    4. [Aufruf] Dringender Test sql 1.6.4
    • frankjoke
      frankjoke last edited by
      Ok,
      hab 1.6.1 wieder runter und dann 1.6.9 installiert. Dort kommt Fehler nicht.
      Aber bei 1.7.0 kommt er wieder.
      Log:
      ! 2018-02-11 19:34:58.504 - [31merror[39m: host.cslstretch instance system.adapter.sql.0 terminated with code 0 (OK) 2018-02-11 19:34:58.504 - [32minfo[39m: host.cslstretch Restart adapter system.adapter.sql.0 because enabled 2018-02-11 19:35:01.689 - [32minfo[39m: host.cslstretch instance system.adapter.sql.0 started with pid 10869 2018-02-11 19:35:03.414 - [34mdebug[39m: sql.0 objectDB connected 2018-02-11 19:35:03.468 - [34mdebug[39m: sql.0 statesDB connected 2018-02-11 19:35:03.537 - [32minfo[39m: sql.0 starting. Version 1.7.0 in /opt/iobroker/node_modules/iobroker.sql, node: v6.12.3 2018-02-11 19:35:03.603 - [32minfo[39m: sql.0 enabled logging of hm-rpc.0.NEQ0532409.1.TEMPERATURE 2018-02-11 19:35:03.603 - [32minfo[39m: sql.0 enabled logging of hm-rpc.0.NEQ0532409.2.TEMPERATURE 2018-02-11 19:35:03.604 - [32minfo[39m: sql.0 enabled logging of hm-rpc.0.NEQ0532409.3.TEMPERATURE 2018-02-11 19:35:03.604 - [32minfo[39m: sql.0 enabled logging of xs1.0.Sensors.Pool 2018-02-11 19:35:03.604 - [32minfo[39m: sql.0 enabled logging of xs1.0.Sensors.TempTER 2018-02-11 19:35:03.605 - [32minfo[39m: sql.0 enabled logging of xs1.0.Sensors.TempSTR 2018-02-11 19:35:03.605 - [32minfo[39m: sql.0 enabled logging of xs1.0.Sensors.TempWZ 2018-02-11 19:35:03.605 - [32minfo[39m: sql.0 enabled logging of xs1.0.Sensors.TempSZ 2018-02-11 19:35:03.606 - [32minfo[39m: sql.0 enabled logging of xs1.0.Sensors.TempAZS 2018-02-11 19:35:03.606 - [32minfo[39m: sql.0 enabled logging of xs1.0.Sensors.HeissWasser 2018-02-11 19:35:03.607 - [32minfo[39m: sql.0 enabled logging of xs1.0.Sensors.LuftfeuchteWZ 2018-02-11 19:35:03.608 - [32minfo[39m: sql.0 enabled logging of xs1.0.Sensors.LuftfeuchteSZ 2018-02-11 19:35:03.609 - [32minfo[39m: sql.0 enabled logging of xs1.0.Sensors.LuftfeuchteAZS 2018-02-11 19:35:03.609 - [32minfo[39m: sql.0 enabled logging of xs1.0.Sensors.LuftfeuchteTER 2018-02-11 19:35:03.609 - [32minfo[39m: sql.0 enabled logging of xs1.0.Sensors.LuftfeuchteSTR 2018-02-11 19:35:03.610 - [32minfo[39m: sql.0 enabled logging of km200.0.heatingCircuits.hc1.roomtemperature 2018-02-11 19:35:03.611 - [32minfo[39m: sql.0 enabled logging of km200.0.heatingCircuits.hc2.actualSupplyTemperature 2018-02-11 19:35:03.611 - [32minfo[39m: sql.0 enabled logging of km200.0.heatingCircuits.hc2.pumpModulation 2018-02-11 19:35:03.611 - [32minfo[39m: sql.0 enabled logging of km200.0.heatingCircuits.hc2.roomtemperature 2018-02-11 19:35:03.612 - [32minfo[39m: sql.0 enabled logging of km200.0.system.heatSources.hs1.actualModulation 2018-02-11 19:35:03.612 - [32minfo[39m: sql.0 enabled logging of km200.0.system.heatSources.hs1.actualPower 2018-02-11 19:35:03.613 - [32minfo[39m: sql.0 enabled logging of km200.0.system.sensors.temperatures.hotWater_t2 2018-02-11 19:35:03.613 - [32minfo[39m: sql.0 enabled logging of km200.0.system.sensors.temperatures.outdoor_t1 2018-02-11 19:35:03.613 - [32minfo[39m: sql.0 enabled logging of km200.0.system.sensors.temperatures.supply_t1 2018-02-11 19:35:03.613 - [32minfo[39m: sql.0 enabled logging of radar.0.ECB-Kurse.USD 2018-02-11 19:35:03.614 - [32minfo[39m: sql.0 enabled logging of radar.0.ECB-Kurse.GBP 2018-02-11 19:35:03.614 - [32minfo[39m: sql.0 enabled logging of javascript.0.StateMachine.sunpos 2018-02-11 19:35:03.614 - [32minfo[39m: sql.0 enabled logging of javascript.0.StateMachine.helligkeit 2018-02-11 19:35:03.614 - [32minfo[39m: sql.0 enabled logging of javascript.0.StateMachine.Astro 2018-02-11 19:35:03.614 - [32minfo[39m: sql.0 enabled logging of hm-rpc.0.NEQ1100493.1.HUMIDITY 2018-02-11 19:35:03.615 - [32minfo[39m: sql.0 enabled logging of hm-rpc.0.NEQ1100493.1.RAINING 2018-02-11 19:35:03.615 - [32minfo[39m: sql.0 enabled logging of hm-rpc.0.NEQ1100493.1.RAIN_COUNTER 2018-02-11 19:35:03.615 - [32minfo[39m: sql.0 enabled logging of hm-rpc.0.NEQ1100493.1.SUNSHINEDURATION 2018-02-11 19:35:03.615 - [32minfo[39m: sql.0 enabled logging of hm-rpc.0.NEQ1100493.1.TEMPERATURE 2018-02-11 19:35:03.615 - [32minfo[39m: sql.0 enabled logging of hm-rpc.0.NEQ1100493.1.WIND_DIRECTION 2018-02-11 19:35:03.616 - [32minfo[39m: sql.0 enabled logging of hm-rpc.0.NEQ1100493.1.WIND_DIRECTION_RANGE 2018-02-11 19:35:03.616 - [32minfo[39m: sql.0 enabled logging of hm-rpc.0.NEQ1100493.1.WIND_SPEED 2018-02-11 19:35:03.616 - [32minfo[39m: sql.0 enabled logging of hm-rega.0.5321 2018-02-11 19:35:03.616 - [32minfo[39m: sql.0 enabled logging of km200.0.heatSources.hs1.actualPower 2018-02-11 19:35:03.616 - [32minfo[39m: sql.0 enabled logging of systeminfo.0.System.Mem_free 2018-02-11 19:35:03.616 - [32minfo[39m: sql.0 enabled logging of systeminfo.0.System.Load.Load 2018-02-11 19:35:03.617 - [32minfo[39m: sql.0 enabled logging of systeminfo.0.Currency.BTC-EUR 2018-02-11 19:35:03.617 - [32minfo[39m: sql.0 enabled logging of systeminfo.0.Currency.USD 2018-02-11 19:35:03.617 - [32minfo[39m: sql.0 enabled logging of systeminfo.0.Currency.GBP 2018-02-11 19:35:03.617 - [32minfo[39m: sql.0 enabled logging of systeminfo.0.System.CPU_Temperatur 2018-02-11 19:35:03.769 - [34mdebug[39m: sql.0 CREATE TABLE sources (id SERIAL NOT NULL PRIMARY KEY, name TEXT); 2018-02-11 19:35:03.776 - [34mdebug[39m: sql.0 Response: {"name":"error","length":101,"severity":"ERROR","code":"42P07","file":"heap.c","line":"1067","routine":"heap_create_with_catalog"} 2018-02-11 19:35:03.777 - [34mdebug[39m: sql.0 OK. Table "sources" yet exists 2018-02-11 19:35:03.789 - [34mdebug[39m: sql.0 CREATE TABLE datapoints (id SERIAL NOT NULL PRIMARY KEY, name TEXT, type INTEGER); 2018-02-11 19:35:03.794 - [34mdebug[39m: sql.0 Response: {"name":"error","length":104,"severity":"ERROR","code":"42P07","file":"heap.c","line":"1067","routine":"heap_create_with_catalog"} 2018-02-11 19:35:03.794 - [34mdebug[39m: sql.0 OK. Table "datapoints" yet exists 2018-02-11 19:35:03.806 - [34mdebug[39m: sql.0 CREATE TABLE ts_number (id INTEGER NOT NULL, ts BIGINT, val REAL, ack BOOLEAN, _from INTEGER, q INTEGER, PRIMARY KEY(id, ts)); 2018-02-11 19:35:03.809 - [34mdebug[39m: sql.0 Response: {"name":"error","length":103,"severity":"ERROR","code":"42P07","file":"heap.c","line":"1067","routine":"heap_create_with_catalog"} 2018-02-11 19:35:03.809 - [34mdebug[39m: sql.0 OK. Table "ts_number" yet exists 2018-02-11 19:35:03.824 - [34mdebug[39m: sql.0 CREATE TABLE ts_string (id INTEGER NOT NULL, ts BIGINT, val TEXT, ack BOOLEAN, _from INTEGER, q INTEGER, PRIMARY KEY(id, ts)); 2018-02-11 19:35:03.827 - [34mdebug[39m: sql.0 Response: {"name":"error","length":103,"severity":"ERROR","code":"42P07","file":"heap.c","line":"1067","routine":"heap_create_with_catalog"} 2018-02-11 19:35:03.827 - [34mdebug[39m: sql.0 OK. Table "ts_string" yet exists 2018-02-11 19:35:03.839 - [34mdebug[39m: sql.0 CREATE TABLE ts_bool (id INTEGER NOT NULL, ts BIGINT, val BOOLEAN, ack BOOLEAN, _from INTEGER, q INTEGER, PRIMARY KEY(id, ts)); 2018-02-11 19:35:03.843 - [34mdebug[39m: sql.0 Response: {"name":"error","length":101,"severity":"ERROR","code":"42P07","file":"heap.c","line":"1067","routine":"heap_create_with_catalog"} 2018-02-11 19:35:03.844 - [34mdebug[39m: sql.0 OK. Table "ts_bool" yet exists 2018-02-11 19:35:03.845 - [32minfo[39m: sql.0 Connected to postgresql 2018-02-11 19:35:03.847 - [34mdebug[39m: sql.0 SELECT id, type, name FROM datapoints; 2018-02-11 19:35:06.187 - [34mdebug[39m: sql.0 new value received for km200.0.heatingCircuits.hc2.actualSupplyTemperature, new-value=27, ts=1518374106182, relog=false 2018-02-11 19:35:12.958 - [34mdebug[39m: sql.0 new value received for km200.0.system.heatSources.hs1.actualModulation, new-value=25, ts=1518374112952, relog=false 2018-02-11 19:35:13.122 - [34mdebug[39m: sql.0 new value received for km200.0.system.heatSources.hs1.actualPower, new-value=5, ts=1518374113101, relog=false 2018-02-11 19:35:13.963 - [34mdebug[39m: sql.0 Datatype km200.0.system.heatSources.hs1.actualModulation: Currently: number, StorageType: false 2018-02-11 19:35:13.970 - [34mdebug[39m: sql.0 Type set in Def for km200.0.system.heatSources.hs1.actualModulation: false 2018-02-11 19:35:13.971 - [34mdebug[39m: sql.0 Type (from DB-Type) for km200.0.system.heatSources.hs1.actualModulation: 0 2018-02-11 19:35:13.972 - [34mdebug[39m: sql.0 SELECT id FROM sources WHERE name='system.adapter.km200.0'; 2018-02-11 19:35:13.994 - [34mdebug[39m: sql.0 INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(57, 1518374112952, 25, true, 8, 0); 2018-02-11 19:35:23.123 - [34mdebug[39m: sql.0 Datatype km200.0.system.heatSources.hs1.actualPower: Currently: number, StorageType: false 2018-02-11 19:35:23.125 - [34mdebug[39m: sql.0 Type set in Def for km200.0.system.heatSources.hs1.actualPower: false 2018-02-11 19:35:23.125 - [34mdebug[39m: sql.0 Type (from DB-Type) for km200.0.system.heatSources.hs1.actualPower: 0 2018-02-11 19:35:23.128 - [34mdebug[39m: sql.0 INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(69, 1518374113101, 5, true, 8, 0); 2018-02-11 19:35:27.541 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.TempSTR, new-value=2.1, ts=1518374127000, relog=false 2018-02-11 19:35:27.552 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.LuftfeuchteSTR, new-value=57, ts=1518374127000, relog=false 2018-02-11 19:35:28.281 - [34mdebug[39m: sql.0 new value received for km200.0.system.sensors.temperatures.hotWater_t2, new-value=50.6, ts=1518374128277, relog=false 2018-02-11 19:35:28.431 - [34mdebug[39m: sql.0 new value received for km200.0.system.sensors.temperatures.outdoor_t1, new-value=1.9, ts=1518374128422, relog=false 2018-02-11 19:35:28.577 - [34mdebug[39m: sql.0 new value received for km200.0.system.sensors.temperatures.supply_t1, new-value=37.4, ts=1518374128571, relog=false 2018-02-11 19:35:29.197 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.TempAZS, new-value=21.6, ts=1518374128000, relog=false 2018-02-11 19:35:29.204 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.LuftfeuchteAZS, new-value=32, ts=1518374128000, relog=false 2018-02-11 19:35:33.407 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.TempWZ, new-value=23.4, ts=1518374132000, relog=false 2018-02-11 19:35:33.410 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.LuftfeuchteWZ, new-value=25, ts=1518374132000, relog=false 2018-02-11 19:35:34.447 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.TempTER, new-value=2.2, ts=1518374133000, relog=false 2018-02-11 19:35:34.448 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.LuftfeuchteTER, new-value=54, ts=1518374133000, relog=false 2018-02-11 19:35:39.483 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.TempSZ, new-value=21.4, ts=1518374138000, relog=false 2018-02-11 19:35:39.488 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.LuftfeuchteSZ, new-value=30, ts=1518374138000, relog=false 2018-02-11 19:35:58.291 - [33mwarn[39m: sql.0 For getHistory for id systeminfo.0.System.Load.Load: Type empty. Need to write data first. Index = 82 2018-02-11 19:35:58.293 - [31merror[39m: sql.0 Please wait till next data record is logged and reload. 2018-02-11 19:35:58.296 - [34mdebug[39m: sql.0 sendTo "getHistory" to system.adapter.web.0 from system.adapter.sql.0 2018-02-11 19:35:58.299 - [34mdebug[39m: sql.0 SELECT ts, val FROM undefined WHERE undefined.id=82 AND undefined.ts < 1518374156832 AND undefined.ts >= 1518287756832 UNION ( SELECT ts, val FROM undefined WHERE undefined.id=82 AND undefined.ts < 1518287756832 ORDER BY undefined.ts DESC LIMIT 1) UNION ( SELECT ts, val FROM undefined WHERE undefined.id=82 AND undefined.ts >= 1518374156832 ORDER BY undefined.ts ASC LIMIT 1) ORDER BY ts ASC; 2018-02-11 19:35:58.300 - [34mdebug[39m: sql.0 SELECT ts, val FROM undefined WHERE undefined.id=82 AND undefined.ts < 1518374156832 AND undefined.ts >= 1518287756832 UNION ( SELECT ts, val FROM undefined WHERE undefined.id=82 AND undefined.ts < 1518287756832 ORDER BY undefined.ts DESC LIMIT 1) UNION ( SELECT ts, val FROM undefined WHERE undefined.id=82 AND undefined.ts >= 1518374156832 ORDER BY undefined.ts ASC LIMIT 1) ORDER BY ts ASC; 2018-02-11 19:35:58.304 - [33mwarn[39m: sql.0 For getHistory for id systeminfo.0.System.Mem_free: Type empty. Need to write data first. Index = 88 2018-02-11 19:35:58.304 - [31merror[39m: sql.0 Please wait till next data record is logged and reload. 2018-02-11 19:35:58.305 - [34mdebug[39m: sql.0 sendTo "getHistory" to system.adapter.web.0 from system.adapter.sql.0 2018-02-11 19:35:58.306 - [34mdebug[39m: sql.0 SELECT ts, val FROM undefined WHERE undefined.id=88 AND undefined.ts < 1518374156832 AND undefined.ts >= 1518287756832 UNION ( SELECT ts, val FROM undefined WHERE undefined.id=88 AND undefined.ts < 1518287756832 ORDER BY undefined.ts DESC LIMIT 1) UNION ( SELECT ts, val FROM undefined WHERE undefined.id=88 AND undefined.ts >= 1518374156832 ORDER BY undefined.ts ASC LIMIT 1) ORDER BY ts ASC; 2018-02-11 19:35:58.307 - [34mdebug[39m: sql.0 SELECT ts, val FROM undefined WHERE undefined.id=88 AND undefined.ts < 1518374156832 AND undefined.ts >= 1518287756832 UNION ( SELECT ts, val FROM undefined WHERE undefined.id=88 AND undefined.ts < 1518287756832 ORDER BY undefined.ts DESC LIMIT 1) UNION ( SELECT ts, val FROM undefined WHERE undefined.id=88 AND undefined.ts >= 1518374156832 ORDER BY undefined.ts ASC LIMIT 1) ORDER BY ts ASC; 2018-02-11 19:35:58.308 - [33mwarn[39m: sql.0 For getHistory for id systeminfo.0.System.CPU_Temperatur: Type empty. Need to write data first. Index = 84 2018-02-11 19:35:58.308 - [31merror[39m: sql.0 Please wait till next data record is logged and reload. 2018-02-11 19:35:58.309 - [34mdebug[39m: sql.0 sendTo "getHistory" to system.adapter.web.0 from system.adapter.sql.0 2018-02-11 19:35:58.309 - [34mdebug[39m: sql.0 SELECT ts, val FROM undefined WHERE undefined.id=84 AND undefined.ts < 1518374156832 AND undefined.ts >= 1518287756832 UNION ( SELECT ts, val FROM undefined WHERE undefined.id=84 AND undefined.ts < 1518287756832 ORDER BY undefined.ts DESC LIMIT 1) UNION ( SELECT ts, val FROM undefined WHERE undefined.id=84 AND undefined.ts >= 1518374156832 ORDER BY undefined.ts ASC LIMIT 1) ORDER BY ts ASC; 2018-02-11 19:35:58.309 - [34mdebug[39m: sql.0 SELECT ts, val FROM undefined WHERE undefined.id=84 AND undefined.ts < 1518374156832 AND undefined.ts >= 1518287756832 UNION ( SELECT ts, val FROM undefined WHERE undefined.id=84 AND undefined.ts < 1518287756832 ORDER BY undefined.ts DESC LIMIT 1) UNION ( SELECT ts, val FROM undefined WHERE undefined.id=84 AND undefined.ts >= 1518374156832 ORDER BY undefined.ts ASC LIMIT 1) ORDER BY ts ASC; 2018-02-11 19:35:58.311 - [33mwarn[39m: sql.0 For getHistory for id javascript.0.StateMachine.Astro: Type empty. Need to write data first. Index = 68 2018-02-11 19:35:58.311 - [31merror[39m: sql.0 Please wait till next data record is logged and reload. 2018-02-11 19:35:58.311 - [34mdebug[39m: sql.0 sendTo "getHistory" to system.adapter.web.0 from system.adapter.sql.0 2018-02-11 19:35:58.311 - [34mdebug[39m: sql.0 SELECT ts, val FROM undefined WHERE undefined.id=68 AND undefined.ts < 1518374156832 AND undefined.ts >= 1518287756832 UNION ( SELECT ts, val FROM undefined WHERE undefined.id=68 AND undefined.ts < 1518287756832 ORDER BY undefined.ts DESC LIMIT 1) UNION ( SELECT ts, val FROM undefined WHERE undefined.id=68 AND undefined.ts >= 1518374156832 ORDER BY undefined.ts ASC LIMIT 1) ORDER BY ts ASC; 2018-02-11 19:35:58.311 - [34mdebug[39m: sql.0 SELECT ts, val FROM undefined WHERE undefined.id=68 AND undefined.ts < 1518374156832 AND undefined.ts >= 1518287756832 UNION ( SELECT ts, val FROM undefined WHERE undefined.id=68 AND undefined.ts < 1518287756832 ORDER BY undefined.ts DESC LIMIT 1) UNION ( SELECT ts, val FROM undefined WHERE undefined.id=68 AND undefined.ts >= 1518374156832 ORDER BY undefined.ts ASC LIMIT 1) ORDER BY ts ASC; 2018-02-11 19:35:58.330 - [31merror[39m: sql.0 error: relation "undefined" does not exist 2018-02-11 19:35:58.331 - [34mdebug[39m: sql.0 sendTo "getHistory" to system.adapter.web.0 from system.adapter.sql.0 2018-02-11 19:35:58.336 - [31merror[39m: sql.0 error: relation "undefined" does not exist 2018-02-11 19:35:58.336 - [34mdebug[39m: sql.0 sendTo "getHistory" to system.adapter.web.0 from system.adapter.sql.0 2018-02-11 19:35:58.341 - [31merror[39m: sql.0 error: relation "undefined" does not exist 2018-02-11 19:35:58.342 - [34mdebug[39m: sql.0 sendTo "getHistory" to system.adapter.web.0 from system.adapter.sql.0 2018-02-11 19:35:58.343 - [31merror[39m: sql.0 error: relation "undefined" does not exist 2018-02-11 19:35:58.343 - [34mdebug[39m: sql.0 sendTo "getHistory" to system.adapter.web.0 from system.adapter.sql.0 2018-02-11 19:36:00.031 - [34mdebug[39m: sql.0 new value received for systeminfo.0.System.CPU_Temperatur, new-value=54, ts=1518374160028, relog=false 2018-02-11 19:36:01.661 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.Pool, new-value=3.5, ts=1518374161000, relog=false 2018-02-11 19:36:09.744 - [34mdebug[39m: sql.0 For getHistory for id hm-rpc.0.NEQ1100493.1.RAINING: Type empty, use dbtype 2 2018-02-11 19:36:09.745 - [34mdebug[39m: sql.0 SELECT ts, val FROM ts_bool WHERE ts_bool.id=71 AND ts_bool.ts < 1518374156832 AND ts_bool.ts >= 1518287756832 UNION ( SELECT ts, val FROM ts_bool WHERE ts_bool.id=71 AND ts_bool.ts < 1518287756832 ORDER BY ts_bool.ts DESC LIMIT 1) UNION ( SELECT ts, val FROM ts_bool WHERE ts_bool.id=71 AND ts_bool.ts >= 1518374156832 ORDER BY ts_bool.ts ASC LIMIT 1) ORDER BY ts ASC; 2018-02-11 19:36:09.751 - [34mdebug[39m: sql.0 SELECT ts, val FROM ts_bool WHERE ts_bool.id=71 AND ts_bool.ts < 1518374156832 AND ts_bool.ts >= 1518287756832 UNION ( SELECT ts, val FROM ts_bool WHERE ts_bool.id=71 AND ts_bool.ts < 1518287756832 ORDER BY ts_bool.ts DESC LIMIT 1) UNION ( SELECT ts, val FROM ts_bool WHERE ts_bool.id=71 AND ts_bool.ts >= 1518374156832 ORDER BY ts_bool.ts