    4. [Adapter] Sonoff- Tasmota
      Balu0127 last edited by
      Hab jetzt Experimentiert mit dem Ping Adapter. Keine Verbesserung.
      Komischerweise funktionieren die Sonoff im Sonweb ohne Probleme. Dort werden die alle 15 Sekunden abgefragt ob an oder aus.
      Hab nur das Problem mit dem Sonoff.0 Adapter.
      Glaub schon langsam nicht mehr das es was mit Geräten zu tun hat?
      Hat jemand eine Idee was man noch probieren könnte?
        Arnulf last edited by
        sonweb?
        Was ist das denn?
          Master77 last edited by
          Einfach eben googlen….. 😉
          https://github.com/arendst/Sonoff-Tasmota/wiki/SonWEB
          Gruß Markus
          Getippt von unterwegs mit Tapatalk Pro.
            TimmBo last edited by
            Hatte fast 3 Wochen ruhe aber jetzt sind die Sonoff wieder auf ner anderen Party :shock:
            ! sonoff.0 2018-03-01 19:10:18.164 warn Client error [Radio_Kueche]: Error: This socket has been ended by the other party
            ! sonoff.0 2018-03-01 19:10:18.163 warn Client error [Radio_Kueche]: Error: This socket has been ended by the other party
            ! sonoff.0 2018-03-01 19:10:18.162 warn Client error [Radio_Kueche]: Error: This socket has been ended by the other party
            ! sonoff.0 2018-03-01 19:10:18.161 warn Client error [Radio_Kueche]: Error: This socket has been ended by the other party
            ! sonoff.0 2018-03-01 19:10:18.160 info Client [Radio_Kueche] closed
            ! sonoff.0 2018-03-01 19:10:17.235 warn Client error [Wandlampe_Kueche]: Error: This socket has been ended by the other party
            ! sonoff.0 2018-03-01 19:10:17.234 warn Client error [Wandlampe_Kueche]: Error: This socket has been ended by the other party
            ! sonoff.0 2018-03-01 19:10:17.233 warn Client error [Wandlampe_Kueche]: Error: This socket has been ended by the other party
            ! sonoff.0 2018-03-01 19:10:17.232 warn Client error [Wandlampe_Kueche]: Error: This socket has been ended by the other party
            ! sonoff.0 2018-03-01 19:10:17.231 info Client [Wandlampe_Kueche] closed
            ! sonoff.0 2018-03-01 19:10:14.752 warn Client error [Toaster]: Error: This socket has been ended by the other party
            ! sonoff.0 2018-03-01 19:10:14.751 warn Client error [Toaster]: Error: This socket has been ended by the other party
            ! sonoff.0 2018-03-01 19:10:14.750 warn Client error [Toaster]: Error: This socket has been ended by the other party
            ! sonoff.0 2018-03-01 19:10:14.749 warn Client error [Toaster]: Error: This socket has been ended by the other party
            ! sonoff.0 2018-03-01 19:10:14.748 info Client [Toaster] closed
            ! sonoff.0 2018-03-01 19:10:11.273 warn Client error [Radio_Bruno]: Error: This socket has been ended by the other party
            ! sonoff.0 2018-03-01 19:10:11.272 warn Client error [Radio_Bruno]: Error: This socket has been ended by the other party
            ! sonoff.0 2018-03-01 19:10:11.271 warn Client error [Radio_Bruno]: Error: This socket has been ended by the other party
            ! sonoff.0 2018-03-01 19:10:11.270 warn Client error [Radio_Bruno]: Error: This socket has been ended by the other party
            ! sonoff.0 2018-03-01 19:10:11.269 warn Client error [Radio_Bruno]: Error: This socket has been ended by the other party
            ! sonoff.0 2018-03-01 19:10:11.267 info Client [Radio_Bruno] closed
            ! sonoff.0 2018-03-01 19:10:10.163 info Client [Radio_Kueche] connected
            ! sonoff.0 2018-03-01 19:10:09.762 info Client [Wandlampe_Kueche] connected
            ! sonoff.0 2018-03-01 19:10:07.749 info Client [Radio_Bruno] connected
            ! sonoff.0 2018-03-01 19:10:06.844 info Client [Toaster] connected
            ! sonoff.0 2018-03-01 19:01:56.153 warn Client error [Radio_Bruno]: Error: This socket has been ended by the other party
            ! sonoff.0 2018-03-01 19:01:56.152 warn Client error [Radio_Bruno]: Error: This socket has been ended by the other party
            ! sonoff.0 2018-03-01 19:01:56.151 warn Client error [Radio_Bruno]: Error: This socket has been ended by the other party
            ! sonoff.0 2018-03-01 19:01:56.150 warn Client error [Radio_Bruno]: Error: This socket has been ended by the other party
            ! sonoff.0 2018-03-01 19:01:56.149 warn Client error [Radio_Bruno]: Error: This socket has been ended by the other party
            ! sonoff.0 2018-03-01 19:01:56.142 info Client [Radio_Bruno] closed
            ! sonoff.0 2018-03-01 19:01:47.897 info Client [Radio_Bruno] connected
            ! admin.0 2018-03-01 18:34:05.625 info Repository received successfully.
