    4. Abfrage Wiffi Pump
    Abfrage Wiffi Pump
    • Jensen
      Jensen last edited by
      Ich dachte, daß es mit dem Inhalt weniger zu tun hat, als generell mit der Vorgehensweise.
      modultyp	"wiffi-pump"
      vars
      0
      name	"0"
      homematic_name	"wiffi_pump_ip"
      desc	"ip des wiffi-pump"
      type	"string"
      unit	""
      value	"192.168.178.43"
      name	"4"
      homematic_name	"wiffi_ntc"
      desc	"Temperatur_NTC"
      type	"number"
      unit	"%"
      value	26.57
      name	"2"
      homematic_name	"wiffi_ww_temp"
      desc	"Temperatur_A"
      type	"number"
      unit	"gradC"
      value	24
      name	"3"
      homematic_name	"wiffi_vorlauftemp"
      desc	"Temperatur_B"
      type	"number"
      unit	"gradC"
      value	24
      name	"1"
      homematic_name	"wiffi_pump"
      desc	"Zirkulationspumpe"
      type	"boolean"
      unit	""
      value	false
      Systeminfo
      MAC-Adresse	"ea:c8:37:94:1:60"
      Homematic_CCU_ip	"my_ccuip"
      WLAN_ssid	"WLAN-JN"
      WLAN_Signal_dBm	-50
      sec_seit_reset	1786
      zeitpunkt	" 7 16:06"
      firmware	"wiffi_pump2_88"
        robsdobs last edited by
        Das ist kein gültiges JSON. Ist das aus dem Browser heraus kopiert?
        • Jensen
          Ja, direkt aus dem Browser.
          Wobei ich gesehen habe, daß einige Doppelpunkte fehlen.
          Ich habe versucht, irgendwas mit einem abgewandelten Script aus dem Forum (Pegelstände) zu bekommen, da klappt nichts.
          Mit dem Parser Adapter bekomme ich mittlerweile einen Datenpunkt mit folgendem Inhalt:
          {"modultyp":"wiffi-pump","vars":[{"name":"0","homematic_name":"wiffi_pump_ip","desc":"ip des wiffi-pump","type":"string","unit":"","value":"192.168.178.43"},{"name":"4","homematic_name":"wiffi_ntc","desc":"Temperatur_NTC","type":"number","unit":"%","value":25.90},{"name":"2","homematic_name":"wiffi_ww_temp","desc":"Temperatur_A","type":"number","unit":"gradC","value":23.6},{"name":"3","homematic_name":"wiffi_vorlauftemp","desc":"Temperatur_B","type":"number","unit":"gradC","value":23.4},{"name":"1","homematic_name":"wiffi_pump","desc":"Zirkulationspumpe","type":"boolean","unit":"","value":false}],"Systeminfo":{"MAC-Adresse":"ea:c8:37:94:1:60","Homematic_CCU_ip":"my_ccuip","WLAN_ssid":"WLAN-JN","WLAN_Signal_dBm":-49,"sec_seit_reset":46,"zeitpunkt":" 5 08:28","firmware":"wiffi_pump2_88"}}
          Aber was mache ich jetzt damit?
          • ruhr70
            ruhr70 last edited by
            probiere mal bitte nur log und nicht console.log
            var request = require('request');
            request('http://192.168.178.43/json:', function (error, response, body) {
              log('error:', error); // Print the error if one occurred
              log('statusCode:', response && response.statusCode); // Print the response status code if a response was received
              log('body:', body); // Print the HTML
            • ruhr70
              @Jensen:
              Aber was mache ich jetzt damit? `
              Der Datenpunkt enthält ein sauberes JSON, welches Du nun wunderbar mit einem Skript verarbeiten und in einzelne Datenpunkte die gewünschten Werte schreiben kannst.
              Dann würde ich an Deiner Stelle auf dieser Basis weitermachen.
                War zu langsam
                • Jensen
                  Also die Sache mit request klappt nicht, egal ob Console.Log oder nur Log.
                  Ich werde mich jetzt mit dem Inhalt des Datenpunktes beschäftigen.
                  Gibt's da vielleicht noch Beispiele irgendwo?
                  Allen Danke für die Hilfe
                  Gruß Jens
                  • ruhr70
                    @Jensen:
                    Gibt's da vielleicht noch Beispiele irgendwo? `
                    probier mal bitte:
                    var idJson ="parser.o.deinJson";
                    function werteAuslesen(jsonStr) {
                        var myJson = JSON.parse(jsonStr);
                        log("wiffi_vorlauftemp: ",myJson.vars[3].value + "°C");
                    on({id:idJson,change:'ne'}, function (obj) {
                        werteAuslesen(obj.state.val);
                    werteAuslesen(getState(idJson).val);
                    In der Zeile:
                    Muss die ID Deines Datenpunkts vom Parseradapter rein.
                    • Jensen
                      Prima, danke, damit kann ich arbeiten.
                      • Jensen
                        So sieht mein derzeitiges script aus. Damit lassen sich die relevanten Daten des WiffiPump abfragen.
                        Das Aktualisierungsintervall entspricht im Moment dem, was im Parser Adapter eingestellt ist.