ASC LIMIT 1) ORDER BY ts ASC; 2018-02-11 19:36:09.789 - [34mdebug[39m: sql.0 Send: 36 of: 35 in: 46ms 2018-02-11 19:36:09.789 - [34mdebug[39m: sql.0 sendTo "getHistory" to system.adapter.web.0 from system.adapter.sql.0 2018-02-11 19:36:32.405 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.TempWZ, new-value=23.4, ts=1518374191000, relog=false 2018-02-11 19:36:32.407 - [34mdebug[39m: sql.0 value not changed xs1.0.Sensors.TempWZ, last-value=23.4, new-value=23.4, ts=1518374191000 2018-02-11 19:36:32.411 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.LuftfeuchteWZ, new-value=25, ts=1518374191000, relog=false 2018-02-11 19:36:32.413 - [34mdebug[39m: sql.0 value not changed xs1.0.Sensors.LuftfeuchteWZ, last-value=25, new-value=25, ts=1518374191000 2018-02-11 19:36:40.193 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.TempAZS, new-value=21.6, ts=1518374199000, relog=false 2018-02-11 19:36:40.195 - [34mdebug[39m: sql.0 value not changed xs1.0.Sensors.TempAZS, last-value=21.6, new-value=21.6, ts=1518374199000 2018-02-11 19:36:40.202 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.LuftfeuchteAZS, new-value=32, ts=1518374199000, relog=false 2018-02-11 19:36:40.206 - [34mdebug[39m: sql.0 value not changed xs1.0.Sensors.LuftfeuchteAZS, last-value=32, new-value=32, ts=1518374199000 2018-02-11 19:36:46.191 - [34mdebug[39m: sql.0 Datatype km200.0.heatingCircuits.hc2.actualSupplyTemperature: Currently: number, StorageType: false 2018-02-11 19:36:46.192 - [34mdebug[39m: sql.0 Type set in Def for km200.0.heatingCircuits.hc2.actualSupplyTemperature: false 2018-02-11 19:36:46.192 - [34mdebug[39m: sql.0 Type (from DB-Type) for km200.0.heatingCircuits.hc2.actualSupplyTemperature: 0 2018-02-11 19:36:46.192 - [34mdebug[39m: sql.0 INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(55, 1518374106182, 27, true, 8, 0); 2018-02-11 19:36:46.480 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.TempSZ, new-value=21.4, ts=1518374205000, relog=false 2018-02-11 19:36:46.480 - [34mdebug[39m: sql.0 value not changed xs1.0.Sensors.TempSZ, last-value=21.4, new-value=21.4, ts=1518374205000 2018-02-11 19:36:46.485 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.LuftfeuchteSZ, new-value=30, ts=1518374205000, relog=false 2018-02-11 19:36:46.486 - [34mdebug[39m: sql.0 value not changed xs1.0.Sensors.LuftfeuchteSZ, last-value=30, new-value=30, ts=1518374205000 2018-02-11 19:36:57.419 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.TempTER, new-value=2.2, ts=1518374216000, relog=false 2018-02-11 19:36:57.420 - [34mdebug[39m: sql.0 value not changed xs1.0.Sensors.TempTER, last-value=2.2, new-value=2.2, ts=1518374216000 2018-02-11 19:36:57.441 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.LuftfeuchteTER, new-value=54, ts=1518374216000, relog=false 2018-02-11 19:36:57.441 - [34mdebug[39m: sql.0 value not changed xs1.0.Sensors.LuftfeuchteTER, last-value=54, new-value=54, ts=1518374216000 2018-02-11 19:37:02.667 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.Pool, new-value=3.4, ts=1518374222000, relog=false 2018-02-11 19:37:02.669 - [34mdebug[39m: sql.0 Min-Delta reached xs1.0.Sensors.Pool, last-value=3.5, new-value=3.4, ts=1518374222000 2018-02-11 19:37:08.283 - [34mdebug[39m: sql.0 Datatype km200.0.system.sensors.temperatures.hotWater_t2: Currently: number, StorageType: false 2018-02-11 19:37:08.284 - [34mdebug[39m: sql.0 Type set in Def for km200.0.system.sensors.temperatures.hotWater_t2: false 2018-02-11 19:37:08.285 - [34mdebug[39m: sql.0 Type (from DB-Type) for km200.0.system.sensors.temperatures.hotWater_t2: 0 2018-02-11 19:37:08.286 - [34mdebug[39m: sql.0 INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(47, 1518374128277, 50.6, true, 8, 0); 2018-02-11 19:37:08.433 - [34mdebug[39m: sql.0 Datatype km200.0.system.sensors.temperatures.outdoor_t1: Currently: number, StorageType: false 2018-02-11 19:37:08.434 - [34mdebug[39m: sql.0 Type set in Def for km200.0.system.sensors.temperatures.outdoor_t1: false 2018-02-11 19:37:08.435 - [34mdebug[39m: sql.0 Type (from DB-Type) for km200.0.system.sensors.temperatures.outdoor_t1: 0 2018-02-11 19:37:08.436 - [34mdebug[39m: sql.0 INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(48, 1518374128422, 1.9, true, 8, 0); 2018-02-11 19:37:08.580 - [34mdebug[39m: sql.0 Datatype km200.0.system.sensors.temperatures.supply_t1: Currently: number, StorageType: false 2018-02-11 19:37:08.581 - [34mdebug[39m: sql.0 Type set in Def for km200.0.system.sensors.temperatures.supply_t1: false 2018-02-11 19:37:08.582 - [34mdebug[39m: sql.0 Type (from DB-Type) for km200.0.system.sensors.temperatures.supply_t1: 0 2018-02-11 19:37:08.583 - [34mdebug[39m: sql.0 INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(51, 1518374128571, 37.4, true, 8, 0); 2018-02-11 19:37:19.953 - [34mdebug[39m: sql.0 new value received for hm-rpc.0.NEQ1100493.1.TEMPERATURE, new-value=1.6, ts=1518374239950, relog=false 2018-02-11 19:37:19.956 - [34mdebug[39m: sql.0 new value received for hm-rpc.0.NEQ1100493.1.HUMIDITY, new-value=75, ts=1518374239951, relog=false 2018-02-11 19:37:19.960 - [34mdebug[39m: sql.0 new value received for hm-rpc.0.NEQ1100493.1.RAINING, new-value=false, ts=1518374239954, relog=false 2018-02-11 19:37:19.962 - [34mdebug[39m: sql.0 new value received for hm-rpc.0.NEQ1100493.1.RAIN_COUNTER, new-value=111.215, ts=1518374239955, relog=false 2018-02-11 19:37:19.962 - [34mdebug[39m: sql.0 new value received for hm-rpc.0.NEQ1100493.1.WIND_SPEED, new-value=0, ts=1518374239956, relog=false 2018-02-11 19:37:19.964 - [34mdebug[39m: sql.0 new value received for hm-rpc.0.NEQ1100493.1.WIND_DIRECTION, new-value=175, ts=1518374239958, relog=false 2018-02-11 19:37:19.965 - [34mdebug[39m: sql.0 new value received for hm-rpc.0.NEQ1100493.1.WIND_DIRECTION_RANGE, new-value=67, ts=1518374239959, relog=false 2018-02-11 19:37:19.969 - [34mdebug[39m: sql.0 new value received for hm-rpc.0.NEQ1100493.1.SUNSHINEDURATION, new-value=141, ts=1518374239963, relog=false 2018-02-11 19:37:20.963 - [34mdebug[39m: sql.0 Datatype hm-rpc.0.NEQ1100493.1.RAINING: Currently: boolean, StorageType: Boolean 2018-02-11 19:37:20.964 - [34mdebug[39m: sql.0 SELECT id FROM sources WHERE name='system.adapter.hm-rpc.0'; 2018-02-11 19:37:20.990 - [34mdebug[39m: sql.0 INSERT INTO ts_bool (id, ts, val, ack, _from, q) VALUES(71, 1518374239954, false, true, 3, 0); 2018-02-11 19:37:31.400 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.TempWZ, new-value=23.4, ts=1518374250000, relog=false 2018-02-11 19:37:31.401 - [34mdebug[39m: sql.0 value not changed xs1.0.Sensors.TempWZ, last-value=23.4, new-value=23.4, ts=1518374250000 2018-02-11 19:37:31.405 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.LuftfeuchteWZ, new-value=25, ts=1518374250000, relog=false 2018-02-11 19:37:31.405 - [34mdebug[39m: sql.0 value not changed xs1.0.Sensors.LuftfeuchteWZ, last-value=25, new-value=25, ts=1518374250000 2018-02-11 19:37:40.033 - [34mdebug[39m: sql.0 Datatype systeminfo.0.System.CPU_Temperatur: Currently: number, StorageType: false 2018-02-11 19:37:40.034 - [34mdebug[39m: sql.0 Type set in Def for systeminfo.0.System.CPU_Temperatur: false 2018-02-11 19:37:40.034 - [34mdebug[39m: sql.0 Type (from DB-Type) for systeminfo.0.System.CPU_Temperatur: 0 2018-02-11 19:37:40.035 - [34mdebug[39m: sql.0 SELECT id FROM sources WHERE name='system.adapter.systeminfo.0'; 2018-02-11 19:37:40.060 - [34mdebug[39m: sql.0 INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(84, 1518374160028, 54, true, 14, 0); 2018-02-11 19:37:40.110 - [34mdebug[39m: sql.0 DELETE FROM ts_number WHERE id=84 AND ts < 1517164620108; 2018-02-11 19:37:51.194 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.TempAZS, new-value=21.6, ts=1518374270000, relog=false 2018-02-11 19:37:51.194 - [34mdebug[39m: sql.0 value not changed xs1.0.Sensors.TempAZS, last-value=21.6, new-value=21.6, ts=1518374270000 2018-02-11 19:37:51.203 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.LuftfeuchteAZS, new-value=32, ts=1518374270000, relog=false 2018-02-11 19:37:51.203 - [34mdebug[39m: sql.0 value not changed xs1.0.Sensors.LuftfeuchteAZS, last-value=32, new-value=32, ts=1518374270000 2018-02-11 19:37:53.476 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.TempSZ, new-value=21.4, ts=1518374272000, relog=false 2018-02-11 19:37:53.476 - [34mdebug[39m: sql.0 value not changed xs1.0.Sensors.TempSZ, last-value=21.4, new-value=21.4, ts=1518374272000 2018-02-11 19:37:53.485 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.LuftfeuchteSZ, new-value=30, ts=1518374272000, relog=false 2018-02-11 19:37:53.486 - [34mdebug[39m: sql.0 value not changed xs1.0.Sensors.LuftfeuchteSZ, last-value=30, new-value=30, ts=1518374272000 2018-02-11 19:38:03.665 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.Pool, new-value=3.4, ts=1518374283000, relog=false 2018-02-11 19:38:03.665 - [34mdebug[39m: sql.0 value not changed xs1.0.Sensors.Pool, last-value=3.4, new-value=3.4, ts=1518374283000 2018-02-11 