    4. [Vorlage] Spotify Skript
      el-lutschi last edited by
      ich habe meinen iobroker neu aufgesetzt und versuche nun den Sporify Adapter zu installieren.
      Leider bekomme ich folgende Fehlermeldung:
      host.SmartHome	2018-02-27 12:43:44.850	info	Update repository "default" under "http://download.iobroker.net/sources-dist.json"
      host.SmartHome	2018-02-27 12:43:44.357	info	iobroker exit 0
      host.SmartHome	2018-02-27 12:43:44.259	info	iobroker npm ERR! Please include the following file with any support request: npm ERR! /npm-debug.log
      host.SmartHome	2018-02-27 12:43:44.195	info	iobroker npm ERR! fetch failed with status code 404npm ERR! npm ERR! If you need help, you may report this error at: npm ERR!
      host.SmartHome	2018-02-27 12:43:44.181	info	iobroker
      host.SmartHome	2018-02-27 12:43:44.170	info	iobroker npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "https://github.com/twonky4/ioBroker.spotify-premium.git/tarball/master" "--production" "--prefix" "/opt/iobroker"npm ERR! node v6.13.0
      host.SmartHome	2018-02-27 12:43:44.169	info	iobroker npm ERR! Linux 4.9.59-v7+
      host.SmartHome	2018-02-27 12:43:44.132	info	iobroker npm ERR! fetch failed https://github.com/twonky4/ioBroker.spotify-premium.git/tarball/master
      iobroker	2018-02-27 12:42:43.608	info	npm WARN retry will retry, error on last attempt: Error: fetch failed with status code 404
      iobroker	2018-02-27 12:42:43.597	info	ERR! fetch failed https://github.com/twonky4/ioBroker.spotify-premium.git/tarball/master
      iobroker	2018-02-27 12:42:43.594	info	npm
      iobroker	2018-02-27 12:42:33.434	info	npm WARN retry will retry, error on last attempt: Error: fetch failed with status code 404
      iobroker	2018-02-27 12:42:33.409	info	npm ERR! fetch failed https://github.com/twonky4/ioBroker.spotify-premium.git/tarball/master
      iobroker	2018-02-27 12:42:20.788	info	npm install https://github.com/twonky4/ioBroker.spotify-premium.git/tarball/master --production --prefix "/opt/iobroker" (System call)
      iobroker	2018-02-27 12:42:20.375	info	install https://github.com/twonky4/ioBroker.spotify-premium.git/tarball/master
      iobroker	2018-02-27 12:42:19.131	info	url "https://github.com/twonky4/ioBroker.spotify-premium.git"
      Andere Adapter aus der Übersicht lassen sich Problemlos installieren.
      Was kann das nur sein?
      • X
        xmace last edited by
        @twonky:
        @xmace: Du benutzt noch das Skript von Lucky. Es gibt mittlerweile einen Adapter, wo dieser Fehler bereits behoben ist: https://github.com/twonky4/ioBroker.spotify-premium `
        Japp ich weis, hab ich ja geschrieben gehabt.
        Hab seitdem den neuen Adapter erfolgreich in Benutzung.
        Hab ne Frage bzgl. dem Objekt "spotify-premium.0.Player.Volume" das wird bei mir nachdem ich die Lautstärke geändert hab immer wieder auf "null" gesetzt
        Im Skript von Lucky blieb der zuletzt eingestellte Wert erhalten.
        Wird nämlich jetzt dann nicht schön im Widget angezeit, Lautstärkeregler springt dann wieder auf 0 zurück.
        Any toughts?
