    4. [Aufruf] Adapter: M-Bus
    • bahnuhr
      iobroker	2018-03-12 19:08:23.587	info	npm ERR! code 1
      iobroker	2018-03-12 19:08:23.587	info	npm ERR! Please include the following file with any support request:npm ERR! C:\ioBroker\node_modules\iobroker\npm-debug.log
      iobroker	2018-03-12 19:08:23.586	info
      iobroker	2018-03-12 19:08:23.525	info
      iobroker	2018-03-12 19:08:23.525	info	npm ERR! There is likely additional logging output above.
      iobroker	2018-03-12 19:08:23.525	info	npm ERR! npm owner ls node-mbus
      iobroker	2018-03-12 19:08:23.525	info	npm bugs node-mbusnpm ERR! Or if that isn't available, you can get their info via:
      iobroker	2018-03-12 19:08:23.524	info	npm ERR!
      iobroker	2018-03-12 19:08:23.524	info	npm ERR! You can get information on how to open an issue for this project with:
      iobroker	2018-03-12 19:08:23.524	info	npm ERR! node-gyp rebuild
      iobroker	2018-03-12 19:08:23.524	info	npm ERR! Tell the author that this fails on your system:
      iobroker	2018-03-12 19:08:23.524	info	npm ERR! not with npm itself.
      iobroker	2018-03-12 19:08:23.524	info	npm ERR! If you do, this is most likely a problem with the node-mbus package,
      iobroker	2018-03-12 19:08:23.524	info	Failed at the node-mbus@0.2.0 install script 'node-gyp rebuild'.npm ERR! Make sure you have the latest version of node.js and npm installed.
      iobroker	2018-03-12 19:08:23.524	info	npm ERR! node-mbus@0.2.0 install: `node-gyp rebuild`npm ERR! Exit status 1
      iobroker	2018-03-12 19:08:23.522	info
      iobroker	2018-03-12 19:08:23.522	info	npm ERR! code ELIFECYCLE
      iobroker	2018-03-12 19:08:23.522	info	npm ERR! npm v3.10.8
      iobroker	2018-03-12 19:08:23.522	info	npm ERR! node v6.9.0
      iobroker	2018-03-12 19:08:23.522	info	ERR! Windows_NT 6.1.7601npm ERR! argv "C:\\Program Files (x86)\\nodejs\\node.exe" "C:\\Program Files (x86)\\nodejs\\node_modules\\npm\\bin\\npm-cli.js" "install" "https://github.com/Apollon77/ioBrok
      iobroker	2018-03-12 19:08:23.521	info	npm
      iobroker	2018-03-12 19:08:20.864	info
      iobroker	2018-03-12 19:08:20.864	info	gyp ERR! node-gyp -v v3.4.0gyp ERR! not ok
      iobroker	2018-03-12 19:08:20.864	info	gyp ERR! node -v v6.9.0
      iobroker	2018-03-12 19:08:20.864	info	gyp ERR! cwd C:\ioBroker\node_modules\iobroker.mbus\node_modules\node-mbus
      iobroker	2018-03-12 19:08:20.864	info	gyp ERR! command "C:\\Program Files (x86)\\nodejs\\node.exe" "C:\\Program Files (x86)\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"
      iobroker	2018-03-12 19:08:20.864	info	gyp ERR! System Windows_NT 6.1.7601
      iobroker	2018-03-12 19:08:20.864	info	gyp ERR! stack at FSReqWrap.oncomplete (fs.js:123:15)
      iobroker	2018-03-12 19:08:20.864	info	gyp ERR! stack at C:\Program Files (x86)\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:404:11
      iobroker	2018-03-12 19:08:20.864	info	gyp ERR! stack Error: Can't find Python executable "python", you can set the PYTHON env variable.gyp ERR! stack at failNoPython (C:\Program Files (x86)\nodejs\node_modules\npm\node_modules\node-g
      iobroker	2018-03-12 19:08:20.863	info	ERR! configure error
      iobroker	2018-03-12 19:08:20.862	info	gyp
      iobroker	2018-03-12 19:08:06.058	info	npm install https://github.com/Apollon77/ioBroker.mbus/tarball/master --production --prefix "C:/ioBroker" (System call)
      iobroker	2018-03-12 19:08:05.915	info	install https://github.com/Apollon77/ioBroker.mbus/tarball/master
      iobroker	2018-03-12 19:08:05.241	info	url "https://github.com/Apollon77/ioBroker.mbus"
      so richtig ?
