    4. Einfach mal zeigen will….. :-) - Teil 2
      fibernet last edited by Jey Cee
      Kann ich tun 😄
      Das common Java Script:
      createState('WeatherSymbol0', '');
      createState('WindSymbol0', '');
      createState('WeatherSymbol1', '');
      createState('WindSymbol1', '');
      createState('WeatherSymbol2', '');
      createState('WindSymbol2', '');
      createState('WeatherSymbol3', '');
      createState('WindSymbol3', '');
      createState('WeatherSymbol4', '');
      createState('WindSymbol4', '');
      createState('WeatherSymbol5', '');
      createState('WindSymbol5', '');
      createState('WeatherSymbol6', '');
      createState('WindSymbol6', '');
      createState('WeatherSymbol7', '');
      createState('WindSymbol7', '');
      on("daswetter.0.NextDaysDetailed.0d.SymbolID", function(obj) {
      var symbol = parseInt(obj.newState.val, 10);
      var temp = 'http://127.0.0.1:8082/daswetter/icons/wetter/' + symbol + 'f.png';
      log (temp);
      setState('WeatherSymbol0', temp );
      on("daswetter.0.NextDaysDetailed.0d.WindSymbolB", function(obj) {
      var windsymbol = parseInt(obj.newState.val, 10);
      var temp = 'http://127.0.0.1:8082/daswetter/icons/viento-wind/galeria 2 - Beaufort/' + windsymbol + '.png';
      log (temp);
      setState('WindSymbol0', temp);
      on("daswetter.0.NextDaysDetailed.1d.SymbolID", function(obj) {
      log (temp);
      setState('WeatherSymbol1', temp );
      on("daswetter.0.NextDaysDetailed.1d.WindSymbolB", function(obj) {
      log (temp);
      setState('WindSymbol1', temp);
      on("daswetter.0.NextDaysDetailed.2d.SymbolID", function(obj) {
      log (temp);
      setState('WeatherSymbol2', temp );
      on("daswetter.0.NextDaysDetailed.2d.WindSymbolB", function(obj) {
      var temp = 'http://127.0.0.1:8082/daswetter/icons/viento-wind/galeria 2 - Beaufort//' + windsymbol + '.png';
      log (temp);
      setState('WindSymbol2', temp);
      on("daswetter.0.NextDaysDetailed.3d.SymbolID", function(obj) {
      log (temp);
      setState('WeatherSymbol3', temp );
      on("daswetter.0.NextDaysDetailed.3d.WindSymbolB", function(obj) {
      log (temp);
      setState('WindSymbol3', temp);
      on("daswetter.0.NextDaysDetailed.4d.SymbolID", function(obj) {
      log (temp);
      setState('WeatherSymbol4', temp );
      on("daswetter.0.NextDaysDetailed.4d.WindSymbolB", function(obj) {
      log (temp);
      setState('WindSymbol4', temp);
      on("daswetter.0.NextDaysDetailed.5d.SymbolID", function(obj) {
      log (temp);
      setState('WeatherSymbol5', temp );
      on("daswetter.0.NextDaysDetailed.5d.WindSymbolB", function(obj) {
      log (temp);
      setState('WindSymbol5', temp);
      on("daswetter.0.NextDaysDetailed.6d.SymbolID", function(obj) {
      log (temp);
      setState('WeatherSymbol6', temp );
      on("daswetter.0.NextDaysDetailed.6d.WindSymbolB", function(obj) {
      log (temp);
      setState('WindSymbol6', temp);
      on("daswetter.0.NextDaysDetailed.7d.SymbolID", function(obj) {
      log (temp);
      setState('WeatherSymbol7', temp );
      on("daswetter.0.NextDaysDetailed.7d.WindSymbolB", function(obj) {
      log (temp);
      setState('WindSymbol7', temp);
      Das Widget
      6912_wetterwidget.txt
      Und Die Grafiken
      6912_weather.rar
      Geändert :oops: waren die verkehrten Icons…..bitte nochmals runter laden sonst passt die Zuordnung nachher nicht mehr
      Ich hoffe gehilft zu haben
      @spoerl.torsten:
      Hallo fibernet,
      > Soooooo, das finale Design steht und ich habe jetzt erstmal die Tools/Wetterseite vervollständigt. Die Buttons sind ausschließlich Metro Tiles, mit CSS formatiert, die Streifen im Hauptmenü und die Trennstreifen sind programmierte SVG Grafiken.