            ! host.raspberrypi 2018-03-01 18:34:03.579 info Update repository "default" under "http://download.iobroker.net/sources-dist.json"
            ! admin.0 2018-03-01 18:34:03.331 info Request actual repository…
            ! web.0 2018-03-01 18:01:52.643 info 2018-03-01T17:01:52.642Z Connected system.user.admin
            ! sonoff.0 2018-03-01 17:43:04.909 info Client [Radio_Bruno] connected
            ! sonoff.0 2018-03-01 17:42:46.928 warn Client error [Radio_Bruno]: Error: This socket has been ended by the other party
            ! sonoff.0 2018-03-01 17:42:46.927 warn Client error [Radio_Bruno]: Error: This socket has been ended by the other party
            ! sonoff.0 2018-03-01 17:42:46.926 warn Client error [Radio_Bruno]: Error: This socket has been ended by the other party
            ! sonoff.0 2018-03-01 17:42:46.925 warn Client error [Radio_Bruno]: Error: This socket has been ended by the other party
            ! sonoff.0 2018-03-01 17:42:46.922 warn Client error [Radio_Bruno]: Error: This socket has been ended by the other party
            ! sonoff.0 2018-03-01 17:42:46.915 info Client [Radio_Bruno] closed
            ! web.0 2018-03-01 17:39:55.424 info 2018-03-01T16:39:55.424Z Connected system.user.admin
            ! web.0 2018-03-01 17:36:54.499 info 2018-03-01T16:36:54.499Z Connected system.user.admin
            ! sonoff.0 2018-03-01 17:30:02.132 info Client [Terrasse_mitte] connected
            ! sonoff.0 2018-03-01 17:30:02.125 info Client [Musik_Wohnzimmer] connected
            ! sonoff.0 2018-03-01 17:30:02.077 info Client [Radio_Kueche] connected
            ! sonoff.0 2018-03-01 17:30:01.931 info Client [Radio_Bruno] connected
            ! sonoff.0 2018-03-01 17:30:01.919 info Client [Wandlampe_Wohnzimmer] connected
            ! sonoff.0 2018-03-01 17:30:01.814 info Client [Toaster] connected
            ! sonoff.0 2018-03-01 17:30:01.756 info Client [Disco] connected
            ! sonoff.0 2018-03-01 17:30:01.300 info Client [Wandlampe_Kueche] connected
            ! sonoff.0 2018-03-01 17:29:56.008 info Starting MQTT authenticated server on port 1883
            ! sonoff.0 2018-03-01 17:29:55.871 info starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.sonoff, node: v6.11.5
            ! host.raspberrypi 2018-03-01 17:29:52.760 info instance system.adapter.sonoff.0 started with pid 11701
            Hab alle 15 min nen ping auf alle Geräte. Im VIS werden alle Sonoff weiterhin Online angezeigt und sind über das Webif zu erreichen.
            Starte ich den Adapter neu sind alle wieder übern Broker erreichbar.
            Ich bin jetzt auch ratlos. :roll:
            • chucky666
              chucky666 last edited by
              @Balu0127:
              Hat jemand eine Idee was man noch probieren könnte? `
              Hallo
              Ich habe auch alles mögliche probiert , seit ich den Sonoff Adapter einmal in der Stunde Neustarte klappt alles super .
              So fahre ich jetzt schon seit Monaten
              Gesendet von iPad mit Tapatalk Pro
                @chucky666
                Hab ich auch versucht irgendwie mach ich was falsch?
                Kann irgendwie die Minuten nicht weglassen.
                Kannst mir das bitte erklären was du dort eingestellt hast?
