    4. [Adapter] Sonoff- Tasmota
      Balu0127 last edited by
      @Bluefox
      Hab jetzt mal alles upgedatet (Iobroker Admin, Rednode, JS u. Sonoff)
      Hab auch Ping und Neustart des Sonoff.0 Adapter, alle Geräte, gelöscht neu geflasht.
      Brachte auch keinen Erfolg.
      Hab die 5.10,5.11,5.12 von arendst u. reloxx13 Probiert.
      Hab immer wieder die Fehler.
      sonoff.0	2018-03-06 11:27:04.239	info	Client [Wohnzimmer-Licht] connected
      sonoff.0	2018-03-06 11:27:03.816	info	Client [Wohnzimmer-Licht] closed
      sonoff.0	2018-03-06 11:27:03.815	error	Closed because of error
      sonoff.0	2018-03-06 11:27:03.814	warn	Client error [Wohnzimmer-Licht]: Error: This socket is closed
      sonoff.0	2018-03-06 11:27:03.813	warn	Client error [Wohnzimmer-Licht]: Error: read ECONNRESET
      sonoff.0	2018-03-06 11:17:14.704	info	Client [Stehlampe] connected
      sonoff.0	2018-03-06 10:59:46.114	info	Client [Coutch] closed
      sonoff.0	2018-03-06 10:59:46.113	error	Closed because of error
      sonoff.0	2018-03-06 10:59:46.112	warn	Client error [Coutch]: Error: This socket is closed
      sonoff.0	2018-03-06 10:59:46.111	warn	Client error [Coutch]: Error: read ECONNRESET
      sonoff.0	2018-03-06 10:59:33.099	info	Client [Coutch] connected
      sonoff.0	2018-03-06 10:55:52.976	info	Client [Nachttischlampe] connected
      sonoff.0	2018-03-06 10:48:06.728	info	Client [Nachttischlampe] connected
      sonoff.0	2018-03-06 10:12:48.232	info	Client [Stehlampe] connected
      sonoff.0	2018-03-06 10:09:46.997	info	Client [Stehlampe] connected
      sonoff.0	2018-03-06 08:46:30.615	info	Client [Stehlampe] connected
      sonoff.0	2018-03-06 08:05:32.297	info	Client [Coutch] closed
      sonoff.0	2018-03-06 08:05:32.297	error	Closed because of error
      sonoff.0	2018-03-06 08:05:32.296	warn	Client error [Coutch]: Error: This socket is closed
      sonoff.0	2018-03-06 08:05:32.295	warn	Client error [Coutch]: Error: read ECONNRESET
      sonoff.0	2018-03-06 08:05:32.191	info	Client [Coutch] connected
      sonoff.0	2018-03-06 07:40:35.976	info	Client [Nachttischlampe] closed
      sonoff.0	2018-03-06 07:40:35.976	error	Closed because of error
      sonoff.0	2018-03-06 07:40:35.974	warn	Client error [Nachttischlampe]: Error: This socket is closed
      sonoff.0	2018-03-06 07:40:35.973	warn	Client error [Nachttischlampe]: Error: read ECONNRESET
      sonoff.0	2018-03-06 07:40:28.581	info	Client [Nachttischlampe] connected
      sonoff.0	2018-03-06 06:43:40.168	info	Client [Vorraum] connected
      sonoff.0	2018-03-06 06:29:13.229	info	Client [Coutch] connected
      sonoff.0	2018-03-06 06:26:09.417	info	Client [Coutch] closed
      sonoff.0	2018-03-06 06:26:09.416	error	Closed because of error
      Hab das Gefühl es kann uns nur Bluefox annähernd erklären was da los ist?
      Wer kann ihn Kontaktieren?
        So jetzt gibt der Sonoff Adapter komplett den geist auf!
        ` > sonoff.0 2018-03-07 09:36:24.007 info Client [Coutch] connected
        sonoff.0 2018-03-07 09:36:22.856 info Client [Versuch] connected
        sonoff.0 2018-03-07 09:36:12.329 info Client [Vorraum] connected
        sonoff.0 2018-03-07 09:36:12.025 info Client [Nachttischlampe] connected
        sonoff.0 2018-03-07 09:36:11.865 info Client [Jungs] connected
        sonoff.0 2018-03-07 09:36:11.828 info Client [Küche-Licht] connected
        sonoff.0 2018-03-07 09:36:11.828 info Client [Stehlampe] connected
        sonoff.0 2018-03-07 09:36:11.827 info Client [Esstisch] connected
        sonoff.0 2018-03-07 09:36:11.749 info Client [Wohnzimmer-Licht] connected
        sonoff.0 2018-03-07 09:36:03.423 info Starting MQTT authenticated server on port 1883
        sonoff.0 2018-03-07 09:36:03.352 info starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.sonoff, node: v6.13.0
        host.ioBroker-Pi 2018-03-07 09:36:01.286 info instance system.adapter.sonoff.0 started with pid 30726
        host.ioBroker-Pi 2018-03-07 09:36:00.223 info Restart adapter system.adapter.sonoff.0 because enabled
        host.ioBroker-Pi 2018-03-07 09:36:00.223 error instance system.adapter.sonoff.0 terminated with code 156 ()
        sonoff.0 2018-03-07 09:36:00.083 info Scheduled restart.
