    4. Adapter: DasWetter
    Adapter: DasWetter
    • wendy2702
      wendy2702 last edited by
      Soweit ich weiß gibt es die nicht im Adapter.
      Ich mache dazu mal ein Github Issue auf.–> DONE
      https://github.com/rg-engineering/ioBro ... /issues/12
      Kann man doch bestimmt noch Integrieren.
        tomdeboom last edited by
        Hallo Mirko,
        Fehlermeldungen fangen wieder an….:
        ! daswetter.0 2018-04-19 21:50:05.508 error exception in 7DaysForecast [TypeError: Cannot read property '0' of undefined]
        ! daswetter.0 2018-04-19 21:50:04.085 info starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v6.13.1
        ! daswetter.0 2018-04-19 21:45:04.809 error exception in 7DaysForecast [TypeError: Cannot read property '0' of undefined]
        ! daswetter.0 2018-04-19 21:45:03.697 info starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v6.13.1
        ! daswetter.0 2018-04-19 21:40:05.003 error exception in 7DaysForecast [TypeError: Cannot read property '0' of undefined]
        ! daswetter.0 2018-04-19 21:40:03.626 info starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v6.13.1
        ! daswetter.0 2018-04-19 21:35:05.305 error exception in 7DaysForecast [TypeError: Cannot read property '0' of undefined]
        ! daswetter.0 2018-04-19 21:35:04.044 info starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v6.13.1
        ! daswetter.0 2018-04-19 21:30:06.603 error exception in 7DaysForecast [TypeError: Cannot read property '0' of undefined]
        ! daswetter.0 2018-04-19 21:30:04.798 info starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v6.13.1
        ! daswetter.0 2018-04-19 21:25:05.537 error exception in 7DaysForecast [TypeError: Cannot read property '0' of undefined]
        ! daswetter.0 2018-04-19 21:25:03.778 info starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v6.13.1
        ! daswetter.0 2018-04-19 21:20:05.952 error exception in 7DaysForecast [TypeError: Cannot read property '0' of undefined]
        ! daswetter.0 2018-04-19 21:20:03.816 info starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v6.13.1
        ! daswetter.0 2018-04-19 21:15:05.189 error exception in 7DaysForecast [TypeError: Cannot read property '0' of undefined]
        ! daswetter.0 2018-04-19 21:15:03.669 info starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v6.13.1
        ! daswetter.0 2018-04-19 21:10:05.220 error exception in 7DaysForecast [TypeError: Cannot read property '0' of undefined]
        ! daswetter.0 2018-04-19 21:10:04.088 info starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v6.13.1
        Ich habe nicht gemacht nichts verändert, ich verstehe es nicht….
        Gruß,
        Tom
        • wendy2702
          @tomdeboom:
          Ich habe nicht gemacht nichts verändert,… `
          Sagt meine Frau auch immer 😉
          Spass beiseite:
          Lege dir mal die Links zur abfrage parat und Versuch mal ob die funktionieren wenn der Fehler im Log kommt. Könnte ja auch mal an „Das Wetter“ liegen.
            ok, mache ich morgen mal. Danke
              Guten Morgen Mirko,
              habe die URL 7-Tage-Wettervorhersage ausprobiert, folgendes bekomme ich jetzt angezeigt:
              ! <report><error>Sie sind kein registrierter Benutzer der daswetter.com-API oder Ihr Konto wurde nicht aktiviert.</error></report>
              Verstehen tue ich das aber nicht, da ich mich bei dasWetter API anmelden kann und auch den selben Link angezeigt bekomme….
              Link iobroker-dasWetter.0:
              ! http://api.daswetter.com/index.php?api_ … 7#####75vl
              Link API dsWetter:
              Gruß,
              Tom
              • wendy2702
                Guten Morgen,
                gerade mal mit meinen Links probiert. Die funktionieren einwandfrei.
                Habe auch keine Fehler im Log file.
                Wie ist denn dein Abfrage Intervall und zu welchen Zeiten?
                  War 5 min… "Zu welcher Zeit" wie meinst du das?
                  Habe jetzt meinen zweiten Account eingesetzt und die Abfrageintervalle auf 16 min gesetzt und anscheinend geht das...
                  • wendy2702
                    Ja, das meinte ich. 5 Minuten könnte zu häufig sein. Gibt Server die blocken einen dann zeitweise oder für immer.
