    4. Maxcul ist komplett unbrauchbar (geloest mit 0.5.2)
      skraw.iobroker last edited by
      Negativ. Schon das erste Event dass versucht wird zu senden endet so:
      maxcul.0	2018-02-21 10:52:20.138	info	Packet 0b01004012345616e3280032 sent but no response!
      maxcul.0	2018-02-21 10:52:17.150	debug	serial port buffer have been drained
      maxcul.0	2018-02-21 10:52:17.136	debug	Send Packet to CUL: 0b01004012345616e3280032, awaiting drain event
      maxcul.0	2018-02-21 10:52:17.134	debug	Retransmit packet 0b01004012345616e3280032, try 3 o 3
      maxcul.0	2018-02-21 10:52:14.150	debug	serial port buffer have been drained
      maxcul.0	2018-02-21 10:52:14.134	debug	Send Packet to CUL: 0b01004012345616e3280032, awaiting drain event
      maxcul.0	2018-02-21 10:52:14.132	debug	Retransmit packet 0b01004012345616e3280032, try 2 of 3
      maxcul.0	2018-02-21 10:52:11.150	debug	serial port buffer have been drained
      maxcul.0	2018-02-21 10:52:11.132	debug	Send Packet to CUL: 0b01004012345616e3280032, awaiting drain event
      maxcul.0	2018-02-21 10:52:11.129	debug	Retransmit packet 0b01004012345616e3280032, try 1 of 3
      maxcul.0	2018-02-21 10:52:08.140	debug	serial port buffer have been drained
      maxcul.0	2018-02-21 10:52:08.120	debug	Send Packet to CUL: 0b01004012345616e3280032, awaiting drain event
      maxcul.0	2018-02-21 10:52:08.100	debug	sendTemperature(maxcul.0.NKF0002665, 25, 0)
      maxcul.0	2018-02-21 10:52:07.065	debug	redis pmessage io.maxcul.0.* io.maxcul.0.NKF0002665.desiredTemperature {"val":25,"ack":false,"ts":1519206727049,"q":0,"from":"system.adapter.admin.0","lc":1519206727049}
      Geht nicht…
      Im Vergleich dazu jetzt mit 0.3.0:
      maxcul.0	2018-02-21 10:58:54.320	debug	got OK-ACK Packet from 16e328
      maxcul.0	2018-02-21 10:58:54.299	debug	RSSI for Message: -45
      maxcul.0	2018-02-21 10:58:54.297	debug	decoding Message Z0E01020216E32812345600011864323A
      maxcul.0	2018-02-21 10:58:54.292	debug	incoming raw data from CUL: Z0E01020216E32812345600011864323A
      maxcul.0	2018-02-21 10:58:53.207	debug	serial port buffer have been drained
      maxcul.0	2018-02-21 10:58:53.201	debug	Send Packet to CUL: 0b01004012345616e3280032, awaiting drain event
      maxcul.0	2018-02-21 10:58:53.176	debug	sendTemperature(maxcul.0.NKF0002665, 25, 0)
      maxcul.0	2018-02-21 10:58:52.186	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":503,"ack":true,"ts":1519207132184,"q":0,"from":"system.adapter.maxcul.0","lc":1519207132184}
      maxcul.0	2018-02-21 10:58:52.164	debug	redis pmessage io.maxcul.0.* io.maxcul.0.NKF0002665.desiredTemperature {"val":25,"ack":false,"ts":1519207132162,"q":0,"from":"system.adapter.admin.0","lc":1519206727049}
      Geht …
      Koennte es sein dass das sowas simples wie ein <cr><lf>Problem ist? (Also ein fehlendes <cr>oder andersherum)?
      (Ich hab den betreffenden Code bis dato nicht gelesen...)
      geändert: Code in Code-Tags; Homoran (Mod)</cr></lf></cr>
        apollon77 last edited by
        Dann ein letzter Versuch … bitte nochmal Github. danach mach ich nen Serialport downgrade ... ich hab keine Idee mehr
          booehmemaik last edited by
          @skraw.iobroker:
          Was fuer Typen/Hersteller? `
          eq-3 MAX! Wandthermostat….. ich bekomme meine nicht über den nanocul (bus) + maxcul ausgelesen, bzw angelernt.
          Maik
            @apollon77:
            Was ist diese "Base Adress"? Was habt Ihr da eingefüllt? `
            die Base Address ist gleich maxcube.0.info.rf_address
            Wenn du alle Thermostate am Cube angelernt hast, stellt diese Adresse die kommunikation sicher.
            Wenn du also beim nanocul mit maxcul diese Adresse hinterlegst, funktioniert auch die Kommunikation ohne weiteres includieren.