        sonoff.0 2018-03-07 09:35:23.697 info Client [Versuch] connected
        sonoff.0 2018-03-07 09:35:23.093 info Client [Coutch] connected
        sonoff.0 2018-03-07 09:35:12.198 info Client [Vorraum] connected
        sonoff.0 2018-03-07 09:35:12.150 info Client [Jungs] connected
        sonoff.0 2018-03-07 09:35:12.049 info Client [Nachttischlampe] connected
        sonoff.0 2018-03-07 09:35:12.048 info Client [Stehlampe] connected
        sonoff.0 2018-03-07 09:35:12.016 info Client [Küche-Licht] connected
        sonoff.0 2018-03-07 09:35:12.015 info Client [Esstisch] connected
        sonoff.0 2018-03-07 09:35:12.015 info Client [Wohnzimmer-Licht] connected
        sonoff.0 2018-03-07 09:35:03.322 info Starting MQTT authenticated server on port 1883
        sonoff.0 2018-03-07 09:35:03.268 info starting. Version 1.0.2 in /opt/iobroker/node_modules/iobroker.sonoff, node: v6.13.0
        host.ioBroker-Pi 2018-03-07 09:35:01.198 info instance system.adapter.sonoff.0 started with pid 30680
        host.ioBroker-Pi 2018-03-07 09:35:00.170 info Restart adapter system.adapter.sonoff.0 because enabled
        host.ioBroker-Pi 2018-03-07 09:35:00.170 error instance system.adapter.sonoff.0 terminated with code 156 () `
        Hat jemand eine LÖSUNG für das Problem?
          Arnulf last edited by
          ich vermute hier eher, dass es von einem zyklischen Restart des Adapters kommt.
          Ich meine, dass ich das auch bekommen habe, als ich Adapter per Cron restarten wollte.
          Schau auch mal hier:
          http://forum.iobroker.net/search.php?ke … bmit=Suche
          • Schubi
            Schubi last edited by
            @TimmBo:
            Der Legacy modus ist für uralt Geräte gedacht. Er sollte im allgemeinen auch nicht verwendet werden, da sich die Geschwindigkeit erheblich reduziert.
            Nicht alle AP´s ermöglichen diese Einstellung!
            Ich würde es auch begrüßen, wenn Bluefox mal seine Meinung zu dem Thema abgiebt.
              Hallo
              Den Code 156 hab ich jetzt wegbekommen, hab den Sonoff Adapter entfernt und wieder hinzugefügt und den Port geändert.
              Hab aber trotzdem immer noch die Fehler.
              onoff.0	2018-03-07 11:35:53.278	info	Client [Coutch] connected
              web.0	2018-03-07 11:34:58.653	info	2018-03-07T10:34:58.652Z Connected system.user.admin
              sonoff.0	2018-03-07 11:33:29.199	info	Client [Stehlampe] connected
              web.0	2018-03-07 11:31:47.046	info	2018-03-07T10:31:47.046Z Connected system.user.admin
              web.0	2018-03-07 11:31:02.717	info	2018-03-07T10:31:02.717Z Connected system.user.admin
              web.0	2018-03-07 11:30:14.803	info	2018-03-07T10:30:14.803Z Connected system.user.admin
              web.0	2018-03-07 11:29:58.565	info	2018-03-07T10:29:58.564Z Connected system.user.admin
              web.0	2018-03-07 11:29:29.789	info	2018-03-07T10:29:29.788Z Connected system.user.admin
              web.0	2018-03-07 11:28:14.201	info	2018-03-07T10:28:14.200Z Connected system.user.admin
              sonoff.0	2018-03-07 11:11:33.071	info	Client [Nachttischlampe] connected
              sonoff.0	2018-03-07 11:11:28.858	info	Client [Coutch] connected
              sonoff.0	2018-03-07 11:11:27.326	warn	Client error [Coutch]: Error: This socket has been ended by the other party
              sonoff.0	2018-03-07 11:11:27.325	warn	Client error [Coutch]: Error: This socket has been ended by the other party
              sonoff.0	2018-03-07 11:11:27.324	warn	Client error [Coutch]: Error: This socket has been ended by the other party
              sonoff.0	2018-03-07 11:11:27.323	info	Client [Coutch] closed
              sonoff.0	2018-03-07 11:11:21.076	info	Client [Versuch] connected
              sonoff.0	2018-03-07 11:11:20.961	info	Client [Wohnzimmer-Licht] connected
              sonoff.0	2018-03-07 11:11:20.154	info	Client [Esstisch] connected
              sonoff.0	2018-03-07 11:11:18.911	warn	Client error [Esstisch]: Error: This socket has been ended by the other party
              sonoff.0	2018-03-07 11:11:18.910	warn	Client error [Esstisch]: Error: This socket has been ended by the other party
              sonoff.0	2018-03-07 11:11:18.909	warn	Client error [Esstisch]: Error: This socket has been ended by the other party
              sonoff.0	2018-03-07 11:11:18.908	warn	Client error [Esstisch]: Error: This socket has been ended by the other party
              sonoff.0	2018-03-07 11:11:18.907	warn	Client error [Esstisch]: Error: This socket has been ended by the other party
              sonoff.0	2018-03-07 11:11:18.906	info	Client [Esstisch] closed
              sonoff.0	2018-03-07 11:11:18.110	warn	Client error [Versuch]: Error: This socket has been ended by the other party
              sonoff.0	2018-03-07 11:11:18.109	warn	Client error [Versuch]: Error: This socket has been ended by the other party
              sonoff.0	2018-03-07 11:11:18.108	warn	Client error [Versuch]: Error: This socket has been ended by the other party
              sonoff.0	2018-03-07 11:11:18.107	warn	Client error [Versuch]: Error: This socket has been ended by the other party
              sonoff.0	2018-03-07 11:11:18.106	info	Client [Versuch] closed
              sonoff.0	2018-03-07 11:11:18.044	warn	Client error [Wohnzimmer-Licht]: Error: This socket has been ended by the other party
              sonoff.0	2018-03-07 11:11:18.043	warn	Client error [Wohnzimmer-Licht]: Error: This socket has been ended by the other party
              sonoff.0	2018-03-07 11:11:18.042	warn	Client error [Wohnzimmer-Licht]: Error: This socket has been ended by the other party
              sonoff.0	2018-03-07 11:11:18.041	warn	Client error [Wohnzimmer-Licht]: Error: This socket has been ended by the other party
              sonoff.0	2018-03-07 11:11:18.039	info	Client [Wohnzimmer-Licht] closed
              sonoff.0	2018-03-07 11:10:43.660	info	Client [Stehlampe] connected
              Hab auch eine Pn an Bluefox geschrieben.
