    4. [Vorlage] Spotify Skript
    • Mic
      Mic Developer last edited by
      Das gleiche leider bei mir. Habe auch die Instanz und Objekte "spotify-premium.0" gelöscht, neu hinzugefügt, Autorisierung neu durchgeführt, etc., und es kommt immer wieder zu den Fehlern.
      ! host.raspberrypi 2018-04-24 21:19:55.242 info Restart adapter system.adapter.spotify-premium.0 because enabled
      ! host.raspberrypi 2018-04-24 21:19:55.242 error instance system.adapter.spotify-premium.0 terminated with code 0 (OK)
      ! host.raspberrypi 2018-04-24 21:19:55.241 error Caught by controller[0]: at IncomingMessage.g (events.js:292:16)
      ! host.raspberrypi 2018-04-24 21:19:55.241 error Caught by controller[0]: at IncomingMessage. (/opt/iobroker/node_modules/iobroker.spotify-premium/node_modules/request/request.js:1085:12)
      ! host.raspberrypi 2018-04-24 21:19:55.241 error Caught by controller[0]: at Request.emit (events.js:188:7)
      ! host.raspberrypi 2018-04-24 21:19:55.239 error Caught by controller[0]: at emitOne (events.js:96:13)
      ! host.raspberrypi 2018-04-24 21:19:55.239 error Caught by controller[0]: at Request. (/opt/iobroker/node_modules/iobroker.spotify-premium/node_modules/request/request.js:1163:10)
      ! host.raspberrypi 2018-04-24 21:19:55.239 error Caught by controller[0]: at Request.emit (events.js:191:7)
      ! host.raspberrypi 2018-04-24 21:19:55.239 error Caught by controller[0]: at emitTwo (events.js:106:13)
      ! host.raspberrypi 2018-04-24 21:19:55.239 error Caught by controller[0]: at Request.self.callback (/opt/iobroker/node_modules/iobroker.spotify-premium/node_modules/request/request.js:186:22)
      ! host.raspberrypi 2018-04-24 21:19:55.239 error Caught by controller[0]: at Request._callback (/opt/iobroker/node_modules/iobroker.spotify-premium/main.js:166:45)
      ! host.raspberrypi 2018-04-24 21:19:55.238 error Caught by controller[0]: at Object.parse (native)
      ! host.raspberrypi 2018-04-24 21:19:55.237 error Caught by controller[0]: SyntaxError: Unexpected end of JSON input
      ! spotify-premium.0 2018-04-24 21:19:55.168 error SyntaxError: Unexpected end of JSON input at Object.parse (native) at Request._callback (/opt/iobroker/node_modules/iobroker.spotify-premium/main.js:166:45) at Request.self.callback (/opt/
      ! spotify-premium.0 2018-04-24 21:19:55.165 error uncaught exception: Unexpected end of JSON input
      ! spotify-premium.0 2018-04-24 21:19:49.543 info starting. Version 0.1.2 in /opt/iobroker/node_modules/iobroker.spotify-premium, node: v6.14.1
      • twonky
        twonky last edited by
        Ich habe das Problem auch. Schein aktuell eine Störung bei Spotify zu sein, der Dienst meldet zwar ein http 200, sendet aber keine Daten. Heißt also einfach warten, bis es wieder geht.
        • Mic
          Danke für Deine sehr schnelle Rückmeldung twonky, dann lasst uns mal abwarten.
          Übrigens herzlichen Dank für Deine Arbeit, die Du hier rein steckst! Dies ebenso an Lucky, der das Script gestartet hat. Very much appreciated
            spraxel last edited by
            Also bis dato funktioniert es immer noch nicht. Irgend eine Lösung?
            • twonky
              Ich habe mir das jetzt mal genauer angesehen. Spotify hat ihre API geändert, wenn gerade kein Device aktiv ist. Habs behoben, Version 0.1.3 ist jetzt verfügbar: https://github.com/twonky4/ioBroker.spotify-premium
              • lobomau
                lobomau last edited by
                Sauber! Läuft wieder! 🙂
                • Mic
                  Super, läuft auch bei mir wieder, vielen Dank!
                  (Hier stand Blödsinn mit der Warnmeldung, die stammte von meinem Aufruf und hat nichts mit dem Adapter zu tun – daher entfernt)
                  • Mic
                    Ich bekomme weiterhin zuverlässig alle 15 Minuten untenstehende error-Log-Einträge vom Spotify-Adapter.
