    4. Yet another HomeKit adapter
    • eumats
      eumats last edited by
      @rom.wagner80:
      Nur wenn der Lauf beendet ist. `
      Versuch es mal damit…
      Blocky Export...
      <xml xmlns="http://www.w3.org/1999/xhtml"><block type="comment" id="y-2HEmkl+M]R.WjzxaCE" x="-787" y="-537"><field name="COMMENT">Hier bei Object ID den Datenpunkt IST-Position eintragen</field>
      <next><block type="on_ext" id="tWe5sMj`+Pa==Qa%e:S{"><mutation items="1"></mutation>
          <value name="OID0"><shadow type="field_oid" id="KTV~)9`v*~3G*Pq3AtZe"><field name="oid">default</field></shadow></value>
          <statement name="STATEMENT"><block type="comment" id="]}?djMl)4%kSXGz2_#;g"><field name="COMMENT">Bei mehrfachem Triggern, den alten Timer löschen</field>
              <next><block type="timeouts_cleartimeout" id="w|1*GQ6Ggi]Xx3`#fEWl"><field name="NAME">timeout</field>
                  <next><block type="comment" id="ACWFoMpEdc[;o-sS1|vh"><field name="COMMENT">Lieber etwas warten, falls sich der IST-Wert noch mal ändert.</field>
                      <next><block type="timeouts_settimeout" id="//kr9FBsV5Gi3}#YaQ?B"><field name="NAME">timeout</field>
                          <field name="DELAY">5</field>
                          <statement name="STATEMENT"><block type="controls_if" id="tPba%M?[iOzgzMgV})GS"><value name="IF0"><block type="logic_compare" id="??*6OcLZxHavMfw/4Li%"><field name="OP">NEQ</field>
                                  <value name="A"><block type="variables_get" id="zbKdzEaoO[[OFM1)`G_t"><field name="VAR">IST-Wert</field></block></value>
                                  <value name="B"><block type="variables_get" id="}D^Rc#^h%Mzo~yj)?+Ce"><field name="VAR">SOLL-Wert</field></block></value></block></value>
                              <statement name="DO0"><block type="comment" id="+BNC.QgfHOh?m-}wU~7|"><field name="COMMENT">Hier bei Object ID den Datenpunkt IST-Position eintragen</field>
                                  <next><block type="control" id="+ERi2QWY.ITzPg@!8y03"><mutation delay_input="false"></mutation>
                                      <value name="VALUE"><block type="variables_get" id="Y0f(3.=GA,.67oqPHd-j"><field name="VAR">IST-Wert</field></block></value></block></next></block></statement></block></statement></block></next></block></next></block></next></block></statement></block></next></block></xml>
      [3610_clipboard01.jpg](/assets/uploads/files/3610_clipboard01.jpg)
        rom.wagner80 last edited by
        Hey. Sowas wäre mir im Leben nicht eingefallen. Werd es morgen direkt mal testen. Vielen Dank dir
          Aber muss ich zum Schluss nicht den Sollwert und nicht den Istwert reinschreiben? Weil die Istposition übernimmt er ja nach erfolgter fahrt richtig und das Problem ist ja, dass die Sollposition beim Tastendruck nicht geändert wird…
          • eumats
            @rom.wagner80:
            Aber muss ich zum Schluss nicht den Sollwert und nicht den Istwert reinschreiben? Weil die Istposition übernimmt er ja nach erfolgter fahrt richtig und das Problem ist ja, dass die Sollposition beim Tastendruck nicht geändert wird… `
            Der IST-Wert muss in den Sollwert geschrieben werden damit in Homekit wieder die Anzeige korrekt ist.
              @eumats:
              @rom.wagner80:
              Der IST-Wert muss in den Sollwert geschrieben werden damit in Homekit wieder die Anzeige korrekt ist. `
              Genau. Aber du schreibst in deinem Script ja den Ist-Wert in das Objekt Istwert, oder? Jedenfalls dein Kommentar im blockly deutet darauf hin.
              • eumats
                @rom.wagner80:
                @eumats:
                @rom.wagner80:
                Genau. Aber du schreibst in deinem Script ja den Ist-Wert in das Objekt Istwert, oder? Jedenfalls dein Kommentar im blockly deutet darauf hin. `
                Ups.in Object ID muss natürlich der Sollwert rein. Ist wohl doch schon zu spät…
                  Kein Problem. Bin froh, dass ich nicht ganz auf dem Schlauch stehe 😉
                  Dank dir nochmal für deine Hilfe. Werd morgen berichten, wie es läuft .
