    4. Flot lädt Grafik nicht mit socketio 2.0.1
      ple last edited by
      Also bei einem Graphen wo es funktioniert schickt er
      sql.0	2018-04-23 06:11:19.763	debug	Send: 41 of: 41 in: 7ms
      sql.0	2018-04-23 06:11:19.756	debug	SELECT ts, val FROM `iobroker`.ts_number WHERE `iobroker`.ts_number.id=50 AND `iobroker`.ts_number.ts < 1524456679626 AND `iobroker`.ts_number.ts >= 1524370279626 UNION ( SELECT ts, val FROM `iobroke
      socketio.0	2018-04-23 06:11:19.753	debug	sendTo "getHistory" to system.adapter.sql.0 from system.adapter.socketio.0
      scheint auch alles normal zu sein.
      Aber bei Temperatur kommt er erst garnicht soweit.
      sql.0	2018-04-23 06:13:22.058	debug	new value received for hm-rpc.0.LEQ1314518.2.POWER, new-value=0, ts=1524456802056, relog=false
      socketio.0	2018-04-23 06:13:22.005	info	Connected system.user.admin from ::ffff:192.168.10.101
      socketio.0	2018-04-23 06:13:21.215	info	Connected system.user.admin from ::ffff:192.168.10.101
      socketio.0	2018-04-23 06:13:19.949	info	Connected system.user.admin from ::ffff:192.168.10.101
      socketio.0	2018-04-23 06:13:18.439	info	Connected system.user.admin from ::ffff:192.168.10.101
      socketio.0	2018-04-23 06:13:17.470	info	Connected system.user.admin from ::ffff:192.168.10.101
      socketio.0	2018-04-23 06:13:16.043	info	Connected system.user.admin from ::ffff:192.168.10.101
      socketio.0	2018-04-23 06:13:14.684	info	Connected system.user.admin from ::ffff:192.168.10.101
      socketio.0	2018-04-23 06:13:13.832	info	Connected system.user.admin from ::ffff:192.168.10.101
      socketio.0	2018-04-23 06:13:13.195	info	Connected system.user.admin from ::ffff:192.168.10.101
      socketio.0	2018-04-23 06:13:12.551	info	Connected system.user.admin from ::ffff:192.168.10.101
      socketio.0	2018-04-23 06:13:11.006	info	Connected system.user.admin from ::ffff:192.168.10.101
      socketio.0	2018-04-23 06:13:10.243	info	Connected system.user.admin from ::ffff:192.168.10.101
      sql.0	2018-04-23 06:13:06.434	debug	sendTo "getHistory" to system.adapter.socketio.0 from system.adapter.sql.0
      Ab und zu meckert der SQL wegen den Primärschlüssel, weiß aber noch nicht warum, weil ich die Datenbank gestern ja bereits gelöscht hatte.
      sql.0	2018-04-23 06:09:23.040	error	Cannot insert INSERT INTO `iobroker`.ts_string (id, ts, val, ack, _from, q) VALUES(140, 1524456561409, 'NULL', 1, 6, 64);: Error: ER_DUP_ENTRY: Duplicate entry '140-1524456561409' for key 'PRIMARY'
        ple last edited by
        So, ich habe noch mal ein paar Test gemacht.
        Socketio, Web, Simple Api gelöscht und ein Neustart.
        Web wird anscheinend für Flot benutzt, also das wieder neuinstalliert.
        Gleicher Effekt, Temperaturen der Mi Home Geräte werden nicht angezeigt. Dann mal Azimut genommen vom Sonnenstandscript, gleiches Spiel, wird auch nicht angezeigt. Andere Werte vom Javascript gehen soweit.
        Dann mal history installiert. Da sind die gleichen Probleme.
        Kann das irgendwer nachstellen?
        Socketio kann ich auch nicht downgraden, da diese nicht mehr verfügbar sind.
        Also für ein paar Tipps wäre ich noch sehr Dankbar 🙂 Oder die radikale Tour neuinstallieren und alles rüberschieben 😞
        • eric2905
          eric2905 last edited by
          kurze Zusammenfassung für mich:
          Welche Versionen hast Du:
          Web
          Socket.io
          js-controller
          Admin
          Ich test gerade bei mir uns versuche das mal nachzustellen.
