.942	error	at Timer.listOnTimeout (timers.js:92:15)
      node-red.0	2018-02-15 11:28:18.942	error	at null._onTimeout (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/nodes/core/core/20-inject.js:58:20)
      node-red.0	2018-02-15 11:28:18.942	error	at InjectNode.emit (events.js:169:7)
      node-red.0	2018-02-15 11:28:18.942	error	at emitOne (events.js:77:13)
      node-red.0	2018-02-15 11:28:18.942	error	at InjectNode. (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/nodes/core/core/20-inject.js:77:22)
      node-red.0	2018-02-15 11:28:18.942	error	at InjectNode.Node.send (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:202:14)
      node-red.0	2018-02-15 11:28:18.942	error	at IOBrokerGetNode.Node.receive (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:215:14)
      node-red.0	2018-02-15 11:28:18.942	error	at IOBrokerGetNode.emit (events.js:169:7)
      node-red.0	2018-02-15 11:28:18.942	error	at IOBrokerGetNode. (/opt/iobroker/node_modules/iobroker.node-red/nodes/ioBroker.js:341:29)
      node-red.0	2018-02-15 11:28:18.942	error	15 Feb 11:28:18 - [error] [ioBroker get:Heizungsrücklauf] TypeError: adapter.getForeignState is not a function
      node-red.0	2018-02-15 11:28:18.938	error	at Timer.listOnTimeout (timers.js:92:15)
      node-red.0	2018-02-15 11:28:18.938	error	at null._onTimeout (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/nodes/core/core/20-inject.js:58:20)
      node-red.0	2018-02-15 11:28:18.938	error	at InjectNode.emit (events.js:169:7)
      node-red.0	2018-02-15 11:28:18.938	error	at emitOne (events.js:77:13)
      node-red.0	2018-02-15 11:28:18.938	error	at InjectNode. (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/nodes/core/core/20-inject.js:77:22)
      node-red.0	2018-02-15 11:28:18.938	error	at InjectNode.Node.send (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:202:14)
      node-red.0	2018-02-15 11:28:18.938	error	at IOBrokerGetNode.Node.receive (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:215:14)
      node-red.0	2018-02-15 11:28:18.938	error	at IOBrokerGetNode.emit (events.js:169:7)
      node-red.0	2018-02-15 11:28:18.938	error	at IOBrokerGetNode. (/opt/iobroker/node_modules/iobroker.node-red/nodes/ioBroker.js:341:29)
      node-red.0	2018-02-15 11:28:18.938	error	15 Feb 11:28:18 - [error] [ioBroker get:Heizungsvorlauf] TypeError: adapter.getForeignState is not a function
      node-red.0	2018-02-15 11:28:18.931	debug	15 Feb 11:28:18 - [info] [inject:8708f6be.fced8] repeat = 5000
      node-red.0	2018-02-15 11:28:18.925	error	at FunctionNode.Node.receive (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:215:14)
      node-red.0	2018-02-15 11:28:18.925	error	at FunctionNode.emit (events.js:169:7)
      node-red.0	2018-02-15 11:28:18.925	error	at emitOne (events.js:77:13)
      node-red.0	2018-02-15 11:28:18.925	error	at FunctionNode. (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/nodes/core/core/80-function.js:205:21)
      node-red.0	2018-02-15 11:28:18.925	error	at sendResults (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/nodes/core/core/80-function.js:52:18)
      node-red.0	2018-02-15 11:28:18.925	error	at FunctionNode.Node.send (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:202:14)
      node-red.0	2018-02-15 11:28:18.925	error	at IOBrokerOutNode.Node.receive (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:215:14)
      node-red.0	2018-02-15 11:28:18.925	error	at IOBrokerOutNode.emit (events.js:169:7)
      node-red.0	2018-02-15 11:28:18.925	error	at IOBrokerOutNode. (/opt/iobroker/node_modules/iobroker.node-red/nodes/ioBroker.js:261:29)
      node-red.0	2018-02-15 11:28:18.925	error	15 Feb 11:28:18 - [error] [ioBroker out:Luftfeuchte] TypeError: adapter.getForeignState is not a function
      node-red.0	2018-02-15 11:28:18.922	error	at FunctionNode.Node.receive (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:215:14)
      node-red.0	2018-02-15 11:28:18.922	error	at FunctionNode.emit (events.js:169:7)
      node-red.0	2018-02-15 11:28:18.922	error	at emitOne (events.js:77:13)
      node-red.0	2018-02-15 11:28:18.922	error	at FunctionNode. (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/nodes/core/core/80-function.js:205:21)
      node-red.0	2018-02-15 11:28:18.922	error	at sendResults (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/nodes/core/core/80-function.js:52:18)
      node-red.0	2018-02-15 11:28:18.922	error	at FunctionNode.Node.send (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:202:14)
      node-red.0	2018-02-15 11:28:18.922	error	at IOBrokerOutNode.Node.receive (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:215:14)
      node-red.0	2018-02-15 11:28:18.922	error	at IOBrokerOutNode.emit (events.js:169:7)
      node-red.0	2018-02-15 11:28:18.922	error	at IOBrokerOutNode. (/opt/iobroker/node_modules/iobroker.node-red/nodes/ioBroker.js:261:29)
      node-red.0	2018-02-15 11:28:18.922	error	15 Feb 11:28:18 - [error] [ioBroker out:Temperatur] TypeError: adapter.getForeignState is not a function
      node-red.0	2018-02-15 11:28:18.830	error	at InjectNode.Node.send (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:202:14)
      node-red.0	2018-02-15 11:28:18.830	error	at TriggerNode.Node.receive (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:215:14)
      node-red.0	2018-02-15 11:28:18.830	error	at TriggerNode.emit (events.js:169:7)
      node-red.0	2018-02-15 11:28:18.830	error	at emitOne (events.js:77:13)
      node-red.0	2018-02-15 11:28:18.830	error	at TriggerNode. (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/nodes/core/core/89-trigger.js:131:56)
      node-red.0	2018-02-15 11:28:18.830	error	at TriggerNode.Node.send (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:137:22)
      node-red.0	2018-02-15 11:28:18.830	error	at IOBrokerOutNode.Node.receive (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:215:14)
      node-red.0	2018-02-15 11:28:18.830	error	at IOBrokerOutNode.emit (events.js:169:7)
      node-red.0	2018-02-15 11:28:18.830	error	at IOBrokerOutNode. (/opt/iobroker/node_modules/iobroker.node-red/nodes/ioBroker.js:261:29)
      node-red.0	2018-02-15 11:28:18.830	error	15 Feb 11:28:18 - [error] [ioBroker out:118ddde.6863622] TypeError: adapter.getForeignState is not a function
      node-red.0	2018-02-15 11:28:18.816	error	at Timer.listOnTimeout (timers.js:92:15)
      node-red.0	2018-02-15 11:28:18.816	error	at null._onTimeout (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/nodes/core/core/20-inject.js:58:20)
      node-red.0	2018-02-15 11:28:18.816	error	at InjectNode.emit (events.js:169:7)
      node-red.0	2018-02-15 11:28:18.816	error	at emitOne (events.js:77:13)
      node-red.0	2018-02-15 11:28:18.816	error	at InjectNode. (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/nodes/core/core/20-inject.js:77:22)
