    4. [Vorlage] Spotify Skript
      web4wasch last edited by
      @twonky:
      @mikiline und @web4wasch: Welche Admin Version benutzt ihr? 2 oder 3? `
      ich nutze 3.4.3 - die version 0.1.x hatte ich ich auch schon unter der 3'er laufen.
        mikiline last edited by
        @twonky:
        @mikiline: Wegen deiner ListBox. Guck doch mal auf https://github.com/twonky4/ioBroker.spotify-premium da habe ich gestern Beispiele hinzugefügt.
        [{"tpl":"tplJquiSelectList","data":{"oid":"spotify-premium.0.playbackInfo.playlist.trackList","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","values":"{spotify-premium.0.playbackInfo.playlist.trackListNumber}","texts":"{spotify-premium.0.playbackInfo.playlist.trackListString}","height":"100","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0},"style":{"left":"505px","top":"369px"},"widgetSet":"jqui"}]
        Super, Danke…..habe in dem Fall den falschen Datenpunkt genommen....
        Adminversion siehe Screenshot
        @twonky
        was jetzt nicht ganz 100% ist, ist das die Liste alle 5 Sekunden (da Intervall so eingestellt) aktualisiert wird. Das schliesst dann die Auswahlliste und man muss erneut klicken.
        Muss man schnell sein beim Tracks durchsuchen 🙂
        • twonky
          twonky last edited by
          Ich habe mal einen Screencap angehängt, wie bei mir die Anmeldung aussieht. Einfach drauf klicken zum ansehen.
          mikiline@ Das Refresh ist mir auch schon aufgefallen. Wenn du den Interval auf 15 hoch stellst hast du mehr Zeit 😉 Ich kümmere mich demnächst drum.
            hallo twonky….
            gleiches prozedere wie in deinem sreencap, nur kein Ergebnis...
            • Mic
              Mic Developer last edited by
              So, hab die 0.2.1 in Betrieb, läuft super.
              Ich habe hier noch eine Frage zur Logik bezüglich dem Abspielen von Playlisten:
              Ich wähle mit Alexa eine Spotify-Playlist aus (hierzu im Cloud-Adapter eine Lampe definiert, und "Alexa, Spotify auf 7%" spielt meine Playliste Nr. 7 ab). Diese wird dann auch durch den Spotify-Adapter schön abgespielt. Damit die Playlisten nicht immer mit dem selben Song und im Shuffle starten, behelfe ich mir wie folgt:
              function global_m_Spotify_Playlist (strPlaylistID, strPlaylistName, intDelayInMilliseconds) {
                  setTimeout(function() {
                      setStateDelayed(strPlaylistID, true, 0, false);
                      setStateDelayed("spotify-premium.0.player.shuffleOn", true, 1500, false); // Delay ist nötig, damit Shuffle greift
                      setStateDelayed("spotify-premium.0.player.skipPlus", true, 2500, false);
                      setStateDelayed("spotify-premium.0.devices.Überall.useForPlayback", true, 1000, false);
                      g_myLog("Spotify Playlist '" + strPlaylistName + "' wird abgespielt");
                  }, intDelayInMilliseconds);
              Die Idee dahinter:
              1.) erst mal Playliste setzen
              2.) dann Shuffle einschalten (Delay von 1500 ist notwendig, wenn kleiner, dann geht Shuffle wieder aus)
              3.) nun einen Track weiter, damit Shuffle greift
              4.) zum Schluss noch Überall-Gruppe zum Playback verwenden.
              Das geht auch so wunderbar, aber ist natürlich ein ziemlicher Workaround mit Shuffle und ein Song weiter. Soll das so sein, oder geht es einfacher, dass eine Playliste automatisch im "Shuffle" gestartet wird?
              • twonky
                Ich habe nun mal den admin v3.4.1 - v3.4.3 getestet. Diese habwn wirklich einen Bug beim kopieren von URLs (& Zeichen). Ich habe dafür das Ticket #268 angelegt. Ich kann soviel sagen das der admin v3.4.0 noch funktioniert.
                  @twonky:
                  Ich habe nun mal den admin v3.4.1 - v3.4.3 getestet. Dieser hat wirklich einen Bug beim kopieren von URLs (& Zeichen). Ich habe dafür das Ticket #268 angelegt. Ich kann soviel sagen das der admin v3.4.0 noch funktioniert. `
                  Alles klar, dann ist da wieder demnächst was behoben.