              Gibt es solche Probleme in der Pro auch?
              Bin am überlegen bei der nächsten Aktion auch die Pro zu kaufen?
                Master77 last edited by
                Hallo zusammen
                Ich habe zwar zur Zeit nur zwei Sonoff Basic in Betrieb.
                Diese machen aber keinerlei Probleme.
                Benutze die pro Cloud und es wurde die Tasmota Version 5.11 geflasht.
                Gruß Markus
                • Bluefox
                  Bluefox last edited by
                  @Master77:
                  Hallo zusammen
                  Gruß Markus `
                  Wie seid ihr auf Idee gekommen, dass es mit Cloud was zu tun hat?
                  Gegenseite schließt die Verbindung:
                  Was sagt wireshark?
                    Hi Bluefox
                    Ich wollte damit eigentlich nur die voran gegangene Frage
                    beantworten.
                    Es wurde ja gefragt ob es mit der pro Cloud Probleme gibt.
                    Gruß Markus
                      Hallo Bluefox
                      Was meinst du mit Wireshark?
                      Hab zwar das Programm auf dem PC aber was willst du wissen?
                      Bitte für Anfänger.
                        TimmBo last edited by
                        Bei mir ist grad einer ausgestiegen.
                        Log Sonoff:
                        ! 13:44:48 MQT: tele/sonoff/STATE = {"Time":"2018.03.07 13:44:48","Uptime":"3 00:05:29","Vcc":3.510,"POWER":"OFF","Wifi":{"AP":1,"SSId":"BND_EINSATZ#24","RSSI":62,"APMac":"AC:22:05:54:82:E1"}}
                        ! 13:44:48 MQT: tele/sonoff/SENSOR = {"Time":"2018.03.07 13:44:48","SI7021":{"Temperature":20.1,"Humidity":46.7},"TempUnit":"C"}
                        ! 13:48:42 MQT: Verbindungsversuch…
                        ! 13:48:47 MQT: Verbindung fehlgeschlagen aufgrund von 192.168.0.108:1883, rc -2. Wiederversuch in 10 sek
                        ! 13:48:58 MQT: Verbindungsversuch...
                        ! 13:49:03 MQT: Verbindung fehlgeschlagen aufgrund von 192.168.0.108:1883, rc -2. Wiederversuch in 10 sek
                        ! 13:49:14 MQT: Verbindungsversuch...
                        ! 13:49:19 MQT: Verbindung fehlgeschlagen aufgrund von 192.168.0.108:1883, rc -2. Wiederversuch in 10 sek
                        ! 13:49:30 MQT: Verbindungsversuch...
                        ! 13:49:30 MQT: verbunden
                        ! 13:49:30 MQT: tele/sonoff/LWT = online (beibehalten)
                        ! 13:49:30 MQT: cmnd/sonoff/POWER =
                        ! 13:50:02 MQT: tele/sonoff/STATE = {"Time":"2018.03.07 13:50:02","Uptime":"3 00:10:29","Vcc":3.510,"POWER":"OFF","Wifi":{"AP":1,"SSId":"BND_EINSATZ#24","RSSI":62,"APMac":"AC:22:05:54:82:E1"}}
                        ! 13:50:02 MQT: tele/sonoff/SENSOR = {"Time":"2018.03.07 13:50:02","SI7021":{"Temperature":19.9,"Humidity":47.0},"TempUnit":"C"}
                        Log IO Broker:
                        ! sonoff.0 2018-03-07 13:49:37.517 warn Client error [Disco]: Error: This socket has been ended by the other party
                        ! sonoff.0 2018-03-07 13:49:37.516 warn Client error [Disco]: Error: This socket has been ended by the other party
                        ! sonoff.0 2018-03-07 13:49:37.516 info Client [Disco] closed
                        ! sonoff.0 2018-03-07 13:49:30.891 info Client [Disco] connected
                        ! sonoff.0 2018-03-07 13:49:10.954 info Client [Musik_Wohnzimmer] connected
                        ! sonoff.0 2018-03-07 13:49:10.209 info Client [Musik_Wohnzimmer] closed
                        ! sonoff.0 2018-03-07 13:49:10.209 error Closed because of error
                        ! sonoff.0 2018-03-07 13:49:10.208 warn Client error [Musik_Wohnzimmer]: Error: This socket is closed
                        ! sonoff.0 2018-03-07 13:49:10.207 warn Client error [Musik_Wohnzimmer]: Error: read ECONNRESET
                        Hatte Wireshark laufen aber keinen Plan was ich da raussuchen soll/kann. Habe ich eben das erste mal benutzt muss mich da noch einlesen.