      node-red.0	2018-02-15 11:28:18.816	error	at InjectNode.Node.send (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:202:14)
      node-red.0	2018-02-15 11:28:18.816	error	at IOBrokerOutNode.Node.receive (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:215:14)
      node-red.0	2018-02-15 11:28:18.816	error	at IOBrokerOutNode.emit (events.js:169:7)
      node-red.0	2018-02-15 11:28:18.816	error	at IOBrokerOutNode. (/opt/iobroker/node_modules/iobroker.node-red/nodes/ioBroker.js:261:29)
      node-red.0	2018-02-15 11:28:18.816	error	15 Feb 11:28:18 - [error] [ioBroker out:Vorrang Wasser] TypeError: adapter.getForeignState is not a function
      node-red.0	2018-02-15 11:28:18.812	error	at Timer.listOnTimeout (timers.js:92:15)
      node-red.0	2018-02-15 11:28:18.812	error	at null._onTimeout (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/nodes/core/core/20-inject.js:58:20)
      node-red.0	2018-02-15 11:28:18.812	error	at InjectNode.emit (events.js:169:7)
      node-red.0	2018-02-15 11:28:18.812	error	at emitOne (events.js:77:13)
      node-red.0	2018-02-15 11:28:18.812	error	at InjectNode. (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/nodes/core/core/20-inject.js:77:22)
      node-red.0	2018-02-15 11:28:18.812	error	at InjectNode.Node.send (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:202:14)
      node-red.0	2018-02-15 11:28:18.812	error	at IOBrokerOutNode.Node.receive (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:215:14)
      node-red.0	2018-02-15 11:28:18.812	error	at IOBrokerOutNode.emit (events.js:169:7)
      node-red.0	2018-02-15 11:28:18.812	error	at IOBrokerOutNode. (/opt/iobroker/node_modules/iobroker.node-red/nodes/ioBroker.js:261:29)
      node-red.0	2018-02-15 11:28:18.812	error	15 Feb 11:28:18 - [error] [ioBroker out:Heizungsstrom] TypeError: adapter.getForeignState is not a function
      node-red.0	2018-02-15 11:28:18.808	error	at Timer.listOnTimeout (timers.js:92:15)
      node-red.0	2018-02-15 11:28:18.808	error	at null._onTimeout (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/nodes/core/core/20-inject.js:58:20)
      node-red.0	2018-02-15 11:28:18.808	error	at InjectNode.emit (events.js:169:7)
      node-red.0	2018-02-15 11:28:18.808	error	at emitOne (events.js:77:13)
      node-red.0	2018-02-15 11:28:18.808	error	at InjectNode. (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/nodes/core/core/20-inject.js:77:22)
      node-red.0	2018-02-15 11:28:18.808	error	at InjectNode.Node.send (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:202:14)
      node-red.0	2018-02-15 11:28:18.808	error	at IOBrokerOutNode.Node.receive (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:215:14)
      node-red.0	2018-02-15 11:28:18.808	error	at IOBrokerOutNode.emit (events.js:169:7)
      node-red.0	2018-02-15 11:28:18.808	error	at IOBrokerOutNode. (/opt/iobroker/node_modules/iobroker.node-red/nodes/ioBroker.js:261:29)
      node-red.0	2018-02-15 11:28:18.808	error	15 Feb 11:28:18 - [error] [ioBroker out:Heizungskessel] TypeError: adapter.getForeignState is not a function
      node-red.0	2018-02-15 11:28:18.804	error	at Timer.listOnTimeout (timers.js:92:15)
      node-red.0	2018-02-15 11:28:18.804	error	at null._onTimeout (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/nodes/core/core/20-inject.js:58:20)
      node-red.0	2018-02-15 11:28:18.804	error	at InjectNode.emit (events.js:169:7)
      node-red.0	2018-02-15 11:28:18.804	error	at emitOne (events.js:77:13)
      node-red.0	2018-02-15 11:28:18.804	error	at InjectNode. (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/nodes/core/core/20-inject.js:77:22)
      node-red.0	2018-02-15 11:28:18.804	error	at InjectNode.Node.send (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:202:14)
      node-red.0	2018-02-15 11:28:18.804	error	at IOBrokerOutNode.Node.receive (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:215:14)
      node-red.0	2018-02-15 11:28:18.804	error	at IOBrokerOutNode.emit (events.js:169:7)
      node-red.0	2018-02-15 11:28:18.804	error	at IOBrokerOutNode. (/opt/iobroker/node_modules/iobroker.node-red/nodes/ioBroker.js:261:29)
      node-red.0	2018-02-15 11:28:18.804	error	15 Feb 11:28:18 - [error] [ioBroker out:WW Zirkulationspumpe] TypeError: adapter.getForeignState is not a function
      node-red.0	2018-02-15 11:28:18.800	error	at Timer.listOnTimeout (timers.js:92:15)
      node-red.0	2018-02-15 11:28:18.800	error	at null._onTimeout (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/nodes/core/core/20-inject.js:58:20)
      node-red.0	2018-02-15 11:28:18.800	error	at InjectNode.emit (events.js:169:7)
      node-red.0	2018-02-15 11:28:18.800	error	at emitOne (events.js:77:13)
      node-red.0	2018-02-15 11:28:18.800	error	at InjectNode. (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/nodes/core/core/20-inject.js:77:22)
      node-red.0	2018-02-15 11:28:18.800	error	at InjectNode.Node.send (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:202:14)
      node-red.0	2018-02-15 11:28:18.800	error	at IOBrokerOutNode.Node.receive (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red/runtime/nodes/Node.js:215:14)
      node-red.0	2018-02-15 11:28:18.800	error	at IOBrokerOutNode.emit (events.js:169:7)
      node-red.0	2018-02-15 11:28:18.800	error	at IOBrokerOutNode. (/opt/iobroker/node_modules/iobroker.node-red/nodes/ioBroker.js:261:29)
      node-red.0	2018-02-15 11:28:18.800	error	15 Feb 11:28:18 - [error] [ioBroker out:WW Ladepumpe] TypeError: adapter.getForeignState is not a function
      		debug	at Timer.listOnTimeout (timers.js:92:15)
      Ich werde jetzt erst einmal eine größere Startverzögerung für die Injects in den Flows einbauen. Die Laufzeitfehler im laufenden Betrieb sind aber sehr problematisch.
      Wie erfolgt eigentlich die Kommunikation mit der States DB? Direktzugriff auf den States-File oder Kommunikation über den Port (9001?) ?
      Ich habe nun Zeitverzögerungen für den ersten Anlauf der Injects eingebaut (>15 Sekunden). Hier das Log zum Neustart von Node-Red mit den entsprechenden Problemen beim Connect zur States DB.
      >!  ` > node-red.0 2018-02-15 12:31:32.277 debug 15 Feb 12:31:32 - [info] [inject:Jede Minute] repeat = 60000
      > node-red.0 2018-02-15 12:31:04.426 debug 15 Feb 12:31:04 - [info] [inject:Jede 15 Sekunden] repeat = 15000
      > node-red.0 2018-02-15 12:31:01.125 debug 15 Feb 12:31:01 - [info] [inject:Jede 15 Sekunden] repeat = 15000
      > node-red.0 2018-02-15 12:30:48.376 warn Reconnection to DB.
      > node-red.0 2018-02-15 12:30:48.343 warn Reconnection to DB.
      > node-red.0 2018-02-15 12:30:50.932 debug 15 Feb 12:30:50 - [info] [inject:Jede 15 Sekunden] repeat = 15000
      > node-red.0 2018-02-15 12:30:48.377 debug 2018-02-15 12:30:48.376 - warn: node-red.0 Reconnection to DB.
      > node-red.0 2018-02-15 12:30:48.345 debug 2018-02-15 12:30:48.344 - warn: node-red.0 Reconnection to DB.
