    4. [Aufruf] Dringender Test sql 1.6.4
    • sissiwup
      sissiwup last edited by
      seit 1.7.0 gibt es wieder vermehrt duplicate Keys:
      host.zotac	2018-02-17 08:06:09.026	info	instance system.adapter.yr.0 terminated with code 0 (OK)
      sql.0	2018-02-17 08:06:05.171	error	Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(236, 1518851163950, 1024, 1, 4, 0);: Error: ER_DUP_ENTRY: Duplicate entry '236-1518851163950' for key 'PRIMARY'
      sql.0	2018-02-17 08:06:05.144	error	Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(236, 1518851163949, 1024, 1, 4, 0);: Error: ER_DUP_ENTRY: Duplicate entry '236-1518851163949' for key 'PRIMARY'
      sql.0	2018-02-17 08:06:05.142	error	Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(236, 1518851163950, 1024, 1, 4, 0);: Error: ER_DUP_ENTRY: Duplicate entry '236-1518851163950' for key 'PRIMARY'
      sql.0	2018-02-17 08:06:05.139	error	Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(236, 1518851163949, 1024, 1, 4, 0);: Error: ER_DUP_ENTRY: Duplicate entry '236-1518851163949' for key 'PRIMARY'
      sql.0	2018-02-17 08:06:05.136	error	Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(236, 1518851163950, 1024, 1, 4, 0);: Error: ER_DUP_ENTRY: Duplicate entry '236-1518851163950' for key 'PRIMARY'
      sql.0	2018-02-17 08:06:05.120	error	Cannot insert INSERT INTO `iobroker`.ts_number (id, ts, val, ack, _from, q) VALUES(236, 1518851163949, 1024, 1, 4, 0);: Error: ER_DUP_ENTRY: Duplicate entry '236-1518851163949' for key 'PRIMARY'
      yr.0	2018-02-17 08:06:03.918	info	got weather data from yr.no
      host.zotac	2018-02-17 07:30:00.065	info	instance system.adapter.tankerkoenig.0 started with pid 11094
      sql.0	2018-02-17 07:29:26.746	error	Cannot insert INSERT INTO `iobroker`.ts_string (id, ts, val, ack, _from, q) VALUES(1617, 1518848965643, 'VS-16 EG Trepphaus AUF', 0, 13, 0);: Error: ER_DUP_ENTRY: Duplicate entry '1617-1518848965643'
      sql.0	2018-02-17 07:29:26.727	error	Cannot insert INSERT INTO `iobroker`.ts_string (id, ts, val, ack, _from, q) VALUES(1617, 1518848965643, 'VS-16 EG Trepphaus AUF', 0, 13, 0);: Error: ER_DUP_ENTRY: Duplicate entry '1617-1518848965643'
      sql.0	2018-02-17 07:29:26.724	error	Cannot insert INSERT INTO `iobroker`.ts_string (id, ts, val, ack, _from, q) VALUES(1617, 1518848965642, 'VS-16 EG Trepphaus AUF', 0, 13, 0);: Error: ER_DUP_ENTRY: Duplicate entry '1617-1518848965642'
      sql.0	2018-02-17 07:29:26.715	error	Cannot insert INSERT INTO `iobroker`.ts_string (id, ts, val, ack, _from, q) VALUES(1617, 1518848965642, 'VS-16 EG Trepphaus AUF', 0, 13, 0);: Error: ER_DUP_ENTRY: Duplicate entry '1617-1518848965642'
      sql.0	2018-02-17 07:29:26.704	error	Cannot insert INSERT INTO `iobroker`.ts_string (id, ts, val, ack, _from, q) VALUES(1617, 1518848965642, 'VS-16 EG Trepphaus AUF', 0, 13, 0);: Error: ER_DUP_ENTRY: Duplicate entry '1617-1518848965642'
      sql.0	2018-02-17 07:29:26.701	error	Cannot insert INSERT INTO `iobroker`.ts_string (id, ts, val, ack, _from, q) VALUES(1617, 1518848965643, 'VS-16 EG Trepphaus AUF', 0, 13, 0);: Error: ER_DUP_ENTRY: Duplicate entry '1617-1518848965643'
      javascript.0	2018-02-17 07:20:00.852	info	script.js.servicemeldungen: Text Homematic-Servicemeldungen: keine Servicemeldungen
      Der erste Punkt wird vom Wetter-Adaper yr gesetzt und ist der Druck.
