    4. Maxcul ist komplett unbrauchbar (geloest mit 0.5.2)
      skraw.iobroker last edited by
      Es tut mir leid, aber:
      maxcul.0	2018-02-24 01:25:43.593	debug	enable MAX! Mode of the CUL868
      maxcul.0	2018-02-24 01:25:42.593	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":453,"ack":true,"ts":1519431942588,"q":0,"from":"system.adapter.maxcul.0","lc":1519431942588}
      maxcul.0	2018-02-24 01:25:42.591	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.limitOverflow {"val":false,"ack":true,"ts":1519431942585,"q":0,"from":"system.adapter.maxcul.0","lc":1519431770879}
      maxcul.0	2018-02-24 01:25:39.631	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.connection {"val":true,"ack":true,"ts":1519431939624,"q":0,"from":"system.adapter.maxcul.0","lc":1519431939624}
      maxcul.0	2018-02-24 01:25:39.629	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.version {"val":"V 1.67 nanoCUL868","ack":true,"ts":1519431939622,"q":0,"from":"system.adapter.maxcul.0","lc":1519041256179}
      maxcul.0	2018-02-24 01:25:39.614	info	CUL FW Version: V 1.67 nanoCUL868
      maxcul.0	2018-02-24 01:25:39.611	debug	incoming raw data from CUL: V 1.67 nanoCUL868
      maxcul.0	2018-02-24 01:25:39.589	debug	Requested CUL Version...
      maxcul.0	2018-02-24 01:25:39.581	debug	check CUL Firmware version
      maxcul.0	2018-02-24 01:25:37.585	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.connection {"val":false,"ack":true,"ts":1519431937582,"q":0,"from":"system.adapter.maxcul.0","lc":1519431809659}
      maxcul.0	2018-02-24 01:25:37.575	info	serialPort /dev/ttyUSB0 is open!
      maxcul.0	2018-02-24 01:25:37.554	info	using serial device /dev/ttyUSB0@38400
      maxcul.0	2018-02-24 01:25:37.025	info	starting. Version 0.5.0 in /opt/iobroker/node_modules/iobroker.maxcul, node: v6.12.0
      maxcul.0	2018-02-24 01:25:36.967	info	States connected to redis: 127.0.0.1:6379
      maxcul.0	2018-02-24 01:25:36.955	debug	statesDB connected
      maxcul.0	2018-02-24 01:25:36.903	debug	objectDB connected
      host.ioBroker-Pi	2018-02-24 01:25:35.225	info	instance system.adapter.maxcul.0 started with pid 25975
      host.ioBroker-Pi	2018-02-24 01:25:35.171	info	object change system.adapter.maxcul.0
      und steht …
      Auch nach einem Reset das gleiche Bild. Nach dem "enable MAX mode" ists aus ...
      geändert: Code in Code-Tags; Homoran (Mod)
        apollon77 last edited by
        ich kapiere es nicht … Ich hab nochmal Debug eingebaut. Bitte schick nochmal log.
        Ansonsten muss ich wirklich auf serialport 3 zurück und verlieren damit halt node8 support ...
          Ok, da geht mehr. Das hat es bisher noch nie getan. Hast Du ausser dem Debug noch was geaendert?
