    4. [Problem] Dream btw. Enigma2 Adapter
    • wendy2702
      wendy2702 last edited by
      Hat iobroker Internet Zugang?
      Warum auch immer kann er das File nicht laden:
       ERR! fetch failed https://github.com/Matten-Matten/ioBroker.enigma2.git/tarball/master
        mikiline last edited by
        installier von dieser URL im Admin
          stephan2k last edited by
          Hat wohl auch nicht geklappt, aber andere Fehlermeldung…
          iobroker	2018-04-21 08:36:09.794	info	exit 0
          iobroker	2018-04-21 08:36:09.665	info	npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
          iobroker	2018-04-21 08:36:09.665	info	npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 (node_modules/authenticate-pam):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 install: `node-gyp rebuil
          iobroker	2018-04-21 08:36:02.437	info	gyp ERR! not ok
          iobroker	2018-04-21 08:36:02.437	info	gyp ERR! node-gyp -v v3.4.0
          iobroker	2018-04-21 08:36:02.437	info	gyp ERR! node -v v6.12.0
          iobroker	2018-04-21 08:36:02.437	info	gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pam
          iobroker	2018-04-21 08:36:02.437	info	gyp ERR! System Linux 4.9.59-v7+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
          iobroker	2018-04-21 08:36:02.433	info	gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:219:12)
          iobroker	2018-04-21 08:36:02.433	info	gyp ERR! stack at ChildProcess.emit (events.js:191:7)
          iobroker	2018-04-21 08:36:02.433	info	gyp ERR! stack at emitTwo (events.js:106:13)
          iobroker	2018-04-21 08:36:02.433	info	gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
          iobroker	2018-04-21 08:36:02.424	info	ERR! build error
          iobroker	2018-04-21 08:36:02.420	info	gyp
          iobroker	2018-04-21 08:36:02.411	info	make: *** [Release/obj.target/authenticate_pam/authenticate_pam.o] Fehler 1
          iobroker	2018-04-21 08:36:02.379	info	compilation terminated.
          iobroker	2018-04-21 08:36:02.379	info	^
          iobroker	2018-04-21 08:36:02.379	info	../authenticate_pam.cc:30:31: fatal error: security/pam_appl.h: Datei oder Verzeichnis nicht gefunden #include
          Er sollte Internet haben… andere Dinge konnte ich auch installieren. Und via Tankkönig holt er ja Daten aus dem INET. ical Kalender ist auch mit Google verknüpft 😕
          Diesen Error: fetch failed with status code 404 habe ich auch bei der Installation vom robonect (Mähroboter) Modul. Vermute eher ein generelles Problem (Falsche Settings)
            LJSven last edited by
            Ich habe den Adapter eingebunden - allerdings drehen sich bei mir in regelmässigen Abständen die "Zahnräder" - der RPI 3 ist vie WLAN angebunden.
            Hat jemand das gleiche Problem?
            • wendy2702
              Welche Node & NPM Version und was für ein System ?
                @wendy2702:
                Welche Node & NPM Version und was für ein System ? `
                node 6.14.1
                NPM 5.8.0
                Raspbian Stretch Lite (glaube ich)
                • N
                  Nepomukl last edited by
                  @LJSven:
                  Hat jemand das gleiche Problem? `
                  Guten Morgen, das hatte ich auch auf einer DM 800SE, die Zahnräder kamen genau zum Abfrageintervall.
                  Denke mal das die Rechenleistung der Box nicht ganz ausreicht um die ständigen Abfragen zu bewältigen.
                  Auf ner DM 820 war davon nix zu sehen, die hat es nicht gestört.
                  Gruß Andreas
                    Ich habe eine 7020 HD / glaubst du, dass es besser ist, wenn ich den Raspberry per LAN anschließe?