        Außerdem heute folgende Meldungen im Log gehabt 2x
        spotify-premium.0	2018-02-27 19:30:17.426	info	terminating
        spotify-premium.0	2018-02-27 19:30:17.276	error	at emitOne (events.js:116:13)
        spotify-premium.0	2018-02-27 19:30:17.276	error	at TLSSocket.socketErrorListener (_http_client.js:387:9)
        spotify-premium.0	2018-02-27 19:30:17.276	error	at ClientRequest.emit (events.js:211:7)
        spotify-premium.0	2018-02-27 19:30:17.276	error	at Request.onRequestError (/opt/iobroker/node_modules/iobroker.spotify-premium/node_modules/request/request.js:878:8)
        spotify-premium.0	2018-02-27 19:30:17.276	error	at Request.emit (events.js:211:7)
        spotify-premium.0	2018-02-27 19:30:17.276	error	at self.callback (/opt/iobroker/node_modules/iobroker.spotify-premium/node_modules/request/request.js:186:22)
        spotify-premium.0	2018-02-27 19:30:17.276	error	at Request._callback (/opt/iobroker/node_modules/iobroker.spotify-premium/main.js:232:17)
        spotify-premium.0	2018-02-27 19:30:17.276	error	at /opt/iobroker/node_modules/iobroker.spotify-premium/main.js:415:43
        spotify-premium.0	2018-02-27 19:30:17.276	error	TypeError: Cannot read property 'hasOwnProperty' of null
        spotify-premium.0	2018-02-27 19:30:17.275	error	uncaught exception: Cannot read property 'hasOwnProperty' of null
        spotify-premium.0	2018-02-27 19:30:17.247	error	erron in Request
          Habe mein problem von vorhin gelöst indem ich npm und den javascript adapter aktualisiert habe.
          Nun bekomme ich aber sobald ich die auth. URL einfüge immer wieder folgende Meldung
          host.SmartHome	2018-02-27 21:07:19.728	info	Restart adapter system.adapter.spotify-premium.0 because enabled
          host.SmartHome	2018-02-27 21:07:19.728	error	instance system.adapter.spotify-premium.0 terminated with code 0 (OK)
          Caught	2018-02-27 21:07:19.728	error	by controller[0]: at IncomingMessage. (/opt/iobroker/node_modules/request/request.js:1085:12)
          Caught	2018-02-27 21:07:19.728	error	by controller[0]: at Request.emit (events.js:188:7)
          Caught	2018-02-27 21:07:19.728	error	by controller[0]: at emitOne (events.js:96:13)
          Caught	2018-02-27 21:07:19.727	error	by controller[0]: at Request. (/opt/iobroker/node_modules/request/request.js:1163:10)
          Caught	2018-02-27 21:07:19.727	error	by controller[0]: at Request.emit (events.js:191:7)
          Caught	2018-02-27 21:07:19.727	error	by controller[0]: at emitTwo (events.js:106:13)
          Caught	2018-02-27 21:07:19.727	error	by controller[0]: at Request.self.callback (/opt/iobroker/node_modules/request/request.js:186:22)
          Caught	2018-02-27 21:07:19.727	error	by controller[0]: at Request._callback (/opt/iobroker/node_modules/iobroker.spotify-premium/main.js:140:25)
          Caught	2018-02-27 21:07:19.726	error	by controller[0]: at /opt/iobroker/node_modules/iobroker.spotify-premium/main.js:992:13
          Caught	2018-02-27 21:07:19.726	error	by controller[0]: at createPlaybackInfo (/opt/iobroker/node_modules/iobroker.spotify-premium/main.js:338:27)
          Caught	2018-02-27 21:07:19.725	error	by controller[0]: TypeError: Cannot read property 'id' of null
          Das alte Skript funktioniert noch ohne Probleme.
          EDIT: Ich nehme alles zurück und behaute das Gegenteil 😄
          Keine Ahnung warum, aber nun funktioniert es plötzlich. Und das sehr gut.
          Also an dieser Stelle ein großes Danke für den Adapter. Ich freue mich schon auf kommende Funktionen 🙂
            schubi82 last edited by
            Wird bei Euch die Variable "is_active" der Devices aktualisiert? Ich wollte eine Grafik nur anzeigen lassen, wenn das Gerät auch online und anspielbar ist, aber die Variable bleibt immer auf TRUE stehen… Oder ist das Objekt falsch?
              @schubi82:
              Wird bei Euch die Variable "is_active" der Devices aktualisiert? Ich wollte eine Grafik nur anzeigen lassen, wenn das Gerät auch online und anspielbar ist, aber die Variable bleibt immer auf TRUE stehen… Oder ist das Objekt falsch? `
              ja, bei mir wird das aktualisiert. Wenn ich z.B. über den PC das Connect Gerät ändere, erscheint dies nach ein paar Sekunden auch so im Adapter.