                    Alle 15 Minuten deshalb, weil in der Adapterkonfiguration unter "Aktualisierungsintervall für Playlisteninformationen" die Zahl 15 eingetragen ist.
                    Setze ich die Zahl auf 2 Minuten, so kommen die Logeinträge eben alle gute 2 Minuten.
                    Das passiert ohne andere aktive Scripts.
                    Wie könnte man denn das lösen? Als Workaround habe ich das jetzt mal auf 1440 gestellt, damit es nur alle 24 Stunden auftritt.
                    Danke!
                    ! spotify-premium.0 2018-04-29 21:16:33.116 info starting. Version 0.1.3 in /opt/iobroker/node_modules/iobroker.spotify-premium, node: v8.11.1
                    ! host.All-In-One_RasPi 2018-04-29 21:16:31.556 info instance system.adapter.spotify-premium.0 started with pid 19188
                    ! host.All-In-One_RasPi 2018-04-29 21:16:01.541 info Restart adapter system.adapter.spotify-premium.0 because enabled
                    ! host.All-In-One_RasPi 2018-04-29 21:16:01.541 error instance system.adapter.spotify-premium.0 terminated with code 0 (OK)
                    ! Caught 2018-04-29 21:16:01.541 error by controller[0]: at emitOne (events.js:116:13)
                    ! Caught 2018-04-29 21:16:01.541 error by controller[0]: at Request. (/opt/iobroker/node_modules/iobroker.spotify-premium/node_modules/request/request.js:1163:10)
                    ! Caught 2018-04-29 21:16:01.540 error by controller[0]: at Request.emit (events.js:214:7)
                    ! Caught 2018-04-29 21:16:01.540 error by controller[0]: at emitTwo (events.js:126:13)
                    ! Caught 2018-04-29 21:16:01.540 error by controller[0]: at Request.self.callback (/opt/iobroker/node_modules/iobroker.spotify-premium/node_modules/request/request.js:186:22)
                    ! Caught 2018-04-29 21:16:01.540 error by controller[0]: at Request._callback (/opt/iobroker/node_modules/iobroker.spotify-premium/main.js:172:25)
                    ! Caught 2018-04-29 21:16:01.540 error by controller[0]: at /opt/iobroker/node_modules/iobroker.spotify-premium/main.js:609:21
                    ! Caught 2018-04-29 21:16:01.540 error by controller[0]: at persistPlaylist (/opt/iobroker/node_modules/iobroker.spotify-premium/main.js:505:21)
                    ! Caught 2018-04-29 21:16:01.540 error by controller[0]: at Array.forEach ()
                    ! Caught 2018-04-29 21:16:01.540 error by controller[0]: at /opt/iobroker/node_modules/iobroker.spotify-premium/main.js:588:33
                    ! Caught 2018-04-29 21:16:01.539 error by controller[0]: TypeError: Cannot read property 'url' of undefined
                    ! spotify-premium.0 2018-04-29 21:16:01.408 error at emitOne (events.js:116:13)
                    ! spotify-premium.0 2018-04-29 21:16:01.408 error at Request. (/opt/iobroker/node_modules/iobroker.spotify-premium/node_modules/request/request.js:1163:10)
                    ! spotify-premium.0 2018-04-29 21:16:01.408 error at Request.emit (events.js:214:7)
                    ! spotify-premium.0 2018-04-29 21:16:01.408 error at emitTwo (events.js:126:13)
                    ! spotify-premium.0 2018-04-29 21:16:01.408 error at Request.self.callback (/opt/iobroker/node_modules/iobroker.spotify-premium/node_modules/request/request.js:186:22)
                    ! spotify-premium.0 2018-04-29 21:16:01.408 error at Request._callback (/opt/iobroker/node_modules/iobroker.spotify-premium/main.js:172:25)
                    ! spotify-premium.0 2018-04-29 21:16:01.408 error at /opt/iobroker/node_modules/iobroker.spotify-premium/main.js:609:21
                    ! spotify-premium.0 2018-04-29 21:16:01.408 error at persistPlaylist (/opt/iobroker/node_modules/iobroker.spotify-premium/main.js:505:21)
                    ! spotify-premium.0 2018-04-29 21:16:01.408 error at Array.forEach ()
                    ! spotify-premium.0 2018-04-29 21:16:01.408 error at /opt/iobroker/node_modules/iobroker.spotify-premium/main.js:588:33
                    ! spotify-premium.0 2018-04-29 21:16:01.408 error TypeError: Cannot read property 'url' of undefined
                    ! spotify-premium.0 2018-04-29 21:16:01.408 error uncaught exception: Cannot read property 'url' of undefined
                    • twonky
                      @Mic: danke für das Log. Sieht für mich so als als sei da eine Playlist ohne Image Url. Vielleicht eine ohne Tracks? Diese dann einfach Löschen und es geht wieder. Ich plane dafür Fix in der kommenden Version.
