    4. Xiaomi Yeelight Smart LED (DE)
    • Meistertr
      @Chris76:
      Wird bei mir leider nicht grün. Wenn ich was tun kann, sag bescheid.
      yeelight.0	2018-03-02 18:32:38.777	info	terminating
      yeelight.0	2018-03-02 18:32:38.272	error	at process._tickCallback (node.js:428:17)
      yeelight.0	2018-03-02 18:32:38.272	error	at nextTickCallbackWith3Args (node.js:522:9)
      yeelight.0	2018-03-02 18:32:38.272	error	at dgram.js:221:7
      yeelight.0	2018-03-02 18:32:38.272	error	at startListening (dgram.js:121:10)
      yeelight.0	2018-03-02 18:32:38.272	error	at Socket.emit (events.js:166:7)
      yeelight.0	2018-03-02 18:32:38.272	error	at emitNone (events.js:67:13)
      yeelight.0	2018-03-02 18:32:38.272	error	at Socket.g (events.js:260:16)
      yeelight.0	2018-03-02 18:32:38.272	error	at Socket. (/opt/iobroker/node_modules/iobroker.yeelight/lib/yeelight.js:112:10)
      yeelight.0	2018-03-02 18:32:38.272	error	at Socket.send (dgram.js:300:11)
      yeelight.0	2018-03-02 18:32:38.272	error	RangeError: Offset + length beyond buffer length
      yeelight.0	2018-03-02 18:32:38.270	error	uncaught exception: Offset + length beyond buffer length
      yeelight.0	2018-03-02 18:32:38.246	info	starting. Version 0.0.1 in /opt/iobroker/node_modules/iobroker.yeelight, node: v4.8.7
      yeelight.0	2018-03-02 18:32:29.040	info	terminating
      yeelight.0	2018-03-02 18:32:28.532	error	at process._tickCallback (node.js:428:17)
      yeelight.0	2018-03-02 18:32:28.532	error	at nextTickCallbackWith3Args (node.js:522:9)
      yeelight.0	2018-03-02 18:32:28.532	error	at dgram.js:221:7
      yeelight.0	2018-03-02 18:32:28.532	error	at startListening (dgram.js:121:10)
      yeelight.0	2018-03-02 18:32:28.532	error	at Socket.emit (events.js:166:7)
      yeelight.0	2018-03-02 18:32:28.532	error	at emitNone (events.js:67:13)
      yeelight.0	2018-03-02 18:32:28.532	error	at Socket.g (events.js:260:16)
      yeelight.0	2018-03-02 18:32:28.532	error	at Socket. (/opt/iobroker/node_modules/iobroker.yeelight/lib/yeelight.js:112:10)
      yeelight.0	2018-03-02 18:32:28.532	error	at Socket.send (dgram.js:300:11)
      yeelight.0	2018-03-02 18:32:28.532	error	RangeError: Offset + length beyond buffer length
      yeelight.0	2018-03-02 18:32:28.530	error	uncaught exception: Offset + length beyond buffer length
      yeelight.0	2018-03-02 18:32:28.522	info	starting. Version 0.0.1 in /opt/iobroker/node_modules/iobroker.yeelight, node: v4.8.7
      yeelight.0	2018-03-02 18:32:22.489	info	terminating
      yeelight.0	2018-03-02 18:32:21.984	error	at process._tickCallback (node.js:428:17)
      yeelight.0	2018-03-02 18:32:21.984	error	at nextTickCallbackWith3Args (node.js:522:9)
      yeelight.0	2018-03-02 18:32:21.984	error	at dgram.js:221:7
      yeelight.0	2018-03-02 18:32:21.984	error	at startListening (dgram.js:121:10)
      yeelight.0	2018-03-02 18:32:21.984	error	at Socket.emit (events.js:166:7)
      yeelight.0	2018-03-02 18:32:21.984	error	at emitNone (events.js:67:13)
      yeelight.0	2018-03-02 18:32:21.984	error	at Socket.g (events.js:260:16)
      yeelight.0	2018-03-02 18:32:21.984	error	at Socket. (/opt/iobroker/node_modules/iobroker.yeelight/lib/yeelight.js:112:10)
      yeelight.0	2018-03-02 18:32:21.984	error	at Socket.send (dgram.js:300:11)
      yeelight.0	2018-03-02 18:32:21.984	error	RangeError: Offset + length beyond buffer length
      yeelight.0	2018-03-02 18:32:21.982	error	uncaught exception: Offset + length beyond buffer length
      yeelight.0	2018-03-02 18:32:21.974	info	starting. Version 0.0.1 in /opt/iobroker/node_modules/iobroker.yeelight, node: v4.8.7
      kannst du mal diese Version ausprobieren, damit sollte es eigentlich klappen:
      https://github.com/MeisterTR/ioBroker.yeelight
      mfg tobi
        MrFiii last edited by
        @Meistertr:
        @Chris76:
        mfg tobi
        Hallo Tobi,
        danke für den Adapter, leider klappt bei mir so rein gar nichts.