                  Es gibt im Netz einige Cron Generator
                  Dieser hier https://www.freeformatter.com/cron-expr … uartz.html gibt für Jede Stunde das aus:
                  0 0 * ? * * *
                  und für jede Stunde startend ab 04:00 Uhr
                  0 0 4/1 ? * * *
                  Generell: Hat jemand einen Git Account? Dann wäre das doch eine Bug-Meldung für den sonoff Adapter wert.
                  Noch ein paar Experimente und Logs einsammeln. Bug: Adapter verbindet sichn nicht wieder selbst, wenn die Verbindung verloren ging. Vorschlag:
                  Bug: Nach einem Verbindungsabbruch bleibt der Adapter empfangsfähig, verliert seine Sendefähigkeit aber dauerhaft.
                  Sobald der Sonoff wieder etwas sendet und der Adapter das empfängt, soll sich der Adapter wieder verbinden und die Sendefähigkeit herstellen.
                    Bin mir jetzt nicht sicher, kann aber sein das Bluefox den Adapter gemacht hat?
                    Man könnte ihn ja auch mal fragen, wenn sich sicher jemand damit auskennt dan Bluefox.
                      gemu last edited by
                      habe magichome tasmota in iobroker sonoff eingebaut. wers testen will einfach die server.js im iobroker sonoff lib Verzeichnis ersetzen und uploaden. Habe selbst nur RGBWW und kann RGB nicht testen, sollte aber auch funktionieren. (Farbtastik und dimmer)
                      Bei RGBWW wird auf Warmweiss geschaltet wenn man Vollweiss also FFFFFF ansteuert.
                      Da die homebridge (Siri) nur mit hue Parametern funktioniert habe ich noch ein Skript zur Konvertierung geschrieben (da muss man die IDs noch anpassen) Skript auch im Anhang.
                      Gruß Gerhard
                      5808_server.js
                      5808_homebridge.js
                        Hallo
                        Wo soll der Ordner genau sein?
                        Kannst bitte ein Foto anhängen?
                        DANKE
                          gemu last edited by
                          @Balu0127:
                          Hallo
                          DANKE `
                          die Datei server.js des sonoff adapters ist in /opt/iobroker/node_modules/iobroker.sonoff/lib
                          danach iobroker upload sonoff und adapter neu starten
                          Das funktioniert aber NUR mit einem TASMOTA Magichome nicht mit dem ungeflashten Original!
                          und der muss auch richtig konfektioniert sein also RRGGBB(WW) für die PWM Ausgänge
                          Bin gerade dabei hier noch einiges mehr einzubauen (neue Version unten)
                          Die hue und Sättigungs Datenpunkte werden jetzt automatisch angelegt, so dass man mit YAHKA direkt die LEDS steuern kann.
                          Die 4 Komponenten Red,Green,Blue,WW werden jetzt auch getrennt angelegt und können einzeln gesteuert werden so dass man auch bis zu 4 weisse Ketten mit einem Controller ansteuern kann.
                          es gibt noch ein paar Probleme weil ich RGBWW UND RGB unterstützen will. RGBWW allein wäre viel einfacher.
                          sollte jetzt weitgehend funktionieren.
                          5808_server.js
                            Ah okay.
                            Dan kann ich nichts damit anfangen, bin auf der suche nach einer Lösung für meinen Sonoff Adapter.
                            Da die Verbindungen zwischen meinen Geräten immer wieder unterbrochen wird.
                            • Schubi
                              Schubi last edited by
                              Ich habe auch lange gkämpft :evil:
                              Nun funktioniert es schon seit 2Monaten stabil!
                              Die genaue Ursache kenne ich auch nicht.
                              Was habe ich gemacht?
                              <list type="decimal">3. WLAN des Asus Router AC87 gegen eine UNIFI AP getauscht
                              1. Powerlineadapter aus dem Netzwerk entfernt
                              2. alle Sonoffs (und auch Wemos D1) mit leerem File überschrieben und neu geflasht
                              3. Ping Adapter installiert und Module anpingen
                              Aus meinen vorangegangenen Versuchen habe ich festgestellt, dass (mit dem AC87) wenn man das Wlan auf legacy umstellt alles prima läuft!
                              Leider kann ich nicht sagen was wirklich den Erfolg gebracht hat - aber es ist zumindest ein Ansatzpunkt für weitere Versuche.
                                Ich hab auch auch einiges versucht zum Schluss hatte ich 3 Wochen Ruhe nach dem ich ein leeres file geflasht habe und dann tasmota.