            Gruss
            Maik
              Ok, ich habe mal in der Github Version (jetzt 0.5.0) wieder die alte Serialport Version eingebaut … Bitte checken.
                Startet nicht mal:
                maxcul.0	2018-02-22 09:03:29.029	error	TypeError: Cannot read property 'removeAllListeners' of undefined at CommunicationServiceLayer.connect (/opt/iobroker/node_modules/iobroker.maxcul/lib/communication-layer.js:49:37) at MaxDrive
                maxcul.0	2018-02-22 09:03:29.029	error	uncaught exception: Cannot read property 'removeAllListeners' of undefined
                maxcul.0	2018-02-22 09:03:29.028	info	using serial device /dev/ttyUSB0@38400
                maxcul.0	2018-02-22 09:03:28.550	info	starting. Version 0.5.0 in /opt/iobroker/node_modules/iobroker.maxcul, node: v6.12.0
                host.ioBroker-Pi	2018-02-22 09:03:26.689	info	instance system.adapter.maxcul.0 started with pid 872
                  Danke, naja die Tests sind nicht vollständig 😞
                  Fixed. Bitte nochmals versuchen
                    Mal was neues, der Adapter haengt, nach dem hier gehts nicht mehr weiter und man kann auch nichts tun. Die "Statusled" steht auf rot und alle drei Punkte auf "falsch"
                    maxcul.0	2018-02-22 10:13:30.797	debug	enable MAX! Mode of the CUL868
                    maxcul.0	2018-02-22 10:13:29.800	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":453,"ack":true,"ts":1519290809793,"q":0,"from":"system.adapter.maxcul.0","lc":1519290809793}
                    maxcul.0	2018-02-22 10:13:29.797	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.limitOverflow {"val":false,"ack":true,"ts":1519290809791,"q":0,"from":"system.adapter.maxcul.0","lc":1519208208071}
                    maxcul.0	2018-02-22 10:13:26.824	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.connection {"val":true,"ack":true,"ts":1519290806814,"q":0,"from":"system.adapter.maxcul.0","lc":1519290806814}
                    maxcul.0	2018-02-22 10:13:26.822	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.version {"val":"V 1.67 nanoCUL868","ack":true,"ts":1519290806812,"q":0,"from":"system.adapter.maxcul.0","lc":1519041256179}
                    maxcul.0	2018-02-22 10:13:26.805	info	CUL FW Version: V 1.67 nanoCUL868
                    maxcul.0	2018-02-22 10:13:26.801	debug	incoming raw data from CUL: V 1.67 nanoCUL868
                    maxcul.0	2018-02-22 10:13:26.792	debug	Requested CUL Version...
                    maxcul.0	2018-02-22 10:13:26.784	debug	check CUL Firmware version
                    maxcul.0	2018-02-22 10:13:24.788	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.connection {"val":false,"ack":true,"ts":1519290804785,"q":0,"from":"system.adapter.maxcul.0","lc":1519290691619}
                    maxcul.0	2018-02-22 10:13:24.776	info	serialPort /dev/ttyUSB0 is open!
                    maxcul.0	2018-02-22 10:13:24.755	info	using serial device /dev/ttyUSB0@38400
                    maxcul.0	2018-02-22 10:13:24.245	info	starting. Version 0.5.0 in /opt/iobroker/node_modules/iobroker.maxcul, node: v6.12.0
                    maxcul.0	2018-02-22 10:13:24.188	info	States connected to redis: 127.0.0.1:6379
                    maxcul.0	2018-02-22 10:13:24.177	debug	statesDB connected
                    maxcul.0	2018-02-22 10:13:24.124	debug	objectDB connected
                    host.ioBroker-Pi	2018-02-22 10:13:22.503	info	instance system.adapter.maxcul.0 started with pid 3997
                    Zur Sicherheit hab ich jetzt das Setup nochmal gebootet. Nunmehr ist zwar der Status der Instanz gruen. Aber zu Objekten wird nichts mehr gesendet bzw von diesen empfangen. Das ganze steht einfach.
                      Hab nochmal was geändert und ne zeile von früher entfernt. Jetzt?
