    4. [GELÖST] Frage: Batteriestatus bzw. Ladezustand
      tempestas last edited by
      Dafür ist das Forum ja da 🙂
      Ich war nur verwirrt wegen der Frage nach dem Skript, das ja direkt oben steht 😉
        tomdeboom last edited by
        sorry eben erst gesehen, also hier erstmal das Widget:
        Zitat:
        [{"tpl":"tplStatefulImage8","data":{"oid":"javascript.0.Batterieanzeige","g_fixed":false,"g_visibility":true,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","count":"6","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src_0":"/vis.0/main/Icon/Batterie/battery_horizontal_10percent.png","src_1":"/vis.0/main/Icon/Batterie/battery_horizontal_20percent.png","src_2":"/vis.0/main/Icon/Batterie/battery_horizontal_40percent.png","src_3":"/vis.0/main/Icon/Batterie/battery_horizontal_60percent.png","src_4":"/vis.0/main/Icon/Batterie/battery_horizontal_80percent.png","src_5":"/vis.0/main/Icon/Batterie/battery_horizontal_full.png","src_6":"/vis.0/main/Icon/Batterie/battery_horizontal_charging.png","src_7":"/icons-addictive-flavour-png/battery/battery_horizontal_charging.png"},"style":{"left":"1090px","top":"-8px","width":"40px","height":"40px","z-index":"2","font-family":"RobotoCondensed-Regular","font-variant":"small-caps","font-style":"normal","font-weight":"normal"},"widgetSet":"basic"}]
        Hier das Script:
        // Batterieanzeige
        "*/20 * * * *"
        const idBatt = 'paw.0.FlurTab.info.battery.level'; // Batterielevel in %
        const idPlug = 'hm-rpc.1.OEQ0171991.1.STATE'; // Ladegerät ein
        const idVis = 'Batterieanzeige'; // Für Vis
        createState(idVis, 0, {
        type: 'number',
        min: 0,
        max: 7,
        role: 'level',
        states: {
        0: 'leer',
        1: '20 %',
        2: '40 %',
        3: '60 %',
        4: '50 %',
        5: 'voll',
        6: 'Ladegerät'
        var level = getState(idBatt).val;
        var plug = getState(idPlug).val;
        function batt() {
        var state = 5; // full
        if(level <= 80) state = 4; // 80 %
        if(level <= 60) state = 3; // 60 %
        if(level <= 40) state = 2; // 40 %
        if(level <= 30) state = 1; // 20 %
        if(level <= 22) state = 0; // empty
        if(plug) state = 6; // Ladegerät ein
        setState(idVis, state, true);
        batt(); // Skriptstart
        on(idBatt, function(dp) {
        level = dp.state.val;
        batt();
        on(idPlug, function(dp) {
        plug = dp.state.val;
        batt();
        Das Script habe ich folgendermaße abgespeichert:
        Die icons findest du unter: /opt/iobroker/iobroker-data/files/icons-addictive-flavour-png/bbattery
        die Abfrage des Akkustand läuft über PAW. "paw.0.FlurTab.info.battery.level"
        siehe hier: http://forum.iobroker.net/viewtopic.php?f=24&t=6274
        Über mein Scirpt wird dann ein Schaltaktor "hm-rpc.1.OEQ0171991", Ein bzw. Aus geschaltet, der wiederum versorgt mein USB Netzteil.
        Gruß Tom
          bimbes112 last edited by
          erstmal Danke für die Erklärungen.
          Habe versucht dieses auch bei mir einzurichten.
          Leider mag es noch nicht ganz. 😮
          Unter Objekte, PAW.0 ist der Level auf dem aktuell ausgelesenen Stand des Tablets.
          Die Funktion der verschiedenen Batterieanzeigen auf der VIS Oberfläche funktioniert aus.
          Was noch nicht geht ist das die HM-Steckdose eingeschaltet wird.
          Habt Ihr eine Idee woran es liegen könnte?
          // Batterieanzeige
          "*/20 * * * *"
          const idBatt = 'paw.0.Tablet.info.battery.level'; // Batterielevel in %
          const idPlug = 'hm-rpc.2.MEQ0257599.1.STATE'; // Ladegerät ein
          type: 'number',
          min: 0,
          max: 7,
          role: 'level',
          states: {
          0: 'leer',
          1: '20 %',
          2: '40 %',
          3: '60 %',
          4: '50 %',
          5: 'voll',
          6: 'Ladegerät'
          function batt() {
          batt();
          batt();
          Vielen Dank
          Jürgen
            Hallo Jürgen,
            "MEQ0257599" ist doch ein Fenstersensor??? Oder was ist das für ein Gerät?