19:38:05.582 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.TempSTR, new-value=2, ts=1518374285000, relog=false 2018-02-11 19:38:05.583 - [34mdebug[39m: sql.0 Min-Delta reached xs1.0.Sensors.TempSTR, last-value=2.1, new-value=2, ts=1518374285000 2018-02-11 19:38:05.599 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.LuftfeuchteSTR, new-value=57, ts=1518374285000, relog=false 2018-02-11 19:38:05.600 - [34mdebug[39m: sql.0 value not changed xs1.0.Sensors.LuftfeuchteSTR, last-value=57, new-value=57, ts=1518374285000 2018-02-11 19:38:20.433 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.TempTER, new-value=2.2, ts=1518374299000, relog=false 2018-02-11 19:38:20.433 - [34mdebug[39m: sql.0 value not changed xs1.0.Sensors.TempTER, last-value=2.2, new-value=2.2, ts=1518374299000 2018-02-11 19:38:20.434 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.LuftfeuchteTER, new-value=55, ts=1518374299000, relog=false 2018-02-11 19:38:20.434 - [34mdebug[39m: sql.0 Min-Delta reached xs1.0.Sensors.LuftfeuchteTER, last-value=54, new-value=55, ts=1518374299000 2018-02-11 19:38:20.435 - [34mdebug[39m: sql.0 Datatype xs1.0.Sensors.LuftfeuchteTER: Currently: number, StorageType: false 2018-02-11 19:38:20.435 - [34mdebug[39m: sql.0 Type set in Def for xs1.0.Sensors.LuftfeuchteTER: false 2018-02-11 19:38:20.435 - [34mdebug[39m: sql.0 Type (from DB-Type) for xs1.0.Sensors.LuftfeuchteTER: 0 2018-02-11 19:38:20.435 - [34mdebug[39m: sql.0 SELECT id FROM sources WHERE name='system.adapter.xs1.0'; 2018-02-11 19:38:20.455 - [34mdebug[39m: sql.0 INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(36, 1518374216000, 54, true, 6, 0); 2018-02-11 19:38:30.397 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.TempWZ, new-value=23.4, ts=1518374309000, relog=false 2018-02-11 19:38:30.397 - [34mdebug[39m: sql.0 value not changed xs1.0.Sensors.TempWZ, last-value=23.4, new-value=23.4, ts=1518374309000 2018-02-11 19:38:30.406 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.LuftfeuchteWZ, new-value=25, ts=1518374309000, relog=false 2018-02-11 19:38:30.407 - [34mdebug[39m: sql.0 value not changed xs1.0.Sensors.LuftfeuchteWZ, last-value=25, new-value=25, ts=1518374309000 2018-02-11 19:38:54.449 - [34mdebug[39m: sql.0 Datatype xs1.0.Sensors.TempTER: Currently: number, StorageType: false 2018-02-11 19:38:54.450 - [34mdebug[39m: sql.0 Type set in Def for xs1.0.Sensors.TempTER: false 2018-02-11 19:38:54.451 - [34mdebug[39m: sql.0 Type (from DB-Type) for xs1.0.Sensors.TempTER: 0 2018-02-11 19:38:54.454 - [34mdebug[39m: sql.0 INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(42, 1518374133000, 2.2, true, 6, 0); 2018-02-11 19:38:59.151 - [34mdebug[39m: sql.0 new value received for javascript.0.StateMachine.sunpos, new-value=-25.5, ts=1518374339146, relog=false 2018-02-11 19:38:59.963 - [34mdebug[39m: sql.0 Datatype hm-rpc.0.NEQ1100493.1.RAIN_COUNTER: Currently: number, StorageType: false 2018-02-11 19:38:59.964 - [34mdebug[39m: sql.0 Type set in Def for hm-rpc.0.NEQ1100493.1.RAIN_COUNTER: false 2018-02-11 19:38:59.964 - [34mdebug[39m: sql.0 Type (from DB-Type) for hm-rpc.0.NEQ1100493.1.RAIN_COUNTER: 0 2018-02-11 19:38:59.965 - [34mdebug[39m: sql.0 INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(76, 1518374239955, 111.215, true, 3, 0); 2018-02-11 19:38:59.968 - [34mdebug[39m: sql.0 Datatype hm-rpc.0.NEQ1100493.1.WIND_SPEED: Currently: number, StorageType: false 2018-02-11 19:38:59.969 - [34mdebug[39m: sql.0 Type set in Def for hm-rpc.0.NEQ1100493.1.WIND_SPEED: false 2018-02-11 19:38:59.969 - [34mdebug[39m: sql.0 Type (from DB-Type) for hm-rpc.0.NEQ1100493.1.WIND_SPEED: 0 2018-02-11 19:38:59.970 - [34mdebug[39m: sql.0 INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(74, 1518374239956, 0, true, 3, 0); 2018-02-11 19:38:59.975 - [34mdebug[39m: sql.0 Datatype hm-rpc.0.NEQ1100493.1.WIND_DIRECTION: Currently: number, StorageType: false 2018-02-11 19:38:59.976 - [34mdebug[39m: sql.0 Type set in Def for hm-rpc.0.NEQ1100493.1.WIND_DIRECTION: false 2018-02-11 19:38:59.976 - [34mdebug[39m: sql.0 Type (from DB-Type) for hm-rpc.0.NEQ1100493.1.WIND_DIRECTION: 0 2018-02-11 19:38:59.976 - [34mdebug[39m: sql.0 INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(77, 1518374239958, 175, true, 3, 0); 2018-02-11 19:38:59.977 - [34mdebug[39m: sql.0 Datatype hm-rpc.0.NEQ1100493.1.WIND_DIRECTION_RANGE: Currently: number, StorageType: false 2018-02-11 19:38:59.978 - [34mdebug[39m: sql.0 Type set in Def for hm-rpc.0.NEQ1100493.1.WIND_DIRECTION_RANGE: false 2018-02-11 19:38:59.978 - [34mdebug[39m: sql.0 Type (from DB-Type) for hm-rpc.0.NEQ1100493.1.WIND_DIRECTION_RANGE: 0 2018-02-11 19:38:59.978 - [34mdebug[39m: sql.0 INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(75, 1518374239959, 67, true, 3, 0); 2018-02-11 19:38:59.979 - [34mdebug[39m: sql.0 Datatype hm-rpc.0.NEQ1100493.1.SUNSHINEDURATION: Currently: number, StorageType: false 2018-02-11 19:38:59.979 - [34mdebug[39m: sql.0 Type set in Def for hm-rpc.0.NEQ1100493.1.SUNSHINEDURATION: false 2018-02-11 19:38:59.979 - [34mdebug[39m: sql.0 Type (from DB-Type) for hm-rpc.0.NEQ1100493.1.SUNSHINEDURATION: 0 2018-02-11 19:38:59.980 - [34mdebug[39m: sql.0 INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(78, 1518374239963, 141, true, 3, 0); 2018-02-11 19:39:02.195 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.TempAZS, new-value=21.6, ts=1518374341000, relog=false 2018-02-11 19:39:02.195 - [34mdebug[39m: sql.0 value not changed xs1.0.Sensors.TempAZS, last-value=21.6, new-value=21.6, ts=1518374341000 2018-02-11 19:39:02.201 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.LuftfeuchteAZS, new-value=32, ts=1518374341000, relog=false 2018-02-11 19:39:02.202 - [34mdebug[39m: sql.0 value not changed xs1.0.Sensors.LuftfeuchteAZS, last-value=32, new-value=32, ts=1518374341000 2018-02-11 19:39:04.667 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.Pool, new-value=3.4, ts=1518374344000, relog=false 2018-02-11 19:39:04.668 - [34mdebug[39m: sql.0 value not changed xs1.0.Sensors.Pool, last-value=3.4, new-value=3.4, ts=1518374344000 2018-02-11 19:39:09.154 - [34mdebug[39m: sql.0 Datatype javascript.0.StateMachine.sunpos: Currently: number, StorageType: Number 2018-02-11 19:39:09.155 - [34mdebug[39m: sql.0 Type set in Def for javascript.0.StateMachine.sunpos: Number 2018-02-11 19:39:09.156 - [34mdebug[39m: sql.0 Type (from Def) for javascript.0.StateMachine.sunpos: 0 2018-02-11 19:39:09.157 - [34mdebug[39m: sql.0 SELECT id FROM sources WHERE name='system.adapter.javascript.0'; 2018-02-11 19:39:09.182 - [34mdebug[39m: sql.0 INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(67, 1518374339146, -25.5, false, 1, 0); 2018-02-11 19:39:09.226 - [34mdebug[39m: sql.0 DELETE FROM ts_number WHERE id=67 AND ts < 1515695940226; 2018-02-11 19:39:24.615 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.TempSTR, new-value=2, ts=1518374364000, relog=false 2018-02-11 19:39:24.616 - [34mdebug[39m: sql.0 value not changed xs1.0.Sensors.TempSTR, last-value=2, new-value=2, ts=1518374364000 2018-02-11 19:39:24.624 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.LuftfeuchteSTR, new-value=57, ts=1518374364000, relog=false 2018-02-11 19:39:24.625 - [34mdebug[39m: sql.0 value not changed xs1.0.Sensors.LuftfeuchteSTR, last-value=57, new-value=57, ts=1518374364000 2018-02-11 19:39:29.395 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.TempWZ, new-value=23.4, ts=1518374368000, relog=false 2018-02-11 19:39:29.396 - [34mdebug[39m: sql.0 value not changed xs1.0.Sensors.TempWZ, last-value=23.4, new-value=23.4, ts=1518374368000 2018-02-11 19:39:29.406 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.LuftfeuchteWZ, new-value=25, ts=1518374368000, relog=false 2018-02-11 19:39:29.406 - [34mdebug[39m: sql.0 value not changed xs1.0.Sensors.LuftfeuchteWZ, last-value=25, new-value=25, ts=1518374368000 2018-02-11 19:39:43.422 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.TempTER, new-value=2.2, ts=1518374382000, relog=false 2018-02-11 19:39:43.423 - [34mdebug[39m: sql.0 value not changed xs1.0.Sensors.TempTER, last-value=2.2, new-value=2.2, ts=1518374382000 2018-02-11 19:39:43.434 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.LuftfeuchteTER, new-value=54, ts=1518374382000, relog=false 2018-02-11 19:39:43.434 - [34mdebug[39m: sql.0 Min-Delta reached xs1.0.Sensors.LuftfeuchteTER, last-value=55, new-value=54, ts=1518374382000 2018-02-11 19:39:57.633 - [34mdebug[39m: sql.0 new value received for km200.0.heatSources.hs1.actualPower, new-value=0, ts=1518374397627, relog=false 2018-02-11 19:40:00.024 - [34mdebug[39m: sql.0 new value received for systeminfo.0.System.CPU_Temperatur, new-value=55, ts=1518374400021, relog=false 2018-02-11 19:40:00.025 - [34mdebug[39m: sql.0 Min-Delta reached systeminfo.0.System.CPU_Temperatur, last-value=54, new-value=55, ts=1518374400021 2018-02-11 19:40:05.667 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.Pool, new-value=3.4, ts=1518374405000, relog=false 