                        Edit:
                        Noch einer
                        Log Sonoff:
                        ! 14:11:16 MQT: Attempting connection…
                        ! 14:11:16 MQT: Connect failed to 192.168.0.108:1883, rc -2. Retry in 10 sec
                        ! 14:11:27 MQT: Attempting connection...
                        ! 14:11:27 MQT: Connected
                        ! 14:11:27 MQT: tele/sonoff/LWT = Online (retained)
                        ! 14:11:32 RSL: cmnd/sonoff/POWER =
                        ! 14:11:58 MQT: Attempting connection...
                        ! 14:12:04 MQT: Connect failed to 192.168.0.108:1883, rc -2. Retry in 10 sec
                        ! 14:12:15 MQT: Attempting connection...
                        ! 14:12:20 MQT: Connected
                        ! 14:12:20 MQT: tele/sonoff/LWT = Online (retained)
                        ! 14:12:20 MQT: cmnd/sonoff/POWER =
                        ! 14:14:49 MQT: tele/sonoff/STATE = {"Time":"2018-03-07T14:14:49","Uptime":"1T19:20:14","Vcc":3.242,"POWER":"OFF","Wifi":{"AP":1,"SSId":"BND_EINSATZ#24","RSSI":100,"APMac":"AC:22:05:54:82:E1"}}
                        ! 14:14:49 MQT: tele/sonoff/SENSOR = {"Time":"2018-03-07T14:14:49","SI7021":{"Temperature":16.8,"Humidity":58.3},"TempUnit":"C"}
                        Log IO Broker
                        ! sonoff.0 2018-03-07 14:12:32.004 warn Client error [Musik_Wohnzimmer]: Error: This socket has been ended by the other party
                        ! sonoff.0 2018-03-07 14:12:32.003 warn Client error [Musik_Wohnzimmer]: Error: This socket has been ended by the other party
                        ! sonoff.0 2018-03-07 14:12:32.002 warn Client error [Musik_Wohnzimmer]: Error: This socket has been ended by the other party
                        ! sonoff.0 2018-03-07 14:12:32.000 warn Client error [Musik_Wohnzimmer]: Error: This socket has been ended by the other party
                        ! sonoff.0 2018-03-07 14:12:31.997 warn Client error [Musik_Wohnzimmer]: Error: This socket has been ended by the other party
                        ! sonoff.0 2018-03-07 14:12:31.989 info Client [Musik_Wohnzimmer] closed
                        ! sonoff.0 2018-03-07 14:12:21.419 info Client [Musik_Wohnzimmer] connected
                        ! host.raspberrypi 2018-03-07 14:12:10.351 info instance system.adapter.weatherunderground.0 terminated with code 0 (OK)
                        Wenn ich "Musik Wohnzimmer" übern Broker ansteuer kommt im Sonoff :
                        ! 14:25:21 MQT: tele/sonoff/STATE = {"Time":"2018-03-07T14:25:21","Uptime":"1T19:30:14","Vcc":3.242,"POWER":"OFF","Wifi":{"AP":1,"SSId":"BND_EINSATZ#24","RSSI":100,"APMac":"AC:22:05:54:82:E1"}}
                        ! 14:25:21 MQT: tele/sonoff/SENSOR = {"Time":"2018-03-07T14:25:21","SI7021":{"Temperature":16.8,"Humidity":58.4},"TempUnit":"C"}
                        ! 14:30:38 MQT: tele/sonoff/STATE = {"Time":"2018-03-07T14:30:38","Uptime":"1T19:35:14","Vcc":3.243,"POWER":"OFF","Wifi":{"AP":1,"SSId":"BND_EINSATZ#24","RSSI":100,"APMac":"AC:22:05:54:82:E1"}}
                        ! 14:30:38 MQT: tele/sonoff/SENSOR = {"Time":"2018-03-07T14:30:38","SI7021":{"Temperature":16.8,"Humidity":58.5},"TempUnit":"C"}
                        im Broker einfach nur :
                        ! sonoff.0 2018-03-07 14:29:55.305 warn Client "Musik_Wohnzimmer" not connected
                          Zur besseren Übersicht habe ich einen neuern Post gemacht.
                          Es ist wieder einer bzw. zwei kurz nacheinander ausgefallen.
