KNX Adapter überholt
Hab jetzt auch meine RAW Daten:
{ "from": "system.adapter.knx.0", "ts": 1519831742540, "common": { "name": "Licht KNX Küche", "type": "boolean", "role": "switch", "min": 0, "max": 1, "read": false, "write": true }, "native": { "dpt": "DPT1.001", "address": "0/2/5", "addressRefId": "P-0B72-0_GA-9", "statusGARefId": "P-0B72-0_GA-99", "actGARefId": "" }, "acl": { "object": 1636, "owner": "system.user.admin", "ownerGroup": "system.group.administrator", "state": 1636 }, "_id": "knx.0.Beleuchtung.Licht_KNX.Licht_KNX_Küche", "type": "state" }
Bin vom 0.8.6 wieder auf den 1.0.4, leider geht da wieder nix
knx.0 2018-03-01 18:26:21.643 error at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15) knx.0 2018-03-01 18:26:21.643 error at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:228:12) knx.0 2018-03-01 18:26:21.643 error at Socket.onevent (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:270:10) knx.0 2018-03-01 18:26:21.643 error at Socket.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20) knx.0 2018-03-01 18:26:21.643 error at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:48:30) knx.0 2018-03-01 18:26:21.643 error at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3190:37) knx.0 2018-03-01 18:26:21.643 error at Object.stateChange (/opt/iobroker/node_modules/iobroker.knx/knx.js:81:1853) knx.0 2018-03-01 18:26:21.643 error at _0x1fafce.(anonymous function).(anonymous function) [as write] (/opt/iobroker/node_modules/iobroker.knx/knx.js:43:701) knx.0 2018-03-01 18:26:21.643 error at _0x2b2e0e.(anonymous function) [as groupValueWrite] (/opt/iobroker/node_modules/iobroker.knx/knx.js:17:32171) knx.0 2018-03-01 18:26:21.643 error at Object.decodeVal (/opt/iobroker/node_modules/iobroker.knx/knx.js:31:27069) knx.0 2018-03-01 18:26:21.643 error Error: unkown Inputvalue! knx.0 2018-03-01 18:26:21.639 error message knx.0.Beleuchtung.Licht_KNX.Licht_KNX_Küche [object Object] unkown Inputvalue!
Ich geh wieder zurück auf 0.8.6 und hoffe, es geht dann wieder alles
Hallo!
Ich muss leider auch sagen: Die 1.x Versionen des Adapters sind nicht wirklich der Burner.
Die Notwendigkeit einer Lizenz ist dazu gekommen, die KNX-Funktionalität mit meinem Router (Enertex) ist allerdings weg….
Das Adapter meldet zwar wunderbar er wäre verbunden und würde GA's senden, er tut es aber einfach nicht, d.h. auf dem Bus kommt nix an.
Lesen hingegen funktioniert, und bei neustart des Adapters werden auch die Werte aller GA's abgefragt, danach aber ist das Schreiben auf den Bus reine Glückssache - ich würde meinen so in 2% der Fälle funktioniert es auch.
Wo ist denn der Slider geblieben mit dem man am Timing drehen konnte - vieleicht ist da was im Argen .....
Hat sowas noch jemand?
Ich habe leider ein komisches Problem mit dem neuen Adapter. Mit 0.8.6 lief bei mir alles hervorragend. Seit dem Upgrade auf 1.0.5 kann ich nur noch Rolladen steuern. Normales Licht An- und Ausschalten funktioniert nicht mehr. Lizenzkey ist eingetragen und wird auch als OK angezeigt. Nachdem ALexa nicht reagiert hat, habe ich direkt über die Objektsicht gesteuert. Hier bekomme ich im Log einen Fehler. Sagt Euch das was? Ich nutze ein MDT IP-Gateway und sonst eigtl auch alles von MDT mit ETS5.
Bin etwas ratlos ob ich einfach auf 0.8.6 bleiben soll, oder was ich tun muss, um die 1.0.5 zu,m laufen zu bringen.