          Ich bin erst morgen wieder zum Testen in der Lage, Du kannst noch ueberlegen 🙂
          maxcul.0	2018-02-24 12:58:17.516	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":383,"ack":true,"ts":1519473497506,"q":0,"from":"system.adapter.maxcul.0","lc":1519473497506}
          maxcul.0	2018-02-24 12:58:12.494	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":378,"ack":true,"ts":1519473492488,"q":0,"from":"system.adapter.maxcul.0","lc":1519473492488}
          maxcul.0	2018-02-24 12:58:07.858	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":374,"ack":true,"ts":1519473487853,"q":0,"from":"system.adapter.maxcul.0","lc":1519473487853}
          maxcul.0	2018-02-24 12:58:07.840	debug	got OK-ACK Packet from 16fb8f
          maxcul.0	2018-02-24 12:58:07.840	debug	RSSI for Message: -40.5
          maxcul.0	2018-02-24 12:58:07.839	debug	decoding Message Z0E01020216FB8F123456000139643443
          maxcul.0	2018-02-24 12:58:07.839	debug	incoming raw data from CUL: Z0E01020216FB8F123456000139643443
          maxcul.0	2018-02-24 12:58:06.739	debug	serial port buffer have been drained
          maxcul.0	2018-02-24 12:58:06.723	debug	Send Packet to CUL: 0b01004012345616fb8f0074, awaiting drain event
          maxcul.0	2018-02-24 12:58:06.701	debug	sendTemperature(maxcul.0.NKF0003406, 26, 1)
          maxcul.0	2018-02-24 12:58:05.686	debug	redis pmessage io.maxcul.0.* io.maxcul.0.NKF0003406.desiredTemperature {"val":26,"ack":false,"ts":1519473485684,"q":0,"from":"system.adapter.admin.0","lc":1519473485684}
          maxcul.0	2018-02-24 12:58:02.494	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":478,"ack":true,"ts":1519473482490,"q":0,"from":"system.adapter.maxcul.0","lc":1519473482490}
          maxcul.0	2018-02-24 12:57:57.507	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":473,"ack":true,"ts":1519473477499,"q":0,"from":"system.adapter.maxcul.0","lc":1519473477499}
          maxcul.0	2018-02-24 12:57:52.480	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":468,"ack":true,"ts":1519473472478,"q":0,"from":"system.adapter.maxcul.0","lc":1519473472478}
          maxcul.0	2018-02-24 12:57:47.478	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":463,"ack":true,"ts":1519473467475,"q":0,"from":"system.adapter.maxcul.0","lc":1519473467475}
          maxcul.0	2018-02-24 12:57:42.476	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":458,"ack":true,"ts":1519473462474,"q":0,"from":"system.adapter.maxcul.0","lc":1519473462474}
          maxcul.0	2018-02-24 12:57:38.502	debug	Za drained
          maxcul.0	2018-02-24 12:57:38.496	debug	Za written
          maxcul.0	2018-02-24 12:57:38.492	debug	Zr drained
          maxcul.0	2018-02-24 12:57:38.488	debug	Zr written
          maxcul.0	2018-02-24 12:57:38.485	debug	X20 drained
          maxcul.0	2018-02-24 12:57:38.481	debug	X20 written
          maxcul.0	2018-02-24 12:57:38.477	debug	enable MAX! Mode of the CUL868
          maxcul.0	2018-02-24 12:57:37.484	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":453,"ack":true,"ts":1519473457478,"q":0,"from":"system.adapter.maxcul.0","lc":1519473457478}
          maxcul.0	2018-02-24 12:57:37.482	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.limitOverflow {"val":false,"ack":true,"ts":1519473457475,"q":0,"from":"system.adapter.maxcul.0","lc":1519464560648}
          maxcul.0	2018-02-24 12:57:34.510	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.connection {"val":true,"ack":true,"ts":1519473454502,"q":0,"from":"system.adapter.maxcul.0","lc":1519473454502}
          maxcul.0	2018-02-24 12:57:34.508	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.version {"val":"V 1.67 nanoCUL868","ack":true,"ts":1519473454500,"q":0,"from":"system.adapter.maxcul.0","lc":1519041256179}
          maxcul.0	2018-02-24 12:57:34.492	info	CUL FW Version: V 1.67 nanoCUL868
          maxcul.0	2018-02-24 12:57:34.489	debug	incoming raw data from CUL: V 1.67 nanoCUL868
          maxcul.0	2018-02-24 12:57:34.473	debug	Requested CUL Version...
          maxcul.0	2018-02-24 12:57:34.465	debug	check CUL Firmware version
          maxcul.0	2018-02-24 12:57:32.470	debug	redis pmessage io.maxcul.0.* io.maxcul.0.info.connection {"val":false,"ack":true,"ts":1519473452466,"q":0,"from":"system.adapter.maxcul.0","lc":1519473339719}
          maxcul.0	2018-02-24 12:57:32.458	info	serialPort /dev/ttyUSB0 is open!