                          Log Broker von Adapter neustart bis zum Ausfall:
                          ! x
                          ! host.raspberrypi 2018-03-07 15:15:04.837 info instance system.adapter.dwd.0 terminated with code 0 (OK)
                          ! host.raspberrypi 2018-03-07 15:15:00.051 info instance system.adapter.dwd.0 started with pid 7189
                          ! sonoff.0 2018-03-07 15:13:41.420 warn Client error [Radio_Kueche]: Error: This socket has been ended by the other party
                          ! sonoff.0 2018-03-07 15:13:41.419 warn Client error [Radio_Kueche]: Error: This socket has been ended by the other party
                          ! sonoff.0 2018-03-07 15:13:41.419 info Client [Radio_Kueche] closed
                          ! sonoff.0 2018-03-07 15:13:40.821 warn Client error [Disco]: Error: This socket has been ended by the other party
                          ! sonoff.0 2018-03-07 15:13:40.820 warn Client error [Disco]: Error: This socket has been ended by the other party
                          ! sonoff.0 2018-03-07 15:13:40.819 warn Client error [Disco]: Error: This socket has been ended by the other party
                          ! sonoff.0 2018-03-07 15:13:40.818 info Client [Disco] closed
                          ! sonoff.0 2018-03-07 15:12:36.970 info Client [Disco] connected
                          ! sonoff.0 2018-03-07 15:12:31.739 info Client [Radio_Kueche] connected
                          ! host.raspberrypi 2018-03-07 15:12:09.371 info instance system.adapter.weatherunderground.0 terminated with code 0 (OK)
                          ! host.raspberrypi 2018-03-07 15:12:00.061 info instance system.adapter.weatherunderground.0 started with pid 7021
                          ! host.raspberrypi 2018-03-07 15:10:05.096 info instance system.adapter.dwd.0 terminated with code 0 (OK)
                          ! host.raspberrypi 2018-03-07 15:10:00.075 info instance system.adapter.dwd.0 started with pid 6921
                          ! sonoff.0 2018-03-07 15:09:24.570 info Client [Wandlampe_Kueche] connected
                          ! sonoff.0 2018-03-07 15:09:24.541 info Client [Radio_Bruno] connected
                          ! sonoff.0 2018-03-07 15:09:24.446 info Client [Radio_Kueche] connected
                          ! sonoff.0 2018-03-07 15:09:24.372 info Client [Disco] connected
                          ! sonoff.0 2018-03-07 15:09:24.214 info Client [Musik_Wohnzimmer] connected
                          ! sonoff.0 2018-03-07 15:09:24.106 info Client [Wandlampe_Wohnzimmer] connected
                          ! sonoff.0 2018-03-07 15:09:24.105 info Client [Toaster] connected
                          ! sonoff.0 2018-03-07 15:09:24.015 info Client [Terrasse_mitte] connected
                          ! sonoff.0 2018-03-07 15:09:17.768 info Starting MQTT authenticated server on port 1883
                          ! sonoff.0 2018-03-07 15:09:17.629 info starting. Version 1.0.0 in /opt/iobroker/node_modules/iobroker.sonoff, node: v6.11.5
                          ! host.raspberrypi 2018-03-07 15:09:14.820 info instance system.adapter.sonoff.0 started with pid 6866
                          ! host.raspberrypi 2018-03-07 15:09:12.440 info instance system.adapter.sonoff.0 terminated with code 0 (OK)
                          ! sonoff.0 2018-03-07 15:09:12.373 info Client [Disco] closed
                          ! host.raspberrypi 2018-03-07 15:09:12.282 info stopInstance system.adapter.sonoff.0 killing pid 6856
                          Log Sonoff " Disco" selber Zeitraum
                          ! 15:09:24 MQT: verbunden
                          ! 15:09:24 MQT: tele/sonoff/LWT = online (beibehalten)
                          ! 15:09:24 MQT: cmnd/sonoff/POWER =
                          ! 15:09:55 MQT: Verbindungsversuch…
                          ! 15:10:00 MQT: Verbindung fehlgeschlagen aufgrund von 192.168.0.108:1883, rc -2. Wiederversuch in 10 sek
                          ! 15:10:11 MQT: Verbindungsversuch...
                          ! 15:10:16 MQT: Verbindung fehlgeschlagen aufgrund von 192.168.0.108:1883, rc -2. Wiederversuch in 10 sek
                          ! 15:10:16 RSL: tele/sonoff/STATE = {"Time":"2018.03.07 15:10:16","Uptime":"3 01:30:29","Vcc":3.510,"POWER":"OFF","Wifi":{"AP":1,"SSId":"BND_EINSATZ#24","RSSI":64,"APMac":"AC:22:05:54:82:E1"}}
                          ! 15:10:16 RSL: tele/sonoff/SENSOR = {"Time":"2018.03.07 15:10:16","SI7021":{"Temperature":20.1,"Humidity":48.1},"TempUnit":"C"}
                          ! 15:10:27 MQT: Verbindungsversuch...
                          ! 15:10:32 MQT: Verbindung fehlgeschlagen aufgrund von 192.168.0.108:1883, rc -2. Wiederversuch in 10 sek
                          ! 15:10:43 MQT: Verbindungsversuch...
                          ! 15:10:48 MQT: Verbindung fehlgeschlagen aufgrund von 192.168.0.108:1883, rc -2. Wiederversuch in 10 sek
                          ! 15:10:58 MQT: Verbindungsversuch...
                          ! 15:11:03 MQT: Verbindung fehlgeschlagen aufgrund von 192.168.0.108:1883, rc -2. Wiederversuch in 10 sek
                          ! 15:11:14 MQT: Verbindungsversuch...
                          ! 15:11:19 MQT: Verbindung fehlgeschlagen aufgrund von 192.168.0.108:1883, rc -2. Wiederversuch in 10 sek
                          ! 15:11:30 MQT: Verbindungsversuch...