      Tolle Wetterview. Ich hätte Interesse an der 5 Tagesvorschau würdest du das Widget inklusive den Icons zur Verfügung stellen?
      Wäre echt klasse.
      LG Torsten `
      1 Reply Last reply Reply Quote 4
        Conquest last edited by
        Danke Fibernet hat super funktioniert.
        LG Torsten
          Dra_gun last edited by Jey Cee
          Hammer Wetterview Fibernet 😮 . Auch von mir Danke dafür :mrgreen:
          Hab dein Wetterwidget etwas erweitert. Wenn man auf Detail drückt öffnet sich eine neue View mit der Tagesansicht.
          Anbei noch der Rest von meinen Views die mit viel Copy Paste aus dem Forum hier entstanden sind 😄 😄 😄
          5767_screenshot_20180513-053826.png 5767_screenshot_20180513-053724.png 5767_screenshot_20180513-053844.png 5767_screenshot_20180513-053818.png
          LG Dragan
            andyb last edited by
            @Dra_gun:
            LG Dragan `
            Würeest du das Wetterwidget und die Detailview bereitstellen?
              @andyb:
              @Dra_gun:
              LG Dragan `
              Würeest du das Wetterwidget und die Detailview bereitstellen? `
              na klar 😄
              hier das Widget
              5767_wetterwidget.txt
              und hier das Javascript für die einzelnen Tage
              skript.txt
              und die Detailview…
              5767_detailview.txt
              • 2
                2hot4you last edited by Jey Cee
                Hallo Dra_gun,
                welche Eintrag hast Du im Adapter vorgenommen mit welchen API Pfad ?
                  @2hot4you:
                  Hallo Dra_gun,
                  welche Eintrag hast Du im Adapter vorgenommen mit welchen API Pfad ? `
                  Hey,
                  Beim dasWetter Adapter die 5 Tages URL und beim API den Pfad 2: XML-Datei mit 5-Tage-Wettervorhersage und detaillierte Informationen für alle 3 Stunden
                  Ihr braucht noch die Grafiken und das common Java Script von Fibernet :mrgreen:
                  • wendy2702
                    wendy2702 last edited by Jey Cee
                    @2hot4you:
                    Hallo Dra_gun,
                    Gibt ein extra Thread zum „Das Wetter“ Adapter.
                    viewtopic.php?f=20&t=5912&hilit=Daswetter
                    Wegen Konfiguration bitte da schauen/fragen oder neues Thema aufmachen. Hier geht es ja hauptsächlich ums „Zeigen“
                      Damich last edited by
                      @Dutchman:
                      so jetzt ich auch mal, nich die schönste Grafik und Aufbau aber technische Wiedergabe einer sonnen anlage (Wasser und Strom) `
                      Hallo Dutchman,
                      deine Diagramme sehen echt gut aus. Wie hast du die erstellt und würdest du eine Vorlage posten ?
