    4. Adapter: ioBroker.unifi
      andyb last edited by
      Ich hab ähnliches Problem.
      host.orangepiplus2e	2017-11-03 07:53:54.537	error	instance system.adapter.unifi.0 terminated with code 0 (OK)
      Caught	2017-11-03 07:53:54.537	error	by controller[1]: at emitOne (events.js:101:20)
      Caught	2017-11-03 07:53:54.536	error	by controller[1]: at TLSSocket.socketCloseListener (_http_client.js:286:9)
      Caught	2017-11-03 07:53:54.536	error	by controller[1]: at ClientRequest.emit (events.js:188:7)
      Caught	2017-11-03 07:53:54.536	error	by controller[1]: at emitOne (events.js:96:13)
      Caught	2017-11-03 07:53:54.535	error	by controller[1]: at Request.onRequestError (/opt/iobroker/node_modules/request/request.js:884:8)
      Caught	2017-11-03 07:53:54.535	error	by controller[1]: at Request.emit (events.js:188:7)
      Caught	2017-11-03 07:53:54.535	error	by controller[1]: at emitOne (events.js:101:20)
      Caught	2017-11-03 07:53:54.534	error	by controller[1]: at Request. (/opt/iobroker/node_modules/iobroker.unifi/node_modules/node-unifi/unifi.js:1099:11)
      Caught	2017-11-03 07:53:54.534	error	by controller[1]: at next (/opt/iobroker/node_modules/iobroker.unifi/node_modules/node-unifi/node_modules/async/dist/async.js:5171:25)
      Caught	2017-11-03 07:53:54.534	error	by controller[1]: at /opt/iobroker/node_modules/iobroker.unifi/node_modules/node-unifi/node_modules/async/dist/async.js:903:32
      Caught	2017-11-03 07:53:54.533	error	by controller[1]: Error: Callback was already called.
      Caught	2017-11-03 07:53:54.533	error	by controller[0]: at emitOne (events.js:96:13)
      Caught	2017-11-03 07:53:54.533	error	by controller[0]: at TLSSocket.socketErrorListener (_http_client.js:310:9)
      Caught	2017-11-03 07:53:54.532	error	by controller[0]: at ClientRequest.emit (events.js:188:7)
      Caught	2017-11-03 07:53:54.532	error	by controller[0]: at emitOne (events.js:96:13)
      Caught	2017-11-03 07:53:54.532	error	by controller[0]: at Request.onRequestError (/opt/iobroker/node_modules/request/request.js:884:8)
      Caught	2017-11-03 07:53:54.531	error	by controller[0]: at Request.emit (events.js:188:7)
      Caught	2017-11-03 07:53:54.531	error	by controller[0]: at emitOne (events.js:101:20)
      Caught	2017-11-03 07:53:54.531	error	by controller[0]: at Request. (/opt/iobroker/node_modules/iobroker.unifi/node_modules/node-unifi/unifi.js:1099:11)
      Caught	2017-11-03 07:53:54.530	error	by controller[0]: at next (/opt/iobroker/node_modules/iobroker.unifi/node_modules/node-unifi/node_modules/async/dist/async.js:5171:25)
      Caught	2017-11-03 07:53:54.527	error	by controller[0]: at /opt/iobroker/node_modules/iobroker.unifi/node_modules/node-unifi/node_modules/async/dist/async.js:903:32
      Caught	2017-11-03 07:53:54.512	error	by controller[0]: Error: Callback was already called.
        Markus76 last edited by
        ich möchte auch gerne die An-Abwesenheits steuerung über den Unifi Adapter machen.
        Installiert ist alles und die Daten kommen beim IOBroker an.
        Nun möchte ich den last_seen Zeitstempel nutzen und wenn dieser upgedatet wird, dann bin ich anwesend und wenn nicht, dann abwesend.
        Variable auf der CCU2 ist angelegt, wir aber leider nicht gefüllt
        Ich bekomme das in Blockly irgendwie nicht hin…
        Kann mir da bitte jemand unter die Arme greifen..