            Gruß Tom
              Hallo Tom,
              nein das ist eine HM-ES-PMSw1-Pl. Das ist die schaltbare Homematic Steckdose.
              Jürgen
                Hi Jürgen,
                ok, dann sollte es gehen.
                Kannst du mal ein Bildschirmfoto von dem Objekt in iobroker für die Steckdose hier posten?
                Gruß,
                Tom
                  ist zwar kein Screenshot hoffe aber das es auch geht:
                  INHIBIT HM-ES-PMSw1-Pl MEQ0257599:1.INHIBIT state state.inhibit Treppenhaus Strom false
                  INSTALL_TEST HM-ES-PMSw1-Pl MEQ0257599:1.INSTALL_TEST state indicator Treppenhaus Strom
                  ON_TIME HM-ES-PMSw1-Pl MEQ0257599:1.ON_TIME state timer.off Treppenhaus Strom 0 s
                  STATE HM-ES-PMSw1-Pl MEQ0257599:1.STATE state state Treppenhaus Strom false
                  WORKING HM-ES-PMSw1-Pl MEQ0257599:1.WORKING state indicator.working Treppenhaus Strom false
                  Jürgen
                    Hi Jürgen,
                    und das steht bei dir alles unter "hm-rpc.2" ?
                    Gruß,
                    Tom
                      wenn ich die Steckdose von Hand einschalte zeigt die VIS Oberfläche an das der Akku geladen wird.
                      Es geht somit nur das Einsachalten und vermutlich das Ausschalten der HM Steckdose nicht.
                      Muss ich in der HM noch was einstellen?
                      Jürgen
                        wenn du die Stechkdose per Hand einschaltest, welcher State zeigt "true" an?
                        Gruß,
                        Tom
                          welchen State meinst Du ?
                            Hi Jürgen,
                            das meinte ich mit State, dort wo jetzt "false" steht müsste bei einschalten der Steckdose nach einer gewissen Zeit "true" stehen.
                            @bimbes112:
                            Jürgen `
                            oder so:
                            Gruß,
                            Tom
                              wie bei Dir. State geht auf true die beiden anderen bleiben auf false.
                              Jürgen
                                Hallo Jürgen,
                                was wird bei dir unter "Objekte/Javascript.0/Batterieanzeige" angezeigt?
                                Ist hier im Bild blau markiert:
                                Gruß,
                                Tom
                                  hier der Zustand während des Ladens
                                    paul53 last edited by
                                    @bimbes112:
                                    hier der Zustand während des Ladens `
                                    Das ist nicht der Zustand während des Ladens, sondern der Zustand des Scripts "common.Akku.Batterieanzeige". Falls es kein Script ist, folgende Warnung: Eigene Datenpunkte niemals unter "scriptEnabled" anlegen !
                                      dort wo Ladegerät(6) steht meinte ich, sieht aber ok aus.
                                      Mach mir bitte nochmal eine Bildschirmkopie von dem Objekt der Steckdose, bitte aber komplett aufgeklappt.
                                      Und eine Bilschitmkopir von dem Objekt "paw.0", hier bitte komplett "info/battery".
                                      Und setzte nochmal dein script hier rein.
                                      Gruß,
                                      Tom
                                        @paul53:
                                        @bimbes112:
                                        hier der Zustand während des Ladens Das ist nicht der Zustand während des Ladens, sondern der Zustand des Scripts "common.Akku.Batterieanzeige". Falls es kein Script ist, folgende Warnung: Eigene Datenpunkte niemals unter "scriptEnabled" anlegen !
                                        Hallo Paul,
                                        das script steht doch direkt unter javascript.0 und nicht unter "scriptEnabled".
                                        Gruß,
                                        Tom
                                          Wenn nicht das markierte Objekt, sondern das unterste Objekt im Bild der Datenpunkt für den Ladezustand ist, ist es in Ordnung.
                                            @paul53:
                                            Wenn nicht das markierte Objekt, sondern das unterste Objekt im Bild der Datenpunkt für den Ladezustand ist, ist es in Ordnung. `
                                            Ist er 🙂
                                            68
                                            22952
