    4. [Aufruf] IKEA-Trådfri Adapter testen
    • AlCalzone
      > C:\WINDOWS\system32\null
      Wie hast du das Update ausgeführt?! Und vor allem wo?
      • N
        nobse last edited by
        Über den Admin wie auch die vorherigen Updates
        • AlCalzone
          Welche Versionen von Admin und JS-Controller hast du? Gibts nen ausführlicheren Log?
          Welche NodeJS- und NPM-Version?
          Und meinst du mit Admin den Github-Dropdown oder das "Aktualisieren"-Symbol in der Adapterliste?
          • N
            Admin 3.3.0
            JS-Controller 1.2.7
            NodeJS 6.11.4
            NPM 3.10.10
            iobroker	2018-03-10 14:17:37.598	info	exit 20
            iobroker	2018-03-10 14:17:37.598	error	host.server error: reading io-package.json Error: ENOENT: no such file or directory, open 'C:\WINDOWS\system32\null\io-package.json'
            iobroker	2018-03-10 14:17:37.598	info	host.server create instance tradfri
            iobroker	2018-03-10 14:17:37.551	info
            iobroker	2018-03-10 14:17:37.551	info	C:\WINDOWS\system32\npm-debug.lognpm ERR! code 1
            iobroker	2018-03-10 14:17:37.551	info	npm ERR! Please include the following file with any support request:npm ERR!
            iobroker	2018-03-10 14:17:37.489	info
            iobroker	2018-03-10 14:17:37.489	info	npm ERR! npm ERR! Please try running this command again as root/Administrator.
            iobroker	2018-03-10 14:17:37.489	info	at Error (native) parent: 'iobroker.tradfri' }
            iobroker	2018-03-10 14:17:37.489	info	ERR! Error: EPERM: operation not permitted, rename 'C:\ioBroker\node_modules\iobroker.tradfri\node_modules\node-aead-crypto' -> 'C:\ioBroker\node_modules\iobroker.tradfri\node_modules\.node-aead-cry
            iobroker	2018-03-10 14:17:37.489	info	npm ERR! at FSReqWrap.oncomplete (fs.js:123:15)
            iobroker	2018-03-10 14:17:37.489	info	ERR! at destStatted (C:\Program Files\nodejs\node_modules\npm\lib\install\action\finalize.js:27:7)npm ERR! at C:\Program Files\nodejs\node_modules\npm\node_modules\graceful-fs\polyfills.js:2
            iobroker	2018-03-10 14:17:37.489	info	npm ERR! at moveAway (C:\Program Files\nodejs\node_modules\npm\lib\install\action\finalize.js:38:5)
            iobroker	2018-03-10 14:17:37.489	info	at Error (native)npm ERR! { Error: EPERM: operation not permitted, rename 'C:\ioBroker\node_modules\iobroker.tradfri\node_modules\node-aead-crypto' -> 'C:\ioBroker\node_modules\iobroker.tradfri
            iobroker	2018-03-10 14:17:37.489	info	npm ERR! Error: EPERM: operation not permitted, rename 'C:\ioBroker\node_modules\iobroker.tradfri\node_modules\node-aead-crypto' -> 'C:\ioBroker\node_modules\iobroker.tradfri\node_modules\.node-aead-c
            iobroker	2018-03-10 14:17:37.489	info	npm ERR! at C:\Program Files\nodejs\node_modules\npm\node_modules\graceful-fs\polyfills.js:267:18
            iobroker	2018-03-10 14:17:37.489	info	npm ERR! at destStatted (C:\Program Files\nodejs\node_modules\npm\lib\install\action\finalize.js:27:7)
            iobroker	2018-03-10 14:17:37.489	info	Error: EPERM: operation not permitted, rename 'C:\ioBroker\node_modules\iobroker.tradfri\node_modules\node-aead-crypto' -> 'C:\ioBroker\node_modules\iobroker.tradfri\node_modules\.node-aead-crypto.D
            iobroker	2018-03-10 14:17:37.489	info	npm ERR! syscall rename
            iobroker	2018-03-10 14:17:37.489	info	npm ERR! errno -4048
            iobroker	2018-03-10 14:17:37.489	info	npm ERR! code EPERM
            iobroker	2018-03-10 14:17:37.489	info	v3.10.10npm ERR! path C:\ioBroker\node_modules\iobroker.tradfri\node_modules\node-aead-crypto
            iobroker	2018-03-10 14:17:37.489	info	npm ERR! node v6.11.4
            iobroker	2018-03-10 14:17:37.489	info	npm ERR! Windows_NT 10.0.14393npm ERR! argv "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\bin\\npm-cli.js" "install" "iobroker.tradfri" "--production" "--save"
            iobroker	2018-03-10 14:17:31.285	info	npm WARN deprecated github@0.2.4: 'github' has been renamed to '@octokit/rest' (https://git.io/vNB11)
            iobroker	2018-03-10 14:17:23.701	info	npm install iobroker.tradfri --production --save --prefix "C:/ioBroker" (System call)
            iobroker	2018-03-10 14:17:22.092	info	NPM version: 3.10.10
            iobroker	2018-03-10 14:17:19.716	info	add tradfri
            Das Update über "Aktualisieren"-Symbol in der Adapterliste.