                                Jetzt seit 3 Tagen aus dem Nichts heraus sind die sonoff wieder auf ner anderen Party. Langsam habe ich keinen Rat mehr. Es macht bei mir auch keinen Unterschied ob ich die dlan_wlan Adapter stecken habe oder nicht.
                                @ schnubi
                                Was bedeutet das wlan auf legacy stellen?
                                  ich hatte auch mal Probleme.
                                  So alle 2 Tage konnte ich mit Alexa dir Lampen nicht mehr erreichen
                                  Seit dem ( ca 1 Monat) keine probleme mehr.
                                  Ich habe an meiner Konfiguration nichts geändert.
                                  Habe auch Sonoffs, die ich nicht extra mit Leerdatei geflasht habe. (würde mich auch wirklich wundern)
                                  Sehr seltsam
                                    @Bluefox
                                    Hab jetzt mal alles upgedatet (Iobroker Admin, Rednode, JS u. Sonoff)
                                    Hab auch Ping und Neustart des Sonoff.0 Adapter, alle Geräte, gelöscht neu geflasht.
                                    Brachte auch keinen Erfolg.
                                    Hab die 5.10,5.11,5.12 von arendst u. reloxx13 Probiert.
                                    Hab immer wieder die Fehler.
                                    sonoff.0	2018-03-06 11:27:04.239	info	Client [Wohnzimmer-Licht] connected
                                    sonoff.0	2018-03-06 11:27:03.816	info	Client [Wohnzimmer-Licht] closed
                                    sonoff.0	2018-03-06 11:27:03.815	error	Closed because of error
                                    sonoff.0	2018-03-06 11:27:03.814	warn	Client error [Wohnzimmer-Licht]: Error: This socket is closed
                                    sonoff.0	2018-03-06 11:27:03.813	warn	Client error [Wohnzimmer-Licht]: Error: read ECONNRESET
                                    sonoff.0	2018-03-06 11:17:14.704	info	Client [Stehlampe] connected
                                    sonoff.0	2018-03-06 10:59:46.114	info	Client [Coutch] closed
                                    sonoff.0	2018-03-06 10:59:46.113	error	Closed because of error
                                    sonoff.0	2018-03-06 10:59:46.112	warn	Client error [Coutch]: Error: This socket is closed
                                    sonoff.0	2018-03-06 10:59:46.111	warn	Client error [Coutch]: Error: read ECONNRESET
                                    sonoff.0	2018-03-06 10:59:33.099	info	Client [Coutch] connected
                                    sonoff.0	2018-03-06 10:55:52.976	info	Client [Nachttischlampe] connected
                                    sonoff.0	2018-03-06 10:48:06.728	info	Client [Nachttischlampe] connected
                                    sonoff.0	2018-03-06 10:12:48.232	info	Client [Stehlampe] connected
                                    sonoff.0	2018-03-06 10:09:46.997	info	Client [Stehlampe] connected
                                    sonoff.0	2018-03-06 08:46:30.615	info	Client [Stehlampe] connected
                                    sonoff.0	2018-03-06 08:05:32.297	info	Client [Coutch] closed
                                    sonoff.0	2018-03-06 08:05:32.297	error	Closed because of error
                                    sonoff.0	2018-03-06 08:05:32.296	warn	Client error [Coutch]: Error: This socket is closed
                                    sonoff.0	2018-03-06 08:05:32.295	warn	Client error [Coutch]: Error: read ECONNRESET
                                    sonoff.0	2018-03-06 08:05:32.191	info	Client [Coutch] connected
                                    sonoff.0	2018-03-06 07:40:35.976	info	Client [Nachttischlampe] closed
                                    sonoff.0	2018-03-06 07:40:35.976	error	Closed because of error
                                    sonoff.0	2018-03-06 07:40:35.974	warn	Client error [Nachttischlampe]: Error: This socket is closed
                                    sonoff.0	2018-03-06 07:40:35.973	warn	Client error [Nachttischlampe]: Error: read ECONNRESET
                                    sonoff.0	2018-03-06 07:40:28.581	info	Client [Nachttischlampe] connected
                                    sonoff.0	2018-03-06 06:43:40.168	info	Client [Vorraum] connected
                                    sonoff.0	2018-03-06 06:29:13.229	info	Client [Coutch] connected
                                    sonoff.0	2018-03-06 06:26:09.417	info	Client [Coutch] closed
                                    sonoff.0	2018-03-06 06:26:09.416	error	Closed because of error
                                    Hab das Gefühl es kann uns nur Bluefox annähernd erklären was da los ist?