        Installieren sieht schon sehr seltsam aus:
        EDIT: Sorry, ich habe gar nicht geblickt, dass das Teil die Birne automatisch in die Objekte hämmert…Passt alles. Vielen Dank!
        2018-03-08 16:47:49.517 - info: iobroker url "https://github.com/MeisterTR/ioBroker.yeelight"
        2018-03-08 16:47:50.786 - info: iobroker install https://github.com/MeisterTR/ioBroker.yeelight/tarball/master
        2018-03-08 16:47:51.355 - info: iobroker npm install https://github.com/MeisterTR/ioBroker.yeelight/tarball/master --production --prefix "/opt/iobroker" (System call)
        2018-03-08 16:48:29.000 - info: iobroker ../authenticate_pam.cc:30:31: fatal error: security/pam_appl.h: Datei oder Verzeichnis nicht gefunden #include
        2018-03-08 16:48:29.002 - info: iobroker compilation terminated.
        2018-03-08 16:48:29.026 - info: iobroker make: *** [Release/obj.target/authenticate_pam/authenticate_pam.o] Fehler 1
        2018-03-08 16:48:29.042 - info: iobroker gyp
        2018-03-08 16:48:29.046 - info: iobroker ERR! build error
        2018-03-08 16:48:29.056 - info: iobroker gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
        gyp ERR! stack at emitTwo (events.js:106:13)
        gyp ERR! stack at ChildProcess.emit (events.js:191:7)
        gyp ERR! stack
        2018-03-08 16:48:29.060 - info: iobroker at Process.ChildProcess._handle.onexit (internal/child_process.js:219:12)gyp ERR! System Linux 4.9.59-v7+
        gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
        gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pam
        gyp ERR! node -v v6.13.0
        gyp ERR! node-gyp -v v3.4.0
        gyp ERR! not ok
        2018-03-08 16:48:34.459 - info: iobroker npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 (node_modules/authenticate-pam):
        2018-03-08 16:48:34.461 - info: iobroker npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 install: `node-gyp rebuild`npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
        2018-03-08 16:48:34.552 - info: iobroker exit 0
        2018-03-08 16:48:34.974 - info: host.ioBroker-Pi Update repository "default" under "http://download.iobroker.net/sources-dist.json"
        Der Adapter ist dann zwar drin, aber bringt mir nur eine Fehlermeldung "Please implement save function in your admin/index.html"
        Die Bilder findest du im Anhang. Bin ich zu doof? 🙂
        • cvidal
          Ich bekomme die selbe Fehlermeldung wie MrFiii.
          Das Log hilft auch nicht weiter.
          yeelight.0	2018-03-08 20:30:45.154	info	terminating
          yeelight.0	2018-03-08 20:30:43.172	info	starting. Version 0.0.2 in /opt/iobroker/node_modules/iobroker.yeelight, node: v6.12.3
          yeelight.0	2018-03-08 20:30:40.303	info	terminating
          Jemand eine Idee?
