    4. [Aufruf] Adapter: M-Bus
      apollon77 last edited by
      Ja da war die Validierung totaler Müll :-)) versuch mal bitte 0.1.8 vom GitHub
        Garf last edited by
        Ja, sieht nun super aus, Adapter läuft und liest die beiden Devices fehlerfrei aus. Im Log werden wohl noch Errormeldungen angezeigt.
        Log:
        ! ` > mbus.0 2018-04-03 22:03:22.131 info Process: 2
        mbus.0 2018-04-03 22:02:54.655 error M-Bus Devices errored: 1 from 4
        mbus.0 2018-04-03 22:02:54.652 error M-Bus ID 1 err: Error: Error: Failed to receive M-Bus response frame[1].
        mbus.0 2018-04-03 22:02:45.628 info Process: 1
        mbus.0 2018-04-03 21:54:42.658 info Process: 4
        mbus.0 2018-04-03 21:54:32.916 info Process: 3
        mbus.0 2018-04-03 21:54:23.202 info Process: 2
        mbus.0 2018-04-03 21:54:13.338 info Schedule initialization for M-Bus-ID 4 with update interval 0
        mbus.0 2018-04-03 21:54:13.337 info Schedule initialization for M-Bus-ID 3 with update interval 0
        mbus.0 2018-04-03 21:54:13.336 info Schedule initialization for M-Bus-ID 2 with update interval 0
        mbus.0 2018-04-03 21:54:13.329 info Process: 1
        mbus.0 2018-04-03 21:54:13.328 info Schedule initialization for M-Bus-ID 1 with update interval 0
        mbus.0 2018-04-03 21:54:13.322 info Initialize M-Bus TCP to 192.168.178.45:1001 with timeout 0
        mbus.0 2018-04-03 21:54:13.321 info Default Update Interval: 0
        mbus.0 2018-04-03 21:54:13.309 info starting. Version 0.1.8 in /opt/iobroker/node_modules/iobroker.mbus, node: v6.12.0
        mbus.0 2018-04-03 21:54:13.232 info States connected to redis: 127.0.0.1:6379
        mbus.0 2018-04-03 21:54:08.764 info terminating
        mbus.0 2018-04-03 21:53:40.389 info List of port: [{"comName":"/dev/ttyAMA0"}]
        mbus.0 2018-04-03 16:33:52.025 info List of port: [{"comName":"/dev/ttyAMA0"}]
        mbus.0 2018-04-03 16:28:48.911 info Process: 4
        mbus.0 2018-04-03 16:28:48.410 error M-Bus Devices errored: 2 from 4
        mbus.0 2018-04-03 16:28:48.409 error M-Bus ID 3 err: Error: Error: Failed to receive M-Bus response frame[3].
        mbus.0 2018-04-03 16:28:39.453 info Process: 3
        mbus.0 2018-04-03 16:28:29.636 info Process: 2
        mbus.0 2018-04-03 16:28:19.756 info Schedule initialization for M-Bus-ID 4 with update interval 0
        mbus.0 2018-04-03 16:28:19.755 info Schedule initialization for M-Bus-ID 3 with update interval 0
        mbus.0 2018-04-03 16:28:19.754 info Schedule initialization for M-Bus-ID 2 with update interval 0
        mbus.0 2018-04-03 16:28:19.753 info Schedule initialization for M-Bus-ID 4 with update interval 0
        mbus.0 2018-04-03 16:28:19.753 info Schedule initialization for M-Bus-ID 3 with update interval 0
        mbus.0 2018-04-03 16:28:19.752 info Schedule initialization for M-Bus-ID 2 with update interval 0
        mbus.0 2018-04-03 16:28:19.738 info Process: 1
        mbus.0 2018-04-03 16:28:19.737 info Schedule initialization for M-Bus-ID 1 with update interval 0
        mbus.0 2018-04-03 16:28:19.735 info Initialize M-Bus TCP to 192.168.178.45:1001 with timeout 0
        mbus.0 2018-04-03 16:28:19.734 info Default Update Interval: 0
        mbus.0 2018-04-03 16:28:19.732 error All M-Bus devices could not be read, reinitialize and start over
        mbus.0 2018-04-03 16:28:19.732 error M-Bus Devices errored: 1 from 1
        mbus.0 2018-04-03 16:28:19.731 error M-Bus ID 1 connect err: Error: No connection possible to MBus Host 192.168.178.45:1001
        mbus.0 2018-04-03 16:28:19.726 info Process: 1
        mbus.0 2018-04-03 16:28:19.724 info Schedule initialization for M-Bus-ID 1 with update interval 0
        mbus.0 2018-04-03 16:28:19.718 info Initialize M-Bus TCP to 192.168.178.45:1001 with timeout 0
        mbus.0 2018-04-03 16:28:19.718 info Default Update Interval: 0
        mbus.0 2018-04-03 16:28:19.706 info starting. Version 0.1.7 in /opt/iobroker/node_modules/iobroker.mbus, node: v6.12.0
        mbus.0 2018-04-03 16:28:19.630 info States connected to redis: 127.0.0.1:6379
        mbus.0 2018-04-03 16:28:15.199 info terminating
        mbus.0 2018-04-03 16:26:58.117 info List of port: [{"comName":"/dev/ttyAMA0"}] `
          Dein TCP-Gateway mag den Adapter irgendwie immer noch manchmal nicht … aber scheint sich ja dann wieder zu fangen
            Garf last edited by
            Vielleicht gibt es da tatsächlich gewisse Unverträglichkeiten. Aber es funktioniert nun alles in der Praxis. Ich habe jetzt alle Zenner-Zähler in Node-Red eingebunden und die Abfrage der einzelnen Wärmezähler klappt wunderbar. Die Werte werden in je zwei Modbusregister geschrieben und von dort von dem zentralen SAIA Regler (PCD3.M5540) ausgelesen und auf dem Web-Terminal im Wohnzimmer angezeigt.