          maxcul.0	2018-02-24 12:57:32.438	info	using serial device /dev/ttyUSB0@38400
          maxcul.0	2018-02-24 12:57:31.923	info	starting. Version 0.5.0 in /opt/iobroker/node_modules/iobroker.maxcul, node: v6.12.0
          maxcul.0	2018-02-24 12:57:31.862	info	States connected to redis: 127.0.0.1:6379
          maxcul.0	2018-02-24 12:57:31.850	debug	statesDB connected
          maxcul.0	2018-02-24 12:57:31.796	debug	objectDB connected
          Nachtrag Thema Wandthermostat:
          Abgesehen von dem Kommando 42 habe ich noch nicht verstanden wie man dieses Thermostat mit dem Broker pairt. Mir scheint naemlich diese Broadcasts an "000000" bringen die in der Naehe befindlichen Heizungsthermostate durcheinander, die versuchen dann dieser Anweisung zu folgen und nicht den Broker-Einstellungen…
            Jetzt ist was passiert, das hatten wir noch nie:
            host.ioBroker-Pi	2018-02-24 13:02:36.028	error	instance system.adapter.maxcul.0 terminated with code 0 (OK)
            host.ioBroker-Pi	2018-02-24 13:02:36.028	error	Caught by controller[0]: at FSReqWrap.wrapper [as oncomplete] (fs.js:683:17)
            host.ioBroker-Pi	2018-02-24 13:02:36.028	error	Caught by controller[0]: at SerialPort. (/opt/iobroker/node_modules/serialport/lib/serialport.js:306:7)
            host.ioBroker-Pi	2018-02-24 13:02:36.027	error	Caught by controller[0]: at SerialPort. (/opt/iobroker/node_modules/serialport/lib/serialport.js:293:14)
            host.ioBroker-Pi	2018-02-24 13:02:36.027	error	Caught by controller[0]: at SerialPort._emitData (/opt/iobroker/node_modules/serialport/lib/serialport.js:313:18)
            host.ioBroker-Pi	2018-02-24 13:02:36.027	error	Caught by controller[0]: at SerialPort. (/opt/iobroker/node_modules/serialport/lib/parsers.js:23:13)
            host.ioBroker-Pi	2018-02-24 13:02:36.026	error	Caught by controller[0]: at Array.forEach (native)
            host.ioBroker-Pi	2018-02-24 13:02:36.025	error	Caught by controller[0]: at /opt/iobroker/node_modules/serialport/lib/parsers.js:24:17
            host.ioBroker-Pi	2018-02-24 13:02:36.025	error	Caught by controller[0]: at SerialPort.emit (events.js:188:7)
            host.ioBroker-Pi	2018-02-24 13:02:36.025	error	Caught by controller[0]: at emitOne (events.js:96:13)
            host.ioBroker-Pi	2018-02-24 13:02:36.025	error	Caught by controller[0]: at SerialPort. (/opt/iobroker/node_modules/iobroker.maxcul/lib/communication-layer.js:93:42)
            host.ioBroker-Pi	2018-02-24 13:02:36.024	error	Caught by controller[0]: at CommunicationServiceLayer.emit (events.js:188:7)
            host.ioBroker-Pi	2018-02-24 13:02:36.024	error	Caught by controller[0]: at emitOne (events.js:96:13)
            host.ioBroker-Pi	2018-02-24 13:02:36.024	error	Caught by controller[0]: at CommunicationServiceLayer. (/opt/iobroker/node_modules/iobroker.maxcul/lib/maxcul.js:46:34)
            host.ioBroker-Pi	2018-02-24 13:02:36.024	error	Caught by controller[0]: at MaxDriver.handleIncommingMessage (/opt/iobroker/node_modules/iobroker.maxcul/lib/maxcul.js:151:57)
            host.ioBroker-Pi	2018-02-24 13:02:36.024	error	Caught by controller[0]: at MaxDriver.ThermostatState (/opt/iobroker/node_modules/iobroker.maxcul/lib/maxcul.js:486:38)
            host.ioBroker-Pi	2018-02-24 13:02:36.023	error	Caught by controller[0]: TypeError: rawBitData.getRange is not a function
            maxcul.0	2018-02-24 13:02:35.969	error	TypeError: rawBitData.getRange is not a function at MaxDriver.ThermostatState (/opt/iobroker/node_modules/iobroker.maxcul/lib/maxcul.js:486:38) at MaxDriver.handleIncommingMessage (/opt/iobrok
            maxcul.0	2018-02-24 13:02:35.969	error	uncaught exception: rawBitData.getRange is not a function
            maxcul.0	2018-02-24 13:02:35.968	debug	got data from heatingelement 16fbae with payload 39002D00FB
            maxcul.0	2018-02-24 13:02:35.967	debug	RSSI for Message: -80
            maxcul.0	2018-02-24 13:02:35.967	debug	decoding Message Z0F00046016FBAE0000000039002D00FBF4
            maxcul.0	2018-02-24 13:02:35.966	debug	incoming raw data from CUL: Z0F00046016FBAE0000000039002D00FBF4
              @skraw.iobroker:
              Ich bin erst morgen wieder zum Testen in der Lage, Du kannst noch ueberlegen 🙂 `
              Ja ich habe noch ein was geändert: Es wird jetzt bei der Initialisierung nach jedem senden einer Nachricht gewartet das die auch wirklich gesendet wurde (draining). Das war vorher nicht so. Da wurde einfach alles direkt nacheinander gesendet.