                          ! 15:11:35 MQT: Verbindung fehlgeschlagen aufgrund von 192.168.0.108:1883, rc -2. Wiederversuch in 10 sek
                          ! 15:11:48 MQT: Verbindungsversuch...
                          ! 15:11:53 MQT: Verbindung fehlgeschlagen aufgrund von 192.168.0.108:1883, rc -2. Wiederversuch in 10 sek
                          ! 15:11:54 DNS: initialisiert
                          ! 15:12:04 MQT: Verbindungsversuch...
                          ! 15:12:09 MQT: Verbindung fehlgeschlagen aufgrund von 192.168.0.108:1883, rc -2. Wiederversuch in 10 sek
                          ! 15:12:20 MQT: Verbindungsversuch...
                          ! 15:12:25 MQT: Verbindung fehlgeschlagen aufgrund von 192.168.0.108:1883, rc -2. Wiederversuch in 10 sek
                          ! 15:12:36 MQT: Verbindungsversuch...
                          ! 15:12:36 MQT: verbunden
                          ! 15:12:36 MQT: tele/sonoff/LWT = online (beibehalten)
                          ! 15:12:36 MQT: cmnd/sonoff/POWER =
                          ! 15:15:55 MQT: tele/sonoff/STATE = {"Time":"2018.03.07 15:15:55","Uptime":"3 01:35:29","Vcc":3.510,"POWER":"OFF","Wifi":{"AP":1,"SSId":"BND_EINSATZ#24","RSSI":64,"APMac":"AC:22:05:54:82:E1"}}
                          ! 15:15:55 MQT: tele/sonoff/SENSOR = {"Time":"2018.03.07 15:15:55","SI7021":{"Temperature":20.1,"Humidity":48.3},"TempUnit":"C"}
                          Log vom anderen:
                          ! 15:12:18 MQT: Connect failed to 192.168.0.108:1883, rc -2. Retry in 10 sec
                          ! 15:12:29 MQT: Attempting connection…
                          ! 15:12:31 MQT: Connected
                          ! 15:12:31 MQT: tele/sonoff/LWT = Online (retained)
                          ! 15:12:31 MQT: cmnd/sonoff/POWER =
                          ! 15:15:25 MQT: tele/sonoff/STATE = {"Time":"2018-03-07T15:15:25","Uptime":"1T22:20:14","Vcc":3.186,"POWER":"ON","Wifi":{"AP":1,"SSId":"BND_EINSATZ#24","RSSI":82,"APMac":"AC:22:05:54:82:E1"}}
                          ! 15:20:25 MQT: tele/sonoff/STATE = {"Time":"2018-03-07T15:20:25","Uptime":"1T22:25:14","Vcc":3.186,"POWER":"ON","Wifi":{"AP":1,"SSId":"BND_EINSATZ#24","RSSI":82,"APMac":"AC:22:05:54:82:E1"}}
                          Wireshark habe ich auch an gehabt.
                          Wie kann nen log hier Posten?
                          Nachtrag : Fast 24 Stunden ohne Ausfall. Hab nix geändert :shock:
                          • Bluefox
                            @TimmBo:
                            ! x
                            Log vom anderen:
                            Nachtrag : Fast 24 Stunden ohne Ausfall. Hab nix geändert :shock: `
                            Ich empfehle dir WiFi Qualität zu prüfen. Liegt oft daran.
                              Bei mir gibt es derzeit ein reproduzierbares Szenario und ich habe in github einen report eingestellt.
                              Bei mir lief alles über Wochen stabil. Dann habe ich einen Sonoff an ein remote location, die über Internet und VPN verbunden ist, verbracht. Hier kommt es durch die tägliche Zwangstrennung ab und an zu Verbindungsabbrüchen, die dann zu dem "connection ended by other party" Fehlerzustand führen. Ich habe die entsprechenden Logs eingesammelt und dukumentiert.
                              Wenn die Verbindung zum Sonoff abbricht und wieder zurückkehrt und dabei der "connection ended by other party" Fehler aufgetreten ist, empfängt der ioBroker-Adapter den sonoff status weiter, sendet aber anscheinend nicht mehr an den Sonoff.
                              Der Sonoff ist weiterhin ueber seine Website ansprechbar, ansteuerbar, auslesbar. Alles ganz normal.
                              Wird dann der Sonoff-adapter im ioBroker neu gestartet, läuft alles wieder, auch das Senden vom ioBroker zum Sonoff.
                              Aus meiner naiven Sicht könnte eine einfache mitigation des Problems so aussehen:
                              Wenn ioBroker Adapter im Fehlermode nach einen "connection ended by other party" Fehler steckt, sollte er versuchen, die Verbindung wieder aufbauen. Spätestens aber wenn er vom Sonoff ein (zyklisch gesendetes) Datum empfängt. Dann hätte man im schlimmsten Fall eine Totzeit in der Größenordnung der zyklischen update rate des Sonoffs, die der user ja im Sonoff einstellen kann.
                                @ Bluefox
                                Habe ich auch immer im Blick. Der eine sonoff "Musik Wohnzimmer" liegt neben dem Router. Habe die wlan Kanäle gewechselt. Ohne eine Änderung.
                                Das Problem das "klassisch" festgestellt hat kann ich bestätigen. Die Sonoff sind nur über den Broker nicht mehr zu erreichen wenn die auf ner anderen Party sind.
