    4. Log Fehler
    Log Fehler
    • wendy2702
      wendy2702 last edited by
      Ich wollte ja den Status sehen.
      Mach mal auf der Konsole:
      iobroker list instances
      Ausgabe bitte in Spoiler und Code Tags Posten.
        willy10 last edited by
        pi@pi:~ $ iobroker list instances
        system.adapter.admin.0 : admin - enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.botvac.0 : botvac - enabled
        system.adapter.broadlink2.0 : broadlink2 - enabled
        system.adapter.cloud.0 : cloud - enabled
        system.adapter.discovery.0 : discovery - enabled
        system.adapter.enigma2.0 : enigma2 - enabled
        system.adapter.fritzdect.0 : fritzdect - enabled
        system.adapter.fronius.0 : fronius - disabled
        system.adapter.harmony.0 : harmony - enabled
        system.adapter.history.0 : history - enabled
        system.adapter.javascript.0 : javascript - enabled
        system.adapter.node-red.0 : node-red - enabled, port: 1880
        system.adapter.ping.0 : ping - enabled
        system.adapter.scenes.0 : scenes - enabled
        system.adapter.sonoff.0 : sonoff - disabled, port: 1881, bind: 0.0.0.0
        system.adapter.sonoff.1 : sonoff - disabled, port: 1883, bind: 0.0.0.0
        system.adapter.sonoff.2 : sonoff - disabled, port: 1885, bind: 0.0.0.0
        system.adapter.sony-bravia.0 : sony-bravia - disabled
        system.adapter.terminal.0 : terminal - enabled, port: 8088, bind: 0.0.0.0, run as: admin
        system.adapter.tr-064.0 : tr-064 - enabled
        system.adapter.vis-bars.0 : vis-bars - enabled
        system.adapter.vis-hqwidgets.0 : vis-hqwidgets - enabled
        system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd - enabled
        system.adapter.vis-justgage.0 : vis-justgage - enabled
        system.adapter.vis-keyboard.0 : vis-keyboard - enabled
        system.adapter.vis-map.0 : vis-map - enabled
        system.adapter.vis-metro.0 : vis-metro - enabled
        system.adapter.vis-rgraph.0 : vis-rgraph - enabled
        system.adapter.vis-timeandweather.0 : vis-timeandweather - enabled
        system.adapter.vis-weather.0 : vis-weather - enabled
        system.adapter.vis.0 : vis - enabled
        system.adapter.web.0 : web - enabled, port: 8082, bind: 0.0.0.0, run as: admin
        pi@pi:~ $
        Hier die instanzen
        Mod-Edit by eric2905, Dann füge ich mal die Code- und Spoiler-Tags ein….
          @willy10:
          system.adapter.web.0 : web - enabled, port: 8082, bind: 0.0.0.0, run as: admin `
          enabled ist er ja (siehe grünes "Pause" Zeichen)
          aber warum ist die Ampel rot?
          Rainer
            das weiss ich nicht.
            Verbunden mit Horst u. Lebenszeichen bei Web.0 …beides auf falsch angezeigt
              und so sieht das aus:
              • wendy2702
                @wendy2702:
                Hi Willy,
                wie und wo hast du iobroker installiert? `
                Zitiere mich mal selber. Bitte beantworten.
                Blöde Frage: hast du iobroker oder das System (was auch immer) mal restartet?
                  ja habe ich ach vom strom weggenommen, und immer wenn was neu war habe ich das dann installiert. Mir ist das im Log erst jetzt aufgefallen mit den Fehlermeldungen. VIS benutze ich sonst nicht. Habe vorhin mal auf meinen ersatz raspy ein alte Backub aufgespielt vom 04.03.23018 mit dem alten iobroken. Der geht.
                    so…ich werde echt beklobt...(((
                    Habe meine alte version jetzt ein modul nach dem anderen ubgedatet. (nicht über die Konsole) und jetzt geht der ganze Kram.
                    Verstehe ich echt nicht. Muss nur noch die sonof Module nachinstalieren. Aber da kann es ja nicht dran gelegen haben. Und die ganzen Skripte uns
                    Szenen müssen auch noch wieder angelegt werden.
                    Trotzdem Vielen Dank für die Hilfe von Euch!
                    Gruss
                    • wendy2702
                      Hi Willy,
                      schön das es geht auch wenn ich jetzt nicht mehr weiß was du gemacht hast. Aber egal… Hauptsache es läuft wieder!
                      Kannst du dann bitte den ersten Beitrag editieren und den Titel um ein````
                      [Gelöst]
                      Schönes Wochenende
                        mein altes backup aufgespielt…das hatte ich gemacht! Und dann alles aktualiesiert. Gut das ich mir das von zeit zu zeit sichere...
                        gruss
                        1983
