    4. Xiaomi Yeelight Smart LED (DE)
      e-p-s last edited by
      Yeah. Nachher mal testen. DANKE.
      Achso habt ihr eine Idee wie man einen Reset Schutz machen kann?
      Ich hab schön die Lampen programmiert, was machen meine 3 jährigen Zwillinge? Einer links im zimmer, der andere gegenüber an dem anderen Schalter?
      Licht an, Licht aus. Licht an, Licht aus…... oh wie schön bunt die blinken :lol: :x
        Chris76 last edited by
        Wird bei mir leider nicht grün. Wenn ich was tun kann, sag bescheid.
        yeelight.0	2018-03-02 18:32:38.777	info	terminating
        yeelight.0	2018-03-02 18:32:38.272	error	at process._tickCallback (node.js:428:17)
        yeelight.0	2018-03-02 18:32:38.272	error	at nextTickCallbackWith3Args (node.js:522:9)
        yeelight.0	2018-03-02 18:32:38.272	error	at dgram.js:221:7
        yeelight.0	2018-03-02 18:32:38.272	error	at startListening (dgram.js:121:10)
        yeelight.0	2018-03-02 18:32:38.272	error	at Socket.emit (events.js:166:7)
        yeelight.0	2018-03-02 18:32:38.272	error	at emitNone (events.js:67:13)
        yeelight.0	2018-03-02 18:32:38.272	error	at Socket.g (events.js:260:16)
        yeelight.0	2018-03-02 18:32:38.272	error	at Socket. (/opt/iobroker/node_modules/iobroker.yeelight/lib/yeelight.js:112:10)
        yeelight.0	2018-03-02 18:32:38.272	error	at Socket.send (dgram.js:300:11)
        yeelight.0	2018-03-02 18:32:38.272	error	RangeError: Offset + length beyond buffer length
        yeelight.0	2018-03-02 18:32:38.270	error	uncaught exception: Offset + length beyond buffer length
        yeelight.0	2018-03-02 18:32:38.246	info	starting. Version 0.0.1 in /opt/iobroker/node_modules/iobroker.yeelight, node: v4.8.7
        yeelight.0	2018-03-02 18:32:29.040	info	terminating
        yeelight.0	2018-03-02 18:32:28.532	error	at process._tickCallback (node.js:428:17)
        yeelight.0	2018-03-02 18:32:28.532	error	at nextTickCallbackWith3Args (node.js:522:9)
        yeelight.0	2018-03-02 18:32:28.532	error	at dgram.js:221:7
        yeelight.0	2018-03-02 18:32:28.532	error	at startListening (dgram.js:121:10)
        yeelight.0	2018-03-02 18:32:28.532	error	at Socket.emit (events.js:166:7)
        yeelight.0	2018-03-02 18:32:28.532	error	at emitNone (events.js:67:13)
        yeelight.0	2018-03-02 18:32:28.532	error	at Socket.g (events.js:260:16)
        yeelight.0	2018-03-02 18:32:28.532	error	at Socket. (/opt/iobroker/node_modules/iobroker.yeelight/lib/yeelight.js:112:10)
        yeelight.0	2018-03-02 18:32:28.532	error	at Socket.send (dgram.js:300:11)
        yeelight.0	2018-03-02 18:32:28.532	error	RangeError: Offset + length beyond buffer length
        yeelight.0	2018-03-02 18:32:28.530	error	uncaught exception: Offset + length beyond buffer length
        yeelight.0	2018-03-02 18:32:28.522	info	starting. Version 0.0.1 in /opt/iobroker/node_modules/iobroker.yeelight, node: v4.8.7
        yeelight.0	2018-03-02 18:32:22.489	info	terminating
        yeelight.0	2018-03-02 18:32:21.984	error	at process._tickCallback (node.js:428:17)
        yeelight.0	2018-03-02 18:32:21.984	error	at nextTickCallbackWith3Args (node.js:522:9)
        yeelight.0	2018-03-02 18:32:21.984	error	at dgram.js:221:7
        yeelight.0	2018-03-02 18:32:21.984	error	at startListening (dgram.js:121:10)
        yeelight.0	2018-03-02 18:32:21.984	error	at Socket.emit (events.js:166:7)
        yeelight.0	2018-03-02 18:32:21.984	error	at emitNone (events.js:67:13)
        yeelight.0	2018-03-02 18:32:21.984	error	at Socket.g (events.js:260:16)
        yeelight.0	2018-03-02 18:32:21.984	error	at Socket. (/opt/iobroker/node_modules/iobroker.yeelight/lib/yeelight.js:112:10)
        yeelight.0	2018-03-02 18:32:21.984	error	at Socket.send (dgram.js:300:11)
        yeelight.0	2018-03-02 18:32:21.984	error	RangeError: Offset + length beyond buffer length
        yeelight.0	2018-03-02 18:32:21.982	error	uncaught exception: Offset + length beyond buffer length
        yeelight.0	2018-03-02 18:32:21.974	info	starting. Version 0.0.1 in /opt/iobroker/node_modules/iobroker.yeelight, node: v4.8.7
        • Meistertr
          Hast du das Script an? Wenn es läuft, ist der Port belegt…
          Gesendet von meinem Handy
            Nein ich habe das Script nicht installiert gehabt.