                      • Mic
                        Danke Twonky! Ich hatte in der Tat leere Playlists in Spotify, diese gelöscht, Ordner "spotify-premium.0.Playlists" gelöscht, jedoch nach Aktualisierung liest der Adapter aufs erste Mal nicht alle ein, und wieder diese Fehler.
                        Daher freue ich mich auf das nächste Update 🙂
                          schubi82 last edited by
                          bei mir ist es irgendwie ein Glücksspiel, ob der Adapter irgendwelche Eingaben annimmt oder nicht… Nach einem Neustart des Adapters geht es dann für unbestimmte Zeit wieder. Wenn es nicht geht, bekomme ich folgende Einträge:
                          ! spotify-premium.0 2018-05-05 18:10:25.416 warn at IncomingMessage.emit (events.js:185:7)
                          ! spotify-premium.0 2018-05-05 18:10:25.416 warn at emitNone (events.js:91:20)
                          ! spotify-premium.0 2018-05-05 18:10:25.416 warn at IncomingMessage.g (events.js:292:16)
                          ! spotify-premium.0 2018-05-05 18:10:25.416 warn at IncomingMessage. (/opt/iobroker/node_modules/request/request.js:1085:12)
                          ! spotify-premium.0 2018-05-05 18:10:25.416 warn at Request.emit (events.js:188:7)
                          ! spotify-premium.0 2018-05-05 18:10:25.416 warn at emitOne (events.js:96:13)
                          ! spotify-premium.0 2018-05-05 18:10:25.416 warn at Request. (/opt/iobroker/node_modules/request/request.js:1163:10)
                          ! spotify-premium.0 2018-05-05 18:10:25.416 warn at Request.emit (events.js:191:7)
                          ! spotify-premium.0 2018-05-05 18:10:25.416 warn at emitTwo (events.js:106:13)
                          ! spotify-premium.0 2018-05-05 18:10:25.416 warn at Request.self.callback (/opt/iobroker/node_modules/request/request.js:186:22)
                          ! spotify-premium.0 2018-05-05 18:10:25.416 warn at Request._callback (/opt/iobroker/node_modules/iobroker.spotify-premium/main.js:258:42)
                          ! spotify-premium.0 2018-05-05 18:10:25.416 warn Error
                          ! spotify-premium.0 2018-05-05 18:10:25.414 warn at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
                          ! spotify-premium.0 2018-05-05 18:10:25.414 warn at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
                          ! spotify-premium.0 2018-05-05 18:10:25.414 warn at Decoder. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                          ! spotify-premium.0 2018-05-05 18:10:25.414 warn at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
                          ! spotify-premium.0 2018-05-05 18:10:25.414 warn at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
                          ! spotify-premium.0 2018-05-05 18:10:25.414 warn at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                          ! spotify-premium.0 2018-05-05 18:10:25.414 warn at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
                          ! spotify-premium.0 2018-05-05 18:10:25.414 warn at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
                          ! spotify-premium.0 2018-05-05 18:10:25.414 warn at Socket. (/opt/iobroker/node_modules/iobroker.spotify-premium/main.js:1162:21)
                          ! spotify-premium.0 2018-05-05 18:10:25.414 warn at sendRequest (/opt/iobroker/node_modules/iobroker.spotify-premium/main.js:158:21)
                          ! spotify-premium.0 2018-05-05 18:10:25.414 warn Error
                          ! spotify-premium.0 2018-05-05 18:10:25.413 warn HTTP Request Error not handled, please debug
                          Jemand eine Idee?