          Gruß,
          Eric
          • Dutchman
            @ple:
            Socketio kann ich auch nicht downgraden, da diese nicht mehr verfügbar sind. `
            sudo iobroker upgrade socket.io@1.8.6
            • eric2905
              @ple:
              Das ist ein Anzeigefehler … die 1.8.6 gibt es.
              Siehe auch den Post vom Dutchman.
              Gruß,
              Eric
                ple last edited by
                So, die 1.8.6 ging dann mit manuell mit dem Terminal. Kann man irgendwie sehen, welche noch verfügbar sind für den Downgrade?
                Die Version 1.8.6 hatte ich auch in meinen Snapshot, da war die Welt noch in Ordnung. Dann im backup auf 2.0.1 upgrade gemacht, und siehe da, es ging nicht. Danach wieder zurück auf 1.8.6 mit einem Neustart. alles wieder gut.
                Bin dann zurück zu meiner neuen installation gegangen und habe dort das gleiche gemacht mit Neustart. Auch dort kommen die Graphen wieder.
                Also scheint irgendwie am socketio zu liegen.
                Ansonsten hier die Versionen
                Web 2.1.9
                Socket.io 2.0.1
                js-controller 1.4.2
                Admin 3.3.9
                Node 6.14.1
                Gruß und Danke für eure Unterstützung
                • fu_zhou
                  fu_zhou last edited by
                  Bei mir ist seit einem Reboot auch vorbei mit Flot Charts:
                  Web 2.3.0
                  Socket.io 2.0.1
                  js-controller 1.4.2
                  Admin 3.3.9
                  Node 6.12.2
                  • eric2905
                    Hi ho,
                    ich habe mit dem socket 2.0.1 auch das Log voll mit
                    socketio.0	2018-04-23 21:08:10.547	info	Connected system.user.admin from ::ffff:192.168.1.78
                    socketio.0	2018-04-23 21:08:12.382	info	Connected system.user.admin from ::ffff:192.168.1.78
                    socketio.0	2018-04-23 21:08:14.547	info	Connected system.user.admin from ::ffff:192.168.1.78
                    Seltsamerweise hatte ich nun auch plötzlich Flot-Diagramme, die nicht angezeigt wurden … nur diese drehende Scheibe.
                    Sobald ich auf die 1.8.6 gehe, hören die Log-Einträge auf.
                    Auch das eben noch "klemmende" Diagram kommt wieder.
                    Sehr seltsam.
                    Gruß,
                    Eric
                      ple last edited by
                      Ok, gut das man es nachstellen kann. Wenn ich noch irgendwie unterstützen kann, dann bitte eben Anweisungen geben 😉
                      • etv
                        etv last edited by
                        Liebe Leute,
                        selbes Problem auch "ohne socket.io" - hab heute den web Adapter aktualisiert und nun das selbe Problem - nur mehr volle logs aber keine Diagramme mehr….
                        allerdings kann auch ich den downgrade nicht machen.....hab es mit "iobroker upgrade web@2.3.0" versucht...hat nix gebracht, die Version ist noch immer die aktuelle 2.3.2
                        D.h. auch da wird die Aktualisierung vom inkludierten socket.io das Problem sein....hoffe, dass wird bald wieder gefixt...
                        Liebe Grüße
                        tom
                        • Bluefox
                          Bluefox last edited by
                          2.3.2 Web hat Patch für Socket.io
                          Wenn du http://ip:8082/lib/js/socket.io.js aufrufst, siehst du da 2.1.0 Version in Comments?
                          Und http://ip:8082/lib/js/socket.io.js ?
                            hrhome last edited by
                            Ich habe bei mir alle Pakete aktuell und mit der 2.3.2 Web habe ich die gleichen Probleme.
                            Nachdem ich mir socket.io 1.8.6 installiert habe und den Webadapter auf die socket.io umgestellt habe geht es wieder.