            • Alex1808
              Alex1808 last edited by
              @Chris76:
              Nein ich habe das Script nicht installiert gehabt. `
              Ich habe node 6 und es funktioniert. Bei dir im Log node: v4.8.7… kann eventuell daran liegen
              • Alex1808
                @Buhu91:
                Ich wollte den Adapter ausprobieren, jedoch hab ich Probleme den Adapter von Git zu Installieren.
                Meldung am Ende:
                Failed to execute '/usr/bin/nodejs /opt/iobroker/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build –fallback-to-build --module=/opt/iobroker/node_modules/usb/src/binding/usb_bindings.node --module_name=usb_bindings --module_path=/opt/iobroker/node_modules/usb/src/binding' (1)
                iobroker.core@0.1.0 /opt/iobroker└── iobroker.yeelight@0.0.1
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/iobroker.radar/node_modules/noble/node_modules/xpc-connection):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/noble/node_modules/xpc-connection):
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: usb@1.3.1 (node_modules/usb):
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: usb@1.3.1 install: node-pre-gyp install --fallback-to-build
                npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                process exited with code 0
                Hab ich die Falsche URL oder was läuft da falsch? `
                node-gyp fehlt? und im zweitem block geht über iobroker.radar)
                • Alex1808
                  @Alex1808:
                  @Buhu91:
                  ! Meldung am Ende:
                  ! Failed to execute '/usr/bin/nodejs /opt/iobroker/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build –fallback-to-build --module=/opt/iobroker/node_modules/usb/src/binding/usb_bindings.node --module_name=usb_bindings --module_path=/opt/iobroker/node_modules/usb/src/binding' (1)
                  ! iobroker.core@0.1.0 /opt/iobroker└── iobroker.yeelight@0.0.1
                  ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/iobroker.radar/node_modules/noble/node_modules/xpc-connection):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                  ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/noble/node_modules/xpc-connection):
                  ! npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                  ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: usb@1.3.1 (node_modules/usb):
                  ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: usb@1.3.1 install: node-pre-gyp install --fallback-to-build
                  ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                  ! process exited with code 0
                  ! Hab ich die Falsche URL oder was läuft da falsch? `
                  node-gyp fehlt? und im zweitem block geht über iobroker.radar) `
                  • Alex1808
                    @Buhu91:
                    ! Meldung am Ende:
                    • Meistertr
                      @Chris76:
                      kannst du mal diese Version ausprobieren, damit sollte es eigentlich klappen:
                      https://github.com/MeisterTR/ioBroker.yeelight
                      mfg tobi
                        MrFiii last edited by
                        @Meistertr:
                        @Chris76:
                        mfg tobi
                        Hallo Tobi,
                        danke für den Adapter, leider klappt bei mir so rein gar nichts.
                        Installieren sieht schon sehr seltsam aus:
                        EDIT: Sorry, ich habe gar nicht geblickt, dass das Teil die Birne automatisch in die Objekte hämmert…Passt alles. Vielen Dank!
                        2018-03-08 16:47:49.517 - info: iobroker url "https://github.com/MeisterTR/ioBroker.yeelight"
                        2018-03-08 16:47:50.786 - info: iobroker install https://github.com/MeisterTR/ioBroker.yeelight/tarball/master
                        2018-03-08 16:47:51.355 - info: iobroker npm install https://github.com/MeisterTR/ioBroker.yeelight/tarball/master --production --prefix "/opt/iobroker" (System call)
                        2018-03-08 16:48:29.000 - info: iobroker ../authenticate_pam.cc:30:31: fatal error: security/pam_appl.h: Datei oder Verzeichnis nicht gefunden #include
                        2018-03-08 16:48:29.002 - info: iobroker compilation terminated.