      • bahnuhr
        wenn ich das ganze direkt in cmd eingebe, dann kommt folgendes:
          @bahnuhr:
          so richtig ? `
          Ja, da schon, aber
          @bahnuhr:
          dann kommt folgendes: `
          hier nicht 😉
          Zum ersten Code:
          @bahnuhr:
          nicht dass ich dir helfen kann, aber vielleicht für @apollon77:
          das sieht aus, als ob die Backslashes hätten escaped werden sollen und statt dessen doppelt sind.
          Rainer
            apollon77 last edited by
            Also an sich sollten die build tools Dir python installieren. Er meckert das das immer noch fehlt. hast Due die Buildtools als Admin installiert?
            Das andere meckert weil Du kein "git" hast. Installier mal git für Windows
            Ingo F
            • bahnuhr
              So noch ne Info von mir.
              Habe ja im Keller einen Raspi der als slave mit iobroker verbunden ist.
              Dort läuft der smartmeter
              Jetzt dachte ich, ich stelle den admin auf den slave und installieren die mbus Instanz dort.
              Im log erscheint dann:
              iobroker	2018-03-12 21:14:01.113	info	exit 0
              iobroker	2018-03-12 21:13:14.894	info	No prebuilt binaries found (target=6.13.0 runtime=node arch=arm platform=linux)
              iobroker	2018-03-12 21:13:14.891	info	WARN install
              iobroker	2018-03-12 21:13:14.889	info	prebuild-install
              iobroker	2018-03-12 21:13:14.867	info	404 https://github.com/node-serialport/node-serialport/releases/download/v6.1.1/serialport-v6.1.1-node-v48-linux-arm.tar.gz
              iobroker	2018-03-12 21:13:14.863	info	http
              iobroker	2018-03-12 21:13:14.860	info	prebuild-install
              iobroker	2018-03-12 21:13:14.256	info	prebuild-install http request GET https://github.com/node-serialport/node-serialport/releases/download/v6.1.1/serialport-v6.1.1-node-v48-linux-arm.tar.gz
              iobroker	2018-03-12 21:13:14.256	info	prebuild-install info looking for cached prebuild @ /root/.npm/_prebuilds/https-github.com-node-serialport-node-serialport-releases-download-v6.1.1-serialport-v6.1.1-node-v48-linux-arm.tar.gz
              iobroker	2018-03-12 21:13:14.256	info	info begin Prebuild-install version 2.5.1prebuild-install info looking for local prebuild @ prebuilds/serialport-v6.1.1-node-v48-linux-arm.tar.gz
              iobroker	2018-03-12 21:13:14.203	info	prebuild-install
              iobroker	2018-03-12 21:12:23.622	info	npm install https://github.com/Apollon77/ioBroker.mbus/tarball/master --production --prefix "/opt/iobroker" (System call)
              iobroker	2018-03-12 21:12:23.252	info	install https://github.com/Apollon77/ioBroker.mbus/tarball/master
              iobroker	2018-03-12 21:12:22.061	info	url "https://github.com/Apollon77/ioBroker.mbus"
              Sieht schon besser aus, aber irgendwas findet er doch nicht, oder ?
              404 https://github.com/node-serialport/node-serialpo…............
              mfg
              Dieter
              • bahnuhr
                @apollon77:
                Ingo F `
                Ja habe cmd als admin aufgerufen (ohne admin geht es gar nicht).
                git für windows -> was ist das ?
                muss ich mal google.
                • bahnuhr
                  so, jetzt habe ich auf dem raspi slave zumindest mal eine Instanz.
                  Diese ist aber leer.
                  • bahnuhr
                    Und nochmal auf dem raspi installiert.
