    4. [Frage] Xiaomi Vacuum cleaner
    • Meistertr
      @SchuetzeSchulz:
      @Meistertr:
      Installiere mal bitte über den link. Die IP ist auf jeden Fall richtig? Es sollte zu mindestens send helo im log stehe `
      Habe die Version vom Link installiert, IP stimmt auch (kann sie sogar anpingen), aber der Adapter bleibt komischerweise immer noch gelb.
      Und im Log kommt auchkein "send helo".
      mihome-vacuum.0	2018-03-16 17:50:08.519	debug	system.adapter.admin.0: logging true
      mihome-vacuum.0	2018-03-16 17:50:08.519	debug	redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":true,"ack":true,"ts":1521219008512,"q":0,"from":"system.adapter.admin.0","lc":1521218923948}
      mihome-vacuum.0	2018-03-16 17:49:59.368	debug	system.adapter.admin.0: logging true
      mihome-vacuum.0	2018-03-16 17:49:59.364	debug	redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":true,"ack":true,"ts":1521218999356,"q":0,"from":"system.adapter.admin.0","lc":1521218923948}
      mihome-vacuum.0	2018-03-16 17:48:53.460	debug	system.adapter.admin.0: logging true
      mihome-vacuum.0	2018-03-16 17:48:53.460	debug	redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":true,"ack":true,"ts":1521218933455,"q":0,"from":"system.adapter.admin.0","lc":1521218923948}
      mihome-vacuum.0	2018-03-16 17:48:53.214	debug	redis pmessage io.mihome-vacuum.0.* io.mihome-vacuum.0.info.connection {"val":false,"ack":true,"ts":1521218933205,"q":0,"from":"system.adapter.mihome-vacuum.0","lc":1521218655373}
      mihome-vacuum.0	2018-03-16 17:48:53.191	debug	server started on 0.0.0.0:53421
      mihome-vacuum.0	2018-03-16 17:48:53.180	info	Create state clean_home for controlling by cloud adapter
      mihome-vacuum.0	2018-03-16 17:48:53.179	info	Expert mode disabled, states deleded
      mihome-vacuum.0	2018-03-16 17:48:53.174	info	starting. Version 1.0.1 in C:/ioBroker/node_modules/iobroker.mihome-vacuum, node: v6.11.1
      mihome-vacuum.0	2018-03-16 17:48:53.020	info	States connected to redis: 127.0.0.1:6379
      mihome-vacuum.0	2018-03-16 17:48:53.016	debug	statesDB connected
      mihome-vacuum.0	2018-03-16 17:48:52.994	debug	objectDB connected
      host.SRV01-IOBROKER	2018-03-16 17:48:52.212	info	instance system.adapter.mihome-vacuum.0 started with pid 1680
      Kann man den Roboter sonst irgendwie mal resetten ohne das das Sprachpaket verloren geht? `
      Der Roboter ist unschuldig. Sehe gerade dass du Windows nutzt, kannst du mal sämtliche Sicherheitssystem Virenprogramm und Firewall ausschalten.
        SchuetzeSchulz last edited by
        Habe die Firewall und das Antivirus komplett deaktiviert, sieht jetzt besser aus:
        mihome-vacuum.0	2018-03-16 19:31:08.753	debug	system.adapter.admin.0: logging true
        mihome-vacuum.0	2018-03-16 19:31:08.753	debug	redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":true,"ack":true,"ts":1521225068748,"q":0,"from":"system.adapter.admin.0","lc":1521225068748}
        mihome-vacuum.0	2018-03-16 19:31:02.689	debug	system.adapter.admin.0: logging false
        mihome-vacuum.0	2018-03-16 19:31:02.689	debug	redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":false,"ack":true,"ts":1521225062684,"q":0,"from":"system.adapter.admin.0","lc":1521225062684}
        mihome-vacuum.0	2018-03-16 19:31:00.396	debug	redis pmessage io.mihome-vacuum.0.* io.mihome-vacuum.0.info.connection {"val":false,"ack":true,"ts":1521225060393,"q":0,"from":"system.adapter.mihome-vacuum.0","lc":1521225060393}
        mihome-vacuum.0	2018-03-16 19:31:00.350	debug	Disconnect
        mihome-vacuum.0	2018-03-16 19:30:40.271	debug	sendMsgRaw >>> 2131005000000000046df91a5aac0db325e45e4c13230e2635df67b844a9ceecb791683d74adc5471ab9ece5453f63b861d08edccddd91e3769a672e0947388beece3cb3380d948953a8a2fab70e1b63
        mihome-vacuum.0	2018-03-16 19:30:40.271	debug	sendMsg >>> {"id":108,"method":"get_carpet_mode"}
        mihome-vacuum.0	2018-03-16 19:30:40.270	debug	Timestamp: 5aac0db3
        mihome-vacuum.0	2018-03-16 19:30:40.270	debug	lastid{"get_status":103,"get_consumable":105,"get_clean_summary":106,"get_clean_record":0,"X_send_command":0,"miIO.info":104,"get_sound_volume":107,"get_carpet_mode":108}
        mihome-vacuum.0	2018-03-16 19:30:39.868	debug	sendMsgRaw >>> 2131005000000000046df91a5aac0db26d20d95955f829736b2a433b2384b95b6cca58b2fe219a7e70844b1de10f43a670d54f73b890ddd829f09b06021d0751579fd9aa7d6f7719c3e38f6d1e62f6c4
        mihome-vacuum.0	2018-03-16 19:30:39.868	debug	sendMsg >>> {"id":107,"method":"get_sound_volume"}
        mihome-vacuum.0	2018-03-16 19:30:39.867	debug	Timestamp: 5aac0db2
        mihome-vacuum.0	2018-03-16 19:30:39.867	debug	lastid{"get_status":103,"get_consumable":105,"get_clean_summary":106,"get_clean_record":0,"X_send_command":0,"miIO.info":104,"get_sound_volume":107,"get_carpet_mode":102}