                  Zum aktualisieren der Playlist…....die Werte brauchen ja nur aktualisiert werden wenn sich der Datenpunkt zum Abspielen ändert (spotify-premium.0.playbackInfo.playlist.id)
                  Ist es möglich auch Albeninformationen zu hinterlegen (Prinzip wie die Playlist, das die enthaltenen Lieder aus einem Album ausgelesen werden)
                  Am Besten im gleichen Format wie die Playlist (um später auch wieder Tracks auswählen zu können)
                  Und hier mal ein fettes DANKE für Deine Arbeit (auch für die schnelle Reaktion)
                    @twonky: heißt? Ich sollte den admin downgraden und ausführen und dann admin wieder upgrade…
                    Danke für die Info.
                    • twonky
                      @web4wasch: Nein musst du nicht. Du kannst auch alle 4 "&" durch "&" ersetzen.
                      @mikiline: Das Problem mit der Auswahlbox ist in Version 0.2.2 behoben.
                      Ich habe später vor auch Album, Artist und Tracklist infos zu laden und entsprechend auch in ein Context info zusammen zufassen. Das braucht aber etwas Zeit.
                      • lobomau
                        lobomau last edited by
                        @web4wasch:
                        Danke für die Info. `
                        Ich habe folgendes workaround gemacht:
                        authorizationURL auf "Schreiben erlauben" ändern. Dann wenn die URL erscheint, diese auswählen und mit Strg-C kopieren und in Browser String-V eintragen. So umgehst du die Copy-Funktion des admins.
                        • twonky
                          @Mic: Was hast du genau vor? Der Shuffle Status bliebt doch wir er war, egal ob ich einen anderen Track oder Playliste auswähle. Also wenn Shuffle an ist und du einen Track aus einer Playliste auswählst spielt diese Liste auch im Shuffle.
                          @lobomau: Nicht nur die Copy-Funktion sondern auch das Edit-Fenster ist kaputt.
                          • lobomau
                            @twonky:
                            @lobomau: Nicht nur die Copy-Funktion sondern auch das Edit-Fenster ist kaputt. `
                            OK. Aus irgendeinem Grund hat es so funktioniert. Ich hatte den Adapter neu installiert, alle Objekte gelöscht. Nun ist alles wieder da. Autorisierung auf true. Admin ist 3.4.3.
                              @twonky: danke dir, war schneller… kann ich nur bestätigen, unter admin 3.4.0 läuft es wie geschmiert. 😉
                              • X
                                xmace last edited by
                                @lobomau:
                                @web4wasch:
                                authorizationURL auf "Schreiben erlauben" ändern. Dann wenn die URL erscheint, diese auswählen und mit Strg-C kopieren und in Browser String-V eintragen. So umgehst du die Copy-Funktion des admins. `
                                vielen dank für den tipp! :thumbsupp:
                                • Mic
                                  @twonky:
                                  @Mic: Was hast du genau vor? Der Shuffle Status bliebt doch wir er war, egal ob ich einen anderen Track oder Playliste auswähle. Also wenn Shuffle an ist und du einen Track aus einer Playliste auswählst spielt diese Liste auch im Shuffle. `
                                  Leider nicht ganz, also:
                                  Angenommen ich spiele mittels TuneIn (Amazon Alexa) Musik auf der Überall-Gruppe von Alexa. Dann drücke ich den Button "spotify-premium.0.player.shuffleOn". Dadurch schaltet "spotify-premium.0.player.shuffle" auf "On(on)". Wenn ich nun eine Playliste starte mit Button, z.B. "spotify-premium.0.playlists.BillboardHot100.playThisList", dann startet diese immer mit dem ersten Song und "spotify-premium.0.player.shuffle" schaltet automatisch auf "Off(off)".
                                  Deswegen mache ich den oben genannten Workaround (Playliste starten, Shuffle zeitverzögert Einschalten, dann zeitverzögert nächster Track), damit die Playliste immer im Shuffle startet und nicht mit dem ersten Song.
                                    schubi82 last edited by
                                    Kann ich mir eine Trackliste auch dauerhaft anzeigen lassen und idealerweise auch Tracks daraus auswählen?
                                    • Mic
                                      Ich hätte noch ein Feature Request 🙂 :
                                      Per Knopfdruck den aktuell abgespielten Song auf eine in einem Datenpunkt hinterlegte Playliste setzen.
                                      Ich habe mir das mal per curl angesehen, das hier ist wohl das Kommando(?):
                                      Wäre cool, wenn Du Dir das mal ansehen könntest, vielen Dank.
                                      • twonky
                                        @schubi82: Hier habe ich dir ein Skript zusammen gebastelt womit du das lösen kannst. Das Design musst du natürlich an deine Bedürfnisse anpassen.