      > node-red.0 2018-02-15 12:30:47.751 warn 2018-02-15 12:30:47.748 - debug: node-red.0 statesDB connected
      > node-red.0 2018-02-15 12:30:47.748 debug statesDB connected
      > node-red.0 2018-02-15 12:30:47.570 warn 2018-02-15 12:30:47.569 - debug: node-red.0 statesDB connected
      > node-red.0 2018-02-15 12:30:47.566 debug statesDB connected
      > node-red.0 2018-02-15 12:30:47.500 warn 15 Feb 12:30:47 - [warn] Communication send error: Error: not opened
      > node-red.0 2018-02-15 12:30:45.205 error no connection to states DB: Connection timeout
      > node-red.0 2018-02-15 12:30:47.246 debug 15 Feb 12:30:47 - [info] [inject:Jede 10 Sekunden] repeat = 10000
      > node-red.0 2018-02-15 12:30:47.228 debug 15 Feb 12:30:47 - [info] [inject:Jede 15 Sekunden] repeat = 15000
      > node-red.0 2018-02-15 12:30:46.213 debug 15 Feb 12:30:46 - [info] [inject:8708f6be.fced8] repeat = 300000
      > node-red.0 2018-02-15 12:30:46.170 debug 15 Feb 12:30:46 - [info] [inject:Jede Minute] repeat = 60000
      > node-red.0 2018-02-15 12:30:45.208 warn 2018-02-15 12:30:45.207 - error: node-red.0 no connection to states DB: Connection timeout
      > node-red.0 2018-02-15 12:30:45.202 debug 15 Feb 12:30:45 - [info] Started flows
      > node-red.0 2018-02-15 12:30:41.760 debug 15 Feb 12:30:41 - [info] [inject:1 hour] repeat = 3600000
      > node-red.0 2018-02-15 12:30:40.453 debug 15 Feb 12:30:40 - [info] [inject:Reset 00:00 Uhr] crontab = 00 00 * * *
      > node-red.0 2018-02-15 12:30:18.177 debug 15 Feb 12:30:18 - [info] Starting flows
      > node-red.0 2018-02-15 12:30:17.405 debug objectDB connected
      > node-red.0 2018-02-15 12:30:17.416 warn 2018-02-15 12:30:17.414 - debug: node-red.0 objectDB connected
      > node-red.0 2018-02-15 12:30:17.351 debug 15 Feb 12:30:17 - [info] Server now running at [http://127.0.0.1:1880/](http://127.0.0.1:1880/)
      > node-red.0 2018-02-15 12:30:17.209 debug 15 Feb 12:30:17 - [37-rpi-piface.js] Error: "gpio load spi" command failed. Check device tree is disabled.
      > node-red.0 2018-02-15 12:30:17.173 debug 15 Feb 12:30:17 - [info] Flows file : /opt/iobroker/iobroker-data/node-red/flows.json
      > node-red.0 2018-02-15 12:30:17.169 warn 15 Feb 12:30:17 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
      > node-red.0 2018-02-15 12:30:17.168 debug 15 Feb 12:30:17 - [info] User directory : /opt/iobroker/iobroker-data/node-red/
      > node-red.0 2018-02-15 12:30:17.164 debug 15 Feb 12:30:17 - [info] Settings file : /opt/iobroker/iobroker-data/node-red/settings.js
      > node-red.0 2018-02-15 12:30:17.025 debug 15 Feb 12:30:17 - [info] Dashboard version 2.8.0 started at /ui
      > node-red.0 2018-02-15 12:30:16.377 debug 15 Feb 12:30:16 - [info] Polymer started at /polymer
      > node-red.0 2018-02-15 12:30:11.140 debug 15 Feb 12:30:11 - [info] Loading palette nodes
      > node-red.0 2018-02-15 12:30:09.995 debug 15 Feb 12:30:09 - [info] Linux 4.9.35-v7+ arm LE
      > node-red.0 2018-02-15 12:30:09.995 debug 15 Feb 12:30:09 - [info] Node.js version: v4.8.7
      > node-red.0 2018-02-15 12:30:09.994 debug 15 Feb 12:30:09 - [info] Node-RED version: v0.18.2
      > node-red.0 2018-02-15 12:30:09.986 debug ===================
      > node-red.0 2018-02-15 12:30:09.986 debug Welcome to Node-RED
      > node-red.0 2018-02-15 12:30:09.986 debug 15 Feb 12:30:09 - [info]
      > node-red.0 2018-02-15 12:30:06.741 info Starting node-red: –max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js `
        apollon77 last edited by
        Aaaaalso ich hab da mal reingeschaut und habe folgendes rausgefunden:
        Wenn ich es korrekt verstehe kann man aktuell maximal 100 "Input"-Nodes nutzen die auf Werte von ioBroker subscriben. Wie viele hast Du da?
        Ansonsten hast Du recht, da gibt es ein Problem wenn die Initialisieirung der State-DB für die "ioBroker.nodes" länger dauert … Dann bist Du ggf mit deinen "set"-Befehlen zu schnell. Ich schaue mal ob mir was einfällt
          Sooooooo … kannst Du Testen ?!
          Ich habe mal auf Github was eingebaut was alle "input"-Befehle von OutNode und GetNode queued wenn die ioBroker.State-DB connection noch nicht initialisiert ist. Sobald initialisiert wird das nachverarbeitet.
          Ich kann selbst nicht korrekt testen ob es tut. Kannst Du mal ?! :-)) Verspreche aber nichts.
          habe Logging eingebaut erstmal zum test. Es wird alles geloggt was gequeued wird und dann wieviele nachverarbeitet worden.
          Und Log per Debug wäre wieder cool 🙂
            Hmmmmmm…....
            Was meinst Du denn mit maximal 100 "Input"-Nodes .....?
            In node-red gibt es ja je eine
            • input-node die auf Änderungen wartet und dann den Flow startet
            • output-node die Werte in die iobroker-Objekte schreibt
            • function-node zum Lesen von Werten aus iobroker-Objekten
            In allen Flows habe ich heute ca. 150 der o.g. Nodes in den unterschiedlichen Flows (das liesse sich bestimmt noch optimieren). Die meisten davon sind function-nodes zum Lesen von iobroker Objektwerten innerhalb der zyklischen Nodes. Sind diese in der geänderten Version auch geqeued?
            Woher kommt denn die Beschränkung auf 100 Nodes? Ist das eine Einschränkung für node-red oder alle Adapter?
            Kannst Du vielleicht auch mal erklären, wie auf die States DB zugegriffen wird?
            Ich teste gerne Morgen im Laufe des Tages mal die geänderte Version mal live an meiner Heizungssteuerung.
            Falls es Probleme gibt, wie komme ich dann zurück zur Version 1.5?
            P.S.: Noch eine andere Frage: Kann ich die Reihenfolge der Starts der Adapter beeinflussen?
              @tom57:
              Hmmmmmm…....
              • function-node zum Lesen von Werten aus iobroker-Objekten `
              Ignoriere das Limit. War ein Missverständnis von mir. Bei mehrt als "100 input-nodes" aknn es sein das Warnungen im Log kommen. Wenn das so wäre müsste man das Limit mal prüfen.
              @tom57:
              In allen Flows habe ich heute ca. 150 der o.g. Nodes in den unterschiedlichen Flows (das liesse sich bestimmt noch optimieren). Die meisten davon sind function-nodes zum Lesen von iobroker Objektwerten innerhalb der zyklischen Nodes. Sind diese in der geänderten Version auch geqeued? `
              Alle Zugriffe auf iobroker werden quasi so lange "verzögert" bis alles initialisiert ist. Bedeutet:
              • "input Nodes": Bei denen ändert sich nichts. Die bekommen erst dann "trigger" bei Wertänderungen wenn die States-DB verbunden ist. War schon so.
              • "output Nodes": Wenn ein Wert in ioBroker geschrieben werden soll und die state DB ist noch nicht verbunden dann wird der Request gequeued und ausgeführt sobald die Verbindung steht
              • "Function Nodes": Wenn die Node im Flow dran kommt und einen State-Wert lesen will und die DB noch nicht verbunden ist wird auch das gequeued und es geht damit dann mit dem Wert weiter sobald die DB da ist und so der Wert gelesen werden konnte.
              @tom57:
              Kannst Du vielleicht auch mal erklären, wie auf die States DB zugegriffen wird? `
              Das ist simpel. Der js-controller verwaltet die States/Object-DBs und stellt diese quasi als "Memory-Datenbank" zur Verfügung. Im Standardfall verbinden sich alle ioBroker-Prozesse über einen Netzwerk-Port dort hin. Diese Initialisierung erfolgt aber "asynchron" und von daher kann es sein das der erste Flow schon los läuft aber diese Verbindung noch nicht steht. Und das sind die Probleme die es hier wohl gibt.
              @tom57:
              Ich teste gerne Morgen im Laufe des Tages mal die geänderte Version mal live an meiner Heizungssteuerung. `
              Super, ich versuche am Ball zu bleiben um bei Problemen helfen zu können.