              Habe den Wert selbst in einigen Scripts eingebaut.
              • X
                und nochmal:
                spotify-premium.0	2018-03-01 17:33:45.257	info	starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.spotify-premium, node: v8.9.4
                host.iobrokerVM	2018-03-01 17:33:43.007	info	instance system.adapter.spotify-premium.0 started with pid 25017
                host.iobrokerVM	2018-03-01 17:33:12.977	info	Restart adapter system.adapter.spotify-premium.0 because enabled
                host.iobrokerVM	2018-03-01 17:33:12.977	error	instance system.adapter.spotify-premium.0 terminated with code 0 (OK)
                Caught	2018-03-01 17:33:12.977	error	by controller[0]: at emitOne (events.js:116:13)
                Caught	2018-03-01 17:33:12.976	error	by controller[0]: at TLSSocket.socketErrorListener (_http_client.js:387:9)
                Caught	2018-03-01 17:33:12.976	error	by controller[0]: at ClientRequest.emit (events.js:211:7)
                Caught	2018-03-01 17:33:12.976	error	by controller[0]: at emitOne (events.js:116:13)
                Caught	2018-03-01 17:33:12.976	error	by controller[0]: at Request.onRequestError (/opt/iobroker/node_modules/iobroker.spotify-premium/node_modules/request/request.js:878:8)
                Caught	2018-03-01 17:33:12.976	error	by controller[0]: at Request.emit (events.js:211:7)
                Caught	2018-03-01 17:33:12.976	error	by controller[0]: at self.callback (/opt/iobroker/node_modules/iobroker.spotify-premium/node_modules/request/request.js:186:22)
                Caught	2018-03-01 17:33:12.976	error	by controller[0]: at Request._callback (/opt/iobroker/node_modules/iobroker.spotify-premium/main.js:232:17)
                Caught	2018-03-01 17:33:12.975	error	by controller[0]: at /opt/iobroker/node_modules/iobroker.spotify-premium/main.js:415:43
                Caught	2018-03-01 17:33:12.975	error	by controller[0]: TypeError: Cannot read property 'hasOwnProperty' of null
                spotify-premium.0	2018-03-01 17:33:12.883	info	terminating
                spotify-premium.0	2018-03-01 17:33:12.833	error	at emitOne (events.js:116:13)
                spotify-premium.0	2018-03-01 17:33:12.833	error	at TLSSocket.socketErrorListener (_http_client.js:387:9)
                spotify-premium.0	2018-03-01 17:33:12.833	error	at ClientRequest.emit (events.js:211:7)
                spotify-premium.0	2018-03-01 17:33:12.833	error	at Request.onRequestError (/opt/iobroker/node_modules/iobroker.spotify-premium/node_modules/request/request.js:878:8)
                spotify-premium.0	2018-03-01 17:33:12.833	error	at Request.emit (events.js:211:7)
                spotify-premium.0	2018-03-01 17:33:12.833	error	at self.callback (/opt/iobroker/node_modules/iobroker.spotify-premium/node_modules/request/request.js:186:22)
                spotify-premium.0	2018-03-01 17:33:12.833	error	at Request._callback (/opt/iobroker/node_modules/iobroker.spotify-premium/main.js:232:17)
                spotify-premium.0	2018-03-01 17:33:12.833	error	at /opt/iobroker/node_modules/iobroker.spotify-premium/main.js:415:43
                spotify-premium.0	2018-03-01 17:33:12.833	error	TypeError: Cannot read property 'hasOwnProperty' of null
                spotify-premium.0	2018-03-01 17:33:12.833	error	uncaught exception: Cannot read property 'hasOwnProperty' of null
                spotify-premium.0	2018-03-01 17:33:12.816	error	erron in Request
                • wendy2702
                  wendy2702 last edited by
                  @xmace:
                  und nochmal: `
                  Da du````
                  node: v8.9.4
                  Hinweis:
                  Installation Node.js
                  Diese Anleitung bezieht sich auf nodejs 6.x
                  Die Nutzung von Nodejs 8.x wäre ebenfalls möglich, jedoch muss das dort mitgelieferte npm 5.x nach der Installation unbedingt auf v4.x downgegradet werden mit
                  sudo npm install -g npm@4
                  npm 5.x enthält noch einen Bug, der bei ioBroker zu massiven Problemen führt.