2018-02-11 19:40:05.668 - [34mdebug[39m: sql.0 value not changed xs1.0.Sensors.Pool, last-value=3.4, new-value=3.4, ts=1518374405000 2018-02-11 19:40:06.162 - [34mdebug[39m: sql.0 new value received for km200.0.heatingCircuits.hc2.actualSupplyTemperature, new-value=26, ts=1518374406156, relog=false 2018-02-11 19:40:06.163 - [34mdebug[39m: sql.0 Min-Delta reached km200.0.heatingCircuits.hc2.actualSupplyTemperature, last-value=27, new-value=26, ts=1518374406156 2018-02-11 19:40:07.479 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.TempSZ, new-value=21.4, ts=1518374406000, relog=false 2018-02-11 19:40:07.482 - [34mdebug[39m: sql.0 value not changed xs1.0.Sensors.TempSZ, last-value=21.4, new-value=21.4, ts=1518374406000 2018-02-11 19:40:07.484 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.LuftfeuchteSZ, new-value=30, ts=1518374406000, relog=false 2018-02-11 19:40:07.484 - [34mdebug[39m: sql.0 value not changed xs1.0.Sensors.LuftfeuchteSZ, last-value=30, new-value=30, ts=1518374406000 2018-02-11 19:40:08.205 - [34mdebug[39m: sql.0 new value received for hm-rpc.0.NEQ1100493.1.TEMPERATURE, new-value=1.5, ts=1518374408199, relog=false 2018-02-11 19:40:08.206 - [34mdebug[39m: sql.0 Min-Delta reached hm-rpc.0.NEQ1100493.1.TEMPERATURE, last-value=1.6, new-value=1.5, ts=1518374408199 2018-02-11 19:40:08.210 - [34mdebug[39m: sql.0 new value received for hm-rpc.0.NEQ1100493.1.HUMIDITY, new-value=75, ts=1518374408205, relog=false 2018-02-11 19:40:08.211 - [34mdebug[39m: sql.0 value not changed hm-rpc.0.NEQ1100493.1.HUMIDITY, last-value=75, new-value=75, ts=1518374408205 2018-02-11 19:40:08.216 - [34mdebug[39m: sql.0 new value received for hm-rpc.0.NEQ1100493.1.RAINING, new-value=false, ts=1518374408208, relog=false 2018-02-11 19:40:08.217 - [34mdebug[39m: sql.0 value not changed hm-rpc.0.NEQ1100493.1.RAINING, last-value=false, new-value=false, ts=1518374408208 2018-02-11 19:40:08.217 - [34mdebug[39m: sql.0 new value received for hm-rpc.0.NEQ1100493.1.RAIN_COUNTER, new-value=111.215, ts=1518374408210, relog=false 2018-02-11 19:40:08.217 - [34mdebug[39m: sql.0 value not changed hm-rpc.0.NEQ1100493.1.RAIN_COUNTER, last-value=111.215, new-value=111.215, ts=1518374408210 2018-02-11 19:40:08.218 - [34mdebug[39m: sql.0 new value received for hm-rpc.0.NEQ1100493.1.WIND_SPEED, new-value=0, ts=1518374408212, relog=false 2018-02-11 19:40:08.218 - [34mdebug[39m: sql.0 value not changed hm-rpc.0.NEQ1100493.1.WIND_SPEED, last-value=0, new-value=0, ts=1518374408212 2018-02-11 19:40:08.269 - [34mdebug[39m: sql.0 new value received for hm-rpc.0.NEQ1100493.1.WIND_DIRECTION, new-value=120, ts=1518374408264, relog=false 2018-02-11 19:40:08.272 - [34mdebug[39m: sql.0 Min-Delta reached hm-rpc.0.NEQ1100493.1.WIND_DIRECTION, last-value=175, new-value=120, ts=1518374408264 2018-02-11 19:40:08.275 - [34mdebug[39m: sql.0 new value received for hm-rpc.0.NEQ1100493.1.WIND_DIRECTION_RANGE, new-value=67, ts=1518374408269, relog=false 2018-02-11 19:40:08.275 - [34mdebug[39m: sql.0 value not changed hm-rpc.0.NEQ1100493.1.WIND_DIRECTION_RANGE, last-value=67, new-value=67, ts=1518374408269 2018-02-11 19:40:08.278 - [34mdebug[39m: sql.0 new value received for hm-rpc.0.NEQ1100493.1.SUNSHINEDURATION, new-value=141, ts=1518374408271, relog=false 2018-02-11 19:40:08.280 - [34mdebug[39m: sql.0 value not changed hm-rpc.0.NEQ1100493.1.SUNSHINEDURATION, last-value=141, new-value=141, ts=1518374408271 2018-02-11 19:40:12.590 - [34mdebug[39m: sql.0 new value received for km200.0.system.heatSources.hs1.actualModulation, new-value=0, ts=1518374412586, relog=false 2018-02-11 19:40:12.591 - [34mdebug[39m: sql.0 Min-Delta reached km200.0.system.heatSources.hs1.actualModulation, last-value=25, new-value=0, ts=1518374412586 2018-02-11 19:40:12.741 - [34mdebug[39m: sql.0 new value received for km200.0.system.heatSources.hs1.actualPower, new-value=0, ts=1518374412736, relog=false 2018-02-11 19:40:12.741 - [34mdebug[39m: sql.0 Min-Delta reached km200.0.system.heatSources.hs1.actualPower, last-value=5, new-value=0, ts=1518374412736 2018-02-11 19:40:13.195 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.TempAZS, new-value=21.6, ts=1518374412000, relog=false 2018-02-11 19:40:13.196 - [34mdebug[39m: sql.0 value not changed xs1.0.Sensors.TempAZS, last-value=21.6, new-value=21.6, ts=1518374412000 2018-02-11 19:40:13.202 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.LuftfeuchteAZS, new-value=32, ts=1518374412000, relog=false 2018-02-11 19:40:13.202 - [34mdebug[39m: sql.0 value not changed xs1.0.Sensors.LuftfeuchteAZS, last-value=32, new-value=32, ts=1518374412000 2018-02-11 19:40:13.592 - [34mdebug[39m: sql.0 Datatype km200.0.system.heatSources.hs1.actualModulation: Currently: number, StorageType: Number 2018-02-11 19:40:13.595 - [34mdebug[39m: sql.0 INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(57, 1518374412586, 0, true, 8, 0); 2018-02-11 19:40:22.743 - [34mdebug[39m: sql.0 new value received for hm-rpc.0.NEQ0532409.1.TEMPERATURE, new-value=25.4, ts=1518374422737, relog=false 2018-02-11 19:40:22.744 - [34mdebug[39m: sql.0 Datatype km200.0.system.heatSources.hs1.actualPower: Currently: number, StorageType: Number 2018-02-11 19:40:22.745 - [34mdebug[39m: sql.0 INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(69, 1518374412736, 0, true, 8, 0); 2018-02-11 19:40:22.825 - [34mdebug[39m: sql.0 new value received for hm-rpc.0.NEQ0532409.2.TEMPERATURE, new-value=24.9, ts=1518374422820, relog=false 2018-02-11 19:40:22.833 - [34mdebug[39m: sql.0 new value received for hm-rpc.0.NEQ0532409.3.TEMPERATURE, new-value=0.5, ts=1518374422828, relog=false 2018-02-11 19:40:28.395 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.TempWZ, new-value=23.4, ts=1518374427000, relog=false 2018-02-11 19:40:28.395 - [34mdebug[39m: sql.0 value not changed xs1.0.Sensors.TempWZ, last-value=23.4, new-value=23.4, ts=1518374427000 2018-02-11 19:40:28.404 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.LuftfeuchteWZ, new-value=25, ts=1518374427000, relog=false 2018-02-11 19:40:28.405 - [34mdebug[39m: sql.0 value not changed xs1.0.Sensors.LuftfeuchteWZ, last-value=25, new-value=25, ts=1518374427000 2018-02-11 19:40:32.746 - [34mdebug[39m: sql.0 Datatype hm-rpc.0.NEQ0532409.1.TEMPERATURE: Currently: number, StorageType: false 2018-02-11 19:40:32.747 - [34mdebug[39m: sql.0 Type set in Def for hm-rpc.0.NEQ0532409.1.TEMPERATURE: false 2018-02-11 19:40:32.747 - [34mdebug[39m: sql.0 Type (from DB-Type) for hm-rpc.0.NEQ0532409.1.TEMPERATURE: 0 2018-02-11 19:40:32.748 - [34mdebug[39m: sql.0 INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(19, 1518374422737, 25.4, true, 3, 0); 2018-02-11 19:40:32.825 - [34mdebug[39m: sql.0 Datatype hm-rpc.0.NEQ0532409.2.TEMPERATURE: Currently: number, StorageType: false 2018-02-11 19:40:32.826 - [34mdebug[39m: sql.0 Type set in Def for hm-rpc.0.NEQ0532409.2.TEMPERATURE: false 2018-02-11 19:40:32.827 - [34mdebug[39m: sql.0 Type (from DB-Type) for hm-rpc.0.NEQ0532409.2.TEMPERATURE: 0 2018-02-11 19:40:32.827 - [34mdebug[39m: sql.0 INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(20, 1518374422820, 24.9, true, 3, 0); 2018-02-11 19:40:33.474 - [34mdebug[39m: sql.0 new value received for km200.0.system.sensors.temperatures.hotWater_t2, new-value=50.1, ts=1518374433467, relog=false 2018-02-11 19:40:33.474 - [34mdebug[39m: sql.0 Min-Delta reached km200.0.system.sensors.temperatures.hotWater_t2, last-value=50.6, new-value=50.1, ts=1518374433467 2018-02-11 19:40:33.763 - [34mdebug[39m: sql.0 new value received for km200.0.system.sensors.temperatures.supply_t1, new-value=30, ts=1518374433757, relog=false 2018-02-11 19:40:33.764 - [34mdebug[39m: sql.0 Min-Delta reached km200.0.system.sensors.temperatures.supply_t1, last-value=37.4, new-value=30, ts=1518374433757 2018-02-11 19:40:43.640 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.TempSTR, new-value=2, ts=1518374443000, relog=false 2018-02-11 19:40:43.640 - [34mdebug[39m: sql.0 value not changed xs1.0.Sensors.TempSTR, last-value=2, new-value=2, ts=1518374443000 2018-02-11 19:40:43.651 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.LuftfeuchteSTR, new-value=57, ts=1518374443000, relog=false 2018-02-11 19:40:43.651 - [34mdebug[39m: sql.0 value not changed xs1.0.Sensors.LuftfeuchteSTR, last-value=57, new-value=57, ts=1518374443000 2018-02-11 19:41:06.429 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.TempTER, new-value=2.2, ts=1518374465000, relog=false 2018-02-11 19:41:06.430 - [34mdebug[39m: sql.0 value not changed xs1.0.Sensors.TempTER, last-value=2.2, new-value=2.2, ts=1518374465000 2018-02-11 19:41:06.438 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.LuftfeuchteTER, new-value=54, ts=1518374465000, relog=false 2018-02-11 19:41:06.439 - [34mdebug[39m: sql.0 value not changed xs1.0.Sensors.LuftfeuchteTER, last-value=54, new-value=54, ts=1518374465000 2018-02-11 19:41:06.664 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.Pool, new-value=3.4, ts=1518374466000, relog=false 