    4. Yahka Konfiguration für Garagentor mit Licht
    • juergen2908
      juergen2908 last edited by
      javascript.0 2018-03-01 19:12:55.938 warn at Object. (script.js.common.garagehomekit:10:6)
      javascript.0 2018-03-01 19:12:55.935 warn Wrong type of javascript.0.schalteGaragentor_HK: "number". Please fix, while deprecated and will not work in next versions.
      javascript.0 2018-03-01 19:12:55.932 warn at Object. (script.js.common.garagehomekit:9:7)
      javascript.0 2018-03-01 19:12:55.929 warn Wrong type of javascript.0.LageGaragentor_HK: "number". Please fix, while deprecated and will not work in next versions.
      javascript.0 2018-03-01 19:12:34.327 warn at Object. (script.js.common.garage_hk_konvertiert:8:7)
      javascript.0 2018-03-01 19:12:34.313 warn Wrong type of javascript.0.schalteGaragentor_HK: "number". Please fix, while deprecated and will not work in next versions.
      javascript.0 2018-03-01 19:12:17.190 warn at Object. (script.js.common.garagehomekit:14:7)
      javascript.0 2018-03-01 19:12:17.187 warn Wrong type of javascript.0.LageGaragentor_HK: "number". Please fix, while deprecated and will not work in next versions.
      javascript.0 2018-03-01 19:12:17.184 warn at Object. (script.js.common.garagehomekit:13:7)
      javascript.0 2018-03-01 19:12:17.181 warn Wrong type of javascript.0.schalteGaragentor_HK: "number". Please fix, while deprecated and will not work in next versions.
      javascript.0 2018-03-01 19:11:57.424 warn at Object. (script.js.common.garagehomekit:10:6)
      javascript.0 2018-03-01 19:11:57.421 warn Wrong type of javascript.0.schalteGaragentor_HK: "number". Please fix, while deprecated and will not work in next versions.
      javascript.0 2018-03-01 19:11:57.418 warn at Object. (script.js.common.garagehomekit:9:7)
      javascript.0 2018-03-01 19:11:57.415 warn Wrong type of javascript.0.LageGaragentor_HK: "number". Please fix, while deprecated and will not work in next versions.
      Kann das die Datenpunkte .LageGaragentor_HK und schalteGaragentor_HK nicht passen ? Ich habe die als Logik definiert?
      LG
      • eumats
        eumats last edited by
        LageGaragentor_HK und schalteGaragentor_HK müssen vom Typ number sein, denn es werden ja 0 und 1 eingetragen. Aber das ist nicht der Grund für das von dir beschriebene Verhalten.
        • juergen2908
          wollte nur bescheid geben, dass es bei mir jetzt funktioniert.
          Habe die Datenpunkte auf Numbers umgestellt und noch einen kleinen Fehler im Skript ausgebessert.
          Werde meine Beschreibung noch hier posten, wenn ich mehr Zeit habe.
          Danke für die Unterstützung.
          LG
          Jürgen
            Rookie3 last edited by
            ich bin neu hier und auf diese Lösung gestoßen.
            Das ist genau das was ich bräuchte.
            @ Jürgen kannst du bitte dein komplettes Skript einstellen?
            Wäre dir sehr dankbar, da ich mich noch nicht so gut auskenne und den Fehler, den du ausgebessert hast nicht finden kann.
            Das mit den Datenpunkten habe ich soweit umgesetzt.
            Besten Dank und LG
            • V
              Vossi80 last edited by
              Ich hätte da auch mal eine Frage zum Thema.
              Ich schalte mein Garagentorantrieb mit einem Homematic schaltaktor der kurz (1sec) schaltet. Den Zustand des Tores gibt mir ein Homematic fensterkontakt.
              Wenn ich im Yahka Adapter den Schalter als Lampe einstelle kann ich das Tor such öffnen und schließen. Schöner wäre es natürlich wenn ich alles als Garagentor konfigurieren könnte aber leider bekomme ich es nicht hin. Ist das überhaupt mit den beiden Geräten (schaltaktor und fensterkontakt) so möglich?