                    Sieht gut aus (glaub ich).
                    iobroker	2018-03-12 21:28:40.567	info	exit 0
                    iobroker	2018-03-12 21:28:40.468	info	upload [0] mbus.admin /opt/iobroker/node_modules/iobroker.mbus/admin/index.html index.html text/html
                    iobroker	2018-03-12 21:28:40.404	info	upload [1] mbus.admin /opt/iobroker/node_modules/iobroker.mbus/admin/index_m.html index_m.html text/html
                    iobroker	2018-03-12 21:28:40.338	info	upload [2] mbus.admin /opt/iobroker/node_modules/iobroker.mbus/admin/mbus.png mbus.png image/png
                    iobroker	2018-03-12 21:28:40.240	info	upload [3] mbus.admin /opt/iobroker/node_modules/iobroker.mbus/admin/words.js words.js application/javascript
                    iobroker	2018-03-12 21:28:40.212	info	got /opt/iobroker/node_modules/iobroker.mbus/admin
                    iobroker	2018-03-12 21:28:40.058	info	└── xmlbuilder@9.0.7
                    iobroker	2018-03-12 21:28:40.058	info	└─┬ xml2js@0.4.19
                    iobroker	2018-03-12 21:28:40.058	info	└─┬ node-mbus@0.2.0
                    iobroker	2018-03-12 21:28:40.058	info	iobroker@1.0.0 /opt/iobroker└─┬ iobroker.mbus@0.0.2
                    iobroker	2018-03-12 21:27:40.352	info	npm install https://github.com/Apollon77/ioBroker.mbus/tarball/master --production --prefix "/opt/iobroker" (System call)
                    iobroker	2018-03-12 21:27:39.982	info	install https://github.com/Apollon77/ioBroker.mbus/tarball/master
                    iobroker	2018-03-12 21:27:38.785	info	url "https://github.com/Apollon77/ioBroker.mbus" --debug
                    Die Adapterkonfiguration ist aber immer noch leer.
                    mfg
                      Windows GIT: https://git-scm.com/download/win
                      Ansonsten: Install hast Du zu schnell abgebrochen. Wenn er serialport nicht findet (404) dann kompiliert er es selbst, das dauert ne Weile 🙂
                      Letzte installationsausgaben sahen gut aus.
                      Das Upload auch.
                      AM besten jetzt nochmal updaten vom Github, hab noch rumgebaut bis eben.
                      Mal ioBroker neu starten und den Browser auch. Kommt dann was?
                      Ich hab Admin3, da ist die Konfig da 😞 Und ehrlich auch kein Admin2 mehr irgendwo 😞
                      Was sagt denn die Browser/JavaScript Konsole? Irgendwelche Fehler?
                      Ingo F
                        @All: ioBroker-mbus 0.0.2 auf Github und morgen im Latest.
                        neu sind Optimierungen und Fixes und vor allem der Gerätescan auf dem M-Bus. Im Tab "Geräte" in der Konfig ist ein Suchbutton. Klicken, ca. 1,5+ Minuten warten (ja so lange und ggf noch länger, also Geduld haben!) und dann sollten alle Secondary-IDs in der Konfig aufgelistet sein.
                        • bahnuhr
                          Ingo,
                          Nachtrag von mir.
                          Habe jetzt admin 3 drauf und da sehe ich die Konfiguration.
                          Jetzt müssen nur noch die Teile kommen.
                          mfg
                            Neue Version 0.1.1 ist auf Github und morgen im Latest.
                            • Admin2 gefixt
                            • andere Bugs gefixt
                            • Windows fix
                              Garf last edited by
                              @apollon77:
                              Jetzt bin ich gespannt ob jemand MBus im Einsatz hat und mittesten kann. `
                              Ich habe hier vier M-Bus Wärmezähler der Fa. Zensus Typ zelsius C5-ISF im Einsatz. Als weitere Testobjekte könnte ich noch einen SAIA Wechselstromzähler ALD1 und einen Drehstromzähler Typ ALE3 an den M-Bus bringen.
                              ioBroker läuft bei mir auf einer QNAP-NAS. Der M-Bus Adapter ließ sich im 2. Anlauf promlemlos installieren. Nach Einrichtung der TCP Schnittstelle wurden die vier Wärmezähler sofort erkannt. Die Werte in den M-Bus Registern werden angezeigt. Soweit schaut schon einmal alles ganz prima aus.
                              Was mir allerdings nicht so gut gefällt sind die Aktivierungsintervalle. Für die Stromzähler ist die Art der Auslesung prima, aber für die Wärmezähler mit ihrer 5-Jahresbatterie eher nicht. Wäre es evtl. möglich so eine Art Abfragezyklus über die Zeit (z.B.Tag/ Uhrzeit) und auf Anfrage einzurichten?
                              Wer so einen Adapter programmieren kann, der kennt sich doch sicher sehr gut mit dem libmbus und mit dem scannen des M-Busses aus und kann mir vielleicht folgende Frage beantworten.
