    3. Entwicklung
    4. [Neuer Adapter] Proxmox VM
    • Dutchman
      Ist ja mega freut mich einen Proxmox Adapter zu sehen werde testen und berichten [emoji3][emoji3][emoji3]
      Send from mobile device
      • eric2905
        eric2905 last edited by
        @ruhr70:
        Jetzt muss ich nur einen Wg finden, wie ich vom esxi auf Proxmox umsteige. [emoji1][emoji51] `
        Schau mal hier : https://www.sysorchestra.com/2017/03/16/migrate-vmware-esxi-virtual-machines-to-proxmox-kvm-with-lvm-thin-logical-volumes/
        Und https://pve.proxmox.com/wiki/Migration_of_servers_to_Proxmox_VE
        Gruß,
        Eric
        Von unterwegs getippert
        • Dutchman
          Installation ist gelungen, log der Github installation:
          $ ./iobroker url "https://github.com/MeisterTR/ioBroker.proxmox"
          install https://github.com/MeisterTR/ioBroker.proxmox/tarball/master
          npm install https://github.com/MeisterTR/ioBroker.proxmox/tarball/master --production --save --prefix "/home/gerrit" (System call)
          process exited with code 0
          Log der instance installation :
          $ ./iobroker add proxmox
          host.iObroker install adapter proxmox
          npm install --production (System call) in "/home/gerrit/node_modules/iobroker.proxmox"
          got /home/gerrit/node_modules/iobroker.proxmox/admin
          upload [3] proxmox.admin /home/gerrit/node_modules/iobroker.proxmox/admin/words.js words.js application/javascript
          upload [2] proxmox.admin /home/gerrit/node_modules/iobroker.proxmox/admin/logo.png logo.png image/png
          upload [1] proxmox.admin /home/gerrit/node_modules/iobroker.proxmox/admin/index_m.html index_m.html text/html
          upload [0] proxmox.admin /home/gerrit/node_modules/iobroker.proxmox/admin/index.html index.html text/html
          Adapter "system.adapter.vis.0" restarted.got /home/gerrit/node_modules/iobroker.proxmox/www
          upload [1] proxmox /home/gerrit/node_modules/iobroker.proxmox/www/index.html index.html text/html
          upload [0] proxmox /home/gerrit/node_modules/iobroker.proxmox/www/README.md README.md text/markdown
          host.iObroker object system.adapter.proxmox created
          host.iObroker create instance proxmox
          host.iObroker object system.adapter.proxmox.upload created
          host.iObroker object system.adapter.proxmox.0.outputCount created
          host.iObroker object system.adapter.proxmox.0.inputCount created
          host.iObroker object system.adapter.proxmox.0.uptime created
          host.iObroker object system.adapter.proxmox.0.memRss created
          host.iObroker object system.adapter.proxmox.0.memHeapTotal created
          host.iObroker object system.adapter.proxmox.0.memHeapUsed created
          host.iObroker object system.adapter.proxmox.0.connected created
          host.iObroker object system.adapter.proxmox.0.alive created
          host.iObroker object system.adapter.proxmox.0 created
          sieht alles gut aus
          Konfiguration :
          • Port sollte standard auf 8006 eingestellt sein
          • request Intervall währe ein standard auch schön, habe mich erstmal für 30 entschieden
          Probleme :
          • Adapter start, admin interface reagiert nicht mehr
          • proxmox adapter lässt sich nicht auf der console stoppen oder löschen:
          xxxx@iObroker:/opt/iobroker$ sudo iobroker stop proxmox.0
          [sudo] password for gerrit:
          events.js:160
                throw er; // Unhandled 'error' event
          Error: listen EADDRINUSE 127.0.0.1:9001
              at Object.exports._errnoException (util.js:1020:11)
              at exports._exceptionWithHostPort (util.js:1043:20)
              at Server._listen2 (net.js:1277:14)
              at listen (net.js:1313:10)
              at net.js:1423:9
              at _combinedTickCallback (internal/process/next_tick.js:83:11)
              at process._tickCallback (internal/process/next_tick.js:104:9)
          gerrit@iObroker:/opt/iobroker$ sudo iobroker del proxmox
          events.js:160
              at net.js:1423:9
          system neu gestartet, direct iObroker gestopt bevor die adapter gestartet waren, das hat geklappt.