Viele Grüße,
Fabian
5728_fehler_2.jpg -
Hab jetzt mal den 1.0.5er installiert, aber besser geworden ist es nicht
(Tags für Code lasse ich wegen den Forensoftwareproblemen mal weg)
knx.0 2018-03-03 15:02:08.292 error at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
knx.0 2018-03-03 15:02:08.292 error at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:228:12)
knx.0 2018-03-03 15:02:08.292 error at Socket.onevent (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:270:10)
knx.0 2018-03-03 15:02:08.292 error at Socket.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
knx.0 2018-03-03 15:02:08.292 error at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:48:30)
knx.0 2018-03-03 15:02:08.292 error at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3190:37)
knx.0 2018-03-03 15:02:08.292 error at Object.stateChange (/opt/iobroker/node_modules/iobroker.knx/knx.js:81:1860)
knx.0 2018-03-03 15:02:08.292 error at _0x5b50ba.(anonymous function).write (/opt/iobroker/node_modules/iobroker.knx/knx.js:43:749)
knx.0 2018-03-03 15:02:08.292 error at _0x5ee457.(anonymous function) [as groupValueWrite] (/opt/iobroker/node_modules/iobroker.knx/knx.js:17:32480)
knx.0 2018-03-03 15:02:08.292 error at Object.decodeVal (/opt/iobroker/node_modules/iobroker.knx/knx.js:31:27239)
knx.0 2018-03-03 15:02:08.292 error Error: unkown Inputvalue!
knx.0 2018-03-03 15:02:08.241 error message knx.0.Beleuchtung.Licht_KNX.Licht_KNX_Küche [object Object] unkown Inputvalue!
@Chefkoch: Wenn Du heute was testen willst: Ich schicke Dir meine Nummer nochmal per PN und lasse die Version mal bis 17 Uhr drauf. Wenn ich bis dahin nichts hre geh ich wieder auf 0.8.6 zurück
Bin jetzt auf die 0.8.6 zurück und jetzt findet Alexa keine Geräte mehr
Wie kann man nochmal prüfen, ob er die eigentlich finden müsste? In den Smartgeräten vom Cloud Adapter sind sie nicht sichtbar.
Langsam verzweifel ich etwas mit dem KNX Adapter
Wenn ich in den Objekten direkt ein Gerät schalte geht es, also scheint der KNX Adpater als solches zumindest richtig zu gehen
EDIT: Manuell kann ich die im Cloud Adapter hinzufügen. Wurden die früher nicht automatisch angelegt?
Hallo @all,
vielen Dank für euer testen und die gelieferten Fehlermeldungen. Suspekter Weise läuft genau diese Version in meinem Testaufbau. Deshalb hatte ich sie auch freigegeben. Nichts desto trotz läuft sie bei euch eben nicht.
Ich arbeite mit Hochdruck daran. Bis dahin bitte und hoffe ich auf ein wenig Geduld. Solange ich das Problem nicht gefunden habe, bleibt die 0.8.6 die "Last-stable".
VG
chefkoch009
Vielen Dank für deine Mühe und genutzte Freizeit.
Hallo chefkoch009, leider kann ich Dir keine PN schicken. Ich war hier im Forum leider noch zu wenig aktiv ;). Gerne würd ich Dir aber bei der Fehlersuche (https://github.com/ioBroker/ioBroker.knx/issues/19) helfen.
Hallo BigS,
ich schau mir Dein Projekt mal an und melde mich dann wieder. BTW….was hast Du für ein KNX/LAN GW?
VG
chefkoch009
Super, vielen Dank. Ich nutze ein MDT IP Interface. Grundsätzlich werden die Telegramme vom Bus empfangen. Da hab ich keine Probleme feststellen können.
Kurze Zwischeninfo: Das Update auf die 1.0.6 und die ganzen anderen Updates (Admin, js-controller) haben keine Änderung gebracht. Ich kann leider nach wie vor kein Projekt importieren. Daher ist für mich gerade ioBroker nicht nutzbar :(.
Kleine Korrektur ;): Ich hab wieder die Version 0.8.6 installiert, dann mein KNX-Projekt (erstellt mit ETS 5.6.4) importiert. Dabei gab es zwar ein paar Fehler im Log, aber es wurden schön brav die Objekte angelegt. Anschließend hat sich aber der KNX-Adapter verabschiedet und konnte auch nicht mehr gestartet werden. Dann habe ich ein Update von 0.8.6 auf die 1.0.6 gemacht. Das verlief auch problemlos und ich bin jetzt glücklich ;). Jetzt sind meine Objekte sauber drin und der Adapter funktioniert. Ich hoffe jetzt nur, dass ich nicht demnächst wieder das Projekt importieren muss.
Wenn ich Dir aber helfen kann, dann sag mir bescheid. Ich teste gerne für Dich.