        • lobomau
          lobomau last edited by
          @Markus76:
          Kann mir da bitte jemand unter die Arme greifen.. `
          Folgendes Blockly Script läuft bei mir sehr gut mit Unifi für die Anwesenheit. Anstatt last_seen habe ich uptime_by_uap. Musst nur den client anpassen, hier wird alle 2 Minuten getriggert:
          Blockly Import:
          ! <xml 1999/xmlns="<URL url=" http:/www.w3.org/xhtml"="">http://www.w3.org/1999/xhtml">
          ! <block type="create" id="LcnDrYS;;Bc/!E+1GuwZ" x="-837" y="13"><field name="NAME">Variablen.ICH_UAP</field></block>
          ! <block type="schedule" id="{@eI25!GvKfragf.dsL" x="-837" y="113"><field name="SCHEDULE">*/2 * * * *</field> ! <statement name="STATEMENT"><block type="controls_if" id="B+@.|[Ga9L/N^}7kRBv,"><mutation else="1"></mutation> ! <value name="IF0"><block type="logic_compare" id="CniS*}L/,0cF#N|nCepx"><field name="OP">EQ</field> ! <value name="A"><block type="logic_compare" id="T_r[9FxM%kil?c^0EZ:J"><field name="OP">LT</field> ! <value name="A"><block type="math_arithmetic" id="B%^IgKuzuM5{246Y!m,(" inline="false"><field name="OP">MINUS</field> ! <value name="A"><shadow type="math_number" id="G5:q#-9.sd2K90TfdAJ"><field name="NUM">1</field></shadow>
          ! <block type="get_value" id="gC-urCBA/^%84(j=^i*"><field name="ATTR">lc</field> ! <field name="OID">unifi.0.default.clients.++MAC-Adresse._uptime_by_uap</field></block></value> ! <value name="B"><shadow type="math_number" id="zYRKTi[[k_,%fr.8Vy7M"><field name="NUM">1</field></shadow> ! <block type="math_arithmetic" id="]J~)QBR4cH/jiG*lz?UL"><field name="OP">MINUS</field> ! <value name="A"><shadow type="math_number" id="XX}xF%B/_0,1}l~SgW-"><field name="NUM">1</field></shadow>
          ! <block type="time_get" id="-4r2Is(JCg_?:Ms_v+Y"><mutation format="false" language="false"></mutation> ! <field name="OPTION">object</field></block></value> ! <value name="B"><shadow type="math_number" id="rCdNrAEh^-FoWAxGU~G"><field name="NUM">120000</field></shadow></value></block></value></block></value>
          ! <value name="B"><block type="math_number" id="DLCYi/V][Pj-{RpP]JE{"><field name="NUM">0</field></block></value></block></value>
          ! <value name="B"><block type="logic_boolean" id="]F~s0eAM%+j//mq0GH"><field name="BOOL">TRUE</field></block></value></block></value>
          ! <statement name="DO0"><block type="control" id="o;yBJXcmet8(TwXWJlMf"><mutation delay_input="false"></mutation>
          ! <field name="OID">javascript.0.Variablen.ICH_UAP</field>
          ! <field name="WITH_DELAY">FALSE</field>
          ! <value name="VALUE"><block type="logic_boolean" id="JD=F=FX|FbaZIy,OPphL"><field name="BOOL">FALSE</field></block></value></block></statement>
          ! <statement name="ELSE"><block type="control" id="GrHf7?!*t8yz{3P2n=w="><mutation delay_input="false"></mutation>
          ! <value name="VALUE"><block type="logic_boolean" id="zTf,][x}2(Hs!fMBWgz:"><field name="BOOL">TRUE</field></block></value></block></statement></block></statement></block></xml>
            adarof last edited by
            Hallo
            Kann mir jemand sagen, ob ich in der Vielfallt der Parameter des Adapters auch einen finde, um das (Gast-)WLAN ein/aus zu schalten?
            Ich möchte das Gast-WLAN einfach nur dann einschalten, wenn auch Gäste zu Besuch sind.
