    5. Bewegungsmelder blockly
      knopers1 last edited by
      Danke für deine Hilfe!
      Ist es so i.O?
       <xml xmlns="http://www.w3.org/1999/xhtml"><block type="on_ext" id="zBkZB8ijuy}8jed3+y8+" x="-437" y="-37"><mutation items="1"></mutation>
          <value name="OID0"><shadow type="field_oid" id="tO[d(C?x:r{3EYzS8*|I"><field name="oid">rflink.0.channels.Eurodomest_2.SWITCH_05</field></shadow></value>
          <statement name="STATEMENT"><block type="debug" id="UYWy~9fb1C8F=++V?G)_"><field name="Severity">log</field>
              <value name="TEXT"><shadow type="text" id="XNYH^r(Ru~24vhOLTwAq"><field name="TEXT">Bewegung Küche erkannt.</field></shadow></value>
              <next><block type="controls_if" id="=~*uGJ2^k@}2pGW8ioG("><value name="IF0"><block type="logic_compare" id="MzmVRpO}C95Ik1~D1n~b"><field name="OP">LT</field>
                      <value name="A"><block type="get_value" id="7;7#~]XTS%8e^(x8/wZS"><field name="ATTR">val</field>
                          <field name="OID">hm-rpc.0.LEQ0240879.1.BRIGHTNESS</field></block></value>
                      <value name="B"><block type="math_number" id="IoLBjb4QA|i|p{e_|Cy%"><field name="NUM">200</field></block></value></block></value>
                  <statement name="DO0"><block type="debug" id="CivfHpdM~@.)pF0Ba`bF"><field name="Severity">log</field>
                      <value name="TEXT"><shadow type="text" id="{glbtY/i:uXZJt@bztbh"><field name="TEXT">Lampe Einschalten</field></shadow></value>
                      <next><block type="timeouts_cleartimeout" id="YihiGR+F6WhCE^yaUqWi"><field name="NAME">timeout</field>
                          <next><block type="control" id="rfS#FPojQg-yU0e:;dIy"><mutation delay_input="false"></mutation>
                              <field name="OID">sonoff.0.Sonoff-Dimmer1.POWER</field>
                              <value name="VALUE"><block type="logic_boolean" id="REEAcX?9l/:{F0_qO+K3"><field name="BOOL">TRUE</field></block></value>
                              <next><block type="control" id=")3M*.KOZTKdD/[)xwP]M"><mutation delay_input="false"></mutation>
                                  <field name="OID">sonoff.0.Sonoff-Dimmer1.Dimmer</field>
                                  <value name="VALUE"><block type="math_number" id="rE#D*=,;*B6g3|stV)=}"><field name="NUM">100</field></block></value>
                                  <next><block type="debug" id="(l;K]W*tQemk3hv%!Bi]"><field name="Severity">log</field>
                                      <value name="TEXT"><shadow type="text" id=";*~GDy=l-Ea:u+eSj}dP"><field name="TEXT">3</field></shadow></value>
                                      <next><block type="timeouts_settimeout" id="6w^hCzjF@b}a==Va@.PR"><field name="NAME">timeout</field>
                                          <field name="DELAY">20</field>
                                          <statement name="STATEMENT"><block type="control" id="l[g1cNgy^|XxH?ny2o;U"><mutation delay_input="false"></mutation>
                                              <value name="VALUE"><block type="logic_boolean" id="Xc:4/vVhw%cS*ghQY^:w"><field name="BOOL">FALSE</field></block></value></block></statement></block></next></block></next></block></next></block></next></block></next></block></statement>
                  <next><block type="timeouts_cleartimeout" id="f!LTX-V:9_qvP!MI_d}s"><field name="NAME">timeout</field></block></next></block></next></block></statement></block></xml>
      • Dutchman
        Fast, der Stop timeout ist richtig aber das ausführen muss da drunter !
        Send from mobile device
          Du meinst es sicherlich so oder?
          • Dutchman
            @knopers1:
            Du meinst es sicherlich so oder? `
            wie mein vadder immer sagte : Grüüüüüünnnnaaauuuuuu :mrgreen:
            damit wird dieser letzte Baustein jetzt ausserhalb deiner IF immer getigert und resettet den timer wie es sein soll.
            Nachteil jetzt, dieses schalte Lampe aus commando wird immer gesendet, also auch wen die Lampe nicht an ist und Bewegung erkannt wird.
            Das könnte man noch mit ner IF-Abfragen
            ~Dutch
              ja :mrgreen: , habe noch die IF Abfrage der Lampe dazu gebastelt. Danke Dir, jetzt zumindest geht mir das Licht nicht aus/an, wenn ich in der Küche
              am Werkeln bin. Dies ging mir schon so ziemlich auf den Sack!
                ltsalvatore last edited by
                hey leute,
                ich würde auch gerne einen bewegungsmelder für das einschalten der leds in der küche benutzen;
                welche hardware habt ihr bei euch in nutzung?
                  Flauschi last edited by
                  Xiaomi Bewegungsmelder und/oder HM-Sen-MDIR-WM55
                    HM-Sen-MDIR-WM55 und ein BM KERUI aus China über den RFLink-Adapter angebunden.
                      @Flauschi:
                      Xiaomi Bewegungsmelder und/oder HM-Sen-MDIR-WM55 `
                      meinst du den hier: Xiaomi Aqara Human Body Sensor
                      wenn ja, brauch ich dafür noch zusätzliche hardware, um den sensor über den iobroker zu steuern?
                      der von Homematic ist auch interssant, aber kostet wieder das dreifache..