                                    Wer kann ihn Kontaktieren?
                                      So jetzt gibt der Sonoff Adapter komplett den geist auf!
                                      ` > sonoff.0 2018-03-07 09:36:24.007 info Client [Coutch] connected
                                      sonoff.0 2018-03-07 09:36:22.856 info Client [Versuch] connected
                                      sonoff.0 2018-03-07 09:36:12.329 info Client [Vorraum] connected
                                      sonoff.0 2018-03-07 09:36:12.025 info Client [Nachttischlampe] connected
                                      sonoff.0 2018-03-07 09:36:11.865 info Client [Jungs] connected
                                      sonoff.0 2018-03-07 09:36:11.828 info Client [Küche-Licht] connected
                                      sonoff.0 2018-03-07 09:36:11.828 info Client [Stehlampe] connected
                                      sonoff.0 2018-03-07 09:36:11.827 info Client [Esstisch] connected
                                      sonoff.0 2018-03-07 09:36:11.749 info Client [Wohnzimmer-Licht] connected
                                      sonoff.0 2018-03-07 09:36:03.423 info Starting MQTT authenticated server on port 1883
                                      sonoff.0 2018-03-07 09:36:03.352 info starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.sonoff, node: v6.13.0
                                      host.ioBroker-Pi 2018-03-07 09:36:01.286 info instance system.adapter.sonoff.0 started with pid 30726
                                      host.ioBroker-Pi 2018-03-07 09:36:00.223 info Restart adapter system.adapter.sonoff.0 because enabled
                                      host.ioBroker-Pi 2018-03-07 09:36:00.223 error instance system.adapter.sonoff.0 terminated with code 156 ()
                                      sonoff.0 2018-03-07 09:36:00.083 info Scheduled restart.
                                      sonoff.0 2018-03-07 09:35:23.697 info Client [Versuch] connected
                                      sonoff.0 2018-03-07 09:35:23.093 info Client [Coutch] connected
                                      sonoff.0 2018-03-07 09:35:12.198 info Client [Vorraum] connected
                                      sonoff.0 2018-03-07 09:35:12.150 info Client [Jungs] connected
                                      sonoff.0 2018-03-07 09:35:12.049 info Client [Nachttischlampe] connected
                                      sonoff.0 2018-03-07 09:35:12.048 info Client [Stehlampe] connected
                                      sonoff.0 2018-03-07 09:35:12.016 info Client [Küche-Licht] connected
                                      sonoff.0 2018-03-07 09:35:12.015 info Client [Esstisch] connected
                                      sonoff.0 2018-03-07 09:35:12.015 info Client [Wohnzimmer-Licht] connected
                                      sonoff.0 2018-03-07 09:35:03.322 info Starting MQTT authenticated server on port 1883
                                      sonoff.0 2018-03-07 09:35:03.268 info starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.sonoff, node: v6.13.0
                                      host.ioBroker-Pi 2018-03-07 09:35:01.198 info instance system.adapter.sonoff.0 started with pid 30680
                                      host.ioBroker-Pi 2018-03-07 09:35:00.170 info Restart adapter system.adapter.sonoff.0 because enabled
                                      host.ioBroker-Pi 2018-03-07 09:35:00.170 error instance system.adapter.sonoff.0 terminated with code 156 () `
                                      Hat jemand eine LÖSUNG für das Problem?
                                        ich vermute hier eher, dass es von einem zyklischen Restart des Adapters kommt.
                                        Ich meine, dass ich das auch bekommen habe, als ich Adapter per Cron restarten wollte.
                                        Schau auch mal hier:
                                        http://forum.iobroker.net/search.php?ke … bmit=Suche
                                        • Schubi
                                          @TimmBo:
                                          Der Legacy modus ist für uralt Geräte gedacht. Er sollte im allgemeinen auch nicht verwendet werden, da sich die Geschwindigkeit erheblich reduziert.
                                          Nicht alle AP´s ermöglichen diese Einstellung!
                                          Ich würde es auch begrüßen, wenn Bluefox mal seine Meinung zu dem Thema abgiebt.
                                            Hallo
                                            Den Code 156 hab ich jetzt wegbekommen, hab den Sonoff Adapter entfernt und wieder hinzugefügt und den Port geändert.
                                            Hab aber trotzdem immer noch die Fehler.