                            Nochmal zum Verständnis… wenn ich den Adapter von Twonky habe, benötige ich das Skript von Lucky nicht, oder? Ich habe anscheinend das Problem, was Lucky auf Seite zwei gelöst hat: ich kann kein Device auswählen, wenn die Wiedergabe nicht läuft. Ist natürlich doof, denn im Vis kann ich die Wiedergabe nicht starten, wenn kein Gerät ausgewählt ist - ein Teufelskreis 🙂
                            Oder muss ich im JavaScript-Adapter doch ein Skript erstellen?
                            • wendy2702
                              wendy2702 last edited by
                              Richtig!
                              Entweder Script oder Adapter. Beides zusammen ist nicht notwendig.
                                Ok, danke. Dann ist das wohl in Twonkys Adapter nicht implementiert…
                                @twonky: Kannst Du da was machen?
                                Mich würde auch noch interessieren, welches Widget ich für die Darstellung von Playlisten oder Sendern nehmen kann, was mir auch das Cover aus den Objekten zieht.
                                • wendy2702
                                  Ich habe ein kleines Blockly gemacht und mit einem Widget verknüpft.
                                  Mit dem Widget schalte ich das Device an und mit dem Blockly „drücke“ ich dann paar Sekunden später den „Use this for playback“ button.
                                    jankir last edited by
                                    @wendy2702:
                                    Mit dem Widget schalte ich das Device an und mit dem Blockly „drücke“ ich dann paar Sekunden später den „Use this for playback“ button. `
                                    So mache ich es auch, aber nach ein paar Minuten geht der State "musiccast.0.WX-030_0E417983.netusb.playback" auf Pause und lässt sich dann auch nicht in der Musiccast oder Spotify app wieder starten. Wenn man auf Play drückt fängt es eine Sekunde zu laufen an und geht dann wieder auf Pause.
                                    Per Knopfdruck auf "spotify-premium.0.Player.Play" geht es wieder.
                                    Hat jemand eine Idee woran das liegen kann?
                                      seppel786 last edited by
                                      ich bin neu hier bzw. auch relativ neu im Bereich ioBroker.
                                      Ich habe eine kleine Frage an Euch: Den Spotifyadapter konnte ich inioBroker ohne Probleme installieren und authorisieren.
                                      Wenn ich nun in den Objekten im Playerordner nun bei Play oder Pause den simulierten Button drücke wird auch eine Aktion ausgeführt.
                                      Füge ich nun in meine View einen einfach Statebutton hinzu und weise diesem bspweise den Wert "spotify-premium.0.Player.Pause" zu
                                      und führe die View und drücke den Button passiert irgendwie nichts.
                                      Das Log wirft folgende Meldung:
                                      spotify-premium.0	2018-05-12 18:27:52.972	info	starting. Version 0.1.3 in /opt/iobroker/node_modules/iobroker.spotify-premium, node: v6.14.2
                                      host.raspberrypi	2018-05-12 18:27:50.522	info	instance system.adapter.spotify-premium.0 started with pid 5619
                                      host.raspberrypi	2018-05-12 18:27:20.479	info	Restart adapter system.adapter.spotify-premium.0 because enabled
                                      host.raspberrypi	2018-05-12 18:27:20.479	error	instance system.adapter.spotify-premium.0 terminated with code 0 (OK)
                                      Caught	2018-05-12 18:27:20.478	error	by controller[0]: at Request.emit (events.js:188:7)
                                      Caught	2018-05-12 18:27:20.478	error	by controller[0]: at emitOne (events.js:96:13)
                                      Caught	2018-05-12 18:27:20.478	error	by controller[0]: at Request. (/opt/iobroker/node_modules/iobroker.spotify-premium/node_modules/request/request.js:1163:10)
                                      Caught	2018-05-12 18:27:20.478	error	by controller[0]: at Request.emit (events.js:191:7)
                                      Caught	2018-05-12 18:27:20.475	error	by controller[0]: at emitTwo (events.js:106:13)
                                      Caught	2018-05-12 18:27:20.475	error	by controller[0]: at Request.self.callback (/opt/iobroker/node_modules/iobroker.spotify-premium/node_modules/request/request.js:186:22)