                    tempestas last edited by
                    ich kriege den Adapter nicht installiert.
                    npm WARN enoent ENOENT: no such file or directory, open '/home/xxxxxxx/package.json'
                    npm WARN xxxxxxxx No description
                    npm WARN xxxxxxxxxxx No repository field.
                    npm WARN xxxxxx No README data
                    npm WARN xxxxx No license field.
                    xxxxx @iobrokerNUC:~$
                    ?? bin doch Linux Nichtkönner 😞
                    • wendy2702
                      Wie hast du es denn versucht?
                        via admin katze von url installieren und via putty sudo npm install iobroker.spotify-premium
                        • wendy2702
                          Du hast bei der Katze diesen Link rein kopiert:
                          Kannst du davon mal das komplette Logfile posten bitte!
                            ich installiere gerade nochmal mit debug ausgänge. mal sehen
                              host.iobrokerNUC	2018-03-01 19:43:30.034	info	Update repository "default" under "http://download.iobroker.net/sources-dist.json"
                              iobroker	2018-03-01 19:43:29.565	info	exit 0
                              iobroker	2018-03-01 19:43:29.485	info	npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                              iobroker	2018-03-01 19:43:29.485	info	npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/noble/node_modules/xpc-connection):
                              iobroker	2018-03-01 19:43:29.485	info	npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/iobroker.radar/node_modules/noble/node_modules/xpc-connection):
                              iobroker	2018-03-01 19:43:29.485	info	npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                              iobroker	2018-03-01 19:43:29.485	info	npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@^1.0.0 (node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents):
                              iobroker	2018-03-01 19:43:29.485	info	npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@^1.0.0 (node_modules/chokidar/node_modules/fsevents):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.1.3: wa
                              iobroker	2018-03-01 19:43:29.470	info	iobroker@1.0.0 /opt/iobroker└── iobroker.spotify-premium@0.1.0
                              iobroker	2018-03-01 19:41:45.099	info	npm install https://github.com/twonky4/ioBroker.spotify-premium/tarball/master --production --prefix "/opt/iobroker" (System call)
                              iobroker	2018-03-01 19:41:44.840	info	install https://github.com/twonky4/ioBroker.spotify-premium/tarball/master
                              iobroker	2018-03-01 19:41:44.176	info	url "https://github.com/twonky4/ioBroker.spotify-premium" --debug
                              • wendy2702
                                Mach mal bitte
                                node -v
                                npm -v
                                  node 6.11.3
                                  npm 4.6.1
                                  • fischi87
                                    fischi87 last edited by
                                    servus, habe auch gerade versucht den adapter zu starten, installation passt, ohne problem aber ich bekomme die autorisierung nicht hin, bekomme immer diesen Fehler:
                                    error	invalid session. You need to open the actual Authorization.Authorization_URL
                                    Mit freundlichen Grüßen
                                    • wendy2702
                                      Hast du den neu installiert?
                                      Wenn ja nach welcher Anleitung und mit welchem OS?
                                      Ist der Adapter wirklich nicht installiert?
                                      • wendy2702
                                        @fischi87:
                                        Mit freundlichen Grüßen `
                                        Du hast alle Schritte die im Adapter erklärt sind „Richtig“ ausgeführt?
                                          edit:
                                          ich war wieder zu blöd
                                          iobroker add spotify-premium fehlte mir.
                                          gut, dass ich mir mal rainers posting dazu in die favs gespeichert habe. nun kann ich mir den adapter anschauen
                                          • wendy2702
                                            Also fehlte die Instanz
                                            Machst du das nicht über die Admin Oberfläche?
                                            javascript
                                            95
                                            745
                                            262747