        mihome-vacuum.0	2018-03-16 19:30:39.466	debug	sendMsgRaw >>> 2131005000000000046df91a5aac0db242042189b49adb289cbda715a720a01b4d041cef3bc047d2a1c46a7b01c5ce3607319c2526a58a4e97b5804bd77b812507ae28b38f76c91773922c59fce28a9c
        mihome-vacuum.0	2018-03-16 19:30:39.466	debug	sendMsg >>> {"id":106,"method":"get_clean_summary"}
        mihome-vacuum.0	2018-03-16 19:30:39.466	debug	Timestamp: 5aac0db2
        mihome-vacuum.0	2018-03-16 19:30:39.465	debug	lastid{"get_status":103,"get_consumable":105,"get_clean_summary":106,"get_clean_record":0,"X_send_command":0,"miIO.info":104,"get_sound_volume":101,"get_carpet_mode":102}
        mihome-vacuum.0	2018-03-16 19:30:39.063	debug	sendMsgRaw >>> 2131005000000000046df91a5aac0db2807ab04e45a1ec0f0f7848bc82490f79f0b433b8dd6ee094f2ee3d68e46aa5edfa7686e0f5ae51462aa8b55264155e7d6f533c213ae5147c0bd45325875173cc
        mihome-vacuum.0	2018-03-16 19:30:39.063	debug	sendMsg >>> {"id":105,"method":"get_consumable"}
        mihome-vacuum.0	2018-03-16 19:30:39.062	debug	Timestamp: 5aac0db2
        mihome-vacuum.0	2018-03-16 19:30:39.062	debug	lastid{"get_status":103,"get_consumable":105,"get_clean_summary":100,"get_clean_record":0,"X_send_command":0,"miIO.info":104,"get_sound_volume":101,"get_carpet_mode":102}
        mihome-vacuum.0	2018-03-16 19:30:38.662	debug	sendMsgRaw >>> 2131004000000000046df91a5aac0db11ec107bb74a982f46cb0e4682f8619e54a183630c235df8006a2e27551c377ffa93fbe755f0d17f111d4462f39f74501
        mihome-vacuum.0	2018-03-16 19:30:38.661	debug	sendMsg >>> {"id":104,"method":"miIO.info"}
        mihome-vacuum.0	2018-03-16 19:30:38.660	debug	Timestamp: 5aac0db1
        mihome-vacuum.0	2018-03-16 19:30:38.660	debug	lastid{"get_status":103,"get_consumable":99,"get_clean_summary":100,"get_clean_record":0,"X_send_command":0,"miIO.info":104,"get_sound_volume":101,"get_carpet_mode":102}
        mihome-vacuum.0	2018-03-16 19:30:38.258	debug	redis pmessage io.mihome-vacuum.0.* io.mihome-vacuum.0.info.connection {"val":true,"ack":true,"ts":1521225038257,"q":0,"from":"system.adapter.mihome-vacuum.0","lc":1521225038257}
        mihome-vacuum.0	2018-03-16 19:30:38.256	debug	sendMsgRaw >>> 2131005000000000046df91a5aac0db115537db90553a2047c2654ed88629e8f8fab8f83be962e62405e526eee4750e6e5a2feec10af2517adf64745dfea9e9cc511dcff223d18bed9dec5f2612adcb3
        mihome-vacuum.0	2018-03-16 19:30:38.256	debug	sendMsg >>> {"id":103,"method":"get_status"}
        mihome-vacuum.0	2018-03-16 19:30:38.256	debug	Timestamp: 5aac0db1
        mihome-vacuum.0	2018-03-16 19:30:38.255	debug	lastid{"get_status":103,"get_consumable":99,"get_clean_summary":100,"get_clean_record":0,"X_send_command":0,"miIO.info":98,"get_sound_volume":101,"get_carpet_mode":102}
        mihome-vacuum.0	2018-03-16 19:30:38.255	debug	requesting params every: 60 Sec
        mihome-vacuum.0	2018-03-16 19:30:38.255	debug	Connected
        mihome-vacuum.0	2018-03-16 19:30:38.254	debug	Receive <<< Helo <<< 2131002000000000046df91a5aac0db1ffffffffffffffffffffffffffffffff
        host.SRV01-IOBROKER	2018-03-16 19:30:08.942	info	instance system.adapter.ical.0 terminated with code 0 (OK)
        host.SRV01-IOBROKER	2018-03-16 19:30:06.541	info	instance system.adapter.weatherunderground.0 terminated with code 0 (OK)
        host.SRV01-IOBROKER	2018-03-16 19:30:00.021	info	instance system.adapter.weatherunderground.0 started with pid 6108
        host.SRV01-IOBROKER	2018-03-16 19:30:00.014	info	instance system.adapter.ical.0 started with pid 5344
        mihome-vacuum.0	2018-03-16 19:29:29.892	debug	system.adapter.admin.0: logging true
        mihome-vacuum.0	2018-03-16 19:29:29.891	debug	redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":true,"ack":true,"ts":1521224969886,"q":0,"from":"system.adapter.admin.0","lc":1521224969886}
        mihome-vacuum.0	2018-03-16 19:29:20.346	debug	redis pmessage io.mihome-vacuum.0.* io.mihome-vacuum.0.info.connection {"val":false,"ack":true,"ts":1521224960344,"q":0,"from":"system.adapter.mihome-vacuum.0","lc":1521224960344}
        mihome-vacuum.0	2018-03-16 19:29:20.343	debug	Disconnect
        mihome-vacuum.0	2018-03-16 19:29:19.346	debug	sendMsgRaw >>> 2131005000000000046df91a5aac0d6263c6f8b6ed5bf17e493b8a084f3758c6550612f642a738691e0a1397767fdae4764146850a0cd1c29da211496181d2adfccb840ec3ccdfd2b3de7346e62dfbcd
        mihome-vacuum.0	2018-03-16 19:29:19.345	debug	sendMsg >>> {"id":102,"method":"get_carpet_mode"}
        mihome-vacuum.0	2018-03-16 19:29:19.344	debug	Timestamp: 5aac0d62
        mihome-vacuum.0	2018-03-16 19:29:19.344	debug	lastid{"get_status":97,"get_consumable":99,"get_clean_summary":100,"get_clean_record":0,"X_send_command":0,"miIO.info":98,"get_sound_volume":101,"get_carpet_mode":102}
        mihome-vacuum.0	2018-03-16 19:29:18.942	debug	sendMsgRaw >>> 2131005000000000046df91a5aac0d61f607a0298ee0ac05ea68e7aecf122bbc597ba678798322e40c229efcf7580777403bc7d7a49980da5b8ac1b1ddb9969dbc902bacd0033a8123fbea0340ffa503