                                      Caught	2018-05-12 18:27:20.475	error	by controller[0]: at Request._callback (/opt/iobroker/node_modules/iobroker.spotify-premium/main.js:172:25)
                                      Caught	2018-05-12 18:27:20.475	error	by controller[0]: at /opt/iobroker/node_modules/iobroker.spotify-premium/main.js:609:21
                                      Caught	2018-05-12 18:27:20.474	error	by controller[0]: at persistPlaylist (/opt/iobroker/node_modules/iobroker.spotify-premium/main.js:505:21)
                                      Caught	2018-05-12 18:27:20.474	error	by controller[0]: at Array.forEach (native)
                                      Caught	2018-05-12 18:27:20.473	error	by controller[0]: at /opt/iobroker/node_modules/iobroker.spotify-premium/main.js:588:32
                                      Caught	2018-05-12 18:27:20.464	error	by controller[0]: TypeError: Cannot read property 'url' of undefined
                                      spotify-premium.0	2018-05-12 18:27:20.413	info	terminating
                                      spotify-premium.0	2018-05-12 18:27:20.225	error	at Request.emit (events.js:188:7)
                                      spotify-premium.0	2018-05-12 18:27:20.225	error	at emitOne (events.js:96:13)
                                      spotify-premium.0	2018-05-12 18:27:20.225	error	at Request. (/opt/iobroker/node_modules/iobroker.spotify-premium/node_modules/request/request.js:1163:10)
                                      spotify-premium.0	2018-05-12 18:27:20.225	error	at Request.emit (events.js:191:7)
                                      spotify-premium.0	2018-05-12 18:27:20.225	error	at emitTwo (events.js:106:13)
                                      spotify-premium.0	2018-05-12 18:27:20.225	error	at Request.self.callback (/opt/iobroker/node_modules/iobroker.spotify-premium/node_modules/request/request.js:186:22)
                                      spotify-premium.0	2018-05-12 18:27:20.225	error	at Request._callback (/opt/iobroker/node_modules/iobroker.spotify-premium/main.js:172:25)
                                      spotify-premium.0	2018-05-12 18:27:20.225	error	at /opt/iobroker/node_modules/iobroker.spotify-premium/main.js:609:21
                                      spotify-premium.0	2018-05-12 18:27:20.225	error	at persistPlaylist (/opt/iobroker/node_modules/iobroker.spotify-premium/main.js:505:21)
                                      spotify-premium.0	2018-05-12 18:27:20.225	error	at Array.forEach (native)
                                      spotify-premium.0	2018-05-12 18:27:20.225	error	at /opt/iobroker/node_modules/iobroker.spotify-premium/main.js:588:32
                                      spotify-premium.0	2018-05-12 18:27:20.225	error	TypeError: Cannot read property 'url' of undefined
                                      spotify-premium.0	2018-05-12 18:27:20.215	error	uncaught exception: Cannot read property 'url' of undefined
                                      Edit:
                                      Nun habe ich über die VIS-Player Widget die ganze Sache zum Laufen zu bekommen. Hier nun diese Meldungen.
                                      Reaktion gab es leider keine 😞
                                      spotify-premium.0	2018-05-12 18:48:59.947	warn	at IncomingMessage.emit (events.js:185:7)
                                      spotify-premium.0	2018-05-12 18:48:59.947	warn	at emitNone (events.js:91:20)
                                      spotify-premium.0	2018-05-12 18:48:59.947	warn	at IncomingMessage.g (events.js:292:16)
                                      spotify-premium.0	2018-05-12 18:48:59.947	warn	at IncomingMessage. (/opt/iobroker/node_modules/iobroker.spotify-premium/node_modules/request/request.js:1085:12)
                                      spotify-premium.0	2018-05-12 18:48:59.947	warn	at Request.emit (events.js:188:7)
                                      spotify-premium.0	2018-05-12 18:48:59.947	warn	at emitOne (events.js:96:13)
                                      spotify-premium.0	2018-05-12 18:48:59.947	warn	at Request. (/opt/iobroker/node_modules/iobroker.spotify-premium/node_modules/request/request.js:1163:10)
                                      spotify-premium.0	2018-05-12 18:48:59.947	warn	at Request.emit (events.js:191:7)
                                      spotify-premium.0	2018-05-12 18:48:59.947	warn	at emitTwo (events.js:106:13)
                                      spotify-premium.0	2018-05-12 18:48:59.947	warn	at Request.self.callback (/opt/iobroker/node_modules/iobroker.spotify-premium/node_modules/request/request.js:186:22)