              @skraw.iobroker:
              Jetzt ist was passiert, das hatten wir noch nie: `
              Da ist scheinbar ein Bug im Code der eine Funktion aufruft die es nicht gibt. Habe bei der "Quelle" (ja habe inzwischen gefunden wo die Logik herkommt und könnte daher auch auf die aktuellste Version updaten) nachgesehen und fix ist auf Github.
              Bitte versuchen und mal laufen lassen. Wenn das erstmal wieder so tut wie in der 0.3.0 dann machen wir es erstmal so live.
              Dann kann ich in einer 0.6 mal die Logik aktualisieren auf den aktuellen Stand (Kommunikation nicht anfassen) und wir sehen was da so geht
                Hab die neue Version jetzt gerade installiert und laeuft. Auf die Schnelle kann ich keinen Absturz mehr produzieren wie beim letzten Mal. Ich lass es jetzt mal laufen, solange ich mich nicht melde kannst Du davon ausgehen dass es noch fehlerfrei laeuft…
                  Ok dann veröffentliche ich die 0.5.0 heute Abend um erstmal was funktionierendes live zu haben. Dann versuche ich die Tage mal eine 0.6 mit Logikaktualisierungen
                    Welchen?
                      Mindestens Unterstützung für die Message 42 von oben und anderem Kram.
                        Mickbaer last edited by
                        @skraw.iobroker:
                        Koennte es sein dass das sowas simples wie ein <cr><lf>Problem ist? (Also ein fehlendes <cr>oder andersherum)?
                        (Ich hab den betreffenden Code bis dato nicht gelesen…)
                        geändert: Code in Code-Tags; Homoran (Mod)</cr></lf></cr> `
                        das befürchte Ich bei dem CUL-Adapter, der am naoCUL nicht initialisiert wird auch. 😢
                        Das läßt sich mit mit Terminal PRG nur schwer debuggen.
                        Aber mal sehen was apolon77 da antwortet.
                        Gruß Mickbaer aus Berlin
                          Hab ich doch schon in dem cul Thread. Bitte auch da mal cul vom github testen.
                            Auch nach drei Tagen Laufzeit ist mir nichts ungewoehnliches mehr aufgefallen. Alles sieht gut aus.
                              Hier hab ich noch so ein Phaenomen, dass aber wahrscheinlich nicht mit neuer/alter Version zusammenhaengt.
                              Aus unbekannten Gruenden haengt sich der nanoCUL manchmal auf. Erkennbar ist das am schnellen Blinken der Uebertragungs-LED.
                              Adapter stoppen und wieder starten bringt:
                              maxcul.0 2018-03-02 23:24:00.535 info Timeout on CUL connect, cul is available but not responding
                              maxcul.0 2018-03-02 23:23:36.571 debug Za drained
                              maxcul.0 2018-03-02 23:23:36.566 debug Za written
                              maxcul.0 2018-03-02 23:23:36.560 debug Zr drained
                              maxcul.0 2018-03-02 23:23:36.554 debug Zr written
                              maxcul.0 2018-03-02 23:23:36.549 debug X20 drained
                              maxcul.0 2018-03-02 23:23:36.543 debug X20 written
                              maxcul.0 2018-03-02 23:23:36.536 debug enable MAX! Mode of the CUL868
                              maxcul.0 2018-03-02 23:23:32.533 debug Requested CUL Version…
                              maxcul.0 2018-03-02 23:23:32.529 debug check CUL Firmware version
                              maxcul.0 2018-03-02 23:23:29.919 info starting. Version 0.5.0 in /opt/iobroker/node_modules/iobroker.maxcul, node: v6.12.0
                              maxcul.0 2018-03-02 23:23:29.855 info States connected to redis: 127.0.0.1:6379
                              maxcul.0 2018-03-02 23:23:29.843 debug statesDB connected
                              maxcul.0 2018-03-02 23:23:29.790 debug objectDB connected
                              Das Ding haengt scheinbar einfach. Vielleicht koennen wir dafuer eine Loesung finden?