            • AlCalzone
              Hmm der will irgendwas umbenennen und darf es nicht. Geh mal in deinen ioBroker-Ordner, Unterordner node_modules und lösche die folgenden Ordner wenn du sie findest:
              iobroker.tradfri
              node-tradfri-client
              node-coap-client
              node-dtls-client
              node-aead-crypto
              Probier danach nochmal den Adapter zu installieren.
              • N
                nach löschen der von dir gelistet Verzeichnisse ging die Installation.
                Gruß Norbert
                  ludino last edited by
                  Ich möchte meine smart Lichtschalter mit dem tradfri koppeln. Sprich diese Lichtschalter können ein short press und ein longpress simulieren, kann ich diese Funktion irgendwie für das dimmen missbrauchen? Also gedrückt halten Lampen werden heller bis 100% und fangen dann wieder bei 0% an….!
                    Seit einer Updaterunde vor ca. 2 Wochen habe ich immer wieder ein "reconnect DB" mit anschliessendem Neustart von history. Wenn das mehrmals passiert, schmiert dann alles ab.
                    Habe jetzt stückweise ziemlich heftig downgegraded, so daß ich "nur" noch ein bis 2 solcher history-Neustart-events pro Tag habe.
                    Die letzten Tage ist das Schema immer das gleiche:
                    • Tradfri-adapter updatet irgendwelche Szenen
                    • Daraufhin kommt es zu einem reconnect DB
                    • Dann startet history neu
                    ! 2018-03-20 06:49:47.968 - [32minfo[39m: web.0 2018-03-20T05:49:47.968Z Connected system.user.admin 2018-03-20 07:36:16.016 - [32minfo[39m: tradfri.0 updating possible scenes for group 168027: ["219832","221310","225907"] 2018-03-20 07:36:16.055 - [32minfo[39m: tradfri.0 updating possible scenes for group 168027: ["219832","221310","225907"] 2018-03-20 07:36:16.094 - [32minfo[39m: tradfri.0 updating possible scenes for group 168027: ["219832","221310","225907"] 2018-03-20 07:38:48.068 - [33mwarn[39m: history.0 Reconnection to DB. 2018-03-20 07:38:48.221 - [33mwarn[39m: history.0 Reconnection to DB. 2018-03-20 07:38:48.484 - [32minfo[39m: history.0 starting. Version 1.5.3 in /opt/iobroker/node_modules/iobroker.history, node: v6.13.1 2018-03-20 07:38:48.506 - [32minfo[39m: history.0 starting. Version 1.5.3 in /opt/iobroker/node_modules/iobroker.history, node: v6.13.1 2018-03-20 07:38:49.313 - [32minfo[39m: history.0 enabled logging of hm-rpc.0.updated 2018-03-20 07:38:49.315 - [32minfo[39m: history.0 enabled logging of hm-rpc.0.BidCoS-RF.0.INSTALL_MODE 2018-03-20 07:38:49.316 - [32minfo[39m: history.0 enabled logging of hm-rpc.0.BidCoS-RF.1.LEVEL ...... !
                    Ist das bei Euch auch so?
                    Habe auf den aktuellen 1.1.7 tradfri aktualisiert aber das Problem beibt.
                    Jetzt pausiere ich mal den Adapter und schaue was passiert.
                    • AlCalzone
                      Ich glaube das hängt nicht wirklich zusammen. Laut deinem Log liegt zwischen der Tradfri-Aktion und dem History-Neustart 1,5 Minuten. Da ist irgendwas anderes faul schätze ich.
                      kommt, wenn der Tradfri-Adapter startet oder neue Szenen vom Gateway empfängt. Das wird entsprechend im "activeScene"-State-Objekt vermerkt für den Dropdown.
                        Vielen Dank für Deine Einschaetzung.
                        Habe derzeit keine Szenen definiert. Ich schalte die Tradfri Lampe mit dem Wandschalter ein und aus. Vielleicht kommt das daher?
                        Ich lasse den Tradfri jetzt mal ein, zwei Tage pausiert, dann werden wir weiter sehen.
                        Ich habe recht viel downgegraded aber immer noch kein so stabiles System wie es mal war.