Hallo @all,
hat schon jemand V1.0.6 getestet? Habe bis jetzt noch kein feedback erhalten.
VG
chefkoch009
Nachdem ich jetzt seit gestern wieder meine Objekte drin habe, habe ich natürlich versucht wieder alles an meine neue Struktur anzupassen. Leider habe ich jetzt auch mit der Adapter-Version 1.0.6 festgestellt, dass ich nicht kontinuierlich Werte empfangen und senden kann. Anfangs dachte ich es läge an meine Konfiguration, jetzt bin ich mir aber sicher, dass es an der Verbindung zu meinem MDT IP Gateway liegt. Das ganze hab ich mit einem TCPDUMP nachvollzogen. In den ersten paar Sekunden, an denen der Adapter läuft, sammelt er schön die Werte ein. Danach passiert nichts mehr. Es werden keine Pakete an das IP Gateway geschickt. Im Log selbst ist natürlich auch nichts los.
Mein TCPDUMP bringt mir übrigens recht häufig folgende Meldung:
15:03:57.187119 IP 192.168.1.68 > 192.168.1.240: ICMP 192.168.1.68 udp port 37395 unreachable, length 59 15:03:57.187346 IP 192.168.1.240.3671 > 192.168.1.68.44594: UDP, length 23 15:03:57.187973 IP 192.168.1.68.44594 > 192.168.1.240.3671: UDP, length 10 15:03:58.122023 IP 192.168.1.240.3671 > 192.168.1.68.37395: UDP, length 23 15:03:58.122047 IP 192.168.1.68 > 192.168.1.240: ICMP 192.168.1.68 udp port 37395 unreachable, length 59 15:04:00.184817 IP 192.168.1.240.3671 > 192.168.1.68.44594: UDP, length 23
192.168.1.68 = ioBroker
192.168.1.240 = IP Interface
Wird vom ioBroker ein ICMP-Ping an das Interface geschickt? Wenn ja, wann und warum?
An sich ist das IP Interface immer per Ping erreichbar, ohne Ausfälle. FHEM, was bei mir noch paralell läuft, hat mit KNXD keinerlei Verbindungsprobleme. Solche Probleme hatte ich mit der 0.8.6 Version nicht.
****Edit:
Ach… die Pings kommen bestimmt vom Ping-Adapter ;)****
So richtig läuft die 1.0.6er leider immer noch nicht.
Ich konnte zwar einmal ein Licht einschalten, aber nicht wieder aus.
Würde sagen, da werden auch zu wenig GAs angelegt.
Start sieht so aus:
hue.0 2018-03-13 16:48:15.909 info final lightState for Voelker_Home.All:{"bri":0,"on":false,"level":0} hue.0 2018-03-13 16:48:15.891 info final lightState for Voelker_Home.All:{"bri":0,"on":false,"level":0} knx.0 2018-03-13 16:48:15.705 info update of actGARefId on RESPONSE : P-0B72-0_GA-6 of knx.0.Beleuchtung.Licht_KNX.Licht_KNX_Lilly to 0 knx.0 2018-03-13 16:48:15.672 info update of actGARefId on RESPONSE : P-0B72-0_GA-8 of knx.0.Beleuchtung.Licht_KNX.Licht_KNX_Bad to 0 knx.0 2018-03-13 16:48:15.595 info update of actGARefId on RESPONSE : P-0B72-0_GA-10 of knx.0.Beleuchtung.Licht_KNX.Licht_KNX_Bad_Spiegel to 0 knx.0 2018-03-13 16:48:15.545 info update of actGARefId on RESPONSE : P-0B72-0_GA-30 of knx.0.Beleuchtung.Licht_Hue.LichtHue_Flur_EG to 1 knx.0 2018-03-13 16:48:15.256 info update of actGARefId on RESPONSE : P-0B72-0_GA-22 of knx.0.Rolladen.Rolladen_lang.Rolladen_Esszimmer to 0 knx.0 2018-03-13 16:48:15.212 info update of actGARefId on RESPONSE : P-0B72-0_GA-24 of knx.0.Rolladen.Rolladen_lang.Rolladen_Küche_Tür to 0 knx.0 2018-03-13 16:48:15.171 info update of actGARefId on RESPONSE : P-0B72-0_GA-26 of knx.0.Rolladen.Rolladen_lang.Rolladen_Marleen to 0 knx.0 2018-03-13 16:48:15.106 info update of actGARefId on RESPONSE : P-0B72-0_GA-28 of knx.0.Rolladen.Rolladen_lang.Rolladen_Lilly to 0 knx.0 2018-03-13 