      Der zweite Punkt wird vom Skript-Adapter geschrieben. Allerdings nur einmal, da die Loggausgaben vom Skript auch nur einmal kommen.
      Wie entstehen die doppelten Werte?
      In der Datenbank kommen im zweiten Fall auch 2 Einträge an.
      Was mich wundert ist, da der Entprelltimer auf 1000ms steht.
      • sissiwup
        Noch eine kleine Unschönheit:
        Wenn man für mehre Werte die Vorgaben ändern möchte:
        Dann geht das für Änderungen Aufzeichnen nicht, wenn es unterschiedliche Werte gibt.
        Für alle anderen kann man es für mehrere Datenpunkte gleichzeitig anpassen.
          apollon77 last edited by
          Duplicate key: keine Ahnung. Bräuchte ich debug log.
          Multi Änderungen: bitte github issue für iobroker.admin auf machen
          • sissiwup
            wenn man den sql-Adapter neu startet, dann kommt, wenn bis dahin kein Datenpunkt geschrieben wurde immer:
            Please wait till next data record is logged and reload.
            Geht man im Browser auf reload, dann sind die Daten sofort da.
            Das gleiche glit auch für float Grafiken. Zuerst leer, wenn einmal geschrieben (irgendwin Datenpunkt von den vielen angezeigten)
            oder reload über Browser, dann ist wieder alles da.
            Ist das bei euch auch so?
            PS: 1.7.1
            • sissiwup
              was sollen mir die Infos sagen:
              sql.0	2018-02-17 17:15:43.140	info	init timed Relog: disable relog because state not set so far for hm-rpc.0.MEQ0381249.0.AES_KEY: null
              sql.0	2018-02-17 17:15:42.070	info	init timed Relog: disable relog because state not set so far for hm-rpc.1.CUX9104011.2.STATE: null
              sql.0	2018-02-17 17:15:31.123	info	init timed Relog: disable relog because state not set so far for hm-rpc.1.CUX2801001.1.STATE: null
              sql.0	2018-02-17 17:15:17.958	info	init timed Relog: disable relog because state not set so far for hm-rpc.1.CUX9104010.4.STATE: null
              sql.0	2018-02-17 17:15:16.586	info	init timed Relog: disable relog because state not set so far for hm-rpc.0.MEQ0381127.0.AES_KEY: null
              sql.0	2018-02-17 17:15:12.178	info	init timed Relog: disable relog because state not set so far for hm-rpc.1.CUX4000001.11.PRESS_SHORT: null
              sql.0	2018-02-17 17:15:12.023	info	init timed Relog: disable relog because state not set so far for hm-rpc.1.CUX9104007.2.STATE: null
              sql.0	2018-02-17 17:15:10.461	error	Please wait till next data record is logged and reload.
              sql.0	2018-02-17 17:15:10.460	warn	For getHistory for id tankerkoenig.0.stations.9.diesel.feed: Type empty. Need to write data first. Index = undefined
              sql.0	2018-02-17 17:15:10.460	error	Please wait till next data record is logged and reload.
              sql.0	2018-02-17 17:15:10.460	warn	For getHistory for id tankerkoenig.0.stations.6.diesel.feed: Type empty. Need to write data first. Index = undefined
              sql.0	2018-02-17 17:15:10.460	warn	For getHistory for id tankerkoenig.0.stations.5.diesel.feed: Type empty. Need to write data first. Index = undefined
              sql.0	2018-02-17 17:15:10.460	warn	For getHistory for id tankerkoenig.0.stations.2.diesel.feed: Type empty. Need to write data first. Index = undefined
              sql.0	2018-02-17 17:15:10.460	warn	For getHistory for id tankerkoenig.0.stations.1.diesel.feed: Type empty. Need to write data first. Index = undefined
                Die Meldungen sagen folgendes:
                Wenn Du für einen Datenpunkt das "gleiche Werte loggen nach x Sekunden" einschaltest verssucht der Adapter das auch zu tun wenn innerhalb der Zeit kein neuer Wert kam. Er sucht dann im Zweifel dafür den zuletzt gespeicherten Wert raus.