            Die Checkbox existiert (siehe Anhang) - aber ich finde aktuell in den ioBroker-Objekten die einzelnen Netzkwerke garnicht abgebildet?!
            Gruss -
              Kiwifranky last edited by
              hab heute mal den Unifi Adapter ausprobieren wollen. Leider schmeisst er beim Start direkt "api.err.Invalid".
              Der Unifi Controller ist Version 5.6.29.
              Irgendwelche Tipps?
              Grüsse
              Franky
                Hallo
                Ich habe hier einen Workround entwickelt, der eine offizielle API von dem Unify Server nutzt:
                #!/bin/bash
                export username= <username>export password= <password>export baseurl=https://localhost:8443
                export site=default
                . unifi_sh_api
                unifi_api /upd/wlanconf/ <networkid>'{"enabled": true}'</networkid></password></username>
                und zum ausschalten:````
                unifi_api /upd/wlanconf/ <networkid>'{"enabled": false}'</networkid>
                Vielleicht hilfts jemandem noch :)
                  Chris71 last edited by
                  habe vor kurzen die IP-adressen in meinem Netzwerk geändert. Danach etwas Probleme mit dem IObroker der auf einem Raspi rennt.
                  Mittlerweile läuft bis auf den Unifi aber wieder alles.
                  Folgende Fehlermeldung steht im LOG.
                  Chris
                    PROBLEM GELÖST!
                    Nach Neustart der Synology DS läuft es jetzt. Da ivh mit anderen Geräten Zugriff auf den Controller hatte wundert mich das jetzt schon ein wenig.
                    Aber egal nun läufts.
                    • I
                      IanS last edited by
                      Hallo Jens und alle Anderen,
                      ich bin die Tage bei meiner Suche nach einer Anwesenheitserkennung auf diesen Adapter gestoßen.
                      Hab Versucht das ganze ans laufen zu bringen, leider ist es aber für mich iwie noch Rakentenwissenschaft….
                      Der Adapter laüft ohne Fehler im Log und in den SV auf der CCU wir auch was geändert, allerdings nicht alles.
                      Ich würde mich über einen Tipp oder Schupps in die richtige Richtung sehr freuen.
                      Ein Handy und ein Gast ist angemeldet und unter .list und .string .Nutzer passt es auch.
                      Nur wird nicht die Anwesenheit gesetzt, Weder vom User noch Gesamtanwesenheit.
                      Einzig beim Gast klappt es....
                      Hier mal das Script, Bild der SVs hänge ich mal unten an.
                      Würde mich echt freuen wenn jemand helfen könnte.
                      FloH
                       * unifi_pdetect v0.1 (29.09.2017)
                       * Copyright (c) 2017 Jens Maus <mail@jens-maus.de>
                      /* define actual user devices here */
                      var user_devices = [];
                      user_devices['C8:3C:85:30:61:59'] = 'FloH';
                      user_devices['9C:5C:F9:53:08:1F'] = 'Jessii';
                      /* define here devices that you 'know', thus should
                       * be ignored
                      var known_devices=[ "34:c0:59:10:f3:b1",
                                          "84:20:96:22:c5:3b",
                                          "7e:49:79:58:cb:55",
                                          "08:78:08:cd:75:f4",
                                          "70:ee:50:22:d3:c4",];
                      /* Enum list of all combinations of users+guest */
                      var enum_list = [];
                      enum_list[0] = "Keiner da";
                      enum_list[1] = "FloH";
                      enum_list[2] = "Jessii";
                      enum_list[3] = "FloH,Jessii";
                      enum_list[4] = "Gast";
                      enum_list[5] = "FloH,Gast";
                      enum_list[6] = "Jessii,Gast";
                      enum_list[7] = "FloH,Jessii,Gast";
                      /* Path to system variables on CCU */
                      var sysvar_prefix= "hm-rega.0.8964"/*Anwesenheit_Mobile*/;
                      var sysvar_user  = "hm-rega.0.8965"/*Anwesenheit.Nutzer*/;
                      var sysvar_guest = "hm-rega.0.8968"/*Anwesenheit.Gast*/;
                      var sysvar_str   = "hm-rega.0.8967"/*Anwesenheit.string*/;
                      var sysvar_list  = "hm-rega.0.8966"/*Anwesenheit.list*/;
                      /* Unifi controller settings */
                      var unifi_ip   = "192.168.XXX.XX";
                      var unifi_port = 8443;
                      var unifi_user = "XXXXXXXX";
                      var unifi_pw   = "XXXXXXXX";
                      /* Don't modify anything from here */
                      function check_presence() {
                          var unifi = require('node-unifi');
                          var controller = new unifi.Controller(unifi_ip, unifi_port);
                          var guest_found = false;
                          var users_found = [];
                          var tmp = known_devices.join('~').toUpperCase();
