    4. Adapter SNMP Drucker, Synology, QNAP etc auslesen
    • Segway
      Segway last edited by
      Sowas könnte ich mir vorstellen - müsst ihr sagen –> das ist aber nur eine Handvoll erst. Die anderen interessanten kommen noch. Mache ich aber erst wenn ich weiss wie ich es machen soll
      QNAP
      Name						OID										Type					Access			MIB Module		Description
      systemInfo				.1.3.6.1.4.1.24681.1.2			NAS-MIB
      systemCPU-Usage		.1.3.6.1.4.1.24681.1.2.1		OCTET STRING			read-only		NAS-MIB	System CPU usage
      systemTotalMem			.1.3.6.1.4.1.24681.1.2.2		OCTET STRING			read-only		NAS-MIB	System total memory
      systemFreeMem			.1.3.6.1.4.1.24681.1.2.3		OCTET STRING			read-only		NAS-MIB	System free memory
      systemUptime			.1.3.6.1.4.1.24681.1.2.4		TIMETICKS				read-only		NAS-MIB	The amount of time since this host was last initialized.  Note that this is different from sysUpTime in the SNMPv2-MIB [RFC1907] because sysUpTime is the uptime of the network management portion of the system.
      cpu-Temperature			.1.3.6.1.4.1.24681.1.2.5		OCTET STRING			read-only		NAS-MIB	CPU temperature
      systemTemperature		.1.3.6.1.4.1.24681.1.2.6		OCTET STRING			read-only		NAS-MIB	System temperature
      ifNumber				.1.3.6.1.4.1.24681.1.2.8		INTEGER					read-only		NAS-MIB	The number of network interfaces (regardless of their current state) present on this system.
      systemIfTable			.1.3.6.1.4.1.24681.1.2.9		SEQUENCE OF IfEntryDef	not-accessible	NAS-MIB	A list of interface entries.  The number of entries is given by the value of IfNumber.
      ifEntry					.1.3.6.1.4.1.24681.1.2.9.1		IfEntryDef				not-accessible	NAS-MIB	An interface entry containing objects at the subnetwork layer and below for a particular interface.
      ifIndex					.1.3.6.1.4.1.24681.1.2.9.1.1	INTEGER					read-only		NAS-MIB	A unique value for each interface.  Its value ranges between 1 and the value of IfNumber.  The value for each interface must remain constant at least from one re-initialization of the entity's network management system to the next re- initialization.
      ifDescr					.1.3.6.1.4.1.24681.1.2.9.1.2	OCTET STRING			read-only		NAS-MIB	A textual string containing information about the interface.  This string should include the name of the manufacturer, the product name and the version of the hardware interface.
      ifPacketsReceived		.1.3.6.1.4.1.24681.1.2.9.1.3	COUNTER					read-only		NAS-MIB	System packets received.
      ifPacketsSent			.1.3.6.1.4.1.24681.1.2.9.1.4	COUNTER					read-only		NAS-MIB	System packets sent.
      ifErrorPackets			.1.3.6.1.4.1.24681.1.2.9.1.5	COUNTER					read-only		NAS-MIB	System error packets.
      hdNumber				.1.3.6.1.4.1.24681.1.2.10		INTEGER					read-only		NAS-MIB	The number of hard drive slots.
      systemHdTable			.1.3.6.1.4.1.24681.1.2.11		SEQUENCE OF HdEntryDef	not-accessible	NAS-MIB	A list of interface entries.  The number of entries is given by the value of HdNumber.
      hdEntry					.1.3.6.1.4.1.24681.1.2.11.1		HdEntryDef				not-accessible	NAS-MIB	An interface entry containing objects at the subnetwork layer and below for a particular interface.
      hdIndex					.1.3.6.1.4.1.24681.1.2.11.1.1	INTEGER					read-only		NAS-MIB	A unique value for each hard disk.  Its value ranges between 1 and the value of IfNumber.  The value for each interface must remain constant at least from one re-initialization of the entity's network management system to the next re- initialization.
      hdDescr					.1.3.6.1.4.1.24681.1.2.11.1.2	OCTET STRING			read-only		NAS-MIB	A textual string containing information about the interface.  This string should include the name of the manufacturer, the product name and the version of the hardware interface.
      hdTemperature			.1.3.6.1.4.1.24681.1.2.11.1.3	OCTET STRING			read-only		NAS-MIB	Hard disk temperature.
      hdStatus				.1.3.6.1.4.1.24681.1.2.11.1.4	INTEGER					read-only		NAS-MIB	HDD status. 0:not availible, 1:availible.