              Lg
              • eumats
                Ja, das geht. Wie ist in diesem und in dem "großen" yahka Thread beschrieben…
                • V
                  Heißt ich muss mit einem Script arbeiten und es geht nicht mit den normalen Einstellungen im Adapter.
                  • eumats
                    @Vossi80:
                    Heißt ich muss mit einem Script arbeiten und es geht nicht mit den normalen Einstellungen im Adapter. `
                    Korrekt. Ist aber alles hier beschrieben…
                    • V
                      Danke….dann werde ich mich mal da einlesen
                      • V
                        Hallo, ich bekomme es mit dem Script einfach nicht hin :oops:
                        Irgendwas läuft da nicht richtig. Habe folgende 2 Scripte mit meinen Geräten versucht zu ändern. Wo liegt denn der Fehler??
                        var timeout;
                        on({id: 'hm-rpc.0.NEQ0067397.1.STATE', change: "ne"}, function (obj) {
                          var value = obj.state.val;
                          timeout = setTimeout(function () {
                            if (getState("hm-rpc.0.NEQ0067397.1.STATE").val == false) {
                              // Definiere Tor für HK als geschlossen
                              setState("javascript.0.scriptEnabled.common.LageGaragentor_HK.LageGaragentor_HK"/*LageGaragentor_HK*/, 1, true);
                              setState("javascript.0.scriptEnabled.common.schalteGaragentor_HK.schalteGaragentor_HK"/*schalteGaragentor_HK*/, 1, true);
                            } else {
                              // Definiere Tor für HK als offen
                              setState("javascript.0.scriptEnabled.common.LageGaragentor_HK.LageGaragentor_HK"/*LageGaragentor_HK*/, 0, true);
                              setState("javascript.0.scriptEnabled.common.schalteGaragentor_HK.schalteGaragentor_HK"/*schalteGaragentor_HK*/, 0, true);
                          }, 1000);
                        und….
                        on({id: 'hm-rpc.0.MEQ0165463.4.STATE', change: "ne"}, function (obj) {
                          if (getState("javascript.0.scriptEnabled.common.LageGaragentor_HK.LageGaragentor_HK").val == 1) {
                            // Tor geschlossen
                            if (getState("hm-rpc.0.MEQ0165463.4.STATE").val == true) {
                              // Öffne das Tor
                          } else if (getState("javascript.0.scriptEnabled.common.LageGaragentor_HK.LageGaragentor_HK").val == 0) {
                            // Tor offen
                              // Schließe das Tor
                              // Tor wird geschlossen
                        on({id: 'javascript.0.scriptEnabled.common.schalteGaragentor_HK.schalteGaragentor_HK', change: "ne"}, function (obj) {
                            // Tor geschlossen
                            if (getState("javascript.0.scriptEnabled.common.schalteGaragentor_HK.schalteGaragentor_HK").val == 0) {
                              // Öffne das Tor
                              setState(""hm-rpc.0.MEQ0165463.4.STATE", true);
                            // Tor offen
                            if (getState("javascript.0.scriptEnabled.common.schalteGaragentor_HK.schalteGaragentor_HK").val == 1) {
                              // Schließe das Tor
                              setState("hm-rpc.0.MEQ0165463.4.STATE", true);
                        • eumats
                          Im Raten bin ich nicht so gut. Bitte das Fehlerbild möglichst genau beschreiben…
                          • V
                            @eumats:
                            Im Raten bin ich nicht so gut. Bitte das Fehlerbild möglichst genau beschreiben… `
                            Sorry….. also es passiert rein garnichts wenn ich im HK das Tor öffnen will. Hier mal das Log....
                            • eumats
                              Eigentlich sagt JavaScript ja im Log wo was falsch ist:
                              Hier ist ein “ zuviel…
                              • V
                                @eumats:
                                Hier ist ein “ zuviel… `
                                Sorry , das hätte ich natürlich sehen müssen :roll:
                                hab das geändert aber der Log schreibt noch immer rot. Die "warn" Meldung kommt immer dann wenn das Tor mit dem Schalter auf und zu gemacht wird. Scripte und überhaupt Biobroker ist für mich noch Neuland deshalb bitte nicht erschlagen 😉
                                  Turbo last edited by
                                  Hast Du denn die Datenpunkte
                                  erstellt?