            So habe ich es mir immer vorgestellt. Hinter dieses Projekt kann ich Dank apollon nun ein Haken machen.
            Jetzt muss ich mich um die nächste Baustelle kümmern. Die Grundfos-Pumpe mit der MS/TP Bacnet-Schnittstelle muss noch eingebunden werden. Mal sehen ob und wie ich das hinbekomme. :?:
              Ich denke das du da ggf im Bacnet Thread genau richtig bist. 😉
                MarcJ last edited by
                Hi!
                Ich habe den Adapter nun auch getestet. Funktioniert mit meinem Wärmemengenzähler "Zenner zelsius C5-ISF" bisher hervorragend! Klasse Arbeit, Ingo! VIIIELEN DANK!
                Eine Frage: Dieses WMZ funktioniert mit festen 2400 Baud. Wenn ich ein weiteres gerät mit 4800 Baud anschließe, wird das nicht gehen, oder? Sollte ich da einen zweiten Adapter installieren mit 4800 Baud? Oder wird das mit ein und demselben mbus-Master nicht funktionieren?
                Danke und Grüße
                Marc
                • bahnuhr
                  Hallo Ingo,
                  nun auch Rückmeldung von mir.
                  Dank an deine Adapter.
                  Habe nun eine raspi3; und an dem hängen 2 x smartmeter und 1 x mbus.
                  Lese also Stromzähler von unserem Versorger + Photovoltaik + Wasserzähler mit einer Wasseruhr von Stark Elektronik.
                  Funktioniert einwandfrei.
                  mfg
                  Dieter
                    @MarcJ:
                    Eine Frage: Dieses WMZ funktioniert mit festen 2400 Baud. Wenn ich ein weiteres gerät mit 4800 Baud anschließe, wird das nicht gehen, oder? Sollte ich da einen zweiten Adapter installieren mit 4800 Baud? Oder wird das mit ein und demselben mbus-Master nicht funktionieren? `
                    Hm, grundsätzlich tut es. Du musst halt sicherstellen das nur einer zu einem zeitpunkt kommuniziert.
                    Da die Adapter aktuell mit "zeitlichen abständen/Intervallen" arbeiten kann man zwei Instanzen nicht wirklich in Einklang bringen.
                    Was aber geht ist zwei Adapter, dort überall Intervall 0 rein (er würde also nur einmal am Adapterstart zugreifen) und dann die Abfragen Über extra Skripte und den "updateNow" Datenpunkt 🙂 entsprechend sicherstellen das es nur nacheinander abgefragt wird
                      Hi Ingo. Noch eine Frage/Hinweis: Ich habe zwei m-bus-Geräte an EINEM USB-Adapter. Die Geräte sind "Jungfräulich". Wenn beide angeschlossen sind, werden keine neuen Geräte gefunden. Erst wenn diese jeweils einzeln dran hängen, werden diese einzeln gefunden. Wenn man dann wieder beide zusammen anschließt und den Adapter neu startet, werden von beiden die Daten übermittelt.
                      Wenn du willst, könntest du das bei mir auch nochmal anschauen.
                      Marc
                        also an sich sollte mit beiden geräten und dann einem "Secondary Scan" (bzw in Admin3 bei den Geräten oben das Such-Icon) sollten an sich beide Geräte befunden werden. Ggf musst Du auf das nächste Update warten da wurde was im Secondary Scan gefixt ( kommt morgen oder so).
                        Ansonsten gibtes Mbus Software mit dessen DU die Primary-IDs der Geräte setzen kannst, ich denke das die ggf jetzt beide die gleiche haben und das kann durchaus Probleme geben.
                          Kannst die 1.0.1 vom Github mal versuchen
                            aprinz last edited by
                            Hallo, hat von Euch jemand Visualisierungen von den Zählern?
                            Plane die Erfassung von 24 Zählern in einem Mehrfamilienhaus.
                              VIS hat Gauge Widgets und anderes was Du nutzen kannst
                                ple last edited by
                                ich hätte da ein paar Fragen zum M-Bus.
                                Im Moment habe ich 2 Wärmemengenzähler, die per WM-Bus senden, naja, was ich nicht wusste, die Werte kommen nur alle 15 Minuten, was eine grafische Darstellung der Wärmeabnahme nicht möglich macht.
                                Nun bin ich auf dem Thread hier gestoßen.
                                Ist es so, dass ich alle M-Bus Teilnehme in Reihe schalten kann und dann an einem Master => USB anschließen kann?
                                Meine Wärmemengezähler werde ich jetzt erst mal nicht mehr tauschen, die bleiben Wireless M-Bus, aber ich hätte noch 2 Kalt und 2 Warm Wasserzähler die ich gerne eingebunden hätte, um z.B. Wasserlecks zu melden.
                                Mein Nuc würde auch im gleichen Raum stehen, wo die komplette Installation ist. Später würde ich noch den Stromzähler tauschen lassen wollen um auch dort ein ganzes Protokoll zu bekommen. Jetzt ist ein HM Zähler dran, wo alle 3 Min ein Wert kommt.
                                Kann mich dahingehen jemand aufklären, was ich alles so benötige und wie das mit dem Mbus läuft? Reihe?
                                  Hi!
                                  Ja, M-Bus kannst du in Reihe oder Stern schalten. Du brauchst nur einen USB-Mbus-Adapter an deinen NUC anzuschließen.
                                  Die Werte kommen dann je nach eingestellter Pollingzeit.