                Wenn es aber keinen gibt - und bei einigen HM-States kann das durchaus passieren - und damit keinerlei "State-Wert" existiert dann kann er auch nichts loggen (NULL loggen macht da keinen Sinn weil es kein echter Wert wäre). Aus dem Grund wird das zeitliche "gleicher Wert loggen" temporär ausgeschaltet. Genau das sagt die Meldung.
                Falls für so einen State ein neuer Wert käme dann würde ab dann automatisch das "gleiche Werte loggen" wieder eingeschaltet werden.
                Zu der Frage wegen:
                Wenn das direkt nach dem Start des Adapters passiert, so kann es sein das deine Grafiken "zu schnell" waren.
                Beim Start des Adapters wird nach dem Verbindung und "Initialisierung" der Datenbanktabellen alle Datenpunkte, typen und Indizes ausgelesen und gespeichert. Ein "Index=undefined" wie in der Meldung oben könnte darauf hinweisen das die History-Daten abgefragt wurden BEVOR die Daten gelesen wurden. Das würde solche meldungen direkt nach dem Start erklären.
                Ich könnte jetzt was einbauen was das im Zweifel behebt und auch das bei getHistory vorher rausliesst … Nötig? 🙂
                • ruhr70
                  ruhr70 last edited by
                  Ich hab auch noch ein kleines Problem mit dem SQL Adapter 1.6.9.
                  Situation:
                  • Javascript: DP über Skript angelegt
                  • Monitoring eingeschaltet -> SQL
                  • Monitoring deaktiviert und dann den Datenpunkt gelöscht
                  • neuen DP (Name geändert) über Skript angelegt
                  • Monitoring aktiviert
                  Nun wird das Log mit Errors vollgeschrieben, Beispiel:
                  ql.0	2018-02-18 04:13:23.408	error	Cannot insert INSERT INTO `iobrokerng2`.ts_string (id, ts, val, ack, _from, q) VALUES(875, 1518923603385, 'CALL 2 Free', 0, 11, 0);: Error: ER_DUP_ENTRY: Duplicate entry '875-1518923603385' for key primary'
                  Beim überfliegen der Fehlermeldungen würde ich sagen, es handelt sich durchgängig um die Duplicate entry Meldungen.
                  Ich sehe den Zusammenhang zwar noch nicht. Kann es sein, dass die Zeit zwischen "Logging deaktivieren" und in den Objekten den Datenpunkt per Hand löschen, zu kurz war?
                    Hm, wüsste nicht wie das zu „duplicate key“ führen sollte. Das ist an sich eher das zum gleichen zeitstempel schon ein wert in der dB existiert.
                    Starte mal sql Adapter neu dann sollten pot Probleme vom manuellen löschen weg sein.
                    Wenn immer noch duplicate key dann bräuchte ich Debug log.
                    • sissiwup
                      @apollon77:
                      Zu der Frage wegen:
                      Ich könnte jetzt was einbauen was das im Zweifel behebt und auch das bei getHistory vorher rausliesst … Nötig? 🙂 `
                      nein. Ich habe jetzt die Punkt ausgenommen vom "gleicher Wert loggen"
                      • sissiwup
                        Hallo.
                        immer noch Duplicate Keys:
                        *   2018-02-18 14:42:19 Alarmstatus: im Haus/Lüften
                        *   2018-02-18 12:26:32 Alarmstatus: OFF
                        *   2018-02-15 21:41:40 Alarmstatus: Haus alles gesichert
                        Das Ereignis wird einmal in eine Variable geschrieben (siehe manuelles Protokoll), aber:
                        In der Datenbank wird es 3x geschrieben:
                        Was mich wundert ist, das er so lange braucht, bis er in die DB Schreibt.