                                Wie resettet man "das Ding" denn wenn es sowwas tut?
                                  Man stoppt den Adapter und steckt den nanoCUL vom USB ab und wieder an, dann startet man den Adapter wieder…
                                    Aaaaaaaaaaahja 🙂
                                    Keine Ahnung wie der Adapter das regeln soll …
                                      Eigentlich waers ja besser festzustellen was da eigentlich abkackt. Ich hab jetzt mal debug eingeschaltet, vielleicht sieht man ja was wenn er wieder haengenbleiben wuerde.
                                      Mir scheint es koennte etwas mit der Auslastung zu tun haben. Ich habe heute nochmal 3 Fensterkontakte dazugenommen und er ist mir allein heute schon dreimal stehengeblieben. Vielleicht findet sich was im debug-log…
                                      (hatte ich vorhin noch nicht an)
                                        Und schon ists passiert:
                                        ! maxcul.0 2018-03-03 00:00:03.037 debug serial port buffer have been drained maxcul.0 2018-03-03 00:00:03.037 debug serial port buffer have been drained maxcul.0 2018-03-03 00:00:03.036 debug serial port buffer have been drained maxcul.0 2018-03-03 00:00:03.001 debug Send Packet to CUL: 0b0100401234561b7c2e0026, awaiting drain event maxcul.0 2018-03-03 00:00:03.000 debug Send Packet to CUL: 0b0100401234561b7bbd0026, awaiting drain event maxcul.0 2018-03-03 00:00:03.000 debug serial port buffer have been drained maxcul.0 2018-03-03 00:00:03.000 debug Send Packet to CUL: 0b0100401234561b7e310022, awaiting drain event maxcul.0 2018-03-03 00:00:02.999 debug Send Packet to CUL: 0b0100401234561b7d410022, awaiting drain event maxcul.0 2018-03-03 00:00:02.999 debug got OK-ACK Packet from 16fbae maxcul.0 2018-03-03 00:00:02.999 debug RSSI for Message: -72 maxcul.0 2018-03-03 00:00:02.999 debug decoding Message Z0E01020216FBAE123456000138002204 maxcul.0 2018-03-03 00:00:02.998 debug incoming raw data from CUL: Z0E01020216FBAE123456000138002204 maxcul.0 2018-03-03 00:00:01.877 debug sendTemperature(maxcul.0.OEQ2604915, 19, 0) maxcul.0 2018-03-03 00:00:01.871 debug sendTemperature(maxcul.0.OEQ2604801, 19, 0) maxcul.0 2018-03-03 00:00:01.868 debug sendTemperature(maxcul.0.OEQ2605429, 17, 0) maxcul.0 2018-03-03 00:00:01.865 debug serial port buffer have been drained maxcul.0 2018-03-03 00:00:01.853 debug Send Packet to CUL: 0b01004012345616fbae0022, awaiting drain event maxcul.0 2018-03-03 00:00:01.851 debug sendTemperature(maxcul.0.OEQ2605190, 17, 0) maxcul.0 2018-03-03 00:00:01.851 debug sendTemperature(maxcul.0.NKF0003377, 17, 0) maxcul.0 2018-03-03 00:00:00.876 debug redis pmessage io.maxcul.0.* io.maxcul.0.OEQ2604915.desiredTemperature {"val":19,"ack":false,"ts":1520031600873,"q":0,"from":"system.adapter.javascript.0","lc":1520031600873} maxcul.0 2018-03-03 00:00:00.868 debug redis pmessage io.maxcul.0.* io.maxcul.0.OEQ2604801.desiredTemperature {"val":19,"ack":false,"ts":1520031600864,"q":0,"from":"system.adapter.javascript.0","lc":1520031600864} maxcul.0 2018-03-03 00:00:00.865 debug redis pmessage io.maxcul.0.* io.maxcul.0.OEQ2605429.desiredTemperature {"val":17,"ack":false,"ts":1520031600864,"q":0,"from":"system.adapter.javascript.0","lc":1520028000856} maxcul.0 2018-03-03 00:00:00.845 debug redis pmessage io.maxcul.0.* io.maxcul.0.OEQ2605190.desiredTemperature {"val":17,"ack":false,"ts":1520031600831,"q":0,"from":"system.adapter.javascript.0","lc":1520031600831} maxcul.0 2018-03-03 00:00:00.844 debug redis pmessage io.maxcul.0.