    3. Entwicklung
    4. Adapter: Worx Landroid v2.x.x
      Asrock last edited by
      Okay, danke werde ich testen.
      Und natürlich berichten.
        😄 Hast Recht, mit den Richtigen Zugangsdaten läuft es dann auch :idea:
        • Meistertr
          @Asrock:
          Danke `
          Der Fehler wird in der nächsten version abgefangen und ein wrong pw ausgegeben..
            Ich hoffe das ist keine Blöde Frage,
            Ich habe dein Code:
            [{"tpl":"tplValueListHtml8","data":{"oid":"landroid-s.0.mower.status","count":"12","gestures-offsetX":0,"gestures-offsetY":0,"test_list":"3","value0":" Idle","value1":"Home","value2":"Start Sequenz","style0":"","value3":"Verlasse Zuhause","style1":"","style2":"","value4":"Folge Kabel","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"value5":"Suche Zuhause","value8":"Angehoben","value7":"Mähen","value6":"Suche Kabel","value9":"Gefangen","value10":"Messer blockiert","g_css_border":false,"g_css_background":false,"name":"Robby","g_css_shadow_padding":false,"value11":"Debug","value12":"Fernbedienung","g_visibility":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","class":"","lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"8px","top":"104px","z-index":"6","width":"223px","height":"21px","font-family":"RobotoCondensed-Regular","color":"#FFFFFF","font-size":"large","font-weight":"bold","text-align":"center"},"widgetSet":"basic"}]
            im VIS eingefügt.
            Angezeigt wird mir jetzt nur "IDEL" in der VIS.
            Unter Objekte habe ich Werte drin stehen.
            Was muss ich noch anstellen damit die mir im VIS auch angezeigt werden? Muss ich noch selber Widgets dazu bauen?
              Ich habe mich mal an einem View für meinen WR106Si versucht.
              Die ganzen Rechtecke füllen sich dann mit höheren Werten. Da er erst 5 Min gelaufen ist sieht man da gerade nichts 🙂
              Min 0 und Max 10000
              Wenn jemand gucken will, ich habe meine View man mit ran gehängt.
              4542_view_blitzy.txt
                gerardnableau last edited by
                Das sieht sehr interessant aus. Ich habe mir auch den landroid 106si zugelegt und den landroid Adapter in iobroker installiert, email Adresse und Passwort eingegeben. Folgende Statusmeldungen gibt der Adapter aus: Verbunden mit Host "wahr", Lebenszeichen "wahr", Verbunden mit Landrois S "falsch". Somit komme ich nicht an die Daten vom Landroid, wo ist der Fehler? Landroid App funktioniert und hat WLAN, Landroid ist eingeschaltet, Node.js ist 4.5.x also aktuell, landroid Adapter nochmal gelöscht und neu installiert, komme echt nicht mehr weiter. Vielleicht gibt es ja noch einen Tipp, der mich zur Lösung bringt. 😉
                • Meistertr
                  @gerardnableau:
                  Das sieht sehr interessant aus. Ich habe mir auch den landroid 106si zugelegt und den landroid Adapter in iobroker installiert, email Adresse und Passwort eingegeben. Folgende Statusmeldungen gibt der Adapter aus: Verbunden mit Host "wahr", Lebenszeichen "wahr", Verbunden mit Landrois S "falsch". Somit komme ich nicht an die Daten vom Landroid, wo ist der Fehler? Landroid App funktioniert und hat WLAN, Landroid ist eingeschaltet, Node.js ist 4.5.x also aktuell, landroid Adapter nochmal gelöscht und neu installiert, komme echt nicht mehr weiter. Vielleicht gibt es ja noch einen Tipp, der mich zur Lösung bringt. 😉 `
                  Was steht denn im log?
                    Jack01 last edited by
                    Moin,
                    auch ich habe mir einen WR106SI bestellt. Er wird hoffentlich in der nächsten Woche eintreffen.
                    Zwischenzeitlich habe ich mich schon einmal an die Erstellung einer View auf Basis von Asrock rangemacht.
                    Dazu eine Frage: In dem in dem Beitrag angehängten File (View_Blitzy.txt) steht ein count von 12 für den Mäher Status.
                    "e00006": {
                    "tpl": "tplValueListHtml8",
                    "data": {
                    "oid": "landroid-s.0.mower.status",
                    "count": "12",
                    "gestures-offsetX": 0,
                    "gestures-offsetY": 0,
                    Ich kann aber max. den Wert 10 eingeben. Ich nutze die VIS Version 1.1.1
                    Hat jemand hier einen Tipp für mich?
                    Hans-Jürgen
                      Ahh,
                      hab's gefunden. Man kann mit den Pfeiltasten keinen höheren Wert als 10 einstellen. Aber man kann die Zahl 12 direkt in das Feld der Werteanzahl eingeben.
                      Hans-Jürgen
                        Sven last edited by
                        hat schon jemand ein widget für den Landroid Adapter erstellt. Habe Heute meinen Worx Landroid M in Betrieb genommen und auch den Adapter instaliert.