          adapter wieder neu installiert, diesmal interval auf 120000 jetzt bleibt der admin funktionieren (die Einstellungen sind wohl Millisekunden wodurch ich mir das System zerschossen habe ?
          Adapter läuft jetzt, es werden keine object angelegt, log :
          proxmox.0	2018-04-25 09:09:27.013	info	ack is not set!
          proxmox.0	2018-04-25 09:09:26.937	warn	Devices: {"data":[{"type":"node","maxdisk":31044079616,"status":"online","maxmem":16753127424,"mem":8807063552,"node":"HomeMaster","disk":2416340992,"uptime":690434,"id":"node/HomeMaster","ssl_finger
          proxmox.0	2018-04-25 09:09:23.781	warn	UUID: 192.168.1.200
          proxmox.0	2018-04-25 09:09:23.773	info	starting. Version 0.0.2 in /home/gerrit/node_modules/iobroker.proxmox, node: v6.14.1
          proxmox.0	2018-04-25 09:09:10.186	info	terminating
          proxmox.0	2018-04-25 09:09:10.088	info	cleaned everything up...
          proxmox.0	2018-04-25 09:09:10.085	error	at TLSSocket.emit (events.js:188:7)
          proxmox.0	2018-04-25 09:09:10.085	error	at emitOne (events.js:96:13)
          proxmox.0	2018-04-25 09:09:10.085	error	at TLSSocket.socketErrorListener (_http_client.js:310:9)
          proxmox.0	2018-04-25 09:09:10.085	error	at ClientRequest.emit (events.js:188:7)
          proxmox.0	2018-04-25 09:09:10.085	error	at Request.onRequestError (/home/gerrit/node_modules/request/request.js:878:8)
          proxmox.0	2018-04-25 09:09:10.085	error	at Request.emit (events.js:188:7)
          proxmox.0	2018-04-25 09:09:10.085	error	at self.callback (/home/gerrit/node_modules/request/request.js:186:22)
          proxmox.0	2018-04-25 09:09:10.085	error	at Request.request [as _callback] (/home/gerrit/node_modules/iobroker.proxmox/lib/proxmox.js:104:16)
          proxmox.0	2018-04-25 09:09:10.085	error	TypeError: Cannot read property 'statusCode' of undefined
          proxmox.0	2018-04-25 09:09:10.081	error	uncaught exception: Cannot read property 'statusCode' of undefined
          proxmox.0	2018-04-25 09:09:06.897	warn	UUID: undefined
          proxmox.0	2018-04-25 09:09:06.847	info	starting. Version 0.0.2 in /home/gerrit/node_modules/iobroker.proxmox, node: v6.14.1
          2018-04-25 09:08:25.669 - error: Caught by controller[0]: TypeError: Cannot read property 'statusCode' of undefined
          2018-04-25 09:08:25.669 - error: Caught by controller[0]: at Request.request [as _callback] (/home/gerrit/node_modules/iobroker.proxmox/lib/proxmox.js:104:16)
          2018-04-25 09:08:25.669 - error: Caught by controller[0]: at self.callback (/home/gerrit/node_modules/request/request.js:186:22)
          2018-04-25 09:08:25.670 - error: Caught by controller[0]: at emitOne (events.js:96:13)
          2018-04-25 09:08:25.670 - error: Caught by controller[0]: at Request.emit (events.js:188:7)
          2018-04-25 09:08:25.670 - error: Caught by controller[0]: at Request.onRequestError (/home/gerrit/node_modules/request/request.js:878:8)
          2018-04-25 09:08:25.670 - error: Caught by controller[0]: at ClientRequest.emit (events.js:188:7)
          2018-04-25 09:08:25.670 - error: Caught by controller[0]: at TLSSocket.socketErrorListener (_http_client.js:310:9)
          2018-04-25 09:08:25.670 - error: Caught by controller[0]: at TLSSocket.emit (events.js:188:7)