                                  Ist also eine feine Sache 🙂
                                  Grüße Marc
                                    ple last edited by
                                    Na toll, dann hätte ich mir die WM-Bus Zähler sparen können sowie den USB STick für WM-Bus 😞
                                    Hast du einen Link, welchen USB-Master Mbus ich nehmen sollte? von Aliexpress?
                                    Welche Kalt und Warmwasserzähler könntet ihr mir empfehlen? Dann kann ich nach und nach alle Zähler im Anschlussraum austauschen.
                                    Wie sieht es mit dem Hauptstromzähler aus? War erst am überlegen einen Discovergy zu nehmen, aber mit Mbus wäre ja auch eine Möglichkeit.
                                    Gruß und Danke
                                      Können wir das in einen anderen Thread verlagern das wir hier beim Adapter-Support bleiben? 🙂
                                        ple last edited by
                                        Sorry, ich mach ne eigenen Thread auf.
                                        Kannst die alten Post dann löschen.
                                          Garf last edited by
                                          Ich möchte gerne einen M-Bus Wechselstromzähler mit der ID 10 einbinden. Leider wird das Gerät nicht gefunden.Mache ich etwas falsch, oder hat der Adapter einen Bug.
                                          Mit der Auslesesoftware der Fa. Relay wird der Wechselstromzähler problemlos gefunden.
                                          mbus.1 2018-06-27 21:59:41.461 error M-Bus Connection failed. Please check configuration.
                                          mbus.1 2018-06-27 21:59:41.460 error Error: No connection possible to MBus Host 192.168.178.45:1001
                                          mbus.1 2018-06-27 21:59:41.460 info Initialize M-Bus TCP to 192.168.xxx.xx:1001 with timeout 0
                                          mbus.1 2018-06-27 21:59:41.460 info Default Update Interval: 0
                                          mbus.1 2018-06-27 21:59:41.460 error All M-Bus devices could not be read, reinitialize and start over
                                          mbus.1 2018-06-27 21:59:41.460 error M-Bus Devices errored: 1 from 1
                                          mbus.1 2018-06-27 21:59:41.460 error M-Bus ID 10 err: Error: Error: Failed to init slaves.
                                          mbus.1 2018-06-27 21:59:41.449 info Process: 10
                                          mbus.1 2018-06-27 21:59:41.449 info Schedule initialization for M-Bus-ID 10 with update interval 0
                                          mbus.1 2018-06-27 21:59:41.449 info Initialize M-Bus TCP to 192.168.xxx.xx:1001 with timeout 0
                                          mbus.1 2018-06-27 21:59:41.449 info Default Update Interval: 0
                                          mbus.1 2018-06-27 21:59:41.444 error All M-Bus devices could not be read, reinitialize and start over
                                          mbus.1 2018-06-27 21:59:41.444 error M-Bus Devices errored: 1 from 1
                                          mbus.1 2018-06-27 21:59:41.444 error M-Bus ID 10 err: Error: Error: Failed to init slaves.
                                          mbus.1 2018-06-27 21:59:41.444 info Process: 10
                                          mbus.1 2018-06-27 21:59:41.444 info Schedule initialization for M-Bus-ID 10 with update interval 0
                                          mbus.1 2018-06-27 21:59:41.444 info Initialize M-Bus TCP to 192.168.xxx.xx:1001 with timeout 0
                                          mbus.1 2018-06-27 21:59:41.444 info Default Update Interval: 0
                                          mbus.1 2018-06-27 21:59:41.443 error M-Bus Devices errored: 1 from 1
                                          mbus.1 2018-06-27 21:59:41.443 error M-Bus ID 10 err: Error: Error: Failed to receive M-Bus response frame[10].
                                          mbus.1 2018-06-27 21:59:32.952 info Process: 10
                                          mbus.1 2018-06-27 21:59:32.952 info Schedule initialization for M-Bus-ID 10 with update interval 0
                                          mbus.1 2018-06-27 21:59:32.952 info Initialize M-Bus TCP to 192.168.xxx.xx:1001 with timeout 0
                                          mbus.1 2018-06-27 21:59:32.952 info Default Update Interval: 0
                                          mbus.1 2018-06-27 21:59:32.952 error All M-Bus devices could not be read, reinitialize and start over
                                          mbus.1 2018-06-27 21:59:32.951 error M-Bus Devices errored: 1 from 1
                                          mbus.1 2018-06-27 21:59:32.951 error M-Bus ID 10 err: Error: Error: Failed to receive M-Bus response frame[10].
                                          mbus.1 2018-06-27 21:59:24.489 info Process: 10
                                          mbus.1 2018-06-27 21:59:24.489 info Schedule initialization for M-Bus-ID 10 with update interval 0
                                          mbus.1 2018-06-27 21:59:24.488 info Initialize M-Bus TCP to 192.168.xxx.xx:1001 with timeout 0
                                          mbus.1 2018-06-27 21:59:24.488 info Default Update Interval: 0
                                          mbus.1 2018-06-27 21:59:24.488 error All M-Bus devices could not be read, reinitialize and start over
                                          mbus.1 2018-06-27 21:59:24.488 error M-Bus Devices errored: 1 from 1
                                          mbus.1 2018-06-27 21:59:24.488 error M-Bus ID 10 err: Error: Error: Failed to init slaves.
                                          mbus.1 2018-06-27 21:59:24.488 info Process: 10
                                          mbus.1 2018-06-27 21:59:24.488 info Schedule initialization for M-Bus-ID 10 with update interval 0
                                          mbus.1 2018-06-27 21:59:24.487 info Initialize M-Bus TCP to 192.168.xxx.xx:1001 with timeout 0
                                          mbus.1 2018-06-27 21:59:24.487 info Default Update Interval: 0
                                          mbus.1 2018-06-27 21:59:24.487 error All M-Bus devices could not be read, reinitialize and start over
                                          mbus.1 2018-06-27 21:59:24.487 error M-Bus Devices errored: 1 from 1
                                          mbus.1 2018-06-27 21:59:24.487 error M-Bus ID 10 err: Error: Error: Failed to init slaves.