                                  Sieht nicht so aus…
                                  • V
                                    @Turbo:
                                    erstellt?
                                    Sieht nicht so aus… `
                                    Ich habe die beiden Scripte so benannt und erstellt. Hab ich da was falsch verstanden. Was genau ist gemeint mit Datenpunkte erstellen?
                                    • V
                                      Hab ein Fehler gefunden, hatte die Datenpunkte(gehe mal davon aus das du die meintest) nicht richtig erstellt. Jetzt kommt im Log schonmal kein Fehler mehr aber läuft trotzdem noch nicht
                                      • eumats
                                        Poste bitte mal keinen Screenshot, sondern das log selber. Bitte Spoiler und Code-Tag benutzen…
                                        Und bitte, MEHR DETAILS!!! Bei läuft nicht kann ich Dir auch nicht helfen. Bitte beschreiben was du gemacht hast und was nicht geht. Die Bedienung über yahka oder manuell geht nicht bzw. die Anzeige ist falsch...
                                        • V
                                          Hier mal der Log.
                                          8-03-25 09:47:43.892 - info: javascript.0 Start javascript script.js.Intern.javascript_0_scriptEnabled_common_schalteGaragentor_HK_schalteGaragentor_HK
                                          2018-03-25 09:47:43.937 - info: javascript.0 script.js.Intern.javascript_0_scriptEnabled_common_schalteGaragentor_HK_schalteGaragentor_HK: registered 2 subscriptions and 0 schedules
                                          2018-03-25 09:48:08.042 - info: javascript.0 Stop script script.js.Intern.javascript_0_scriptEnabled_common_schalteGaragentor_HK_schalteGaragentor_HK
                                          2018-03-25 09:48:48.514 - warn: javascript.0 State "javascript.0.scriptEnabled.common.LageGaragentor_HK.LageGaragentor_HK" not found
                                          2018-03-25 09:48:48.524 - warn: javascript.0 at Object. (script.js.Intern.javascript_0_scriptEnabled_common_LageGaragentor_HK_LageGaragentor_HK:13:7)
                                          2018-03-25 09:48:48.525 - warn: javascript.0 State "javascript.0.scriptEnabled.common.schalteGaragentor_HK.schalteGaragentor_HK" not found
                                          2018-03-25 09:48:48.527 - warn: javascript.0 at Object. (script.js.Intern.javascript_0_scriptEnabled_common_LageGaragentor_HK_LageGaragentor_HK:14:7)
                                          2018-03-25 09:49:03.529 - warn: javascript.0 State "javascript.0.scriptEnabled.common.LageGaragentor_HK.LageGaragentor_HK" not found
                                          2018-03-25 09:49:03.531 - warn: javascript.0 at Object. (script.js.Intern.javascript_0_scriptEnabled_common_LageGaragentor_HK_LageGaragentor_HK:9:7)
                                          2018-03-25 09:49:03.532 - warn: javascript.0 State "javascript.0.scriptEnabled.common.schalteGaragentor_HK.schalteGaragentor_HK" not found
                                          2018-03-25 09:49:03.533 - warn: javascript.0 at Object. (script.js.Intern.javascript_0_scriptEnabled_common_LageGaragentor_HK_LageGaragentor_HK:10:7)
                                          Betätige ich den Taster fürs Garagentor öffnet/schließt das Tor und im Log schreibt er die "warn" sobald das Tor ganz auf/zu ist also wenn der Homematic Kontakt sein Signal gibt.
                                          Versuche ich über die Home App das Tor zu öffnen (Info im Log)zeigt das Icon mir das sich das Tor öffnent und dieser Kreis dreht und dreht aber leider passiert nichts. Ich hoffe das ich das jetzt vernünftig rüber gebracht habe. Muss du noch was wissen?
                                            Sorry, aber die Meldung "not found" heisst für mich, die Datenpunkte sind nicht da, wo sie sein sollten…
                                            Vielleicht kannst Du mal zeigen, wo diese unter Objekte angelegt sind?
                                            144
                                            17480