          Gruß Christian
          • Meistertr
            @cvidal:
            Jemand eine Idee?
            Gruß Christian `
            Das ist keine Fehlermeldung, sondern nur ein info popup, welches nun auch schon wieder weg sein sollte, die Indexseite war noch nciht ganz auf admin3 eingestellt. wenn du den Adapter aus und an machst, sollte mehr im log stehen. so kann man da nicht viel mit anfangen. Wichtig ist, wenn man das Script genutzt hat, dass man es ausstellt und ggf. den javascript adapter neu startet, damit die Leitung nicht belegt ist 🙂
              Vielen Dank Tobi!
              Die Meldung ist bei mir zwar nicht weg, aber ich habe trotzdem alles hinbekommen, da der Adapter ja direkt ein Objekt meiner Lampe erzeugt hat.
              Hat schon jemand Erfahrung mit der Einbindung in yahka?
              Die Lampe bekomme ich rein, An und Aus geht, dimmen geht, Farben einstellen kann ich allerdings nicht. Hat jemand eine Konfiguration dafür?
              Ich bekomme es leider nicht hin und muss immer auf die Yeelight App ausweichen.
              Edit: Sehe gerade, dass es neue Commits gibt. Werde das später ausprobieren.
                Stoni last edited by
                Also ich habe den Adapter auch mal installiert. Er leuchtet auch grün. Aber es wird unter den Objekten nichts erstellt. Ich habe die Yeelight bislang über ifttt eingebunden, liegt es vielleicht daran? Hatte mal irgendwo etwas gelesen, dass es nicht geht, wenn der Port bereits belegt ist. Jemand einen Tipp für mich?
                Gruß Stoni
                • nick21
                  nick21 last edited by
                  Hat sich jemand mit den Bluetooth Geräten von Yeelight beschäftigt? Habe noch eine alte Bedside lamp und eine Candela.
                    rh1212 last edited by
                    Hallo Leute,
                    Ich habe heute die Adapter probiert. Ich habe zwei Mi Bedside Lamp und 2 Yeelight RGBW, die Bedside Lampen wurden erkannt aber die RGBW nicht. Hat jemand eine Idee?
                    VG,
                    RH
                      root_ last edited by
                      meine RGBW werden auch nicht gefunden. Der telnet port ist doch 55443 oder?
                        @root_:
                        meine RGBW werden auch nicht gefunden. Der telnet port ist doch 55443 oder? `
                        Glaub ich…
                        Hat jemand Yeelight RGBW lampen die mit der Adapter funktionieren?
                        • Z
                          zwickolino last edited by
                          Hab den Adapter heute installiert.
                          Objekte (2 yeelight rgbw) sind sofort erkannt worden.
                          Perfekt! Danke dafür…die Bash-Geschichte war mir zu kompliziert...
                          An/Aus und dimmen nutze ich über den yahka Adapter für homekit. Läuft...
                          Leider bekomme ich den farbwechsel/Farbton noch nicht hin, da muss ich nochmal schauen wo es da klemmt.
                          Grüße Sven
                            @zwickolino:
                            Grüße Sven `
                            Hmm bei mir nur die 2 Bedside Lampen wurden erakannt, die RGBW nicht, keine Ahnung wo das Problem ist.
                            Hat jemand mehr als 2 Yeelight Lampen, die erkannt sind?