        mihome-vacuum.0	2018-03-16 19:29:18.942	debug	sendMsg >>> {"id":101,"method":"get_sound_volume"}
        mihome-vacuum.0	2018-03-16 19:29:18.940	debug	Timestamp: 5aac0d61
        mihome-vacuum.0	2018-03-16 19:29:18.940	debug	lastid{"get_status":97,"get_consumable":99,"get_clean_summary":100,"get_clean_record":0,"X_send_command":0,"miIO.info":98,"get_sound_volume":101,"get_carpet_mode":96}
        mihome-vacuum.0	2018-03-16 19:29:18.539	debug	sendMsgRaw >>> 2131005000000000046df91a5aac0d610302c7c06bd60711678f49ca63f2c468ef2e51daec787d1060fe1967349d2083a88779f49a97eb249cbdd5093051b5ad5f5e543a69f0e2265682987b8a24c882
        mihome-vacuum.0	2018-03-16 19:29:18.538	debug	sendMsg >>> {"id":100,"method":"get_clean_summary"}
        mihome-vacuum.0	2018-03-16 19:29:18.536	debug	Timestamp: 5aac0d61
        mihome-vacuum.0	2018-03-16 19:29:18.535	debug	lastid{"get_status":97,"get_consumable":99,"get_clean_summary":100,"get_clean_record":0,"X_send_command":0,"miIO.info":98,"get_sound_volume":95,"get_carpet_mode":96}
        mihome-vacuum.0	2018-03-16 19:29:18.134	debug	sendMsgRaw >>> 2131005000000000046df91a5aac0d6174ad9b7a01b94d1acbcdab37bea5b9997f120d7172d09ea7170076b769932d41219ca94acb4bc2db981aa4a8e70a117f99c5e5782563caebd1caf62d0f456aea
        mihome-vacuum.0	2018-03-16 19:29:18.134	debug	sendMsg >>> {"id":99,"method":"get_consumable"}
        mihome-vacuum.0	2018-03-16 19:29:18.133	debug	Timestamp: 5aac0d61
        mihome-vacuum.0	2018-03-16 19:29:18.133	debug	lastid{"get_status":97,"get_consumable":99,"get_clean_summary":94,"get_clean_record":0,"X_send_command":0,"miIO.info":98,"get_sound_volume":95,"get_carpet_mode":96}
        mihome-vacuum.0	2018-03-16 19:29:17.733	debug	sendMsgRaw >>> 2131004000000000046df91a5aac0d60c17aa4b9741f973ac33e9d53ad248a16bac13afe0d85cca088fb39323291883c124a67fae99b7c5474547b42e05ed529
        mihome-vacuum.0	2018-03-16 19:29:17.732	debug	sendMsg >>> {"id":98,"method":"miIO.info"}
        mihome-vacuum.0	2018-03-16 19:29:17.731	debug	Timestamp: 5aac0d60
        mihome-vacuum.0	2018-03-16 19:29:17.731	debug	lastid{"get_status":97,"get_consumable":93,"get_clean_summary":94,"get_clean_record":0,"X_send_command":0,"miIO.info":98,"get_sound_volume":95,"get_carpet_mode":96}
        mihome-vacuum.0	2018-03-16 19:29:17.330	debug	sendMsgRaw >>> 2131004000000000046df91a5aac0d60c813cf5b03cc9cfc12f7695f72e93b6374d97c427c965ff4d18a80b7f16f324bbbf3762b6871597659ed0cab5ecaa6f6
        mihome-vacuum.0	2018-03-16 19:29:17.329	debug	sendMsg >>> {"id":97,"method":"get_status"}
        mihome-vacuum.0	2018-03-16 19:29:17.329	debug	Timestamp: 5aac0d60
        mihome-vacuum.0	2018-03-16 19:29:17.328	debug	lastid{"get_status":97,"get_consumable":93,"get_clean_summary":94,"get_clean_record":0,"X_send_command":0,"miIO.info":92,"get_sound_volume":95,"get_carpet_mode":96}
        mihome-vacuum.0	2018-03-16 19:29:17.328	debug	requesting params every: 60 Sec
        mihome-vacuum.0	2018-03-16 19:29:16.959	debug	system.adapter.admin.0: logging false
        mihome-vacuum.0	2018-03-16 19:29:16.958	debug	redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":false,"ack":true,"ts":1521224956952,"q":0,"from":"system.adapter.admin.0","lc":1521224956952}
        mihome-vacuum.0	2018-03-16 19:28:59.367	debug	sendMsgRaw >>> 2131005000000000046df91a5aac0d4ed00cd601545179281c0a4361301e96f6cbd4d85dfbf4148fcd5626ee7562623eee9601a81d07223578fab2561571dd6d25d791c23a7ce1d8f856e26ce2e798af
        mihome-vacuum.0	2018-03-16 19:28:59.367	debug	sendMsg >>> {"id":96,"method":"get_carpet_mode"}
        mihome-vacuum.0	2018-03-16 19:28:59.367	debug	Timestamp: 5aac0d4e
        mihome-vacuum.0	2018-03-16 19:28:59.366	debug	lastid{"get_status":91,"get_consumable":93,"get_clean_summary":94,"get_clean_record":0,"X_send_command":0,"miIO.info":92,"get_sound_volume":95,"get_carpet_mode":96}
        mihome-vacuum.0	2018-03-16 19:28:58.965	debug	sendMsgRaw >>> 2131005000000000046df91a5aac0d4d79f17ddbea5ef2f6c671cb47df106af858e91e5141cabaa12a75b53496ff2744c82c0c0ce83b35da7e8038a8821148ab0fb7bdddac3771a204e14132d38b6407
        mihome-vacuum.0	2018-03-16 19:28:58.965	debug	sendMsg >>> {"id":95,"method":"get_sound_volume"}
        mihome-vacuum.0	2018-03-16 19:28:58.964	debug	Timestamp: 5aac0d4d
        mihome-vacuum.0	2018-03-16 19:28:58.964	debug	lastid{"get_status":91,"get_consumable":93,"get_clean_summary":94,"get_clean_record":0,"X_send_command":0,"miIO.info":92,"get_sound_volume":95,"get_carpet_mode":90}
        mihome-vacuum.0	2018-03-16 19:28:58.562	debug	sendMsgRaw >>> 2131005000000000046df91a5aac0d4d50101d093c87261d823618f0cf8396b7346e2e093a3a53c6b20f5328cc621aad23b82c395b3614ee828237c14c054a2ee99334394e747db5b1be06b59c3944d8
        mihome-vacuum.0	2018-03-16 19:28:58.561	debug	sendMsg >>> {"id":94,"method":"get_clean_summary"}