                            • Bluefox
                              @hrhome:
                              Nachdem ich mir socket.io 1.8.6 installiert habe und den Webadapter auf die socket.io umgestellt habe geht es wieder. `
                              Das hilft mir nicht. Hast du Browser cache gelöscht?
                              Geht Admin 3.3.9 ? Der hat auch 2.1.0 Socket.io
                              Ist iobroker.Socketio als Instanz oder im Web integriert?
                              • Bluefox
                                Iobroker.socketio 2.0.1 braucht unbedingt Web 2.3.2 und dabei nach restart vom web sollte browser cache gelöscht sein
                                Wenn das alles mit ja beantwortet sein kann, dann kann man weiter suchen.
                                Ich bin auch über Situation nicht glücklich, weil ich von Socket.io Paket erwarte, dass das Ding funktioniert, aber das tut nicht und da sind ganz andere Leute involviert.
                                  @Bluefox:
                                  @hrhome:
                                  Ist iobroker.Socketio als Instanz oder im Web integriert? `
                                  Web Instance ist natürlich neu gestartet und der komplette ioBroker auch schon.
                                  Browser Cache war gelöscht und gleiches verhalten an unterschiedlichen Rechnern und Browsern.
                                  Admin ist 3.4.0 und funktioniert problemlos.
                                  Mit web 2.3.2 funktionieren die Flot mit integrierter Socket nicht. Mit aktuellster zusätzlicher Socket.io funktioniert es aber auch nicht.
                                  Funktionieren tun die Flot nur in der Kombination mit aktueller web 2.3.2 und zusätzlicher socket.io in Version 1.8.6.
                                  • N
                                    nobody last edited by
                                    Hallo bluefox,
                                    danke für die Änderungen. Zumindest bei mir werden die Diagramme im Browser wieder korrekt angezeigt.
                                    In der Cordova-App noch nicht. Die muss wohl auch mit den neuen Versionen neu kompiliert werden.
                                    Markus
                                      @nobody:
                                      Hallo bluefox,
                                      Markus `
                                      Welche Änderungen?
                                      Wie ist denn deine Konfig mit welchen Versionen?
                                      Integrierte socket.io oder zusätzliche Instanz?
                                      Bei mir und auch anderen hier im Forum gibt es ja immer noch probleme.
                                      Holger
                                      • etv
                                        etv last edited by
                                        @Bluefox:
                                        Und http://ip:8082/lib/js/socket.io.js ? `
                                        …leider nein - kommt eine ganze Lawine an Daten, aber auf der gesamten Seite ist lt. Suchfunktion 2.1.0 nicht zu finden...
                                        Auch "2.1" ist nicht zu finden, nur 2.0.0. kommt auf der Seite 2x vor....
                                        Den Output hab ich angehängt.
                                        Aber ein paar der Diagramme gehen nun wieder - Temp und Hum alle nicht aber z.B. LUX oder Heizzeiten Diagramme sind wieder da....Unterschied der mir da einfällt: die letzteren haben keine Komastellen, Temp und Hum schon.....hilft das weiter??
                                        Liebe Grüße
                                        tom
                                        915_output.txt
                                        • Dutchman
                                          ich habe soeben web aus der latest repository auf 2.2.3 gebracht, socket.io war bereits 2.0.1
                                          im moment sieht es für mich so aus als wen flog wieder vernünftig reagiert, die Grafiken laden schneller und ich hatte nach mehreren reloads noch keine Aussetzer
                                            @Dutchman:
                                            im moment sieht es für mich so aus als wen flog wieder vernünftig reagiert, die Grafiken laden schneller und ich hatte nach mehreren reloads noch keine Aussetzer `
                                            Nach einem downgrade von web oder socket.io geht es ja anscheinend wieder.
                                            Ich habe web aktuell mit 2.3.2 und socket.io 1.8.6. Damit rennt es zumindest wieder.
                                            Vorher haben auch einge wenige Graphen was angezeigt. Aber ich habe den Verdacht das es eher an der Menge der Daten liegt die per SQL abgefragt werden. Kleinere Graphen mit wenig Daten wurden geladen und andere mit mehr Daten wurden nämlich nicht geladen.
                                            Holger
                                            61
                                            6575