                            • Meistertr
                              hab mir gerade eine rgb leuchte bestellt, sollte in 3 tagen ankommen, dann schauen wir mal weiter
                              • Z
                                zdenko33 last edited by
                                @Meistertr:
                                hab mir gerade eine rgb leuchte bestellt, sollte in 3 tagen ankommen, dann schauen wir mal weiter `
                                @Meistertr
                                Hallo
                                Könnte man in deinem adapter: https://github.com/MeisterTR/ioBroker.yeelight
                                diese Datenpunkte auch einfügen, wie in diesem domoticz Forum?:
                                http://www.domoticz.com/forum/viewtopic … 33#p161352
                                Sat = Saturation a value between 0 and 100
                                Bri = Brightness a value between 1 and 100 /dieser ist schon vorhanden
                                Hue = Hue, color a value between 0 and 359
                                dort in dem script sind auch Farben definiert.
                                und dann eventuell die Farben über Alexa schalten, wie es mit hue Lichtern geht?
                                Danke 😄
                                  MatStone last edited by
                                  Der Adapter funktioniert bei mir an sich sehr gut. Farbwechsel muss ich erst noch ran.
                                  Alle Lampen werden super erkannt.
                                  Meine Schwierigkeit ist die Objektbezeichnung. Wenn ich den einzelnen Objekten eigene Namen gebe, sind diese nur solange da, bis der Yeelight Adapter neu gestartet wird.
                                  Hier werden alle Geräte wohl komplett neu eingebunden und die bisherigen Einstellungen werden gelöscht.
                                  Somit weiß ich nie, welche Lampe hinter welchem Objekt steht.
                                  Die Id bleibt gleich, aber der zugewiesene Name als Eigenschaft geht verloren.
                                  Habt ihr dazu eine Idee?
                                  vielen Dank 🙂
                                    @MatStone:
                                    vielen Dank 🙂 `
                                    Hallo MatStone,
                                    Hast Versucht ein Object im Ordner der jeweiligen Lampe zu erstellen mit eine Name? ( zB "_Lampe1") Das wäre eine Lösung vielleicht, bin nicht socher ob das Object gelöscht wird beim neustarten.
                                      Bei mir wurden immer noch nur die Bedside Lampen erkannt. Die 2 RGBW sind nicht erkannt.
                                      Neustarten oder Adapter neu installieren hilft nicht. Könnte man vielleicht die möglichkeit haben die IPs in der Einstellungen eingeben?
                                        @rh1212:
                                        @MatStone:
                                        vielen Dank 🙂 `
                                        Hallo MatStone,
                                        Hast Versucht ein Object im Ordner der jeweiligen Lampe zu erstellen mit eine Name? ( zB "_Lampe1") Das wäre eine Lösung vielleicht, bin nicht socher ob das Object gelöscht wird beim neustarten. `
                                        Danke für den Vorschlag, das hat leider aber auch nicht funktioniert. Die Objekte scheinen beim Neustart des Adapters neu angelegt zu werden und alle Änderungen sind dadurch weg.
                                        Hat noch jemand anders eine Idee, was man machen könnte um die einzelnen Lampen zu identifizieren?
                                        Habe inzwischen an die 20 verschiedene Yeelight Lampen und dann wird es etwas schwierig wenn viele gleich heißen 😄
                                        Herzlichen Dank für weitere Anregungen und Ideen.
                                          @MatStone:
                                          @rh1212:
                                          @MatStone:
                                          vielen Dank 🙂 `
                                          Hallo MatStone,
                                          Herzlichen Dank für weitere Anregungen und Ideen. `
                                          Das ist ja komisch. Bei mir bleibt das Objekt wenn ich die Instanz neu starte.
                                          Und bei Dir wurden alle 20 Lampen erkannt!!! Bei mir nur 2 und kann das nicht ändern. Du hast die RGBW oder?
                                            dali3 last edited by
                                            Hallo MatStone
                                            Frage mal Bluefox, er hatte die selben Probleme beim MiHome Adapter.
                                            Ev. ist es dasselbe auch hier.
                                            Danke für deinen Einsatz!
                                            @MatStone:
                                            @rh1212:
                                            @MatStone:
                                            vielen Dank 🙂 `
                                            Hallo MatStone,
                                            277
                                            85474