                        2018-03-08 16:48:29.026 - info: iobroker make: *** [Release/obj.target/authenticate_pam/authenticate_pam.o] Fehler 1
                        2018-03-08 16:48:29.042 - info: iobroker gyp
                        2018-03-08 16:48:29.046 - info: iobroker ERR! build error
                        2018-03-08 16:48:29.056 - info: iobroker gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
                        gyp ERR! stack at emitTwo (events.js:106:13)
                        gyp ERR! stack at ChildProcess.emit (events.js:191:7)
                        gyp ERR! stack
                        2018-03-08 16:48:29.060 - info: iobroker at Process.ChildProcess._handle.onexit (internal/child_process.js:219:12)gyp ERR! System Linux 4.9.59-v7+
                        gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                        gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pam
                        gyp ERR! node -v v6.13.0
                        gyp ERR! node-gyp -v v3.4.0
                        gyp ERR! not ok
                        2018-03-08 16:48:34.459 - info: iobroker npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 (node_modules/authenticate-pam):
                        2018-03-08 16:48:34.461 - info: iobroker npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 install: `node-gyp rebuild`npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                        2018-03-08 16:48:34.552 - info: iobroker exit 0
                        2018-03-08 16:48:34.974 - info: host.ioBroker-Pi Update repository "default" under "http://download.iobroker.net/sources-dist.json"
                        Der Adapter ist dann zwar drin, aber bringt mir nur eine Fehlermeldung "Please implement save function in your admin/index.html"
                        Die Bilder findest du im Anhang. Bin ich zu doof? 🙂
                        • cvidal
                          Ich bekomme die selbe Fehlermeldung wie MrFiii.
                          Das Log hilft auch nicht weiter.
                          yeelight.0	2018-03-08 20:30:45.154	info	terminating
                          yeelight.0	2018-03-08 20:30:43.172	info	starting. Version 0.0.2 in /opt/iobroker/node_modules/iobroker.yeelight, node: v6.12.3
                          yeelight.0	2018-03-08 20:30:40.303	info	terminating
                          Jemand eine Idee?
                          Gruß Christian
                          • Meistertr
                            @cvidal:
                            Jemand eine Idee?
                            Gruß Christian `
                            Das ist keine Fehlermeldung, sondern nur ein info popup, welches nun auch schon wieder weg sein sollte, die Indexseite war noch nciht ganz auf admin3 eingestellt. wenn du den Adapter aus und an machst, sollte mehr im log stehen. so kann man da nicht viel mit anfangen. Wichtig ist, wenn man das Script genutzt hat, dass man es ausstellt und ggf. den javascript adapter neu startet, damit die Leitung nicht belegt ist 🙂
                              Vielen Dank Tobi!
                              Die Meldung ist bei mir zwar nicht weg, aber ich habe trotzdem alles hinbekommen, da der Adapter ja direkt ein Objekt meiner Lampe erzeugt hat.
                              Hat schon jemand Erfahrung mit der Einbindung in yahka?
                              Die Lampe bekomme ich rein, An und Aus geht, dimmen geht, Farben einstellen kann ich allerdings nicht. Hat jemand eine Konfiguration dafür?
                              Ich bekomme es leider nicht hin und muss immer auf die Yeelight App ausweichen.
                              Edit: Sehe gerade, dass es neue Commits gibt. Werde das später ausprobieren.
                                Stoni last edited by
                                Also ich habe den Adapter auch mal installiert. Er leuchtet auch grün. Aber es wird unter den Objekten nichts erstellt. Ich habe die Yeelight bislang über ifttt eingebunden, liegt es vielleicht daran? Hatte mal irgendwo etwas gelesen, dass es nicht geht, wenn der Port bereits belegt ist. Jemand einen Tipp für mich?
                                Gruß Stoni
                                • nick21
                                  nick21 last edited by
                                  Hat sich jemand mit den Bluetooth Geräten von Yeelight beschäftigt? Habe noch eine alte Bedside lamp und eine Candela.
                                    rh1212 last edited by
                                    Hallo Leute,
                                    Ich habe heute die Adapter probiert. Ich habe zwei Mi Bedside Lamp und 2 Yeelight RGBW, die Bedside Lampen wurden erkannt aber die RGBW nicht. Hat jemand eine Idee?
                                    VG,
                                    RH
                                      root_ last edited by
                                      meine RGBW werden auch nicht gefunden. Der telnet port ist doch 55443 oder?
                                        @root_:
                                        meine RGBW werden auch nicht gefunden. Der telnet port ist doch 55443 oder? `
                                        Glaub ich…
                                        Hat jemand Yeelight RGBW lampen die mit der Adapter funktionieren?
                                        • Z
                                          zwickolino last edited by
                                          Hab den Adapter heute installiert.
                                          Objekte (2 yeelight rgbw) sind sofort erkannt worden.
                                          Perfekt! Danke dafür…die Bash-Geschichte war mir zu kompliziert...
                                          An/Aus und dimmen nutze ich über den yahka Adapter für homekit. Läuft...
                                          Leider bekomme ich den farbwechsel/Farbton noch nicht hin, da muss ich nochmal schauen wo es da klemmt.
                                          Grüße Sven
                                            @zwickolino:
                                            Grüße Sven `
                                            Hmm bei mir nur die 2 Bedside Lampen wurden erakannt, die RGBW nicht, keine Ahnung wo das Problem ist.
                                            Hat jemand mehr als 2 Yeelight Lampen, die erkannt sind?
                                            277
                                            85471