      hdModel					.1.3.6.1.4.1.24681.1.2.11.1.5	OCTET STRING			read-only		NAS-MIB	Hard disk model.
      hdCapacity				.1.3.6.1.4.1.24681.1.2.11.1.6	OCTET STRING			read-only		NAS-MIB	Hard disk capacity.
      hdSmartInfo				.1.3.6.1.4.1.24681.1.2.11.1.7	OCTET STRING			read-only		NAS-MIB	Hard disk SMART information.
      modelName				.1.3.6.1.4.1.24681.1.2.12		OCTET STRING			read-only		NAS-MIB	Model name
      hostName				.1.3.6.1.4.1.24681.1.2.13		OCTET STRING			read-only		NAS-MIB	Model name
      sysFanNumber			.1.3.6.1.4.1.24681.1.2.14		INTEGER					read-only		NAS-MIB	The number of system fan (regardless of their current state) present on this system.
      systemFanTable			.1.3.6.1.4.1.24681.1.2.15		SEQUENCE OF SysFanEntryDef	not-accessible	NAS-MIB	A list of interface entries.  The number of entries is given by the value of SysFanNumber.
      sysFanEntry				.1.3.6.1.4.1.24681.1.2.15.1		SysFanEntryDef			not-accessible	NAS-MIB	An system fan entry containing objects at the subnetwork layer and below for a particular interface.
      sysFanIndex				.1.3.6.1.4.1.24681.1.2.15.1.1	INTEGER					read-only		NAS-MIB	A unique value for each system fan. Its value ranges between 1 and the value of SysFanNumber.  The value for each interface must remain constant at least from one re-initialization of the entity's network management system to the next re- initialization.
      sysFanDescr				.1.3.6.1.4.1.24681.1.2.15.1.2	OCTET STRING			read-only		NAS-MIB	A textual string containing information about the interface.  This string should include the name of the manufacturer, the product name and the version of the hardware interface.
      sysFanSpeed				.1.3.6.1.4.1.24681.1.2.15.1.3	OCTET STRING			read-only		NAS-MIB	System fan speed.
      sysVolumeNumber			.1.3.6.1.4.1.24681.1.2.16		INTEGER					read-only		NAS-MIB	The number of system volumes (regardless of their current state) present on this system.
      systemVolumeTable		.1.3.6.1.4.1.24681.1.2.17		SEQUENCE OF SysVolumeEntryDef	not-accessible	NAS-MIB	A list of volume entries.  The number of entries is given by the value of SysVolumeNumber.
      sysVolumeEntry			.1.3.6.1.4.1.24681.1.2.17.1		SysVolumeEntryDef		not-accessible	NAS-MIB	An system volume entry
      sysVolumeIndex			.1.3.6.1.4.1.24681.1.2.17.1.1	INTEGER					read-only		NAS-MIB	A unique value for each system volume. Its value ranges between 1 and the value of SysVolumeNumber.  The value for each volume must remain constant at least from one re-initialization of the entity's volume system to the next re-initialization.
      sysVolumeDescr			.1.3.6.1.4.1.24681.1.2.17.1.2	OCTET STRING			read-only		NAS-MIB	A textual string containing information about the volume.
      sysVolumeFS				.1.3.6.1.4.1.24681.1.2.17.1.3	OCTET STRING			read-only		NAS-MIB	System Volume file system.
      sysVolumeTotalSize		.1.3.6.1.4.1.24681.1.2.17.1.4	OCTET STRING			read-only		NAS-MIB	System Volume total size.
      sysVolumeFreeSize		.1.3.6.1.4.1.24681.1.2.17.1.5	OCTET STRING			read-only		NAS-MIB	System Volume free size.
      sysVolumeStatus			.1.3.6.1.4.1.24681.1.2.17.1.6	OCTET STRING			read-only		NAS-MIB	System Volume status.
        Stuti last edited by
        ich habe SNMP eben mal auf Windows 10 und Debian aktiviert. Die Uptime lässt sich immer gut auslesen.
        Bei allen System gibt es eine C Partition. Die Größe ist in einer OID und müsste mit der Blockgröße multipliziert und dann von Byte in GB umgerechnet werden. Soweit die Theorie…
        hrStorageDescr.1; .1.3.6.1.2.1.25.2.3.1.3.1
        hrStorageSize.1; .1.3.6.1.2.1.25.2.3.1.5
        hrStorageUsed.1; .1.3.6.1.2.1.25.2.3.1.6
        Beim Adapter kommt folgende Meldung:
        Error session.get: RequestFailedError: NoSuchName: 1.3.6.1.2.1.25.2.3.1.5
        Im MIB Browser werden die alle mit Werten angezeigt.