                                            onoff.0	2018-03-07 11:35:53.278	info	Client [Coutch] connected
                                            web.0	2018-03-07 11:34:58.653	info	2018-03-07T10:34:58.652Z Connected system.user.admin
                                            sonoff.0	2018-03-07 11:33:29.199	info	Client [Stehlampe] connected
                                            web.0	2018-03-07 11:31:47.046	info	2018-03-07T10:31:47.046Z Connected system.user.admin
                                            web.0	2018-03-07 11:31:02.717	info	2018-03-07T10:31:02.717Z Connected system.user.admin
                                            web.0	2018-03-07 11:30:14.803	info	2018-03-07T10:30:14.803Z Connected system.user.admin
                                            web.0	2018-03-07 11:29:58.565	info	2018-03-07T10:29:58.564Z Connected system.user.admin
                                            web.0	2018-03-07 11:29:29.789	info	2018-03-07T10:29:29.788Z Connected system.user.admin
                                            web.0	2018-03-07 11:28:14.201	info	2018-03-07T10:28:14.200Z Connected system.user.admin
                                            sonoff.0	2018-03-07 11:11:33.071	info	Client [Nachttischlampe] connected
                                            sonoff.0	2018-03-07 11:11:28.858	info	Client [Coutch] connected
                                            sonoff.0	2018-03-07 11:11:27.326	warn	Client error [Coutch]: Error: This socket has been ended by the other party
                                            sonoff.0	2018-03-07 11:11:27.325	warn	Client error [Coutch]: Error: This socket has been ended by the other party
                                            sonoff.0	2018-03-07 11:11:27.324	warn	Client error [Coutch]: Error: This socket has been ended by the other party
                                            sonoff.0	2018-03-07 11:11:27.323	info	Client [Coutch] closed
                                            sonoff.0	2018-03-07 11:11:21.076	info	Client [Versuch] connected
                                            sonoff.0	2018-03-07 11:11:20.961	info	Client [Wohnzimmer-Licht] connected
                                            sonoff.0	2018-03-07 11:11:20.154	info	Client [Esstisch] connected
                                            sonoff.0	2018-03-07 11:11:18.911	warn	Client error [Esstisch]: Error: This socket has been ended by the other party
                                            sonoff.0	2018-03-07 11:11:18.910	warn	Client error [Esstisch]: Error: This socket has been ended by the other party
                                            sonoff.0	2018-03-07 11:11:18.909	warn	Client error [Esstisch]: Error: This socket has been ended by the other party
                                            sonoff.0	2018-03-07 11:11:18.908	warn	Client error [Esstisch]: Error: This socket has been ended by the other party
                                            sonoff.0	2018-03-07 11:11:18.907	warn	Client error [Esstisch]: Error: This socket has been ended by the other party
                                            sonoff.0	2018-03-07 11:11:18.906	info	Client [Esstisch] closed
                                            sonoff.0	2018-03-07 11:11:18.110	warn	Client error [Versuch]: Error: This socket has been ended by the other party
                                            sonoff.0	2018-03-07 11:11:18.109	warn	Client error [Versuch]: Error: This socket has been ended by the other party
                                            sonoff.0	2018-03-07 11:11:18.108	warn	Client error [Versuch]: Error: This socket has been ended by the other party
                                            sonoff.0	2018-03-07 11:11:18.107	warn	Client error [Versuch]: Error: This socket has been ended by the other party
                                            sonoff.0	2018-03-07 11:11:18.106	info	Client [Versuch] closed
                                            sonoff.0	2018-03-07 11:11:18.044	warn	Client error [Wohnzimmer-Licht]: Error: This socket has been ended by the other party
                                            sonoff.0	2018-03-07 11:11:18.043	warn	Client error [Wohnzimmer-Licht]: Error: This socket has been ended by the other party
                                            sonoff.0	2018-03-07 11:11:18.042	warn	Client error [Wohnzimmer-Licht]: Error: This socket has been ended by the other party
                                            sonoff.0	2018-03-07 11:11:18.041	warn	Client error [Wohnzimmer-Licht]: Error: This socket has been ended by the other party
                                            sonoff.0	2018-03-07 11:11:18.039	info	Client [Wohnzimmer-Licht] closed
                                            sonoff.0	2018-03-07 11:10:43.660	info	Client [Stehlampe] connected
                                            Hab auch eine Pn an Bluefox geschrieben.
                                            Gibt es solche Probleme in der Pro auch?
                                            Bin am überlegen bei der nächsten Aktion auch die Pro zu kaufen?
                                            720
                                            204097