2018-02-11 19:41:06.664 - [34mdebug[39m: sql.0 value not changed xs1.0.Sensors.Pool, last-value=3.4, new-value=3.4, ts=1518374466000 2018-02-11 19:41:14.471 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.TempSZ, new-value=21.4, ts=1518374473000, relog=false 2018-02-11 19:41:14.472 - [34mdebug[39m: sql.0 value not changed xs1.0.Sensors.TempSZ, last-value=21.4, new-value=21.4, ts=1518374473000 2018-02-11 19:41:14.484 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.LuftfeuchteSZ, new-value=30, ts=1518374473000, relog=false 2018-02-11 19:41:14.485 - [34mdebug[39m: sql.0 value not changed xs1.0.Sensors.LuftfeuchteSZ, last-value=30, new-value=30, ts=1518374473000 2018-02-11 19:41:24.194 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.TempAZS, new-value=21.6, ts=1518374483000, relog=false 2018-02-11 19:41:24.195 - [34mdebug[39m: sql.0 value not changed xs1.0.Sensors.TempAZS, last-value=21.6, new-value=21.6, ts=1518374483000 2018-02-11 19:41:24.202 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.LuftfeuchteAZS, new-value=32, ts=1518374483000, relog=false 2018-02-11 19:41:24.203 - [34mdebug[39m: sql.0 value not changed xs1.0.Sensors.LuftfeuchteAZS, last-value=32, new-value=32, ts=1518374483000 2018-02-11 19:41:27.399 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.TempWZ, new-value=23.4, ts=1518374486000, relog=false 2018-02-11 19:41:27.400 - [34mdebug[39m: sql.0 value not changed xs1.0.Sensors.TempWZ, last-value=23.4, new-value=23.4, ts=1518374486000 2018-02-11 19:41:27.406 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.LuftfeuchteWZ, new-value=25, ts=1518374486000, relog=false 2018-02-11 19:41:27.407 - [34mdebug[39m: sql.0 value not changed xs1.0.Sensors.LuftfeuchteWZ, last-value=25, new-value=25, ts=1518374486000 2018-02-11 19:41:37.637 - [34mdebug[39m: sql.0 Datatype km200.0.heatSources.hs1.actualPower: Currently: number, StorageType: Number 2018-02-11 19:41:37.638 - [34mdebug[39m: sql.0 Type set in Def for km200.0.heatSources.hs1.actualPower: Number 2018-02-11 19:41:37.639 - [34mdebug[39m: sql.0 Type (from Def) for km200.0.heatSources.hs1.actualPower: 0 2018-02-11 19:41:37.639 - [34mdebug[39m: sql.0 INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(89, 1518374397627, 0, true, 8, 0); 2018-02-11 19:41:40.026 - [34mdebug[39m: sql.0 Datatype systeminfo.0.System.CPU_Temperatur: Currently: number, StorageType: Number 2018-02-11 19:41:40.027 - [34mdebug[39m: sql.0 INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(84, 1518374400021, 55, true, 14, 0); 2018-02-11 19:41:46.166 - [34mdebug[39m: sql.0 Datatype km200.0.heatingCircuits.hc2.actualSupplyTemperature: Currently: number, StorageType: Number 2018-02-11 19:41:46.167 - [34mdebug[39m: sql.0 INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(55, 1518374406156, 26, true, 8, 0); 2018-02-11 19:41:48.272 - [34mdebug[39m: sql.0 Datatype hm-rpc.0.NEQ1100493.1.WIND_DIRECTION: Currently: number, StorageType: Number 2018-02-11 19:41:48.273 - [34mdebug[39m: sql.0 INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(77, 1518374408264, 120, true, 3, 0); 2018-02-11 19:42:00.033 - [34mdebug[39m: sql.0 new value received for systeminfo.0.System.CPU_Temperatur, new-value=59, ts=1518374520029, relog=false 2018-02-11 19:42:00.033 - [34mdebug[39m: sql.0 Min-Delta reached systeminfo.0.System.CPU_Temperatur, last-value=55, new-value=59, ts=1518374520029 2018-02-11 19:42:07.554 - [34mdebug[39m: sql.0 Datatype xs1.0.Sensors.LuftfeuchteSTR: Currently: number, StorageType: false 2018-02-11 19:42:07.555 - [34mdebug[39m: sql.0 Type set in Def for xs1.0.Sensors.LuftfeuchteSTR: false 2018-02-11 19:42:07.556 - [34mdebug[39m: sql.0 Type (from DB-Type) for xs1.0.Sensors.LuftfeuchteSTR: 0 2018-02-11 19:42:07.557 - [34mdebug[39m: sql.0 INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(44, 1518374127000, 57, true, 6, 0); 2018-02-11 19:42:07.674 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.Pool, new-value=3.4, ts=1518374527000, relog=false 2018-02-11 19:42:07.675 - [34mdebug[39m: sql.0 value not changed xs1.0.Sensors.Pool, last-value=3.4, new-value=3.4, ts=1518374527000 2018-02-11 19:42:09.200 - [34mdebug[39m: sql.0 Datatype xs1.0.Sensors.TempAZS: Currently: number, StorageType: false 2018-02-11 19:42:09.201 - [34mdebug[39m: sql.0 Type set in Def for xs1.0.Sensors.TempAZS: false 2018-02-11 19:42:09.202 - [34mdebug[39m: sql.0 Type (from DB-Type) for xs1.0.Sensors.TempAZS: 0 2018-02-11 19:42:09.202 - [34mdebug[39m: sql.0 INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(38, 1518374128000, 21.6, true, 6, 0); 2018-02-11 19:42:09.207 - [34mdebug[39m: sql.0 Datatype xs1.0.Sensors.LuftfeuchteAZS: Currently: number, StorageType: false 2018-02-11 19:42:09.208 - [34mdebug[39m: sql.0 Type set in Def for xs1.0.Sensors.LuftfeuchteAZS: false 2018-02-11 19:42:09.209 - [34mdebug[39m: sql.0 Type (from DB-Type) for xs1.0.Sensors.LuftfeuchteAZS: 0 2018-02-11 19:42:09.209 - [34mdebug[39m: sql.0 INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(39, 1518374128000, 32, true, 6, 0); 2018-02-11 19:42:13.409 - [34mdebug[39m: sql.0 Datatype xs1.0.Sensors.TempWZ: Currently: number, StorageType: false 2018-02-11 19:42:13.410 - [34mdebug[39m: sql.0 Type set in Def for xs1.0.Sensors.TempWZ: false 2018-02-11 19:42:13.411 - [34mdebug[39m: sql.0 Type (from DB-Type) for xs1.0.Sensors.TempWZ: 0 2018-02-11 19:42:13.412 - [34mdebug[39m: sql.0 INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(41, 1518374132000, 23.4, true, 6, 0); 2018-02-11 19:42:13.415 - [34mdebug[39m: sql.0 Datatype xs1.0.Sensors.LuftfeuchteWZ: Currently: number, StorageType: false 2018-02-11 19:42:13.416 - [34mdebug[39m: sql.0 Type set in Def for xs1.0.Sensors.LuftfeuchteWZ: false 2018-02-11 19:42:13.416 - [34mdebug[39m: sql.0 Type (from DB-Type) for xs1.0.Sensors.LuftfeuchteWZ: 0 2018-02-11 19:42:13.417 - [34mdebug[39m: sql.0 INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(35, 1518374132000, 25, true, 6, 0); 2018-02-11 19:42:13.475 - [34mdebug[39m: sql.0 Datatype km200.0.system.sensors.temperatures.hotWater_t2: Currently: number, StorageType: Number 2018-02-11 19:42:13.476 - [34mdebug[39m: sql.0 INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(47, 1518374433467, 50.1, true, 8, 0); 2018-02-11 19:42:13.765 - [34mdebug[39m: sql.0 Datatype km200.0.system.sensors.temperatures.supply_t1: Currently: number, StorageType: Number 2018-02-11 19:42:13.766 - [34mdebug[39m: sql.0 INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(51, 1518374433757, 30, true, 8, 0); 2018-02-11 19:42:14.449 - [34mdebug[39m: sql.0 Datatype xs1.0.Sensors.LuftfeuchteTER: Currently: number, StorageType: Number 2018-02-11 19:42:14.450 - [34mdebug[39m: sql.0 INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(36, 1518374382000, 54, true, 6, 0); 2018-02-11 19:42:19.484 - [34mdebug[39m: sql.0 Datatype xs1.0.Sensors.TempSZ: Currently: number, StorageType: false 2018-02-11 19:42:19.485 - [34mdebug[39m: sql.0 Type set in Def for xs1.0.Sensors.TempSZ: false 2018-02-11 19:42:19.486 - [34mdebug[39m: sql.0 Type (from DB-Type) for xs1.0.Sensors.TempSZ: 0 2018-02-11 19:42:19.486 - [34mdebug[39m: sql.0 INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(40, 1518374138000, 21.4, true, 6, 0); 2018-02-11 19:42:19.490 - [34mdebug[39m: sql.0 Datatype xs1.0.Sensors.LuftfeuchteSZ: Currently: number, StorageType: false 2018-02-11 19:42:19.491 - [34mdebug[39m: sql.0 Type set in Def for xs1.0.Sensors.LuftfeuchteSZ: false 2018-02-11 19:42:19.492 - [34mdebug[39m: sql.0 Type (from DB-Type) for xs1.0.Sensors.LuftfeuchteSZ: 0 2018-02-11 19:42:19.492 - [34mdebug[39m: sql.0 INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(34, 1518374138000, 30, true, 6, 0); 2018-02-11 19:42:19.958 - [34mdebug[39m: sql.0 Datatype hm-rpc.0.NEQ1100493.1.HUMIDITY: Currently: number, StorageType: false 2018-02-11 19:42:19.959 - [34mdebug[39m: sql.0 Type set in Def for hm-rpc.0.NEQ1100493.1.HUMIDITY: false 2018-02-11 19:42:19.960 - [34mdebug[39m: sql.0 Type (from DB-Type) for hm-rpc.0.NEQ1100493.1.HUMIDITY: 0 2018-02-11 19:42:19.960 - [34mdebug[39m: sql.0 INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(72, 1518374239951, 75, true, 3, 0); 2018-02-11 19:42:21.476 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.TempSZ, new-value=21.4, ts=1518374540000, relog=false 2018-02-11 19:42:21.477 - [34mdebug[39m: sql.0 value not changed xs1.0.Sensors.TempSZ, last-value=21.4, new-value=21.4, ts=1518374540000 2018-02-11 19:42:21.485 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.LuftfeuchteSZ, new-value=30, ts=1518374540000, relog=false 2018-02-11 19:42:21.486 - [34mdebug[39m: sql.0 value not changed xs1.0.Sensors.LuftfeuchteSZ, last-value=30, new-value=30, ts=1518374540000 2018-02-11 19:42:26.403 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.TempWZ, new-value=23.4, ts=1518374545000, relog=false 2018-02-11 19:42:26.415 - [34mdebug[39m: sql.0 value not changed xs1.0.Sensors.TempWZ, last-value=23.4, new-value=23.4, ts=1518374545000 2018-02-11 