              @tom57:
              Falls es Probleme gibt, wie komme ich dann zurück zur Version 1.5? `
              Über Admin unter Adapterkannst Du jede frühere Version auswählen. Auch die 1.5.0 …
              @tom57:
              P.S.: Noch eine andere Frage: Kann ich die Reihenfolge der Starts der Adapter beeinflussen? `
              nope. Das bestimmt der js-controller.
              Warum?
                Bei mir wird im Admin die Version 1.5 noch nicht angezeigt. Auch nach Aktualisierung der Adapterinformationen.
                … habe ich jetzt gefunden, musste den aktiven Verwahrungsort ändern ... 🙂
                Mir ist aufgefallen, dass sich die Startreihenfolge der Adapter je nach Version des js-controllers ändert.
                Es wäre gut, wenn node-red als letzter Adapter starten würde oder es eine Möglichkeit gebe, die Startreihenfolge bei den Instanzen einzugeben, wie auch andere Parameter (Ram-Limit etc)
                Ich habe gerade wieder eine lange Fehlerliste im Log. Innerhalb von 100-200 mSek Fehler beim Zugriff auf die states DB.
                Liegt glaube ich daran, dass in einigen Flows periodisch 6-10 Werte direkt hintereinander abgefragt werden.
                Der gepufferte Zugriff sollte dann also die Lösung sein...werde ich jetzt mal testen
                Vielen Dank erst einmal für Deine Unterstützung
                Grüße Thomas
                  Version 1.5.1 funktioniert leider nicht. Läuft in einen unendlichen Loop bei Start 😞
                  ! host.rasp1 2018-02-16 09:55:15.147 info instance system.adapter.node-red.0 terminated with code 0 (OK)
                  ! node-red.0 2018-02-16 09:55:15.115 info terminating
                  ! host.rasp1 2018-02-16 09:55:15.103 info stopInstance timeout "1000 system.adapter.node-red.0 killing pid 18869
                  ! node-red.0 2018-02-16 09:55:14.843 debug 16 Feb 09:55:14 - [info] Starting flows
                  ! host.rasp1 2018-02-16 09:55:14.087 info stopInstance system.adapter.node-red.0
                  ! node-red.0 2018-02-16 09:55:14.096 info kill node-red task
                  ! node-red.0 2018-02-16 09:55:14.028 debug objectDB connected
                  ! host.rasp1 2018-02-16 09:55:14.077 info object change system.adapter.node-red.0
                  ! node-red.0 2018-02-16 09:55:14.039 warn 2018-02-16 09:55:14.037 - debug: node-red.0 objectDB connected
                  ! node-red.0 2018-02-16 09:55:13.972 debug 16 Feb 09:55:13 - [info] Server now running at http://127.0.0.1:1880/
                  ! node-red.0 2018-02-16 09:55:13.827 debug 16 Feb 09:55:13 - [37-rpi-piface.js] Error: "gpio load spi" command failed. Check device tree is disabled.
                  ! node-red.0 2018-02-16 09:55:13.784 debug 16 Feb 09:55:13 - [info] Flows file : /opt/iobroker/iobroker-data/node-red/flows.json
                  ! node-red.0 2018-02-16 09:55:13.781 warn 16 Feb 09:55:13 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
                  ! node-red.0 2018-02-16 09:55:13.780 debug 16 Feb 09:55:13 - [info] User directory : /opt/iobroker/iobroker-data/node-red/
                  ! node-red.0 2018-02-16 09:55:13.771 debug 16 Feb 09:55:13 - [info] Settings file : /opt/iobroker/iobroker-data/node-red/settings.js
                  ! node-red.0 2018-02-16 09:55:13.617 debug 16 Feb 09:55:13 - [info] Dashboard version 2.8.1 started at /ui
                  ! node-red.0 2018-02-16 09:55:12.938 debug 16 Feb 09:55:12 - [info] Polymer started at /polymer
                  ! node-red.0 2018-02-16 09:55:07.430 debug 16 Feb 09:55:07 - [info] Loading palette nodes
                  ! node-red.0 2018-02-16 09:55:06.249 debug 16 Feb 09:55:06 - [info] Linux 4.9.35-v7+ arm LE
                  ! node-red.0 2018-02-16 09:55:06.248 debug 16 Feb 09:55:06 - [info] Node.js version: v4.8.7
                  ! node-red.0 2018-02-16 09:55:06.247 debug 16 Feb 09:55:06 - [info] Node-RED version: v0.18.3
                  ! node-red.0 2018-02-16 09:55:06.238 debug ===================
                  ! node-red.0 2018-02-16 09:55:06.238 debug Welcome to Node-RED
                  ! node-red.0 2018-02-16 09:55:06.238 debug 16 Feb 09:55:06 - [info]
                  ! node-red.0 2018-02-16 09:55:02.866 info Starting node-red: –max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
                  ! node-red.0 2018-02-16 09:54:57.861 info node-red exited with 1
                  ! node-red.0 2018-02-16 09:54:57.357 debug at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8)
                  ! node-red.0 2018-02-16 09:54:57.357 debug at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                  ! node-red.0 2018-02-16 09:54:57.357 debug at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                  ! node-red.0 2018-02-16 09:54:57.357 debug at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
                  ! node-red.0 2018-02-16 09:54:57.357 debug at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9)
                  ! node-red.0 2018-02-16 09:54:57.357 debug at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:699:17)
                  ! node-red.0 2018-02-16 09:54:57.357 debug at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4659:18)
                  ! node-red.0 2018-02-16 09:54:57.357 debug at Adapter.emit (events.js:166:7)
                  ! node-red.0 2018-02-16 09:54:57.357 debug at emitNone (events.js:67:13)
                  ! node-red.0 2018-02-16 09:54:57.357 debug at Adapter. (/opt/iobroker/node_modules/iobroker.node-red/nodes/ioBroker.js:58:24)
                  ! node-red.0 2018-02-16 09:54:57.357 debug 16 Feb 09:54:57 - TypeError: Cannot read property 'node' of undefined
                  ! node-red.0 2018-02-16 09:54:57.347 debug 16 Feb 09:54:57 - Uncaught Exception:
                  ! node-red.0 2018-02-16 09:54:57.307 warn 2018-02-16 09:54:57.306 - debug: node-red.0 statesDB connected
                  ! node-red.0 2018-02-16 09:54:57.305 debug statesDB connected
                  ! node-red.0 2018-02-16 09:54:57.239 warn 2018-02-16 09:54:57.238 - debug: node-red.0 statesDB connected
                  ! node-red.0 2018-02-16 09:54:57.237 debug statesDB connected
                  ! node-red.0 2018-02-16 09:54:56.815 warn 16 Feb 09:54:56 - [warn] Communication send error: Error: not opened
                  ! node-red.0 2018-02-16 09:54:56.573 debug 16 Feb 09:54:56 - [info] [inject:Jede 10 Sekunden] repeat = 10000
                  ! node-red.0 2018-02-16 09:54:56.572 debug Message for "HC.01.Brennerauslastung" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:54:56.567 debug Message for "HC.01.Brennerlaufzeit_Std" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:54:56.560 debug Message for "HC.01.Brenner" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:54:56.550 debug 16 Feb 09:54:56 - [info] [inject:Jede 15 Sekunden] repeat = 15000
                  ! node-red.0 2018-02-16 09:54:56.464 debug Message for "HC.01.Sensoren.1wire.Aussentemperatur" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:54:56.464 debug Message for "HC.01.Sensoren.1wire.Wassertemperatur" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:54:56.464 debug Message for "HC.01.Sensoren.1wire.Kesseltemperatur" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:54:56.464 debug Message for "HC.01.Sensoren.1wire.Fussbodenrücklauf" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:54:56.464 debug Message for "HC.01.Sensoren.1wire.Fussbodenvorlauf" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:54:56.464 debug Message for "HC.01.Sensoren.1wire.Heizungsrücklauf" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:54:56.462 debug Message for "HC.01.Sensoren.1wire.Heizungsvorlauf" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:54:56.462 debug 16 Feb 09:54:56 - [info] [inject:8708f6be.fced8] repeat = 300000