                      Damich
                        sveni_lee last edited by
                        @Dra_gun:
                        @andyb:
                        @Dra_gun:
                        LG Dragan `
                        na klar 😄
                        hier das Widget
                        WetterWidget.txt
                        ! createState('WeatherSymbol10', '');
                        ! createState('WeatherSymbol11', '');
                        ! createState('WeatherSymbol12', '');
                        ! createState('WeatherSymbol13', '');
                        ! createState('WeatherSymbol14', '');
                        ! createState('WeatherSymbol15', '');
                        ! createState('WeatherSymbol16', '');
                        ! createState('WeatherSymbol17', '');
                        ! createState('WeatherSymbol20', '');
                        ! createState('WeatherSymbol21', '');
                        ! createState('WeatherSymbol22', '');
                        ! createState('WeatherSymbol23', '');
                        ! createState('WeatherSymbol24', '');
                        ! createState('WeatherSymbol25', '');
                        ! createState('WeatherSymbol26', '');
                        ! createState('WeatherSymbol27', '');
                        ! createState('WeatherSymbol30', '');
                        ! createState('WeatherSymbol31', '');
                        ! createState('WeatherSymbol32', '');
                        ! createState('WeatherSymbol33', '');
                        ! createState('WeatherSymbol34', '');
                        ! createState('WeatherSymbol35', '');
                        ! createState('WeatherSymbol36', '');
                        ! createState('WeatherSymbol37', '');
                        ! createState('WeatherSymbol40', '');
                        ! createState('WeatherSymbol41', '');
                        ! createState('WeatherSymbol42', '');
                        ! createState('WeatherSymbol43', '');
                        ! createState('WeatherSymbol44', '');
                        ! createState('WeatherSymbol45', '');
                        ! createState('WeatherSymbol46', '');
                        ! createState('WeatherSymbol47', '');
                        ! createState('WeatherSymbol50', '');
                        ! createState('WeatherSymbol51', '');
                        ! createState('WeatherSymbol52', '');
                        ! createState('WeatherSymbol53', '');
                        ! createState('WeatherSymbol54', '');
                        ! createState('WeatherSymbol55', '');
                        ! createState('WeatherSymbol56', '');
                        ! createState('WeatherSymbol57', '');
                        ! on("daswetter.0.NextDaysDetailed.0d.0h.SymbolID", function(obj) {
                        ! var symbol = parseInt(obj.newState.val, 10);
                        ! var temp = 'http://192.168.2.111:8082/daswetter/icons/wetter/' + symbol + 'f.png';
                        ! log (temp);
                        ! setState('WeatherSymbol10', temp );
                        ! on("daswetter.0.NextDaysDetailed.0d.1h.SymbolID", function(obj) {
                        ! log (temp);
                        ! setState('WeatherSymbol11', temp );
                        ! on("daswetter.0.NextDaysDetailed.0d.2h.SymbolID", function(obj) {
                        ! log (temp);
                        ! setState('WeatherSymbol12', temp );
                        ! on("daswetter.0.NextDaysDetailed.0d.3h.SymbolID", function(obj) {
                        ! log (temp);
                        ! setState('WeatherSymbol13', temp );
                        ! on("daswetter.0.NextDaysDetailed.0d.4h.SymbolID", function(obj) {
                        ! log (temp);
                        ! setState('WeatherSymbol14', temp );
                        ! on("daswetter.0.NextDaysDetailed.0d.5h.SymbolID", function(obj) {
                        ! log (temp);
                        ! setState('WeatherSymbol15', temp );
                        ! on("daswetter.0.NextDaysDetailed.0d.6h.SymbolID", function(obj) {
                        ! log (temp);
                        ! setState('WeatherSymbol16', temp );
                        ! on("daswetter.0.NextDaysDetailed.0d.7h.SymbolID", function(obj) {
                        ! log (temp);
                        ! setState('WeatherSymbol17', temp );
                        ! on("daswetter.0.NextDaysDetailed.1d.0h.SymbolID", function(obj) {
                        ! log (temp);
                        ! setState('WeatherSymbol20', temp );
                        ! on("daswetter.0.NextDaysDetailed.1d.1h.SymbolID", function(obj) {
                        ! log (temp);
                        ! setState('WeatherSymbol21', temp );
                        ! on("daswetter.0.NextDaysDetailed.1d.2h.SymbolID", function(obj) {
                        ! log (temp);
                        ! setState('WeatherSymbol22', temp );
                        ! on("daswetter.0.NextDaysDetailed.1d.3h.SymbolID", function(obj) {
                        ! log (temp);
                        ! setState('WeatherSymbol23', temp );
                        ! on("daswetter.0.NextDaysDetailed.1d.4h.SymbolID", function(obj) {
