    4. REDIS will be back
    REDIS will be back
    • Dutchman
      hmm wird wohl an mir liegen….
      neu installation von iobroker auf ubuntu mit nodejs 6 und redis, iobroker einmal gestartet ohne redis danach umgeschaltet (redis vorher natuerlich installiert.
      Iobroker admin nicht erreicht, commando iobroker status sagt running....
      log:
      2017-07-15 23:24:39.933  - ^[[32minfo^[[39m: iobroker _restart
      2017-07-15 23:24:39.941  - ^[[32minfo^[[39m: host.HomeMaster terminated
      2017-07-15 23:24:40.181  - ^[[32minfo^[[39m: iobroker Starting node restart.js
      2017-07-15 23:24:40.188  - ^[[32minfo^[[39m: iobroker exit 0
      2017-07-15 23:24:40.333  - ^[[32minfo^[[39m: host.HomeMaster received SIGTERM
      2017-07-15 23:24:40.334  - ^[[32minfo^[[39m: host.HomeMaster terminated
      2017-07-15 23:24:45.707  - ^[[32minfo^[[39m: host.HomeMaster iobroker.js-controller version 1.1.2 js-controller starting
      2017-07-15 23:24:45.711  - ^[[32minfo^[[39m: host.HomeMaster Copyright (c) 2014-2017 bluefox, hobbyquaker
      2017-07-15 23:24:45.711  - ^[[32minfo^[[39m: host.HomeMaster hostname: HomeMaster, node: v6.11.1
      2017-07-15 23:24:45.712  - ^[[32minfo^[[39m: host.HomeMaster ip addresses: 192.168.1.60 fe80::20c:29ff:fef3:bb55
      2017-07-15 23:24:45.740  - ^[[32minfo^[[39m: host.HomeMaster States connected to redis: 127.0.0.1:6379
      2017-07-15 23:24:45.741  - ^[[32minfo^[[39m: host.HomeMaster InRedisDB connected
      2017-07-15 23:24:45.760  - ^[[31merror^[[39m: uncaught exception: Cannot read property 'views' of null
      2017-07-15 23:24:45.762  - ^[[31merror^[[39m: TypeError: Cannot read property 'views' of null
          at /opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInRedis.js:1380:24
          at Command.callback (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:639:49)
          at normal_reply (/opt/iobroker/node_modules/redis/index.js:721:21)
          at RedisClient.return_reply (/opt/iobroker/node_modules/redis/index.js:819:9)
          at JavascriptRedisParser.returnReply (/opt/iobroker/node_modules/redis/index.js:192:18)
          at JavascriptRedisParser.execute (/opt/iobroker/node_modules/redis-parser/lib/parser.js:574:12)
          at Socket. <anonymous>(/opt/iobroker/node_modules/redis/index.js:274:27)
          at emitOne (events.js:96:13)
          at Socket.emit (events.js:188:7)
          at readableAddChunk (_stream_readable.js:176:18)
      2017-07-15 23:24:45.765  - ^[[32minfo^[[39m: iobroker _restart
      2017-07-15 23:24:45.774  - ^[[32minfo^[[39m: host.HomeMaster terminated
      2017-07-15 23:24:46.006  - ^[[32minfo^[[39m: iobroker Starting node restart.js
      2017-07-15 23:24:46.012  - ^[[32minfo^[[39m: iobroker exit 0
      2017-07-15 23:24:46.158  - ^[[32minfo^[[39m: host.HomeMaster received SIGTERM
      2017-07-15 23:24:46.158  - ^[[32minfo^[[39m: host.HomeMaster terminated</anonymous>
      nach umschalten auf settings ohne redis geht alles wieder
      Edit: Dieser depp der Dutchman heist sollte mal vernuenftig lesen…. es laeuft !
      Datei => REDIS:
      >iobroker stop
      >iobroker setup custom
      ` > Type of objects DB [file, couch, redis], default [file]:
      Host of objects DB(file), default[127.0.0.1]:
      Port of objects DB(file), default[9001]:
      Type of states DB [file, redis], default [file]: redis
      Host of states DB (redis), default[127.0.0.1]:
      Port of states DB (redis), default[6379]:
      Data directory (file), default[../../../iobroker-data/]:
      Host name of this machine [FastPC]:
      creating conf/iobroker.json `
      iobroker start
      nur die states und nicht alles auf redis setzen !
        hab da ein Problem mit multihost
        redis läuft auf dem Master … kann mich auch von aussen mit verbinden
        started
        Sun Dec 10 2017 10:48:54 GMT+0100 (CET)Restarting iobroker...
        Sun Dec 10 2017 10:48:55 GMT+0100 (CET)Stopping daemon iobroker...
        Sun Dec 10 2017 10:48:55 GMT+0100 (CET)Exit code for "kill -KILL 631": 1
        Sun Dec 10 2017 10:48:55 GMT+0100 (CET)Exit code for "kill -KILL 796": 1
        Sun Dec 10 2017 10:48:55 GMT+0100 (CET)Exit code for "kill -KILL 1025": 1
        Sun Dec 10 2017 10:48:55 GMT+0100 (CET)Exit code for "kill -KILL 1018": 1
        steht im log auf dem Master.. iobroker startet nicht…
        multihost Umgebung
        Master
        Type of objects DB [file, couch, redis], default [file]: redis
        Host of objects DB(file), default[127.0.0.1]: <0.0.0.0>
        Port of objects DB(file), default[6379]: ENTER
        Type of states DB [file, redis], default [file]: ENTER
        Host of states DB (file), default[0.0.0.0]: ENTER
        Port of states DB (file), default[6379]: ENTER
        Host name of this machine [hostname]: ENTER
        Slave alles gleich bis auf die IP
        • Dutchman
          Hast du redis so konfiguriert dass er externe Verbindungen erlaubt ?
          Send from mobile device
            Ich weiß nicht ob das wichtig ist, aber dein master hat angeblich keinen Namen.
            Zu Dutchmans hinweis
            http://www.iobroker.net/docu/?page_id=3 … _mit_redis
            Gruß Rainer
              @Dutchman:
              Send from mobile device `
              jo.. komme von aussen auch hin
              hab es an 0.0.0.0 gebunden also offen wie ein Scheunentor
              doch hab es nur nicht reinkopiert.
              hat iobroker nen debugschalter ??? vielleicht kann ich im Log was mehr sehen oder consolenausgaben ??
                nur die States Arthur nicht die Objekte…. ahhhhhhhhhhhhhhhhh
                so läuft zumindest vorerst.. hab aber in Redis keine objekte abgelegt bekommen... hmm.. die Db's sind leer
                UPDATE:
                habe redis gerade neu Installiert... jetzt werden auch die objekte in der DB angelegt..
                  robsdobs last edited by
                  hat jemand die objects DB auf redis laufen?
                  Was würde das bringen?
                  Robert
                  • ruhr70
                    ruhr70 last edited by
                    @arteck:
                    UPDATE:
                    habe redis gerade neu Installiert... jetzt werden auch die objekte in der DB angelegt.. `
                    womit greifst Du per GUI suf Redis zu?
                      apollon77 last edited by
                      Objects gehen noch nicht im Redis. Nur States.
                        @apollon77:
                        Objects gehen noch nicht im Redis. Nur States. ` Ok, Danke!
                        104
                        22572