                        Wieder tot… auch nach Reboot das gleiche Bild
                        maxcul.0	2018-02-22 12:42:45.424	debug	enable MAX! Mode of the CUL868
                        maxcul.0	2018-02-22 12:42:44.402	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":453,"ack":true,"ts":1519299764396,"q":0,"from":"system.adapter.maxcul.0","lc":1519299764396}
                        maxcul.0	2018-02-22 12:42:44.399	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.limitOverflow {"val":false,"ack":true,"ts":1519299764393,"q":0,"from":"system.adapter.maxcul.0","lc":1519208208071}
                        maxcul.0	2018-02-22 12:42:41.460	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.connection {"val":true,"ack":true,"ts":1519299761449,"q":0,"from":"system.adapter.maxcul.0","lc":1519299761449}
                        maxcul.0	2018-02-22 12:42:41.454	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.version {"val":"V 1.67 nanoCUL868","ack":true,"ts":1519299761447,"q":0,"from":"system.adapter.maxcul.0","lc":1519041256179}
                        maxcul.0	2018-02-22 12:42:41.441	info	CUL FW Version: V 1.67 nanoCUL868
                        maxcul.0	2018-02-22 12:42:41.437	debug	incoming raw data from CUL: V 1.67 nanoCUL868
                        maxcul.0	2018-02-22 12:42:41.418	debug	Requested CUL Version...
                        maxcul.0	2018-02-22 12:42:41.410	debug	check CUL Firmware version
                        maxcul.0	2018-02-22 12:42:39.415	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.connection {"val":false,"ack":true,"ts":1519299759411,"q":0,"from":"system.adapter.maxcul.0","lc":1519299153998}
                        maxcul.0	2018-02-22 12:42:39.404	info	serialPort /dev/ttyUSB0 is open!
                        maxcul.0	2018-02-22 12:42:39.371	info	using serial device /dev/ttyUSB0@38400
                        maxcul.0	2018-02-22 12:42:38.789	info	starting. Version 0.5.0 in /opt/iobroker/node_modules/iobroker.maxcul, node: v6.12.0
                        maxcul.0	2018-02-22 12:42:38.725	info	States connected to redis: 127.0.0.1:6379
                        Meinst Du nicht es waere einfacher den ganzen "neuen" Code wegzuwerfen und mit dem 0.3.0 einfach nochmal anzufangen?
                        Was fuer Aenderungen brauchen wir denn in dem Adapter unbedingt? 0.3.0 geht echt gut bei mir und auch anderen die ich kenne…
                          @booehmemaik:
                          @skraw.iobroker:
                          Maik `
                          Ich hab mir jetzt mal so ein Ding bestellt, mal sehen wie das geht wenns da ist …
                          Das Wandthermostat ist heute gekommen. Es kann nicht so viel, aber was es kann kann der maxcul Adapter leider nicht, naemlich dieses Kommando:
                          A 0C 5804 42 029D99 000000 00 A2 22 -> SetPointAndCurrentTemperature
                          42 - SetPointAndCurrentTemperature
                          029D99 - eigene Adresse
                          000000 - Zieladresse == Broadcast
                          00 - Zielraum
                          A2 - Aktuelle Temperatur ? hex(A2) = 162 / 8 = 20,25°C? oder 162 /10 + 4,5(festes Offset) = 20,7°C
                          22 - Sollwert 17°C (hex(22)/2) eingestellt
                          Bei mir saehe ein solches Kommando wie folgt aus:
                          2018-02-23 19:49:25.094 - [[34mdebug[[39m: maxcul.0 incoming raw data from CUL: Z0C07044217FAB200000000A80342M
                          2018-02-23 19:49:25.094 - [[34mdebug[[39m: maxcul.0 decoding Message Z0C07044217FAB200000000A80342
                          2018-02-23 19:49:25.095 - [[34mdebug[[39m: maxcul.0 RSSI for Message: -41
                          2018-02-23 19:49:25.095 - [[34mdebug[[39m: maxcul.0 received unknown command id 42
                          • Yellowball
                            Yellowball last edited by
                            Wo wir gerade beim CUL sind:
                            Wie sieht's mit einem funktionierenden Adapter für den Cube aus?
                            Ich hatte mal einen über einen Github-Link installiert, aber der lies permanent meinen ioBroker abstürzen…
                              @Yellowball:
                              Wie sieht's mit einem funktionierenden Adapter für den Cube aus? `
                              Wo ist denn da der Zusammenhang??
                              Dies ist ein Thread zu MaxCul.
                              • und der verbindet sich über einen Busware Cul zu den Max-Geräten
                              • die einbindung eines Selbstbau-CUL wird gerade versucht zu implementieren.
                              Rainer
                                @Yellowball:
                                Ich hatte mal einen über einen Github-Link installiert, aber der lies permanent meinen ioBroker abstürzen… `
                                der Maxcube adapter funktioniert auf meine Pi ohne Problem. Das einzige Problem ist der Cube selbst 😉 wenn man ihn fremd steuert. aber auch das ist gelöst mit einiger hilfe von leute aus dem Forum oder der FB Gruppe.
                                  @Yellowball:
                                  Es gibt wohl einen ioBroker.maxcube Adapter … mehr weiss ich aber nicht.