* io.maxcul.0.NKF0003377.desiredTemperature {"val":17,"ack":false,"ts":1520031600820,"q":0,"from":"system.adapter.javascript.0","lc":1520028000802} javascript.0 2018-03-03 00:00:00.830 info script.js.Skript-Heizung-Esszimmer: setForeignState(id=maxcul.0.OEQ2605190.desiredTemperature, state=17) javascript.0 2018-03-03 00:00:00.827 info script.js.Skript-Heizung-Wohnzimmer: setForeignState(id=maxcul.0.NKF0003377.desiredTemperature, state=17) maxcul.0 2018-03-02 23:59:58.914 debug redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":900,"ack":true,"ts":1520031598899,"q":0,"from":"system.adapter.maxcul.0","lc":1520031458787} maxcul.0 2018-03-02 23:59:53.899 debug redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":900,"ack":true,"ts":1520031593896,"q":0,"from":"system.adapter.maxcul.0","lc":1520031458787} maxcul.0 2018-03-02 23:59:48.897 debug redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":900,"ack":true,"ts":1520031588894,"q":0,"from":"system.adapter.maxcul.0","lc":1520031458787} maxcul.0 2018-03-02 23:59:43.898 debug redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":900,"ack":true,"ts":1520031583894,"q":0,"from":"system.adapter.maxcul.0","lc":1520031458787} maxcul.0 2018-03-02 23:59:38.881 debug redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":900,"ack":true,"ts":1520031578877,"q":0,"from":"system.adapter.maxcul.0","lc":1520031458787} maxcul.0 2018-03-02 23:59:33.877 debug redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":900,"ack":true,"ts":1520031573873,"q":0,"from":"system.adapter.maxcul.0","lc":1520031458787} maxcul.0 2018-03-02 23:58:48.844 debug redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":900,"ack":true,"ts":1520031528835,"q":0,"from":"system.adapter.maxcul.0","lc":1520031458787} maxcul.0 2018-03-02 23:58:43.840 debug redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":900,"ack":true,"ts":1520031523831,"q":0,"from":"system.adapter.maxcul.0","lc":1520031458787} maxcul.0 2018-03-02 23:58:38.831 debug redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":900,"ack":true,"ts":1520031518829,"q":0,"from":"system.adapter.maxcul.0","lc":1520031458787} maxcul.0 2018-03-02 23:58:33.831 debug redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":900,"ack":true,"ts":1520031513827,"q":0,"from":"system.adapter.maxcul.0","lc":1520031458787} maxcul.0 2018-03-02 23:58:28.829 debug redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":900,"ack":true,"ts":1520031508825,"q":0,"from":"system.adapter.maxcul.0","lc":1520031458787} maxcul.0 2018-03-02 23:58:23.829 debug redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":900,"ack":true,"ts":1520031503823,"q":0,"from":"system.adapter.maxcul.0","lc":1520031458787} maxcul.0 2018-03-02 23:58:18.827 debug redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":900,"ack":true,"ts":1520031498821,"q":0,"from":"system.adapter.maxcul.0","lc":1520031458787} maxcul.0 2018-03-02 23:58:13.811 debug redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":900,"ack":true,"ts":1520031493804,"q":0,"from":"system.adapter.maxcul.0","lc":1520031458787} maxcul.0 2018-03-02 23:58:08.809 debug redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":900,"ack":true,"ts":1520031488802,"q":0,"from":"system.adapter.maxcul.0","lc":1520031458787} maxcul.0 2018-03-02 23:58:03.808 debug redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":900,"ack":true,"ts":1520031483799,"q":0,"from":"system.adapter.maxcul.0","lc":1520031458787} maxcul.0 2018-03-02 23:58:01.280 debug redis pmessage io.maxcul.0.* io.maxcul.0.OEQ2604915.rssi {"val":-66.5,"ack":true,"ts":1520031481275,"q":0,"from":"system.adapter.maxcul.0","lc":1520031481275} maxcul.0 2018-03-02 23:58:01.274 debug redis pmessage io.maxcul.0.* io.maxcul.0.OEQ2604915.batteryLow {"val":false,"ack":true,"ts":1520031481267,"q":0,"from":"system.adapter.maxcul.0","lc":1519979406969} maxcul.0 2018-03-02 23:58:01.269 debug redis pmessage io.maxcul.0.* io.maxcul.0.OEQ2604915.rfError {"val":false,"ack":true,"ts":1520031481260,"q":0,"from":"system.adapter.maxcul.0","lc":1519979406964} maxcul.0 2018-03-02 23:58:01.263 debug redis pmessage io.maxcul.0.* io.maxcul.0.OEQ2604915.measuredTemperature {"val":20.1,"ack":true,"ts":1520031481253,"q":0,"from":"system.adapter.maxcul.0","lc":1520031481253} maxcul.0 2018-03-02 23:58:01.256 debug redis pmessage io.maxcul.0.* io.maxcul.0.OEQ2604915.valvePosition {"val":22,"ack":true,"ts":1520031481247,"q":0,"from":"system.adapter.maxcul.0","lc":1520031481247} maxcul.0 2018-03-02 23:58:01.248 debug redis pmessage io.maxcul.0.