          2018-04-25 09:08:25.670 - error: host.iObroker instance system.adapter.proxmox.0 terminated with code 0 (OK)
          • Dutchman
            Der Fehler sitzt hinterm Bildschirm, die object werden angelegt ich hatte einen filter actief 😕
            im log kommt die meldung:
            2018-04-25 12:08:47.529  - [32minfo[39m: proxmox.0 starting. Version 0.0.2 in /home/gerrit/node_modules/iobroker.proxmox, node: v6.14.1
            2018-04-25 12:08:47.537  - [33mwarn[39m: proxmox.0 UUID: 192.168.1.200
            2018-04-25 12:08:50.700  - [33mwarn[39m: proxmox.0 Devices: {"data":[{"status":"online","type":"node","maxdisk":31044079616,"maxmem":16753127424,"mem":8787021824,"node":"HomeMaster","disk":2417025024,"uptime":701175,"maxcpu":4,"cpu":0.117036472342439,"ssl_fingerprint":"2E:61:8F:D9:0C:C1:10:A5:AC:93:2C:24:04:02:F7:74:93:8F:C9:4F:3F:F9:3A:36:F3:30:EC:BC:91:4D:DF:F4","id":"node/HomeMaster","level":""}]}
            2018-04-25 12:08:50.736  - [32minfo[39m: proxmox.0 ack is not set!
            • Dutchman
              So da der adapter jetzt seit über einer stunde läuft mal ein update, ich haben den interval auf 10000 (10 Sekunden) eingestellt
              Zu erst feedback zur Konfiguration :
              • request Intervall sollte nicht in Millisekunden sondern Sekunden sein mit einem standard wert (z.b. 30)
              Da ich mir nicht bewusst war das dies Millisekunden sind und beim ersten mal 30 eingegeben hate lief min kompletter Biobroker fest.
              Desweiteren :
              • objecte werden erstellt
              • objecte werden alle 10 Sekunden aktualisiert
              • adapter läuft bis jetzt stabil
              • beim starten bekommen ich 2 "warn meldung" und die info "ach is not set!"
              Soweit sieht es sehr gut aus und ich freue mich bereits auf die Erweiterungen welche geplant sind, vor allem storage Verbrauch vom host und den virtuellen platten sind sehr sinnvoll dan kann Biobroker und Pushover meine warnmeldungen für proxmox übernehmen.
              Wen die function für "snaphots" implementiert wird währe es sehr schön zu sehen ob/wan der snapshot fertig erstellt wurde.
              Danke @Meistertr super adapter !
              • ruhr70
                ruhr70 last edited by
                @eric2905:
                @ruhr70:
                Gruß,
                Eric
                Von unterwegs getippert `
                Danke Eric.
                scheue mich trotzdem, da der NUC, auf dem der esxi ist dann für Proxmos herhalten muss.
                VMs auf zwei internen SSDs und eine Freigabe vom NAS plus ein eingebundenes iSCSI (?) Volume vom NAS.
                12 Maschinen.
                Wenn ich damit anfange gibt es kein Weg zurück.
                Das meinte ich eigentlich mit „Weg finde“ [emoji3][emoji848]
                  Habe jetzt auch mal installiert - lief auf Anhieb.
                  Intervall: sind das msec?
                  User und Passwort in Klartext - nicht ganz so prickelnd
                  Rainer
                  • eric2905
                    @ruhr70:
                    Wenn ich damit anfange gibt es kein Weg zurück. `
                    ich könnte Dir für die Migration einen NUC (i3 oder i5 - bin mir nicht ganz sicher) leihen.