                                          mbus.1 2018-06-27 21:59:24.487 info Process: 10
                                          mbus.1 2018-06-27 21:59:24.487 info Schedule initialization for M-Bus-ID 10 with update interval 0
                                          mbus.1 2018-06-27 21:59:24.485 info Schedule initialization for M-Bus-ID 10 with update interval 0
                                          mbus.1 2018-06-27 21:59:24.483 info Initialize M-Bus TCP to 192.168.xxx.xx:1001 with timeout 0
                                          mbus.1 2018-06-27 21:59:24.483 info Default Update Interval: 0
                                          mbus.1 2018-06-27 21:59:24.481 error All M-Bus devices could not be read, reinitialize and start over
                                          mbus.1 2018-06-27 21:59:24.481 error M-Bus Devices errored: 1 from 1
                                          mbus.1 2018-06-27 21:59:24.481 error M-Bus ID 10 err: Error: Error: Failed to receive M-Bus response frame[10].
                                          mbus.1 2018-06-27 21:59:14.917 info Process: 10
                                          mbus.1 2018-06-27 21:59:14.917 info Schedule initialization for M-Bus-ID 10 with update interval 0
                                          mbus.1 2018-06-27 21:59:14.917 info Initialize M-Bus TCP to 192.168.xxx.xx:1001 with timeout 0
                                          mbus.1 2018-06-27 21:59:14.917 info Default Update Interval: 0
                                          mbus.1 2018-06-27 21:59:14.917 error All M-Bus devices could not be read, reinitialize and start over
                                          mbus.1 2018-06-27 21:59:14.917 error M-Bus Devices errored: 1 from 1
                                          mbus.1 2018-06-27 21:59:14.916 error M-Bus ID 10 err: Error: Error: Failed to init slaves.
                                          mbus.1 2018-06-27 21:59:13.902 info Process: 10
                                          mbus.1 2018-06-27 21:59:13.902 info Schedule initialization for M-Bus-ID 10 with update interval 0
                                          mbus.1 2018-06-27 21:59:13.902 info Initialize M-Bus TCP to 192.168.xxx.xx:1001 with timeout 0
                                          mbus.1 2018-06-27 21:59:13.902 info Default Update Interval: 0
                                          mbus.1 2018-06-27 21:59:13.902 error All M-Bus devices could not be read, reinitialize and start over
                                          mbus.1 2018-06-27 21:59:13.902 error M-Bus Devices errored: 1 from 1
                                          mbus.1 2018-06-27 21:59:13.902 error M-Bus ID 10 err: Error: Error: Failed to init slaves.
                                          mbus.1 2018-06-27 21:59:13.901 info Initialize M-Bus TCP to 192.168.xxx.xx:1001 with timeout 0
                                          mbus.1 2018-06-27 21:59:13.899 info Default Update Interval: 0
                                          mbus.1 2018-06-27 21:59:13.899 error All M-Bus devices could not be read, reinitialize and start over
                                          mbus.1 2018-06-27 21:59:13.899 error M-Bus Devices errored: 1 from 1
                                          mbus.1 2018-06-27 21:59:13.899 error M-Bus ID 10 err: Error: Error: Failed to init slaves.
                                          mbus.1 2018-06-27 21:59:13.899 info Process: 10
                                          mbus.1 2018-06-27 21:59:13.898 info Schedule initialization for M-Bus-ID 10 with update interval 0
                                          mbus.1 2018-06-27 21:59:13.898 info Initialize M-Bus TCP to 192.168.xxx.xx:1001 with timeout 0
                                          mbus.1 2018-06-27 21:59:13.898 info Default Update Interval: 0
                                          mbus.1 2018-06-27 21:59:13.898 error All M-Bus devices could not be read, reinitialize and start over
                                          mbus.1 2018-06-27 21:59:13.898 error M-Bus Devices errored: 1 from 1
                                          mbus.1 2018-06-27 21:59:13.898 error M-Bus ID 10 err: Error: Error: Failed to init slaves.
                                          mbus.1 2018-06-27 21:59:13.857 info Process: 10
                                          mbus.1 2018-06-27 21:59:13.857 info Schedule initialization for M-Bus-ID 10 with update interval 0
                                          mbus.1 2018-06-27 21:59:13.857 info Initialize M-Bus TCP to 192.168.xxx.xx:1001 with timeout 0
                                          mbus.1 2018-06-27 21:59:13.857 info Default Update Interval: 0
                                          mbus.1 2018-06-27 21:59:13.857 error All M-Bus devices could not be read, reinitialize and start over
                                          mbus.1 2018-06-27 21:59:13.857 error M-Bus Devices errored: 1 from 1
                                          mbus.1 2018-06-27 21:59:13.856 error M-Bus ID 10 err: Error: Error: Failed to init slaves.
                                          mbus.1 2018-06-27 21:59:13.839 info Process: 10
                                          mbus.1 2018-06-27 21:59:13.838 info Schedule initialization for M-Bus-ID 10 with update interval 0
                                          mbus.1 2018-06-27 21:59:13.838 info Initialize M-Bus TCP to 192.168.xxx.xx:1001 with timeout 0
                                          mbus.1 2018-06-27 21:59:13.838 info Default Update Interval: 0
                                          mbus.1 2018-06-27 21:59:13.838 error All M-Bus devices could not be read, reinitialize and start over
                                          mbus.1 2018-06-27 21:59:13.838 error M-Bus Devices errored: 1 from 1
                                          mbus.1 2018-06-27 21:59:13.838 error M-Bus ID 10 err: Error: Error: Failed to init slaves.