                                        `createState('javascript.0.spotify-premium.trackListHtml', '', false);
                                        function refreshTrackList() {
                                        	var current = getState('spotify-premium.0.playbackInfo.playlist.trackList').val;
                                        	var source = getState('spotify-premium.0.playbackInfo.playlist.trackListArray').val;
                                        	var html = '';
                                        	for (var i = 0; i < source.length; i++) {
                                        		html += '';
                                        		html += '';
                                        		html += '';
                                        		html += '';
                                        	html += '
                                        		if(current == i) html += '**';
                                        		html += source[i].artist;
                                        		html += ' | ';
                                        		html += source[i].title;
                                        		html += ' |
                                        	setState('javascript.0.spotify-premium.trackListHtml', html, true);
                                        on('spotify-premium.0.playbackInfo.playlist.trackList', refreshTrackList);
                                        on('spotify-premium.0.playbackInfo.playlist.trackListArray', refreshTrackList);
                                        refreshTrackList();
                                        // [{"tpl":"tplHtml","data":{"g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","refreshInterval":"0","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"html":"{javascript.0.spotify-premium.trackListHtml}"},"style":{"left":"669px","top":"207px","width":"303px","height":"454px"},"widgetSet":"basic"}]`
                                        @Mic: Mir klingt das zu sehr nach spezial Fall um es in den Adapter einzubauen. Ich habe aber gerade mal versucht ein Skript zu basteln was genau das macht, was du möchtest. Da der spotify-premium Adapter aber nicht die Berechtigungen "playlist-modify-public" und/oder "playlist-modify-private" hat, klappt das leider nicht. Und ich möchte ungerne Berechtigungen bei allen Usern abfragen, die eigentlich nicht gebraucht werden. Ich schreibe mir das aber mal als Feature Request auf.
                                        Was die Sache mit dem Shuffle angeht: Ich benutze leider kein tuneln. Kriegst du den Fall auch rein mit Spotify hin? Wenn ich bei mir Was abspiele, dann shuffle auf On stelle und playThisList aufrufe bleibt shuffle nämlich auf On.  :([/i][/i]
                                        • Mic
                                          @twonky:
                                          @Mic: Mir klingt das zu sehr nach spezial Fall um es in den Adapter einzubauen. Ich habe aber gerade mal versucht ein Skript zu basteln was genau das macht, was du möchtest. Da der spotify-premium Adapter aber nicht die Berechtigungen "playlist-modify-public" und/oder "playlist-modify-private" hat, klappt das leider nicht. Und ich möchte ungerne Berechtigungen bei allen Usern abfragen, die eigentlich nicht gebraucht werden. Ich schreibe mir das aber mal als Feature Request auf. `
                                          Vielen Dank twonky. Nun, der Use Case ist, dass Spotify quasi als "Shazam" agiert (ok, nicht ganz, man sieht ja sieht was gerade gespielt wird) und das aktuelle Lied bei Gefallen auf eine Favoriten-Playliste setzt. Aber verstehe, dass das rechte-technisch wohl nicht so einfach geht…
                                          @twonky:
                                          Was die Sache mit dem Shuffle angeht: Ich benutze leider kein tuneln. Kriegst du den Fall auch rein mit Spotify hin? Wenn ich bei mir Was abspiele, dann shuffle auf On stelle und playThisList aufrufe bleibt shuffle nämlich auf On. 😞 `
                                          Das ist echt interessant. Hier mal zum reproduzieren ganz ohne TuneIn und nur mit Spotify, ich mache alles im ioBroker:
                                          1.) Ich klicke auf Button spotify-premium.0.playlists.XYZ-Playlist-A.playThisList
                                          2.) Ich klicke auf spotify-premium.0.player.shuffleOn –> Shuffle ist nun ON (State spotify-premium.0.player.shuffle)
                                          3.) Ich klicke auf Button spotify-premium.0.playlists.XYZ-Playlist-B.playThisList –> Shuffle geht auf OFF.
                                          Grundsätzlich kann das ja ein Soptify-Feature sein, dass beim Wechseln einer Playliste Shuffle immer wieder aus geht; dank ioBroker und deinem Adapter eh kein Problem und ich setze halt den shuffle-State dann einfach zusätzlich per Javascript 8-)
                                          • twonky
                                            @Mic: Shazam kenne ich wiederum auch nicht :?
                                            Ich habe dein Shuffle Workflow mal durchgespielt. Bei mir bleibt das Shuffel am Ende auf On und wechselt nicht zu Off :shock: Vielleicht ist das Geräte Konfiguration, mit was für ein Gerät passiert dir das?
                                            javascript
                                            95
                                            745
                                            262414