                  ! node-red.0 2018-02-16 09:54:56.459 debug Message for "HC.01.Sensoren.DHT22.Keller.Luftfeuchte" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:54:56.458 debug Message for "HC.01.Sensoren.DHT22.Keller.Temperatur" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:54:56.412 debug 16 Feb 09:54:56 - [info] [inject:Jede Minute] repeat = 60000
                  ! node-red.0 2018-02-16 09:54:56.407 debug Message for "hm-rpc.0.info.connection" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:54:56.405 debug Message for "HC.01.Status" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:54:55.448 debug Message for "HC.01.Vorrang_Wasser" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:54:55.448 debug Message for "HC.01.Relais.6" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:54:55.448 debug Message for "HC.01.Relais.7" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:54:55.446 debug Message for "HC.01.Relais.5" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:54:55.446 debug Message for "HC.01.Relais.4" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:54:55.446 debug Message for "HC.01.Relais.3" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:54:55.446 debug Message for "HC.01.Relais.2" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:54:55.446 debug Message for "HC.01.Relais.1" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:54:55.446 debug Message for "HC.01.Relais.0" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:54:55.445 debug Message for "HC.01.Vorrang_Wasser" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:54:55.444 debug Message for "HC.01.Brennerstarts" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:54:55.444 debug Message for "HC.01.Brennerstart_Zeit" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:54:55.444 debug Message for "HC.01.Brennerlaufzeit_Tag" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:54:55.444 debug Message for "HC.01.Brennerlaufzeit_Std" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:54:55.443 debug Message for "HC.01.Brennerlaufzeit" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:54:55.433 warn 2018-02-16 09:54:55.432 - error: node-red.0 no connection to states DB: Connection timeout
                  ! node-red.0 2018-02-16 09:54:54.453 error no connection to states DB: Connection timeout
                  ! node-red.0 2018-02-16 09:54:54.445 debug 16 Feb 09:54:54 - [info] Started flows
                  ! node-red.0 2018-02-16 09:54:50.868 debug 16 Feb 09:54:50 - [info] [inject:1 hour] repeat = 3600000
                  ! node-red.0 2018-02-16 09:54:49.487 debug 16 Feb 09:54:49 - [info] [inject:Reset 00:00 Uhr] crontab = 00 00 * * *
                  ! node-red.0 2018-02-16 09:54:26.660 debug 16 Feb 09:54:26 - [info] Starting flows
                  ! node-red.0 2018-02-16 09:54:25.891 debug objectDB connected
                  ! node-red.0 2018-02-16 09:54:25.902 warn 2018-02-16 09:54:25.901 - debug: node-red.0 objectDB connected
                  ! node-red.0 2018-02-16 09:54:25.835 debug 16 Feb 09:54:25 - [info] Server now running at http://127.0.0.1:1880/
                  ! node-red.0 2018-02-16 09:54:25.692 debug 16 Feb 09:54:25 - [37-rpi-piface.js] Error: "gpio load spi" command failed. Check device tree is disabled.
                  ! node-red.0 2018-02-16 09:54:25.651 debug 16 Feb 09:54:25 - [info] Flows file : /opt/iobroker/iobroker-data/node-red/flows.json
                  ! node-red.0 2018-02-16 09:54:25.643 warn 16 Feb 09:54:25 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
                  ! node-red.0 2018-02-16 09:54:25.641 debug 16 Feb 09:54:25 - [info] User directory : /opt/iobroker/iobroker-data/node-red/
                  ! node-red.0 2018-02-16 09:54:25.634 debug 16 Feb 09:54:25 - [info] Settings file : /opt/iobroker/iobroker-data/node-red/settings.js
                  ! node-red.0 2018-02-16 09:54:25.481 debug 16 Feb 09:54:25 - [info] Dashboard version 2.8.1 started at /ui
                  ! node-red.0 2018-02-16 09:54:24.825 debug 16 Feb 09:54:24 - [info] Polymer started at /polymer
                  ! node-red.0 2018-02-16 09:54:19.426 debug 16 Feb 09:54:19 - [info] Loading palette nodes
                  ! node-red.0 2018-02-16 09:54:18.179 debug 16 Feb 09:54:18 - [info] Linux 4.9.35-v7+ arm LE
                  ! node-red.0 2018-02-16 09:54:18.178 debug 16 Feb 09:54:18 - [info] Node.js version: v4.8.7
                  ! node-red.0 2018-02-16 09:54:18.177 debug 16 Feb 09:54:18 - [info] Node-RED version: v0.18.3
                  ! node-red.0 2018-02-16 09:54:18.170 debug ===================
                  ! node-red.0 2018-02-16 09:54:18.170 debug Welcome to Node-RED
                  ! node-red.0 2018-02-16 09:54:18.170 debug 16 Feb 09:54:18 - [info]
                  ! node-red.0 2018-02-16 09:54:14.832 info Starting node-red: –max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
                  ! node-red.0 2018-02-16 09:54:09.826 info node-red exited with 1
                  ! node-red.0 2018-02-16 09:54:08.896 debug at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8)
                  ! node-red.0 2018-02-16 09:54:08.896 debug at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                  ! node-red.0 2018-02-16 09:54:08.896 debug at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                  ! node-red.0 2018-02-16 09:54:08.896 debug at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
                  ! node-red.0 2018-02-16 09:54:08.896 debug at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9)
                  ! node-red.0 2018-02-16 09:54:08.896 debug at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:699:17)
                  ! node-red.0 2018-02-16 09:54:08.896 debug at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4659:18)
                  ! node-red.0 2018-02-16 09:54:08.896 debug at Adapter.emit (events.js:166:7)
                  ! node-red.0 2018-02-16 09:54:08.896 debug at emitNone (events.js:67:13)
                  ! node-red.0 2018-02-16 09:54:08.896 debug at Adapter. (/opt/iobroker/node_modules/iobroker.node-red/nodes/ioBroker.js:58:24)
                  ! node-red.0 2018-02-16 09:54:08.896 debug 16 Feb 09:54:08 - TypeError: Cannot read property 'node' of undefined
                  ! node-red.0 2018-02-16 09:54:08.883 debug 16 Feb 09:54:08 - Uncaught Exception:
                  ! node-red.0 2018-02-16 09:54:08.837 warn 2018-02-16 09:54:08.837 - debug: node-red.0 statesDB connected
                  ! node-red.0 2018-02-16 09:54:08.836 debug statesDB connected
                  ! node-red.0 2018-02-16 09:54:08.739 warn 2018-02-16 09:54:08.738 - debug: node-red.0 statesDB connected
                  ! node-red.0 2018-02-16 09:54:08.735 debug statesDB connected
                  ! node-red.0 2018-02-16 09:54:07.396 error no connection to states DB: Connection timeout
                  ! node-red.0 2018-02-16 09:54:08.556 debug 16 Feb 09:54:08 - [info] [inject:Jede 10 Sekunden] repeat = 10000
                  ! node-red.0 2018-02-16 09:54:08.554 debug Message for "HC.01.Brennerauslastung" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:54:08.551 debug Message for "HC.01.Brennerlaufzeit_Std" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:54:08.547 debug Message for "HC.01.Brenner" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:54:08.537 debug 16 Feb 09:54:08 - [info] [inject:Jede 15 Sekunden] repeat = 15000
                  ! node-red.0 2018-02-16 09:54:07.486 debug Message for "HC.01.Sensoren.1wire.Aussentemperatur" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:54:07.486 debug Message for "HC.01.Sensoren.1wire.Wassertemperatur" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:54:07.486 debug Message for "HC.01.Sensoren.1wire.Kesseltemperatur" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:54:07.486 debug Message for "HC.01.Sensoren.1wire.Fussbodenrücklauf" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:54:07.486 debug Message for "HC.01.Sensoren.1wire.Fussbodenvorlauf" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:54:07.486 debug Message for "HC.01.Sensoren.1wire.Heizungsrücklauf" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:54:07.486 debug Message for "HC.01.Sensoren.1wire.Heizungsvorlauf" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:54:07.483 debug 16 Feb 09:54:07 - [info] [inject:8708f6be.fced8] repeat = 300000