                                      spotify-premium.0	2018-05-12 18:48:59.947	warn	at Request._callback (/opt/iobroker/node_modules/iobroker.spotify-premium/main.js:258:42)
                                      spotify-premium.0	2018-05-12 18:48:59.947	warn	Error
                                      spotify-premium.0	2018-05-12 18:48:59.945	warn	at tryOnImmediate (timers.js:645:5)
                                      spotify-premium.0	2018-05-12 18:48:59.945	warn	at runCallback (timers.js:672:20)
                                      spotify-premium.0	2018-05-12 18:48:59.945	warn	at Immediate. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3194:38)
                                      spotify-premium.0	2018-05-12 18:48:59.945	warn	at Adapter.emit (events.js:191:7)
                                      spotify-premium.0	2018-05-12 18:48:59.945	warn	at emitTwo (events.js:106:13)
                                      spotify-premium.0	2018-05-12 18:48:59.945	warn	at Adapter. (/opt/iobroker/node_modules/iobroker.spotify-premium/main.js:1318:14)
                                      spotify-premium.0	2018-05-12 18:48:59.945	warn	at Array.forEach (native)
                                      spotify-premium.0	2018-05-12 18:48:59.945	warn	at /opt/iobroker/node_modules/iobroker.spotify-premium/main.js:1322:19
                                      spotify-premium.0	2018-05-12 18:48:59.945	warn	at Object.func (/opt/iobroker/node_modules/iobroker.spotify-premium/main.js:1183:9)
                                      spotify-premium.0	2018-05-12 18:48:59.945	warn	at sendRequest (/opt/iobroker/node_modules/iobroker.spotify-premium/main.js:158:21)
                                      spotify-premium.0	2018-05-12 18:48:59.945	warn	Error
                                      spotify-premium.0	2018-05-12 18:48:59.945	warn	HTTP Request Error not handled, please debug
                                      spotify-premium.0	2018-05-12 18:48:58.940	warn	at IncomingMessage.emit (events.js:185:7)
                                      spotify-premium.0	2018-05-12 18:48:58.940	warn	at emitNone (events.js:91:20)
                                      spotify-premium.0	2018-05-12 18:48:58.940	warn	at IncomingMessage.g (events.js:292:16)
                                      spotify-premium.0	2018-05-12 18:48:58.940	warn	at IncomingMessage. (/opt/iobroker/node_modules/iobroker.spotify-premium/node_modules/request/request.js:1085:12)
                                      spotify-premium.0	2018-05-12 18:48:58.940	warn	at Request.emit (events.js:188:7)
                                      spotify-premium.0	2018-05-12 18:48:58.940	warn	at emitOne (events.js:96:13)
                                      spotify-premium.0	2018-05-12 18:48:58.940	warn	at Request. (/opt/iobroker/node_modules/iobroker.spotify-premium/node_modules/request/request.js:1163:10)
                                      spotify-premium.0	2018-05-12 18:48:58.940	warn	at Request.emit (events.js:191:7)
                                      spotify-premium.0	2018-05-12 18:48:58.940	warn	at emitTwo (events.js:106:13)
                                      spotify-premium.0	2018-05-12 18:48:58.940	warn	at Request.self.callback (/opt/iobroker/node_modules/iobroker.spotify-premium/node_modules/request/request.js:186:22)
                                      spotify-premium.0	2018-05-12 18:48:58.940	warn	at Request._callback (/opt/iobroker/node_modules/iobroker.spotify-premium/main.js:258:42)
                                      spotify-premium.0	2018-05-12 18:48:58.940	warn	Error
                                      spotify-premium.0	2018-05-12 18:48:58.938	warn	at tryOnImmediate (timers.js:645:5)
                                      spotify-premium.0	2018-05-12 18:48:58.938	warn	at runCallback (timers.js:672:20)
                                      spotify-premium.0	2018-05-12 18:48:58.938	warn	at Immediate. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3194:38)
                                      spotify-premium.0	2018-05-12 18:48:58.938	warn	at Adapter.emit (events.js:191:7)
                                      spotify-premium.0	2018-05-12 18:48:58.938	warn	at emitTwo (events.js:106:13)
                                      spotify-premium.0	2018-05-12 18:48:58.938	warn	at Adapter. (/opt/iobroker/node_modules/iobroker.spotify-premium/main.js:1318:14)
                                      spotify-premium.0	2018-05-12 18:48:58.938	warn	at Array.forEach (native)
                                      spotify-premium.0	2018-05-12 18:48:58.938	warn	at /opt/iobroker/node_modules/iobroker.spotify-premium/main.js:1322:19
