[gelöst] JSON-Tabelle mit js.script triggern
Sorry, vor function() muss ein Komma anstelle der schließenden Klammer.
sched1 = schedule(t[1] + ' ' + t[0] + ' * * *', function() { -
kein Problem,
Danke für die schnelle Hilfe…
Ich habe das Script jetzt mal getestet aber irgendwie wird die Bewässerungszeit nicht gesetzt.
Ich habe gestern abend einen Terminn für heute früh gesetzt, weil ich gesehen hatte das Du einen Schedule
täglich kurz nach 0:00Uhr gesetzt hast. Aber auch das hat nichts bewirkt.
ich hätte auch noch eine anderen JSON-String...
{"0":{"Bew1":{"wecken":false,"nachricht":0,"dauer":90,"stunde":5,"minute":25},"Bew2":{"wecken":false,"nachricht":"","dauer":0,"stunde":0,"minute":0},"Optionen":{"Active":true,"Option1":"","Option2":"","Option3":""}},"1":{"Bew1":{"wecken":true,"nachricht":1,"dauer":90,"stunde":5,"minute":30},"Bew2":{"wecken":true,"nachricht":"","dauer":0,"stunde":0,"minute":0},"Optionen":{"Active":true,"Option1":"","Option2":"","Option3":""}},"2":{"Bew1":{"wecken":true,"dauer":90,"nachricht":1,"stunde":5,"minute":"25"},"Bew2":{"wecken":true,"nachricht":"","dauer":0,"stunde":0,"minute":0},"Optionen":{"Active":true,"Option1":"","Option2":"","Option3":""}},"3":{"Bew1":{"wecken":true,"nachricht":0,"dauer":90,"stunde":5,"minute":25},"Bew2":{"wecken":true,"nachricht":"","dauer":0,"stunde":0,"minute":0},"Optionen":{"Active":true,"Option1":"","Option2":"","Option3":""}},"4":{"Bew1":{"wecken":true,"nachricht":0,"dauer":90,"stunde":5,"minute":25},"Bew2":{"wecken":true,"nachricht":"","dauer":0,"stunde":0,"minute":0},"Optionen":{"Active":true,"Option1":"","Option2":"","Option3":""}},"5":{"Bew1":{"wecken":false,"nachricht":2,"dauer":5,"stunde":23,"minute":10},"Bew2":{"wecken":false,"nachricht":"","dauer":0,"stunde":0,"minute":0},"Optionen":{"Active":true,"Option1":"","Option2":"","Option3":""}},"6":{"Bew1":{"wecken":true,"nachricht":2,"dauer":90,"stunde":9,"minute":0},"Bew2":{"wecken":true,"nachricht":"","dauer":0,"stunde":0,"minute":0},"Optionen":{"Active":true,"Option1":"","Option2":"","Option3":""}}}in diesem Fall sind keine Wochentage worhanden sondern nur 0-6…
eventuell ist der ja leichter zu händeln...
Ich habe das Script jetzt mal getestet aber irgendwie wird die Bewässerungszeit nicht gesetzt. `
Dann füge mal Logs ein, um zu sehen, woran es hakt.const idJSON = 'javascript.0.Bewässerung.Ventil_1.BewaesserungsPlan'; const idBew = 'javascript.0.Bewässerung.Ventil1.LaufzeitVentil1'; var debug = true; var sched1 = null; var sched2 = null; var json = getState(idJSON).val; function zeiten() { var arr = JSON.parse(json); // Array aus 7 Elementen (Wochentage) var now = new Date(); var wd = now.getDay() - 1; // Wochentag (0 = Montag) if(wd < 0) wd = 6; // Sonntag if(debug) log('Wochentag: ' + wd); var obj = arr[wd]; if(debug) log(JSON.stringify(obj)); if(sched1) clearSchedule(sched1); if(debug) log('Active: ' + obj.Active + ' Typ: ' + typeof obj.Active); if(debug) log('Bew1 um: ' + obj.Bew1 + ' für ' + obj.Bew1_time + ' Minuten ' + ' Typ: ' + typeof obj.Bew1_time); if(obj.Active == "true" && obj.Bew1_time) { // ist Active ein String ? var t = obj.Bew1.split(':'); sched1 = schedule(t[1] + ' ' + t[0] + ' * * *', function() { setState(idBew, obj.Bew1_time); if(debug) log('Bewässerung1 gestartet'); }); } if(sched2) clearSchedule(sched2); if(obj.Active == "true" && obj.Bew2_time) { t = obj.Bew2.split(':'); sched2 = schedule(t[1] + ' ' + t[0] + ' * * *', function() { setState(idBew, obj.Bew1_time); }); } } zeiten(); // Skriptstart schedule('1 0 * * *', zeiten); // kurz nach Mitternacht // Änderung des JSON-Strings on(idJSON, function(dp) { json = dp.state.val; zeiten(); });EDIT: Fehlendes + korrigiert