                    • Dutchman
                      @LJSven:
                      glaubst du, dass es besser ist, wenn ich den Raspberry per LAN anschließe? `
                      LAN ist sowieso immer besser als WiFi vor allem wenn man ihn als Server System benutzt und ununterbrochene Verbindung haben sollte
                      Send from mobile device
                        ich habs eben nochmal unter admin 3.3.9 versucht, bekomme folgenden Fehler….
                        Berechtigung?
                        Ich glaube langsam, das grundsätzlich was nicht mit der Installation passt. Habe das komplett fertige Image von iobroker aufn raspberry installiert...
                        host.ioBroker-Pi	2018-04-23 23:37:31.349	warn	warning: Following packages cannot be read: lgtv11
                        host.ioBroker-Pi	2018-04-23 23:37:30.685	info	Update repository "default" under "http://download.iobroker.net/sources-dist.json"
                        iobroker	2018-04-23 23:37:30.000	info	exit 0
                        iobroker	2018-04-23 23:37:29.882	info	npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                        iobroker	2018-04-23 23:37:29.882	info	optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 (node_modules/authenticate-pam):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 install: `node-gyp rebuild`
                        iobroker	2018-04-23 23:37:29.879	info	WARN
                        iobroker	2018-04-23 23:37:29.878	info	npm
                        iobroker	2018-04-23 23:37:18.957	info	gyp ERR! not ok
                        iobroker	2018-04-23 23:37:18.957	info	gyp ERR! node-gyp -v v3.4.0
                        iobroker	2018-04-23 23:37:18.957	info	gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pamgyp ERR! node -v v6.14.1
                        iobroker	2018-04-23 23:37:18.952	info	command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                        iobroker	2018-04-23 23:37:18.950	info	gyp ERR! System Linux 4.14.34-v7+gyp ERR!
                        iobroker	2018-04-23 23:37:18.949	info	stack at ChildProcess.emit (events.js:191:7)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:219:12)
                        iobroker	2018-04-23 23:37:18.947	info
                        iobroker	2018-04-23 23:37:18.943	info	gyp ERR! stack at emitTwo (events.js:106:13)gyp ERR!
                        iobroker	2018-04-23 23:37:18.941	info	ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
                        iobroker	2018-04-23 23:37:18.940	info	gyp
                        iobroker	2018-04-23 23:37:18.932	info	ERR! build error
                        iobroker	2018-04-23 23:37:18.931	info	gyp
                        iobroker	2018-04-23 23:37:18.928	info	make: *** [Release/obj.target/authenticate_pam/authenticate_pam.o] Fehler 1
                        iobroker	2018-04-23 23:37:18.895	info	compilation terminated.
                        iobroker	2018-04-23 23:37:18.895	info	^
                        iobroker	2018-04-23 23:37:18.895	info	../authenticate_pam.cc:30:31: fatal error: security/pam_appl.h: Datei oder Verzeichnis nicht gefunden #include
                        iobroker	2018-04-23 23:37:14.166	info	WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/6.14.1"gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/authenticate
                        iobroker	2018-04-23 23:37:14.164	info
                        iobroker	2018-04-23 23:37:14.161	info	gyp
                        iobroker	2018-04-23 23:36:14.772	info	npm install https://github.com/vader722/ioBroker.vuplus/tarball/master --production --prefix "/opt/iobroker" (System call)
                        iobroker	2018-04-23 23:36:14.202	info	install https://github.com/vader722/ioBroker.vuplus/tarball/master
                        iobroker	2018-04-23 23:36:12.843	info	url "https://github.com/vader722/ioBroker.vuplus.git"
                        • wendy2702
                          Moin,
                          Jetzt hast du aber auch einen anderen Adapter versucht zu installieren und nicht den von MattenMatten wenn ich das richtig sehe.
                          Hat mit Zugriffsrechten nichts zu tun, er wechselt ja dann in ein Temporäres Verzeichnis.
                          PI3 oder schon der neue?
                          Welches Image?
                          Welche Versionen Node & NPM?