16:48:12.755 info DPP erstellt für : 0/2/1 Licht KNX WCmit DPT1.001 knx.0 2018-03-13 16:48:12.755 info DPP erstellt für : 0/2/2 Licht KNX Lillymit DPT1.001 knx.0 2018-03-13 16:48:12.755 info DPP erstellt für : 0/2/3 Licht KNX Marleenmit DPT1.001 knx.0 2018-03-13 16:48:12.755 info DPP erstellt für : 0/2/4 Licht KNX Badmit DPT1.001 knx.0 2018-03-13 16:48:12.755 info DPP erstellt für : 0/2/5 Licht KNX Küchemit DPT1.001 knx.0 2018-03-13 16:48:12.754 info DPP erstellt für : 0/2/6 Licht KNX Bad Spiegelmit DPT1.001 knx.0 2018-03-13 16:48:12.754 info DPP erstellt für : 0/2/7 Licht KNX Küchenzeilemit DPT1.001 knx.0 2018-03-13 16:48:12.753 info DPP erstellt für : 0/3/1 LichtHue Flur EGmit DPT1.001 knx.0 2018-03-13 16:48:12.753 info DPP erstellt für : 0/3/2 LichtHue Flur OGmit DPT1.001 knx.0 2018-03-13 16:48:12.753 info DPP erstellt für : 0/3/4 LichtHue Wohnzimmermit DPT1.001 knx.0 2018-03-13 16:48:12.752 info DPP erstellt für : 0/3/6 LichtHue Esszimmermit DPT1.001 knx.0 2018-03-13 16:48:12.752 info DPP erstellt für : 0/3/7 LichtHue Elternmit DPT1.001 knx.0 2018-03-13 16:48:12.751 info DPP erstellt für : 0/3/8 LichtHue Dekolampemit DPT1.001 knx.0 2018-03-13 16:48:12.751 info DPP erstellt für : 0/3/10 Hue Szene Wohnzimmerlichtmit DPT1.001 knx.0 2018-03-13 16:48:12.750 info DPP erstellt für : 0/3/11 Hue Szene Fernsehlichtmit DPT1.001 knx.0 2018-03-13 16:48:12.750 info DPP erstellt für : 1/1/1 Rolladen Wohnzimmermit DPT1.008 knx.0 2018-03-13 16:48:12.749 info DPP erstellt für : 1/1/2 Rolladen Esszimmermit DPT1.008 knx.0 2018-03-13 16:48:12.749 info DPP erstellt für : 1/1/3 Rolladen Küchemit DPT1.008 knx.0 2018-03-13 16:48:12.748 info DPP erstellt für : 1/1/4 Rolladen Küche Türmit DPT1.008 knx.0 2018-03-13 16:48:12.748 info DPP erstellt für : 1/1/5 Rolladen Badmit DPT1.008 knx.0 2018-03-13 16:48:12.747 info DPP erstellt für : 1/1/6 Rolladen Marleenmit DPT1.008 knx.0 2018-03-13 16:48:12.747 info DPP erstellt für : 1/1/7 Rolladen Elternmit DPT1.008 knx.0 2018-03-13 16:48:12.747 info DPP erstellt für : 1/1/8 Rolladen Lillymit DPT1.008 knx.0 2018-03-13 16:48:12.746 info DPP erstellt für : 1/1/9 Rolladen Lilly Türmit DPT1.008 knx.0 2018-03-13 16:48:12.746 info DPP erstellt für : 1/1/20 Rolladen zentralmit DPT1.008 knx.0 2018-03-13 16:48:12.745 info DPP erstellt für : 1/1/10 Rolladen Treppenhausmit DPT1.008 knx.0 2018-03-13 16:48:12.745 info DPP erstellt für : 3/1/2 Tag-Nachtmit DPT1.002 knx.0 2018-03-13 16:48:12.616 info /opt/iobroker/node_modules/iobroker.js-controller knx.0 2018-03-13 16:48:12.616 info Connecting to knx GW: 192.168.0.112:3671 with phy. Adr: 15.15.242 knx.0 2018-03-13 16:48:12.612 info knx license is OK. knx.0 2018-03-13 16:48:12.183 info starting. Version 1.0.6 in /opt/iobroker/node_modules/iobroker.knx, node: v6.13.0
Er wirft auch Fehler:
knx.0 2018-03-13 16:50:51.293 error at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15) knx.0 2018-03-13 16:50:51.293 error at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:228:12) knx.0 2018-03-13 16:50:51.293 error at Socket.onevent (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:270:10) knx.0 2018-03-13 16:50:51.293 error at Socket.