so funktioniert jetzt…
ein Fehler habe ich gefunden:
if(debug) log('Bew1 um: ' + obj.Bew1 + ' für ' + obj.Bew1_time ' Minuten ' + ' Typ: ' + typeof obj.Bew1_time);vor 'Minuten' fehlt ein +
und das eigendiche Problem war hier
if(obj.Active == "true" && obj.Bew1_time) { // ist Active ein String ?und wenn richtig gelesen hätte wäre es mir auch aufgefallen. Active ist ein String also…
if(obj.Active == "x" && obj.Bew1_time) { // ist Active ein String ?und schon klappt es
if(obj.Active == "x" && obj.Bew1_time) { // ist Active ein String ? ```` `Dann habe ich dies falsch interpretiert:
@sveni_lee:soll immer bewässert werden wenn, wenn Active=true ist und … `
Markiere bitte noch das Thema als gelöst (im Betreff des ersten Beitrags). -
Ich hätte jetzt doch noch zwei Fragen zu dem Skript:
Ich habe nun 2 Kreisläufe die ich nun gern steuern möchte.
Kann ich das script einfach um eine Funktion bspw. Funktion zeiten_Ventil2() erweitern? Im grunde ist es der selbe Aufbau nur das
sich die beiden Konstanten ändern "const idJSON" und "const idBew"…
und ich würde mir gern anzeigen lassen, wann die nächste Bewesserung gestartet werden soll und für wie lange...
ist das auch irgendwie realisierbar?
ich würde mir gern anzeigen lassen, wann die nächste Bewesserung gestartet werden soll und für wie lange… `
Dann ergänze das Skript um einen Datenpunkt (Typ Zeichenkette) für die Zeitanzeige.const idZeit = 'javascript.0.Bewässerung.Ventil1.Zeitpunkt';setState(idZeit, obj.Bew1 + ' für ' + obj.Bew1_time + ' Minuten', true); var t = obj.Bew1.split(':'); sched1 = schedule(t[1] + ' ' + t[0] + ' * * *', function() { setState(idBew, obj.Bew1_time); if(debug) log('Bewässerung1 gestartet'); if(obj.Bew2_time) setState(idZeit, obj.Bew2 + ' für ' + obj.Bew2_time + ' Minuten', true); });Ich habe nun 2 Kreisläufe die ich nun gern steuern möchte.
Kann ich das script einfach um eine Funktion bspw. Funktion zeiten_Ventil2() erweitern? `
Das Skript einfach in ein zweites Skript kopieren und die 3 ID-Konstanten am Anfang ändern. -
Danke, das klappt super…
ich hab jetzt noch Uhrzeit und dauer von einander getrennt...
setState(idZeit, obj.Bew1, true); setState(idDauer, obj.Bew1_time + ' Minuten', true);Kann mann noch irgendwie den Wochentag dort mit reinbringen? Es kann ja vorkommen, das nicht jeden Tag bewässert wird.
Kann mann noch irgendwie den Wochentag dort mit reinbringen? Es kann ja vorkommen, das nicht jeden Tag bewässert wird. `
Der Wochtentag als Zahl 0…6 liegt in der Variablen wd bereits vor. Durch Verwendung der Zahl als Index in ein Array, kann ein Name zugeordnet werden.const days = ['Mo','Di','Mi','Do','Fr','Sa','So']; log('Wochentag: ' + days[wd]); -
Jepp… auch das klappt wunderbar...!
So langsam bekomme ich Ahnung wie man was realisieren kann.
Das Skript überprüft ja kurz nach Mitternacht ob für den dann aktuellen Tag was ansteht, das hat zur Folge, dass bis zum nächsten Tag als nächste Bewässerung immer noch die Zeit von heute angezeigt wird...