                    Also ich frage alle 22 Minuten ab, also nie zu Standardzeiten wie 15, 30, 45, 60 Minuten oder so. Mache ich bei allen meinen Abfragen immer so das ich "krumme" Zeiten nehme und fahre bisher ganz gut damit.
                      Ok, dann hab ich ja mit den 16 min auch eine krumme Zeit.
                      Mal schauen wie es sich verhält.
                      Gruß,
                      Tom
                        Guten Morgen,
                        und täglich grüßt das Murmeltier :evil:
                        ! daswetter.0 2018-04-21 07:22:04.466 error exception in 7DaysForecast [TypeError: Cannot read property '0' of undefined]
                        ! daswetter.0 2018-04-21 07:22:02.614 info starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v6.13.1
                        ! daswetter.0 2018-04-21 07:00:07.616 error exception in 7DaysForecast [TypeError: Cannot read property '0' of undefined]
                        ! daswetter.0 2018-04-21 07:00:05.574 info starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v6.13.1
                        ! daswetter.0 2018-04-21 06:32:04.500 error exception in 7DaysForecast [TypeError: Cannot read property '0' of undefined]
                        ! daswetter.0 2018-04-21 06:32:02.843 info starting. Version 1.0.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v6.13.1
                        Downloadstatistik dasWetter:
                        ! Download-Statistik
                        ! 21. APRIL:
                        ! 0
                        ! APRIL:
                        ! 131
                        ! 2018:
                        ! 169
                        Ich bin mit meinem Latein am Ende…
                        Gruß,
                        Tom
                        • wendy2702
                          Beide Accounts oder immer nur einer und dann derselbe?
                          Ich habe nur einen Account aber das noch nie gehabt.
                          Vielleicht schreibst du „Das Wetter“ mal an. Sieht ja so aus als wenn es immer zur gleichen Zeit kommt, oder?
                            Ja jedes mal ungefähr zur gleichen Zeit….
                            Habe die beiden Accounts immer gewechselt, und dann hat es ein Tag funktioniert und am nächsten Tag nicht mehr.
                            Ich werde mal deren Support anschreiben und sie fragen woran dies liegen könnte.
                            Und vielleicht auch fragen ob man nicht beide Accounts löscht und einen neuen Anlegt.
                            Danke und Gruß,
                            Tom
                              tempestas last edited by
                              Bei mir scheint sich der Adapter aufgehängt zu haben. Wenn ich die Forecast URL direct eingebe, dann bekomme ich die korrekten Daten geliefert.
                              In der Instanz bzw den Objekten steht aber letzte Änderung 2018-4-12, entsprechend sind auch z.B. die Tage falsch (morgen ist Freitag…). Im Log steht nichts, Abruf ist auf alle 15 Minuten eingestellt.
                              Neugestartet habe ich schon
                                Ich habe gestern das Konto bei dasWetter nochmals aktiviert und heute zeigt es die richtigen Daten an mal schauen ob es das war?
                                @tempestas: Deinstalliere mal den Adapter komplett inkl.der Objekte und dann neu Installieren und schauen ob er es dann aktualisiert, so über 2-3Tage.
                                Gruß,
                                Tom
                                  jetzt bleibt einfach alles leer…
                                  • wendy2702
                                    Hast du JS-Controller 1.4.2 ?
                                      Du musst ca. 1-2 std. warten dann sollte es sich füllen.
                                      • V
                                        valbuz last edited by
                                        war bei mir auch, einfach mal warten (wieso auch immer…)
                                          @wendy2702:
                                          Hast du JS-Controller 1.4.2 ? `
                                          1.2.3, also stable Version.
                                          dasWetter bleibt leer… im Log steht, was er called und die Adresse liefert auch Daten (direkte Eingabe im Browser); aber im Adapter bleiben die Objekte leer
                                            Guten Morgen,
                                            stoppe mal den Adapter, starte ihn wieder und dann wenn er Grün ist, dann aktualisierst du ihn nochmal.
                                            Hatte bei mir geholfen.
                                            Normalerweiße sollte er jetzt zumindestens "NextDays" aktualisieren, der Rest kommt dann noch.
                                            Meiner läuft jetzt schon 2 Tage ohne Probleme, ich will es aber nicht beschreien…. 😉
                                            Gruß,
                                            Tom
                                            81.1k
                                            1208
                                            407052