                                          mbus.1 2018-06-27 21:59:13.825 info Process: 10
                                          mbus.1 2018-06-27 21:59:13.825 info Schedule initialization for M-Bus-ID 10 with update interval 0
                                          mbus.1 2018-06-27 21:59:13.825 info Initialize M-Bus TCP to 192.168.xxx.xx:1001 with timeout 0
                                          mbus.1 2018-06-27 21:59:13.825 info Default Update Interval: 0
                                          mbus.1 2018-06-27 21:59:13.825 error All M-Bus devices could not be read, reinitialize and start over
                                          mbus.1 2018-06-27 21:59:13.825 error M-Bus Devices errored: 1 from 1
                                          mbus.1 2018-06-27 21:59:13.825 error M-Bus ID 10 err: Error: Error: Failed to init slaves.
                                          mbus.1 2018-06-27 21:59:13.804 info Process: 10
                                          mbus.1 2018-06-27 21:59:13.804 info Schedule initialization for M-Bus-ID 10 with update interval 0
                                          mbus.1 2018-06-27 21:59:13.804 info Initialize M-Bus TCP to 192.168.xxx.xx:1001 with timeout 0
                                          mbus.1 2018-06-27 21:59:13.804 info Default Update Interval: 0
                                          mbus.1 2018-06-27 21:59:13.804 error All M-Bus devices could not be read, reinitialize and start over
                                          mbus.1 2018-06-27 21:59:13.804 error M-Bus Devices errored: 1 from 1
                                          mbus.1 2018-06-27 21:59:13.803 error M-Bus ID 10 err: Error: Error: Failed to init slaves.
                                          mbus.1 2018-06-27 21:59:13.792 info Process: 10
                                          mbus.1 2018-06-27 21:59:13.792 info Schedule initialization for M-Bus-ID 10 with update interval 0
                                          mbus.1 2018-06-27 21:59:13.792 info Initialize M-Bus TCP to 192.168.xxx.xx:1001 with timeout 0
                                          mbus.1 2018-06-27 21:59:13.792 info Default Update Interval: 0
                                          mbus.1 2018-06-27 21:59:13.792 error All M-Bus devices could not be read, reinitialize and start over
                                          mbus.1 2018-06-27 21:59:13.792 error M-Bus Devices errored: 1 from 1
                                          mbus.1 2018-06-27 21:59:13.792 error M-Bus ID 10 err: Error: Error: Failed to init slaves.
                                          mbus.1 2018-06-27 21:59:13.791 error M-Bus Devices errored: 1 from 1
                                          mbus.1 2018-06-27 21:59:13.789 error M-Bus ID 10 err: Error: Error: Failed to init slaves.
                                          mbus.1 2018-06-27 21:59:13.761 info Process: 10
                                          mbus.1 2018-06-27 21:59:13.761 info Schedule initialization for M-Bus-ID 10 with update interval 0
                                          mbus.1 2018-06-27 21:59:13.761 info Initialize M-Bus TCP to 192.168.xxx.xx:1001 with timeout 0
                                          mbus.1 2018-06-27 21:59:13.761 info Default Update Interval: 0
                                          mbus.1 2018-06-27 21:59:13.761 error All M-Bus devices could not be read, reinitialize and start over
                                          mbus.1 2018-06-27 21:59:13.761 error M-Bus Devices errored: 1 from 1
                                          mbus.1 2018-06-27 21:59:13.760 error M-Bus ID 10 err: Error: Error: Failed to receive M-Bus response frame[10].
                                          mbus.1 2018-06-27 21:59:05.301 info Process: 10
                                          mbus.1 2018-06-27 21:59:05.301 info Schedule initialization for M-Bus-ID 10 with update interval 0
                                          mbus.1 2018-06-27 21:59:05.301 info Initialize M-Bus TCP to 192.168.xxx.xx:1001 with timeout 0
                                          mbus.1 2018-06-27 21:59:05.301 info Default Update Interval: 0
                                          mbus.1 2018-06-27 21:59:05.301 error All M-Bus devices could not be read, reinitialize and start over
                                          mbus.1 2018-06-27 21:59:05.301 error M-Bus Devices errored: 1 from 1
                                          mbus.1 2018-06-27 21:59:05.301 error M-Bus ID 10 err: Error: Error: Failed to init slaves.
                                          mbus.1 2018-06-27 21:59:05.300 error M-Bus ID 10 err: Error: Error: Failed to init slaves.
                                          mbus.1 2018-06-27 21:59:04.274 info Process: 10
                                          mbus.1 2018-06-27 21:59:04.274 info Schedule initialization for M-Bus-ID 10 with update interval 0
                                          mbus.1 2018-06-27 21:59:04.274 info Initialize M-Bus TCP to 192.168.xxx.xx:1001 with timeout 0
                                          mbus.1 2018-06-27 21:59:04.274 info Default Update Interval: 0
                                          mbus.1 2018-06-27 21:59:04.274 error All M-Bus devices could not be read, reinitialize and start over
                                          mbus.1 2018-06-27 21:59:04.274 error M-Bus Devices errored: 1 from 1
                                          mbus.1 2018-06-27 21:59:04.273 error M-Bus ID 10 err: Error: Error: Failed to init slaves.
                                          mbus.1 2018-06-27 21:59:04.266 info Process: 10
                                          mbus.1 2018-06-27 21:59:04.266 info Schedule initialization for M-Bus-ID 10 with update interval 0
                                          mbus.1 2018-06-27 21:59:04.266 info Initialize M-Bus TCP to 192.168.xxx.xx:1001 with timeout 0
                                          mbus.1 2018-06-27 21:59:04.266 info Default Update Interval: 0
                                          mbus.1 2018-06-27 21:59:04.266 error All M-Bus devices could not be read, reinitialize and start over
                                          mbus.1 2018-06-27 21:59:04.266 error M-Bus Devices errored: 1 from 1
                                          mbus.1 2018-06-27 21:59:04.266 error M-Bus ID 10 err: Error: Error: Failed to init slaves.