                          known_devices = tmp.split('~');
                          // LOGIN
                          controller.login(unifi_user, unifi_pw, function(err) {
                              if(err) {
                                  console.log('ERROR: ' + err);
                                  return;
                              // GET SITE STATS
                              controller.getSitesStats(function(err, sites) {
                                  // GET CLIENT DEVICES
                                  controller.getClientDevices(sites[0].name, function(err, client_data) {
                                      //log('curtime: ' + Math.floor((new Date).getTime()/1000));
                                      for (var i=0; i < client_data[0].length; i++) {
                                          if(typeof(client_data[0][i].ip) !== 'undefined' && client_data[0][i].ip) {
                                              if(typeof(client_data[0][i]._last_seen_by_uap) !== 'undefined' && client_data[0][i]._last_seen_by_uap) {
                                                  //log(client_data[0][i].mac + " " + client_data[0][i]._last_seen_by_uap + " " + client_data[0][i].idletime + " " + client_data[0][i].ip + " " + client_data[0][i].hostname + " " + client_data[0][i].is_guest);
                                                  var user_device = user_devices[client_data[0][i].mac.toUpperCase()];
                                                  if(typeof(user_device) !== 'undefined') {
                                                      //log('user device[' + user_device + ']: ' + client_data[0][i].mac.toUpperCase() + ' ' + client_data[0][i].hostname + ' - idle: ' + client_data[0][i].idletime);
                                                      users_found.push(user_device);
                                                  else if(known_devices.indexOf(client_data[0][i].mac.toUpperCase()) === -1)
                                                      //log('guest device found: ' + client_data[0][i].mac.toUpperCase() + ': ' + client_data[0][i].hostname + ' - idle: ' + client_data[0][i].idletime);
                                                      guest_found = true;
                                      controller.logout();
                                      if(getState(sysvar_user).val !== (users_found.length > 0)) {
                                          setState(sysvar_user, (users_found.length > 0));
                                      var presence_string = "";
                                      var num_presence = 0;
                                      for (var j in user_devices) {
                                          var user_present = users_found.indexOf(user_devices[j]) !== -1;
                                          if(user_present === true) {
                                              if(num_presence > 0)
                                                  presence_string += ",";
                                              presence_string += user_devices[j];
                                              num_presence++;
                                          var id = getIdByName(sysvar_prefix + '.' + user_devices[j]);
                                          if(typeof(id) !== 'undefined' && id) {
                                              if(getState(id).val !== user_present) {
                                                  setState(id, user_present);
                                                  log("User '" + user_devices[j] + "' changed present state: " + user_present);
                                      // find out if guest mode is already on or off and then we switch it
                                      // accordingly
                                      if(getState(sysvar_guest).val !== guest_found) {
                                          setState(sysvar_guest, guest_found);
                                          log('Guest mode set to ' + guest_found);
                                      if(guest_found === true) {
                                          presence_string += "Gast";
                                      if(getState(sysvar_str).val !== presence_string) {
                                          setState(sysvar_str, presence_string);
                                      var enum_id = enum_list.indexOf(presence_string);
                                      if(enum_id === -1)
                                          enum_id = 0;
                                      if(getState(sysvar_list).val !== enum_id) {
                                          setState(sysvar_list, enum_id);
                      schedule("*/15 * * * * *", function () { // Execute every 15 seconds
                          check_presence();
                      });</mail@jens-maus.de>`
                        [2820_screenshot_2018-03-01_19.58.42.png](/assets/uploads/files/2820_screenshot_2018-03-01_19.58.42.png)  [/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i]
                        Flauschi last edited by
                        Du könntest Jens sein addon auf der CCU installieren und das damit machen?