                        ! log (temp);
                        ! setState('WeatherSymbol24', temp );
                        ! on("daswetter.0.NextDaysDetailed.1d.5h.SymbolID", function(obj) {
                        ! log (temp);
                        ! setState('WeatherSymbol25', temp );
                        ! on("daswetter.0.NextDaysDetailed.1d.6h.SymbolID", function(obj) {
                        ! log (temp);
                        ! setState('WeatherSymbol26', temp );
                        ! on("daswetter.0.NextDaysDetailed.1d.7h.SymbolID", function(obj) {
                        ! log (temp);
                        ! setState('WeatherSymbol27', temp );
                        ! on("daswetter.0.NextDaysDetailed.2d.0h.SymbolID", function(obj) {
                        ! log (temp);
                        ! setState('WeatherSymbol30', temp );
                        ! on("daswetter.0.NextDaysDetailed.2d.1h.SymbolID", function(obj) {
                        ! log (temp);
                        ! setState('WeatherSymbol31', temp );
                        ! on("daswetter.0.NextDaysDetailed.2d.2h.SymbolID", function(obj) {
                        ! log (temp);
                        ! setState('WeatherSymbol32', temp );
                        ! on("daswetter.0.NextDaysDetailed.2d.3h.SymbolID", function(obj) {
                        ! log (temp);
                        ! setState('WeatherSymbol33', temp );
                        ! on("daswetter.0.NextDaysDetailed.2d.4h.SymbolID", function(obj) {
                        ! log (temp);
                        ! setState('WeatherSymbol34', temp );
                        ! on("daswetter.0.NextDaysDetailed.2d.5h.SymbolID", function(obj) {
                        ! log (temp);
                        ! setState('WeatherSymbol35', temp );
                        ! on("daswetter.0.NextDaysDetailed.2d.6h.SymbolID", function(obj) {
                        ! log (temp);
                        ! setState('WeatherSymbol36', temp );
                        ! on("daswetter.0.NextDaysDetailed.2d.7h.SymbolID", function(obj) {
                        ! log (temp);
                        ! setState('WeatherSymbol37', temp );
                        ! on("daswetter.0.NextDaysDetailed.3d.0h.SymbolID", function(obj) {
                        ! log (temp);
                        ! setState('WeatherSymbol40', temp );
                        ! on("daswetter.0.NextDaysDetailed.3d.1h.SymbolID", function(obj) {
                        ! log (temp);
                        ! setState('WeatherSymbol41', temp );
                        ! on("daswetter.0.NextDaysDetailed.3d.2h.SymbolID", function(obj) {
                        ! log (temp);
                        ! setState('WeatherSymbol42', temp );
                        ! on("daswetter.0.NextDaysDetailed.3d.3h.SymbolID", function(obj) {
                        ! log (temp);
                        ! setState('WeatherSymbol43', temp );
                        ! on("daswetter.0.NextDaysDetailed.3d.4h.SymbolID", function(obj) {
                        ! log (temp);
                        ! setState('WeatherSymbol44', temp );
                        ! on("daswetter.0.NextDaysDetailed.3d.5h.SymbolID", function(obj) {
                        ! log (temp);
                        ! setState('WeatherSymbol45', temp );
                        ! on("daswetter.0.NextDaysDetailed.3d.6h.SymbolID", function(obj) {
                        ! log (temp);
                        ! setState('WeatherSymbol46', temp );
                        ! on("daswetter.0.NextDaysDetailed.3d.7h.SymbolID", function(obj) {
                        ! log (temp);
                        ! setState('WeatherSymbol47', temp );
                        ! on("daswetter.0.NextDaysDetailed.4d.0h.SymbolID", function(obj) {
                        ! log (temp);
                        ! setState('WeatherSymbol50', temp );
                        ! on("daswetter.0.NextDaysDetailed.4d.1h.SymbolID", function(obj) {
                        ! log (temp);
                        ! setState('WeatherSymbol51', temp );
                        ! on("daswetter.0.NextDaysDetailed.4d.2h.SymbolID", function(obj) {
                        ! log (temp);
                        ! setState('WeatherSymbol52', temp );
                        ! on("daswetter.0.NextDaysDetailed.4d.3h.SymbolID", function(obj) {
                        ! log (temp);
                        ! setState('WeatherSymbol53', temp );
                        ! on("daswetter.0.NextDaysDetailed.4d.4h.SymbolID", function(obj) {
                        ! log (temp);
                        ! setState('WeatherSymbol54', temp );
                        ! on("daswetter.0.NextDaysDetailed.4d.5h.SymbolID", function(obj) {
                        ! log (temp);
                        ! setState('WeatherSymbol55', temp );
                        ! on("daswetter.0.NextDaysDetailed.4d.6h.SymbolID", function(obj) {
                        ! log (temp);
                        ! setState('WeatherSymbol56', temp );
                        ! on("daswetter.0.NextDaysDetailed.4d.7h.SymbolID", function(obj) {
                        ! log (temp);
                        ! setState('WeatherSymbol57', temp );
                        und die Detailview…
                        detailview.txt `
                        Danke fürs teilen.