                                          mbus.1 2018-06-27 21:59:04.246 info Process: 10
                                          mbus.1 2018-06-27 21:59:04.246 info Schedule initialization for M-Bus-ID 10 with update interval 0
                                          mbus.1 2018-06-27 21:59:04.246 info Initialize M-Bus TCP to 192.168.xxx.xx:1001 with timeout 0
                                          mbus.1 2018-06-27 21:59:04.246 info Default Update Interval: 0
                                          mbus.1 2018-06-27 21:59:04.246 error All M-Bus devices could not be read, reinitialize and start over
                                          mbus.1 2018-06-27 21:59:04.245 error M-Bus Devices errored: 1 from 1
                                          mbus.1 2018-06-27 21:59:04.245 error M-Bus ID 10 err: Error: Error: Failed to init slaves.
                                          mbus.1 2018-06-27 21:59:04.234 info Process: 10
                                          mbus.1 2018-06-27 21:59:04.234 info Schedule initialization for M-Bus-ID 10 with update interval 0
                                          mbus.1 2018-06-27 21:59:04.234 info Initialize M-Bus TCP to 192.168.xxx.xx:1001 with timeout 0
                                          mbus.1 2018-06-27 21:59:04.234 info Default Update Interval: 0
                                          mbus.1 2018-06-27 21:59:04.232 error All M-Bus devices could not be read, reinitialize and start over
                                          mbus.1 2018-06-27 21:59:04.232 error M-Bus Devices errored: 1 from 1
                                          mbus.1 2018-06-27 21:59:04.232 error M-Bus ID 10 err: Error: Error: Failed to init slaves.
                                          mbus.1 2018-06-27 21:59:04.232 info Process: 10
                                          mbus.1 2018-06-27 21:59:04.232 info Schedule initialization for M-Bus-ID 10 with update interval 0
                                          mbus.1 2018-06-27 21:59:04.232 info Initialize M-Bus TCP to 192.168.xxx.xx:1001 with timeout 0
                                          mbus.1 2018-06-27 21:59:04.232 info Default Update Interval: 0
                                          mbus.1 2018-06-27 21:59:04.231 error M-Bus Devices errored: 1 from 1
                                          mbus.1 2018-06-27 21:59:04.231 error M-Bus ID 10 err: Error: Error: Failed to init slaves.
                                          mbus.1 2018-06-27 21:59:04.201 info Process: 10
                                          mbus.1 2018-06-27 21:59:04.200 info Schedule initialization for M-Bus-ID 10 with update interval 0
                                          mbus.1 2018-06-27 21:59:04.200 info Initialize M-Bus TCP to 192.168.xxx.xx:1001 with timeout 0
                                          mbus.1 2018-06-27 21:59:04.200 info Default Update Interval: 0
                                          mbus.1 2018-06-27 21:59:04.200 error All M-Bus devices could not be read, reinitialize and start over
                                          mbus.1 2018-06-27 21:59:04.200 error M-Bus Devices errored: 1 from 1
                                          mbus.1 2018-06-27 21:59:04.200 error M-Bus ID 10 err: Error: Error: Failed to init slaves.
                                          mbus.1 2018-06-27 21:59:04.183 info Process: 10
                                          mbus.1 2018-06-27 21:59:04.183 info Schedule initialization for M-Bus-ID 10 with update interval 0
                                          mbus.1 2018-06-27 21:59:04.183 info Initialize M-Bus TCP to 192.168.xxx.xx:1001 with timeout 0
                                          mbus.1 2018-06-27 21:59:04.183 info Default Update Interval: 0
                                          mbus.1 2018-06-27 21:59:04.183 error All M-Bus devices could not be read, reinitialize and start over
                                          mbus.1 2018-06-27 21:59:04.183 error M-Bus Devices errored: 1 from 1
                                          mbus.1 2018-06-27 21:59:04.183 error M-Bus ID 10 err: Error: Error: Failed to init slaves.
                                          mbus.1 2018-06-27 21:59:04.182 info Default Update Interval: 0
                                          mbus.1 2018-06-27 21:59:04.182 error All M-Bus devices could not be read, reinitialize and start over
                                          mbus.1 2018-06-27 21:59:04.182 error M-Bus Devices errored: 1 from 1
                                          mbus.1 2018-06-27 21:59:04.182 error M-Bus ID 10 err: Error: Error: Failed to init slaves.
                                          mbus.1 2018-06-27 21:59:04.145 info Process: 10
                                          mbus.1 2018-06-27 21:59:04.144 info Schedule initialization for M-Bus-ID 10 with update interval 0
                                          mbus.1 2018-06-27 21:59:04.144 info Initialize M-Bus TCP to 192.168.xxx.xx:1001 with timeout 0
                                          mbus.1 2018-06-27 21:59:04.144 info Default Update Interval: 0
                                          mbus.1 2018-06-27 21:59:04.144 error All M-Bus devices could not be read, reinitialize and start over
                                          mbus.1 2018-06-27 21:59:04.144 error M-Bus Devices errored: 1 from 1
                                          mbus.1 2018-06-27 21:59:04.144 error M-Bus ID 10 err: Error: Error: Failed to init slaves.
