    4. [Problem] iobroker nicht mehr erreichbar
    • Blackmike
      Blackmike last edited by
      ok, nu bin ich auch wieder am rechner.
      das ist der entscheidende Part meines logs. wenn ichs richtig interpretiere, startet da der jscontroller und der admin neu ?
      ! 2018-05-03 04:30:03.576 - [32minfo[39m: weatherunderground.0 starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v6.14.1
      ! 2018-05-03 04:30:08.776 - [32minfo[39m: host.OPI instance system.adapter.weatherunderground.0 terminated with code 0 (OK)
      ! 2018-05-03 04:36:45.913 - [32minfo[39m: javascript.0 script.js.Licht.Licht_Haustür_V2: 11
      ! 2018-05-03 04:36:45.917 - [32minfo[39m: javascript.0 script.js.Licht.Licht_Haustür_V2: verzögert an: 120000
      ! 2018-05-03 04:40:00.196 - [32minfo[39m: host.OPI instance system.adapter.weatherunderground.0 started with pid 11590
      ! 2018-05-03 04:40:03.556 - [32minfo[39m: weatherunderground.0 starting. Version 1.1.2 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v6.14.1
      ! 2018-05-03 04:40:16.323 - [32minfo[39m: host.OPI instance system.adapter.weatherunderground.0 terminated with code 0 (OK)
      ! 2018-05-03 04:17:12.656 - [32minfo[39m: host.OPI iobroker.js-controller version 1.4.2 js-controller starting
      ! 2018-05-03 04:17:12.676 - [32minfo[39m: host.OPI Copyright © 2014-2018 bluefox, 2014 hobbyquaker
      ! 2018-05-03 04:17:12.679 - [32minfo[39m: host.OPI hostname: OPI, node: v6.14.1
      ! 2018-05-03 04:17:12.682 - [32minfo[39m: host.OPI ip addresses: 192.168.2.5 2003:c9:1f28:f200:81:eeff:fec5:f86 fe80::81:eeff:fec5:f86
      ! 2018-05-03 04:17:13.096 - [32minfo[39m: host.OPI inMem-states listening on port 9000
      ! 2018-05-03 04:17:13.974 - [32minfo[39m: host.OPI inMem-objects listening on port 9001
      ! 2018-05-03 04:17:14.014 - [32minfo[39m: host.OPI InMemoryDB connected
      ! 2018-05-03 04:17:14.089 - [32minfo[39m: host.OPI 30 instances found
      ! 2018-05-03 04:17:14.204 - [32minfo[39m: host.OPI starting 18 instances
      ! 2018-05-03 04:17:14.357 - [32minfo[39m: host.OPI instance system.adapter.admin.0 started with pid 1026
      ! 2018-05-03 06:23:01.113 - [32minfo[39m: host.OPI instance system.adapter.web.0 started with pid 1051[/spoiler]
      syslog beginnt erst ab dem neustart
      in dieser Uhrzeit warf dann auch die CCU mit errors, als die RPC Adapter im IoBroker ihren Dienst einstellten
      top in laufen System ist avolut harmlos, speicher sollte satt und genug sein und die CPU dümpelt bei 480MHz rum (auf einem oPI+2e)
      ! top - 19:25:34 up 13:02, 1 user, load average: 0,25, 0,17, 0,17
      ! Tasks: 120 total, 1 running, 75 sleeping, 0 stopped, 0 zombie
      ! %Cpu(s): 2,4 us, 0,7 sy, 0,0 ni, 96,9 id, 0,0 wa, 0,0 hi, 0,0 si, 0,0 st
      ! KiB Mem : 2062388 total, 1263028 free, 569196 used, 230164 buff/cache
      ! KiB Swap: 131068 total, 131068 free, 0 used. 1424384 avail Mem
      ! PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
      ! 1014 root 20 0 189820 91448 17380 S 4,9 4,4 63:03.59 iobroker.js-con
      ! 22225 root 20 0 8832 3068 2624 R 2,3 0,1 0:00.71 top
      ! 1383 root 20 0 125856 36712 17136 S 2,0 1,8 21:16.88 io.history.0
      ! 1100 root 20 0 124624 32956 17024 S 1,3 1,6 7:13.12 io.simple-api.0
      ! 781 root 20 0 0 0 0 D 0,7 0,0 1:07.93 RTW_CMD_THREAD
      ! 1108 root 20 0 180084 80632 17856 S 0,7 3,9 16:12.52 io.javascript.0