Das Skript überprüft ja kurz nach Mitternacht ob für den dann aktuellen Tag was ansteht, das hat zur Folge, dass bis zum nächsten Tag als nächste Bewässerung immer noch die Zeit von heute angezeigt wird… `
Ja, oderif(obj.Bew2_time) setState(idZeit, obj.Bew2 + ' für ' + obj.Bew2_time + ' Minuten', true); else setState(idZeit, 'morgen oder später', true; -
ich habe mich jetzt intensive damit auseinandergesetzt…
Mein Ziel ist/war es die Geplante nächste Bewässerung anzeigen zu lassen auch wenn sie erst in den nächsten Tagen geplant ist.
also habe ich das skript mit meinen bescheidenen Kenntnissen erweitert.
const idJSON = 'javascript.0.Bewässerung.Ventil_1.BewaesserungsPlan'; const idBew = ''; const idZeit = 'javascript.0.Bewässerung.Ventil1.Zeitpunkt'; const idDauer = 'javascript.0.Bewässerung.Ventil1.Dauer_next'; const days = ['Mo','Di','Mi','Do','Fr','Sa','So']; var debug = true; var sched1 = null; var sched2 = null; var json = getState(idJSON).val; function zeiten() { setState(idZeit, '--:--', true); // default Anzeige falls keine Zeit gefunden wird setState(idDauer, ' nicht geplant', true); // default Anzeife falls keine Zeit gefunden wird var arr = JSON.parse(json); // Array aus 7 Elementen (Wochentage) var now = new Date(); var wd = now.getDay() - 1; // Wochentag (0 = Montag) if(wd < 0) wd = 6; // Sonntag if(debug) log('Wochentag: ' + wd); var obj = arr[wd]; if(debug) log(JSON.stringify(obj)); if(sched1) clearSchedule(sched1); if(debug) log('Active: ' + obj.Active + ' Typ: ' + typeof obj.Active); if(debug) log('Bew1 um: ' + obj.Bew1 + ' für ' + obj.Bew1_time + ' Minuten ' + ' Typ: ' + typeof obj.Bew1_time); var time = ("0" + now.getHours()).slice(-2) + ":" + ("0" + now.getMinutes()).slice(-2); log('Zeit jetzt: ' + time); //nur für Testzwecke log(time < obj.Bew1); // nur für Testzwecke if(obj.Active == "x" && obj.Bew1_time && time < obj.Bew1) { // ist Active ein String ? setState(idZeit, days[wd] + '. ' + obj.Bew1, true); setState(idDauer, obj.Bew1_time + ' Minuten', true); var t = obj.Bew1.split(':'); sched1 = schedule(t[1] + ' ' + t[0] + ' * * *', function() { setState(idBew, obj.Bew1_time); if(debug) log('Bewässerung1 gestartet'); }); } if(sched2) clearSchedule(sched2); if(obj.Active == "x" && obj.Bew2_time && time < obj.Bew2) { setState(idZeit, days[wd] + '. ' + obj.Bew2, true); setState(idDauer, obj.Bew2_time + ' Minuten', true); t = obj.Bew2.split(':'); sched2 = schedule(t[1] + ' ' + t[0] + ' * * *', function() { setState(idBew, obj.Bew2_time); }); } else for (i=1; i<=7; i++) { wd = wd + 1 if(wd>6) wd = 0; //umschalten Sonntag auf Montag obj = arr[wd]; if(obj.Active == "x" && obj.Bew1_time) { setState(idZeit, days[wd] + '. ' + obj.Bew1, true); setState(idDauer, obj.Bew1_time + ' Minuten', true); break; } else if(obj.Active == "x" && obj.Bew2_time) { setState(idZeit, days[wd] + '. ' + obj.Bew2, true); setState(idDauer, obj.Bew2_time + ' Minuten', true); break; } } } zeiten(); // Skriptstart schedule('1 0 * * *', zeiten); // kurz nach Mitternacht // Änderung des JSON-Strings on(idJSON, function(dp) { json = dp.state.val; zeiten(); });das klappt auch mit einer Ausnahme. Ich habe für heute eine Bew. für 19:25 eingetragen aber diese wird mir nicht angezeigt als nächste
Bewässerung. Ich habe sicher irgendwo einen Fehler aber ich finde ihn einfach nicht…
EDIT:
hab's gelöst.... klappt jetzt... musste noch ein wenig mit dem "if" und "else if" Konditionen spielen