                                  Gff testen und neuen Thread mit genauen Fehlerinfos auf machen. "ioBroker abstützen lassen" kann ich nicht glauben 🙂
                                    @skraw.iobroker:
                                    Was fuer Aenderungen brauchen wir denn in dem Adapter unbedingt? 0.3.0 geht echt gut bei mir und auch anderen die ich kenne… `
                                    Es gibt ausser Serial Kommunikationsupdate und andere Library/Dependency-Updates keinerlei Änderungen. Ich hab jetzt den Kommunikationscode von 0.3.0 wiederhergestellt in der 0.5.0. Bitte nochmal versuchen.
                                    Wenn es immer noch nicht tut muss ich noch mehr reverten …
                                    Das Problem daran alles wieder zurückzustellen ist das wir im Notfall an einem Punkt landen wo wir keine Updates mehr machen können. Das wäre schlecht.
                                      @skraw.iobroker:
                                      00 - Zielraum
                                      2018-02-23 19:49:25.095 - [[34mdebug[[39m: maxcul.0 received unknown command id 42 `
                                      Also ich habe Code gefunden der das implementieren würde … aber bevor nicht die kommunikation nicht sauber läuft mach ich gar nix. `
                                        @apollon77:
                                        @skraw.iobroker:
                                        Das Problem daran alles wieder zurückzustellen ist das wir im Notfall an einem Punkt landen wo wir keine Updates mehr machen können. Das wäre schlecht. `
                                        gab noch einen Fehler. Aber ab jetzt (0:42 Uhr) bitte nochmal versuchen.
                                        PS: DIe kommunikation war in der 0.3.0 auf "serialport 3.0". Das ist offiziell nur bis nodejs 4 unterstützt. Ich habe es jetzt auf "Serialport 4", wodurch grundsätzlich bis nodejs 8.x unterstützt ist.
                                          Es tut mir leid, aber:
                                          maxcul.0	2018-02-24 01:25:43.593	debug	enable MAX! Mode of the CUL868
                                          maxcul.0	2018-02-24 01:25:42.593	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":453,"ack":true,"ts":1519431942588,"q":0,"from":"system.adapter.maxcul.0","lc":1519431942588}
                                          maxcul.0	2018-02-24 01:25:42.591	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.limitOverflow {"val":false,"ack":true,"ts":1519431942585,"q":0,"from":"system.adapter.maxcul.0","lc":1519431770879}
                                          maxcul.0	2018-02-24 01:25:39.631	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.connection {"val":true,"ack":true,"ts":1519431939624,"q":0,"from":"system.adapter.maxcul.0","lc":1519431939624}
                                          maxcul.0	2018-02-24 01:25:39.629	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.version {"val":"V 1.67 nanoCUL868","ack":true,"ts":1519431939622,"q":0,"from":"system.adapter.maxcul.0","lc":1519041256179}
                                          maxcul.0	2018-02-24 01:25:39.614	info	CUL FW Version: V 1.67 nanoCUL868
                                          maxcul.0	2018-02-24 01:25:39.611	debug	incoming raw data from CUL: V 1.67 nanoCUL868
                                          maxcul.0	2018-02-24 01:25:39.589	debug	Requested CUL Version...
                                          maxcul.0	2018-02-24 01:25:39.581	debug	check CUL Firmware version
                                          maxcul.0	2018-02-24 01:25:37.585	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.connection {"val":false,"ack":true,"ts":1519431937582,"q":0,"from":"system.adapter.maxcul.0","lc":1519431809659}
                                          maxcul.0	2018-02-24 01:25:37.575	info	serialPort /dev/ttyUSB0 is open!
                                          maxcul.0	2018-02-24 01:25:37.554	info	using serial device /dev/ttyUSB0@38400
                                          maxcul.0	2018-02-24 01:25:37.025	info	starting. Version 0.5.0 in /opt/iobroker/node_modules/iobroker.maxcul, node: v6.12.0
                                          maxcul.0	2018-02-24 01:25:36.967	info	States connected to redis: 127.0.0.1:6379
                                          maxcul.0	2018-02-24 01:25:36.955	debug	statesDB connected
                                          maxcul.0	2018-02-24 01:25:36.903	debug	objectDB connected
                                          host.ioBroker-Pi	2018-02-24 01:25:35.225	info	instance system.adapter.maxcul.0 started with pid 25975
                                          host.ioBroker-Pi	2018-02-24 01:25:35.171	info	object change system.adapter.maxcul.0
                                          und steht …
                                          Auch nach einem Reset das gleiche Bild. Nach dem "enable MAX mode" ists aus ...
                                            ich kapiere es nicht … Ich hab nochmal Debug eingebaut. Bitte schick nochmal log.
                                            Ansonsten muss ich wirklich auf serialport 3 zurück und verlieren damit halt node8 support ...
                                            81.1k
                                            maxcul maxcul error
                                            15236