                    RAM und SSD müsste ausreichen.
                    Gruß,
                    Eric
                    • Dutchman
                      @Homoran:
                      Intervall: sind das msec? `
                      jup, siehe meinen post damit hab ich mir meinen Biobroker zerschossen durch dies auf 30 zu stellen da ging niks mehr 🙂
                      @Homoran:
                      User und Passwort in Klartext - nicht ganz so prickelnd `
                      agree, kompleet vergessen in meiner Übersicht
                      • ruhr70
                        @eric2905:
                        @ruhr70:
                        Gruß,
                        Eric `
                        mhhh…
                        also vom Ablauf:
                        • Proxmox auf temporären Rechner
                        • VMs migrieren und testen
                        • ESXi plattmachen
                        • Proxmox auf dem NUC installieren
                        • Umzug der VMs
                        ich habe noch ein altes Notebook mit 8GB RAM. Ich probiere das mal. Die VMs kann ich zur Not nach dem Test auf dem NAS zwischenspeichern
                        Danke für Dein Angebot!
                        • Dutchman
                          @ruhr70:
                          mhhh…
                          also vom Ablauf:
                          • ESXi plattmachen
                          • Umzug der VMs
                          Danke für Dein Angebot! `
                          klinkt gut, du wirst es nicht bereuen glaube mir ich war auch erst skeptisch wegen der Arbeit die es mit sich mitbringt nur jetzt nachdem proxmox ne zeit läuft möchte ich nicht mehr zurück ! :mrgreen:
                            @Dutchman:
                            agree, kompleet vergessen in meiner Übersicht `
                            zu allem Ärger komme ich auch nur mit dem root an die Daten mit dem User klappt es nicht, habe jetzt noch einen zweiten User angeleget, damit auch nicht 😞
                            Trotzdem ist die Ampel grün
                            Rainer
                            • ruhr70
                              glaube ich auch [emoji2]
                              hab es schon auf einem Firmennotebook getestet.
                              will ja unbedingt wechseln, alleine schon wg. dem Backup.
                              dann muss ich wohl mal einen Tag einplanen
                              • eric2905
                                Melde Dich, wenn Du den NUC leihen willst.
                                Gruß,
                                Eric
                                • Dutchman
                                  Mir ist aufgefallen das die werte von dem nicht den jetzigen genutztem ram sonder "freien ram" widerspiegeln, sollte also memfree heissen
                                  Edit : hmm… nee auch nicht, Fazit is das dem nicht jetzig benutzen oder freien ram wiedergibt also was für ein wert das genau ist mir schleierhaft 🙂
                                  • Meistertr
                                    @Dutchman:
                                    Edit : hmm… nee auch nicht, Fazit is das dem nicht jetzig benutzen oder freien ram wiedergibt also was für ein wert das genau ist mir schleierhaft 🙂 ` Hab gerade nachgeschaut, hab nen Rechenfehler, es muss nicht dezimal sonder binär umgerechnet werde. Änder ich
                                    Gesendet von meinem Handy
                                    • Dutchman
                                      @Meistertr:
                                      Hab gerade nachgeschaut, hab nen Rechenfehler, es muss nicht dezimal sonder binär umgerechnet werde. Änder ich `
                                      Nice ! wen du doch bei dem stück vom code bist, währe es auch möglich "Free mem" in Prozent als object zu bekommen sagt mehr als der wert 🙂
                                      • Meistertr
                                        Ja das hatte ich eh vor
                                        • Dutchman
                                          @Meistertr:
                                          Gesendet von meinem Handy `
                                          Super danke!
                                          Adapter läuft jetzt seit 9 Stunden stabiel durch und polled alle 6 Sekunden bin begeistert
                                            Bist du unter root oder dummUser drin?
                                            proxmox
                                            75
                                            486
                                            109404