                        hm_pdetect glaub heisst es.
                        Das läuft bei mir mit meinen Unifi Geräten absolut perfekt und rasch.
                          Superdad last edited by
                          @Flauschi
                          Wie hast du das eingestellt in hm_pdetect, dass es dann auf die Unifi-Geräte zugreift?
                            es funktioniert einfach.
                            Das addon schaut in der Fritzbox nach, ob diese Geräte im Netzwerk sind.
                            Der Unifi liefert die Information korrekt an die Fritzbox.
                              Aha, man braucht also noch die Fritzbox dazu.
                              Die habe ich abgeschafft.
                              Dann geht es darüber wohl nicht?
                              • I
                                IanS last edited by
                                @Flauschi
                                Danke die Variante kenne ich.
                                Würde es dennoch lieber mit dieser Lösung machen.
                                Ich möchte ja dazu was lernen und wissen was ich falsch gemacht habe. [emoji16]
                                Gruß FloH
                                  davidsieg82 last edited by
                                  Hallo Jens,
                                  ich hatte gerade versucht deinen Adapter zu installieren.
                                  Bei der Configseite kommt der Fehler: "File index.html not found"
                                  Hast du da eine Lösung?
                                  David
                                  • I
                                    IanS last edited by
                                    gibt es einen Grund das fast alle Beiträge von Jens hier verschwunden sind??
                                    Gruß FloH
                                    EDIT: Das alles was mit dem Script zur Anwesenheit verschwunden ist??
                                    Sogar in meinem Post ist das Script verschwunden….. :shock: :shock: :shock:
                                    EDIT 2: Sorry, hab das mit dem Serverproblem erst jetzt gelesen :oops: :oops: :oops:
                                    • stephan1827
                                      stephan1827 last edited by
                                      @Kiwifranky:
                                      Irgendwelche Tipps?
                                      Grüsse
                                      Franky `
                                      Ich habe das gleiche Problem. Gibt es dafür schon eine Lösung?
                                      • stephan1827
                                        @stephanstricker:
                                        @Kiwifranky:
                                        Irgendwelche Tipps?
                                        Grüsse
                                        Franky `
                                        Ich habe das gleiche Problem. Gibt es dafür schon eine Lösung? `
                                        Habs gefunden, Benutzername war falsch
                                          Wuehler last edited by
                                          ich bin zwar auf Basis fhem unterwegs, denke aber, dass auch iobroker dieselbe Anforderung an unifi hat, wie ich. Wenn ich es richtig sehe pollt iobroker.unifi ebenfalls regelmäßig, ob zB ein User connected ist. Das könnte man mit den neuen notification-emails des Unifi-Controllers auf einen push-Mechanismus umstellen, schön wäre das Ganze aber nicht wirklich.
                                          Unter
                                          https://community.ubnt.com/t5/UniFi-Fea … -p/2276503
                                          habe ich daher einen FeatureRequest gestellt, um nicht nur mails zu bekommen sondern eine Callback-URL angeben zu können, die mit JSON-Daten aufgerufen werden soll.
                                          Wäre cool, wenn ihr das mit unterstützt und ein paar "Daumen hoch" oder Kommentare hinterlasst.
                                          Danke,
                                          Wuehler
                                            @jens.maus:
                                            @jensus11:
                                            so wie schon im Homematic Forum gefragt, wie machst du jetzt deine Anwesenheitssteuerung?