19:42:26.422 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.LuftfeuchteWZ, new-value=25, ts=1518374545000, relog=false 2018-02-11 19:42:26.422 - [34mdebug[39m: sql.0 value not changed xs1.0.Sensors.LuftfeuchteWZ, last-value=25, new-value=25, ts=1518374545000 2018-02-11 19:42:29.426 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.TempTER, new-value=2.2, ts=1518374548000, relog=false 2018-02-11 19:42:29.427 - [34mdebug[39m: sql.0 value not changed xs1.0.Sensors.TempTER, last-value=2.2, new-value=2.2, ts=1518374548000 2018-02-11 19:42:29.439 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.LuftfeuchteTER, new-value=54, ts=1518374548000, relog=false 2018-02-11 19:42:29.440 - [34mdebug[39m: sql.0 value not changed xs1.0.Sensors.LuftfeuchteTER, last-value=54, new-value=54, ts=1518374548000 2018-02-11 19:42:35.196 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.TempAZS, new-value=21.6, ts=1518374554000, relog=false 2018-02-11 19:42:35.196 - [34mdebug[39m: sql.0 value not changed xs1.0.Sensors.TempAZS, last-value=21.6, new-value=21.6, ts=1518374554000 2018-02-11 19:42:35.203 - [34mdebug[39m: sql.0 new value received for xs1.0.Sensors.LuftfeuchteAZS, new-value=32, ts=1518374554000, relog=false 2018-02-11 19:42:35.204 - [34mdebug[39m: sql.0 value not changed xs1.0.Sensors.LuftfeuchteAZS, last-value=32, new-value=32, ts=1518374554000 2018-02-11 19:42:41.929 - [34mdebug[39m: sql.0 new value received for hm-rpc.0.NEQ1100493.1.TEMPERATURE, new-value=1.5, ts=1518374561926, relog=false 2018-02-11 19:42:41.929 - [34mdebug[39m: sql.0 value not changed hm-rpc.0.NEQ1100493.1.TEMPERATURE, last-value=1.5, new-value=1.5, ts=1518374561926 2018-02-11 19:42:41.951 - [34mdebug[39m: sql.0 new value received for hm-rpc.0.NEQ1100493.1.HUMIDITY, new-value=76, ts=1518374561947, relog=false 2018-02-11 19:42:41.952 - [34mdebug[39m: sql.0 Min-Delta reached hm-rpc.0.NEQ1100493.1.HUMIDITY, last-value=75, new-value=76, ts=1518374561947 2018-02-11 19:42:41.952 - [34mdebug[39m: sql.0 Datatype hm-rpc.0.NEQ1100493.1.HUMIDITY: Currently: number, StorageType: Number 2018-02-11 19:42:41.952 - [34mdebug[39m: sql.0 INSERT INTO ts_number (id, ts, val, ack, _from, q) VALUES(72, 1518374408205, 75, true, 3, 0); 2018-02-11 19:42:41.977 - [34mdebug[39m: sql.0 new value received for hm-rpc.0.NEQ1100493.1.RAINING, new-value=false, ts=1518374561974, relog=false 2018-02-11 19:42:41.977 - [34mdebug[39m: sql.0 value not changed hm-rpc.0.NEQ1100493.1.RAINING, last-value=false, new-value=false, ts=1518374561974 2018-02-11 19:42:41.980 - [34mdebug[39m: sql.0 new value received for hm-rpc.0.NEQ1100493.1.RAIN_COUNTER, new-value=111.215, ts=1518374561976, relog=false 2018-02-11 19:42:41.981 - [34mdebug[39m: sql.0 value not changed hm-rpc.0.NEQ1100493.1.RAIN_COUNTER, last-value=111.215, new-value=111.215, ts=1518374561976 2018-02-11 19:42:41.986 - [34mdebug[39m: sql.0 new value received for hm-rpc.0.NEQ1100493.1.WIND_SPEED, new-value=0, ts=1518374561978, relog=false 2018-02-11 19:42:41.986 - [34mdebug[39m: sql.0 value not changed hm-rpc.0.NEQ1100493.1.WIND_SPEED, last-value=0, new-value=0, ts=1518374561978 2018-02-11 19:42:41.987 - [34mdebug[39m: sql.0 new value received for hm-rpc.0.NEQ1100493.1.WIND_DIRECTION, new-value=80, ts=1518374561978, relog=false 2018-02-11 19:42:41.987 - [34mdebug[39m: sql.0 Min-Delta reached hm-rpc.0.NEQ1100493.1.WIND_DIRECTION, last-value=120, new-value=80, ts=1518374561978 2018-02-11 19:42:41.990 - [34mdebug[39m: sql.0 new value received for hm-rpc.0.NEQ1100493.1.WIND_DIRECTION_RANGE, new-value=67, ts=1518374561980, relog=false 2018-02-11 19:42:41.993 - [34mdebug[39m: sql.0 value not changed hm-rpc.0.NEQ1100493.1.WIND_DIRECTION_RANGE, last-value=67, new-value=67, ts=1518374561980 2018-02-11 19:42:41.993 - [34mdebug[39m: sql.0 new value received for hm-rpc.0.NEQ1100493.1.SUNSHINEDURATION, new-value=141, ts=1518374561983, relog=false 2018-02-11 19:42:41.994 - [34mdebug[39m: sql.0 value not changed hm-rpc.0.NEQ1100493.1.SUNSHINEDURATION, last-value=141, new-value=141, ts=1518374561983 !
      Der Fehler passiert hach getHistory wo
      als SQL generiert wird!
      Da der content von getHistory gleich ist wie vorher ist da etwas bei der SQL-Erzeugung faul da es undefined anstatt ts_number liefert.
      • sissiwup
        sissiwup last edited by
        ich hab noch ein neues Problem festgestellt:
        Ich habe ein neues Heizkörperthermostat.
        Ich logge da Ventil, Aktuelle Temperatur und Soll(set)-Temperatur.
        Ventil, Aktuelle Temperatur laufen. Soll Temperatur (wird natürlich seltener geändert)
        wird nicht mehr geloggt. Dieser Datenpunkt steht auf "Änderungen". Alle anderen sind
        ohne "Änderungen".
        Kann das noch wer feststellen?
        • sissiwup
          Noch eine weitere Unschönheit:
          Ändere ich auch nur irgendetwas an einen Datenpunkt, wird dieser bis er einen Wert loggt
          nicht mehr abfragbar. Warum wird hier nicht der Wert aus der Datenbank genommen?
          Es hilft auch nichts den Datenpunkt von Automatisch auf den korrekten Wert zu stellen.
          Ich habe durchaus Datenpunkte, die nur einmal pro Woche Aktiv werden, oder seltener (z.B. ausgelöster Alarm).
          Die kann ich dann erst wieder anzeigen, wenn ich einmal Alarm ausgelöst habe. :?:
            Kueppert last edited by
            Hi Sissi,
            ich hatte Probleme mit den Adapter, allerdings wurde immer geloggt. Ich nutze auch die Option, nur Änderungen zu speichern. Mach Mal einen Screen von deinen SQL Einstellungen für das Objekt.
            Dass die Werte in Objekt unter Tabelle nicht angezeigt werden hatte ich auch. Die Werte sind allerdings noch alle da. Das Phänomen hatte ich aber nur, wenn ich den Adapter neu gestartet habe oder den Datentyp von automatisch auf was aber geändert habe…
            VG Thorsten
            • sissiwup
              anbei eine weitere Merkwürdigkeit:
              kommt mit Fehler:
              sql.0	2018-02-16 09:11:37.702	error	Please wait till next data record is logged and reload.
              sql.0	2018-02-16 09:11:37.701	warn	For getHistory for id hm-rpc.0.LEQ1023360.1.LEVEL: Type empty. Need to write data first. Index = undefined
              in der DB ist aber:
              sauber hinterlegt.
              Kann es sein das er type = 0 als nicht vorhanden erkennt?
              • sissiwup
                @Kueppert:
                Hi Sissi,
                VG Thorsten
                Gesendet von meinem HUAWEI RIO-L01 mit Tapatalk `
                habe das "Änderung" rausgenommen. Jetzt geht er wieder.
                • sissiwup
                  Habe das Parallel-Schreiben rausgenommen, da 1500 Connections nicht ausgereicht haben:
                  sql.0	2018-02-16 20:23:18.586	error	Cannot queue new requests, because more than 100
                  sql.0	2018-02-16 20:23:18.573	error	Cannot queue new requests, because more than 100
                  sql.0	2018-02-16 20:23:16.117	error	Cannot queue new requests, because more than 100
                  sql.0	2018-02-16 20:23:16.083	error	Cannot queue new requests, because more than 100
                  sql.0	2018-02-16 20:23:16.061	error	Cannot queue new requests, because more than 100
                  was kann man da machen?
                    Wohin speicherst du deine Daten? Auf eine Synology? Da kannst du via phpmyadmin dem User unbegrenzt Verbindungen einräumen. Evtl hilft das…
                    • sissiwup
                      @Kueppert:
                      Wohin speicherst du deine Daten? Auf eine Synology? Da kannst du via phpmyadmin dem Bedburger unbegrenzt Verbindungen einräumen. Evtl hilft das…
                      Ne, ist ein Server. Der kann 1500 Verbindungen….
                        apollon77 last edited by
                        @fsjoke:
                        Ok, hab mir Flot 1.7.5 mal angeschaut.
                        flot 1.7.6 hat das ersetzt durch console.error.
                        @sissiwup:
                        Es hilft auch nichts den Datenpunkt von Automatisch auf den korrekten Wert zu stellen. `
                        Bitte 1.7.1 von sql ansehen. Ich habe bei History mal eingebaut das der DBtyp (falls vorhanden) genutzt wird. Die Logik war vorher "zu vorsichtig" 🙂
                          @sissiwup:
                          was kann man da machen? `
                          Was genau meinst Du?
                          Parallele Requests = Eingeschaltet sollte diese Fehlermeldung niemals generieren!
                          Wie kommst Du darauf das 1500 Requests nicht ausgereicht haben? Gab es Connection Fehler?
                          • sissiwup
                            @apollon77:
                            @sissiwup:
                            Wie kommst Du darauf das 1500 Requests nicht ausgereicht haben? Gab es Connection Fehler? `
                            ja, die DB hat einen Fehler zuviele Connections angezeigt. Und da sind 1500 angelegt.