const idJSON = 'javascript.0.Bewässerung.Ventil_1.BewaesserungsPlan'; const idBew = ''; const idZeit = 'javascript.0.Bewässerung.Ventil1.Zeitpunkt'; const idDauer = 'javascript.0.Bewässerung.Ventil1.Dauer_next'; const days = ['Mo','Di','Mi','Do','Fr','Sa','So']; var debug = true; var sched1 = null; var sched2 = null; var json = getState(idJSON).val; function zeiten() { setState(idZeit, '--:--', true); // default Anzeige falls keine Zeit gefunden wird setState(idDauer, ' nicht geplant', true); // default Anzeife falls keine Zeit gefunden wird var t = 0; var arr = JSON.parse(json); // Array aus 7 Elementen (Wochentage) var now = new Date(); var wd = now.getDay() - 1; // Wochentag (0 = Montag) if(wd < 0) wd = 6; // Sonntag if(debug) log('Wochentag: ' + wd); var obj = arr[wd]; if(debug) log(JSON.stringify(obj)); if(sched1) clearSchedule(sched1); if(debug) log('Active: ' + obj.Active + ' Typ: ' + typeof obj.Active); if(debug) log('Bew1 um: ' + obj.Bew1 + ' für ' + obj.Bew1_time + ' Minuten ' + ' Typ: ' + typeof obj.Bew1_time); var time = ("0" + now.getHours()).slice(-2) + ":" + ("0" + now.getMinutes()).slice(-2); log('Zeit jetzt: ' + time); //nur für Testzwecke log(time < obj.Bew1); // nur für Testzwecke if(obj.Active == "x" && obj.Bew1_time && time < obj.Bew1) { // ist Active ein String ? setState(idZeit, days[wd] + '. ' + obj.Bew1, true); setState(idDauer, obj.Bew1_time + ' Minuten', true); t = obj.Bew1.split(':'); sched1 = schedule(t[1] + ' ' + t[0] + ' * * *', function() { setState(idBew, obj.Bew1_time); if(debug) log('Bewässerung1 gestartet'); }); } if(sched2) clearSchedule(sched2); if(obj.Active == "x" && obj.Bew2_time && time < obj.Bew2 && (obj.Bew1_time === 0 || time > obj.Bew1)) { setState(idZeit, days[wd] + '. ' + obj.Bew2, true); setState(idDauer, obj.Bew2_time + ' Minuten', true); t = obj.Bew2.split(':'); sched2 = schedule(t[1] + ' ' + t[0] + ' * * *', function() { setState(idBew, obj.Bew2_time); }); } else if (t===0) for (i=1; i<=7; i++) { wd = wd + 1; if(wd>6) wd = 0; //umschalten Sonntag auf Montag obj = arr[wd]; if(obj.Active == "x" && obj.Bew1_time) { setState(idZeit, days[wd] + '. ' + obj.Bew1, true); setState(idDauer, obj.Bew1_time + ' Minuten', true); break; } else if(obj.Active == "x" && obj.Bew2_time) { setState(idZeit, days[wd] + '. ' + obj.Bew2, true); setState(idDauer, obj.Bew2_time + ' Minuten', true); break; } } } zeiten(); // Skriptstart schedule('1 0 * * *', zeiten); // kurz nach Mitternacht // Änderung des JSON-Strings on(idJSON, function(dp) { json = dp.state.val; zeiten(); }); -
hoffe es ist in Ordnung wenn ich hier mal frage welches Ventil du verwendest? Bin mir noch unschlüssig welches elektrische Ventil ich kaufen soll um eine Wasserleitung zu öffnen bzw zu schließen..
Danke und Gruß
Klar… ich beende Hunter 1 1/4 Zoll Ventile 9v.
Die werden mit einem Hutschienen Trafo versorgt...
so, nachdem ich das script nun einige Tage testen konnte, ist doch noch ein kleines Problem aufgetaucht.
Ich habe für meine beiden Bewässerungskreisläufe jeweils ein script zu laufen. Nun wollte benötige ich die
Möglichkeit die scripte via Widget zu starten und zu stoppen. und zwar mit bei scripts mit nur einem Schalter.
es gibt zwar die möglichkeit ein script via "scriptEnabled.common.Bewaesserung.Timestamp_Ventil1" zu starten und zu stoppen
aber das klappt nicht aus einen script heraus um zwei Scripte (scriptEnabled.common.Bewaesserung.Timestamp_Ventil1 + scriptEnabled.common.Bewaesserung.Timestamp_Ventil2) zu "schalten"
also wollte ich das die Funktion innerhalb des Scripts nur bei eingeschaltetem Datenpunkt läuft
on({id: "javascript.0.Bewässerung.Trigger_Semi_Automatic"/*Trigger_Semi_Automatic*/, val: true}, function (obj) { zeiten(); // Skriptstart schedule('1 0 * * *', zeiten); // kurz nach Mitternacht // Änderung des JSON-Strings on(idJSON, function(dp) { json = dp.state.val; zeiten(); }); });die Funktion Zeiten wird aber nun auch ausgeführt wernn der Datenpunkt "javascript.0.Bewässerung.Trigger_Semi_Automatic" auf false steht.
hab ich noch irgendetwas falsch verstanden?