      ! 17799 root 20 0 0 0 0 I 0,7 0,0 0:39.82 kworker/1:0
      ! 493 message+ 20 0 5316 2780 2408 S 0,3 0,1 0:12.43 dbus-daemon
      ! 503 root 20 0 88608 12904 11072 S 0,3 0,6 0:38.31 NetworkManager
      ! 1026 root 20 0 154936 53656 17136 S 0,3 2,6 1:23.93 io.admin.0
      ! 1236 root 20 0 128128 35984 16944 S 0,3 1,7 1:05.16 io.lightify.0
      ! 1318 root 20 0 139756 42328 17076 S 0,3 2,1 4:49.50 io.hm-rega.1
      ! 1348 root 20 0 126168 37472 17068 S 0,3 1,8 1:45.46 io.hm-rpc.3
      ! 21775 root 20 0 0 0 0 I 0,3 0,0 0:01.40 kworker/0:0
      ! 22091 root 20 0 0 0 0 I 0,3 0,0 0:00.18 kworker/3:1
      ! 1 root 20 0 25840 5444 3864 S 0,0 0,3 0:07.08 systemd
      Black
        AingTii last edited by
        na bei mir vermute ich mal der Speicherräuber der unifi Controller mit 163644 KB immerhin 17,%
        Dann muss ich den wohl woanders unterbringen entweder auf der synology oder auf nen anderen Pi.
        • wendy2702
          wendy2702 last edited by
          @Blackmike:
          syslog beginnt erst ab dem neustart `
          Meinst du das iobroker log?
          Du musst mal das Linux SYSLOG checken.
          • Blackmike
            so, ichhatte das heute früh nochmal…
            da sah das ganze dann so aus unter top
            ! top - 06:42:05 up 9 min, 1 user, load average: 5,32, 4,46, 2,32
            ! Tasks: 116 total, 4 running, 71 sleeping, 0 stopped, 0 zombie
            ! %Cpu(s): 57,4 us, 2,0 sy, 0,0 ni, 40,5 id, 0,0 wa, 0,0 hi, 0,1 si, 0,0 st
            ! KiB Mem : 2062388 total, 1264036 free, 584876 used, 213476 buff/cache
            ! KiB Swap: 131068 total, 131068 free, 0 used. 1411036 avail Mem
            ! 1857 root 20 0 110632 55476 16160 R 100,3 2,7 0:14.94 node
            ! 911 root 20 0 271928 187912 17324 R 99,4 9,1 7:41.35 iobroker.js-con
            ! 1771 root 20 0 122372 30680 17096 S 7,7 1,5 0:16.47 io.js2fs.0
            ! 1735 root 20 0 135016 49040 16964 S 6,1 2,4 0:42.66 io.hm-rega.1
            ! 1753 root 20 0 116524 29804 16916 S 5,1 1,4 0:15.54 io.web.0
            ! 1741 root 20 0 134584 40732 17084 S 4,8 2,0 0:22.53 io.admin.0
            ! 1819 root 20 0 8664 2920 2468 R 3,5 0,1 0:02.67 top
            ! 1759 root 20 0 115644 28044 17060 S 2,9 1,4 0:13.11 io.simple-api.0
            ! 1538 root 20 0 161344 63316 17140 S 1,9 3,1 0:32.73 io.javascript.2
            ! 1617 root 20 0 123288 35272 16996 R 1,3 1,7 0:15.39 io.lightify.0
            ! 1765 root 20 0 117316 29660 17120 S 1,3 1,4 0:14.97 io.hm-rpc.3
              apollon77 last edited by
              Hm … ein „Node“ Prozess mit 100% cpu und einmal js-Controller mit 99% ...
              Bei sowas nochmal mach mal ein „ps auxww|grep node“ weil die Frage ists was das für ein Prozess ist.
              Ansonsten load 5 heist erstmal nur das alles langsamer ist 😉
                Hallo Zusammen,
                was mich etwas stutzig macht, ich denke mal bei mir war die Ursache, dass der Speicher des RasPi nicht
                reichte, somit habe ich jetzt extra den unifi Controller (160MB Speichernutzung) vom RasPi verband.
                Fazit: Gestern satte 20% round about 200MB anstatt vorher um die 40MB frei.
                Heute schaue ich rein, überhaupt nichts gemacht und es sind nur noch 10% also 100MB frei.
                Wie kann dass denn sein?