                                          mbus.1 2018-06-27 21:59:04.144 info Process: 10
                                          mbus.1 2018-06-27 21:59:04.143 info Schedule initialization for M-Bus-ID 10 with update interval 0
                                          mbus.1 2018-06-27 21:59:04.143 info Initialize M-Bus TCP to 192.168.xxx.xx:1001 with timeout 0
                                          mbus.1 2018-06-27 21:59:04.143 info Default Update Interval: 0
                                          mbus.1 2018-06-27 21:59:04.143 error All M-Bus devices could not be read, reinitialize and start over
                                          mbus.1 2018-06-27 21:59:04.143 error M-Bus Devices errored: 1 from 1
                                          mbus.1 2018-06-27 21:59:04.143 error M-Bus ID 10 err: Error: Error: Failed to init slaves.
                                          mbus.1 2018-06-27 21:59:04.143 info Process: 10
                                          mbus.1 2018-06-27 21:59:04.141 info Initialize M-Bus TCP to 192.168.xxx.xx:1001 with timeout 0
                                          mbus.1 2018-06-27 21:59:04.141 info Default Update Interval: 0
                                          mbus.1 2018-06-27 21:59:04.141 error All M-Bus devices could not be read, reinitialize and start over
                                          mbus.1 2018-06-27 21:59:04.141 error M-Bus Devices errored: 1 from 1
                                          mbus.1 2018-06-27 21:59:04.141 error M-Bus ID 10 err: Error: Error: Failed to init slaves.
                                          mbus.1 2018-06-27 21:59:04.141 info Process: 10
                                          mbus.1 2018-06-27 21:59:04.141 info Schedule initialization for M-Bus-ID 10 with update interval 0
                                          mbus.1 2018-06-27 21:59:04.140 error M-Bus ID 10 err: Error: Error: Failed to receive M-Bus response frame[10].
                                          mbus.1 2018-06-27 21:58:55.615 info Process: 10
                                          mbus.1 2018-06-27 21:58:55.615 info Schedule initialization for M-Bus-ID 10 with update interval 0
                                          mbus.1 2018-06-27 21:58:55.615 info Initialize M-Bus TCP to 192.168.xxx.xx:1001 with timeout 0
                                          mbus.1 2018-06-27 21:58:55.615 info Default Update Interval: 0
                                          mbus.1 2018-06-27 21:58:55.615 error All M-Bus devices could not be read, reinitialize and start over
                                          mbus.1 2018-06-27 21:58:55.615 error M-Bus Devices errored: 1 from 1
                                          mbus.1 2018-06-27 21:58:55.615 error M-Bus ID 10 err: Error: Error: Failed to init slaves.
                                          mbus.1 2018-06-27 21:58:55.613 info Schedule initialization for M-Bus-ID 10 with update interval 0
                                          mbus.1 2018-06-27 21:58:55.613 info Initialize M-Bus TCP to 192.168.xxx.xx:1001 with timeout 0
                                          mbus.1 2018-06-27 21:58:55.611 info Default Update Interval: 0
                                          mbus.1 2018-06-27 21:58:55.611 error All M-Bus devices could not be read, reinitialize and start over
                                          mbus.1 2018-06-27 21:58:55.611 error M-Bus Devices errored: 1 from 1
                                          mbus.1 2018-06-27 21:58:55.611 error M-Bus ID 10 err: Error: Error: Failed to init slaves.
                                          mbus.1 2018-06-27 21:58:55.581 info Process: 10
                                          mbus.1 2018-06-27 21:58:55.581 info Schedule initialization for M-Bus-ID 10 with update interval 0
                                          mbus.1 2018-06-27 21:58:55.581 info Initialize M-Bus TCP to 192.168.xxx.xx:1001 with timeout 0
                                          mbus.1 2018-06-27 21:58:55.581 info Default Update Interval: 0
                                          mbus.1 2018-06-27 21:58:55.580 error All M-Bus devices could not be read, reinitialize and start over
                                          mbus.1 2018-06-27 21:58:55.580 error M-Bus Devices errored: 1 from 1
                                          mbus.1 2018-06-27 21:58:55.580 error M-Bus ID 10 err: Error: Error: Failed to receive M-Bus response frame[10].
                                          mbus.1 2018-06-27 21:58:47.089 info Process: 10
                                          mbus.1 2018-06-27 21:58:47.086 info Schedule initialization for M-Bus-ID 10 with update interval 0
                                          mbus.1 2018-06-27 21:58:47.082 info Initialize M-Bus TCP to 192.168.xxx.xx:1001 with timeout 0
                                          mbus.1 2018-06-27 21:58:47.082 info Default Update Interval: 0
                                          mbus.1 2018-06-27 21:58:47.081 error All M-Bus devices could not be read, reinitialize and start over
                                          mbus.1 2018-06-27 21:58:47.081 error M-Bus Devices errored: 1 from 1
                                          mbus.1 2018-06-27 21:58:47.081 error M-Bus ID 10 err: Error: Error: Failed to init slaves.
                                          mbus.1 2018-06-27 21:58:47.072 info Process: 10
                                          mbus.1 2018-06-27 21:58:47.072 info Schedule initialization for M-Bus-ID 10 with update interval 0
                                          mbus.1 2018-06-27 21:58:47.069 info Initialize M-Bus TCP to 192.168.xxx.xx:1001 with timeout 0
                                          mbus.1 2018-06-27 21:58:47.069 info Default Update Interval: 0
                                          mbus.1 2018-06-27 21:58:47.068 error All M-Bus devices could not be read, reinitialize and start over
                                          mbus.1 2018-06-27 21:58:47.068 error M-Bus Devices errored: 1 from 1
                                          mbus.1 2018-06-27 21:58:47.067 error M-Bus ID 10 err: Error: Error: Failed to init slaves.