                  ! node-red.0 2018-02-16 09:54:07.473 debug Message for "HC.01.Sensoren.DHT22.Keller.Luftfeuchte" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:54:07.470 debug Message for "HC.01.Sensoren.DHT22.Keller.Temperatur" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:54:07.442 debug 16 Feb 09:54:07 - [info] [inject:Jede Minute] repeat = 60000
                  ! node-red.0 2018-02-16 09:54:07.442 debug Message for "hm-rpc.0.info.connection" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:54:07.442 debug Message for "HC.01.Status" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:54:07.420 debug Message for "HC.01.Vorrang_Wasser" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:54:07.420 debug Message for "HC.01.Relais.6" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:54:07.420 debug Message for "HC.01.Relais.7" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:54:07.420 debug Message for "HC.01.Relais.5" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:54:07.418 debug Message for "HC.01.Relais.4" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:54:07.418 debug Message for "HC.01.Relais.3" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:54:07.418 debug Message for "HC.01.Relais.2" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:54:07.418 debug Message for "HC.01.Relais.1" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:54:07.418 debug Message for "HC.01.Relais.0" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:54:07.417 debug Message for "HC.01.Vorrang_Wasser" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:54:07.416 debug Message for "HC.01.Brennerstarts" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:54:07.416 debug Message for "HC.01.Brennerstart_Zeit" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:54:07.416 debug Message for "HC.01.Brennerlaufzeit_Tag" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:54:07.416 debug Message for "HC.01.Brennerlaufzeit_Std" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:54:07.415 debug Message for "HC.01.Brennerlaufzeit" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:54:07.402 warn 2018-02-16 09:54:07.397 - error: node-red.0 no connection to states DB: Connection timeout
                  ! node-red.0 2018-02-16 09:54:07.391 debug 16 Feb 09:54:07 - [info] Started flows
                  ! node-red.0 2018-02-16 09:54:03.862 debug 16 Feb 09:54:03 - [info] [inject:1 hour] repeat = 3600000
                  ! node-red.0 2018-02-16 09:54:02.479 debug 16 Feb 09:54:02 - [info] [inject:Reset 00:00 Uhr] crontab = 00 00 * * *
                  ! node-red.0 2018-02-16 09:53:39.737 debug 16 Feb 09:53:39 - [info] Starting flows
                  ! node-red.0 2018-02-16 09:53:38.958 debug objectDB connected
                  ! node-red.0 2018-02-16 09:53:38.969 warn 2018-02-16 09:53:38.967 - debug: node-red.0 objectDB connected
                  ! node-red.0 2018-02-16 09:53:38.862 debug 16 Feb 09:53:38 - [info] Server now running at http://127.0.0.1:1880/
                  ! node-red.0 2018-02-16 09:53:38.762 debug 16 Feb 09:53:38 - [37-rpi-piface.js] Error: "gpio load spi" command failed. Check device tree is disabled.
                  ! node-red.0 2018-02-16 09:53:38.726 debug 16 Feb 09:53:38 - [info] Flows file : /opt/iobroker/iobroker-data/node-red/flows.json
                  ! node-red.0 2018-02-16 09:53:38.721 warn 16 Feb 09:53:38 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
                  ! node-red.0 2018-02-16 09:53:38.719 debug 16 Feb 09:53:38 - [info] User directory : /opt/iobroker/iobroker-data/node-red/
                  ! node-red.0 2018-02-16 09:53:38.715 debug 16 Feb 09:53:38 - [info] Settings file : /opt/iobroker/iobroker-data/node-red/settings.js
                  ! node-red.0 2018-02-16 09:53:38.566 debug 16 Feb 09:53:38 - [info] Dashboard version 2.8.1 started at /ui
                  ! node-red.0 2018-02-16 09:53:37.897 debug 16 Feb 09:53:37 - [info] Polymer started at /polymer
                  ! node-red.0 2018-02-16 09:53:32.365 debug 16 Feb 09:53:32 - [info] Loading palette nodes
                  ! node-red.0 2018-02-16 09:53:31.158 debug 16 Feb 09:53:31 - [info] Linux 4.9.35-v7+ arm LE
                  ! node-red.0 2018-02-16 09:53:31.158 debug 16 Feb 09:53:31 - [info] Node.js version: v4.8.7
                  ! node-red.0 2018-02-16 09:53:31.155 debug 16 Feb 09:53:31 - [info] Node-RED version: v0.18.3
                  ! node-red.0 2018-02-16 09:53:31.148 debug ===================
                  ! node-red.0 2018-02-16 09:53:31.148 debug Welcome to Node-RED
                  ! node-red.0 2018-02-16 09:53:31.148 debug 16 Feb 09:53:31 - [info]
                  ! node-red.0 2018-02-16 09:53:27.865 info Starting node-red: –max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
                  ! node-red.0 2018-02-16 09:53:22.860 info node-red exited with 1
                  ! node-red.0 2018-02-16 09:53:22.615 debug at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:332:8)
                  ! node-red.0 2018-02-16 09:53:22.615 debug at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                  ! node-red.0 2018-02-16 09:53:22.615 debug at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
                  ! node-red.0 2018-02-16 09:53:22.615 debug at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
                  ! node-red.0 2018-02-16 09:53:22.615 debug at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:312:9)
                  ! node-red.0 2018-02-16 09:53:22.615 debug at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:699:17)
                  ! node-red.0 2018-02-16 09:53:22.615 debug at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4659:18)
                  ! node-red.0 2018-02-16 09:53:22.615 debug at Adapter.emit (events.js:166:7)
                  ! node-red.0 2018-02-16 09:53:22.615 debug at emitNone (events.js:67:13)
                  ! node-red.0 2018-02-16 09:53:22.615 debug at Adapter. (/opt/iobroker/node_modules/iobroker.node-red/nodes/ioBroker.js:58:24)
                  ! node-red.0 2018-02-16 09:53:22.615 debug 16 Feb 09:53:22 - TypeError: Cannot read property 'node' of undefined
                  ! node-red.0 2018-02-16 09:53:22.604 debug 16 Feb 09:53:22 - Uncaught Exception:
                  ! node-red.0 2018-02-16 09:53:22.522 warn 2018-02-16 09:53:22.521 - debug: node-red.0 statesDB connected
                  ! node-red.0 2018-02-16 09:53:22.520 debug statesDB connected
                  ! node-red.0 2018-02-16 09:53:22.392 debug 16 Feb 09:53:22 - [info] [inject:Jede 10 Sekunden] repeat = 10000
                  ! node-red.0 2018-02-16 09:53:22.392 debug Message for "HC.01.Brennerauslastung" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:53:22.381 debug Message for "HC.01.Brennerlaufzeit_Std" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:53:22.375 debug Message for "HC.01.Brenner" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:53:22.364 debug 16 Feb 09:53:22 - [info] [inject:Jede 15 Sekunden] repeat = 15000