        mihome-vacuum.0	2018-03-16 19:28:58.559	debug	Timestamp: 5aac0d4d
        mihome-vacuum.0	2018-03-16 19:28:58.559	debug	lastid{"get_status":91,"get_consumable":93,"get_clean_summary":94,"get_clean_record":0,"X_send_command":0,"miIO.info":92,"get_sound_volume":89,"get_carpet_mode":90}
        mihome-vacuum.0	2018-03-16 19:28:58.158	debug	sendMsgRaw >>> 2131005000000000046df91a5aac0d4d7843f3a998e71062d82d59608241c4b7bbb901f1c1570ed902be40cb6639f5a291de5006fe51fc34dfac1921e02e29baddc0f70fc4d29a92e2ffbb41d1153d37
        mihome-vacuum.0	2018-03-16 19:28:58.158	debug	sendMsg >>> {"id":93,"method":"get_consumable"}
        mihome-vacuum.0	2018-03-16 19:28:58.157	debug	Timestamp: 5aac0d4d
        mihome-vacuum.0	2018-03-16 19:28:58.157	debug	lastid{"get_status":91,"get_consumable":93,"get_clean_summary":88,"get_clean_record":0,"X_send_command":0,"miIO.info":92,"get_sound_volume":89,"get_carpet_mode":90}
        mihome-vacuum.0	2018-03-16 19:28:57.754	debug	sendMsgRaw >>> 2131004000000000046df91a5aac0d4c0fd9a132cce3f95ac043c10f5966c5ba3017b7d79daae5036d2c65fe55ed87b02554aad118cc74fd825c22465f70e7f7
        mihome-vacuum.0	2018-03-16 19:28:57.754	debug	sendMsg >>> {"id":92,"method":"miIO.info"}
        mihome-vacuum.0	2018-03-16 19:28:57.754	debug	Timestamp: 5aac0d4c
        mihome-vacuum.0	2018-03-16 19:28:57.753	debug	lastid{"get_status":91,"get_consumable":87,"get_clean_summary":88,"get_clean_record":0,"X_send_command":0,"miIO.info":92,"get_sound_volume":89,"get_carpet_mode":90}
        mihome-vacuum.0	2018-03-16 19:28:57.354	debug	redis pmessage io.mihome-vacuum.0.* io.mihome-vacuum.0.info.connection {"val":true,"ack":true,"ts":1521224937353,"q":0,"from":"system.adapter.mihome-vacuum.0","lc":1521224937353}
        mihome-vacuum.0	2018-03-16 19:28:57.352	debug	sendMsgRaw >>> 2131004000000000046df91a5aac0d4c7cc111ee4c9838d584ce304ef72d16b8669b2500842809e7826e3a89d440b15cfe5a8161709a0fa29c15b52443873368
        mihome-vacuum.0	2018-03-16 19:28:57.352	debug	sendMsg >>> {"id":91,"method":"get_status"}
        mihome-vacuum.0	2018-03-16 19:28:57.352	debug	Timestamp: 5aac0d4c
        mihome-vacuum.0	2018-03-16 19:28:57.352	debug	lastid{"get_status":91,"get_consumable":87,"get_clean_summary":88,"get_clean_record":0,"X_send_command":0,"miIO.info":86,"get_sound_volume":89,"get_carpet_mode":90}
        mihome-vacuum.0	2018-03-16 19:28:57.351	debug	requesting params every: 60 Sec
        mihome-vacuum.0	2018-03-16 19:28:57.351	debug	Connected
        mihome-vacuum.0	2018-03-16 19:28:57.350	debug	Receive <<< Helo <<< 2131002000000000046df91a5aac0d4cffffffffffffffffffffffffffffffff
        mihome-vacuum.0	2018-03-16 19:28:00.345	debug	redis pmessage io.mihome-vacuum.0.* io.mihome-vacuum.0.info.connection {"val":false,"ack":true,"ts":1521224880343,"q":0,"from":"system.adapter.mihome-vacuum.0","lc":1521224880343}
        mihome-vacuum.0	2018-03-16 19:28:00.342	debug	Disconnect
        mihome-vacuum.0	2018-03-16 19:27:50.480	debug	system.adapter.admin.0: logging true
        mihome-vacuum.0	2018-03-16 19:27:50.480	debug	redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":true,"ack":true,"ts":1521224870474,"q":0,"from":"system.adapter.admin.0","lc":1521224870474}
        mihome-vacuum.0	2018-03-16 19:27:39.367	debug	sendMsgRaw >>> 2131005000000000046df91a5aac0cfe56f3f43be42f233842c5207e978eb134a806c022eebec45ff8e0c9750890eb21000e3b8ecc864bf150115e0830e5a574f37a7188ea52fe29d74acebd72bfcf65
        mihome-vacuum.0	2018-03-16 19:27:39.367	debug	sendMsg >>> {"id":90,"method":"get_carpet_mode"}
        mihome-vacuum.0	2018-03-16 19:27:39.366	debug	Timestamp: 5aac0cfe
        mihome-vacuum.0	2018-03-16 19:27:39.366	debug	lastid{"get_status":85,"get_consumable":87,"get_clean_summary":88,"get_clean_record":0,"X_send_command":0,"miIO.info":86,"get_sound_volume":89,"get_carpet_mode":90}
        mihome-vacuum.0	2018-03-16 19:27:38.964	debug	sendMsgRaw >>> 2131005000000000046df91a5aac0cfd91f147b0bf4ffab99956671866d29ad550fe90c6fcaeb3e7e221f1925de0d80df236ac6e630fd59b4e415cd751ec3995d51c2ee5c55fc69254dc02ac35e7f15a
        mihome-vacuum.0	2018-03-16 19:27:38.964	debug	sendMsg >>> {"id":89,"method":"get_sound_volume"}
        mihome-vacuum.0	2018-03-16 19:27:38.963	debug	Timestamp: 5aac0cfd
        mihome-vacuum.0	2018-03-16 19:27:38.963	debug	lastid{"get_status":85,"get_consumable":87,"get_clean_summary":88,"get_clean_record":0,"X_send_command":0,"miIO.info":86,"get_sound_volume":89,"get_carpet_mode":84}
        mihome-vacuum.0	2018-03-16 19:27:38.562	debug	sendMsgRaw >>> 2131005000000000046df91a5aac0cfdc9d8efa5efddb64b928484241b22e60c368904a5b124a32fa2da9a537510260319554905312621d5c30e30709940b0bcf52de0956e80c4a085a51e64932b4e24
        mihome-vacuum.0	2018-03-16 19:27:38.562	debug	sendMsg >>> {"id":88,"method":"get_clean_summary"}