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20) knx.0 2018-03-13 16:50:51.293 error at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:48:30) knx.0 2018-03-13 16:50:51.293 error at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3420:37) knx.0 2018-03-13 16:50:51.293 error at Object.stateChange (/opt/iobroker/node_modules/iobroker.knx/knx.js:81:1902) knx.0 2018-03-13 16:50:51.293 error at _0x2ee508.(anonymous function).(anonymous function) [as write] (/opt/iobroker/node_modules/iobroker.knx/knx.js:43:822) knx.0 2018-03-13 16:50:51.293 error at _0x5c6f3a.(anonymous function) [as groupValueWrite] (/opt/iobroker/node_modules/iobroker.knx/knx.js:17:37502) knx.0 2018-03-13 16:50:51.293 error at _0x5c6f3a.emit (events.js:163:17) knx.0 2018-03-13 16:50:51.293 error Error: Uncaught, unspecified "error" event. (no connection to KNX Bus) knx.0 2018-03-13 16:50:51.286 error message knx.0.Beleuchtung.Licht_KNX.Licht_KNX_Küche [object Object] Uncaught, unspecified "error" event. (no connection to KNX Bus) knx.0 2018-03-13 16:50:47.954 error at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15) knx.0 2018-03-13 16:50:47.954 error at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:228:12) knx.0 2018-03-13 16:50:47.954 error at Socket.onevent (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:270:10) knx.0 2018-03-13 16:50:47.954 error at Socket.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20) knx.0 2018-03-13 16:50:47.954 error at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:48:30) knx.0 2018-03-13 16:50:47.954 error at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3420:37) knx.0 2018-03-13 16:50:47.954 error at Object.stateChange (/opt/iobroker/node_modules/iobroker.knx/knx.js:81:1902) knx.0 2018-03-13 16:50:47.954 error at _0x2ee508.(anonymous function).(anonymous function) [as write] (/opt/iobroker/node_modules/iobroker.knx/knx.js:43:822) knx.0 2018-03-13 16:50:47.954 error at _0x5c6f3a.(anonymous function) [as groupValueWrite] (/opt/iobroker/node_modules/iobroker.knx/knx.js:17:37502) knx.0 2018-03-13 16:50:47.954 error at _0x5c6f3a.emit (events.js:163:17) knx.0 2018-03-13 16:50:47.954 error Error: Uncaught, unspecified "error" event. (no connection to KNX Bus) knx.0 2018-03-13 16:50:47.919 error message knx.0.Beleuchtung.Licht_KNX.Licht_KNX_Küche [object Object] Uncaught, unspecified "error" event. (no connection to KNX Bus)
Dein Lan-GW schreibt an den ioBroker auf Port 44954 in (1) und in (2) antwortet der ioBroker über diesen Port auf die 3671 des KNX/LAN GW. Soweit alles OK.
In (3) möchte dein LAN GW aber auf Port 37395 an den iobroker schreiben. Dieser Port ist aber nicht offen. Das sagt er aber auch in (4) und versucht es schliesslich wieder auf der 44594 in (5).
15:03:57.187119 IP 192.168.1.68 > 192.168.1.240: ICMP 192.168.1.68 udp port 37395 unreachable, length 59 1) 15:03:57.187346 IP 192.168.1.240.3671 > 192.168.1.68.>>>44594<<<: UDP, length 23 2) 15:03:57.187973 IP 192.168.1.68.>>>44594<<< > 192.168.1.240.3671: UDP, length 10 3) 15:03:58.122023 IP 192.168.1.240.3671 > 192.168.1.68.>>>37395<<<: UDP, length 23 4) 15:03:58.122047 IP 192.168.1.68 > 192.168.1.240: ICMP 192.168.1.68 udp port 37395 unreachable, length 59 5) 15:04:00.184817 IP 192.168.1.240.3671 > 192.168.1.68>>>44594<<<: UDP, length 23
Das nur kurz zur Info…läuft vielleicht noch etwas anderes im Hintergrund? Hattest Du vorher einen Verbindungsabbruch?
VG
chefkoch009
Hallo!