* io.maxcul.0.OEQ2604915.desiredTemperature {"val":20,"ack":true,"ts":1520031481241,"q":0,"from":"system.adapter.maxcul.0","lc":1520030166413} maxcul.0 2018-03-02 23:58:01.240 debug redis pmessage io.maxcul.0.* io.maxcul.0.OEQ2604915.mode {"val":null,"ack":true,"ts":1520031481232,"q":0,"from":"system.adapter.maxcul.0","lc":1520031481232} maxcul.0 2018-03-02 23:58:01.236 debug ThermostatStateReceived: {"src":"1b7c2e","desiredTemperature":20,"valvePosition":22,"measuredTemperature":20.1,"dstSetting":1,"lanGateway":1,"panel":1,"rfError":0,"batteryLow":0,"untilString":"","rssi maxcul.0 2018-03-02 23:58:01.235 debug got data from heatingelement 1b7c2e with payload 39162800C9 maxcul.0 2018-03-02 23:58:01.235 debug RSSI for Message: -66.5 maxcul.0 2018-03-02 23:58:01.234 debug decoding Message Z0F0004601B7C2E0000000039162800C90F maxcul.0 2018-03-02 23:58:01.234 debug incoming raw data from CUL: Z0F0004601B7C2E0000000039162800C90F maxcul.0 2018-03-02 23:57:58.804 debug redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":900,"ack":true,"ts":1520031478797,"q":0,"from":"system.adapter.maxcul.0","lc":1520031458787} maxcul.0 2018-03-02 23:57:53.799 debug redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":900,"ack":true,"ts":1520031473796,"q":0,"from":"system.adapter.maxcul.0","lc":1520031458787} maxcul.0 2018-03-02 23:57:48.795 debug redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":900,"ack":true,"ts":1520031468792,"q":0,"from":"system.adapter.maxcul.0","lc":1520031458787} maxcul.0 2018-03-02 23:57:43.793 debug redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":900,"ack":true,"ts":1520031463790,"q":0,"from":"system.adapter.maxcul.0","lc":1520031458787} maxcul.0 2018-03-02 23:57:38.795 debug redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":900,"ack":true,"ts":1520031458787,"q":0,"from":"system.adapter.maxcul.0","lc":1520031458787} maxcul.0 2018-03-02 23:57:33.792 debug redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":895,"ack":true,"ts":1520031453785,"q":0,"from":"system.adapter.maxcul.0","lc":1520031453785} maxcul.0 2018-03-02 23:57:30.114 debug redis pmessage io.maxcul.0.* io.maxcul.0.MEQ1480497.rssi {"val":-75.5,"ack":true,"ts":1520031450110,"q":0,"from":"system.adapter.maxcul.0","lc":1520031450110} maxcul.0 2018-03-02 23:57:30.106 debug redis pmessage io.maxcul.0.* io.maxcul.0.MEQ1480497.batteryLow {"val":false,"ack":true,"ts":1520031450104,"q":0,"from":"system.adapter.maxcul.0","lc":1518824069530} maxcul.0 2018-03-02 23:57:30.103 debug redis pmessage io.maxcul.0.* io.maxcul.0.MEQ1480497.rfError {"val":false,"ack":true,"ts":1520031450100,"q":0,"from":"system.adapter.maxcul.0","lc":1519997246688} maxcul.0 2018-03-02 23:57:30.099 debug redis pmessage io.maxcul.0.* io.maxcul.0.MEQ1480497.isOpen {"val":false,"ack":true,"ts":1520031450095,"q":0,"from":"system.adapter.maxcul.0","lc":1520002444590} maxcul.0 2018-03-02 23:57:30.098 debug ShutterContactStateReceived: {"src":"133721","isOpen":0,"rfError":0,"batteryLow":0,"rssi":-75.5} maxcul.0 2018-03-02 23:57:30.098 debug got data from shutter contact 133721 10000 maxcul.0 2018-03-02 23:57:30.097 debug RSSI for Message: -75.5 maxcul.0 2018-03-02 23:57:30.097 debug decoding Message Z0B5106301337211234560010FD maxcul.0 2018-03-02 23:57:30.097 debug incoming raw data from CUL: Z0B5106301337211234560010FD maxcul.0 2018-03-02 23:57:30.097 debug ignored auto-ack packet maxcul.0 2018-03-02 23:57:30.097 debug RSSI for Message: -74 maxcul.0 2018-03-02 23:57:30.097 debug decoding Message Z0B510002123456133721000000 maxcul.0 2018-03-02 23:57:30.096 debug incoming raw data from CUL: Z0B510002123456133721000000 maxcul.0 2018-03-02 23:57:28.786 debug redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":900,"ack":true,"ts":1520031448783,"q":0,"from":"system.adapter.maxcul.0","lc":1520031208598} maxcul.0 2018-03-02 23:57:23.780 debug redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":900,"ack":true,"ts":1520031443778,"q":0,"from":"system.adapter.maxcul.0","lc":1520031208598} maxcul.0 