                                            Erkläre das doch mal bitte. `
                                            Das ganze mache ich momentan über das "node-unifi" nodejs Modul und nicht über mein unifi iobroker Adapter. Voraussetzung ist, das man im js-controller als Zusatzpaket eben "node-unifi" angegeben hat (siehe Einstellung des js-controller). Dann kann man folgendes Skript nutzen um eine an hm_pdetect angelehnte Anwesenheitserkennung durchzuführen und Systemvariablen in der CCU/RaspberryMatic setzen zu lassen:
                                             * Copyright (c) 2017 Jens Maus <mail@jens-maus.de>*
                                            user_devices['AA:BB:CC:DD:EE:FF'] = 'John';
                                            user_devices['AA:BB:CC:DD:EE:FF'] = 'Jane';
                                             * be ignored
                                            var known_devices=[ "AA:BB:CC:DD:EE:FF",
        "AA:BB:CC:DD:EE:FF"];
                                            var enum_list = [];
                                            enum_list[0] = "Nobody";
                                            enum_list[1] = "John";
                                            enum_list[2] = "Jane";
                                            enum_list[3] = "John,Jane";
                                            enum_list[4] = "Guest";
                                            enum_list[5] = "John,Guest";
                                            enum_list[6] = "Jane,Guest";
                                            enum_list[7] = "John,Jane,Guest";
                                            var sysvar_prefix= "Anwesenheit";
                                            var sysvar_user  = "hm-rega.0.35037"/*Anwesenheit.Nutzer*/;
                                            var sysvar_guest = "hm-rega.0.15785"/*Anwesenheit.Gast*/;
                                            var sysvar_str   = "hm-rega.0.31854"/*Anwesenheit.string*/;
                                            var sysvar_list  = "hm-rega.0.31853"/*Anwesenheit.list*/;
                                            var unifi_ip   = "192.168.X.X";
                                            var unifi_user = "admin";
                                            var unifi_pw   = "XxxxxxxX";
                                                // LOGIN
                                                    if(err) {
                                                        return;
                                                    // GET SITE STATS
        guest_found = true;
        num_presence++;
                                                            // accordingly
                                                            if(enum_id === -1)
        enum_id = 0;
                                                check_presence();
                                            Ich hoffe das sollte selbsterklärend sein. Wie gesagt, momentan nur ein Anfang und ohne Beteiligung des unifi iobroker Adapters von mir, aber es sollte äquivalent zu hm_pdetect gehen. Voraussetzung ist wie gesagt das man das 'node_unifi' nodejs einbindet (js-controller einstellungen) und das man natürlich die gleichen Systemvariablen verwendet wie mit hm_pdetect. Ggf. werde ich das ganze noch etwas erweitern/verbessern und ggf. sogar in den unifi iobroker Adapter direkt integrieren damit man hier kein extra Skript machen muss sondern der Adapter das direkt anbietet. Aber dafür fehlt mir momentan die Zeit.
                                            Viel Spass damit. Und ich freue mich wie immer über Feedback.
                                            habe vorher auch eine Anwesenheitsteuerung über Fritzbox mit dem Zusatzprogramm HM-Pdetect realisiert.
                                            Das funktionierte super einfach. Da ich jetzt auch auch Unifi baue möchte versuchen die Anwesenheit mit dem Skript von Jens Maus zu realisieren.
                                            Mir fehlen da aber Grundkenntnisse was Skriptprogrammierung angeht.
                                            Wie bekomme ich die Einstellungen im Js-Controller getätig? Muss ich da über Putty in die Datei? Momentan läuft mein IO-Broker auf einem Raspi.
                                            Controller für die Unifi-Geräte läuft auf einer Synology.
                                            Bevor ich jetzt wieder irgendetwas mache und mein IO-Broker schmiert mir ab, kann mir da vieleicht jemand helfen?
                                            Oder ist in absehbarer Zeit evtl. ein fertiger Adapter in Arbeit der mit der Anwesenheitsimulation arbeitet kann?
                                            Christian[/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i][/i]
                                            unifi
                                            171
                                            1010
                                            386161