                                Übers web interface geht's ohne Probleme. Auch wenn ich die über die IP schalten lasse. Starte ich den Sonoff Adapter neu ohne was am sonoff zu machen ist alles wieder gut.
                                Zur Zeit lasse ich den Adapter 1x in der Stunde neu starten. Ist aber auch keine ideale Lösung da die sonoff teilweise nach 5 min wieder weg sind.
                                Wenn der Adapter sich wieder automatisch mit den Sonoff verbinden könnte wäre das mit Sicherheit eine bessere Lösung.
                                Schönen Samstag Gruß Timm
                                  consul58 last edited by
                                  @Bluefox:
                                  Ich empfehle dir WiFi Qualität zu prüfen. Liegt oft daran. `
                                  Das ist mir zu einfach. Wieso kann der Adapter nicht selbständig auf Erreichbarkeit prüfen und daraus seine Schlüsse ziehen? Oder soll er das schon können, aber es funktioniert nicht?
                                  Btw.: In FHEM laufen die Sonoffs ohne diese Probleme.
                                    @bluefox
                                    Am Wlan kann es auch nicht liegen.
                                    Der Pi hängt bei mir am Kabel.
                                    Wlan Signal meist bei 75 - 100%
                                    Und warum sollten die im Sonweb dan funktionieren?
                                    Hab mal Probiert die Aktualisierung bei Sonweb runter zu setzen auf 2 Sek. hatte dan im Sonweb immer wieder Fehler. Entweder Sonweb ist da noch nicht ausgereift oder die Sonoff können die schnellen Zugriffe nicht Verarbeiten.
                                    Könnte ja auch sein das die Zugriffe bei Iobroker teils zu oft kommen und der Sonoff dan nicht mehr alles abarbeiten kann.
                                    Kann das sein?
                                    • modmax
                                      modmax last edited by
                                      Diese Fehler "Error: This socket has been ended by the other party" hatte ich auch eine zeitlang täglich im ioBroker log,
                                      jedoch seit 2 Wochen nicht mehr.
                                      Die Lösung war aber etwas kompliziert, da ich meine "eigene" Firmware geflasht habe.
                                      1.) Die Sonoffs per FTDI komoplett löschen mit einem leeren 1MB-bin-File.
                                      2.) Die letzte Firmware aus dem Tasmota-Repo geholt (war die 5.12d).
                                      3.) Diese Firmware dann in Atom.io/Platform.io eingebunden und die Datei
                                      user_config.h auf meine Bedürfnisse angepat (insbes. die Webeinstellungen).
                                      USE_DOMOTICZ und USE_HOME_ASSISTANT dabei auch auskommentiert.
                                      MY_LANGUAGE auf de_DE gesetzt, damit alles schön in deutsch daher kommt.
                                      In der IDE kann man nun alles bauen lassen.
                                      Oder eben einzeln per FTDI flashen.
                                      Seitdem hatte ich keinen einzigen dieser Fehler mehr.
                                      Wichtig ist eben nur Tasmota 5.12.d zu verwenden oder aber die 5.11.1,
                                      da es mit der 5.12.0 Probleme damit gibt.
                                      Jedoch kann es dann noch zu Problemen kommen, daß der Sonoff-Adapter irgendwann mal
                                      die Verbindung verliert und dann wieder kein Connect hinbekommt, obwohl der Sonoff selber
                                      noch fleißig schickt.
                                      Im Datenpunkt "sonoff.0.info.connection" kann man auch sehen, welche Sonoffs verbunden sind.
                                      Meist verbinden sich die Sonoffs dann gleich wieder; aber selten eben auch nicht mehr,
                                      obwohl der Sonoff noch funktioniert.
                                      Dafür habe ich dann ein Skript geschrieben, was mir dann einen Neustart ermöglich.
                                      Bei mir sieht das zwar anders aus als üblich, da ich virtuelle Geräte verwenden (Forum-Suche nach virtualDevice),
                                      aber vielleicht hilft das ja etwas.
                                      `// definierte Hosts
                                      var devices = [];
                                      devices.push({hostName: 'sonoff1', virtual: 'virtualDevice.Schalter.Sonoff1'});
                                      ! // bei Änderung an connections auslösen
                                      on('sonoff.0.info.connection', function (obj) {
                                      var connections = obj.state.val;
                                      ! // prüfe ob jedes Gerät noch verbunden ist
                                      for (var i = 0; i < devices.length; i++) {
                                          var hostName  = devices[i].hostName;
                                          var virtual = devices[i].virtual;
                                      ! if (connections.indexOf(hostName) == -1) {
                                      // CASE: Gerät nicht verbunden
                                      ! var delays = getStateDelayed(virtual+'.reconnects');
                                      if ((delays.length === 0) && (getState(virtual+'.reconnects').val === 0)) {
                                      // setze reconnects in 3 Minuten auf 1
                                      setStateDelayed(virtual+'.reconnects', 1, true, 180000);
                                      } else {
                                      // CASE: Gerät verbunden
                                              // lösche laufende schedules und counter
                                              clearStateDelayed(virtual+'.reconnects')
                                              setStateIfChanged(virtual+'.reconnects', 0, true);
                                      ! // bei Skriptstart
                                      var virtualDevice = devices[i].virtual;
                                      log('Create subscription for ' + virtualDevice, 'debug');
                                      ! on({id: 'javascript.'+instance+'.'+virtualDevice+'.reconnects', change: 'gt'}, function (obj) {
                                      var virtual = obj.id.replace('javascript.0.','').replace('.reconnects','');
                                      var reconnects = obj.state.val;
                                          if (reconnects === 4) {
                                              // nach 3 erfolglosen Reconnect-Versuchen Push-Over-Nachrichten versenden
                                              sendTo('pushover', {
                                                  title :  'Sonoff-Neustart erfolglos',
                                                  message: virtual
                                          } else if (reconnects < 4) {
                                              log('Neustart von Sonoff: ' + virtual);
                                              var ip = getState(virtual+'.ipAddress').val;
                                      ! request('http://'+ip+'/cm?cmnd=Restart 1', function(error, response, body) {
                                      if (error || response.statusCode !== 200) {
                                      log('Fehler beim Neustart von Sonoff: ' + virtual + ' (StatusCode = ' + response.statusCode + ')');
                                      // erhöhe reconnects in 3 Minuten um 1
                                      setStateDelayed(virtual+'.reconnects', reconnects+1, true, 180000);
                                      ! Aber im Grunde sehe ich das Problem beim Sonoff-Adaper, da er Meldungen vom Sonoff machmal anscheinend verschluckt.