2018-03-02 23:57:18.783 debug redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":900,"ack":true,"ts":1520031438776,"q":0,"from":"system.adapter.maxcul.0","lc":1520031208598} maxcul.0 2018-03-02 23:57:13.779 debug redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":900,"ack":true,"ts":1520031433773,"q":0,"from":"system.adapter.maxcul.0","lc":1520031208598} maxcul.0 2018-03-02 23:57:08.778 debug redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":900,"ack":true,"ts":1520031428770,"q":0,"from":"system.adapter.maxcul.0","lc":1520031208598} maxcul.0 2018-03-02 23:57:03.761 debug redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":900,"ack":true,"ts":1520031423753,"q":0,"from":"system.adapter.maxcul.0","lc":1520031208598} maxcul.0 2018-03-02 23:56:58.757 debug redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":900,"ack":true,"ts":1520031418750,"q":0,"from":"system.adapter.maxcul.0","lc":1520031208598} maxcul.0 2018-03-02 23:56:53.753 debug redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":900,"ack":true,"ts":1520031413748,"q":0,"from":"system.adapter.maxcul.0","lc":1520031208598} maxcul.0 2018-03-02 23:56:48.753 debug redis pmessage io.maxcul.0.* io.maxcul.0.info.quota {"val":900,"ack":true,"ts":1520031408747,"q":0,"from":"system.adapter.maxcul.0","lc":1520031208598} !
                                        So schauts aus, hilft uns das was?
                                        Koennte es sein dass man beim Senden eines Paketes auch auf seine "Fertigstellung" (sprich kompletten Versand) warten sollte?
                                          Hier ist das Problem:
                                          Zeile 150 communication-layer.js:
                                                  CommunicationServiceLayer.prototype.serialWrite = function(data) {
                                                      var command;
                                                      if (this._serialDeviceInstance.isOpen()) {
                                                          command = 'Zs' + data + '\n';
                                                          return this._serialDeviceInstance.writeAsync(command).then((function(_this) {
                                                              return function() {
        env.logger.debug('Send Packet to CUL: ' + data + ', awaiting drain event');
        return _this._serialDeviceInstance.drainAsync().then(function() {
        return env.logger.debug('serial port buffer have been drained');
                                                          })(this));
                                                      } else {
                                                          env.logger.debug('Can not send packet because serial port is not open');
                                                          return Promise.reject('Error: serial port is not open');
                                          Diese Funktion braucht ein Locking. Am besten innerhalb des ersten if.
                                          Damit serialisiert man das Handling des Devices und alles wird funktionieren …
                                          Gibts in dieser Umgebung ein Lock/Unlock? Falls nein einfach "von Hand".
                                          Eine statische Variable hochzaehlen und danach ueberpruefen ob sie 1 ist (0 init). Falls nicht 1 Sekunde warten und nochmal pruefen.
                                          Unlock per Variable--.
                                          Oder sowas ginge auch:
                                          https://github.com/kirill-konshin/mutex-promise
                                            naja, das macht man in nodejs etwas anders/einfacher 🙂
                                            Ich schaue mal wann ich Zeit finde
                                            81.1k
                                            maxcul maxcul error
                                            15243