                                      spotify-premium.0	2018-05-12 18:48:58.938	warn	at Object.func (/opt/iobroker/node_modules/iobroker.spotify-premium/main.js:1183:9)
                                      spotify-premium.0	2018-05-12 18:48:58.938	warn	at sendRequest (/opt/iobroker/node_modules/iobroker.spotify-premium/main.js:158:21)
                                      spotify-premium.0	2018-05-12 18:48:58.938	warn	Error
                                      spotify-premium.0	2018-05-12 18:48:58.938	warn	HTTP Request Error not handled, please debug
                                      spotify-premium.0	2018-05-12 18:48:57.810	warn	at IncomingMessage.emit (events.js:185:7)
                                      spotify-premium.0	2018-05-12 18:48:57.810	warn	at emitNone (events.js:91:20)
                                      spotify-premium.0	2018-05-12 18:48:57.810	warn	at IncomingMessage.g (events.js:292:16)
                                      spotify-premium.0	2018-05-12 18:48:57.810	warn	at IncomingMessage. (/opt/iobroker/node_modules/iobroker.spotify-premium/node_modules/request/request.js:1085:12)
                                      spotify-premium.0	2018-05-12 18:48:57.810	warn	at Request.emit (events.js:188:7)
                                      spotify-premium.0	2018-05-12 18:48:57.810	warn	at emitOne (events.js:96:13)
                                      spotify-premium.0	2018-05-12 18:48:57.810	warn	at Request. (/opt/iobroker/node_modules/iobroker.spotify-premium/node_modules/request/request.js:1163:10)
                                      spotify-premium.0	2018-05-12 18:48:57.810	warn	at Request.emit (events.js:191:7)
                                      spotify-premium.0	2018-05-12 18:48:57.810	warn	at emitTwo (events.js:106:13)
                                      spotify-premium.0	2018-05-12 18:48:57.810	warn	at Request.self.callback (/opt/iobroker/node_modules/iobroker.spotify-premium/node_modules/request/request.js:186:22)
                                      spotify-premium.0	2018-05-12 18:48:57.810	warn	at Request._callback (/opt/iobroker/node_modules/iobroker.spotify-premium/main.js:258:42)
                                      spotify-premium.0	2018-05-12 18:48:57.810	warn	Error
                                      spotify-premium.0	2018-05-12 18:48:57.808	warn	at tryOnImmediate (timers.js:645:5)
                                      spotify-premium.0	2018-05-12 18:48:57.808	warn	at runCallback (timers.js:672:20)
                                      spotify-premium.0	2018-05-12 18:48:57.808	warn	at Immediate. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3194:38)
                                      spotify-premium.0	2018-05-12 18:48:57.808	warn	at Adapter.emit (events.js:191:7)
                                      spotify-premium.0	2018-05-12 18:48:57.808	warn	at emitTwo (events.js:106:13)
                                      spotify-premium.0	2018-05-12 18:48:57.808	warn	at Adapter. (/opt/iobroker/node_modules/iobroker.spotify-premium/main.js:1318:14)
                                      spotify-premium.0	2018-05-12 18:48:57.808	warn	at Array.forEach (native)
                                      spotify-premium.0	2018-05-12 18:48:57.808	warn	at /opt/iobroker/node_modules/iobroker.spotify-premium/main.js:1322:19
                                      spotify-premium.0	2018-05-12 18:48:57.808	warn	at Object.func (/opt/iobroker/node_modules/iobroker.spotify-premium/main.js:1183:9)
                                      spotify-premium.0	2018-05-12 18:48:57.808	warn	at sendRequest (/opt/iobroker/node_modules/iobroker.spotify-premium/main.js:158:21)
                                      spotify-premium.0	2018-05-12 18:48:57.808	warn	Error
                                      spotify-premium.0	2018-05-12 18:48:57.807	warn	HTTP Request Error not handled, please debug
                                      spotify-premium.0	2018-05-12 18:48:40.360	warn	at IncomingMessage.emit (events.js:185:7)
                                      spotify-premium.0	2018-05-12 18:48:40.360	warn	at emitNone (events.js:91:20)
                                      spotify-premium.0	2018-05-12 18:48:40.360	warn	at IncomingMessage.g (events.js:292:16)
                                      spotify-premium.0	2018-05-12 18:48:40.360	warn	at IncomingMessage. (/opt/iobroker/node_modules/iobroker.spotify-premium/node_modules/request/request.js:1085:12)
                                      spotify-premium.0	2018-05-12 18:48:40.360	warn	at Request.emit (events.js:188:7)