        Noch etwas, sobald ich versuche eine Sortierung in der Instanzkonfiguration vorzunehmen schmeißt er alle Werte raus. Die Zeilen bleiben alle da, aber sind leer.
        Gibt es auch irgendwo eine Konfigurationsdatei, die ich bearbeiten könnte? Oder wo wird die Konfiguration im allgemeinen abgespeichert?
        Mit nen bisschen Feintunning wird das ein super Adapter, der die wichtigsten Werte schön grafisch anzeigen kann.
          apollon77 last edited by
          @marcolotti: vllt im github das Wiki aktivieren in deinem Adapter repo und dort direkt die Listen einstellen ?! Du kannst glaube ich erlauben das Leute Wiki frei editieren.
          Oder Starte ne Google docs Tabelle mit freiem Zugriff per Link?!
            skraw.iobroker last edited by
            Also das ist jetzt snmp Client Seite.
            Gibt es denn einen Adapter mit dem man "von aussen" irgendwelche Werte von Objekten per SNMP abfragen kann - also SNMP Server?
            Das waere beispielsweise fuer Temperatur-Messkurven interessant …
              Adnim last edited by
              cooler adapter, wäre auch schön wenn er die NAS von Asustor unterstützen würde.
              Anbei die MIB dateien davon
              4760_asustor_mib.zip
              • cash
                Ich habe mich jetzt auch mit dem Adapter befasst. Wirklich super Arbeit. Leider müllt der Adapter meine Log voll wenn das IP Gerät nicht erreichbar ist.
                In meinen Fall habe ich neben dem Synology einen HP Officejet eingepflegt. Der Adapter liefert mir auch brav gedruckte Seiten, Tintenstände usw. Nur läuft der Drucker bei mir nicht 24/7 sondern eher abends ein paar Stunden. Ich fände es praktisch wenn der Adapter nur abfragen macht wenn das Gerät pingbar ist. Z. B. Über ein Feld im iobroker. Der Pingadapter füllt ja brav alle möglichen IP Komponenten mit true wenn das Gerät erreichbar ist…
                  bekomme bei meinen Brother nur Minus Werte. Weis wer die Richtige OID?
                    claus1993 last edited by
                    versuche bei meiner Synology DS207+ die Werte für CPU Last und die Festplatte auszulesen. Die Codes aus der offiziellen MIB Liste von Synology funktionieren bei der DS207+ leider nicht.
                    Hat hier eventuell jemand alternative Codes die ich zum Auslesen von der CPU Last und der Festplatten nutzen kann?
                    VG Claus
                      @sigi234:
                      bekomme bei meinen Brother nur Minus Werte. Weis wer die Richtige OID? `
                      Habe auch einen Brother und bekomme auch diese Minus Werte. Soweit ich es kenne bedeutet es das der Füllzustand -3 eine leere Kartusche bedeutet. Voll wäre meines Wissens eine "0". Was mich hier jedoch irritiert ist das ich bei der Abfrage der Max Werte für meine Kartusche eine -2 bekomme.
                      VG Claus
                        eine leere Kartusche kann nicht sein, der Drucker ist Neu.
                        • Webranger
                          Webranger last edited by
                          Kann ich beim synology NAS auch die platten auslesen, bzw im vis dann anzeigen lassen 47% frei oder so
                            Schau mal weiter oben in diesem Thread da war einiges zu synology.
                              @sigi234:
                              eine leere Kartusche kann nicht sein, der Drucker ist Neu. `
                              Meine Kartuschen sind leer, ich habe die gleichen Einstellungen und bekomme auch -3 angezeigt 😮
                              Muss eh bald mal die Kartuschen wechseln und bin dann gespannt was mir angezeigt wird….
                              • Webranger
                                @apollon77:
                                Schau mal weiter oben in diesem Thread da war einiges zu synology. `
                                Hab ich gesehen aber leider kein Wert für HDD füllstand.
                                Oder ich hab es überlesen
                                  Kuddel last edited by
                                  ich hab mir heute den Adapter auch installiert und konnte schon enige Werte von meinem QNAP-Backup-NAS abfragen.
                                  In wie weit kann ich Windows abfragen, da ich meine Daten auf einem Windows Server 2012R2 habe.
                                  Ich habe auf einer Win10 VM mal den SNMP Service hinzugefügt, "public" als Community eingetragen und die IP vom ioBroker freigegeben.