                        • AlCalzone
                          @klassisch:
                          Habe derzeit keine Szenen definiert. `
                          Jede Lampe bzw. Gruppe hat standardmäßig 3 Szenen (bzw. IKEA nennt sie "Moods"), die auch über die App aktiviert werden können. Die haben nix mit ioBroker zu tun, werden aber vom Adapter zur Auswahl angeboten.
                            Es scheint tatsächlich so zu sein, daß bei jedem Netzeinschalten der Lampe dreimal die info-Meldung
                            tradfri.0	2018-03-27 19:20:03.444	info	updating possible scenes for group 168027: ["219832","221310","225907"]
                            tradfri.0	2018-03-27 19:20:03.443	info	updating possible scenes for group 168027: ["219832","221310","225907"]
                            tradfri.0	2018-03-27 19:20:03.442	info	updating possible scenes for group 168027: ["219832","221310","225907"]
                            kommt.
                            Nicht, daß das schlimm sei, wollte es nur angemerkt haben.
                            Mein Stabilitätsthema hat(te) wahrscheinlich andere Primärursachen, also nicht den tradfri Adapter. Bin nach einigen Änderungen gerade in der Beobachungs-/Bewährungsphase.
                            • AlCalzone
                              Ja, das loggt er ein bisschen zu oft. Ich versuche es im nächsten Update zu reduzieren.
                                ich habe mal eine Frage und zwar wenn ich die Lampen über Szenen.adapter oder Blocky einen Wert vorgebe, gehen diese nicht genau auf diesen wert, sondern z.b. 0,1% drüber oder Drunter.
                                beispiel möchte Farbe auf 20% haben und die Ikea Lampen stellen 20,1% ein.
                                Dieses wäre ja nicht weiter tragisch. Das problem ist wenn ich z.b. eine Szene im VIS darstellen und schalten möchte. Wenn die Werte nicht genau sind sagt mir der Szenen Adapter das der Zustand undefiniert ist. Dieses macht es mir auch schwer über Vis ein True False befehl abzusetzten, bzw den zustand anzuzeigen.
                                Gibt es dafür eine Lösung bzw, kann ich den Datenpunkt sagen das er die Komma stellen auf oder abrunden soll?
                                • AlCalzone
                                  @ludino:
                                  beispiel möchte Farbe auf 20% haben und die Ikea Lampen stellen 20,1% ein. `
                                  Das ist eine Eigenheit des verwendeten Protokolls. Die Farbtemperatur wird intern als Ganzzahl im Bereich von 250-454 dargestellt, d.h. es gibt nur eine Schrittweite von etwa 0,49%. Die nächsten darstellbaren Werte sind dementsprechend 19,6 oder 20,1%. Bei einigen anderen Werten ist die Schrittweite 0,394%, d.h. egal wie ich runde, irgendwas passt immer nicht.
                                  Und standardmäßig auf Ganzzahlen zu runden wollte ich auch nicht, weil dann wieder Skripte wie Homoran's Sonnenaufgang nicht richtig funktionieren. Ich nehm die Anregung aber mal auf, dass das Runden konfigurierbar gemacht wird.
                                    Danke für die Antwort!
                                    Schade das es nicht geht!
                                    Wenn ich das richtig verstehe rechnest du die werte von 250-454 in eine Prozentzahl um. Ich vermute mal diese kann ich nicht im Klartext angeben. So wäre mein Problem auch gelöst.
                                    • AlCalzone
                                      Ne das wird nicht unterstützt und ist mehr Aufwand als das Runden zu konfigurieren.
                                      • AlCalzone
                                        @ludino:
                                        Im nächsten Release wird es möglich sein einzustellen, dass keine (bzw. 0-2) Nachkommastellen verwendet werden. Damit dürfte dein Problem behoben werden.
                                          @AlCalzone:
                                          Im nächsten Release wird es möglich sein einzustellen, dass keine (bzw. 0-2) Nachkommastellen verwendet werden. Damit dürfte dein Problem behoben werden. `
                                          Vielen danke, du bist spitze!
                                          • 4
                                            4-Real last edited by
                                            Hallo @AlCazone.
                                            Dein Adapter funktioniert einwandfrei bei mir und da wollte ich erstmal danke sagen!
                                            Jetzt habe ich eine Doofe Frage: Die Bewegungssensoren werden ja auch erkannt, gibt es bald in irgendwelchen weitern Updates die Möglich den Status eines Sensors abzufragen? Also wenn gerade eine Bewegung erkannt wird, das ein Status auf true geht?
                                            Dadurch wäre dann die Möglichkeit umfangreicher mit den Sensoren und etc zusammenzuarbeiten.
                                            Danke schonmal!
                                            471
                                            104235