        mihome-vacuum.0	2018-03-16 19:27:38.562	debug	Timestamp: 5aac0cfd
        mihome-vacuum.0	2018-03-16 19:27:38.561	debug	lastid{"get_status":85,"get_consumable":87,"get_clean_summary":88,"get_clean_record":0,"X_send_command":0,"miIO.info":86,"get_sound_volume":83,"get_carpet_mode":84}
        mihome-vacuum.0	2018-03-16 19:27:38.160	debug	sendMsgRaw >>> 2131005000000000046df91a5aac0cfdcabe570de8f08bffb868693096546a323aa1cb49a69ba577551c1164dd19dd821c6946bca6e6d8aaaf6d9fe08b9663b1e1303e147a83a67172d7bc4883a44a15
        mihome-vacuum.0	2018-03-16 19:27:38.160	debug	sendMsg >>> {"id":87,"method":"get_consumable"}
        mihome-vacuum.0	2018-03-16 19:27:38.159	debug	Timestamp: 5aac0cfd
        mihome-vacuum.0	2018-03-16 19:27:38.159	debug	lastid{"get_status":85,"get_consumable":87,"get_clean_summary":82,"get_clean_record":0,"X_send_command":0,"miIO.info":86,"get_sound_volume":83,"get_carpet_mode":84}
        mihome-vacuum.0	2018-03-16 19:27:37.757	debug	sendMsgRaw >>> 2131004000000000046df91a5aac0cfc69c6c4909ea64335ab17598a9a21f47704f1a464b5ccf7df27f104ffd8c447cfcac339a280751652ca7fa4527bc15953
        mihome-vacuum.0	2018-03-16 19:27:37.757	debug	sendMsg >>> {"id":86,"method":"miIO.info"}
        mihome-vacuum.0	2018-03-16 19:27:37.756	debug	Timestamp: 5aac0cfc
        mihome-vacuum.0	2018-03-16 19:27:37.755	debug	lastid{"get_status":85,"get_consumable":81,"get_clean_summary":82,"get_clean_record":0,"X_send_command":0,"miIO.info":86,"get_sound_volume":83,"get_carpet_mode":84}
        mihome-vacuum.0	2018-03-16 19:27:37.351	debug	redis pmessage io.mihome-vacuum.0.* io.mihome-vacuum.0.info.connection {"val":true,"ack":true,"ts":1521224857350,"q":0,"from":"system.adapter.mihome-vacuum.0","lc":1521224857350}
        mihome-vacuum.0	2018-03-16 19:27:37.350	debug	sendMsgRaw >>> 2131004000000000046df91a5aac0cfc396f422c043cfe6f71cf21c19f7df78dfedf6f471e068ec6b5714f47ed884ca0c0000bdb6b6bc890059215d52ccda7df
        mihome-vacuum.0	2018-03-16 19:27:37.350	debug	sendMsg >>> {"id":85,"method":"get_status"}
        mihome-vacuum.0	2018-03-16 19:27:37.349	debug	Timestamp: 5aac0cfc
        mihome-vacuum.0	2018-03-16 19:27:37.349	debug	lastid{"get_status":85,"get_consumable":81,"get_clean_summary":82,"get_clean_record":0,"X_send_command":0,"miIO.info":80,"get_sound_volume":83,"get_carpet_mode":84}
        mihome-vacuum.0	2018-03-16 19:27:37.349	debug	requesting params every: 60 Sec
        mihome-vacuum.0	2018-03-16 19:27:37.349	debug	Connected
        mihome-vacuum.0	2018-03-16 19:27:37.348	debug	Receive <<< Helo <<< 2131002000000000046df91a5aac0cfcffffffffffffffffffffffffffffffff
        mihome-vacuum.0	2018-03-16 19:27:20.345	debug	redis pmessage io.mihome-vacuum.0.* io.mihome-vacuum.0.info.connection {"val":false,"ack":true,"ts":1521224840343,"q":0,"from":"system.adapter.mihome-vacuum.0","lc":1521224840343}
        mihome-vacuum.0	2018-03-16 19:27:20.342	debug	Disconnect
        mihome-vacuum.0	2018-03-16 19:27:19.339	debug	sendMsgRaw >>> 2131005000000000046df91a5aac0cea09b8613664cf6c9b2da561e4caeb451e2bce19ec1ac2da70898b851e71646b19295c34fc25aaab1c175c5ce86466018d9ee975417b2d4264613a1bb481d4aa43
        mihome-vacuum.0	2018-03-16 19:27:19.339	debug	sendMsg >>> {"id":84,"method":"get_carpet_mode"}
        mihome-vacuum.0	2018-03-16 19:27:19.339	debug	Timestamp: 5aac0cea
        mihome-vacuum.0	2018-03-16 19:27:19.338	debug	lastid{"get_status":79,"get_consumable":81,"get_clean_summary":82,"get_clean_record":0,"X_send_command":0,"miIO.info":80,"get_sound_volume":83,"get_carpet_mode":84}
        mihome-vacuum.0	2018-03-16 19:27:18.937	debug	sendMsgRaw >>> 2131005000000000046df91a5aac0ce94647802363ee7e0aa8053b7df335546f47835b219283e7b53187a832aabfdf83c422dae6aba7e42b7351ce6f71824aac38c52d3f3402231d5c87ab473f584db6
        mihome-vacuum.0	2018-03-16 19:27:18.937	debug	sendMsg >>> {"id":83,"method":"get_sound_volume"}
        mihome-vacuum.0	2018-03-16 19:27:18.936	debug	Timestamp: 5aac0ce9
        mihome-vacuum.0	2018-03-16 19:27:18.936	debug	lastid{"get_status":79,"get_consumable":81,"get_clean_summary":82,"get_clean_record":0,"X_send_command":0,"miIO.info":80,"get_sound_volume":83,"get_carpet_mode":78}
        mihome-vacuum.0	2018-03-16 19:27:18.536	debug	sendMsgRaw >>> 2131005000000000046df91a5aac0ce9f6208243a5947735c1b963e0892cac43bea88badbba66bf4ac9babff0ed07e9636676b3369686d507cef0e3fde50bcdc79fa55f26385354147a09eec65c02ce7
        mihome-vacuum.0	2018-03-16 19:27:18.534	debug	sendMsg >>> {"id":82,"method":"get_clean_summary"}
        mihome-vacuum.0	2018-03-16 19:27:18.534	debug	Timestamp: 5aac0ce9
        mihome-vacuum.0	2018-03-16 19:27:18.533	debug	lastid{"get_status":79,"get_consumable":81,"get_clean_summary":82,"get_clean_record":0,"X_send_command":0,"miIO.info":80,"get_sound_volume":77,"get_carpet_mode":78}