                                      spotify-premium.0	2018-05-12 18:48:40.360	warn	at emitOne (events.js:96:13)
                                      spotify-premium.0	2018-05-12 18:48:40.360	warn	at Request. (/opt/iobroker/node_modules/iobroker.spotify-premium/node_modules/request/request.js:1163:10)
                                      spotify-premium.0	2018-05-12 18:48:40.360	warn	at Request.emit (events.js:191:7)
                                      spotify-premium.0	2018-05-12 18:48:40.360	warn	at emitTwo (events.js:106:13)
                                      spotify-premium.0	2018-05-12 18:48:40.360	warn	at Request.self.callback (/opt/iobroker/node_modules/iobroker.spotify-premium/node_modules/request/request.js:186:22)
                                      spotify-premium.0	2018-05-12 18:48:40.360	warn	at Request._callback (/opt/iobroker/node_modules/iobroker.spotify-premium/main.js:258:42)
                                      spotify-premium.0	2018-05-12 18:48:40.360	warn	Error
                                      spotify-premium.0	2018-05-12 18:48:40.357	warn	at tryOnImmediate (timers.js:645:5)
                                      spotify-premium.0	2018-05-12 18:48:40.357	warn	at runCallback (timers.js:672:20)
                                      spotify-premium.0	2018-05-12 18:48:40.357	warn	at Immediate. (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3194:38)
                                      spotify-premium.0	2018-05-12 18:48:40.357	warn	at Adapter.emit (events.js:191:7)
                                      spotify-premium.0	2018-05-12 18:48:40.357	warn	at emitTwo (events.js:106:13)
                                      spotify-premium.0	2018-05-12 18:48:40.357	warn	at Adapter. (/opt/iobroker/node_modules/iobroker.spotify-premium/main.js:1318:14)
                                      spotify-premium.0	2018-05-12 18:48:40.357	warn	at Array.forEach (native)
                                      spotify-premium.0	2018-05-12 18:48:40.357	warn	at /opt/iobroker/node_modules/iobroker.spotify-premium/main.js:1322:19
                                      spotify-premium.0	2018-05-12 18:48:40.357	warn	at Object.func (/opt/iobroker/node_modules/iobroker.spotify-premium/main.js:1183:9)
                                      spotify-premium.0	2018-05-12 18:48:40.357	warn	at sendRequest (/opt/iobroker/node_modules/iobroker.spotify-premium/main.js:158:21)
                                      spotify-premium.0	2018-05-12 18:48:40.357	warn	Error
                                      spotify-premium.0	2018-05-12 18:48:40.347	warn	HTTP Request Error not handled, please debug
                                      Kann mir da bitte jemand unter die Arme greifen?
                                      Danke für Eure Hilfe,
                                      Daniel aka Seppel
                                      Geändert: Code in Code-Tags; Homoran (Admin)
                                      • twonky
                                        Ich habe jetzt eine ganze Weile an Version https://github.com/twonky4/ioBroker.spotify-premium gearbeitet.
                                        Der große Versionssprung, weil ich die States umbenannt habe. Sie folgen nun einem einheitlichem Namensschema das mit den Standard ioBroker States übereinstimmt. Alles States haben nun eine Beschreibung und es sind auch einige neue hinzugekommen. Es müssen also die alten Instanzen gelöscht und neu angelegt werden.
                                        Was mir für eine Veröffentlichung nur noch fehlt sind ein paar VIS Beispiele.
                                        Nun happy State umbennen 😉 (Ja, ich weiß das ist nervig, aber ich wollte das machen bevor der Adapter in das ioBroker repo aufgenommen wird)
                                        • Mic
                                          Vielen Dank twonky, funktioniert sehr gut
                                            mikiline last edited by
                                            ich hab da wieder probleme die app zu autorisieren….
                                            Browser bleibt beim Login stehen und wird nicht weitergeleitet......Es wird aber trotzdem bei spotify eingeloggt.
                                            Beim 2. Aufruf kommt dann die redirect uri....
                                            Weiss jemand weiter?
                                            1.2k
                                            javascript
                                            95
                                            745
                                            262696