                        var idJson = "parser.0.WiffiPump";
                        var state1 = "javascript.0.WiffiPump.T1";
                        var state2 = "javascript.0.WiffiPump.T2";
                        var state3 = "javascript.0.WiffiPump.T3";
                        var state4 = "javascript.0.WiffiPump.On";
                        createState(state1, {name: "T1", unit: "°C"});
                        createState(state2, {name: "T2", unit: "°C"});
                        createState(state3, {name: "T3", unit: "°C"});
                        createState(state4, {name: "On",});
                            var T1 = myJson.vars[1].value;
                            var T2 = myJson.vars[2].value;
                            var T3 = myJson.vars[3].value;
                            var On = myJson.vars[4].value;
                            log("wiffiPumpT1: " + T1 + "°C");
                            log("wiffiPumpT2: " + T2 + "°C");
                            log("wiffiPumpT3: " + T3 + "°C");
                            log("wiffiPumpOn: " + On);
                            setState(state1, T1);
                            setState(state2, T2);
                            setState(state3, T3);
                            setState(state4, On);
                        • ruhr70
                          @Jensen:
                          danke fürs teilen!
                          • Jensen
                            Und hier dann gleich noch für Wiffi WZ, vom gleichen Anbieter.
                            Auch eine interessante Sensorplatine.
                            var idJson = "parser.1.WiffiWZ";
                            var state01 = "javascript.0.WiffiWZ.CO2";
                            var state02 = "javascript.0.WiffiWZ.Temp";
                            var state03 = "javascript.0.WiffiWZ.Feuchte";
                            var state04 = "javascript.0.WiffiWZ.Taupunkt";
                            var state05 = "javascript.0.WiffiWZ.Absolutfeuchte";
                            var state06 = "javascript.0.WiffiWZ.Luftdruck";
                            var state07 = "javascript.0.WiffiWZ.Helligkeit";
                            var state08 = "javascript.0.WiffiWZ.MotionLinks";
                            var state09 = "javascript.0.WiffiWZ.MotionRechts";
                            var state10 = "javascript.0.WiffiWZ.Noise";
                            var state11 = "javascript.0.WiffiWZ.SecSinceReset";
                            createState(state01, {name: "CO2", unit: "%"});
                            createState(state02, {name: "Temp", unit: "°C"});
                            createState(state03, {name: "Feuchte", unit: "%rH"});
                            createState(state04, {name: "Taupunkt", unit: "°C"});
                            createState(state05, {name: "Absolutfeuchte", unit: "g/m3"});
                            createState(state06, {name: "Luftdruck", unit: "mB"});
                            createState(state07, {name: "Helligkeit", unit: "lux"});
                            createState(state08, {name: "MotionLinks"});
                            createState(state09, {name: "MotionRechts"});
                            createState(state10, {name: "Noise"});
                            createState(state11, {name: "SecSinceReset", unit: "sec"});
                                var v01 = myJson.vars[1].value;
                                var v02 = myJson.vars[2].value;
                                var v03 = myJson.vars[3].value;
                                var v04 = myJson.vars[4].value;
                                var v05 = myJson.vars[5].value;
                                var v06 = myJson.vars[6].value;
                                var v07 = myJson.vars[8].value;
                                var v08 = myJson.vars[9].value;
                                var v09 = myJson.vars[10].value;
                                var v10 = myJson.vars[12].value;
                                var v11 = myJson.Systeminfo.millis_seit_reset/1000;
                                setState(state01, v01);
                                setState(state02, v02);
                                setState(state03, v03);
                                setState(state04, v04);
                                setState(state05, v05);
                                setState(state06, v06);
                                setState(state07, v07);
                                setState(state08, v08);
                                setState(state09, v09);
                                setState(state10, v10);
                                setState(state11, v11);
                                log("WiffiWZ CO2: " + v01 + "%");
                              @Jensen:
                              für Wiffi WZ `
                              siehe hier:
                              viewtopic.php?f=34&t=2688&hilit=wiffi+skript
                              Rainer
                                f0rd42 last edited by
                                Sorry wenn ich den Thread noch mal auskrame.
                                Mir ist nicht so ganz klar, was ich denn beim Parser machen muss.
                                Derzeit habe ich den Parser installiert und den Endpunkt eingegeben:
                                ~~![](</s><URL url=)https://cdn.pbrd.co/images/HXC8ypPf.png" />
                                als Script habe ich das letzte aus dem Thread genutzt:
                                in den Objekten sehe ich nun auch unter javascript.0.WiffiPump die Objekte "ON", T1, T2 und T3
                                aber ein Update der Variablen findet nicht statt.
                                Ich denke mal ich habe hier im Parser noch was falsch, habe mich aber noch null damit beschäftigt.
                                Danke~~
                                • Jensen
                                  so wirklich kann ich nicht helfen, wundere mich fast über mich selbst, wenn ich die Beiträge durchscrolle, daß die von mir sind.
                                  Aber schau' mal, weiter oben sind solche Log Zeilen mit drin, vielleicht kommst du damit dem Problem auf die Schliche?
                                  Gruß Jens
                                    Hallo Jens
                                    Kannst du mir mal einen Screenshot von deinen Parser Einstellungen schicken?
                                    1506