        mihome-vacuum.0	2018-03-16 19:27:18.131	debug	sendMsgRaw >>> 2131005000000000046df91a5aac0ce9fe7c0bc3c01e095dcf03ca51600a382c31855e08538ae1bf9265f4a6218f19cd68c87445f08094ffafa2162948a09c96e952672ba9eb845383bc2e23b497d9cf
        mihome-vacuum.0	2018-03-16 19:27:18.131	debug	sendMsg >>> {"id":81,"method":"get_consumable"}
        mihome-vacuum.0	2018-03-16 19:27:18.129	debug	Timestamp: 5aac0ce9
        mihome-vacuum.0	2018-03-16 19:27:18.129	debug	lastid{"get_status":79,"get_consumable":81,"get_clean_summary":76,"get_clean_record":0,"X_send_command":0,"miIO.info":80,"get_sound_volume":77,"get_carpet_mode":78}
        mihome-vacuum.0	2018-03-16 19:27:17.729	debug	sendMsgRaw >>> 2131004000000000046df91a5aac0ce8ca2791616554a5e0c8af7140f4575b87cf6e6a85ac6640cdb97363701dbce4c7098b94e653de9f1dc164fd351e9ca4b5
        mihome-vacuum.0	2018-03-16 19:27:17.728	debug	sendMsg >>> {"id":80,"method":"miIO.info"}
        mihome-vacuum.0	2018-03-16 19:27:17.728	debug	Timestamp: 5aac0ce8
        mihome-vacuum.0	2018-03-16 19:27:17.727	debug	lastid{"get_status":79,"get_consumable":75,"get_clean_summary":76,"get_clean_record":0,"X_send_command":0,"miIO.info":80,"get_sound_volume":77,"get_carpet_mode":78}
        mihome-vacuum.0	2018-03-16 19:27:17.327	debug	sendMsgRaw >>> 2131004000000000046df91a5aac0ce8b3a422743fcc2194be16fa3a09950bd5887fb5a8745f70cc308582ac9aef384dfddaee50a1322664ee8e8c7a9781c6e2
        mihome-vacuum.0	2018-03-16 19:27:17.326	debug	sendMsg >>> {"id":79,"method":"get_status"}
        mihome-vacuum.0	2018-03-16 19:27:17.322	debug	Timestamp: 5aac0ce8
        mihome-vacuum.0	2018-03-16 19:27:17.321	debug	lastid{"get_status":79,"get_consumable":75,"get_clean_summary":76,"get_clean_record":0,"X_send_command":0,"miIO.info":74,"get_sound_volume":77,"get_carpet_mode":78}
        mihome-vacuum.0	2018-03-16 19:27:17.321	debug	requesting params every: 60 Sec
        mihome-vacuum.0	2018-03-16 19:27:17.234	debug	system.adapter.admin.0: logging false
        mihome-vacuum.0	2018-03-16 19:27:17.234	debug	redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":false,"ack":true,"ts":1521224837227,"q":0,"from":"system.adapter.admin.0","lc":1521224837227}
        mihome-vacuum.0	2018-03-16 19:27:04.829	debug	system.adapter.admin.0: logging true
        mihome-vacuum.0	2018-03-16 19:27:04.828	debug	redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":true,"ack":true,"ts":1521224824823,"q":0,"from":"system.adapter.admin.0","lc":1521224824823}
        mihome-vacuum.0	2018-03-16 19:26:59.362	debug	sendMsgRaw >>> 2131005000000000046df91a5aac0cd69e6d6ab97b36d57f1358e3d5f71efc419bcb6b7c9c1734ce546865db183168c5844f528c15acce7d9971dd71118917b682db504ee05ae69cc249b032ed5d4e8d
        mihome-vacuum.0	2018-03-16 19:26:59.360	debug	sendMsg >>> {"id":78,"method":"get_carpet_mode"}
        mihome-vacuum.0	2018-03-16 19:26:59.359	debug	Timestamp: 5aac0cd6
        mihome-vacuum.0	2018-03-16 19:26:59.359	debug	lastid{"get_status":73,"get_consumable":75,"get_clean_summary":76,"get_clean_record":0,"X_send_command":0,"miIO.info":74,"get_sound_volume":77,"get_carpet_mode":78}
        mihome-vacuum.0	2018-03-16 19:26:58.958	debug	sendMsgRaw >>> 2131005000000000046df91a5aac0cd5d9e2fceca9d36f12a26f2ce256afa2416d5e566f0d0b2410da3285e72aeb72c48552412fa9174a036bb9c771811d3979e1f541e8bb5025baac04fd6037141c25
        mihome-vacuum.0	2018-03-16 19:26:58.958	debug	sendMsg >>> {"id":77,"method":"get_sound_volume"}
        mihome-vacuum.0	2018-03-16 19:26:58.957	debug	Timestamp: 5aac0cd5
        mihome-vacuum.0	2018-03-16 19:26:58.957	debug	lastid{"get_status":73,"get_consumable":75,"get_clean_summary":76,"get_clean_record":0,"X_send_command":0,"miIO.info":74,"get_sound_volume":77,"get_carpet_mode":72}
        mihome-vacuum.0	2018-03-16 19:26:58.557	debug	sendMsgRaw >>> 2131005000000000046df91a5aac0cd5e2722969da2a46ed44afea9417e2b67ef476a2ed6ffdffc930e09419a5d2314487e8af201f0258b4c6155cc56a7073956efc38f5b1a06ca709669f16ba3d3a96
        mihome-vacuum.0	2018-03-16 19:26:58.556	debug	sendMsg >>> {"id":76,"method":"get_clean_summary"}
        mihome-vacuum.0	2018-03-16 19:26:58.555	debug	Timestamp: 5aac0cd5
        mihome-vacuum.0	2018-03-16 19:26:58.555	debug	lastid{"get_status":73,"get_consumable":75,"get_clean_summary":76,"get_clean_record":0,"X_send_command":0,"miIO.info":74,"get_sound_volume":71,"get_carpet_mode":72}
        mihome-vacuum.0	2018-03-16 19:26:58.152	debug	sendMsgRaw >>> 2131005000000000046df91a5aac0cd50b47e50c808f7f642d01e3219defb1173c371ea7ac0eab3fd34798cbe846f1baab5ac869f45fe636a7286dd36d49cb0f0d5b4a18f319ea0733ac931096d139f2
        mihome-vacuum.0	2018-03-16 19:26:58.152	debug	sendMsg >>> {"id":75,"method":"get_consumable"}
        mihome-vacuum.0	2018-03-16 19:26:58.151	debug	Timestamp: 5aac0cd5
        mihome-vacuum.0	2018-03-16 19:26:58.151	debug	lastid{"get_status":73,"get_consumable":75,"get_clean_summary":70,"get_clean_record":0,"X_send_command":0,"miIO.info":74,"get_sound_volume":71,"get_carpet_mode":72}