                  Gute Nacht
                    @rom.wagner80:
                    Gute Nacht `
                    Also, die Grundfunktion ist Super. Klappt alles wie es soll, im HomeKit wird alles richtig angezeigt….ABER 🙂 nach den eingestellten 5 Sekunden kommt es hin und wieder vor, dass die Rolllade noch ein zehntel Sekündchen fährt. ich denke das liegt daran, dass der Jalousieaktor irgendwo stehen bleibt und dann durch den Sollwert auf genau die Prozentzahl fährt. Beispiel : Istwert tatsächlich: 25,4 % Istwert angezeigt : 25 % Sollwert nach 5 Sekunden 25 %. somit fährt der Rollladen noch um 0,4 Prozent nach oben...dafür vielleicht noch ne Idee ? 🙂 brauch ich den Timeout von 5 Sekunden überhaupt ? Weil bei erneuter Bewegung der Rolllade und der damit einhergehenden Veränderung des Istwertes wird der Trigger erneut ausgeführt und somit die Sollposition wieder berrechnet
                      Hey,
                      Gerade beim ansteuern der Rolllade durch Taster noch gesehen, dass es Log-Einträge über den Vorgang gibt… was kann das bedeuten?
                      • eumats
                        @rom.wagner80:
                        Hey,
                        Gerade beim ansteuern der Rolllade durch Taster noch gesehen, dass es Log-Einträge über den Vorgang gibt… was kann das bedeuten? `
                        Poste mal einen Screenshot der RAW Daten des Datenpunktes…
                        • eumats
                          @rom.wagner80:
                          @rom.wagner80:
                          Gute Nacht `
                          Also, die Grundfunktion ist Super. Klappt alles wie es soll, im HomeKit wird alles richtig angezeigt….ABER 🙂 nach den eingestellten 5 Sekunden kommt es hin und wieder vor, dass die Rolllade noch ein zehntel Sekündchen fährt. ich denke das liegt daran, dass der Jalousieaktor irgendwo stehen bleibt und dann durch den Sollwert auf genau die Prozentzahl fährt. Beispiel : Istwert tatsächlich: 25,4 % Istwert angezeigt : 25 % Sollwert nach 5 Sekunden 25 %. somit fährt der Rollladen noch um 0,4 Prozent nach oben...dafür vielleicht noch ne Idee ? 🙂 brauch ich den Timeout von 5 Sekunden überhaupt ? Weil bei erneuter Bewegung der Rolllade und der damit einhergehenden Veränderung des Istwertes wird der Trigger erneut ausgeführt und somit die Sollposition wieder berrechnet `
                          Lass dir mal in deinem Skript per Debug die Werte für IST und SOLL ausgeben
                            Hier mal der Datenpunkt, der das Problem im Post verursacht. Allerdings machen das Alle Rollläden. Die Einstellungen sind aber auch für alle Datenpunkte gleich.
                              @eumats:
                              @rom.wagner80:
                              @rom.wagner80:
                              Gute Nacht `
                              Also, die Grundfunktion ist Super. Klappt alles wie es soll, im HomeKit wird alles richtig angezeigt….ABER 🙂 nach den eingestellten 5 Sekunden kommt es hin und wieder vor, dass die Rolllade noch ein zehntel Sekündchen fährt. ich denke das liegt daran, dass der Jalousieaktor irgendwo stehen bleibt und dann durch den Sollwert auf genau die Prozentzahl fährt. Beispiel : Istwert tatsächlich: 25,4 % Istwert angezeigt : 25 % Sollwert nach 5 Sekunden 25 %. somit fährt der Rollladen noch um 0,4 Prozent nach oben...dafür vielleicht noch ne Idee ? 🙂 brauch ich den Timeout von 5 Sekunden überhaupt ? Weil bei erneuter Bewegung der Rolllade und der damit einhergehenden Veränderung des Istwertes wird der Trigger erneut ausgeführt und somit die Sollposition wieder berrechnet Lass dir mal in deinem Skript per Debug die Werte für IST und SOLL ausgeben
                              Das werd ich aber erst morgen schaffen… werde weiter berichten 🙂
                              • eumats
                                @rom.wagner80:
                                Hier mal der Datenpunkt, der das Problem im Post verursacht. Allerdings machen das Alle Rollläden. Die Einstellungen sind aber auch für alle Datenpunkte gleich. `
                                Ändere mal den Typ der Darenpunkte in Zahl (number)…
                                  @eumats:
                                  Ändere mal den Typ der Darenpunkte in Zahl (number)… `
                                  Da hat schonmal funktioniert 🙂
                                    @eumats:
                                    Lass dir mal in deinem Skript per Debug die Werte für IST und SOLL ausgeben `
                                    Also folgendes ist zu beobachten !? :
                                    • eumats
                                      Hast du bei diesem Log den Rolladen manuell bedient und hat er da wieder „gestottert“?
                                        Ja, genau.
                                        • eumats
                                          Hast du ihn nur ganz kurz (also 3%) fahren lassen? Lass ihn mal bitte länger fahre. Natürlich manuell und dann das Log posten.
                                            @eumats:
                                            Hast du ihn nur ganz kurz (also 3%) fahren lassen? Lass ihn mal bitte länger fahre. Natürlich manuell und dann das Log posten. `
                                            Werd ich morgen mal machen… weiß nicht mehr ob’s 3% waren... könnte aber sein.
                                            Schönen Abend noch
                                            1764
                                            798311