                              Wie kann ich aus dem M-Bus Telegramm der Wärmezähler Zensus Zelsius C5-ISF den Variablenyp (16bit/32bit) auslesen?
                              Diese Infos bräuchte ich um ein M-Bus / Modbus Gateway projektieren zu können.
                                @Garf:
                                Der M-Bus Adapter ließ sich im 2. Anlauf promlemlos installieren. `
                                Was gabs beim ersten Versuch?
                                @Garf:
                                Nach Einrichtung der TCP Schnittstelle wurden die vier Wärmezähler sofort erkannt. Die Werte in den M-Bus Registern werden angezeigt. Soweit schaut schon einmal alles ganz prima aus. `
                                Super! Danke
                                @Garf:
                                Was mir allerdings nicht so gut gefällt sind die Aktivierungsintervalle. Für die Stromzähler ist die Art der Auslesung prima, aber für die Wärmezähler mit ihrer 5-Jahresbatterie eher nicht. Wäre es evtl. möglich so eine Art Abfragezyklus über die Zeit (z.B.Tag/ Uhrzeit) und auf Anfrage einzurichten? `
                                Du hast gesehen das Du das Abfrageintervall je Device in der Deviceliste anders einstellen kannst?
                                Du könntest also bei dem Wärmezähler als Intervall einmal Täglich (in Sekunden dann halt) eintragen. Hilft das?
                                Was ich noch vor habe (im Adapter noch fehlt) sind "update"-States pro Device sodass man manuell eine Abfrage triggern kann.
                                @Garf:
                                Wer so einen Adapter programmieren kann, der kennt sich doch sicher sehr gut mit dem libmbus und mit dem scannen des M-Busses aus und kann mir vielleicht folgende Frage beantworten. `
                                Danke für das Vertrauen … ich kanns versuchen 🙂
                                @Garf:
                                Diese Infos bräuchte ich um ein M-Bus / Modbus Gateway projektieren zu können. `
                                Ohne das genaue Telegram zu kennen kann ich nur auf http://www.m-bus.com/mbusdoc/md6.php verweisen … in 6.3.2 (als Beispiel) steht das im DIB ... musst Du Dekodieren ... Warum nimmst Du nicht die libmbus zum dekodieren?
                                  Garf last edited by
                                  @apollon77:
                                  Was gabs beim ersten Versuch? `
                                  Sorry, beim besten Willen kann ich dies leider nicht mehr reproduzieren. Eigentlich wollte ich damit dann auch hier im Thread aufschlagen, aber dann habe ich die Installation einfach noch einmal durchgeführt. Der Adapter wurde nachgeladen und ich konnte ihn konfigurieren.
                                  @apollon77:
                                  Was ich noch vor habe (im Adapter noch fehlt) sind "update"-States pro Device sodass man manuell eine Abfrage triggern kann. `
                                  Ja, habe ich gesehen und zweimal täglich eingestellt (43200 Sek). Aber scheint noch nicht zu funktionieren, da sich seit der gestrigen Einrichtung (1.Scan) die Werte nicht mehr verändert haben. Da habe ich wohl noch eine Baustelle. Triggern auf Anforderung wäre genau das was ich bräuchte.
                                  Ich würde gerne den Solarwärmezähler auf Knopdruck abfragen, um die momentane Leistung der Solaranlage sehen zu können. Finde ich zwar alles nicht so toll, aber bei einem batteriebetriebenen Wärmezähler geht es leider nicht anders. Man müsste diese blöden Zähler mit eine externen Stromversogung speisen können, dann gäbe es all die Probleme nicht.
                                  @apollon77:
                                  Ohne das genaue Telegram zu kennen kann ich nur auf http://www.m-bus.com/mbusdoc/md6.php verweisen … in 6.3.2 (als Beispiel) steht das im DIB ... musst Du Dekodieren ... Warum nimmst Du nicht die libmbus zum dekodieren? `
                                  Das Telegramm könnte ich dir in Hexform zur Verfügung stellen. Ich habe es auch schon versucht zu übersetzen, aber spätestens beim variablen Teil muss ich echt passen.
                                  Mit dem libmbus komme ich leider nicht wirklich klar, bis auf die zwei Konsolenbefehle
                                  mbus-tcp-scan 192.168.0.100 1001 und mbus-tcp-request-data kann ich mit dem Rest nicht wirklich etwas anfangen. Auch die Dokumentation hilft mir leider nicht wirklich weiter. http://www.rscada.se/libmbus/doc/libmbus-api.pdf
                                  Da fehlt mir wohl das notwendige Hintergrundwissen.