                                  Leider funktioniert die Abfrage der Uptime (.1.3.6.1.2.1.1.3.0) nicht.
                                  Mit dem MIB Browser bekomme ich auch ein Timeout.
                                  Jemand eine Idee, was das Problem sein könnte?
                                    Habe mal für meinen Brother Laserdrucker die Werte angefordert und bekomme als aktuellen Stand den Wert "-3" und als Zustand wenn Voll den Wert -2
                                    Zustand, wenn voll:
                                    root@nagios:~# snmpget -v1 -c public 192.168.120.31 1.3.6.1.2.1.43.11.1.1.8.1.1
                                    Antwort: SNMPv2-SMI::mib-2.43.11.1.1.8.1.1 = INTEGER: -2
                                    Aktueller Stand:
                                    root@nagios:~# snmpget -v1 -c public 192.168.120.31 1.3.6.1.2.1.43.11.1.1.9.1.1
                                    Antwort: SNMPv2-SMI::mib-2.43.11.1.1.9.1.1 = INTEGER: -3
                                    Damit ich das in meiner VIS anzeigen kann wollte ich es in Prozentwerte umrechnen. Meine Idee war folgende Berechnung;
                                    Füllstand = Stand * 100 / Voll
                                    Füllstand = -2 * 100 / -3
                                    Füllstand = -200 / -3
                                    Füllstand = 66,67
                                    Soweit ist das für mich verständlich, verstehe nur nicht das die Kartusche als Größe -2 und als aktuellen Stand -3 hat. Wenn ich das mit der Formel berechne ergibt sich ein Füllstand von 150% :shock:
                                    Irgendwo habe ich einen Denkfehler und hoffe auf eure Unterstützung.
                                    Danke und Grüße,
                                    Claus
                                    • RK62
                                      RK62 last edited by
                                      Soweit ich weiß, lassen sich die Füllstände bei BROTHER Druckern nicht via SNMP auslesen.
                                      Ich habe das mit das mit dem Parser von Website des Druckers ausgelesen:
                                      `Seite: http://<ip-des-druckers>/general/information.html?kind=item
                                      RegEx: \(C\)\*\*<\/dt></ip-des-druckers>`
                                      <dd>`\(([0-9.]*)%\)` Für die anderen Farben BK, Y, M  einsetzen.
                                      Gruß, Ralf</dd>
                                      • RK62
                                        RK62 last edited by
                                        Ich habe noch das Problem, dass Dezimalwerte scheinbar nicht ausgelesen werden können.
                                        Siehe https://github.com/CTJaeger/ioBroker.snmp/issues/16
                                        Ist das bei euch auch so oder ist es ein Problem meiner ioBroker-Installation?
                                        Gruß, Ralf
                                          @RK62:
                                          Gruß, Ralf
                                          </dd>
                                          Hallo Ralf,
                                          wie funktioniert das genau? Wo BK,Y,M einsetzen?
                                          Sigi
                                          • RK62
                                            RK62 last edited by
                                            • parser Adapter im Admin installieren und eine Instanz erzeugen
                                            • http:// <ip des/druckers="">im Browser aufrufen und zur Seite mit den Tonerständen navigieren. Bei mir ist das die Seite Wartungsinformationen http://10.0.0.204/general/information.html?kind=item</ip>
                                            • Diese Zeilen werden dann gesucht und ausgelesen:
                                            ![](https://i.imgur.com/Pb9yLTT.png)~~![](</s><URL url=)https://i.imgur.com/Pb9yLTT.png" />~~  ~~*   Dann im Parser die 4 Zeilen für die Farben anlegen:
                                            ![](https://i.imgur.com/kRZXHR8.png)~~![](</s><URL url=)https://i.imgur.com/kRZXHR8.png" />
                                            Die RegEx-Parameter lauten bei mir wie folgt:
                                            `Cyan:    \(C\)\*\*<\/dt>
                                            <dd>\(([0-9.]*)%\)
                                            Magenta: \(M\)\*\*<\/dt></dd>
                                            <dd>\(([0-9.]*)%\)
                                            Gelb:    \(Y\)\*\*<\/dt></dd>
                                            <dd>\(([0-9.]*)%\)
                                            Black:   \(BK\)\*\*<\/dt></dd>`
                                            <dd>`\(([0-9.]*)%\)`</dd>
                                            ```~~  ~~*   Die RegEx-Parameter kann man hier am besten testen: [https://regex101.com](https://regex101.com)
                                            Gruß, Ralf~~~~
                                            snmp
                                            85
                                            365
                                            83038