                            peinlich..
                            ich nehm alles zurück…
                            Hab das System nicht ganz verstanden
                            1. Unter Adapter -> Installieren aus eigener URL
                            2. Dann erst scheint die gewünschte Software unter Adapter in der Übersicht und lässt sich mit dem + installieren..
                            3. Dann funktioniert es auch..
                            Vermute meine Fehler kamen weil ich den 1. Punkt öfters wiederholt habe, weil ich dachte es geht nicht.
                            Ist nun drauf, funktioniert.
                            Kurze andere Frage,
                            verstehe ich es richtig das ich pro vu+ Box die ich habe jeweils eine eiegene Instanz benötige?
                            • wendy2702
                              Ja,
                              Pro Box eine Instanz da jede Box eine eigene IP hat und du pro Instanz nur eine IP vergeben kannst.
                              • Q
                                quorle last edited by
                                Hab mir den Adapter auch einmal geladen und installiert ( ohne Fehler ).
                                Nun wollte ich in meinem Cloud Adapter den Standby einfügen. Aber es kommt nur: " Dieses Objekt kann nicht hinzugefügt werden, da es nicht unterstützt wird. "
                                Hätte gedacht, ich könnte via Alexa den Receiver Ein und Aus schalten… :lol:
                                  @quorle:
                                  Hätte gedacht, ich könnte via Alexa den Receiver Ein und Aus schalten… :lol: `
                                  Erstelle dir einfach eine Szene - dann geht es bestimmt.
                                  • Q
                                    Klappt irgendwie nicht.
                                    Sobald ich Enigma2.STANDBY auf "true" setzte, wird er sofort wieder auf "false" gesetzt.
                                    • BBTown
                                      BBTown last edited by
                                      @quorle:
                                      Hätte gedacht, ich könnte via Alexa den Receiver Ein und Aus schalten… :lol: ` und ganz genau das mache ich ja auch tagtäglich … 8-)
                                      Da Du aber keinen Screenshot schickst und nicht erzählst was Du bisher gemacht hast, wüßte ich nicht wo ich anfangen sollte dir zu helfen was Du anders machen solltest :roll:
                                      [Nachtrag]
                                      Ich schalte meine Dreambox allerdings über Alexa indem ich Blockly Scripte antriggere die wiederum hhtp-Requests absetzen.
                                      Nicht über den Enigma Adapter!!
                                      • BBTown
                                        @quorle:
                                        Sobald ich Enigma2.STANDBY auf "true" setzte, wird er sofort wieder auf "false" gesetzt. ` seit wann kann man denn mit dem Enigma Adapter etwas anderes machen als ein Enigma Gerät auszulesen?
                                        … ich wüßte nicht, dass man mit dem Adapter stand heute auch Befehle <u>SENDEN</u> kann 8-)
                                        [Nachtrag]:
                                        Wie sich das mit dem VU+ Adpter verhällt, kann ich wiederum nicht sagen
                                        • Ralla66
                                          Ralla66 Most Active last edited by
                                          Der VU Adapter verhält sich auch so.
                                          Nur lesen.
                                          Ralla
                                          • dslraser
                                            kann eigentlich nicht für alle Datenpunkte stimmen.
                                            Ich schalte z.B. die Lautstärke in der VU über den Adapter mit Alexa.
                                            Alexa, Lautstärke im Wohnzimmer auf xy% (funktioniert bei mir)![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201804 ... 082a9b.jpg">https://uploads.tapatalk-cdn.com/20180426/281e8709effe4e3e6e52f6a3cf082a9b.jpg</link_text>" />![](</s><URL url=)<link_text text="https://uploads.tapatalk-cdn.com/201804 ... c59149.jpg">https://uploads.tapatalk-cdn.com/20180426/fb8420c67d7373a1e5c65d597ac59149.jpg</link_text>" />~~~~
                                            739
                                            189771