                        @ltsalvatore:
                        wenn ja, brauch ich dafür noch zusätzliche hardware, um den sensor über den iobroker zu steuern? `
                        jop der isses…man braucht dazu noch ein Gateway (welches man mit ioBroker koppelt) und dann die Sensoren als reine Objekte hat
                          @Flauschi:
                          @ltsalvatore:
                          jop der isses…man braucht dazu noch ein Gateway (welches man mit ioBroker koppelt) und dann die Sensoren als reine Objekte hat `
                          OK danke.
                          gibt es davon eigentlich auch Sensoren für Fenster?
                          für den Winter müsste ich noch Fenster Sensoren kaufen, und die von Homematic für meine CCU sind ein Tick zu teuer, finde ich.
                          deshalb wäre es natürlich optimal, wenn ich von dem gleichen Hersteller beide Geräte erwerben könnte.
                          würde nämlich schon versuchen wollen so wenig unterschiedliche Hersteller wie möglich zu betreiben.
                            https://www.gearbest.com/alarm-systems/pp_659226.html?wid=1433363
                            https://www.gearbest.com/access-control/pp_626702.html?wid=1433363
                            https://www.gearbest.com/access-control/pp_626703.html?wid=1433363
                            https://www.gearbest.com/Aqara-_gear/
                            beim Gateway würde ich auf Angebote warten…da habe ich meins für um die 18$ gekauft
                              @Flauschi:
                              beim Gateway würde ich auf Angebote warten…da habe ich meins für um die 18$ gekauft `
                              cool, danke.. da ich ja bereits ein xiaomi vacuum besitze, macht es ja "sinn" weitere geräte von apple.. ähm.. xiaomi zu implementieren/benutzen.
                              bei gateway gehe ich mal davon aus, dass es für alle xiaomi geräte nur ein gateway gibt.. und zwar den hier:
                              https://www.ebay.de/itm/Xiaomi-Smart-Ho … XjCS40JSRw
                              oder gibt es auch dort unterschiedliche gateways?
                                jop das ist es.
                                es gibt es nur mit China Plug und man benötigt einen Adapter…
                                es gibt noch ein altes glaub ich, das ist aber das aktuelle, welches Du geposted hast.
                                  @Flauschi:
                                  jop das ist es.
                                  es gibt noch ein altes glaub ich, das ist aber das aktuelle, welches Du geposted hast. `
                                  hab ich doch jetzt richtig verstanden,
                                  das was ich gepostet habe, das ist das aktuelle, welches für meine zwecke das richtige ist.
                                  dann gibt es das doch auch als EU version, so wie ich das sehe. oder hab ich da was missverstanden?
                                    da wird nur ein Adapter mit bei sein…
                                    meines Wissens gibts das nativ nur mit China Plug
                                      ah ok, gut, das kann natürlich sein…
                                      dann passt das ja... dann würde ich das bestellen 😛
                                      danke nochmal für die schnelle rückmeldung
                                      • MathiasJ
                                        MathiasJ last edited by
                                        Ich habe nun auch die Bewegungsmelder von Xiaomi bestellt.
                                        Ich habe nur auf der Raspberrymatic ein paar SysVar angelegt.
                                        Diese SysVar werden mittels Blockly "gefüttert".
                                        Mein erster Eindruck: die Bewegungsmelder sind der Hammer! Bewegung wird gleich erkannt und auch auf den Variablen angezeigt.
                                        Ich laufe nun ein paar Tests durch, weil in der CCU-Alarmanlage alle Bewegungsmelder-Variablen auf "keine Bewegung" gesetzt werden, wenn ich scharf schalte.
                                        Ich hoffe nur, dass die Xiaomi jetzt nicht prellen und nach dem scharf schalten eine Bewegung melden.
                                        Sonst bekomme ich eine Mitteilung, dass eine Bewegung erkannt wurde.
                                        Sollten sich die Bewegungsmelder bewähren, werden sie komplett in die Programme übernommen. Das zurücksetzen der Variablen führe ich auch mit den originalen HM-Bewegungsmeldern durch und kann hier nur gutes berichten.
                                        Gruß,
                                        Mathias
                                        Gesendet von meinem SM-N915FY mit Tapatalk
                                          @MathiasJ:
                                          Gruß,
                                          Mathias
                                          Gesendet von meinem SM-N915FY mit Tapatalk `
                                          worüber hast du die bestellt?
                                          • MathiasJ
                                            Ich habe 4 Stück bei Aliexpress bestellt.
                                            Kaufe aber von 2 verschiedenen Händlern, wenn Du auch mehrere willst, sonst schlägt der Zoll zu.
                                            *** UPDATE ***
                                            Da die Teile anscheinend doch prellen, muß die Scharfschaltung zeitverzögert erfolgen.
                                            Ich füttere die SysVar per Blockly.
                                            Das Alarmprogramm selbst schreibe ich in der CCU2/Raspberrymatic/piVCCU/YAHM
                                            Die Scharfschaltung muß 10 sec zeitverzögert erfolgen. Die SysVar mi-Bewegungsmelder muß SOFORT auf keine Bewegung zurückgesetzt werden.
                                            Gruß,
                                            Mathias
                                            blockly
                                            15
                                            117
                                            26155