                        Ich habe mich mal ein wenig mit der Wetteransicht auseinandergesetzt.
                        Korrigiere mich wenn ich falsch liege aber ich glaube man könnte auf das script verzichten wenn man mit Bindings arbeitet.
                        Ich habe für die Wettericons das "Basic Image " - Widget genommen unf folgendes bei Quelle eingegebn: /daswetter/icons/wetter/{daswetter.0.NextDays.0d.ConditionID}f.png
                        das klappt sowei auch…
                          ` > Hallo,
                          Danke fürs teilen.
                          das klappt sowei auch… `
                          wie soll ich dich korrigieren wenn ich keinen Plan von dem ganzen hier habe :lol: :lol: :lol: :lol:
                          hab es mal getestet , funktioniert 😄 script gelöscht :mrgreen: Danke :mrgreen:
                          Wichtig zu wissen : im VIS Editor wird nichts angezeigt. Erst im Vis sieht man dann das Bild ( hat mich ewig Zeit gekostet bis ich das geblickt habe :roll: )
                            ich habe das ganze noch ein wenig weiter entwickelt…
                            um für jeden Tag eine Detail auskunft zu bekommen habe ich ein Script geschrieben das die entsprechenden Datenpunkte bei click auf detail schreibt schreibt. Dazu muss nur im im button eine dem Tag (0, 1, 2, 3, 4) entsprechender State gesetzt werden. in meinem Fall "javascript.0.Wetter.DayID".
                            und die Widgets in der Detailansicht anpassen...
                            var a = ['hour', 'Temperature', 'Symbol', 'SymbolID', 'Wind', 'Humidity', 'Rain'];
                            for (var x in a) {
                               for (var i = 0; i <= 7; i++) {
                                  var createSt = 'Wetter.Detail.' + a[x] + '.' + i + 'h';
                                  createState(createSt, '');
                            on({id: 'javascript.0.Wetter.DayID'}, function (obj) {
                                var DayID = getState("javascript.0.Wetter.DayID").val;
                                for (var x in a){
                                      getSt = 'daswetter.0.NextDaysDetailed.' + DayID + 'd.' + i + 'h.' + a[x];
                                      var State = getState(getSt).val;
                                      setSt = 'javascript.0.Wetter.Detail.' + a[x] + '.' + i + 'h';
                                      setState(setSt, State);
                            • SmarthomeMF
                              SmarthomeMF last edited by Jey Cee
                              Hallo
                              Mein Wetter View
                                Arnulf last edited by
                                ist "Himel" ein Schreibfehler oder steht das für eine Abkürzung?
                                Gefällt mit übrigens sehr gut. wäre eine bessere Variante als die, die ich gebastelt habe
                                  @Dra_gun:
                                  Wichtig zu wissen : im VIS Editor wird nichts angezeigt. Erst im Vis sieht man dann das Bild ( hat mich ewig Zeit gekostet bis ich das geblickt habe :roll: ) `
                                  leider funktioniert das ganze bei mir in der Android-App nur wenn ich noch http//ipzuiobroker/davor setze.
                                  dann sind die Icon über den Cloudzugang aber nicht mehr sichtbar…
                                  Wie hast Du die Wetterkarten eingebunden?
                                    Torsten81 last edited by
                                    @schittl
                                    Könnte ich eventuell deine Energie View bekommen, wo du die einzelnen Geräte auflistest? Das sieht echt top aus, sowas fehlt mir noch
                                    @vtwo
                                    Deine Vis gefällt mir sehr gut, ist es da eventuell möglich das ganze Projekt zu bekommen?
                                      ltsalvatore last edited by
                                      hi zusammen,
                                      ich habe mal eine grundlegende frage, bevor ich hier weiter mache an mein vis zu basteln, welchen ich abschließend gerne mit der community teilen möchte.