                Da hat die Aktion ja irgendwie nicht viel gebracht 😢
                Gruß Jens
                  http://www.linuxatemyram.com
                  Entscheidend ist der verfügbare Speicher (available) 144_screenshot_20180509-182222.jpg
                  Hier siehst du mal wie krass der Unterschied sein kann
                  Gruß Rainer
                  • wendy2702
                    @Homoran:
                    Gruß Rainer `
                    Hi Rainer,
                    der link geht nicht bzw. so wie es eingefügt ist geht nicht.
                    Mirko
                      Korrigiert!
                      Rainer
                        ok, also sollte ich davon ausgehen, dass vorher mit dem unifi der Speicher wirklich zu knapp
                        war und daher iobroker die Instanzen terminiert hat.
                        Nun aber lediglich Linux von den 200MB freien Speicher die hälfte gemobst hat aber
                        auch ruck zuck zurückgeben kann, sollte es kritisch werden…
                        Also beobachten.
                        Ahja, ist ja ne top Übersicht, sind dass Deinen ganzen Pi's?
                        Gruß Jens
                          @AingTii:
                          sind dass Deinen ganzen Pi's? `
                          Nicht alle 😉
                          Der view ist noch größer und alle SBCs sind noch nicht drin
                          Gruß Rainer
                            easymeter last edited by
                            ich habe auch das Problem, dass ich iobroker nicht mehr erreiche, weder den Admin noch die vis.
                            Die erste Hilfe Sachen (http://www.iobroker.net/docu/?page_id=3928&lang=de) hatte ich soweit probiert, ohne Erfolg.
                            Im Putty bekomme ich immer "BUS Verbindungsfehler"
                            Hat hier jemand Erfahrungen bzw. Tipps zur Abhilfe?
                            Markus
                            • wendy2702
                              Wobei kommt der Fehler?
                              Screenshot oder Logfile bitte Posten.
                                auf der Console, beispielweise beim Versuch den Admin von Hand zu starten kommt diese Melung "Bus verbindungsfehler" auf dem Raspi
                                Das ganze ist irgendwie ziemlich schräg. Iobroker lief durchgehend stabil bis auf bisher zwei Ausfälle, bedingt durch Speichermangel, weil Historywerte bzw. Logs den Platz belegten. Nachdem ich diese vom Raspi verschoben und gelöscht hatte lief aber alles wieder problemlos.
                                Am letzten Wochenede blieb das ganze dann aber wieder stehen, obwohl eigendlich noch genügend Speicherplatz da war….
                                Die Logs müsste ich nachher mal heraussuchen, bin gerade unterwegs
                                  Guten morgen,
                                  eine verrückte Woche geht zu Ende und ich finde jetzt endlich mal wieder Zeit mich mit meinem Problem zu beschäftigen. Anbei mal ein detailierteres Fehlerbild.
                                  Hier das Aussehen auf unsren Frontend, ein TAB im HWR:
                                  Den Raspi kann ich auf der Fritzbox einwandfrei sehen und auch mit SSH erreichen. IP passt, hatte ich aber auch nichts dran geändert….
                                  Wenn ich jetzt den Ablauf aus der "Ersten Hilfe" im iobroker net durchführe klemmt es schon bei der Kontrolle ob der JS-controler läuft.
                                  Bei Versuch iobroker von Hand zu starten kommt dann schon dieser ominöse BUS Fehler:
                                  Das hier sind die letzten Einträge im LOG. Irgendwie aber ohne Fehlermeldungen ???
                                  Vielleicht hat von Euch jemand einen guten Hinweis, wie ich hier weiterkommen könnte.
                                  Gruß Markus
                                  • wendy2702
                                    Versuch mal````
                                    sudo iobroker start
                                      Leider nur der Ausschrieb "Bus Error"
                                      • Dutchman
                                        @easymeter:
                                        Leider nur der Ausschrieb "Bus Error" `
                                        Screenshot bitte
                                            Ein kleines update,
                                            mein iobroker läuft wieder !!!! 😄 😄
                                            Ich habe den Raspi geupdatetet und upgegradet, rebootet und den cache geleert.
                                            (Beschreibung aus dem elektronik kompendium : https://www.elektronik-kompendium.de/si … 002041.htm)
                                            und.... nach dem dritten reboot lief der admin wieder, auch aus dem autostart....
                                            Euch Allen vielen Dank für die Hilfe!
                                            8366