                        Wenn schon mal jemand ein Widget für die Kommunikation erstellt hat und ich das nutzen könnte wäre toll.
                          So im Anhang mal der log mit den Fehlermeldungen, das richtige PW wird sofort erkannt. Trotzdem habe ich keine Verbindung zum Landroid und auch nicht zu den Werten
                          landroid-s.0 2018-03-25 23:11:51.161 info Logged in as geraldstrack@gmx.de API Token Set to : QNVMCysLU0ClsLtCtIWphnRQMd8NQmgA
                          landroid-s.0 2018-03-25 23:11:50.608 info starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.landroid-s, node: v6.13.1
                          landroid-s.0 2018-03-25 23:11:46.395 info terminating
                          landroid-s.0 2018-03-25 23:11:46.363 info cleaned everything up…
                          landroid-s.0 2018-03-25 23:11:10.298 error wrong email or password!
                          landroid-s.0 2018-03-25 23:11:09.754 info starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.landroid-s, node: v6.13.1
                          landroid-s.0 2018-03-25 23:11:05.573 info terminating
                          landroid-s.0 2018-03-25 23:11:05.556 info cleaned everything up...
                          hoffe man kann mir irgendwie helfen.
                          • Meistertr
                            @gerardnableau:
                            hoffe man kann mir irgendwie helfen. `
                            stelle den adapter bitte einmal auf debug um (im reiter instanzen) und schicke mir dann den log Auszug bitte per pn. hier im log steht, dass email oder passwort falsch ist.
                              StefanH 0 last edited by
                              Hallo, habe gestern meinen Worx Landroid M1000i WIFI (WG796E.1) wieder für die neue Saison in Betrieb genommen und dann versucht den Adapter für den Mäher zu nutzen. Da ich neu im Thema bin tauchen auch direkt ein paar Fragen auf. Es gibt ja zwei Adapter einen "Worx Landroid adapter" und einen "Worx Landroid S". Habe zunächst den ersten ausprobiert. Dieser verlangt ja als Parameter die IP-Adresse und den PIN. Dieser liefert aber lediglich Werte für die Datenpunkte lastsync, connect und bordercut.
                              Beim zweiten Adapter wird als Parameter eine eMail-Adresse und ein Password verlangt. Ich verstehe das so, dass dieser Adapter über eine Worx-Cloud läuft. Nun habe ich aber bei der Registrierung meines Mäher bei Worx wegen der Garantieverlängerung lediglich meine Seriennummer und meine eMail-Adresse angegeben. Einen Account habe ich bei Worx bisher nicht benötigt.
                              Welchen Adapter sollte ich sinnvollerweise für mein Modell verwenden?
                              • Meistertr
                                @StefanH:
                                Welchen Adapter sollte ich sinnvollerweise für mein Modell verwenden? ` Das sagt auch schon der Name, da du einen m hast, kommt der s adapter nicht in Frage. Die m und l Modelle haben eine lokale API, die s Modelle nur eine cloud Verbindung.
                                Gesendet von meinem Handy
                                  Ok, Danke für die schnelle Rückmeldung. Dann gleich die nächste Frage. Warum liefert der „Worx Landroid Adapter“ bei mir denn kein Werte für die Datenpunkte, obwohl er mit meinem Mäher connecten konnte?
                                    Das Problem hat sich bei mir gelöst, ich habe nun plötzlich Daten.
                                    Diese kamen scheinbar erst mit einer gewissen Verzögerung!
                                      Hallo, bei mir liefert der Datenpunkt: Landroid.0.mower.lastsync eine falsche Uhrzeit, ca. -2 Stunden Abweichung zur tatsächlichen Uhrzeit. Wenn ich die aktuelle Uhrzeit des PI über JavaScript abfrage erhalte ich die korrekte Uhrzeit.
                                      Kennt jemand den Grund dafür?
                                      • Webranger
                                        Webranger last edited by
                                        Die 2 Stunden Abweichung habe ich bei mir auch stehen.
                                        • Webranger
                                          @Meistertr:
                                          @Stoni:
                                          @Meistertr tolle Arbeit. Danke für Deine Mühe.
                                          Ich versuche gerade, die Daten vom Landroid wieder in VIS einzupflegen. Ich wollte gerne den aktuellen Status darstellen. Als "mäht", "Home", "blockiert" etc.
                                          Welches Widget kann ich dafür nehmen? Beim Basic String werden nur die Zahlen angezeigt…
                                          Gruss Stoni `
                                          damit gehts:
                                          Das widget geht ja so nur für die S modele, ich habe ein M model und würde das auch gerne im VIS sehen wie mach ich das?
                                          Unter objekte hab ich nicht Wert 1 bis 12 stehen sondern : Status Text home usw
                                          Gruss Danyel
                                          edit Lösung gefunden und setzt jetzt eigenen Datenpunkte dafür
                                          • Webranger
                                            Werden bei euch die werte bei Distanz angezeigt?
                                            Wenn mein M in der Station steht wird mir "-9m" angezeigt.
                                            Ansonsten wilde Zahlen "-20446" oder "938778" ein Tag vorher.
                                            1194
                                            452745