                                          mbus.1 2018-06-27 21:58:47.060 info Process: 10
                                          mbus.1 2018-06-27 21:58:47.060 info Schedule initialization for M-Bus-ID 10 with update interval 0
                                          mbus.1 2018-06-27 21:58:47.057 info Initialize M-Bus TCP to 192.168.xxx.xx:1001 with timeout 0
                                          mbus.1 2018-06-27 21:58:47.057 info Default Update Interval: 0
                                          mbus.1 2018-06-27 21:58:47.056 error All M-Bus devices could not be read, reinitialize and start over
                                          mbus.1 2018-06-27 21:58:47.056 error M-Bus Devices errored: 1 from 1
                                          mbus.1 2018-06-27 21:58:47.056 error M-Bus ID 10 err: Error: Error: Failed to receive M-Bus response frame[10].
                                          mbus.1 2018-06-27 21:58:38.572 info Process: 10
                                          mbus.1 2018-06-27 21:58:38.570 info Schedule initialization for M-Bus-ID 10 with update interval 0
                                          mbus.1 2018-06-27 21:58:38.568 info Initialize M-Bus TCP to 192.168.xxx.xx:1001 with timeout 0
                                          mbus.1 2018-06-27 21:58:38.567 info Default Update Interval: 0
                                          mbus.1 2018-06-27 21:58:38.566 error All M-Bus devices could not be read, reinitialize and start over
                                          mbus.1 2018-06-27 21:58:38.558 error M-Bus Devices errored: 1 from 1
                                          mbus.1 2018-06-27 21:58:38.558 error M-Bus ID 10 err: Error: Error: Failed to init slaves.
                                          mbus.1 2018-06-27 21:58:38.527 info Process: 10
                                          mbus.1 2018-06-27 21:58:38.527 info Schedule initialization for M-Bus-ID 10 with update interval 0
                                          mbus.1 2018-06-27 21:58:38.525 info Initialize M-Bus TCP to 192.168.xxx.xx:1001 with timeout 0
                                          mbus.1 2018-06-27 21:58:38.525 info Default Update Interval: 0
                                          mbus.1 2018-06-27 21:58:38.525 error All M-Bus devices could not be read, reinitialize and start over
                                          mbus.1 2018-06-27 21:58:38.525 error M-Bus Devices errored: 1 from 1
                                          mbus.1 2018-06-27 21:58:38.524 error M-Bus ID 10 err: Error: Error: Failed to init slaves.
                                          mbus.1 2018-06-27 21:58:38.508 info Process: 10
                                          mbus.1 2018-06-27 21:58:38.508 info Schedule initialization for M-Bus-ID 10 with update interval 0
                                          mbus.1 2018-06-27 21:58:38.506 info Initialize M-Bus TCP to 192.168.xxx.xx:1001 with timeout 0
                                          mbus.1 2018-06-27 21:58:38.506 info Default Update Interval: 0
                                          mbus.1 2018-06-27 21:58:38.506 error All M-Bus devices could not be read, reinitialize and start over
                                          mbus.1 2018-06-27 21:58:38.506 error M-Bus Devices errored: 1 from 1
                                          mbus.1 2018-06-27 21:58:38.506 error M-Bus ID 10 connect err: Error: No connection possible to MBus Host 192.168.xxx.xx:1001
                                          mbus.1 2018-06-27 21:58:38.502 info Process: 10
                                          mbus.1 2018-06-27 21:58:38.502 info Schedule initialization for M-Bus-ID 10 with update interval 0
                                          mbus.1 2018-06-27 21:58:38.490 info Initialize M-Bus TCP to 192.168.xxx.xx:1001 with timeout 0
                                          mbus.1 2018-06-27 21:58:38.489 info Default Update Interval: 0
                                          mbus.1 2018-06-27 21:58:38.489 error All M-Bus devices could not be read, reinitialize and start over
                                          mbus.1 2018-06-27 21:58:38.489 error M-Bus Devices errored: 1 from 1
                                          mbus.1 2018-06-27 21:58:38.487 error M-Bus ID 10 err: Error: Error: Failed to init slaves.
                                          mbus.1 2018-06-27 21:58:38.484 info Process: 10
                                          mbus.1 2018-06-27 21:58:38.484 info Schedule initialization for M-Bus-ID 10 with update interval 0
                                          mbus.1 2018-06-27 21:58:38.478 info Initialize M-Bus TCP to 192.168.xxx.xx:1001 with timeout 0
                                          mbus.1 2018-06-27 21:58:38.477 info Default Update Interval: 0
                                          mbus.1 2018-06-27 21:58:38.476 error All M-Bus devices could not be read, reinitialize and start over
                                          mbus.1 2018-06-27 21:58:38.476 error M-Bus Devices errored: 1 from 1
                                          mbus.1 2018-06-27 21:58:38.475 error M-Bus ID 10 err: Error: Error: Failed to receive M-Bus response frame[10].
                                          mbus.1 2018-06-27 21:58:30.027 info Process: 10
                                          mbus.1 2018-06-27 21:58:30.021 info Schedule initialization for M-Bus-ID 10 with update interval 0
                                          mbus.1 2018-06-27 21:58:30.017 info Initialize M-Bus TCP to 192.168.xxx.xx:1001 with timeout 0
                                          mbus.1 2018-06-27 21:58:30.017 info Default Update Interval: 0
                                          mbus.1 2018-06-27 21:58:30.016 error All M-Bus devices could not be read, reinitialize and start over
                                          mbus.1 2018-06-27 21:58:30.016 error M-Bus Devices errored: 1 from 1
                                          mbus.1 2018-06-27 21:58:30.016 error M-Bus ID 10 err: Error: Error: Failed to init slaves.
                                          mbus.1 2018-06-27 21:58:30.005 info Process: 10
                                            Hm … kannst du vom iobroker Host denn die IP vom Mbus Master erreichen? Auch den Port?
                                            Sieht mir nach Problemen im Netzwerk oder Timeouts oder so aus.
                                            Gesendet vom Handy ...
                                            79.9k
                                            159
                                            35707