                        Und warum er überhaupt doppelt schreibt,
                        a) ist entprellen auf 1 Sekunde gesetzt.
                        b) sollen nur Änderungen geschrieben werden
                        Wie ist denn der Ablauf des SQL-Adapters?
                        Beim starten sollte er sich alle Werte für Datenpunkte + ts aus der DB holen. -> Wertecache
                        Bei jeder Änderung sollte er
                        Das muss Atomar sein:
                        a) prüfen ob aktueller ts - Entprell-Intervall > letzter ts
                        b) prüfen ob aktueller Wert <> alter Wert aus DB (bei nur Änderungen)
                        c) Wenn er denn schreiben möchte, dann Cache aktualisieren
                        Jetzt kann parallelisiert werden
                        d) schreiben
                          Um die Duplicates zu verstehen bräuchte ich Debug Log bitte.
                          Die genaue Logik zu beschreiben ist sehr umfangreich. Ganz grob (ohne spezielle Startlogik):
                          Sämtliche Abarbeitung ist atomar weil nur ein Prozess läuft. Alles asynchrone bei JS wird am Ende auch nur sequenziell abgearbeitet.
                          • Werteänderung kommt rein
                          • prüfen ob je nach einstellungen geloggt werden soll oder nicht (vergleich mit letztem geloggten Wert)
                          • Wenn nein, geskippten Wert intern zusätzlich sichern
                          • Wenn ja, Wert sichern und diesen als Referenzwert speichern
                          Wie die Duplicates zustandekommen weiss ich gerade nicht. Ich finde in deinem Screenshot nur nteressant das der timestamp in der Query und die in der Fehlermeldung unterschiedlich sind.
                          Ich weiss aber das es sonderlogik für "Duplicates" gibt die das ganze mit +1ms Timestamp nochmals schreibt. Die ist schon ewig drin …
                          Ingo
                          • ruhr70
                            @apollon77:
                            Starte mal sql Adapter neu dann sollten pot Probleme vom manuellen löschen weg sein. `
                            Nach einem Neustart des SQL-Adapters sind die Meldungen weg.
                            • sissiwup
                              @apollon77:
                              Ingo `
                              Leider tritt der Fehler nur sporadisch auf und der SQL-Adapter schreibt im debug solche Massen an Logdaten, dass ich den nicht für längere Zeit aktivieren möchte.
                              Es ist scheinbar meistens eine Datenpunkt der vom JavaScript-Adapter ausgelöst/geschrieben wird.
                                Hm … dann ist es echt schwierig dem auf die Spur zu kommen ... 😞
                                Ist es immer der gleiche Datenpunkt?
                                Wenn ja vllt zweite ssql-Instanz in Debug Log aufsetzen in zweite DB schreiben und nur wenige Datenpunkte dort aktivieren (die halt wo sowas passiert). Ich kann es aktuell nicht nachvollziehen. Ich brauche aber die Info was passiert wenn es das erste mal passiert
                                • sissiwup
                                  @apollon77:
                                  Wenn ja vllt zweite ssql-Instanz in Debug Log aufsetzen in zweite DB schreiben und nur wenige Datenpunkte dort aktivieren (die halt wo sowas passiert). Ich kann es aktuell nicht nachvollziehen. Ich brauche aber die Info was passiert wenn es das erste mal passiert `
                                  War die Woche auf Dienstreise, werde das mal ausprobieren. Habe ja noch einen 2. Server der die DB schon installiert hat und vor sich hinläuft.
                                  • sissiwup
                                    Wie verhext. Reload im Browser und die Daten sind da.
                                    Ist das vlt. ein Timeout?
                                      welche sql.Adapter Version? Ehrlich noch die 1.6.4?
                                      • sissiwup
                                        @sissiwup:
                                        Ist das vlt. ein Timeout? `
                                        1.7.1
                                          Hm … wann vorher neu gestartet?
                                          • sissiwup
                                            @apollon77:
                                            Hm … wann vorher neu gestartet? `
                                            Jede Nacht um 4:00.
                                            Ist aber der erste Aufruf von vis.
                                            203
                                            25342