                  ! node-red.0 2018-02-16 09:53:22.287 debug Message for "HC.01.Sensoren.1wire.Aussentemperatur" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:53:22.287 debug Message for "HC.01.Sensoren.1wire.Wassertemperatur" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:53:22.287 debug Message for "HC.01.Sensoren.1wire.Kesseltemperatur" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:53:22.287 debug Message for "HC.01.Sensoren.1wire.Fussbodenrücklauf" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:53:22.287 debug Message for "HC.01.Sensoren.1wire.Fussbodenvorlauf" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:53:22.287 debug Message for "HC.01.Sensoren.1wire.Heizungsrücklauf" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:53:22.287 debug Message for "HC.01.Sensoren.1wire.Heizungsvorlauf" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:53:22.287 debug 16 Feb 09:53:22 - [info] [inject:8708f6be.fced8] repeat = 300000
                  ! node-red.0 2018-02-16 09:53:22.275 debug Message for "HC.01.Sensoren.DHT22.Keller.Luftfeuchte" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:53:22.274 debug Message for "HC.01.Sensoren.DHT22.Keller.Temperatur" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:53:22.239 debug 16 Feb 09:53:22 - [info] [inject:Jede Minute] repeat = 60000
                  ! node-red.0 2018-02-16 09:53:22.239 debug Message for "hm-rpc.0.info.connection" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:53:22.239 debug Message for "HC.01.Status" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:53:22.215 debug Message for "HC.01.Vorrang_Wasser" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:53:22.215 debug Message for "HC.01.Relais.6" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:53:22.215 debug Message for "HC.01.Relais.7" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:53:22.215 debug Message for "HC.01.Relais.5" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:53:22.215 debug Message for "HC.01.Relais.4" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:53:22.215 debug Message for "HC.01.Relais.3" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:53:22.215 debug Message for "HC.01.Relais.2" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:53:22.215 debug Message for "HC.01.Relais.1" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:53:22.215 debug Message for "HC.01.Relais.0" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:53:22.215 debug Message for "HC.01.Brennerstarts" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:53:22.215 debug Message for "HC.01.Brennerstart_Zeit" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:53:22.215 debug Message for "HC.01.Brennerlaufzeit_Tag" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:53:22.215 debug Message for "HC.01.Brennerlaufzeit_Std" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:53:22.209 debug Message for "HC.01.Brennerlaufzeit" queued because ioBroker connection not initialized
                  ! node-red.0 2018-02-16 09:53:22.200 warn 2018-02-16 09:53:22.198 - error: node-red.0 no connection to states DB: Connection timeout
                  ! node-red.0 2018-02-16 09:53:22.190 error no connection to states DB: Connection timeout
                  ! node-red.0 2018-02-16 09:53:20.200 debug 16 Feb 09:53:20 - [info] Started flows
                  ! node-red.0 2018-02-16 09:53:16.709 debug 16 Feb 09:53:16 - [info] [inject:1 hour] repeat = 3600000
                  ! node-red.0 2018-02-16 09:53:15.363 debug 16 Feb 09:53:15 - [info] [inject:Reset 00:00 Uhr] crontab = 00 00 * * *
                  ! node-red.0 2018-02-16 09:52:52.799 debug 16 Feb 09:52:52 - [info] Starting flows
                  ! node-red.0 2018-02-16 09:52:52.036 debug objectDB connected
                  ! node-red.0 2018-02-16 09:52:52.050 warn 2018-02-16 09:52:52.046 - debug: node-red.0 objectDB connected
                  ! node-red.0 2018-02-16 09:52:51.941 debug 16 Feb 09:52:51 - [info] Server now running at http://127.0.0.1:1880/
                  ! node-red.0 2018-02-16 09:52:51.896 warn 16 Feb 09:52:51 - [info] Flows file : /opt/iobroker/iobroker-data/node-red/flows.json
                  ! node-red.0 2018-02-16 09:52:51.896 warn 16 Feb 09:52:51 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
                  ! node-red.0 2018-02-16 09:52:51.893 debug 16 Feb 09:52:51 - [info] User directory : /opt/iobroker/iobroker-data/node-red/
                  ! node-red.0 2018-02-16 09:52:51.886 debug 16 Feb 09:52:51 - [info] Settings file : /opt/iobroker/iobroker-data/node-red/settings.js
                  ! node-red.0 2018-02-16 09:52:51.790 debug 16 Feb 09:52:51 - [37-rpi-piface.js] Error: "gpio load spi" command failed. Check device tree is disabled.
                  ! node-red.0 2018-02-16 09:52:51.557 debug 16 Feb 09:52:51 - [info] Dashboard version 2.8.1 started at /ui
                  ! node-red.0 2018-02-16 09:52:50.746 debug 16 Feb 09:52:50 - [info] Polymer started at /polymer
                  ! node-red.0 2018-02-16 09:52:44.632 debug 16 Feb 09:52:44 - [info] Loading palette nodes
                  ! node-red.0 2018-02-16 09:52:43.378 debug 16 Feb 09:52:43 - [info] Linux 4.9.35-v7+ arm LE
                  ! node-red.0 2018-02-16 09:52:43.377 debug 16 Feb 09:52:43 - [info] Node.js version: v4.8.7
                  ! node-red.0 2018-02-16 09:52:43.375 debug 16 Feb 09:52:43 - [info] Node-RED version: v0.18.3
                  ! node-red.0 2018-02-16 09:52:43.369 debug ===================
                  ! node-red.0 2018-02-16 09:52:43.369 debug Welcome to Node-RED
                  ! node-red.0 2018-02-16 09:52:43.369 debug 16 Feb 09:52:43 - [info]
                  ! node-red.0 2018-02-16 09:52:39.823 info Starting node-red: –max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
                  ! node-red.0 2018-02-16 09:52:39.184 info starting. Version 1.5.1 in /opt/iobroker/node_modules/iobroker.node-red, node: v4.8.7
                  ! node-red.0 2018-02-16 09:52:39.118 debug statesDB connected
                  ! node-red.0 2018-02-16 09:52:39.006 debug objectDB connected
                  ! host.rasp1 2018-02-16 09:52:37.398 info instance system.adapter.node-red.0 started with pid 18869
                    Srry, Fehler eingeschlichen.
                    Bitte nochmal installieren. Jetzt ?! :-))
                      tp1de last edited by
                      Startet jetzt. So sieht der Startlog aus:
                      ! node-red.0 2018-02-16 11:06:51.192 debug 16 Feb 11:06:51 - [info] [inject:Jede Minute] repeat = 60000
                      ! node-red.0 2018-02-16 11:06:23.395 debug 16 Feb 11:06:23 - [info] [inject:Jede 15 Sekunden] repeat = 15000
                      ! node-red.0 2018-02-16 11:06:19.887 debug 16 Feb 11:06:19 - [info] [inject:Jede 15 Sekunden] repeat = 15000
                      ! node-red.0 2018-02-16 11:06:10.718 debug 16 Feb 11:06:10 - [info] [inject:Jede 15 Sekunden] repeat = 15000
                      ! node-red.0 2018-02-16 11:06:07.141 debug 29 queued state values set in ioBroker
                      ! node-red.0 2018-02-16 11:06:06.997 warn 2018-02-16 11:06:06.990 - [34mdebug[39m: node-red.0 statesDB connected
                      ! node-red.0 2018-02-16 11:06:06.913 warn 16 Feb 11:06:06 - [warn] Communication send error: Error: not opened
                      ! node-red.0 2018-02-16 11:06:06.634 debug Message for "HC.01.Relais.6" queued because ioBroker connection not initialized Message for "HC.01.Sensoren.1wire.Fussbodenvorlauf" queued because ioBroker connection not initialized Message for "HC.0
                      ! node-red.0 2018-02-16 11:06:06.634 debug Message for "HC.01.Sensoren.1wire.Heizungsrücklauf" queued because ioBroker connection not initialized Message for "HC.01.Vorrang_Wasser" queued because ioBroker connection not initialized
                      ! node-red.0 2018-02-16 11:06:06.633 debug Message for "HC.01.Relais.7" queued because ioBroker connection not initialized
                      ! node-red.0 2018-02-16 11:06:06.567 warn 2018-02-16 11:06:06.565 - [34mdebug[39m: node-red.0 objectDB connected
                      ! node-red.0 2018-02-16 11:06:05.550 debug Message for "HC.01.Relais.0" queued because ioBroker connection not initialized Message for "HC.01.Relais.1" queued because ioBroker connection not initialized Message for "HC.01.Relais.2" queued beca