                                  Vielleicht bekomme ich noch Infos vom Hersteller. Die Anfrage habe ich über Stark Elektronik gestellt.
                                  Wenn ich überhaupt nicht weiterkommen, dann muss ich halt für jeden Wert zwei Modbusregister vorhalten. In Summe wären es dann 44 Modbusregister (16bit) je Zähler, bei 5 Zähler dann doch 220 Register. :shock:
                                    @Garf:
                                    @apollon77:
                                    Ich würde gerne den Solarwärmezähler auf Knopdruck abfragen, um die momentane Leistung der Solaranlage sehen zu können. Finde ich zwar alles nicht so toll, aber bei einem batteriebetriebenen Wärmezähler geht es leider nicht anders. Man müsste diese blöden Zähler mit eine externen Stromversogung speisen können, dann gäbe es all die Probleme nicht. `
                                    Also das sollte tun. Wichtig ist aber hier das der Adapter die Werte prüft ob SIe sich geändert haben und nur das in ioBroker schreibt. Wenn Du log auf "Info" hast siehst Du wann er welches Device abfragt. Ist aktuell noch das test-Logging. So kannst Du testen was wann ausgelesen wurde.
                                    Ich habe gerade 0.1.3 auf Github gestellt (nur dort aktuell weil noch nahezu komplett ungetestet). Da gbt es jetzt pro Device auch ein "updateNow"-State. Das auf "true" setzen und es sollte eine Anfrage getriggert werden (to be tested) 🙂
                                    @Garf:
                                    @apollon77:
                                    Wenn ich überhaupt nicht weiterkommen, dann muss ich halt für jeden Wert zwei Modbusregister vorhalten. In Summe wären es dann 44 Modbusregister (16bit) je Zähler, bei 5 Zähler dann doch 220 Register. :shock: `
                                    Ok, so tief bin ich auch nicht drin. Könnte es auch nur versuchen auf Protokollebene auseinanderzunehmen mit der Doku … deswegen hab ich die libmbus genommen anstelle das protokoll selbst zu parsen 🙂
                                      PS: "updateNow" geht erst ab 23:35 vom GitHub … falls Du schneller warst nochmal installieren bitte 🙂
                                        Garf last edited by
                                        Hi appollon,
                                        ich bin da nicht wirklich der Experte, was die Installation und das Updaten von Adaptern angeht. Bei mir wurde der M-bus Adapter Ver. 0.1.1 installiert. Und wenn ich mir die Installationsmeldung von der Konsole anshene, so scheint auch nicht wirklich alles so sauber durchgelaufen zu sein?! 😮
                                        Werfe ich ein Blick auf den changelog, dann müsste doch eigentlich der Adapter Vers. 0.1.2 in ioBroker zu sehen sein. Wie ich jetzt auf Vers. 0.1.3 updaten soll, weiß ich leider auch nicht. Sorry für die blöden Anfängerfragen, aber ich beschäfige mich erst Samstag mit ioBroker und den zu Verfügung stehenden Adapter. Installiert habe ich den M-Bus- und den Modbus-Adapter. Wobei der Modbus-Adapter mit den Einstellung tadelos läuft und zyklisch die erte ausliest. Vielleicht magst Du mich ja in die richtige Richtung lenken, damit es auch mit dem M-Busadapter klappt. In der Zwischenzeit suche ich mal im Forum nach Anleitungen für ioBroker Anfänger.
                                          Am besten nicht direkt per NPM (das geht auch aber dann kommt ggf sowas), sondern per ioBroker-Admin.
                                          Dort gibt es oben ein Icon mit dem GitHub-Symbol - beschriftet mit "Custom Install". Dort aus der Liste "mbus" whlen und klicken … dann läufts los.
                                          Wenn Du wirklich kommandozeile willst dann iobroker update mbus@0.1.3
                                          Am besten warte noch bis heute Abend. Habe noch an der Libary rumgebaut. Dann kommt eine 0.1.4 ... die ist besser, schneller, stabiler. Schreibe hier nochmal ne Info wenn verfügbar
                                            0.1.4 ist verfügbar
                                            31.7k
                                            79.8k
                                            159
                                            35636