                            • sissiwup
                              seit 1.7.0 gibt es wieder vermehrt duplicate Keys:
                              host.zotac	2018-02-17 08:06:09.026	info	instance system.adapter.yr.0 terminated with code 0 (OK)
                              sql.0	2018-02-17 08:06:05.171	error	Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(236, 1518851163950, 1024, 1, 4, 0);: Error: ER_DUP_ENTRY: Duplicate entry '236-1518851163950' for key 'PRIMARY'
                              sql.0	2018-02-17 08:06:05.144	error	Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(236, 1518851163949, 1024, 1, 4, 0);: Error: ER_DUP_ENTRY: Duplicate entry '236-1518851163949' for key 'PRIMARY'
                              sql.0	2018-02-17 08:06:05.142	error	Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(236, 1518851163950, 1024, 1, 4, 0);: Error: ER_DUP_ENTRY: Duplicate entry '236-1518851163950' for key 'PRIMARY'
                              sql.0	2018-02-17 08:06:05.139	error	Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(236, 1518851163949, 1024, 1, 4, 0);: Error: ER_DUP_ENTRY: Duplicate entry '236-1518851163949' for key 'PRIMARY'
                              sql.0	2018-02-17 08:06:05.136	error	Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(236, 1518851163950, 1024, 1, 4, 0);: Error: ER_DUP_ENTRY: Duplicate entry '236-1518851163950' for key 'PRIMARY'
                              sql.0	2018-02-17 08:06:05.120	error	Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(236, 1518851163949, 1024, 1, 4, 0);: Error: ER_DUP_ENTRY: Duplicate entry '236-1518851163949' for key 'PRIMARY'
                              yr.0	2018-02-17 08:06:03.918	info	got weather data from yr.no
                              host.zotac	2018-02-17 07:30:00.065	info	instance system.adapter.tankerkoenig.0 started with pid 11094
                              sql.0	2018-02-17 07:29:26.746	error	Cannot insert INSERT INTO `iobroker`.ts_string (id, ts, val, ack, _from, q) VALUES(1617, 1518848965643, 'VS-16 EG Trepphaus AUF', 0, 13, 0);: Error: ER_DUP_ENTRY: Duplicate entry '1617-1518848965643'
                              sql.0	2018-02-17 07:29:26.727	error	Cannot insert INSERT INTO `iobroker`.ts_string (id, ts, val, ack, _from, q) VALUES(1617, 1518848965643, 'VS-16 EG Trepphaus AUF', 0, 13, 0);: Error: ER_DUP_ENTRY: Duplicate entry '1617-1518848965643'
                              sql.0	2018-02-17 07:29:26.724	error	Cannot insert INSERT INTO `iobroker`.ts_string (id, ts, val, ack, _from, q) VALUES(1617, 1518848965642, 'VS-16 EG Trepphaus AUF', 0, 13, 0);: Error: ER_DUP_ENTRY: Duplicate entry '1617-1518848965642'
                              sql.0	2018-02-17 07:29:26.715	error	Cannot insert INSERT INTO `iobroker`.ts_string (id, ts, val, ack, _from, q) VALUES(1617, 1518848965642, 'VS-16 EG Trepphaus AUF', 0, 13, 0);: Error: ER_DUP_ENTRY: Duplicate entry '1617-1518848965642'
                              sql.0	2018-02-17 07:29:26.704	error	Cannot insert INSERT INTO `iobroker`.ts_string (id, ts, val, ack, _from, q) VALUES(1617, 1518848965642, 'VS-16 EG Trepphaus AUF', 0, 13, 0);: Error: ER_DUP_ENTRY: Duplicate entry '1617-1518848965642'
                              sql.0	2018-02-17 07:29:26.701	error	Cannot insert INSERT INTO `iobroker`.ts_string (id, ts, val, ack, _from, q) VALUES(1617, 1518848965643, 'VS-16 EG Trepphaus AUF', 0, 13, 0);: Error: ER_DUP_ENTRY: Duplicate entry '1617-1518848965643'
                              javascript.0	2018-02-17 07:20:00.852	info	script.js.servicemeldungen: Text Homematic-Servicemeldungen: keine Servicemeldungen
                              Der erste Punkt wird vom Wetter-Adaper yr gesetzt und ist der Druck.
                              Der zweite Punkt wird vom Skript-Adapter geschrieben. Allerdings nur einmal, da die Loggausgaben vom Skript auch nur einmal kommen.
                              Wie entstehen die doppelten Werte?
                              In der Datenbank kommen im zweiten Fall auch 2 Einträge an.
                              Was mich wundert ist, da der Entprelltimer auf 1000ms steht.
                              • sissiwup
                                Noch eine kleine Unschönheit:
                                Wenn man für mehre Werte die Vorgaben ändern möchte:
                                Dann geht das für Änderungen Aufzeichnen nicht, wenn es unterschiedliche Werte gibt.
                                Für alle anderen kann man es für mehrere Datenpunkte gleichzeitig anpassen.
                                  Duplicate key: keine Ahnung. Bräuchte ich debug log.
                                  Multi Änderungen: bitte github issue für iobroker.admin auf machen
                                  • sissiwup
                                    wenn man den sql-Adapter neu startet, dann kommt, wenn bis dahin kein Datenpunkt geschrieben wurde immer:
                                    Geht man im Browser auf reload, dann sind die Daten sofort da.
                                    Das gleiche glit auch für float Grafiken. Zuerst leer, wenn einmal geschrieben (irgendwin Datenpunkt von den vielen angezeigten)
                                    oder reload über Browser, dann ist wieder alles da.
                                    Ist das bei euch auch so?
                                    PS: 1.7.1
                                    • sissiwup
                                      was sollen mir die Infos sagen:
                                      sql.0	2018-02-17 17:15:43.140	info	init timed Relog: disable relog because state not set so far for hm-rpc.0.MEQ0381249.0.AES_KEY: null
                                      sql.0	2018-02-17 17:15:42.070	info	init timed Relog: disable relog because state not set so far for hm-rpc.1.CUX9104011.2.STATE: null
                                      sql.0	2018-02-17 17:15:31.123	info	init timed Relog: disable relog because state not set so far for hm-rpc.1.CUX2801001.1.STATE: null
                                      sql.0	2018-02-17 17:15:17.958	info	init timed Relog: disable relog because state not set so far for hm-rpc.1.CUX9104010.4.STATE: null
                                      sql.0	2018-02-17 17:15:16.586	info	init timed Relog: disable relog because state not set so far for hm-rpc.0.MEQ0381127.0.AES_KEY: null
                                      sql.0	2018-02-17 17:15:12.178	info	init timed Relog: disable relog because state not set so far for hm-rpc.1.CUX4000001.11.PRESS_SHORT: null
                                      sql.0	2018-02-17 17:15:12.023	info	init timed Relog: disable relog because state not set so far for hm-rpc.1.CUX9104007.2.STATE: null
                                      sql.0	2018-02-17 17:15:10.461	error	Please wait till next data record is logged and reload.
                                      sql.0	2018-02-17 17:15:10.460	warn	For getHistory for id tankerkoenig.0.stations.9.diesel.feed: Type empty. Need to write data first. Index = undefined
                                      sql.0	2018-02-17 17:15:10.460	error	Please wait till next data record is logged and reload.
                                      sql.0	2018-02-17 17:15:10.460	warn	For getHistory for id tankerkoenig.0.stations.6.diesel.feed: Type empty. Need to write data first. Index = undefined
                                      sql.0	2018-02-17 17:15:10.460	warn	For getHistory for id tankerkoenig.0.stations.5.diesel.feed: Type empty. Need to write data first. Index = undefined
                                      sql.0	2018-02-17 17:15:10.460	warn	For getHistory for id tankerkoenig.0.stations.2.diesel.feed: Type empty. Need to write data first. Index = undefined
                                      sql.0	2018-02-17 17:15:10.460	warn	For getHistory for id tankerkoenig.0.stations.1.diesel.feed: Type empty. Need to write data first. Index = undefined
                                        Die Meldungen sagen folgendes:
                                        Wenn Du für einen Datenpunkt das "gleiche Werte loggen nach x Sekunden" einschaltest verssucht der Adapter das auch zu tun wenn innerhalb der Zeit kein neuer Wert kam. Er sucht dann im Zweifel dafür den zuletzt gespeicherten Wert raus.
                                        Wenn es aber keinen gibt - und bei einigen HM-States kann das durchaus passieren - und damit keinerlei "State-Wert" existiert dann kann er auch nichts loggen (NULL loggen macht da keinen Sinn weil es kein echter Wert wäre). Aus dem Grund wird das zeitliche "gleicher Wert loggen" temporär ausgeschaltet. Genau das sagt die Meldung.
                                        Falls für so einen State ein neuer Wert käme dann würde ab dann automatisch das "gleiche Werte loggen" wieder eingeschaltet werden.
                                        Zu der Frage wegen:
                                        Wenn das direkt nach dem Start des Adapters passiert, so kann es sein das deine Grafiken "zu schnell" waren.
                                        Beim Start des Adapters wird nach dem Verbindung und "Initialisierung" der Datenbanktabellen alle Datenpunkte, typen und Indizes ausgelesen und gespeichert. Ein "Index=undefined" wie in der Meldung oben könnte darauf hinweisen das die History-Daten abgefragt wurden BEVOR die Daten gelesen wurden. Das würde solche meldungen direkt nach dem Start erklären.
                                        Ich könnte jetzt was einbauen was das im Zweifel behebt und auch das bei getHistory vorher rausliesst … Nötig? 🙂
                                        • ruhr70
                                          ruhr70 last edited by
                                          Ich hab auch noch ein kleines Problem mit dem SQL Adapter 1.6.9.
                                          Situation:
                                          • Javascript: DP über Skript angelegt
                                          • Monitoring eingeschaltet -> SQL
                                          • Monitoring deaktiviert und dann den Datenpunkt gelöscht
                                          • neuen DP (Name geändert) über Skript angelegt
                                          • Monitoring aktiviert
                                          Nun wird das Log mit Errors vollgeschrieben, Beispiel:
                                          ql.0	2018-02-18 04:13:23.408	error	Cannot insert INSERT INTO `iobrokerng2`.ts_string (id, ts, val, ack, _from, q) VALUES(875, 1518923603385, 'CALL 2 Free', 0, 11, 0);: Error: ER_DUP_ENTRY: Duplicate entry '875-1518923603385' for key primary'
                                          Beim überfliegen der Fehlermeldungen würde ich sagen, es handelt sich durchgängig um die Duplicate entry Meldungen.
                                          Ich sehe den Zusammenhang zwar noch nicht. Kann es sein, dass die Zeit zwischen "Logging deaktivieren" und in den Objekten den Datenpunkt per Hand löschen, zu kurz war?
                                            Hm, wüsste nicht wie das zu „duplicate key“ führen sollte. Das ist an sich eher das zum gleichen zeitstempel schon ein wert in der dB existiert.
                                            Starte mal sql Adapter neu dann sollten pot Probleme vom manuellen löschen weg sein.
                                            Wenn immer noch duplicate key dann bräuchte ich Debug log.
                                            203
                                            25341