        mihome-vacuum.0	2018-03-16 19:26:57.750	debug	sendMsgRaw >>> 2131004000000000046df91a5aac0cd45e0d824062fa6976c35a8ba4824e966da462de2db816f87dcfbe1e59dcdf40d15d332ebedb560a4b21f590ff3e33b20f
        mihome-vacuum.0	2018-03-16 19:26:57.750	debug	sendMsg >>> {"id":74,"method":"miIO.info"}
        mihome-vacuum.0	2018-03-16 19:26:57.749	debug	Timestamp: 5aac0cd4
        mihome-vacuum.0	2018-03-16 19:26:57.749	debug	lastid{"get_status":73,"get_consumable":69,"get_clean_summary":70,"get_clean_record":0,"X_send_command":0,"miIO.info":74,"get_sound_volume":71,"get_carpet_mode":72}
        mihome-vacuum.0	2018-03-16 19:26:57.350	debug	redis pmessage io.mihome-vacuum.0.* io.mihome-vacuum.0.info.connection {"val":true,"ack":true,"ts":1521224817349,"q":0,"from":"system.adapter.mihome-vacuum.0","lc":1521224817349}
        mihome-vacuum.0	2018-03-16 19:26:57.348	debug	sendMsgRaw >>> 2131004000000000046df91a5aac0cd4cb1c427d853c345c8fa46d58d7560d95e639bbaa8c99f80c67b0a7f73d42c3362e7ec1a9a33b73ef7da56a94f90b2656
        mihome-vacuum.0	2018-03-16 19:26:57.348	debug	sendMsg >>> {"id":73,"method":"get_status"}
        mihome-vacuum.0	2018-03-16 19:26:57.348	debug	Timestamp: 5aac0cd4
        mihome-vacuum.0	2018-03-16 19:26:57.348	debug	lastid{"get_status":73,"get_consumable":69,"get_clean_summary":70,"get_clean_record":0,"X_send_command":0,"miIO.info":68,"get_sound_volume":71,"get_carpet_mode":72}
        mihome-vacuum.0	2018-03-16 19:26:57.347	debug	requesting params every: 60 Sec
        mihome-vacuum.0	2018-03-16 19:26:57.347	debug	Connected
        mihome-vacuum.0	2018-03-16 19:26:57.347	debug	Receive <<< Helo <<< 2131002000000000046df91a5aac0cd4ffffffffffffffffffffffffffffffff
        mihome-vacuum.0	2018-03-16 19:26:22.842	debug	system.adapter.admin.0: logging false
        mihome-vacuum.0	2018-03-16 19:26:22.841	debug	redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":false,"ack":true,"ts":1521224782835,"q":0,"from":"system.adapter.admin.0","lc":1521224782835}
        mihome-vacuum.0	2018-03-16 19:26:07.435	debug	system.adapter.admin.0: logging true
        mihome-vacuum.0	2018-03-16 19:26:07.435	debug	redis pmessage io.*.logging io.system.adapter.admin.0.logging {"val":true,"ack":true,"ts":1521224767429,"q":0,"from":"system.adapter.admin.0","lc":1521224767429}
        Allerdings werden die Objekte nicht aktualisiert (z.B. steht info.state noch auf "Cleaning" obwohl der Roboter schon seit ca. 10 Minuten lädt).
        Weiterhin kann ich auch keinen Befehl wie z.B. clean_home oder find absetzen.
        Ich bin langsam mit meinem Latein am Ende.
        hab aus Verzweiflung auch schon die beiden Ports des Adapters in der Fritzbox freigegeben.
        • Meistertr
          Das sieht gut aus. Und jetzt nochmal Adapter aus und Roboterneu starten. Dann Adapter an und einfach mal eine Stunde laufen lassen..
            Adapter an und eine Stunde laufen lassen dann ohne Befehl und irgendwas zu machen, richtig?
              Habe bis heute nichts mehrg emacht.
              Habe den Staubsauger mal komplett (inkl. WLAN) zurückgesetzt und im Adapter inkl. neuem Token neu eingerichtet.
              Leider immer noch keine aktuellen Objekte…
              • Meistertr
                Der sauger ist aber nicht im gastwlan?
                  Nein, ich habe kein aktives Gast WLAN.
                  Ist es evtl. ein Firmware Problem? Mein Sauger hat die 3.3.9_003096
                  • Meistertr
                    @SchuetzeSchulz:
                    Ist es evtl. ein Firmware Problem? Mein Sauger hat die 3.3.9_003096 `
                    nein, mit der FW ist es def. möglicht. hast du die Neuste Version der flole vac? habe gerade gelesen, dass da nicht mehr der token im klartext, sondern verschlüsselt gespeichert wird, somit kann man mit der neusten fw der flole vac auch nicht mehr den token auslesen. Wir haben jetzt alles ausgeschlossen. Verbindung steht und er antwortet auf die Halo Nachricht, dann kann es eigentlich nur am token liegen
                      Die letzten Male habe ich den Token immer mit dem MiToolkit ausgelesen. Soll ichs mal mit der Flole Vac App versuchen?
                      • Meistertr
                        @SchuetzeSchulz:
                        Die letzten Male habe ich den Token immer mit dem MiToolkit ausgelesen. Soll ichs mal mit der Flole Vac App versuchen? `
                        ne so war das nicht gemeint.
                        ich bin mit meinem Wissen nun leider auch am ende. Es müsste eigentlich gehen aber warum es nicht geht kann ich dir leider nicht sagen. wir haben nun alle Möglichkeiten durch. wobei es bei dir ja schon mal Funktioniert hat, es muss sich ja irgend etwas geändert haben an deinem System, wodurch es dann nicht mehr ging..