                      ! node-red.0 2018-02-16 11:06:05.545 debug Message for "HC.01.Vorrang_Wasser" queued because ioBroker connection not initialized
                      ! node-red.0 2018-02-16 11:06:05.521 debug 16 Feb 11:06:05 - [info] [inject:Jede 15 Sekunden] repeat = 15000
                      ! node-red.0 2018-02-16 11:06:05.427 debug 16 Feb 11:06:05 - [info] [inject:8708f6be.fced8] repeat = 300000
                      ! node-red.0 2018-02-16 11:06:05.423 debug Message for "HC.01.Sensoren.DHT22.Keller.Luftfeuchte" queued because ioBroker connection not initialized
                      ! node-red.0 2018-02-16 11:06:05.422 debug Message for "HC.01.Sensoren.DHT22.Keller.Temperatur" queued because ioBroker connection not initialized
                      ! node-red.0 2018-02-16 11:06:04.897 debug Message for "HC.01.Brennerauslastung" queued because ioBroker connection not initialized 16 Feb 11:06:04 - [info] [inject:Jede 10 Sekunden] repeat = 10000
                      ! node-red.0 2018-02-16 11:06:04.893 debug Message for "HC.01.Brennerlaufzeit_Std" queued because ioBroker connection not initialized
                      ! node-red.0 2018-02-16 11:06:04.890 debug Message for "HC.01.Brenner" queued because ioBroker connection not initialized
                      ! node-red.0 2018-02-16 11:06:04.875 debug Message for "hm-rpc.0.info.connection" queued because ioBroker connection not initialized 16 Feb 11:06:04 - [info] [inject:Jede Minute] repeat = 60000
                      ! node-red.0 2018-02-16 11:06:04.869 debug Message for "HC.01.Status" queued because ioBroker connection not initialized
                      ! node-red.0 2018-02-16 11:06:04.866 debug Message for "HC.01.Brennerlaufzeit_Std" queued because ioBroker connection not initialized Message for "HC.01.Brennerlaufzeit_Tag" queued because ioBroker connection not initialized Message for "HC.01
                      ! node-red.0 2018-02-16 11:06:04.865 debug Message for "HC.01.Brennerlaufzeit" queued because ioBroker connection not initialized
                      ! node-red.0 2018-02-16 11:06:04.842 warn 2018-02-16 11:06:04.839 - [31merror[39m: node-red.0 no connection to objects DB
                      ! node-red.0 2018-02-16 11:06:04.818 debug 16 Feb 11:06:04 - [info] Started flows
                      ! node-red.0 2018-02-16 11:06:01.162 debug 16 Feb 11:06:01 - [info] [inject:1 hour] repeat = 3600000
                      ! node-red.0 2018-02-16 11:05:59.788 debug 16 Feb 11:05:59 - [info] [inject:Reset 00:00 Uhr] crontab = 00 00 * * *
                      ! node-red.0 2018-02-16 11:05:36.621 debug 16 Feb 11:05:36 - [info] Starting flows
                      ! node-red.0 2018-02-16 11:05:35.736 debug 16 Feb 11:05:35 - [info] Server now running at http://127.0.0.1:1880/
                      ! node-red.0 2018-02-16 11:05:35.704 debug 16 Feb 11:05:35 - [37-rpi-piface.js] Error: "gpio load spi" command failed. Check device tree is disabled.
                      ! node-red.0 2018-02-16 11:05:35.670 debug 16 Feb 11:05:35 - [info] Flows file : /opt/iobroker/iobroker-data/node-red/flows.json
                      ! node-red.0 2018-02-16 11:05:35.664 warn 16 Feb 11:05:35 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
                      ! node-red.0 2018-02-16 11:05:35.661 debug 16 Feb 11:05:35 - [info] User directory : /opt/iobroker/iobroker-data/node-red/
                      ! node-red.0 2018-02-16 11:05:35.655 debug 16 Feb 11:05:35 - [info] Settings file : /opt/iobroker/iobroker-data/node-red/settings.js
                      ! node-red.0 2018-02-16 11:05:35.502 debug 16 Feb 11:05:35 - [info] Dashboard version 2.8.1 started at /ui
                      ! node-red.0 2018-02-16 11:05:34.845 debug 16 Feb 11:05:34 - [info] Polymer started at /polymer
                      ! node-red.0 2018-02-16 11:05:29.375 debug 16 Feb 11:05:29 - [info] Loading palette nodes
                      ! node-red.0 2018-02-16 11:05:28.134 debug 16 Feb 11:05:28 - [info] Linux 4.9.35-v7+ arm LE
                      ! node-red.0 2018-02-16 11:05:28.134 debug 16 Feb 11:05:28 - [info] Node.js version: v4.8.7
                      ! node-red.0 2018-02-16 11:05:28.131 debug 16 Feb 11:05:28 - [info] Node-RED version: v0.18.3
                      ! node-red.0 2018-02-16 11:05:28.112 debug 16 Feb 11:05:28 - [info] Welcome to Node-RED ===================
                      ! node-red.0 2018-02-16 11:05:24.700 info Starting node-red: –max-old-space-size=128 /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/iobroker-data/node-red/settings.js
                      ! node-red.0 2018-02-16 11:05:24.182 info starting. Version 1.5.1 in /opt/iobroker/node_modules/iobroker.node-red, node: v4.8.7
                      ! node-red.0 2018-02-16 11:05:24.125 debug statesDB connected
                      ! node-red.0 2018-02-16 11:05:24.027 debug objectDB connected
                      ! host.rasp1 2018-02-16 11:05:22.306 info instance system.adapter.node-red.0 started with pid 21238
                        Sieht gut aus, oder ?!
                        Die eine Zeile:
                        kommt von irgendwelcher anderen Kommunikation, oder ?!
                          Werde jetzt mal laufen lassen und Dir dann ein weiteres Feedback geben. Habe jetzt den Start der Flows um mindestens 10 Sekunden verzögert, das geht ja in der aktuellen Node-Red Version.
                          Habe noch keine Ahnung woher der communication error kommt. Mir ist nur aufgefallen, dass ich nach Neustart von node-red nicht auf die Web-Oberfläche (Port 1880) komme. Musste nochmal starten, dann ging es …..
                            Dann baue ich heute Abend das zusätzliche Logging mal aus und release die 1.5.1. Klappt ja 🙂
                              Ingo,
                              ich habe jetzt noch einmal intensiv getestet. Das Puffern scheint zu funktionieren es spricht aus meiner Sicht nichts dagegen, diese Version produktiv zu setzten. Ich würde aber die Debug-Messages erst einmal drin lassen um zu sehen, wie häufig das Zwischenpuffern notwendig ist. Bleibt noch die Frage warum?
                              Auffällig ist, das beim Start von node-red die States DB connected wird, ca. 4 Sekunden später startet der erste Flow und 5 mSek später kommt der Connection Timeout zur States DB.
                              Dann dauert es ca. 2.5 Sekunden bis diese wieder verbunden ist. Dazwischen werden die die Messages gepuffert und nach Reconnect ca. 200 mSek später geschrieben. Beim letzten Start waren das 24 Werte !
                              Irgendwas muss doch die States DB Abbrüche verursachen …
                              Aber erst einmal vielen Dank und Grüße
                              Thomas
                                @tom57:
                                Ich würde aber die Debug-Messages erst einmal drin lassen um zu sehen, wie häufig das Zwischenpuffern notwendig ist. Bleibt noch die Frage warum? `
                                Eigentlich unnötig weil es nur beim Starten puffert. Man bekommt aktuell potentielle "reconnectes" der State-DB nicht mit. Müsste man mal schauen was dann passiert.
                                @tom57:
                                Irgendwas muss doch die States DB Abbrüche verursachen … `
                                In deinem letzten Log gab es aber keine reconnects … oder spielst Du daraf an das er doppet verbindet? DAS ist Absicht in dem node-red Fall.
                                Zuerst startet der Adapter selbst, er connected die State-DB, dann startet er node-red.
                                Node-red initialisiert dann die ganzen Nodes unter anderem die "ioBroker-Nodes". Diese bauen eine (gemeinsame) eigene Verbindung zur States-DB auf.
                                Das sieht man in deinem Log an sich schön. Da ist auch keinerlei Reconnect oder sonst was drin.
                                3134