                                      ich besitze folgende endgeräte über die die visualisierung genutzt werden soll:
                                      ipad air im landscape
                                      iphone 6s im portrait
                                      iphone 7 plus im portrait
                                      muss ich nun für jedes endgerät, welches ja eine andere auflösung hat, ein eigenes projekt im vis erstellen und in den entsprechenden projekten die passende auflösung nehmen?
                                      oder reicht es ein vis zu erstellen, und dieses dann responsive gestalten? wenn ja, wie ist dies realisierbar?
                                      danke und gruß
                                        schittl last edited by Jey Cee
                                        @Torsten81:
                                        Könnte ich eventuell deine Energie View bekommen, wo du die einzelnen Geräte auflistest? Das sieht echt top aus, sowas fehlt mir noch `
                                        Natürlich… Hier mal ein Energie-Komplettwidget einer Steckdose für mein Aquarium...
                                        [{"tpl":"tplHtml","data":{"visibility-cond":"==","visibility-val":1,"refreshInterval":"0","html":"","comment":"","visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"706px","top":"305px","width":"298px","height":"215px","color":"#ffffff","text-align":"center","font-family":"RobotoCondensed-Light","font-style":"","font-variant":"normal","font-weight":"400","font-size":"18px","background":"#2e353d","padding":"","z-index":"0","line-height":"24px","box-shadow":"","opacity":""},"widgetSet":"basic"},{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"Aquarium Bad"},"style":{"left":"726px","top":"313px","width":"160px","height":"25px","color":"#787d83","font-size":"20px","font-family":"RobotoCondensed-Light","line-height":"25px"},"widgetSet":"basic"},{"tpl":"tplContainerIconDialog","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"src":"/icons-material-png/action/ic_assessment_white_48dp.png","setId":"javascript.0.VIS.Energie.ZeigeGraphNr","setValue":"1","contains_view":"cardFlotEnergie","noHeader":true,"dialog_width":"100%","dialog_height":"500","dialog_top":"0","dialog_left":"0","class":"mdui-flatbutton","filterkey":"","comment":"","invert_icon":false},"style":{"left":"897px","top":"313px","z-index":"","width":"30px","height":"30px","opacity":"0.8"},"widgetSet":"jqui"},{"tpl":"tplValueBool","data":{"oid":"hm-rpc.0.OEQXXXXXXX.0.UPDATE_PENDING","g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_true":"![](\"/icons-material-png/action/ic_info_white_48dp.png\")","html_false":"![](\"/icons-material-png/action/ic_info_white_48dp.png\")","class":"mdui-state","filterkey":"","comment":""},"style":{"left":"931px","top":"313px","width":"30px","height":"30px","border-radius":"","border-width":"","border-color":"","position":"","z-index":"1","opacity":"0.8"},"widgetSet":"basic"},{"tpl":"tplValueBool","data":{"oid":"hm-rpc.0.OEQXXXXXXX.0.UNREACH","g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":true,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html_true":"![](\"/icons-material-png/notification/ic_wifi_white_48dp.png\")","html_false":"![](\"/icons-material-png/notification/ic_wifi_white_48dp.png\")","class":"mdui-state","filterkey":"","comment":""},"style":{"left":"965px","top":"313px","width":"30px","height":"30px","border-radius":"","border-width":"","border-color":"","position":"","z-index":"1","opacity":"0.8"},"widgetSet":"basic"},{"tpl":"tplValueBoolCheckbox","data":{"oid":"hm-rpc.0.OEQXXXXXXX.1.STATE","g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"html_append":"<label for="\&quot;w00508_checkbox\&quot;"><label>","class":"mdui-switch mdui-blue-acc","lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"filterkey":""},"style":{"left":"943px","top":"366px","width":"48px","height":"16px","z-index":1},"widgetSet":"basic"},{"tpl":"tplValueFloatBar","data":{"oid":"hm-rpc.0.OEQXXXXXXX.2.POWER","g_fixed":true,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","min":"0","max":"500","orientation":"horizontal","color":"{v:hm-rpc.0.OEQXXXXXXX.2.POWER;v < 150 ? \"#4CAF50\" :: v < 300 ? \"#FFEB3B\" :: \"#F44336\"}","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"reverse":false,"class":"mdui-bargraph mdui-ramp","border":"","lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"726px","top":"342px","width":"100px","height":"15px","z-index":2},"widgetSet":"basic"},{"tpl":"tplValueFloat","data":{"hm_id":"1940","digits":"2","factor":"","min":0,"max":1,"step":0.01,"is_comma":false,"filterkey":"","html_append_singular":" W","html_append_plural":" W","hm_id_state":"","visibility-cond":"==","visibility-val":1,"oid":"hm-rpc.0.OEQXXXXXXX.2.POWER","gestures-offsetX":0,"gestures-offsetY":0,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"visibility-groups-action":"hide","is_tdp":"false","lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"locked":false,"comment":""},"style":{"left":"835px","top":"342px","text-shadow":"","color":"{v:hm-rpc.0.OEQXXXXXXX.2.POWER;v < 150 ? \"#4CAF50\" :: v < 300 ? \"#FFEB3B\" :: \"#F44336\"}","width":"60px","height":"18px","font-size":"small","font-family":"RobotoCondensed-Light","text-align":"left","z-index":"5","line-height":"18px"},"widgetSet":"basic"},{"tpl":"tplHtml","data":{"g_fixed":true,"g_visibility":false,"g_css_font_text":true,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"10000","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"html":"\n  \n    \n      \n      \n      \n    \n  \n  \n    \n      \n      \n      \n    \n    \n      \n      \n      \n    \n    \n      \n      \n      \n    \n    \n      \n      \n      \n    \n    \n      \n      \n      \n    \n  \n
                                        >! | Laufzeit | Verbrauch | Kosten |
                                        | Heute | {javascript.0.Strom.SteckdoseAquariumBadMess..Verbrauch.Tag} kW/h | {javascript.0.Strom.SteckdoseAquariumBadMess..Kosten.Tag} € |
                                        | Woche | {javascript.0.Strom.SteckdoseAquariumBadMess..Verbrauch.Woche} kW/h | {javascript.0.Strom.SteckdoseAquariumBadMess..Kosten.Woche} € |
                                        | Monat | {javascript.0.Strom.SteckdoseAquariumBadMess..Verbrauch.Monat} kW/h | {javascript.0.Strom.SteckdoseAquariumBadMess..Kosten.Monat} € |
                                        | Quartal | {javascript.0.Strom.SteckdoseAquariumBadMess..Verbrauch.Quartal} kW/h | {javascript.0.Strom.SteckdoseAquariumBadMess..Kosten.Quartal} € |
                                        | Jahr | {javascript.0.Strom.SteckdoseAquariumBadMess..Verbrauch.Jahr} kW/h | {javascript.0.Strom.SteckdoseAquariumBadMess..Kosten.Jahr} € |
                                        >! ","class":"mdui-table mdui-table-striped","lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"filterkey":"","locked":false},"style":{"left":"726px","top":"389px","width":"265px","height":"120px","overflow-y":"","font-size":"small","font-style":"","font-family":"RobotoCondensed-Light","opacity":"0.7","z-index":"5"},"widgetSet":"basic"}]</label></label>
                                          @schittl:
                                          @Torsten81:
                                          Natürlich… Hier mal ein Energie-Komplettwidget einer Steckdose für mein Aquarium... `
                                          gäbe es auch die möglichkeit, dein komplettes projekt zu exportieren und als download zur verfügung zu stellen? das sieht nämlich richtig gut aus 8-)
                                            Da aktuell der Export anonymized nicht funktioniert (VIS 1.1.2 und iobroker.pro) kann ich dieses leider nicht tun. Ich versuche aber die Tage das Projekt mal auf https://iobroker.click/ zu laden. Da hat dann jeder etwas davon 🙂
                                            @ltsalvatore:
                                            oder reicht es ein vis zu erstellen, und dieses dann responsive gestalten? wenn ja, wie ist dies realisierbar? `
                                            Ich habe für jedes mobile Endgerät eine eigene View erstellt (iPhone & iPad).
                                            916
                                            422534