                          Brati last edited by
                          @Meistertr
                          So, mein S50 fährt endlich über das mihome-vacuum.0.control.X_send_command. Er reagierte allergisch auf ein Freizeichen und die kopierte ")" am Ende.
                          Den Datenpunkt goTo und zoneClean habe ich übrigens nicht. Womit das nächste Problem wäre, das ZoneClean auszulösen:
                          app_zone_clean; [25500,29000,27500,26000,1]
                          Ist es leider nicht. Und mein Mittelpunkt scheint übrigens 25.500, 25.500 zu sein.
                          Wenn ich es richtig sehe, scheinen die x/y Koordinaten aber immer relativ zum "Nullpunkt" zu liegen, dass würde bedeuten, dass er sie auch ohne hinterlegte Karte finden müßte. Bzw. man kann sich dann auch eine Sequenz zum Karte erstellen basteln.
                          Kannst du bitte nochmal beim ZoneClean helfen?
                          Danke, Grüße
                          Brati
                            Hallo MeisterTr,
                            ich glaube ich bin meinem Problem näher gekommen.
                            Es scheint an der Windows Firewall zu liegen denke ich.
                            Wenn ich diese komplett deaktiviere, sheint es zu funktionieren (Dauertest steht noch aus).
                            Wenn ich Sie aktiviere und beide Ports aus der Adapter-Konfiguration komplett freigebe/öffne, dann gehts nicht.
                            Werden evtl. noch andere Ports genutzt?
                            • U
                              uschi08 last edited by
                              @Brati:
                              @Meistertr
                              Danke, Grüße
                              Brati `
                              Hi Brati,
                              geht doch wunderbar mit
                              app_zoned_clean;[[24117,26005,25767,27205,1],[24320,24693,25970,25843,1]]
                              das sind zwei Zonen, mit jeweils Koordinaten für "links unten", "rechts oben".
                              Vielen Dank für den Hinweis, jetzt kann ich endlich verschiedene Räume (Zonen) ansteuern!
                                @uschi08
                                Na Perfekt, es läuft. Jetzt muss ich ihm nur noch abgewöhnen die Karte manchmal um 90Grad zu drehen. Das ist irgendwie nervig und ich kann auch nicht nachvollziehen wann es passiert.
                                Nach dem Reinigen war sie auf einmal senkrecht. Somit haben die Koordinaten (z.B. vor dem Mülleimer parken) nicht mehr gestimmt. Jetzt gerade beim Test der Zonen Funktion wurde die Karte auf einmal wieder "normal" angezeigt.
                                Brati
                                  simpixo last edited by
                                  Wie finde ich den die Koordinaten raus!?
                                  Adrian
                                    @simpixo:
                                    Adrian
                                    Gesendet von iPhone mit Tapatalk Pro `
                                    Schau mal auf die Karte in diesem Post.
                                    viewtopic.php?f=23&t=4898&start=1580#p135853
                                    Ich habe den Screenshot in Word importiert und trivial drüber gemalt. Der Mittelpunkt ist 25500,25500. Fährst du danach 26500,25500 an, bist auf gleicher Höhe rechts. Hier einfach das entsprechende Maß finden und selber das Raster drüber legen. Wahrscheinlich macht sich das in Excel sogar leichter.
                                    Brati
                                    • Z
                                      Zer0x last edited by
                                      EDIT: Problem wurde gelöst. Man sollte keine Szene erstellen sondern einfach den Haken "add Alexa state" beim "MiHome-vacuum Adapter" setzten dann funktionierts! Danke nochmal an MeisterTr.
                                      bin recht neu hier jedoch hat mir der Thread sehr weitergeholfen, vorallem der Hinweis, dass sich der Token nach jedem Wlan-Reset erneuert.
                                      Nach mehreren Stunden habe ich es endlich geschafft den Token auszulesen. Danke dafür!
                                      Nun habe ich leider noch ein weiteres Problem.
                                      Ich möchte meinen Xiaomi Vaccum Roboter über Alexa steuern können.
                                      Was ist mir bis jetzt gelungen:
                                      • Installation aller nötigen Adapter
                                      • Einrichtung des MiVacuum sowie Cloud-Adpater
                                      • Über ioBroker > Objekte > mihome-vacuum.0 > kann ich Befehle an den Roboter senden (start, find etc.)
                                      • Szene "Staubsauger"erstellt für Alexa und im Cloud Adapter hinzugefügt
                                      Problem: Nach Aufruf von Alexa: "Schalte Staubsauger ein" passiert nichts. Sie sagt noch "Okay" das wars.
                                      In der Szene habe ich auch alle Werte richtig ausgewählt, dass habe ich schon geprüft und im ioBroker ändert sich der Wert der jeweiligen Einstellung nach dem Alexa-Kommando von False auf True. Leider bleibt der Roboter still…
                                      Hier noch Logs (sieht aber nicht sehr spektakulär aus)
                                      mihome-vacuum.0	2018-03-26 15:15:29.435	info	Cloud control disabled
                                      mihome-vacuum.0	2018-03-26 15:15:29.431	info	Expert mode disabled, states deleded
                                      mihome-vacuum.0	2018-03-26 15:15:29.418	info	starting. Version 0.6.0 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v6.13.1
                                      mihome-vacuum.0	2018-03-26 15:15:29.340	info	States connected to redis: 127.0.0.1:6379
                                      Habe ich irgendwas vergessen?
                                      Für Tipps wäre ich sehr dankbar!
                                        Turbo last edited by
                                        Sag mal "Alexa starte Staubsauger".
                                        Bei mir fängt bei "Schalte Staubsauger ein" Alexa an zu saugen :lol:
                                        Edit: Halt, falsch, war andersrum.
                                        Aber was meinst Du mit Szene? Staubsauger müsste doch ein vom Script erstellter Datenpunkt sein…
                                        • Meistertr
                                          Beide falsch. Einfach den Haken in der Konfiguration setzen dann ist der Staubsauger automatisch im cloud Adapter
                                          Gesendet von meinem Handy
                                          • Z
                                            Danke!!! Habe es ohne hier zu lesen einfach mal probiert und dann ging es… Danke auch nochmal für den Hinweis.
                                            Bin nämlich als erstes über eine Youtube-Anleitung gegangen und da wurde es noch mit der Szene gemacht.
                                            Gelöst!
                                            2196
                                            959997
