    4. [Vorlage] Spotify Skript
      tempestas last edited by
      ich installiere gerade nochmal mit debug ausgänge. mal sehen
        host.iobrokerNUC	2018-03-01 19:43:30.034	info	Update repository "default" under "http://download.iobroker.net/sources-dist.json"
        iobroker	2018-03-01 19:43:29.565	info	exit 0
        iobroker	2018-03-01 19:43:29.485	info	npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
        iobroker	2018-03-01 19:43:29.485	info	npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/noble/node_modules/xpc-connection):
        iobroker	2018-03-01 19:43:29.485	info	npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/iobroker.radar/node_modules/noble/node_modules/xpc-connection):
        iobroker	2018-03-01 19:43:29.485	info	npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
        iobroker	2018-03-01 19:43:29.485	info	npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@^1.0.0 (node_modules/iobroker.js2fs/node_modules/chokidar/node_modules/fsevents):
        iobroker	2018-03-01 19:43:29.485	info	npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@^1.0.0 (node_modules/chokidar/node_modules/fsevents):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.1.3: wa
        iobroker	2018-03-01 19:43:29.470	info	iobroker@1.0.0 /opt/iobroker└── iobroker.spotify-premium@0.1.0
        iobroker	2018-03-01 19:41:45.099	info	npm install https://github.com/twonky4/ioBroker.spotify-premium/tarball/master --production --prefix "/opt/iobroker" (System call)
        iobroker	2018-03-01 19:41:44.840	info	install https://github.com/twonky4/ioBroker.spotify-premium/tarball/master
        iobroker	2018-03-01 19:41:44.176	info	url "https://github.com/twonky4/ioBroker.spotify-premium" --debug
        • wendy2702
          wendy2702 last edited by
          Mach mal bitte
          node -v
          npm -v
            node 6.11.3
            npm 4.6.1
            • fischi87
              fischi87 last edited by
              servus, habe auch gerade versucht den adapter zu starten, installation passt, ohne problem aber ich bekomme die autorisierung nicht hin, bekomme immer diesen Fehler:
              error	invalid session. You need to open the actual Authorization.Authorization_URL
              Mit freundlichen Grüßen
              • wendy2702
                Hast du den neu installiert?
                Wenn ja nach welcher Anleitung und mit welchem OS?
                Ist der Adapter wirklich nicht installiert?
                • wendy2702
                  @fischi87:
                  Mit freundlichen Grüßen `
                  Du hast alle Schritte die im Adapter erklärt sind „Richtig“ ausgeführt?
                    edit:
                    ich war wieder zu blöd
                    iobroker add spotify-premium fehlte mir.
                    gut, dass ich mir mal rainers posting dazu in die favs gespeichert habe. nun kann ich mir den adapter anschauen
                    • wendy2702
                      Also fehlte die Instanz
                      Machst du das nicht über die Admin Oberfläche?
                        doch hatte ich. passiert bei mir aber gelegentlich, dass da keine instanz mitkommt.
                        • wendy2702
                          Ok
                          Ist das der neue Admin ?
                            Nein.
                            leider kann ich mich mal wieder nicht authen.
                            Die im Browser angezeigte URI bleibt genau die gleiche, die ich auch eingegeben habe aus dem Adapter. Ich sehe dann auch, dass ich verbinden soll, mache ich und dann kommt wie erwartet "invalid redirect uri".
                            Nur, dass in der Adresszeile halt das gleiche drin steht wie vorher. Ich bekomme nichts, um es in die auth Zeile einzugeben
                            genau genommen passiert auf der spotify account page halt einfach gar nichts, wenn ich mich anmelden will. Wenn ich was falsches angebe reagiert sie und sagt falsches PW, beim richtigen passiert einfach… nichts
                            • wendy2702
                              Das sieht nur genauso aus.
                              Hast du bestimmt nicht Zeichen für Zeichen verglichen, oder doch !?
                              Einfach kopieren und einfügen.
                                @wendy2702:
                                Gesendet von iPhone mit Tapatalk Pro `
                                hab sie mal untereinander gepackt die uris, die sahen für mich 100% gleich aus
                                ok nun wirds vollends strange. wie gesagt reagiert der anmelde button nicht.
                                wenn ich dann "ZURÜCK" klicke auf der Maus kommt dann die Abfrage, ob ich verbinden will (??) und auch hier tut der "ok" button einfach… gar nichts
                                  Conquest last edited by
                                  @tempestas:
                                  @wendy2702:
                                  wenn ich dann "ZURÜCK" klicke auf der Maus kommt dann die Abfrage, ob ich verbinden will (??) und auch hier tut der "ok" button einfach… gar nichts ` Browser Cache gelöscht? Hat bei mir geholfen.
                                  LG Torsten
                                  • wendy2702
                                    So,
                                    Rechner mal angeschmissen.
                                    Du hast alle Punkte aus der Adapter Beschreibung ausgeführt?
                                    Kein Copy & Paste fehler bei Client ID und/oder Client Secret? Da hatte ich mal ein leerzeichen am Anfang mit kopiert.
                                    Welchen Browser benutzt du? Cache gelöscht oder anderen Probiert!?
                                    Wie sieht deine Einstellung der Spotify Developer App aus?
                                      Danke, bei mir ändert sich nichts. Der Button tut einfach nichts. Wie gesagt, bei falschem PW wird genörgelt, beim richtiugen passiert nichts ??
                                      • fischi87
                                        @wendy2702:
                                        @fischi87:
                                        Du hast alle Schritte die im Adapter erklärt sind „Richtig“ ausgeführt? `
                                        Ja hab ich getan.
                                          @wendy2702:
                                          So,
                                          Wie sieht deine Einstellung der Spotify Developer App aus? `
                                          ist alles ok.
                                          Mein Problem ist eben das verbinden mit Spotify. Der Button tut halt nichts. So kann ich mich bei Spotify anmelden.
                                            Hast du die richtige Redirect URI eingegeben?
                                            http://localhost
                                            LG Torsten
                                            javascript
                                            95
                                            745
                                            263708