                                      ! Genauso wie das "alive" auch nicht wirklich funktioniert.[/i][/i][/i]
                                        Vielen Dank für die Impulse zum workaround.
                                        Deine Beobachtungen kann ich nur bestätigen. Und ich teile Deine Meinung, daß das Thema am besten beim Adapter zu beseitigen oder zumindest zu mitigieren ist.
                                        Ist das bei Dir auch so, daß vom "abgehängten" Sonoff weiterhin Botschaften empfangen werden? Spätestens dann könnte man den Adapter neu starten.
                                          Danke für die Tipps.
                                          Drücke dir die Daumen das das Problem lösen konntest.
                                          Nach dem selben Weg bin ich auf vorgegangen. Hatte dann ca 3 Wochen Ruhe und ohne das ich was an den Sonoff geändert habe ging das Problem wieder los.
                                          Werde ma die neuste Firmware Flaschen und die Daumen drücken.
                                          Mfg Timm
                                          • modmax
                                            @klassisch
                                            Bei mir ist das Problem auch so, daß der Sonoff was schickt, aber der Adapter nix verarbeitet.
                                            Der Sonoff erscheint nicht mehr unter "sonoff.0.info.connection".
                                            Und wenn der da nicht mehr drin ist (auch wenn der per Web noch erreichbar ist),
                                            dann meldet der Sonoff-Adapter beim Sendern auch den Fehler, daß der Sonoff nicht verbunden ist.
                                            Wird wohl vor jedem senden geprüft, ob der Sonoff in der connections-Liste drin ist; anstatt auf
                                            das ALIVE des Sonoff zu setzen oder dergleichen.
                                            Mein Skript habe ich eben noch mal umgeschrieben, so daß es von jedem verwendet werden kann.
                                            Es erzeugt dann ein paar neue States im Javascript-Adapter und darüber funzt dann der Neustart.
                                            Einzugtragen sind nur alle Geräte, die man im Sonoff-Adapter hat; könnte man sicherlich auch eleganter lösen,
                                            so daß man nicht alle Sonoffs eintragen muß, aber da es bei mir anderes benutzt wird, sollte das reichen.
                                            Hab das Skript nun aber nicht ausführlich getestet, sondern lediglich umgeschrieben
                                            und geprüft, damit es lauffähig ist.
                                            `// definierte devices
                                            var devices = [];
                                            devices.push('sonoff_1');
                                            var deviceName = devices[i];
                                            ! if (connections.indexOf(deviceName) == -1) {
                                            ! var delays = getStateDelayed('sonoff.reconnects.'+deviceName);
                                            if ((delays.length === 0) && (getState('sonoff.reconnects.'+deviceName).val === 0)) {
                                            // setze reconnects in 3 Minuten auf 1, wenn keine Delay läuft und reconnects=0 ist
                                            setStateDelayed('sonoff.reconnects.'+deviceName, 1, true, 180000);
                                            } else {
                                                    clearStateDelayed('sonoff.reconnects.'+deviceName);
                                                    setState('sonoff.reconnects.'+deviceName, 0, true);
                                            log('Create subscription for ' + deviceName, 'debug');
                                            createState('sonoff.reconnects.'+deviceName, 0, {type: 'number', read: true, write: false, role: 'value', name: deviceName});
                                            ! on({id: 'javascript.0.sonoff.reconnects.'+deviceName, change: 'gt'}, function (obj) {
                                            var sonoffDevice = obj.id.replace('javascript.0.sonoff.reconnects.','');
                                                    // nach 3 erfolglosen Reconnect-Versuchen Push-Over-Nachricht versenden
                                                        message: virtual
                                                    log('Neustart von Sonoff: ' + sonoffDevice);
                                                    var ip = getState('sonoff.0.'+sonoffDevice+'.INFO.IPAddress').val;
                                            log('Fehler beim Neustart von Sonoff: ' + sonoffDevice + ' (StatusCode = ' + response.statusCode + ')');
                                            setStateDelayed('sonoff.reconnects.'+sonoffDevice, reconnects+1, true, 180000);
                                            }` [/i][/i]
                                            720
                                            204118