Hat sowas noch jemand? `
ich hab das gleiche Problem mit dem Enertex Router.
Hast du das Problem geloest?
Gruss
Stefan
Ich habe gerade auch mal die aktuelle Version getestet, aber hiermit bekomme ich gar keine Verbindung mehr hin.
Bin deswegen auch zurück auf 0.86
Unter Log wird mir auch angezeigt:
host.ioBroker-RasPi 2018-03-20 08:25:28.474 error startInstance knx.0: cannot find start file
Nachtrag:
Habe jetzt noch mal alles runtergeschmissen und neu installiert und jetzt hab ich eine Verbindung, aber es werden beim einlesen bzw. starten des Adapters immer ungewollte Schalthandlungen ausgeführt (div. Lampen gehen an, Jalousien fahren runter usw.)
VG
chefkoch009 `
Hallo Chefkoch009,
sorry das ich mich erst jetzt melde. Bezogen auf meinen TCPDUMP muss ich Dir leider widersprechen.
1. Die gesamte Kommunikation zwischen ioBroker und dem LAN-GW erfolgt über UDP. UDP hat keine Fehlererkennung wie TCP. Somit werden die Datenpakete einfach nur vom Absender an den Empfänger geschickt, es findet keine Fehlerkorrektur statt. Also kann auch keiner der Beteiligten feststellen, dass ein Port nicht offen ist und selbstständig entscheiden, dass er einen anderen verwendet.
2. Die Zeile 4 zeigt ein ICMP paket (z. B. Ping). Diese Zeile kommt zwar von meinem ioBroker und geht an mein LAN-GW, hat aber nichts mit der eigentlichen Kommunikation zwischen den beiden zu tun. Das war ein reines Ping, verursacht durch den Discovery oder Ping Adapter in meiner ioBroker konfiguration.
Deshalb hatte ich ja meinen Beitrag editiert und relativiert ;).
Ok, aber nun zu meinen Beobachtungen mit der Version 1.0.6 und 1.0.7:
Leider ist es mir nach wie vor nicht möglich, mein KNX-Projekt hochzuladen. Es kommt leider immer noch der folgende Fehler:
2018-03-21 22:22:02.401 - error: knx.0 message messagebox.system.adapter.knx.0 [object Object] Cannot read property 'nodeType' of undefined 2018-03-21 22:22:02.403 - error: knx.0 TypeError: Cannot read property 'nodeType' of undefined at /opt/iobroker/node_modules/iobroker.knx/knx.js:87:2147 at _0x11a5b1 (/opt/iobroker/node_modules/iobroker.knx/knx.js:87:464) at /opt/iobroker/node_modules/iobroker.knx/knx.js:87:210 at null.matches (/opt/iobroker/node_modules/iobroker.knx/knx.js:87:1793) at Function._0x152e3f.(anonymous function) [as applyStep] (/opt/iobroker/node_modules/iobroker.knx/knx.js:87:59528) at /opt/iobroker/node_modules/iobroker.knx/knx.js:87:59937 at /opt/iobroker/node_modules/iobroker.knx/knx.js:87:1102 at /opt/iobroker/node_modules/iobroker.knx/knx.js:87:668 at _0x11a5b1 (/opt/iobroker/node_modules/iobroker.knx/knx.js:87:464) at /opt/iobroker/node_modules/iobroker.knx/knx.js:87:1041
Zusätzlich habe ich ähnliche Erfahrungen wie Merlin123 gemacht. Wenn ich den KNX-Adapter neustarte, kann ich eine gewisse Zeit z. B. eine Lampe steuern. Allerdings oft mit aussetztern. Auch konnte ich feststellen, dass ich z. B. meine Rolläden immer steuern kann. Dann kann ich feststellen, das meine MDT Wetterstation fast dauerhaft die Temperatur übertragen kann. Irgedwann aber, kommt wieder ein disconnect und es werden weder Daten empfangen, noch Telegramme an den Bus gesendet. Dann geht einfach wieder gar nichts mehr.
Ich hoffe ich konnte Dir etwas helfen.
Ich hatte gleiche Symptome wie ihr. Nach einer Weile kein Senden und Empfangen mehr. Bin dann auf einen NUC mit mehr RAM umgestiegen. Vorher hatte ich einen Rasperry. Seit dem hatte ich keinen Fehler mehr mit Verbindungsabbrüchen. Was nutzt ihr für eine Hardware?
